    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    • Merlin123
      Merlin123 @Lucky_ESA last edited by
      @lucky_esa Das kam raus:
      homeconnect.0
      2025-08-14 10:15:46.660	error	{"error":{"description":"The rate limit \"5 stop program calls in 1 minute\" was reached. Requests are blocked during the remaining period of 55 seconds.","key":"429"}}
      homeconnect.0
      2025-08-14 10:15:46.659	error	AxiosError: Request failed with status code 429
      homeconnect.0
      2025-08-14 10:15:46.589	debug	homeconnect.0.464040536427032105.commands.BSH_Common_Command_StopProgram true
      homeconnect.0
      2025-08-14 10:15:45.644	error	{"error":{"description":"RemoteStart is not enabled","key":"BSH.Common.Error.RemoteStartNotActive"}}
      homeconnect.0
      2025-08-14 10:15:45.644	error	AxiosError: Request failed with status code 409
      homeconnect.0
      2025-08-14 10:15:45.588	debug	homeconnect.0.464040536427032105.commands.BSH_Common_Command_StopProgram true
      homeconnect.0
      2025-08-14 10:15:44.652	error	{"error":{"description":"RemoteStart is not enabled","key":"BSH.Common.Error.RemoteStartNotActive"}}
      homeconnect.0
      2025-08-14 10:15:44.652	error	AxiosError: Request failed with status code 409
      homeconnect.0
      2025-08-14 10:15:44.587	debug	homeconnect.0.464040536427032105.commands.BSH_Common_Command_StopProgram true
      homeconnect.0
      2025-08-14 10:15:43.679	error	{"error":{"description":"RemoteStart is not enabled","key":"BSH.Common.Error.RemoteStartNotActive"}}
      homeconnect.0
      2025-08-14 10:15:43.678	error	AxiosError: Request failed with status code 409
      homeconnect.0
      2025-08-14 10:15:43.599	debug	homeconnect.0.BOSCH-WAYH2842-68A40E2AA61D.commands.BSH_Common_Command_StopProgram true
      homeconnect.0
      2025-08-14 10:15:42.653	error	{"error":{"description":"RemoteStart is not enabled","key":"BSH.Common.Error.RemoteStartNotActive"}}
      homeconnect.0
      2025-08-14 10:15:42.652	error	AxiosError: Request failed with status code 409
      homeconnect.0
      2025-08-14 10:15:42.586	debug	homeconnect.0.BOSCH-WAYH2842-68A40E2AA61D.commands.BSH_Common_Command_StopProgram true
      homeconnect.0
      2025-08-14 10:15:41.704	error	{"error":{"description":"RemoteStart is not enabled","key":"BSH.Common.Error.RemoteStartNotActive"}}
      homeconnect.0
      2025-08-14 10:15:41.704	error	AxiosError: Request failed with status code 409
      homeconnect.0
      2025-08-14 10:15:41.628	debug	homeconnect.0.BOSCH-WAYH2842-68A40E2AA61D.commands.BSH_Common_Command_StopProgram true
        Lucky_ESA Developer Most Active @Merlin123 last edited by
        @merlin123 Vielen Dank. Unglaublich dass das Rate Limit nicht per Device ist. Wenn man mehr als 3 Geräte hat wird man dazu gezwungen, sich einen anderen Account anzulegen und die Geräte aufteilt.
        Gruß//Lucky
        • Merlin123
          @lucky_esa ich hab genau drei, die auch ne Zeit liefen... Nur jetzt geht das eine halt nicht mehr
            @merlin123 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
            Ich zitiere mal @arteck da hat ein Programmierer was kaputtoptimmiert.. kann auch sein.-
            Gruß//Lucky
            • Merlin123
              @lucky_esa Klar. Wäre nur interessant, ob man rausfindet, was da anders ist. Ich hab ja mit dem Cloudless Adapter ne Alternative, trotzdem irgendwie schade.
              R arteck 2 Replies Last reply Reply Quote 0
                RISSN @Merlin123 last edited by
                @merlin123 warum ist der Cloudless Adapter eine Alternative? Der sollte doch erste Wahl sein, immerhin brauche ich keine Internetverbindung und der funktioniert einfach super. Als der Adapter kam, habe ich nicht lange überlegt, sondern habe umgestellt.
                  arteck Developer Most Active @Merlin123 last edited by
                  @merlin123 alles was lokal läuft ist 1000 besser als die abhängigkeit von der Cloud.. es gibt auch kein Vorteil von einer Cloudlösung ausser es gibt keine lokale..
                  • Ro75
                    Ro75 last edited by Ro75
                    Ich habe wieder mal etwas für die Visualisierung gebastelt. Vielleicht kann es ja einer gebrauchen.
                    oder diese hier
                    Ro75.
                    1 Reply Last reply Reply Quote 6
                      Lucky_ESA Developer Most Active last edited by
                      es gibt für latest User ein neues Release 1.5.0.
                      Hier nun einige wichtige Infos zu den neuen Funktionen.
                      In der Instanz-Einstellung könnt ihr eure Sprache auswählen. Die Objekt werden dann in der ausgewählten Sprache angelegt (Name vom Objekt)
                      Alle Objekte werden nun mit den richtigen Roles und Types angelegt. Die Device Objekte werden nun auch richtig angelegt. Erkennt man daran, dass diese jetzt editierbar sind
                      Der Adapter kann nun mit dem Rate Limiting umgehen. Beispiel 50 Request in 10 Minuten: Hier blockiert der Adapter ab dem 49 Request für die Restzeit. Sonst wurde man immer für 10 Minuten gesperrt. Die 5 Start Requests konnte ich nur für den Geschirrspüler implementieren da ich nicht weiß, was die mit Start meinen?! Vielleicht kann mir da mal jemand helfen. Die JSON`s von den 2 Rates sind in der Anleitung beschrieben. Kann man sich in VIS anzeigen lassen. Die Teit ist ein ISO String OHNE Zeitzone.
                      Das Token Limit kann man nur erreichen, wenn der Adapter in einer Reboot-Schleife ist.
                      Zusätzlich Infos:
                      Die Objekte unter Events werden nur angelegt wenn diese ausgelöst werden. Das Geräte muss dazu eingeschaltet sein.
                      Es werden nicht immer alle Programme angezeigt. Einige erscheinen erst wenn diese in der APP ausgewählt werden....Das ist echt lächerlich von HomeConnect...
                      Fehler können gerne hier angesprochen werden.
                      Gruß//Lucky
                      Bernd1967 1 Reply Last reply Reply Quote 1
                      • Bernd1967
                        Bernd1967 @Lucky_ESA last edited by Bernd1967
                        @lucky_esa sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                        Super, bin mal gespannt was Rate Limit dann so anzeigt.
                        Ich denke das ist wörtlich zu nehmen, man darf nur 5X pro Minute die Maschine starten.
                        Warum nicht die Waschmaschine ?
                        Nachtrag:
                        Was mir noch auffällt:
                        Beim Datenpunkt "homeconnect.0.rateLimit.limitJson" geht die Zeilenanzahl bei nur paar Versuchen sehr schnell hoch durch die gespeicherten "requests".
                        Sollte man das vielleicht abschaltbar machen ?
                        P.S.: Einmal Adater neu starten und ich hab schon bei "requestsMinutesCount": 46.......
                          Lucky_ESA Developer Most Active @Bernd1967 last edited by
                          @bernd1967
                          Da habe ich mich wohl missverständlich ausgedrückt. Für Stopp gibt es ja das Objekt homeconnect.0.xxx.commands.BSH_Common_Command_StopProgram aber es gibt kein Start Objekt. Für den Geschirrspüller zähle ich das Objekt homeconnect.0.xxx.programs.active.BSH_Common_Root_ActiveProgram aber welches Objekt ist es bei andere Geräte....
                          Was genau meinst du?
                          Wenn man einige Geräte hat kann das schon sein. Hier kann ich die Reboots zählen und nur beim graden Counter alle Requests blocken...
                          Bernd1967 1 Reply Last reply Reply Quote 0
                          • Bernd1967
                            @lucky_esa
                            Hab hier eine Bosch Waschmaschine WGB244040
                            Dort ist der Start auch bei
                            "homeconnect.0.xxx.programs.active.BSH_Common_Root_ActiveProgram"
                            Bei dem Datenpunkt "homeconnect.0.rateLimit.limitJson" habe ich die Sorge das die Datengröße zu schnell anwächst. Nach kurzer Zeit hatte ich über 1000 Zeilen im Block "requests".Im Adapter hatte ich die Optione "Abrufprogramme beim Anschließen deaktivieren (reduziert die Ratenlimit)" mal angehackt, aber die Datenmenge blieb gleich.
                            Aber ich werde das mal weiter beobachten, gegebenfalls bei einer bestimmten Größe einfach löschen.
                              Lucky_ESA Developer Most Active @Bernd1967 last edited by Lucky_ESA
                              @bernd1967 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                              @lucky_esa
                              OK, jetzt verstehe auch ich es 😊 Die Daten werden um 24 Uhr automatisch gelöscht. Bitte nicht händisch löschen. Kannst du mir den JSON mal per Mail senden github@luckyskills.de
                              Wie viele Geräte hast du?
                              EDIT:
                              Das ist mein Verbrauch von heute. Der Geschirrspüler läuft gerade.
                               "requestsMinutesMax": 49,
                               "requestsMinutesCount": 0,
                               "requestsMinutesLast": 1757008464725,
                               "requestsDayMax": 999,
                               "requestsDayCount": 13,
                               "requestsDayLast": 1756936824604,
                               "requestsMinutesStartMax": 4,
                               "requestsMinutesStartCount": 0,
                               "requestsMinutesStartLast": 1757008464725,
                               "requestsMinutesStopMax": 4,
                               "requestsMinutesStopCount": 0,
                               "requestsMinutesStopLast": 1757008464725,
                               "responseErrorLast10MinutesMax": 9,
                               "responseErrorLast10MinutesCount": 0,
                               "responseErrorLast10MinutesLast": 0,
                               "requestBlock": false,
                               "requestBlockTime": 0,
                               "requestReason": "No Block",
                               "requests": [
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/programs/active/options",
                                   "date": "2025-09-04T06:27:22.143Z",
                                   "response": "Error"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/programs/selected",
                                   "date": "2025-09-04T06:27:27.522Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/settings",
                                   "date": "2025-09-04T06:27:28.283Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/status",
                                   "date": "2025-09-04T06:27:28.701Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/programs/active",
                                   "date": "2025-09-04T06:27:28.843Z",
                                   "response": "Error"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/programs/selected/options",
                                   "date": "2025-09-04T06:27:30.433Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "url": "/settings/BSH.Common.Setting.PowerState",
                                   "date": "2025-09-04T06:27:30.460Z",
                                   "response": "OK"
                                   "methode": "PUT",
                                   "haId": "xxx",
                                   "date": "2025-09-04T16:39:00.125Z",
                                   "response": "OK"
                                   "methode": "PUT",
                                   "haId": "xxx",
                                   "date": "2025-09-04T16:39:02.186Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "date": "2025-09-04T16:39:04.325Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "date": "2025-09-04T16:39:04.653Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "date": "2025-09-04T16:39:04.695Z",
                                   "response": "OK"
                                   "methode": "GET",
                                   "haId": "xxx",
                                   "date": "2025-09-04T16:39:05.591Z",
                                   "response": "OK"
                              • Bernd1967
                                @lucky_esa
                                Habe zwei Geräte von Bosch
                                Mail ist raus.
                                  @lucky_esa
                                  Mail ist raus.
                                  Danke.
                                  Bist du am testen? Du wählst sehr oft ein Programm aus was dann dazu führt, dass die Optionen neu abgefragt werden. Das könnte ich eventuell speichern und damit die Abfragen sparen.
                                  Gruß//Lucky
                                  • Bernd1967
                                    @lucky_esa
                                    Ja, bin am testen, wollte ja sehen was da an Abfragen zusammen kommt.
                                    Wird natürlich wieder weniger 🙂
                                    bsh bsh home connect home connect homeconnect adapter
                                    193
                                    1365
                                    474376
