    4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
      Thomas Braun Most Active @marcel-drzal last edited by
      @marcel-drzal
      dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
      sudo apt update
      sagt?
      marcel-drzal 1 Reply Last reply Reply Quote 0
      • marcel-drzal
        marcel-drzal @Thomas Braun last edited by marcel-drzal
        direcktes uptadt aus iobroker:
        marcel@10.10.50.16's password:
        Linux iobroker 6.14.8-2-pve #1 SMP PREEMPT_DYNAMIC PMX 6.14.8-2 (2025-07-22T10:0                                                       4Z) x86_64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Tue Aug 26 18:40:15 2025 from 10.10.10.166
        marcel@iobroker:~$ sudo apt update
        [sudo] password for marcel:
        Hit:1 http://deb.debian.org/debian trixie InRelease
        Get:2 http://security.debian.org/debian-security trixie-security InRelease [43.4                                                        kB]
        Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.1 kB]
        Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
        Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
        Get:6 http://security.debian.org/debian-security trixie-security/main amd64 Pack                                                       ages [33.1 kB]
        Get:7 http://security.debian.org/debian-security trixie-security/main Translatio                                                       n-en [22.0 kB]
        Err:4 https://repos.influxdata.com/debian buster InRelease
          The following signatures couldn't be verified because the public key is not av                                                       ailable: NO_PUBKEY D8FF8E1F7DF8B07E
        Get:8 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [7803 B]
        Err:9 https://dl.yarnpkg.co m/debian InRelease
          Could not connect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connec                                                       tion refused) Could not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect                                                        (111: Connection refused)
        Fetched 178 kB in 1s (325 kB/s)
        Reading package lists... Done
        Building dependency tree... Done
        471 packages can be upgraded. Run 'apt list --upgradable' to see them.
        W: An error occurred during the signature verification. The repository is not up                                                       dated and the previous index files will be used. GPG error: https://repos.influx                                                       data.com/debian buster InRelease: The following signatures couldn't be verified                                                        because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  T                                                       he following signatures couldn't be verified because the public key is not avail                                                       able: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not con                                                       nect to dl.yarnpkg.co:443 (3.225.137.198). - connect (111: Connection refused) C                                                       ould not connect to dl.yarnpkg.co:443 (44.207.185.150). - connect (111: Connecti                                                       on refused)
        W: Some index files failed to download. They have been ignored, or old ones used                                                        instead.
        PlatformBetriebssystem:linux
        Architektur:x64
        CPUs:2
        Geschwindigkeit:4043 MHz
        Modell:unknown
        RAM:6 GB
        System-Betriebszeit:2 T. 00:15:05
        Node.js:v22.18.0
        Zeit:1756964837826
        Zeitversatz:-120
        NPM:10.9.3
        Adapter-Anzahl:574
        Datenträgergröße:29.4 GB
        Freier Festplattenspeicher:18.5 GB
        Aktive Instanzen:21
        Pfad:/opt/iobroker/
        Betriebszeit:2 T. 00:15:01
        aktiv:true
        _nodeCurrent:22.18.0
        _nodeNewest:22.19.0
        _nodeNewestNext:22.19.0
        _npmCurrent:10.9.3
        _npmNewest:10.9.3
        _npmNewestNext:10.9.3
          Thomas Braun Most Active @marcel-drzal last edited by Thomas Braun
          @marcel-drzal
          Hau die 471 Updates rein, verdammt.
          Die influxdb-Quelle ist veraltet. Leg die neu an.
          Geht so:
          https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
          Und dann schau, aus welcher Datei dieses yarn-Dingsi kommt.
          cd /etc/apt/
          grep -r yarn .
          Die Zeile mit dem Eintrag zu yarn würde ich löschen.
          • marcel-drzal
            habe ich bekomme hier die Meldung:
            Fetched 38.5 MB in 3s (11.3 MB/s)
            Reading changelogs... Done
            Extracting templates from packages: 100%
            Preconfiguring packages ...
            (Reading database ... 43860 files and directories currently installed.)
            Preparing to unpack .../base-files_13.8_amd64.deb ...
            * The base-files package cannot be installed because
            * /bin is a directory, but should be a symbolic link.
            * Please install the usrmerge package to convert this system to merged-/usr.
            * For more information please read https://wiki.debian.org/UsrMerge.
            dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb (--unpack):
             new base-files package pre-installation script subprocess returned error exit status 1
            Errors were encountered while processing:
            E: Sub-process /usr/bin/dpkg returned an error code (1)
            marcel@iobroker:~$
              @marcel-drzal
              Hast du das ganze Ding über Jahre von Release zu Release geschliffen?
              Oder von Buster direkt auf Trixie gesprungen?
              Da scheint mir einiges schiefgelaufen zu sein.
              Installier es von Grund auf neu.
              • marcel-drzal
                @thomas-braun nein denke habe es immer auf den neusten Stand gehalten.
                Neu? Gibt es einen anderen Weg. Wie kann ich da am besten vor gehen?
                  @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                  Von wo aus? Also doch über Generationen rübergetragen?
                  Ich würde es neuinstallieren. Da fehlt mindestens der usrmerge auf der Kiste und wer weiß was sonst noch alles.
                  Edit:
                  Und dein Herumgehampel als root trägt auch nicht dazu bei da ein stabiles, sauberes System zu haben.
                  • marcel-drzal
                    ok, ich mach alles neu.
                    kannst du mir dabei helfen?
                    würde erst mal ein neues sauberes System auf setzen in Proxmox.
                    also es erst mal parallel laufen lassen und nach und nach alles rüber ziehen.
                    oder geht das nich ?
                    ich denke wenn ich ein Backup ziehe in iobroker habe ich die gelichen Probleme dann wieder oder?
                    da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
                    • da_Woody
                      da_Woody @marcel-drzal last edited by
                      @marcel-drzal bin jetzt auch kein profi, aber sauber aufsetzen (beschreibungen gibts genug), backup mit dem backitup adapter machen, dann sollten keine schweinereien mehr sein nach rückspielen.
                        Nein, das darunterliegende System ist krumm und schief, der ioBroker dürfte da nicht direkt von betroffen sein.
                        Zur Installation auf Proxmox:
                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                        da_Woody 1 Reply Last reply Reply Quote 1
                        • da_Woody
                          da_Woody @Thomas Braun last edited by
                          @thomas-braun da wäre erstmal die frage, wie aktuell proxmox ist... 😉
                            Thomas Braun Most Active @da_Woody last edited by
                            @da_woody
                            Da würde ich halt auch die aktuelle Version empfehlen...
                            marcel-drzal 1 Reply Last reply Reply Quote 1
                            • marcel-drzal
                              @thomas-braun Danke erst mal.
                              ich werde einen neuen iObroker auf einen LXC Container erstellen.
                              Kann ich die beiden iObroker dann parallel laufen lassen oder muss ich den alten ab stellen?
                                @marcel-drzal
                                Das hängt von den Adaptern ab, ob da Doubles möglich sind. Tendenziell würde ich es aber vermeiden Dinge doppelt laufen zu haben
                                • marcel-drzal
                                  marcel-drzal last edited by marcel-drzal
                                  Iobroker läuft
                                  auf den neuen System
                                  das alte habe ich erst mal runter gefahren.
                                  am Ende der Instllation kam die info das ich iob fix eingeben soll nach dem es läuft.
                                  hier erhalte ich aber eine Fehlermeldung:
                                  marcel@PiObroker:/opt/iobroker$ iob stop
                                  marcel@PiObroker:/opt/iobroker$ iob fix
                                  bash: /home/iobroker/.fix.sh: Permission denied
                                  habe aber den Befehl ausgeführt:
                                  adduser marcel
                                  Anschließend muss der User noch der sudo Gruppe zugeordnet werden.
                                  usermod -aG sudo marcel
                                  marcel@PiObroker:/opt/iobroker$ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v22.19.0
                                  v22.19.0
                                  10.9.3
                                  marcel
                                  /opt/iobroker
                                  Hit:2 http://security.debian.org trixie-security InRelease
                                  Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                                  Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                  All packages are up to date.
                                  Warning: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                  nodejs:
                                    Installed: 22.19.0-1nodesource1
                                    Candidate: 22.19.0-1nodesource1
                                    Version table:
                                   *** 22.19.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                          100 /var/lib/dpkg/status
                                       22.18.0-1nodesource1 1001
                                       22.17.1-1nodesource1 1001
                                       22.17.0-1nodesource1 1001
                                       22.16.0-1nodesource1 1001
                                       22.15.1-1nodesource1 1001
                                       22.15.0-1nodesource1 1001
                                       22.14.0-1nodesource1 1001
                                       22.13.1-1nodesource1 1001
                                       22.13.0-1nodesource1 1001
                                       22.12.0-1nodesource1 1001
                                       22.11.0-1nodesource1 1001
                                       22.10.0-1nodesource1 1001
                                       22.9.0-1nodesource1 1001
                                       22.8.0-1nodesource1 1001
                                       22.7.0-1nodesource1 1001
                                       22.6.0-1nodesource1 1001
                                       22.5.1-1nodesource1 1001
                                       22.5.0-1nodesource1 1001
                                       22.4.1-1nodesource1 1001
                                       22.4.0-1nodesource1 1001
                                       22.3.0-1nodesource1 1001
                                       22.2.0-1nodesource1 1001
                                       22.1.0-1nodesource1 1001
                                       22.0.0-1nodesource1 1001
                                       20.19.2+dfsg-1 500
                                          500 http://deb.debian.org/debian trixie/main amd64 Packages
                                  lines 16-57/57 (END)
                                    Die kommt immer, das muss nach der Erst Installation gemacht werden.
                                    ls -l /home
                                    sagt?
                                    Edith: Einen User legt man als erstes an, dann kann der nämlich von iobroker-Installer direkt richtig konfiguriert werden.
                                    • marcel-drzal
                                      habe erst einen User marcel angelegt wie in der Doku gesagt wurde komisch
                                      marcel@PiObroker:~$ ls -l /home
                                      total 8
                                      drwxr-x--- 2 iobroker iobroker 4096 Sep 11 17:50 iobroker
                                      drwx------ 5 marcel   marcel   4096 Sep 11 18:06 marcel
                                      marcel@PiObroker:~$
                                      CPU: 0,67 %
                                      RAM: 6 %
                                      Betriebszeit: 0h
                                      Verfügbar: 7.0.7
                                      Installiert: 7.0.7
                                      Ereignisse: ⇥5 / ↦13
                                      Plattform: linux
                                      Betriebssystem: linux
                                      Architektur: x64
                                      CPUs: 2
                                      Geschwindigkeit: 400 MHz
                                      Modell: Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
                                      RAM: 6 GB
                                      System-Betriebszeit: 00:04:45
                                      Node.js: v22.19.0
                                      Zeit: 11.9.2025, 18:19:25
                                      Zeitversatz: -120
                                      NPM: 10.9.3
                                      Adapter-Anzahl: 576
                                      Datenträgergröße: 7.8 GB
                                      Freier Festplattenspeicher: 5.5 GB
                                      Aktive Instanzen: 3
                                      Pfad: /opt/iobroker/
                                      Betriebszeit: 00:04:36
                                      aktiv: true
                                      _nodeCurrent: 22.19.0
                                      _nodeNewest: 22.19.0
                                      _nodeNewestNext: 22.19.0
                                      _npmCurrent: 10.9.3
                                      _npmNewest: 10.9.3
                                      _npmNewestNext: 10.9.3
                                        @marcel-drzal
                                        Als user marcel:
                                        id
                                        • marcel-drzal
                                          was meinst du mit id
                                          wir bekomme ich das gerade gezogen?
                                            @marcel-drzal
                                            Das ist ein Kommando in deinem Terminal.
                                            1906
