    4. Test Adapter Vaillant multiMatic/senso und myVaillant
      smarteppi @tombox last edited by smarteppi
      @tombox vaillant.0
      2025-06-26 15:31:11.981 error Login failed
      vaillant.0
      2025-06-26 15:31:11.979 warn Missing username or password
      vaillant.0
      2025-06-26 15:31:11.978 info Generate new Id
      vaillant.0
      2025-06-26 15:31:11.961 info starting. Version 0.7.3 (non-npm: TA2k/ioBroker.vaillant#848d951f0081c66bc6b309ded4a834f3ad1c29af) in /opt/iobroker/node_modules/iobroker.vaillant, node: v20.19.2, js-controller: 7.0.6
      Admin 7.6.17
        tombox @smarteppi last edited by
        @smarteppi passiert das auch mit der 0.7.4?
          ja leider
          vaillant.0
          2025-06-27 16:48:58.733 error Login failed
          vaillant.0
          2025-06-27 16:48:58.731 warn Missing username or password
          vaillant.0
          2025-06-27 16:48:58.729 info Generate new Id
          vaillant.0
          2025-06-27 16:48:58.711 info starting. Version 0.7.4 (non-npm: TA2k/ioBroker.vaillant#81b2fc6c0a6915501a158416d14d2d16fd5e8a44) in /opt/iobroker/node_modules/iobroker.vaillant, node: v20.19.2, js-controller: 7.0.6
            smarteppi @smarteppi last edited by
            @smarteppi in einer alten io Instanz läuft der Adapter noch. In der neuen nicht mehr.
            vaillant.0
            2025-07-01 19:30:49.155 info Receiving first time stats
            vaillant.0
            2025-07-01 19:30:48.849 info Receiving first time status
            vaillant.0
            2025-07-01 19:30:48.639 info Found 1 system
            vaillant.0
            2025-07-01 19:30:48.466 info Getting myv devices
            vaillant.0
            2025-07-01 19:30:48.466 info Login successful
            vaillant.0
            2025-07-01 19:30:47.314 info Generate new Id
            vaillant.0
            2025-07-01 19:30:47.286 info starting. Version 0.7.3 (non-npm: TA2k/ioBroker.vaillant#d5e937b6d1506adb7d5d032096ec700ec2a68bdd) in /opt/iobroker/node_modules/iobroker.vaillant, node: v18.7.0, js-controller: 7.0.6
            vaillant.0
            2025-07-01 19:30:42.234 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            vaillant.0
            2025-07-01 19:30:42.234 info terminating
            vaillant.0
            2025-07-01 19:30:42.233 info cleaned everything up...
            vaillant.0
            2025-07-01 19:30:42.228 info Got terminate signal TERMINATE_YOURSELF
              Disk65 @smarteppi last edited by
              Der Adapter funktioniert schon ganz prima. Ich bekomme Stati und kann auch Temperaturen anpassen.
              Allerdings scheitere ich noch daran die Betriebsarten für Heizung und/oder Warmwasser umzuschalten.
              Ich habe die Version 0.7.5 des Adapters und eine aroTHERM plus.
              Muss ich in vaillant.0.xxxx.configuration.zones01.heating.operationModeHeating etwas anderes eintragen als OFF, MANUAL, TIME_CONTROLLED? Es wird von der Wärmepumpe einfach nicht übernommen. Nach der Updatezeit (bei mir 5 Minuten) steht wieder die Betriebsart drin, die ich in der App gewählt hatte.
              L R 2 Replies Last reply Reply Quote 0
                lesiflo Most Active @Disk65 last edited by
                @disk65 Hat bei mir auch nicht geklappt. Ich bin dann den Umweg über Home Assistent gegangen. Hab mir einen HA Server eingerichtet mit Vaillant Instanz und auf iobroker den Hass Adapter installiert. Damit klappt das dann. Ist zwar etwas umständlich aber geht. Damit lässt sich dann alles in iobroker einstellen was über die Handy App auch geht.
                  hendi062 @hendi062 last edited by
                  Guten Abend,
                  ich bin leider erst jetzt dazu gekommen die Version 0.7.5.
                  Damit funktioniert es jetzt die Einstellungen zu übernehmen und ich bekomme die Werte der Steuerung! Danke für die Aktualisierung!
                  • Andre 6
                    Andre 6 last edited by
                    Moin,
                    wo finde ich den aktuellen Stromverbrauch der WP?
                    In der APP zu sehen unter Status -> Hauptsystem -> aroTHERM oder uniTOWER , dort werden aktuelle Leistungsaufnahme, Betriebslaufzeit und die Ein/Aus-Zyklen angezeigt.
                    MfG
                    L M 2 Replies Last reply Reply Quote 0
                      lesiflo Most Active @Andre 6 last edited by
                      @andre-6 Ich glaube gar nicht. Hab's auch nicht gefunden.
                        RaBe52 @Disk65 last edited by
                        @disk65 sagte in Test Adapter Vaillant multiMatic/senso und myVaillant:
                        Da würde ich auch gern wissen, wie man das mit dem Steuern hinbekommt.
                          maxe1111 @Andre 6 last edited by
                          @andre-6
                          die aktuelle Momentanleistung kriegst du nur direkt vom ebus. Im Vaillant Adapter sind nur die Verbrauchsdaten, verteilt auf WP und uniTower. Im ebus Adapter heißt der Datenpunkt ebus.0.hmu.messages.RunDataElectricPowerConsumption.fields.value.value
                          Andre 6 M 2 Replies Last reply Reply Quote 0
                          • Andre 6
                            Andre 6 @maxe1111 last edited by
                            @maxe1111 Hierzu benötige ich aber noch einen eBus Koppler? Gibt es denn dazu eine vollständige Anleitung? Habe noch nichts gefunden womit ich klar komme.
                            icebear 1 Reply Last reply Reply Quote 0
                            • icebear
                              icebear @Andre 6 last edited by
                              @andre-6
                              Oder du lässt dir vom Elektiker deines Vertrauens einen Zwischenzähler setzten z.B. Eastron SDM630 Modbus und holtst dir über Modbus die Daten nach ioBroker. Dazu gibts hier im Forum auch irgendwo eine Anleitung.
                                maxe1111 @maxe1111 last edited by maxe1111
                                @andre-6
                                Ja genau, das geht z.B.mit einem ebus Adapter der auf einen Raspi gesteckt wird.
                                Hier gibts Infos: https://adapter.ebusd.eu/v5-c6/
                                Bei mir läuft der C6 Adapter auf einem Raspi4.
                                Man muss auf dem Raspi eigentlich nur ebusd installieren und im iobroker den normalen ebus Adapter. Wenn beides richtig konfiguriert ist holt sich der ebus Adapter dann die Daten vom ebusd Adapter ab.
                                Der Vaillant ebus wird physisch am C6 auf Klemme gelegt. Bei mir hab ich das aus einer vorhandenen Busverteilerdose abgezweigt. Der C6 hat ein eigenes Webfrontend über das man ihn konfigurieren kann. Er macht ein eigenes WLAN auf.
                                multimatic senso vaillan vr900 vr920
                                92
                                928
                                302092
