    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      arteck Developer Most Active @Thomas Braun last edited by
      @thomas-braun sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
      Wobei hier dann wohl eine ungesunde Distanz zwischen stable und beta besteht:
      ja ich weiss... muss ich noch tun
        Fichte @ilovegym last edited by
        @ilovegym
        Auch hier (2.12.6) habe ich den selben Fehler.
        Liebe Grüße
        ilovegym 1 Reply Last reply Reply Quote 0
        • ilovegym
          ilovegym @Fichte last edited by
          @fichte
          zeig bitte mal die Ausgabe von "iob diag" komplett, hier in Code Tags gesetzt.
            @ilovegym
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
             Static hostname: ioBroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
                      Kernel: Linux 6.14.8-2-pve
                Architecture: x86-64
            OS is similar to:
            model name      : Intel(R) Core(TM) i5-9500T CPU @ 2.20GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             13:08:29 up 6 days,  1:46,  3 users,  load average: 0.42, 0.45, 0.51
            CPU threads: 6
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** TIME AND TIMEZONES ***
                           Local time: Thu 2025-09-04 13:08:29 CEST
                       Universal time: Thu 2025-09-04 11:08:29 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            Fichte
            HOME=/home/Fichte
            GROUPS=Fichte adm dialout sudo audio video plugdev users iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            8.6G         65M        4.7G        139K        3.8G        8.5G
            Swap:             0B          0B          0B
            Total:          8.6G         65M        4.7G
            Active iob-Instances:   1
                     8192 M total memory
                       62 M used memory
                      147 M active memory
                     3374 M inactive memory
                     4486 M free memory
                        0 M buffer memory
                     3642 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 13:08:29 up 6 days,  1:46,  3 users,  load average: 0.42, 0.45, 0.51
            Tasks:  63 total,   1 running,  62 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8192.0 total,   4485.2 free,     64.0 used,   3643.0 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8128.0 avail Mem
            *** FAILED SERVICES ***
              UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
            * iobroker.service     loaded failed failed ioBroker Server
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            2 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            dmesg: read kernel buffer failed: Operation not permitted
            No critical errors detected
            *** FILESYSTEM ***
            /dev/loop0     ext4       16G  6.5G  8.4G  44% /
            none           tmpfs     492K  4.0K  488K   1% /dev
            none           tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-path/pci-0000:00:14.0-usb-0:1:1.0-port0
            udev           devtmpfs   32G     0   32G   0% /dev/tty
            tmpfs          tmpfs      32G     0   32G   0% /dev/shm
            tmpfs          tmpfs      13G  132K   13G   1% /run
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
            Show mounted filesystems:
            TARGET SOURCE     FSTYPE OPTIONS
            /      /dev/loop0 ext4   rw,relatime
            /var:
            489M    /var/
            292M    /var/cache
            288M    /var/cache/apt
            213M    /var/cache/apt/archives
            147M    /var/lib
            Archived and active journals take up 48.0M in the file system.
            /opt/iobroker/backups:
            616M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.9G    /opt/iobroker/iobroker-data/
            1.3G    /opt/iobroker/iobroker-data/history
            528M    /opt/iobroker/iobroker-data/files
            130M    /opt/iobroker/iobroker-data/backup-objects
            104M    /opt/iobroker/iobroker-data/files/vis
            find: Failed to change directory: /root: Permission denied
            find: Failed to restore initial working directory: /root: Permission denied
            USB-Devices by-id:
            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
            *** ZigBee Settings ***
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            HINT:
            Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            HINT:
            Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
            tcp
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v22.19.0
            /usr/bin/node           v22.19.0
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            /usr/bin/corepack       0.34.0
            nodejs:
              Installed: 22.19.0-1nodesource1
              Candidate: 22.19.0-1nodesource1
              Version table:
             *** 22.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 22.18.0-1nodesource1 1001
                 22.17.1-1nodesource1 1001
                 22.17.0-1nodesource1 1001
                 22.16.0-1nodesource1 1001
                 22.15.1-1nodesource1 1001
                 22.15.0-1nodesource1 1001
                 22.14.0-1nodesource1 1001
                 22.13.1-1nodesource1 1001
                 22.13.0-1nodesource1 1001
                 22.12.0-1nodesource1 1001
                 22.11.0-1nodesource1 1001
                 22.10.0-1nodesource1 1001
                 22.9.0-1nodesource1 1001
                 22.8.0-1nodesource1 1001
                 22.7.0-1nodesource1 1001
                 22.6.0-1nodesource1 1001
                 22.5.1-1nodesource1 1001
                 22.5.0-1nodesource1 1001
                 22.4.1-1nodesource1 1001
                 22.4.0-1nodesource1 1001
                 22.3.0-1nodesource1 1001
                 22.2.0-1nodesource1 1001
                 22.1.0-1nodesource1 1001
                 22.0.0-1nodesource1 1001
                 18.20.4+dfsg-1~deb12u1 500
                    500 http://security.debian.org bookworm-security/main amd64 Packages
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            Checking for nodejs vulnerability:
            *** ioBroker-Installation ***
            ioBroker Status
            Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 1022)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.6.17
            javascript:     8.9.2
            nodejs modules from github:     2
            +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
            +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
            Adapter State
              system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
              system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
              system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
              system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
              system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
              system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
              system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
              system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
              system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
              system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
              system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: ioBroker                                 -  enabled
              system.adapter.espresense.0             : espresense            : ioBroker                                 - disabled
              system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
              system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
              system.adapter.history.0                : history               : ioBroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
              system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
              system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 -  enabled
              system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
              system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
              system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
              system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
              system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
              system.adapter.onvif.0                  : onvif                 : ioBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
              system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
              system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
              system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
              system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 4500, bind: 0.0.0.0
              system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
              system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
              system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
              system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
              system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : ioBroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
              system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 -  enabled
              system.adapter.zigbee.0                 : zigbee                : ioBroker
              system.adapter.zigbee.1                 : zigbee                : ioBroker
              system.adapter.zigbee.2                 : zigbee                : ioBroker
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.6.17   , installed 7.6.17
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "ankersolix2"  : 2.3.0    , installed 2.3.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.12.1  , installed 2.12.6
            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
            Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
            Adapter    "espresense"   : 0.6.3    , installed 0.6.3
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
            Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "logparser"    : 2.4.0    , installed 2.4.0
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
            Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "radar2"       : 2.3.0    , installed 2.3.0
            Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
            Adapter    "shelly"       : 10.1.0   , installed 10.1.0
            Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
            Adapter    "socketio"     : 6.7.1    , installed 7.0.8
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
            Adapter    "ws"           : 2.6.2    , installed 3.0.19
            Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
            Objects and States
            Objects:        32937
            States:         29257
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12881      1/init
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13829      295/master
            tcp6       0      0 :::111                  :::*                    LISTEN      0          12883      1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          11939      1/init
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13830      295/master
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12882      1/init
            udp6       0      0 :::111                  :::*                                0          12884      1/init
            2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.zigbee.1 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.113  - info: host.ioBroker instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.energiefluss-erweitert.1 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.linux-control.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.onvif.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.132  - info: host.ioBroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.156  - info: host.ioBroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.156  - info: host.ioBroker instance system.adapter.device-watcher.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:28.156  - warn: host.ioBroker instance system.adapter.pushover.0 terminated due to SIGKILL
            2025-09-04 13:05:28.156  - info: host.ioBroker instance system.adapter.pushover.0 terminated with code null ()
            2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.telegram.0 terminated due to SIGKILL
            2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.telegram.0 terminated with code null ()
            2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.sonoff.0 terminated due to SIGKILL
            2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.sonoff.0 terminated with code null ()
            2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.echarts.0 terminated due to SIGKILL
            2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.echarts.0 terminated with code null ()
            2025-09-04 13:05:28.176  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
            2025-09-04 13:05:28.176  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
            2025-09-04 13:05:29.065  - info: tuya.0 (124862) terminating
            2025-09-04 13:05:29.066  - info: tuya.0 (124862) Terminated (NO_ERROR): Without reason
            2025-09-04 13:05:29.622  - info: host.ioBroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
            2025-09-04 13:05:29.622  - info: host.ioBroker All instances are stopped.
            2025-09-04 13:05:29.681  - info: host.ioBroker terminated
            iob diag has finished.
              Thomas Braun Most Active @Fichte last edited by
              @fichte sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
              Mit laufendem ioBroker könnte man mehr sehen.
                Fichte @Thomas Braun last edited by Fichte
                Ja Sorry habs gesehen 🙄
                Script v.2025-08-09
                *** BASE SYSTEM ***
                  Virtualization: lxc
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 13:22:09 up 6 days,  2:00,  3 users,  load average: 0.88, 0.74, 0.71
                CPU threads: 6
                               Local time: Thu 2025-09-04 13:22:09 CEST
                           Universal time: Thu 2025-09-04 11:22:09 UTC
                                 RTC time: n/a
                          RTC in local TZ: no
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:            8.6G        3.3G        1.4G        143K        3.9G        5.3G
                Swap:             0B          0B          0B
                Total:          8.6G        3.3G        1.4G
                Active iob-Instances:   40
                         8192 M total memory
                         3154 M used memory
                         3126 M active memory
                         3416 M inactive memory
                         1350 M free memory
                            0 M buffer memory
                         3687 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                top - 13:22:10 up 6 days,  2:00,  3 users,  load average: 0.88, 0.74, 0.71
                Tasks:  74 total,   2 running,  72 sleeping,   0 stopped,   0 zombie
                MiB Mem :   8192.0 total,   1348.6 free,   3155.9 used,   3687.7 buff/cache
                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   5036.1 avail Mem
                1 loaded units listed.
                *** FILESYSTEM ***
                /dev/loop0     ext4       16G  6.5G  8.3G  44% /
                tmpfs          tmpfs      13G  136K   13G   1% /run
                /var:
                489M    /var/
                292M    /var/cache
                288M    /var/cache/apt
                147M    /var/lib
                2.0G    /opt/iobroker/iobroker-data/
                USB-Devices by-id:
                HINT:
                tcp
                HINT:
                tcp
                HINT:
                tcp
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.9.3
                /usr/bin/npx            10.9.3
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 691)
                admin:          7.6.17
                javascript:     8.9.2
                Adapter State
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
                + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
                + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: ioBroker                                 -  enabled
                + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: ioBroker                                 -  enabled
                + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
                + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                + system.adapter.onvif.0                  : onvif                 : ioBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
                + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
                + system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 4500, bind: 0.0.0.0
                + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
                + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 -  enabled
                + system.adapter.zigbee.0                 : zigbee                : ioBroker
                + system.adapter.zigbee.1                 : zigbee                : ioBroker
                + instance is alive
                Objects and States
                Objects:        32934
                States:         29677
                Hit:2 http://security.debian.org bookworm-security InRelease
                Pending Updates: 0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       46074353   128666/io.mqtt.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       46075511   128735/io.shelly.0
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       46074691   128769/io.sonoff.0
                tcp        0      0 0.0.0.0:4500            0.0.0.0:*               LISTEN      1000       46092954   129380/io.sainlogic
                tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       46072354   128346/iobroker.js-
                tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       46069613   128346/iobroker.js-
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46071412   128365/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46090902   129460/io.web.0
                udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       46074129   128561/io.broadlink
                udp        0      0 0.0.0.0:55076           0.0.0.0:*                           1000       46074132   128561/io.broadlink
                udp        0      0 0.0.0.0:56116           0.0.0.0:*                           1000       46074189   128561/io.broadlink
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       46077311   128711/io.radar2.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       46076891   128787/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       46076892   128787/io.tuya.0
                2025-09-04 13:20:25.687  - info: host.ioBroker instance system.adapter.dwd.0 having pid 129670 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-09-04 13:21:00.005  - info: device-watcher.0 (129650) Scheduled restart.
                2025-09-04 13:21:00.005  - info: device-watcher.0 (129650) cleaned everything up...
                2025-09-04 13:21:00.047  - info: device-watcher.0 (129650) terminating
                2025-09-04 13:21:00.048  - info: device-watcher.0 (129650) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2025-09-04 13:21:00.508  - info: device-watcher.0 (129650) terminating
                2025-09-04 13:21:00.602  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
                2025-09-04 13:21:00.602  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
                2025-09-04 13:21:01.909  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 129689
                2025-09-04 13:21:02.748  - info: device-watcher.0 (129689) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
                2025-09-04 13:21:02.782  - info: device-watcher.0 (129689) Number of selected adapters to monitor devices: 5. Loading data from: Nut, Shelly, Sonoff, Unifi, Zigbee ...
                2025-09-04 13:22:00.004  - info: device-watcher.0 (129689) Scheduled restart.
                2025-09-04 13:22:00.005  - info: device-watcher.0 (129689) cleaned everything up...
                2025-09-04 13:22:00.008  - info: device-watcher.0 (129689) terminating
                2025-09-04 13:22:00.008  - info: device-watcher.0 (129689) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2025-09-04 13:22:00.507  - info: device-watcher.0 (129689) terminating
                2025-09-04 13:22:00.560  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
                2025-09-04 13:22:00.560  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
                2025-09-04 13:22:01.876  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 129801
                2025-09-04 13:22:02.680  - info: device-watcher.0 (129801) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
                2025-09-04 13:22:02.716  - info: device-watcher.0 (129801) Number of selected adapters to monitor devices: 5. Loading data from: Nut, Shelly, Sonoff, Unifi, Zigbee ...
                2025-09-04 13:22:18.582  - info: zigbee.0 (128834) checking configure on message :  next attempt in -161707 seconds
                2025-09-04 13:22:18.582  - info: zigbee.0 (128834) Configure on Message for 0x00124b00234e5828
                2025-09-04 13:22:18.582  - info: zigbee.0 (128834) Configuring 0x00124b00234e5828 SNZB-03
                2025-09-04 13:22:28.595  - info: zigbee.0 (128834) Timeout trying to configure 0x00124b00234e5828 SNZB-03 (0).
                ilovegym Thomas Braun 2 Replies Last reply Reply Quote 0
                • ilovegym
                  @fichte na bei sovielen permission denied solltest du mal dein system gerade biegen oder besser neu aufsetzen..da ist grundsaetzlich viel viel schief...
                    @ilovegym sagte in Test Adapter Device-Watcher v2.x.x GitHub/Latest:
                    Das system ist eine woche alt ohne Backup zurückspielen
                    da_Woody ilovegym 2 Replies Last reply Reply Quote 0
                    • da_Woody
                      da_Woody @Fichte last edited by
                      @fichte fummelst du da als root rum?
                      • ilovegym
                        ilovegym @Fichte last edited by ilovegym
                        Dann ging vor ner Woche so einiges schief, deshalb jetzt auch die Probleme.. schau dir die Diagnose doch mal an..
                        Mein Tip: iobroker backup starten, datei sichern, komplettes System neu aufsetzen (aber richtig, schau bei Thomas Braun's Tipps) und dann iobroker wieder restoren.
                        Edit: ist ne Arbeit von 2h, evtl sogar schneller, je nach System und hardware
                          Thomas Braun Most Active @Fichte last edited by Thomas Braun
                          Da stimmt ohnehin irgendwas grundsätzliches nicht mit deinen usern:
                          Da muss der user auftauchen, der 'iob diag' aufruft.
                          Und auch die Meldungen zu /root: Permission denied sollten auf einem richtig aufgesetzten LXC nicht erscheinen.
                          Da hätte ich auch gleich Debian 13 'Trixie' hergenommen.
                            Da gebe ich dir Recht.! Ich setz gerade einen neuen LXC auf und mach es noch mal von vorn. Ich hab irgendwo letzte Woche etwas in den USer falsch gemacht 🙄 Ich geb rückmeldung
                              Noch immer das selbe.
                              Habe das ding jetzt per Hand installiert und alle einstellungen händisch eingetragen.
                              Script v.2025-08-09
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               22:58:56 up 3 min,  2 users,  load average: 2.07, 1.43, 1.40
                              CPU threads: 4
                                             Local time: Thu 2025-09-04 22:58:56 CEST
                                         Universal time: Thu 2025-09-04 20:58:56 UTC
                                               RTC time: n/a
                                        RTC in local TZ: no
                              andre
                              HOME=/home/andre
                              GROUPS=andre sudo users iobroker
                              iobroker
                              HOME=/home/iobroker
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:            8.6G        3.4G        4.4G        147K        774M        5.2G
                              Swap:             0B          0B          0B
                              Total:          8.6G        3.4G        4.4G
                              Active iob-Instances:   39
                                       8192 M total memory
                                       3253 M used memory
                                       3279 M active memory
                                        551 M inactive memory
                                       4199 M free memory
                                          0 M buffer memory
                                        739 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              top - 22:58:56 up 3 min,  2 users,  load average: 2.07, 1.43, 1.40
                              Tasks:  71 total,   1 running,  70 sleeping,   0 stopped,   0 zombie
                              MiB Mem :   8192.0 total,   4198.3 free,   3254.6 used,    739.3 buff/cache
                              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   4937.4 avail Mem
                              *** FILESYSTEM ***
                              /dev/loop0     ext4       16G  4.4G   11G  30% /
                              tmpfs          tmpfs      13G  140K   13G   1% /run
                              tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
                              /var:
                              437M    /var/
                              256M    /var/cache
                              252M    /var/cache/apt
                              175M    /var/cache/apt/archives
                              155M    /var/lib
                              Archived and active journals take up 8.0M in the file system.
                              124M    /opt/iobroker/backups/
                              576M    /opt/iobroker/iobroker-data/
                              96M     /opt/iobroker/iobroker-data/files/vis/widgets
                              67M     /opt/iobroker/iobroker-data/files/echarts.admin
                              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                              31M     /opt/iobroker/iobroker-data/objects.jsonl
                              26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                              26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                              USB-Devices by-id:
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              tcp
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.9.3
                              /usr/bin/npx            10.9.3
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 182)
                              admin:          7.6.17
                              javascript:     8.9.2
                              Adapter State
                              + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://10.10.10.17:20108
                              + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://10.10.10.18:20108
                                system.adapter.zigbee.2                 : zigbee                : ioBroker                                 - disabled, port: tcp://10.10.10.160:6638
                              + instance is alive
                              Objects and States
                              Objects:        28232
                              States:         26499
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       50671491   128/iobroker.js-con
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       50673829   128/iobroker.js-con
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       50681075   767/io.sonoff.0
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       50673641   621/io.shelly.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       50677030   651/io.mqtt.0
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          50671128   1/init
                              tcp        0      0 0.0.0.0:4500            0.0.0.0:*               LISTEN      1001       50692938   1387/io.sainlogic.0
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          50671366   295/master
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          50673752   1/init
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          50671130   1/init
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50669194   306/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       50684708   984/io.web.0
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          50671367   295/master
                              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       50677143   726/io.radar2.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          50671129   1/init
                              udp        0      0 0.0.0.0:33407           0.0.0.0:*                           1001       50674505   501/io.broadlink2.0
                              udp        0      0 0.0.0.0:36640           0.0.0.0:*                           1001       50669565   501/io.broadlink2.0
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       50677329   786/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       50677330   786/io.tuya.0
                              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       50673340   501/io.broadlink2.0
                              udp6       0      0 :::111                  :::*                                0          50671131   1/init
                              Proxmox:  ioBroker (22:58)
                              2025-09-04 22:58:48.577  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist nicht mehr erreichbar: \nProxmox:  ioBroker (22:58)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                              2025-09-04 22:59:00.004  - info: device-watcher.0 (1071) Scheduled restart.
                              2025-09-04 22:59:00.004  - info: device-watcher.0 (1071) cleaned everything up...
                              2025-09-04 22:59:00.006  - info: device-watcher.0 (1071) terminating
                              2025-09-04 22:59:00.007  - info: device-watcher.0 (1071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              2025-09-04 22:59:00.507  - info: device-watcher.0 (1071) terminating
                              2025-09-04 22:59:00.554  - info: host.ioBroker instance system.adapter.device-watcher.0 scheduled normal terminated and will be restarted on schedule.
                              2025-09-04 22:59:00.554  - info: host.ioBroker Restart adapter system.adapter.device-watcher.0 because enabled
                              2025-09-04 22:59:01.850  - info: host.ioBroker instance system.adapter.device-watcher.0 in version "2.12.6" started with pid 1806
                              2025-09-04 22:59:02.767  - info: device-watcher.0 (1806) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v22.19.0, js-controller: 7.0.7
                              2025-09-04 22:59:02.801  - info: device-watcher.0 (1806) Number of selected adapters to monitor devices: 6. Loading data from: Nut, Proxmox, Sonoff, Tuya, Unifi, Zigbee ...
                              2025-09-04 22:59:03.010  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:03.060  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:03.112  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:03.162  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:03.205  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:03.248  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:03.326  - error: device-watcher.0 (1806) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                              2025-09-04 22:59:11.978  - info: device-watcher.0 (1806) Das folgende Gerät ist wieder verfügbar:
                              Proxmox:  ioBroker (22:59)
                              2025-09-04 22:59:12.023  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist wieder verfügbar: \nProxmox:  ioBroker (22:59)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                              2025-09-04 22:59:12.192  - info: device-watcher.0 (1806) Das folgende Gerät ist nicht mehr erreichbar:
                              2025-09-04 22:59:12.237  - info: pushover.0 (427) Sending pushover notification: {"message":"Das folgende Gerät ist nicht mehr erreichbar: \nProxmox:  ioBroker (22:59)","title":"ioBroker","device":"galaxys25ultra","user":"","priority":"0","sound":"bike"}
                                Zumindest die grundsätzlichen Kinken sind jetzt raus.
                                Was sagt denn
                                cd /opt/iobroker/ && npm ls cron-parser
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├─┬ iobroker.backitup@3.3.5
                                  │ ├── cron-parser@5.3.1
                                  │ └─┬ node-schedule@2.1.1
                                  │   └── cron-parser@4.9.0
                                  ├─┬ iobroker.js-controller@7.0.7
                                  └─┬ iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                                    └─┬ node-schedule@1.3.3
                                      └── cron-parser@2.18.0
                                    @fichte
                                    Hab den Adapter auch gerade mal installiert. Schaut hier ähnlich aus:
                                    2025-09-04 23:21:15.515  - info: device-watcher.0 (1054123) starting. Version 2.12.6 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v24.7.0, js-controller: 7.0.7
                                    2025-09-04 23:21:15.547  - info: device-watcher.0 (1054123) Number of selected adapters to monitor devices: 1. Loading data from: Alexa2 ...
                                    2025-09-04 23:21:16.753  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                    2025-09-04 23:21:16.763  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                    2025-09-04 23:21:16.867  - error: device-watcher.0 (1054123) [getPreviousCronRun] - TypeError: cronParser.parseExpression is not a function
                                      Dank deines Tipps hab ich jetzt erst mal ein Sauberes System 👍
                                      Jetzt Lösche ich gerade alle Adapter Rückwärts um zu sehen ob es an einem Adapter liegt.
                                        Also wenn ich alle Instanzen mit CRON Job Lösche ist der Fehler nach und nach weg wie zbs. bei mir:
                                        ical
                                        feiertage
                                        dwd
                                        das wetter
                                        Der Fehler tritt auch auf wenn man die Zeiten zum Abrufen der Daten wie ical ändern möchte.
                                        Wie ich gesehen habe ist der Entwickler des Adapters nicht mehr hier.
                                        Wird dieser Adapter von jemand anderen weitere geführt oder war es das damit.?
                                        Liebe Grüße
                                          arteck Developer Most Active @Fichte last edited by
                                          wenn du RICHTIG geschaut hättest würdest du festgestellt haben dass ich den pflege..
                                          ich kann dir nicht folgen welche Einstellungen du meinst.. zeigmal screenshot
                                            Fichte @arteck last edited by Fichte
                                            @arteck
                                            Es war eine normale frage und wollte hier keinen Ankreiten, Sorry.
                                            Der Fehler Erscheint bei Instanzen mit CronJobs
                                            Lösche ich die Instanz ist der Fehler nach und nach weg.
                                            Ich hatte Anfangs 7 solcher Instanzen und nach löschen der der einzellnen Instanzen wurden die fehler immer weniger bis gaanz weg.
                                            da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                                            1510
                                            530590
