    3. Einsteigerfragen
    4. Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.
      Homoran Global Moderator Administrators @Duffy last edited by
      @duffy dann steht bestimmt was passendes im log
      • Duffy
        Duffy @Homoran last edited by Duffy
        zigbee.0
        	2025-09-09 19:03:35.040	warn	Zigbee autostart option not set - omitting start of zigbee substystem!
        zigbee.0
        	2025-09-09 19:03:35.040	info	--- creating device debug ---
        zigbee.0
        	2025-09-09 19:03:35.036	info	delete old Backup files. keep only last 10
        zigbee.0
        	2025-09-09 19:03:34.958	info	init localConfig
        zigbee.0
        	2025-09-09 19:03:34.956	info	Adapter ready - starting subsystems. Adapter is running in info mode.
        zigbee.0
        	2025-09-09 19:03:34.914	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
        zigbee.0
        	2025-09-09 19:02:58.916	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        	2025-09-09 19:02:58.913	info	terminating
        zigbee.0
        	2025-09-09 19:02:58.912	info	cleanup successful
        zigbee.0
        	2025-09-09 19:02:58.911	info	zigbecontroller stopped successfully
        zigbee.0
        	2025-09-09 19:02:58.900	info	Saved local configuration data
        zigbee.0
        	2025-09-09 19:02:58.896	info	cleaning everything up...
        zigbee.0
        	2025-09-09 19:02:58.895	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
        zigbee.0
        	2025-09-09 19:02:58.891	info	Got terminate signal TERMINATE_YOURSELF
        zigbee.0
        	2025-09-09 19:01:09.431	error	Error herdsman start
        zigbee.0
        	2025-09-09 19:01:09.431	error	Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
        zigbee.0
        	2025-09-09 19:01:09.425	info	Unable to obtain herdsman settings
        zigbee.0
        	2025-09-09 19:01:09.240	info	Starting Zigbee-Herdsman
        zigbee.0
        	2025-09-09 19:01:09.239	info	configured transmit power : normal
        zigbee.0
        	2025-09-09 19:01:09.238	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
        zigbee.0
        	2025-09-09 19:01:09.225	info	Starting Adapter npm ...
        zigbee.0
        	2025-09-09 19:01:02.442	error	Error herdsman start
        zigbee.0
        	2025-09-09 19:01:02.441	error	Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
        zigbee.0
        	2025-09-09 19:01:02.436	info	Unable to obtain herdsman settings
        zigbee.0
        	2025-09-09 19:01:02.246	info	Starting Zigbee-Herdsman
        zigbee.0
        	2025-09-09 19:01:02.245	info	configured transmit power : normal
        zigbee.0
        	2025-09-09 19:01:02.244	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
        zigbee.0
        	2025-09-09 19:01:02.228	info	Starting Adapter npm ...
        zigbee.0
        	2025-09-09 18:54:30.660	error	Error herdsman start
        zigbee.0
        	2025-09-09 18:54:30.660	error	Starting zigbee-herdsman problem : startup failed - configuration-adapter mismatch - see logs above for more information
        zigbee.0
        	2025-09-09 18:54:30.651	warn	Network parameters on Coordinator: panID=9041 channel=11 extendedPanID=21272f2a004b1200
        zigbee.0
        	2025-09-09 18:54:30.650	warn	Network parameters in Config : panID=8702 channel=11 extendedPanID=
        zigbee.0
        	2025-09-09 18:54:30.273	info	Starting Zigbee-Herdsman
        zigbee.0
        	2025-09-09 18:54:30.272	info	configured transmit power : normal
        zigbee.0
        	2025-09-09 18:54:30.269	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
        zigbee.0
        	2025-09-09 18:54:30.260	info	Starting Adapter npm ...
        zigbee.0
        	2025-09-09 18:54:25.692	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
        zigbee.0
        	2025-09-09 18:53:04.681	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
        Das hier. Kam gerade noch ein Updaze rein
        • Asgothian
          Asgothian Developer @Duffy last edited by Asgothian
          @duffy sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
          Dumme frage ? Hast du den Haken bei 'zigbee automatisch starten wieder (oder immer noch) gesetzt ?
          Wenn Nein, warum nutzt du dann nicht die 'start' und 'stop' Funktion innerhalb der Zigbee Konfiguration ? (der nette play/stop) button ?
          Da kannst du versuchen zu starten, dann versuchen anzuhalten, und hast direkt auch das Log dazu. Und das noch so das man es hier besser lesen kann (siehe Screenshot)
          Wenn ja - raus damit, und alles in der Oberfläche des Admin machen - da geht deutlich mehr als mit 'start adapter / stop adapter'
          A.
          Nachtrag 2: wir können da gemeinsam auf Discord drauf schauen, wenn du mic und ton hast. Ich sitz da im 2 user only
          • Duffy
            Duffy @Asgothian last edited by Duffy
            @asgothian
            Autostart ist noch nicht aktiviert.
            Du meinst diesen
            nicht diesen
            beim druck auf diesen
            kommt das
            overriding zigbee options with:
            extPanID : 602b3cc4c9e55067
            panID : 8702
            channel : 11
            port : /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            adapterType : zstack
            baudRate : 115200
            precfgkey : 01030507090B0D0F000xxxxxxx
            flowCTRL : false
            Starting zigbee-herdsman...
            Network parameters in Config     : panID=8702 channel=11 extendedPanID=602b3cc4c9exxxxxxxxxxx
            Network parameters on Coordinator: panID=9041 channel=11 extendedPanID=21272f2xxxxxxxxxxx
            Muss nur kurz zum Essen sonst kann ich mir heute Nacht einen Schlafplatz unter der Brücke suchen. Melde mich gleich noch mal.
            • Asgothian
              Und da steht was nicht passt. Also nvram read, damit es passt, und dann nochmal versuchen zu starten (mit dem start-stop button). Die Zigbee Einstellungen nie verlassen.
              A.
              • Duffy
                @asgothian
                NVram gedrückt
                dann
                gedrückt
                extPanID : 21272f2a004b1200
                panID : 9041
                channel : 11
                baudRate : 115200
                precfgkey : 01030507090b0d0f00020406080a0c0d
                flowCTRL : false
                aus zweiter iob Session den Log ausgelesen, sollte die Einstellungen ja nicht verlassen:
                02
                Log-Größe: 41.7 KB
                Zeit
                zigbee.0
                	2025-09-09 19:11:41.523	info	Device '0xbc026efffe00466f' announced itself
                zigbee.0
                	2025-09-09 19:08:24.187	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
                Aber leider bleibt der Adapter gelb:
                • Asgothian
                  @asgothian
                  Klar - steht da ja auch.
                  Cannot lock port bedeutet dass der Prozess der die serielle Schnittstelle belegt nicht sauber beendet wurde. Die Lösung dazu ist:
                  • stick abziehen
                  • 20 s warten
                  • stick einstecken
                  • nochmal start drücken
                  Das OS gibt den Port nicht frei.
                  Wenn ich das irgendwann mal stabil im debugger habe wird der Adapter das auch erkennen und beheben.
                  A.
                  Duffy 1 Reply Last reply Reply Quote 1
                  • Duffy
                    @asgothian
                    Es läuft endlich vielen Dank für deinen Support.
                    Ich hatte den Testpi einfach neu gestartet wodurch vermutlich der Port wieder freigegeben wurde.
                    Jetzt habe ich auch den "start the Zigbee network" hacken gesetzt.
                    Ein Fenstersensor ist Testhalber auch gekoppelt. (funktioniert)
                    Vielleicht noch zur Erklärung für mich. Was macht des NVRam lesen bzw löschen?
                    Greift das direkt auf den USB Stick zu was beim löschen auch zur folge hätte das alle angelernten Geräte gelöscht wrerden?
                    Das war jetzt eine schwere Geburt; jetzt schnell aus machen bevor wieder was in die Hosen geht.
                    Danke noch mal und VG
                    Duffy
                      ja
                      • Asgothian
                        Asgothian Developer @Homoran last edited by Asgothian
                        @homoran sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
                        ja
                        Jein. - ja, man muss zumeist neu anlernen, nein, es greift nicht auf den USB Stick zu - geht also auch wenn man da keinen Zugriff drauf hat.
                        Die Bezeichnung ist etwas verwirrend - eigentlich ist es 'nvram backup lesen' und 'nvram backup löschen'
                        Es geht dabei um eine Datei nvbackup.json, die je nach Koordinator existiert oder nicht.
                        Beim Lesen werden die Werte aus der nvbackup in die Konfiguration übertragen. Dann kann testweise gestartet werden, ohne die Parameter zu speichern. Wenn es geht, gut.
                        Beim nvbackup löschen wird diese Datei gelöscht. Damit wird dann das Zigbee-Netzwerk als neues Netzwerk aufgesetzt - ggf. auch mit anderen Parametern als zuvor.
                        Diese Meldungen vergleichen das was der Adapter versucht zu setzen und was entweder auf dem Koordinator oder in der nvbackup.json gespeichert ist. Das macht der Zigbee-Herdsman, nicht der Adapter.
                        in config is tads was du eingestellt hast, on coordinator ist das was via nvram oder nvbackup existiert.
                        Solange das nicht überein stimmt verweigert der Adapter den Start. Das kann man durch den Haken 'mit inkonsistenter Konfiguration starten' umgehen - soll man aber nicht.
                        An dieser Stelle wird es jetzt etwas kompliziert.
                        Je nach Parameter, Koordinator, Geräten bedeutet ein löschen des nvbackup das auch die Geräte auf dem Koordinator gelöscht werden. Aber halt nicht immer. Insbesondere haben einige Netzwerk-Koordinatoren echtes nvRam - das wird nicht gelöscht. Die meisten USB Sticks haben kein nvram - deswegen das Backup. Bedeutet auch das man (sofern man den gleichen typ nutzt, und den richtig konfiguriert hat) den Stick einfach gegen einen anderen ersetzen kann. Das mach ich hier immer mal wieder mit 1 von 4 TI-Based Koordinatoren 🙂
                        Neu anlernen muss man zumeist trotzdem, weil sich die Netzwerk Verschlüsselung ändert (durch andere PanID / ExtPanID)
                        A.
                        Homoran Duffy 2 Replies Last reply Reply Quote 1
                          Homoran Global Moderator Administrators @Asgothian last edited by
                          @asgothian Danke für diese erweiterte Schulung!
                          ich hielt die nvbackup immer für eine Sicherungskopie des nvram.
                          und nvram Auslesen dementsprechend für das Auslesen des echten nvRam
                          • Duffy
                            @asgothian
                            Vielen Dank für deine ausführliche Erörterung.
                            Bisher konnte ich ja den Zigbee Adapter stoppen, den USB Koordinator abstecken und durch einen anderen frisch aufgesetzen Koordinator (Neue Firmware) wieder anstecken, den Adapter neu starten und es wurden alle Einstellungen wieder übernommen so das man nahtlos weitermachen konnt.
                            Ist das jetzt auch noch möglich weil du schreibst es müssten möglicherweise die Geräte neu angelernt werden?
                            VG Duffy
                            • Asgothian
                              @asgothian
                              VG Duffy
                              Neue Firmware, gleicher Chipsatz => geht gleich weiter.
                              Neue Firmware, neuer Chipsatz => kann gehen, muss nicht
                              A.
                              • Duffy
                                @asgothian
                                Vielen Dank
                                • Sleepless135
                                  Sleepless135 last edited by
                                  Moin,
                                  ich hoffe ich bin hier richtig, hatte danach gesucht aber nichts wirklich gefunden.
                                  Habe auf zwei Instanzen Zigbee Adapter 2.0.5 nach dem Upgrade auf 3.0.5 sind alle Geräte verschwunden.
                                  Muss ich bei dem Upgrade alle Geräte neu Anlernen ? Habe gut 30 Stück in der Wohnung verteilt. Würde mir die Arbeit gerne Sparen.
                                  Mit besten Grüßen aus dem halb Smart Home
                                  Tim
                                  Fabio 1 Reply Last reply Reply Quote 0
                                  • Fabio
                                    Fabio @Sleepless135 last edited by
                                    @sleepless135 sind die Adapter grün.Was sagt das Log.
                                    • Sleepless135
                                      Moin,
                                      nach dem Update startet der Adapter durch und läuft, es ist nur kein Gerät mehr aufgelistet.
                                      Gut das ich davor ein Snapshot gemacht hatte 😉
                                      • Asgothian
                                        Asgothian Developer @Sleepless135 last edited by
                                        @sleepless135 sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
                                        Moin,
                                        Bist du sicher das der Adapter durchstartet ?
                                        Hast du den Haken bei start the Zigbee network automatically gesetzt ?
                                        Und wie schon @Fabio schrieb:
                                        Das Log vom start des Adapters hilft ungemein. Warum postest Du es nicht ?
                                        A.
                                        Sleepless135 1 Reply Last reply Reply Quote 1
                                        • Sleepless135
                                          Sleepless135 @Asgothian last edited by
                                          @asgothian
                                          ok ich bin ein Idiot -.- nächste Runde geht auf mich -.-
                                          Dachte mit Automatisch starten, das sich der Adapter nicht startet. Hacken rein alles wieder da.
                                          Nächste Runde geht auf mich, entschuldig für mein nicht Nachdenken.
                                          1.2k
                                          81.1k
                                          1863
