    3. Einsteigerfragen
    4. Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.
    • Duffy
      Duffy @Thomas Braun last edited by
      @thomas-braun sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
      Halt zuvor die entsprechenden Quellen anlegen, dann ist es eine Installation wie jede andere auch.
      Das hatte ich die letzten Tage auch verwendet weil Grafana eine Warnung gebracht hatte.
      Dann sind das die Befehle für die Installation von Grafan und Influx?
      Möglich. Zeig mal die Ausgabe von iob diag
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.34+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       15:05:12 up 10 days, 19:41,  2 users,  load average: 2.17, 2.40, 2.16
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-09-09 15:05:12 CEST
                 Universal time: Tue 2025-09-09 13:05:12 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.2G        4.7G        366M        1.2M        3.2G        3.5G
      Swap:           209M        209M         28K
      Total:          8.4G        4.9G        366M
      Active iob-Instances:   35
               7819 M total memory
               4503 M used memory
               3386 M active memory
               3724 M inactive memory
                349 M free memory
                140 M buffer memory
               2926 M swap cache
                199 M total swap
                199 M used swap
                  0 M free swap
      top - 15:05:13 up 10 days, 19:41,  2 users,  load average: 2.17, 2.40, 2.16
      Tasks: 222 total,   4 running, 218 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 60.0 us, 20.0 sy,  0.0 ni, 20.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7819.9 total,    349.0 free,   4504.1 used,   3067.6 buff/cache
      MiB Swap:    200.0 total,      0.0 free,    200.0 used.   3315.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda2      ext4       29G   12G   16G  44% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.0G    /var/
      1.5G    /var/log/journal/458ebafb08a8432dbfe417c962c32f87
      1.5G    /var/log
      890M    /var/lib
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      940M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      573M    /opt/iobroker/iobroker-data/
      418M    /opt/iobroker/iobroker-data/files
      115M    /opt/iobroker/iobroker-data/backup-objects
      74M     /opt/iobroker/iobroker-data/files/vis
      67M     /opt/iobroker/iobroker-data/files/vis/widgets
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.19.0
      /usr/bin/node           v22.19.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.19.0-1nodesource1
        Candidate: 22.19.0-1nodesource1
        Version table:
       *** 22.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.20.4+dfsg-1~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 934882)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     1
      +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.matter.0                 : matter                : raspberrypi                              - disabled
      + system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : raspberrypi                              -  enabled, port: 1847, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.6  , installed 2.12.6
      Adapter    "drag-indicator": 2.4.0   , installed 2.4.0
      Adapter    "echarts"      : 1.9.2    , installed 2.0.8
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "matter"       : 0.5.2    , installed 0.5.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "operating-hours": 1.3.0  , installed 1.3.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
      Objects and States
      Objects:        14235
      States:         13110
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
      Hit:7 https://apt.grafana.com stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1847            0.0.0.0:*               LISTEN      1001       9199       1644/io.sainlogic.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20333536   309844/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1741       703/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6039       874/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6507       874/iobroker.js-con
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1743       703/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9148       1594/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        7361       767/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8407       926/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9150       1578/io.web.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      106        7403       873/grafana
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1654       570/avahi-daemon: r
      udp        0      0 0.0.0.0:39491           0.0.0.0:*                           104        1656       570/avahi-daemon: r
      udp6       0      0 fe80::e5bd:4ca9:170:546 :::*                                0          802        643/NetworkManager
      udp6       0      0 :::54158                :::*                                104        1657       570/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        1655       570/avahi-daemon: r
      2025-09-09 15:04:41.104  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:41.105  - info: fritzdect.0 (397454) create Main object DECT_ 087610200870 DS-218 Sicherung 🔐 switch
      2025-09-09 15:04:41.511  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:41.512  - info: fritzdect.0 (397454) create Main object DECT_ 087610200871 Drucker 🖨 switch
      2025-09-09 15:04:41.828  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:41.829  - info: fritzdect.0 (397454) create Main object DECT_ 087610125360 Computer switch
      2025-09-09 15:04:42.263  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:42.263  - info: fritzdect.0 (397454) create Main object DECT_ 087610201621 PV 2 switch
      2025-09-09 15:04:42.584  - info: sourceanalytix.0 (226470) Disabled SourceAnalytix for : fritzdect.0.DECT_087610201621.energy
      2025-09-09 15:04:43.105  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:43.106  - info: fritzdect.0 (397454) create Main object DECT_ 087610216588 Raspberrypi switch
      2025-09-09 15:04:43.476  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:43.476  - info: fritzdect.0 (397454) create Main object DECT_ 087610121625 Kompressor switch
      2025-09-09 15:04:43.773  - info: fritzdect.0 (397454) ____________________________________________
      2025-09-09 15:04:43.773  - info: fritzdect.0 (397454) create Main object DECT_ 087610197338 Klima switch
      2025-09-09 15:04:44.070  - info: fritzdect.0 (397454) finished creating devices/groups (if any)
      2025-09-09 15:04:44.070  - info: fritzdect.0 (397454) templates are used(false)
      2025-09-09 15:04:44.070  - info: fritzdect.0 (397454) start creating templates
      2025-09-09 15:04:44.665  - info: fritzdect.0 (397454) finished creating templates (if any)
      2025-09-09 15:04:44.665  - info: fritzdect.0 (397454) routines are used(false)
      2025-09-09 15:04:44.666  - info: fritzdect.0 (397454) start creating routines
      2025-09-09 15:04:45.152  - info: fritzdect.0 (397454) finished creating routines (if any)
      2025-09-09 15:04:45.153  - info: fritzdect.0 (397454) start initial updating devices/groups
      2025-09-09 15:04:48.498  - info: fritzdect.0 (397454) finished initial updating devices/groups
      2025-09-09 15:04:48.499  - info: fritzdect.0 (397454) going over to cyclic polling, messages to poll activity only in debug-mode
      Vorhin war der Life Cycle Status noch grün jetzt ist er schon Gelb 🤦‍♀️
      Kann ich da noch was retten?
      VG Duffy
        Thomas Braun Most Active @Duffy last edited by
        @duffy sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
        Ja, weil sich nun die Berechnung des Status aktualisiert hat und deine Installation jetzt halt als 'oldstable' eingestuft wird.
        Ich würde noch ein paar Wochen abwarten, bis auch RaspberryOS auf Basis von Debian 13 'Trixie' veröffentlicht wurde und dann danach das Upgrade machen:
        https://forum.iobroker.net/topic/81187/upgrade-von-debian-12-bookworm-auf-debian-13-trixie
        • Duffy
          Ok dann werde ich das mal im Auge behalten.
          Was empfiehlst du eigentlich für einen Pi?
          Aktuell habe ich ein Raspberry pi4 mit 8Gb
          Lohnt es sich auf einen 5er umzusteigen und wieviel GB sollte der haben?
          Ich würde eine 16GB nehmen, haben ist besser als brauchen, aber brauchts das wirklich?
          VG Duffy
            Hab ich auch, mir reicht der aus. Und das wohl auch noch geraume Zeit.
            Kann ich dir nicht sagen, das hängt ja stark davon ab, was man da betreibt oder künftig noch betreiben will.
            Duffy 1 Reply Last reply Reply Quote 1
            • Duffy
              Na wenn dir der 4er reicht dann sollte er bei mir noch weitaus weiter reichem 🙂
              Danke für deine Expertise.
              VF Duffy
                @duffy
                Meiner ist aber deutlich weniger ausgelastet als deine Kiste:
                Da scheinen mir bei dir die drei? influxdb-Instanzen reinzuspielen.
                Duffy Michael Schmitt 2 Replies Last reply Reply Quote 0
                • Duffy
                  Dann muss ich wohl doch langfristig mal was machen.
                  Was mein Pi auch gerne macht, ist abstürzen wenn ich mit e-charts abfragen mache die etwas grösser sind.
                  Z.B. Balkon PV über 1-2 Monate. Da kann es schonmal sein das gar nichts mehr geht und ich sogar den Stecker ziehen muß.
                  Ich habe zwar dann einen Monitor und Tastatur am Pi dran aber er nimmt nichts mehr an.
                  VG Duffy
                  • Michael Schmitt
                    Michael Schmitt @Thomas Braun last edited by
                    @duffy
                    ab welchen Werten wird es denn bedenklich bei load average ?
                      Thomas Braun Most Active @Michael Schmitt last edited by Thomas Braun
                      @michael-schmitt sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
                      Das hängt von der Anzahl der verfügbaren Threads ab:
                      CPU threads: 4
                      Die Kiste ist also dauerhaft zur Hälfte ausgelastet.
                      Die drei Werte stellen die durchschnittliche Auslastung der letzen 1, 5 und 15 Minuten dar.
                      • Duffy
                        Duffy @Thomas Braun last edited by Duffy
                        Threads
                        Was sind den Threads (Themen)nd wie entlockt man dem Pi die Werte?
                        Und warum habe ich 2 Benutzer? OK du wirs sagen das ich das doch selber wissen muss aber ich habe nur einen angelegt und zwar den "Pi" von einem anderen wüsste ich nichts.
                        Michael Schmitt Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Michael Schmitt
                           16:15:56 up 1 day,  3:07,  1 user,  load average: 0.38, 0.28, 0.27
                          CPU threads: 4
                          na dann langweilt sich mein Pi
                          • Michael Schmitt
                            Michael Schmitt @Duffy last edited by
                            @duffy Threads = Rechenkerne des CPU (bei dir =4)
                            • Duffy
                              Duffy @Michael Schmitt last edited by
                              @michael-schmitt
                              Danke schön 🙂
                                Es gibt auch noch den user 'iobroker'.
                                • Duffy
                                  Müsste nicht @Michael-Schmitt auch 2 haben?
                                    Thomas Braun Most Active @Duffy last edited by Thomas Braun
                                    @duffy
                                    Mit
                                    who
                                    kannst du die eingeloggten user sehen.
                                    Kann auch sein, das du da gerade zwei Sessions offen hast. Zählt auch jeweils als user.
                                    • Duffy
                                      So, nun bin ich so weit das ich den Zigbee Adapter installiert habe, womit wir wieder beim Ursprungstheme wären.
                                      Leider klappt das auch wieder nicht.
                                      Ich habe die Einstellungen mit dem Aktiv Pi verglichen aber es kommt tzrotzdem folgende Meldung:
                                      Zeit
                                      zigbee.0
                                      	2025-09-09 17:54:39.814	error	Error herdsman start
                                      zigbee.0
                                      	2025-09-09 17:54:39.814	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                      zigbee.0
                                      	2025-09-09 17:54:39.804	info	Unable to obtain herdsman settings
                                      zigbee.0
                                      	2025-09-09 17:54:39.553	info	Starting Zigbee-Herdsman
                                      zigbee.0
                                      	2025-09-09 17:54:39.552	info	configured transmit power : normal
                                      zigbee.0
                                      	2025-09-09 17:54:39.549	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
                                      zigbee.0
                                      	2025-09-09 17:54:39.523	info	Starting Adapter npm ...
                                      zigbee.0
                                      	2025-09-09 17:54:39.522	info	Autostart Zigbee subsystem
                                      zigbee.0
                                      	2025-09-09 17:54:39.521	info	--- creating device debug ---
                                      zigbee.0
                                      	2025-09-09 17:54:39.517	info	delete old Backup files. keep only last 10
                                      zigbee.0
                                      	2025-09-09 17:54:39.442	info	init localConfig
                                      zigbee.0
                                      	2025-09-09 17:54:39.440	info	Adapter ready - starting subsystems. Adapter is running in info mode.
                                      zigbee.0
                                      	2025-09-09 17:54:39.395	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
                                      host.testpi
                                      	2025-09-09 17:54:36.822	info	instance system.adapter.zigbee.0 in version "3.0.5" started with pid 1097
                                      host.testpi
                                      	2025-09-09 17:54:36.417	info	"system.adapter.zigbee.0" enabled
                                      Kann es sein das ich den Zigbee USB Stick noch auf Werkseinstellungen zurücksetzen muss?
                                      LG Duffy
                                      Edit:
                                      Da ist ein rotes Kreuz dran aber auch das Ändern der Nummer führt nicht zum Erfolg.
                                      Im Protokoll schaut das jetzt so aus:
                                      Zeit
                                      admin.0
                                      	2025-09-09 18:08:03.057	info	<== Disconnect system.user.admin from ::ffff:192.168.178.116
                                      admin.0
                                      zigbee.0
                                      	2025-09-09 18:07:41.494	error	Error herdsman start
                                      zigbee.0
                                      	2025-09-09 18:07:41.494	error	Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
                                      zigbee.0
                                      	2025-09-09 18:07:41.489	info	Unable to obtain herdsman settings
                                      zigbee.0
                                      	2025-09-09 18:07:41.295	info	Starting Zigbee-Herdsman
                                      zigbee.0
                                      	2025-09-09 18:07:41.294	info	configured transmit power : normal
                                      zigbee.0
                                      	2025-09-09 18:07:41.293	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
                                      zigbee.0
                                      	2025-09-09 18:07:41.269	info	Starting Adapter npm ...
                                      zigbee.0
                                      	2025-09-09 18:07:18.556	error	Error herdsman start
                                      zigbee.0
                                      	2025-09-09 18:07:18.555	error	Starting zigbee-herdsman problem : startup failed - configuration-adapter mismatch - see logs above for more information
                                      zigbee.0
                                      	2025-09-09 18:07:18.546	warn	Network parameters on Coordinator: panID=65534 channel=0 extendedPanID=21272f2a004b1200
                                      zigbee.0
                                      	2025-09-09 18:07:18.546	warn	Network parameters in Config : panID=7908 channel=11 extendedPanID=
                                      zigbee.0
                                      	2025-09-09 18:07:18.150	info	Starting Zigbee-Herdsman
                                      zigbee.0
                                      	2025-09-09 18:07:18.149	info	configured transmit power : normal
                                      zigbee.0
                                      	2025-09-09 18:07:18.146	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
                                      zigbee.0
                                      	2025-09-09 18:07:18.121	info	Starting Adapter npm ...
                                      zigbee.0
                                      	2025-09-09 18:07:18.120	info	Autostart Zigbee subsystem
                                      zigbee.0
                                      	2025-09-09 18:07:18.119	info	--- creating device debug ---
                                      zigbee.0
                                      	2025-09-09 18:07:18.115	info	delete old Backup files. keep only last 10
                                      zigbee.0
                                      	2025-09-09 18:07:18.040	info	init localConfig
                                      zigbee.0
                                      	2025-09-09 18:07:18.038	info	Adapter ready - starting subsystems. Adapter is running in info mode.
                                      zigbee.0
                                      	2025-09-09 18:07:17.993	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
                                      und im Adapter so:
                                      reading access rights for /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                      read and write access available for /dev/serial/by-id/us
                                      overriding zigbee options with:
                                      extPanID : 03e1680xxxxxxxxxxxxxxxx
                                      panID : 7908
                                      channel : 11
                                      port : /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                      adapterType : zstack
                                      baudRate : 115200
                                      precfgkey : 0103050709xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                      flowCTRL : false
                                      Starting zigbee-herdsman...
                                      Was mache ich den nun schon wieder falsch? Kann mir bitte jemand weiter helfen?
                                      Es ist zwar nur das Testsystem aber auch gerade da solle es funktionieren.
                                      VG Duffy
                                      Asgothian 2 Replies Last reply Reply Quote 0
                                      • Asgothian
                                        Asgothian Developer @Duffy last edited by
                                        Nein, du musst die AnLeiTung lesen und befolgen.
                                        Da steht schritt für schritt was du tun musst. Einfach von wo anders übernehmen geht nicht immer.
                                        A.
                                        • Asgothian
                                          Asgothian Developer @Duffy last edited by Asgothian
                                          Du gehst nicht schritt für schritt nach der Anleitung, sondern du bastelst frei schnautze rum. Das ist Mist.
                                          A.
                                          Nachtrag: Wofür schreib ich eigentlich diese Anleitungen in 2 Sprachen, wenn sie sowieso kein ... liest und statt dessen einfach dumm herum probiert wird ? (/rant ende)
                                          Duffy 1 Reply Last reply Reply Quote 3
                                          • Duffy
                                            Duffy @Asgothian last edited by
                                            @asgothian
                                            Ich hatte die Anleitung schon verwendet aber es klappt trotzdem was nicht.
                                            1.2k
                                            81.1k
                                            1863
