    4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
    • marcel-drzal
      marcel-drzal @haselchen last edited by marcel-drzal
      @haselchen
      ich hoffe ihr könnt mir helfen. Versuche es nun erst einmal Sauber zu ziehen und dann Updaten.
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 11 (bullseye)
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
                  Kernel: Linux 6.8.12-13-pve
            Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:54:07 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-08-24 11:54:07 CEST
                 Universal time: Sun 2025-08-24 09:54:07 UTC
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      marcel
      HOME=/home/marcel
      GROUPS=marcel sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            6.1G        1.9G        3.6G        0.0K        633M        4.3G
      Swap:           512M          0B        512M
      Total:          6.7G        1.9G        4.1G
      Active iob-Instances:   23
               6144 M total memory
               1892 M used memory
               1886 M active memory
                493 M inactive memory
               3618 M free memory
                  0 M buffer memory
                633 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 11:54:08 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
      Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   6144.0 total,   3617.9 free,   1892.3 used,    633.8 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4251.6 avail Mem
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * influxdb.service              loaded failed failed InfluxDB is an open-source, distributed, time series database
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      4 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--160--disk--0 ext4       30G   11G   17G  39% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
      tmpfs                            tmpfs      13G  108K   13G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--160--disk--0 ext4   rw,relatime,stripe=16
      /var:
      1.7G    /var/
      709M    /var/cache
      704M    /var/cache/apt
      669M    /var/log
      665M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
      Archived and active journals take up 33.3M in the file system.
      /opt/iobroker/backups:
      2.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      670M    /opt/iobroker/iobroker-data/
      377M    /opt/iobroker/iobroker-data/files
      176M    /opt/iobroker/iobroker-data/backup-objects
      49M     /opt/iobroker/iobroker-data/files/vis.0
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      19M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.18.0
      /usr/bin/node           v22.18.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.33.0
      nodejs:
        Installed: 22.18.0-1nodesource1
        Candidate: 22.18.0-1nodesource1
        Version table:
       *** 22.18.0-1nodesource1 600
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.17.1-1nodesource1 600
           22.17.0-1nodesource1 600
           22.16.0-1nodesource1 600
           22.15.1-1nodesource1 600
           22.15.0-1nodesource1 600
           22.14.0-1nodesource1 600
           22.13.1-1nodesource1 600
           22.13.0-1nodesource1 600
           22.12.0-1nodesource1 600
           22.11.0-1nodesource1 600
           22.10.0-1nodesource1 600
           22.9.0-1nodesource1 600
           22.8.0-1nodesource1 600
           22.7.0-1nodesource1 600
           22.6.0-1nodesource1 600
           22.5.1-1nodesource1 600
           22.5.0-1nodesource1 600
           22.4.1-1nodesource1 600
           22.4.0-1nodesource1 600
           22.3.0-1nodesource1 600
           22.2.0-1nodesource1 600
           22.1.0-1nodesource1 600
           22.0.0-1nodesource1 600
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 58433)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     1
      +-- iobroker.luxtronik2@0.3.0 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e3a8b912a68cdb84c808a91c6a2250ae4f7ec1b9)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.judoisoft.0              : judoisoft             : iobroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 10.10.50.16
        system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 - disabled, port: 8214
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.16
      + system.adapter.myuplink.0               : myuplink              : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Stable (default)
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: Stable (default)
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "homekit-controller": 0.5.11, installed 0.5.11
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "judoisoft"    : 1.1.2    , installed 1.1.2
      Adapter    "klf200"       : 1.3.5    , installed 1.3.5
      Adapter    "knx"          : 2.0.30   , installed 2.0.30
      Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
      Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        8765
      States:         6459
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused)
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
      Hit:2 http://deb.debian.org/debian trixie InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Err:6 https://dl.yarnpkg.co m/debian InRelease
        Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
      Err:4 https://repos.influxdata.com/debian buster InRelease
      Fetched 12.9 kB in 0s (46.8 kB/s)
      Reading package lists...
      W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
      Pending Updates: 125
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       22058      140/iobroker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       17359      140/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11038      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21672      193/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21795      320/master
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       32747      712/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22163      342/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       27465      667/io.simple-api.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21796      320/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          11040      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          21674      193/sshd: /usr/sbin
      udp        0      0 10.10.50.16:50137       0.0.0.0:*                           1000       435218     547/io.knx.0
      udp        0      0 10.10.50.16:55244       0.0.0.0:*                           1000       1650387    547/io.knx.0
      udp        0      0 10.10.50.16:57540       0.0.0.0:*                           1000       56405      547/io.knx.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16336      75/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11039      1/init
      udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          21644      172/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21642      172/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21638      172/ntpd
      udp        0      0 10.10.50.16:33034       0.0.0.0:*                           1000       766879     547/io.knx.0
      udp        0      0 10.10.50.16:33292       0.0.0.0:*                           1000       42281      547/io.knx.0
      udp        0      0 10.10.50.16:33516       0.0.0.0:*                           1000       796516     547/io.knx.0
      udp        0      0 10.10.50.16:35890       0.0.0.0:*                           1000       2015188    547/io.knx.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34914      742/io.wled.0
      udp        0      0 10.10.50.16:38368       0.0.0.0:*                           1000       27253      547/io.knx.0
      udp        0      0 10.10.50.16:42227       0.0.0.0:*                           1000       144075     547/io.knx.0
      udp        0    960 10.10.50.16:43259       0.0.0.0:*                           1000       2062242    547/io.knx.0
      udp        0      0 10.10.50.16:43538       0.0.0.0:*                           1000       2015226    547/io.knx.0
      udp        0      0 10.10.50.16:47107       0.0.0.0:*                           1000       1431661    547/io.knx.0
      udp6       0      0 :::111                  :::*                                0          11041      1/init
      udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        22015      172/ntpd
      udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        22013      172/ntpd
      udp6       0      0 ::1:123                 :::*                                0          21646      172/ntpd
      udp6       0      0 :::123                  :::*                                0          21635      172/ntpd
      2025-08-24 11:42:49.822  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:42:56.387  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
      2025-08-24 11:42:56.430  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
      2025-08-24 11:42:56.518  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
      2025-08-24 11:43:49.845  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:43:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:44:49.836  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:44:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:45:10.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3952
      2025-08-24 11:45:10.613  - info: dwd.0 (3952) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.18.0, js-controller: 7.0.7
      2025-08-24 11:45:10.805  - info: dwd.0 (3952) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-08-24 11:45:11.314  - info: host.iobroker instance system.adapter.dwd.0 having pid 3952 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-08-24 11:45:49.834  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:45:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:46:49.854  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:46:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:47:49.843  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:47:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:47:56.999  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
      2025-08-24 11:47:57.042  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
      2025-08-24 11:47:57.134  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
      2025-08-24 11:48:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:48:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:49:49.839  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:49:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:50:49.820  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:50:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:51:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:51:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:52:49.858  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:52:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-24 11:52:57.648  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
      2025-08-24 11:52:57.690  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
      2025-08-24 11:52:57.782  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
      2025-08-24 11:53:49.823  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      iob diag has finished.
      • marcel-drzal
        marcel-drzal @mcm1957 last edited by
        @mcm1957
        Danke für deine Hilfe.
        Yahkara nutze ich nicht mehr. hatte ich eigendlich gelöscht
        • mcm1957
          mcm1957 @marcel-drzal last edited by mcm1957
          @marcel-drzal
          Zum Zeitpunkt der Fehlermeldung war yahka aber installiert.Bist du sicher, dass du den ADAPTER und nicht nur die INSTANZ gelöscht hast?
          EDIT:
          Lt iob diag in commentar https://forum.iobroker.net/topic/81995/js-controler-auf-7-07-geht-nicht-fehlermeldung-iob/12 hast du jetzt yahka 1.1.5 installiert - allerdings ohne aktive instanz.
          Du hast also offensichtlich nur die Instanz gelöscht 🙂
          @Thomas-Braun
          Anregung für iob diag: Warnung bei Adaptern die installiert sind aber keine Instanz besitzen wär zu überlegen.
          marcel-drzal Thomas Braun 3 Replies Last reply Reply Quote 0
          • marcel-drzal
            @mcm1957
            • mcm1957
              @marcel-drzal
              Yep ist installiert. Wenn du ihn nicht mehr benutzt solltest du ihn deinstallieren.
                Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                @mcm1957 sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                Schwierig zu checken. Können ja auch Adapter ohne Instanz sein oder die Nummerierung ist instanz.3 oder so.
                • mcm1957
                  mcm1957 @Thomas Braun last edited by
                  Also zu checken of die Instanz .0 oder .99 ist wär sicher trivial machbar.
                  Hast du Beispiele für Adapter ohne Instanz? Da gibts sicher ein Kriterium dazu.
                  • marcel-drzal
                    marcel-drzal @mcm1957 last edited by marcel-drzal
                    @mcm1957 Adapter habe ich gelöscht
                    habe nun einen error:
                    dpkg: error
                    470 upgraded, 165 newly installed, 34 to remove and 0 not upgraded.
                    Need to get 0 B/341 MB of archives.
                    After this operation, 743 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] Y
                    Reading changelogs... Done
                    Extracting templates from packages: 100%
                    Preconfiguring packages ...
                    (Reading database ... 43860 files and directories currently installed.)
                    Preparing to unpack .../base-files_13.8_amd64.deb ...
                    * The base-files package cannot be installed because
                    * /bin is a directory, but should be a symbolic link.
                    * Please install the usrmerge package to convert this system to merged-/usr.
                    * For more information please read https://wiki.debian.org/UsrMerge.
                    dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb               (--unpack):
                     new base-files package pre-installation script subprocess returned error exit s              tatus 1
                    Errors were encountered while processing:
                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                      Thomas Braun Most Active @marcel-drzal last edited by
                      @marcel-drzal
                      dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
                      sudo apt update
                      sagt?
                      marcel-drzal 1 Reply Last reply Reply Quote 0
                      • marcel-drzal
                        marcel-drzal @Thomas Braun last edited by marcel-drzal
                        direcktes uptadt aus iobroker:
                        marcel@10.10.50.16's password:
                        Linux iobroker 6.14.8-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.14.8-2 (2025-07-22T10:0                                                       4Z) x86_64
                        The programs included with the Debian GNU/Linux system are free software;
                        the exact distribution terms for each program are described in the
                        individual files in /usr/share/doc/*/copyright.
                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                        permitted by applicable law.
                        Last login: Tue Aug 26 18:40:15 2025 from 10.10.10.166
                        marcel@iobroker:~$ sudo apt update
                        [sudo] password for marcel:
                        Hit:1 http://deb.debian.org/debian trixie InRelease
                        Get:2 http://security.debian.org/debian-security trixie-security InRelease [43.4                                                        kB]
                        Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
                        Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
                        Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Pack                                                       ages [33.1 kB]
                        Get:7 http://security.debian.org/debian-security trixie-security/main Translatio                                                       n-en [22.0 kB]
                          The following signatures couldn't be verified because the public key is not av                                                       ailable: NO_PUBKEY D8FF8E1F7DF8B07E
                        Get:8 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [7803 B]
                        Err:9 https://dl.yarnpkg.co m/debian InRelease
                          Could not connect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connec                                                       tion refused) Could not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect                                                        (111: Connection refused)
                        Fetched 178 kB in 1s (325 kB/s)
                        Reading package lists... Done
                        Building dependency tree... Done
                        471 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        W: An error occurred during the signature verification. The repository is not up                                                       dated and the previous index files will be used. GPG error: https://repos.influx                                                       data.com/debian buster InRelease: The following signatures couldn't be verified                                                        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                                                       he following signatures couldn't be verified because the public key is not avail                                                       able: NO_PUBKEY D8FF8E1F7DF8B07E
                        W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not con                                                       nect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connection refused) C                                                       ould not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect (111: Connecti                                                       on refused)
                        PlatformBetriebssystem:linux
                        Architektur:x64
                        CPUs:2
                        Geschwindigkeit:4043 MHz
                        Modell:unknown
                        RAM:6 GB
                        System-Betriebszeit:2 T. 00:15:05
                        Node.js:v22.18.0
                        Zeit:1756964837826
                        Zeitversatz:-120
                        NPM:10.9.3
                        Adapter-Anzahl:574
                        Datenträgergröße:29.4 GB
                        Freier Festplattenspeicher:18.5 GB
                        Aktive Instanzen:21
                        Pfad:/opt/iobroker/
                        Betriebszeit:2 T. 00:15:01
                        aktiv:true
                        _nodeCurrent:22.18.0
                        _nodeNewest:22.19.0
                        _nodeNewestNext:22.19.0
                        _npmCurrent:10.9.3
                        _npmNewest:10.9.3
                        _npmNewestNext:10.9.3
                          Thomas Braun Most Active @marcel-drzal last edited by Thomas Braun
                          @marcel-drzal
                          Hau die 471 Updates rein, verdammt.
                          Die influxdb-Quelle ist veraltet. Leg die neu an.
                          Geht so:
                          https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                          Und dann schau, aus welcher Datei dieses yarn-Dingsi kommt.
                          cd /etc/apt/
                          grep -r yarn .
                          Die Zeile mit dem Eintrag zu yarn würde ich löschen.
                          • marcel-drzal
                            habe ich bekomme hier die Meldung:
                            Fetched 38.5 MB in 3s (11.3 MB/s)
                             new base-files package pre-installation script subprocess returned error exit status 1
                            marcel@iobroker:~$
                              @marcel-drzal
                              Hast du das ganze Ding über Jahre von Release zu Release geschliffen?
                              Oder von Buster direkt auf Trixie gesprungen?
                              Da scheint mir einiges schiefgelaufen zu sein.
                              Installier es von Grund auf neu.
                              • marcel-drzal
                                @thomas-braun nein denke habe es immer auf den neusten Stand gehalten.
                                Neu? Gibt es einen anderen Weg. Wie kann ich da am besten vor gehen?
                                  @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                                  Von wo aus? Also doch über Generationen rübergetragen?
                                  Ich würde es neuinstallieren. Da fehlt mindestens der usrmerge auf der Kiste und wer weiß was sonst noch alles.
                                  Edit:
                                  Und dein Herumgehampel als root trägt auch nicht dazu bei da ein stabiles, sauberes System zu haben.
                                  • marcel-drzal
                                    ok, ich mach alles neu.
                                    kannst du mir dabei helfen?
                                    würde erst mal ein neues sauberes System auf setzen in Proxmox.
                                    also es erst mal parallel laufen lassen und nach und nach alles rüber ziehen.
                                    oder geht das nich ?
                                    ich denke wenn ich ein Backup ziehe in iobroker habe ich die gelichen Probleme dann wieder oder?
                                    da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • da_Woody
                                      da_Woody @marcel-drzal last edited by
                                      @marcel-drzal bin jetzt auch kein profi, aber sauber aufsetzen (beschreibungen gibts genug), backup mit dem backitup adapter machen, dann sollten keine schweinereien mehr sein nach rückspielen.
                                        Nein, das darunterliegende System ist krumm und schief, der ioBroker dürfte da nicht direkt von betroffen sein.
                                        Zur Installation auf Proxmox:
                                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                                        da_Woody 1 Reply Last reply Reply Quote 1
                                        • da_Woody
                                          da_Woody @Thomas Braun last edited by
                                          @thomas-braun da wäre erstmal die frage, wie aktuell proxmox ist... 😉
                                            Thomas Braun Most Active @da_Woody last edited by
                                            @da_woody
                                            Da würde ich halt auch die aktuelle Version empfehlen...
                                            marcel-drzal 1 Reply Last reply Reply Quote 1
                                            1910
