    3. Off Topic
    4. Pflege des Betriebssystems
    5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
      Thomas Braun Most Active @sunny9999 last edited by
      @sunny9999 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
      bleibt bei Deiner Befehlsfolge die Asterisk erhalten ?
      Musst du schauen. Ist asterisk noch in den Standardquellen drin?
      Muss da evtl. eine externe Quelle angelegt werden?
      apt policy asterisk
      sagt dir das ggfls.
      Michael Schmitt 2 Replies Last reply Reply Quote 0
      • Michael Schmitt
        Michael Schmitt @Thomas Braun last edited by Michael Schmitt
        scheint alles funktioniert zu haben 😉
        ========== Start marking the full check here ===========
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.34+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         17:50:13 up  4:42,  1 user,  load average: 0.38, 0.28, 0.29
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-09-08 17:50:13 CEST
                   Universal time: Mon 2025-09-08 15:50:13 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        SUDO_HOME=/home/pi
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            4.0G        2.6G        778M         10M        694M        1.4G
        Swap:           536M          0B        536M
        Total:          4.5G        2.6G        1.3G
        Active iob-Instances:   20
                 3795 M total memory
                 2486 M used memory
                 2469 M active memory
                  388 M inactive memory
                  742 M free memory
                   71 M buffer memory
                  591 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        top - 17:50:13 up  4:42,  1 user,  load average: 0.43, 0.30, 0.29
        Tasks: 205 total,   1 running, 204 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.2 us,  0.0 sy,  0.0 ni, 97.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.8 total,    743.3 free,   2486.3 used,    662.7 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1309.5 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  6.6M  374M   2% /run
        /dev/sda2      ext4      220G  5.4G  204G   3% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G  3.0M  1.9G   1% /tmp
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
        /dev/sda1      vfat      510M   65M  446M  13% /boot/firmware
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
        tmpfs          tmpfs     380M   12K  380M   1% /run/user/1000
        [Mon Sep  8 13:08:00 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:05:E3:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e74f749d-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
        [Mon Sep  8 13:08:02 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
        [Mon Sep  8 13:08:04 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
        Show mounted filesystems:
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        872M    /var/
        185M    /var/lib
        172M    /var/cache
        164M    /var/cache/apt
        144M    /var/lib/apt
        Archived and active journals take up 5.3M in the file system.
        /opt/iobroker/backups:
        162M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        365M    /opt/iobroker/iobroker-data/
        168M    /opt/iobroker/iobroker-data/files
        103M    /opt/iobroker/iobroker-data/backup-objects
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
        90M     /opt/iobroker/iobroker-data/objects.jsonl
        8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
        8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
        5.1M    /opt/iobroker/iobroker-data/states.jsonl
        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2419780-if00
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.19.0
        /usr/bin/node           v22.19.0
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.19.0-1nodesource1
          Candidate: 22.19.0-1nodesource1
          Version table:
         *** 22.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             20.19.2+dfsg-1 500
                500 http://deb.debian.org/debian trixie/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 16932)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.6.17
        javascript:     8.9.2
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
          system.adapter.devices.0                : devices               : raspberrypi                              - disabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
        + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.matter.0                 : matter                : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'stable'           │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 2       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "deconz"       : 1.6.4    , installed 1.6.4
        Adapter    "devices"      : 1.1.5    , installed 1.2.8
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "iot"          : 3.3.0    , installed 3.6.0
        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "matter"       : 0.5.2    , installed 0.5.2
        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 3.0.19
        Objects and States
        Objects:        5779
        States:         4283
        W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
        Hit:1 http://deb.debian.org/debian trixie InRelease
        Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Hit:4 http://phoscon.de/apt/deconz generic InRelease
        Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
        Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       12609      1535/io.socketio.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7397       1015/exim4
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6984       721/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6989       721/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6864       738/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       7169       529/deCONZ
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       5117       529/deCONZ
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9303       1040/io.admin.1
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12549      1509/io.simple-api.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12746      1746/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7087       1029/io.admin.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7398       1015/exim4
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6866       738/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       123306     11803/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       123292     11803/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       123284     11803/io.matter.0
        udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       11333      1410/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4931       523/avahi-daemon: r
        udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       123301     11803/io.matter.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10653      1312/io.deconz.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       8196       529/deCONZ
        udp        0      0 0.0.0.0:44997           0.0.0.0:*                           104        4933       523/avahi-daemon: r
        udp6       0      0 fe80::62d5:ebcd:e5c:546 :::*                                0          7295       701/NetworkManager
        udp6       0      0 :::42215                :::*                                104        4934       523/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                1001       123307     11803/io.matter.0
        udp6       0      0 :::5353                 :::*                                1001       123295     11803/io.matter.0
        udp6       0      0 :::5353                 :::*                                1001       123287     11803/io.matter.0
        udp6       0      0 :::5353                 :::*                                104        4932       523/avahi-daemon: r
        udp6       0      0 :::5540                 :::*                                1001       123300     11803/io.matter.0
        udp6       0      0 :::1900                 :::*                                1001       10656      1312/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       10655      1312/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       10654      1312/io.deconz.0
        2025-09-08 16:42:06.727  - info: email.0 (1058) terminating
        2025-09-08 16:42:07.008  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-09-08 16:42:20.939  - info: host.raspberrypi "system.adapter.email.0" enabled
        2025-09-08 16:42:22.603  - info: host.raspberrypi instance system.adapter.email.0 in version "2.0.4" started with pid 12291
        2025-09-08 16:42:25.327  - info: email.0 (12291) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v22.19.0, js-controller: 7.0.7
        2025-09-08 16:42:37.080  - info: javascript.0 (1141) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: email.0 is connected
        Wert: false
        Adapter NICHT erreichbar
        2025-09-08 16:43:10.364  - info: javascript.0 (1141) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: email.0 is connected
        Wert: true
        Adapter ist wieder erreichbar
        2025-09-08 16:43:34.817  - info: admin.0 (1029) <== Disconnect system.user.admin from ::ffff:192.168.178.76 admin
        2025-09-08 16:43:35.934  - info: admin.0 (1029) <== Disconnect system.user.admin from ::ffff:192.168.178.76 devices
        2025-09-08 16:43:35.936  - info: admin.0 (1029) <== Disconnect system.user.admin from ::ffff:192.168.178.76 admin
        2025-09-08 16:43:41.620  - info: admin.0 (1029) <== Disconnect system.user.admin from ::ffff:192.168.178.76 admin
        2025-09-08 17:00:00.085  - info: javascript.0 (1141) script.js.common.Müllkalender.Müllerinnerung: telegram['Michael']: Morgen wird die Biotonne abgeholt
        2025-09-08 17:07:18.731  - info: javascript.0 (1141) script.js.common.Tür_Fenster_Sensoren.Wohnungstüre: telegram[Michael]: Wohnungstür wurde geöffnet !
        2025-09-08 17:07:40.805  - info: javascript.0 (1141) script.js.common.Tür_Fenster_Sensoren.Wohnungstüre: telegram[Michael]: Wohnungstür wurde geschlossen !
        2025-09-08 17:11:34.535  - info: javascript.0 (1141) script.js.common.Anwesendheitscheck.Marvin_PC_AN_AUS_Wlan: telegram['Michael']: Marvin Pc wurde angemacht (Wlan)
        2025-09-08 17:11:35.288  - info: javascript.0 (1141) script.js.common.Anwesendheitscheck.Marvin_I_Phone_Anwesend_JA_NEIN: telegram[Michael]: Marvin IPhone ist im Wlan
        2025-09-08 17:30:00.047  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.16.2" started with pid 14347
        2025-09-08 17:30:02.903  - info: ical.0 (14347) starting. Version 1.16.2 in /opt/iobroker/node_modules/iobroker.ical, node: v22.19.0, js-controller: 7.0.7
        2025-09-08 17:30:03.818  - info: ical.0 (14347) processing URL: Müllkalender https://calendar.google.com/calendar/ical/8n95sqg3r88betcpncgkhe3m8c%40group.calendar.google.com/private-32cc3a968fd521a665efcc600d6ce4d4/basic.ics
        2025-09-08 17:30:09.127  - info: ical.0 (14347) Terminated (NO_ERROR): Without reason
        2025-09-08 17:30:09.681  - info: host.raspberrypi instance system.adapter.ical.0 having pid 14347 terminated with code 0 (NO_ERROR)
        • Michael Schmitt
          was bedeutet denn diese Meldung? Hab ich gerade bei einem update erhalten.
          pi@raspberrypi:~ $ sudo apt update
          All packages are up to date.
          Warning: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          Notice: Missing Signed-By in the sources.list(5) entry for 'http://phoscon.de/apt/deconz'
          Notice: Missing Signed-By in the sources.list(5) entry for 'http://archive.raspberrypi.com/debian'
            Thomas Braun Most Active @Michael Schmitt last edited by Thomas Braun
            @michael-schmitt
            Deine Quellen sind nicht richtig aufgesetzt und es gibt Probleme mit den Signaturen.
            Bei nodesource kannst du noch nichts machen, da gibt es noch keinen aktuellen Signaturschlüssel.
            Bei den anderen beiden Dateien musste mal schauen was drin steht.
            cat /etc/apt/sources.list.d/deconz*
            cat /etc/apt/sources.list.d/raspi*
            Michael Schmitt 1 Reply Last reply Reply Quote 0
            • Michael Schmitt
              pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/deconz*
              deb http://phoscon.de/apt/deconz             generic main
              Types: deb
              URIs: http://phoscon.de/apt/deconz/
              Suites: generic
              Components: main
              Signed-By:
              pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/raspi*
              deb http://archive.raspberrypi.com/debian/ trixie main
              # Uncomment line below then 'apt-get update' to enable 'apt-get source'
              #deb-src http://archive.raspberrypi.com/debian/ trixie main
              Types: deb
              URIs: http://archive.raspberrypi.com/debian/
              Suites: trixie
              Components: main
              Signed-By:
              EDIT: war wohl ein "cat" zuviel
                @michael-schmitt
                Das sind Doubletten und Dateien im neuen Format.
                Lösch die deconz.list und deconz.sources und leg die neu an:
                wget -qO- http://phoscon.de/apt/deconz.pub.key | sudo gpg --dearmor -o /etc/apt/keyrings/deconz.gpg > /dev/null
                sudo sh -c "echo 'deb [signed-by=/etc/apt/keyrings/deconz.gpg] http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
                Bei der raspi.sources fehlt der Eintrag zur Signatur. Und es ist wohl auch eine Doublette, es wird da auch noch eine raspi.list geben.
                raspi.sources schaut bei mir so aus:
                Types: deb
                Suites: trixie
                Components: main
                Signed-By: /usr/share/keyrings/raspberrypi-archive-keyring.pgp
                Michael Schmitt 1 Reply Last reply Reply Quote 1
                • Michael Schmitt
                  muß dann die raspi.list auch weg ? und wie ändere ich die raspi.sources?
                    @michael-schmitt sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                    Ja, entweder .list oder .sources. Beides gleichzeitig führt zu Chaos.
                    Mit einem Editor? nano?
                    • Michael Schmitt
                      Ign:1 http://phoscon.de/apt/deconz trixie InRelease
                      Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
                      Hit:3 http://deb.debian.org/debian trixie InRelease
                      Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
                      Hit:5 http://deb.debian.org/debian trixie-updates InRelease
                      Err:6 http://phoscon.de/apt/deconz trixie Release
                        404  Not Found [IP: 144.76.96.194 80]
                      Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                      Error: The repository 'http://phoscon.de/apt/deconz trixie Release' does not have a Release file.
                      Notice: Updating from such a repository can't be done securely, and is therefore disabled by default.
                      Notice: See apt-secure(8) manpage for repository creation and user configuration details.
                      pi@raspberrypi:~ $
                        Es gibt noch keine Veröffentlichung für trixie. Stell da einstweilen bookworm ein.
                        Michael Schmitt Thomas Braun 2 Replies Last reply Reply Quote 1
                        • Michael Schmitt
                          so aber jetzt
                          Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
                          Hit:2 http://deb.debian.org/debian trixie InRelease
                          Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
                          Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                          pi@raspberrypi:~ $
                            @michael-schmitt
                            Jetzt passt es.
                            • Michael Schmitt
                              @thomas-braun viiieeeelllleeen Dank
                              da ist noch eine nodesource.list.bak drin, kann die auch weg ?
                                Jan1 @Michael Schmitt last edited by
                                @michael-schmitt
                                Das ist da Buckup der vorherigen nodesource.list, kann weg, muss aber nicht.
                                  Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                                  @thomas-braun sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                                  Hab gerade nochmal geschaut, das Repo verwendet nun keine release names mehr sondern nur noch generische Pakete.
                                  Ersetze also den Eintrag bookworm durch generic.
                                  Michael Schmitt 1 Reply Last reply Reply Quote 2
                                  • Michael Schmitt
                                    @thomas-braun erledigt 😉
                                    Hit:3 http://phoscon.de/apt/deconz generic InRelease
                                    pi@raspberrypi:~ $
                                    • fuzzy1955
                                      fuzzy1955 @Thomas Braun last edited by fuzzy1955
                                      Hi!
                                      Danke für die erstklassige Anleitung zum Upgrade auf Debian 13 "Trixie"! Für mich als 2025-Linux-Newbie war das sehr schlüssig nachvollziehbar und das Upgrade hat wunderbar geklappt. Natürlich - ein paar alte MS DOS Kenntnisse aus den 80ern waren hilfreich 😊
                                      Gruß, hf
                                      Edit: Das Upgrade bezog sich auf einen produktiven Raspi 5 per SSH via Putty. Auf dem darauf installiertem IOB mit einer mySQL-Datenbank läuft seit einigen Wochen das gesamte Strommanagement meines Hauses (PV, WR, Akku, 2 Wallboxen, Not- und Fremdstrombezug) sowie die Klimatisierungssteuerung (Solarluft, Pelletsofen, WW-Boiler, Kühlung). Und natürlich die Auswertung der relevanten Infos.
                                      • meute
                                        meute last edited by meute
                                        ich habe nun auch nach der Top-Anleitung das Debian-Upgrade von 12 bookworm zu 13 trixie gemacht. 👍
                                        Debian läuft in einem LXC-Container auf Proxmox.
                                        Es hat soweit geklappt.
                                        Aber ich erhalte bei iob diag einen npm error.
                                        Wie kann ich den Fehler beheben?
                                        $ iob diag
                                        [sudo] Passwort für mf:
                                        *** iob diag is starting up, please wait ***
                                        npm error code ELSPROBLEMS
                                        npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                                        npm error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
                                        npm error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
                                        npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
                                        npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
                                        npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
                                        npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
                                        npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
                                        *** ioBroker Diagnosis ***
                                        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                        https://forum.iobroker.net
                                        Just copy and paste the Summary Page, including the ``` characters at start and end.
                                        It helps us to help you!
                                        * Some output is masked. For full results please use 'iob diag --unmask' *
                                        Press any key to continue
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                         Static hostname: iobroker84
                                               Icon name: computer-container
                                                 Chassis: container ☐
                                          Virtualization: lxc
                                                  Kernel: Linux 6.14.11-3-pve
                                            Architecture: x86-64
                                        OS is similar to:
                                        model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
                                        Docker          : false
                                        Virtualization  : lxc
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         11:42:36 up 3 min,  1 user,  load average: 0.80, 1.12, 1.01
                                        CPU threads: 2
                                                       Local time: Sun 2025-10-12 11:42:36 CEST
                                                   Universal time: Sun 2025-10-12 09:42:36 UTC
                                                         RTC time: n/a
                                                      NTP service: inactive
                                                  RTC in local TZ: no
                                        mf
                                        HOME=/home/mf
                                        GROUPS=mf adm sudo users iobroker lxc_shares
                                        iobroker
                                        HOME=/home/iobroker
                                        SUDO_HOME=/home/mf
                                        GROUPS=iobroker tty dialout audio video plugdev lxc_shares
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:            4.3G        1.3G        2.6G        3.9M        470M        3.0G
                                        Swap:           536M          0B        536M
                                        Total:          4.8G        1.3G        3.1G
                                        Active iob-Instances:   15
                                                 4096 M total memory
                                                 1203 M used memory
                                                 1449 M active memory
                                                  127 M inactive memory
                                                 2446 M free memory
                                                    0 M buffer memory
                                                  449 M swap cache
                                                  512 M total swap
                                                    0 M used swap
                                                  512 M free swap
                                        top - 11:42:37 up 3 min,  1 user,  load average: 0.80, 1.12, 1.01
                                        Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  4.0 us,  4.0 sy,  0.0 ni, 88.0 id,  4.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   4096.0 total,   2445.0 free,   1205.2 used,    449.4 buff/cache
                                        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2890.8 avail Mem
                                          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                                        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                                SUB    -> The low-level unit activation state, values depend on unit type.
                                        2 loaded units listed.
                                        dmesg: read kernel buffer failed: Operation not permitted
                                        *** FILESYSTEM ***
                                        Filesystem                                  Type      Size  Used Avail Use% Mounted on
                                        /dev/mapper/pve-vm--100--disk--0            ext4       12G  7.7G  3.5G  70% /
                                        //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs      467G   51G  416G  11% /mnt/nas8
                                        none                                        tmpfs     492K  4.0K  488K   1% /dev
                                        udev                                        devtmpfs  9.7G     0  9.7G   0% /dev/tty
                                        tmpfs                                       tmpfs     9.7G     0  9.7G   0% /dev/shm
                                        tmpfs                                       tmpfs     3.9G  3.3M  3.9G   1% /run
                                        tmpfs                                       tmpfs     5.0M     0  5.0M   0% /run/lock
                                        tmpfs                                       tmpfs     9.7G  460K  9.7G   1% /tmp
                                        tmpfs                                       tmpfs     2.0G  8.0K  2.0G   1% /run/user/1000
                                        /           /dev/mapper/pve-vm--100--disk--0            ext4   rw,relatime,stripe=16
                                        `-/mnt/nas8 //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs   rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=fritznas,uid=100000,forceuid,gid=110000,forcegid,addr=192.168.23.8,file_mode=0770,dir_mode=0770,soft,nounix,mapposix,reparse=nfs,nativesocket,symlink=native,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
                                        /var:
                                        2.7G    /var/
                                        1.3G    /var/log/journal
                                        1.3G    /var/log
                                        1.2G    /var/cache/apt
                                        1.2G    /var/cache
                                        Archived and active journals take up 1G in the file system.
                                        69M     /opt/iobroker/backups/
                                        369M    /opt/iobroker/iobroker-data/
                                        300M    /opt/iobroker/iobroker-data/files
                                        67M     /opt/iobroker/iobroker-data/files/echarts.admin
                                        61M     /opt/iobroker/iobroker-data/files/echarts
                                        53M     /opt/iobroker/iobroker-data/backup-objects
                                        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                                        26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                                        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                        24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                                        18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/nodejs         v22.20.0
                                        /usr/bin/node           v22.20.0
                                        /usr/bin/npm            11.6.2
                                        /usr/bin/npx            11.6.2
                                        nodejs:
                                          Installed: 22.20.0-1nodesource1
                                          Candidate: 22.20.0-1nodesource1
                                          Version table:
                                         *** 22.20.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                             20.19.2+dfsg-1 500
                                                500 http://deb.debian.org/debian trixie/main amd64 Packages
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker84          iobroker84 (version: 7.0.7, hostname: iobroker84    , alive, uptime: 183)
                                        admin:          7.7.2
                                        javascript:     8.9.2
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.alias-manager.0          : alias-manager         : iobroker84                               - disabled
                                        + system.adapter.backitup.0               : backitup              : iobroker84                               -  enabled
                                        + system.adapter.discovery.0              : discovery             : iobroker84                               -  enabled
                                        + system.adapter.echarts.0                : echarts               : iobroker84                               -  enabled
                                          system.adapter.ical.0                   : ical                  : iobroker84                               -  enabled
                                        + system.adapter.influxdb.0               : influxdb              : iobroker84                               -  enabled, port: 8086
                                        + system.adapter.iqontrol.0               : iqontrol              : iobroker84                               -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker84                               -  enabled
                                        + system.adapter.modbus.0                 : modbus                : iobroker84                               -  enabled
                                          system.adapter.ping.0                   : ping                  : iobroker84                               - disabled
                                        + system.adapter.shelly.0                 : shelly                : iobroker84                               -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonoff.0                 : sonoff                : iobroker84                               -  enabled, port: 1885, bind: 0.0.0.0
                                        + system.adapter.tr-064.0                 : tr-064                : iobroker84                               -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : iobroker84                               -  enabled
                                        + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker84                               -  enabled
                                        + instance is alive
                                        Adapter    "admin"        : 7.7.2    , installed 7.7.2
                                        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                        Adapter    "ical"         : 1.17.0   , installed 1.17.0
                                        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                        Adapter    "shelly"       : 10.2.0   , installed 10.2.0
                                        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                        Objects and States
                                        Objects:        1346
                                        States:         1056
                                        Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                                        Hit:3 http://security.debian.org trixie-security InRelease
                                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                                        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30392745   277/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30392287   277/iobroker.js-con
                                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          30392581   264/smbd
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30390652   1/init
                                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          30392580   264/smbd
                                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       30393200   450/io.sonoff.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30392832   313/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30396478   525/io.web.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        30392118   192/influxd
                                        tcp6       0      0 :::139                  :::*                    LISTEN      0          30392579   264/smbd
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          30390654   1/init
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          30391102   1/init
                                        tcp6       0      0 :::445                  :::*                    LISTEN      0          30392578   264/smbd
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30390653   1/init
                                        udp        0      0 192.168.23.255:137      0.0.0.0:*                           0          30392381   222/nmbd
                                        udp        0      0 192.168.23.84:137       0.0.0.0:*                           0          30392380   222/nmbd
                                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          30392368   222/nmbd
                                        udp        0      0 192.168.23.255:138      0.0.0.0:*                           0          30392383   222/nmbd
                                        udp        0      0 192.168.23.84:138       0.0.0.0:*                           0          30392382   222/nmbd
                                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          30392369   222/nmbd
                                        udp        0      0 192.168.23.84:5353      0.0.0.0:*                           1001       30396440   495/io.tr-064.0
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30393134   430/io.shelly.0
                                        udp6       0      0 :::111                  :::*                                0          30390655   1/init
                                        2025-10-12 11:40:23.767  - info: host.iobroker84 instance system.adapter.web.0 in version "7.0.8" started with pid 525
                                        2025-10-12 11:40:25.537  - info: web.0 (525) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
                                        2025-10-12 11:40:25.795  - info: web.0 (525) socket.io server listening on port 8082
                                        2025-10-12 11:40:25.799  - info: web.0 (525) http server listening on port 8082
                                        2025-10-12 11:40:27.762  - info: host.iobroker84 instance system.adapter.iqontrol.0 in version "3.0.0" started with pid 540
                                        2025-10-12 11:40:29.125  - info: iqontrol.0 (540) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v22.20.0, js-controller: 7.0.7
                                        2025-10-12 11:40:29.169  - info: iqontrol.0 (540) systemLanguage = de
                                        2025-10-12 11:40:29.170  - info: iqontrol.0 (540) Creating Passphrase...
                                        2025-10-12 11:40:29.217  - info: iqontrol.0 (540) Creating Popup States...
                                        2025-10-12 11:40:29.290  - info: iqontrol.0 (540) Creating Widget States...
                                        2025-10-12 11:40:29.291  - info: iqontrol.0 (540) Lists deactivated.
                                        2025-10-12 11:40:29.292  - info: iqontrol.0 (540) Deleting unused Objects...
                                        2025-10-12 11:40:29.292  - info: iqontrol.0 (540) Subscribing to states...
                                        2025-10-12 11:40:29.294  - info: iqontrol.0 (540) iQontrol ready.
                                        2025-10-12 11:40:31.715  - info: host.iobroker84 instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 555
                                        2025-10-12 11:40:33.165  - info: trashschedule.0 (555) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v22.20.0, js-controller: 7.0.7
                                        2025-10-12 11:40:33.243  - info: trashschedule.0 (555) [onReady] starting with source "ical" -> ical
                                        2025-10-12 11:40:33.249  - info: trashschedule.0 (555) [ical] configured ical preview is 45 days (until 26.11.2025) - increase this value to find more events in the future
                                        2025-10-12 11:40:35.666  - info: host.iobroker84 instance system.adapter.echarts.0 in version "1.9.2" started with pid 570
                                        2025-10-12 11:40:36.881  - info: echarts.0 (570) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.20.0, js-controller: 7.0.7
                                        2025-10-12 11:40:52.818  - info: sonoff.0 (450) Client [Steckdose01] connected with secret 1760262052812_6539
                                        2025-10-12 11:40:52.978  - info: sonoff.0 (450) Client [Steckdose02] connected with secret 1760262052977_7832
                                        2025-10-12 11:40:53.209  - info: sonoff.0 (450) Client [Stromzaehler] connected with secret 1760262053207_304
                                        2025-10-12 11:41:20.278  - info: admin.0 (313) ==> Connected system.user.admin from ::ffff:192.168.23.27
                                        2025-10-12 11:41:35.334  - info: admin.0 (313) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
                                        iob diag has finished.
                                        EDIT:
                                        Hier der Inhalt vom npm-Log /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
                                        $ cat /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
                                        0 verbose cli /usr/bin/node /usr/bin/npm
                                        1 info using npm@11.6.2
                                        2 info using node@v22.20.0
                                        3 silly config load:file:/usr/lib/node_modules/npm/npmrc
                                        4 silly config load:file:/opt/iobroker/.npmrc
                                        5 silly config load:file:/home/mf/.npmrc
                                        6 silly config load:file:/usr/etc/npmrc
                                        7 verbose title npm ls
                                        8 verbose argv "ls" "--all"
                                        9 verbose logfile logs-max:10 dir:/home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-
                                        10 verbose logfile /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
                                        11 silly logfile start cleaning logs, removing 1 files
                                        12 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
                                        13 silly logfile done cleaning log files
                                        14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
                                        15 verbose stack Error: invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                                        15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
                                        15 verbose stack missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
                                        15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
                                        15 verbose stack missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
                                        15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
                                        15 verbose stack missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
                                        15 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:206:9)
                                        15 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
                                        15 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5)
                                        16 error code ELSPROBLEMS
                                        17 error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                                        17 error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
                                        17 error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
                                        17 error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
                                        17 error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
                                        17 error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
                                        17 error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
                                        18 verbose cwd /opt/iobroker
                                        19 verbose os Linux 6.14.11-3-pve
                                        20 verbose node v22.20.0
                                        21 verbose npm  v11.6.2
                                        22 verbose exit 1
                                        23 verbose code 1
                                        24 error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
                                        un99known99 1 Reply Last reply Reply Quote 0
                                        • un99known99
                                          un99known99 @meute last edited by un99known99
                                          Danke für die Super-Anleitung 🙂 !
                                          Ich habe aktuell 2 Probleme, vielleicht kann mir da jemand helfen:
                                          (1) vor dem Upgrade auf Trixie ist unter /etc/apt/sources.list.d nur eine Datei mit Namen raspi.list, nach dem Upgrade und dem Modernisieren habe ich eine "raspi.sources" (http://archive.raspberrypi.org/debian/) und eine "raspbian.sources" (http://raspbian.raspberrypi.org/raspbian/). Die raspi.sources ist NICHT "Signed-By". Braucht man beide rasp*.sources oder nur die raspbian.sources? Wenn man beide braucht, wo/wie bekomme ich die Signierung für raspi.sources (http://archive.raspberrypi.org/debian/)?
                                          (2) Nach dem Upgrade auf Trixie habe ich Probleme mit Botprogrammen (Bookworm war ja python 3.11.2 und Trixie ist 3.13.5).
                                          Fehlermeldung z.B.
                                          "traceback (most recent call last):
                                          File "/usr/local/searxng/searxng-src/searx/webapp.py", line 21, in <module>
                                          import httpx
                                          ModuleNotFoundError: No module named 'httpx'"
                                          In der webapp.py ist die line 21:
                                          #!/usr/bin/env python3
                                          - - coding: utf-8 - -
                                          import httpx
                                          Muss man Pfade o.ä. ändern/anpassen?
                                            Thomas Braun Most Active @un99known99 last edited by Thomas Braun
                                            @un99known99
                                            Was steht denn drin?
                                            Eine raspbian.sources gibt es auf meinem System nicht. Die /etc/apt/sources.list.d/raspi.sources schaut so aus:
                                            Types: deb
                                            Suites: trixie
                                            Components: main
                                            Ist der keyring installiert?
                                            apt policy raspberrypi-archive-keyring
                                            Zu 2) fragst du wohl besser bei
                                            https://docs.searxng.org/admin/installation-searxng.html#installation-basic
                                            nach.
                                            1.2k
                                            81.1k
                                            192
                                            26379
