Test Adapter Linux Control v1.x.x
Fehler gefunden....
Ich hatte noch keinen openssh Server auf dem Desktop installiertJetzt geht es.
Danke -
ich habe auch probleme mit dem Adapter
über Putty kann ich ohne probleme zugreifen
Mein IObroker ist bei allem auf aktuellen stand
Node.js: v20.19.4
JS Controller 7.0.6
Adapter. 1.1.5host.iOBroker 2025-08-13 20:44:20.577 info "system.adapter.linux-control.0" disabled linux-control.0 2025-08-13 20:44:06.264 error Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string" host.iOBroker 2025-08-13 20:44:05.094 info instance system.adapter.linux-control.0 in version "1.1.5" started with pid 3987 host.iOBroker 2025-08-13 20:43:34.740 info Restart adapter system.adapter.linux-control.0 because enabled host.iOBroker 2025-08-13 20:43:34.740 error instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[14]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[14]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[14]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[14]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[14]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[13]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[13]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[13]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[13]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[13]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[12]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[12]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[12]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[12]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[12]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[11]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[11]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[11]: ReplyError: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[11]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[10]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[10]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[10]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[10]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[9]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[9]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[9]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[9]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[9]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[8]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[8]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[8]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[8]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[7]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[7]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[7]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[7]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.740 error Caught by controller[5]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[5]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[5]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[5]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[5]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[4]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[4]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[4]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[4]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[3]: at processTicksAndRejections (node:internal/process/task_queues:95:5) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[3]: at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[3]: at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[3]: Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[2]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[2]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[2]: ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[1]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[1]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[1]: ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern host.iOBroker 2025-08-13 20:43:34.739 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: linux-control.0 2025-08-13 20:43:34.634 error [needrestart] hyperion (192.168.178.67:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4272:19) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4346:33) linux-control.0 2025-08-13 20:43:34.595 error Cannot find view "system" for search "state" : Connection is closed. linux-control.0 2025-08-13 20:43:34.593 error [servicesInfo] hyperion (192.168.178.67:22): error: DB closed, stack: Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:639:26) at Socket.emit (node:events:524:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:343:12) linux-control.0 2025-08-13 20:43:34.554 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.554 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.554 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.553 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.515 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.515 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.515 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.514 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.480 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.480 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.479 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.479 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.464 error Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.463 error ReplyError: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14) linux-control.0 2025-08-13 20:43:34.463 error unhandled promise rejection: Error The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.463 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). host.iOBroker-Server 2025-08-13 20:43:34.462 warn States 127.0.0.1:45704 Error from InMemDB: Error: The pattern "linux-control.0.hyperion.services.systemd-fsck@dev-disk-by\x2dpartuuid-2f6f3587\x2d01.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:242:14) at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26) at RedisHandler.emit (node:events:524:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37) at processImmediate (node:internal/timers:483:21) linux-control.0 2025-08-13 20:43:34.436 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.436 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.435 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.435 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.366 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.366 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.365 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.365 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.351 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.351 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.351 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.350 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.288 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.288 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.287 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.287 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.256 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.256 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.255 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.255 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.215 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.215 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.215 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.215 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.194 error The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.194 error Error: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at Module.pattern2RegEx (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2490:15) at StateRedisClient.subscribe (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1127:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) linux-control.0 2025-08-13 20:43:34.145 error unhandled promise rejection: The pattern "io.linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.145 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). linux-control.0 2025-08-13 20:43:34.138 error ReplyError: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14) linux-control.0 2025-08-13 20:43:34.138 error unhandled promise rejection: Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.138 error Error The pattern "linux-control.0.hyperion.services.●.restart" is not a valid ID pattern linux-control.0 2025-08-13 20:43:34.137 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
@denjo sagte in Test Adapter Linux Control v1.x.x:
Ist das Problem
Moin,
leider bekomme ich neuerdings nur noch die Meldungen: "Host seems not to be online".
Ich habe den Adapter in Version 1.1.6 installiert.Ping vom anderen Rechner bzw. Server auf den Host gehen ohne Probleme. Auch die ssh Verbindung von der iobroker shell zum betreffenden Host gehen ohne Probleme.
iputils-ping habe ich neu installiert.
Hat jemand eine Idee woran es liegen könnte?
@flispy sagte in Test Adapter Linux Control v1.x.x:
Moin,
hab es lösen können. Ich musste folgendes ausführen
sudo setcap cap_net_raw+p /usr/bin/ping
Moin,
Geht wieder, habe den Befehl auf dem iobroker ausgeführt. Danke!
Hallo zusammen
Ich hab heut Trixie (Debian 13) unter Proxmox getestet und da erscheint diese Meldung
[getConnection] Host 'Name' (IP:Port) seems not to be online
"Ping wird nicht mehr mit erhöhten Privilegien ausgeführt"
Quelle hierHeisst unter einem anderen User außer root geht der befehl "Ping" nicht mehr.
Wird aber vom Adapter benötigt um zu schauem ob er online ist.Abhilfe steht im Link und ist relativ einfach:
- Anmelden
- sudo nano /usr/lib/sysctl.d/50-default.conf
- nach "net.ipv4.ping_group_range = .........." suchen und gegen "net.ipv4.ping_group_range = 1 1000" ersetzen.
- Speichern und Neustarten
Liebe Grüße
@fichte
danke für den Hinweis, Ping arbeitet wieder -
@fichte auch nach einem Restart ?
@wendy2702 Ja Punkt 4
@fichte sagte in Test Adapter Linux Control v1.x.x:
Hallo zusammen
- Anmelden
Liebe Grüße
Muss das auf jedem server durchgeführt werden oder nur auf dem iob?
@mading nur auf dem wo der Linux Control Adapter läuft.
