      australien @TT-Tom last edited by australien
      @tt-tom
      das script läuft nicht mehr..
      die autoexec.be
      # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (improved Message Handling)| code by Armilar
      # based on;
      # Sonoff NSPanel Tasmota Lovelace UI Berry Driver (Extended Flashing to faster speeds; improved Error Handling)| code by joBr99
      # based on;
      # Sonoff NSPanel Tasmota (Nextion with Flashing) driver | code by peepshow-21
      # based on;
      # Sonoff NSPanel Tasmota driver v0.47 | code by blakadder and s-hadinger
      # Example Flash
      # FlashNextion http://nspanel.de/nspanel-vX.X.X.tft
      class Nextion : Driver
          static header = bytes('55BB')
          static flash_block_size = 4096
          var flash_mode
          var flash_start_millis
          var flash_size
          var flash_written
          var flash_buff
          var flash_offset
          var flash_proto_version
          var flash_proto_baud
          var awaiting_offset
          var tcp
          var ser
          var last_per
          var url
          def split_55(b)
            var ret = []
            var s = size(b)
            var i = s-2   # start from last-1
            while i > 0
              if b[i] == 0x55 && b[i+1] == 0xBB
                ret.push(b[i..s-1]) # push last msg to list
                b = b[(0..i-1)]   # write the rest back to b
              end
              i -= 1
            end
            ret.push(b)
            return ret
          end
          def crc16(data, poly)
            if !poly  poly = 0xA001 end
            # CRC-16 MODBUS HASHING ALGORITHM
            var crc = 0xFFFF
            for i:0..size(data)-1
              crc = crc ^ data[i]
              for j:0..7
                if crc & 1
                  crc = (crc >> 1) ^ poly
                else
                  crc = crc >> 1
                end
              end
            end
            return crc
          end
          # encode using custom protocol 55 BB [payload length] [payload length] [payload] [crc] [crc]
          def encode(payload)
            var b = bytes()
            b += self.header
            b.add(size(payload), 2)   # add size as 2 bytes, little endian
            b += bytes().fromstring(payload)
            var msg_crc = self.crc16(b)
            b.add(msg_crc, 2)       # crc 2 bytes, little endian
            return b
          end
          def encodenx(payload)
              var b = bytes().fromstring(payload)
              b += bytes('FFFFFF')
              return b
          end
          def sendnx(payload)
              import string
              var payload_bin = self.encodenx(payload)
              self.ser.write(payload_bin)
              log(string.format("NXP: Nextion command sent = %s",str(payload_bin)), 3)
          end
          def send(payload)
              var payload_bin = self.encode(payload)
              if self.flash_mode==1
                  log("NXP: skipped command because still flashing", 3)
              else
                  log("NXP: payload sent = " + str(payload_bin), 3)
              end
          end
          def write_to_nextion(b)
              self.ser.write(b)
          end
          def screeninit()
              log("NXP: Screen Initialized")
              self.sendnx("recmod=1")
          end
          def write_block()
              import string
              #log("FLH: Read block",3)
              while size(self.flash_buff)<self.flash_block_size && self.tcp.connected()
                  if self.tcp.available()>0
                      self.flash_buff += self.tcp.readbytes(4096)
                  else
                      tasmota.delay(50)
                      log("FLH: Wait for available...",4)
                  end
              end
              #log("FLH: Buff size "+str(size(self.flash_buff)),3)
              var to_write
              if size(self.flash_buff)>self.flash_block_size
                  to_write = self.flash_buff[0..self.flash_block_size-1]
                  self.flash_buff = self.flash_buff[self.flash_block_size..]
              else
                  self.flash_buff = bytes()
              end
              #log("FLH: Writing "+str(size(to_write)),3)
              var per = (self.flash_written*100)/self.flash_size
              if (self.last_per!=per)
                  self.last_per = per
                  tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": \"%d\", \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
              end
              if size(to_write)>0
                  self.flash_written += size(to_write)
                  self.ser.write(to_write)
              end
              #log("FLH: Total "+str(self.flash_written),3)
              log("FLH: Read block - Writing: "+str(size(to_write))+" - Total: "+str(self.flash_written)+" - Buffer size: "+str(size(self.flash_buff)) ,3)
              if (self.flash_written==self.flash_size)
      	    tasmota.delay(25)
                  log("FLH: Flashing complete - Time elapsed: %d", (tasmota.millis()-self.flash_start_millis)/1000)
                  tasmota.publish_result(string.format("{\"Flashing\":{\"complete\": \"done\", \"time_elapsed\": %d}}",per , (tasmota.millis()-self.flash_start_millis)/1000), "RESULT")
                  tasmota.cmd('RuleTimer3 120')
                  tasmota.cmd('Rule3 1')
                  tasmota.delay(50)
                  self.flash_mode = 0
                  self.ser.deinit()
                  self.ser = serial(17, 16, 115200, serial.SERIAL_8N1)
              end
          end
          def every_100ms()
              import string
              if self.ser.available() > 0
                  var msg = self.ser.read()
                  if size(msg) > 0
                      log(string.format("NXP: Received Raw = %s",str(msg)), 4)
                      if (self.flash_mode==1)
                          var strv = msg[0..-4].asstring()
                          if string.find(strv,"comok 2")>=0
                              tasmota.delay(20)
                              log("FLH: Send (High Speed) flash start")
                              self.flash_start_millis = tasmota.millis()
                              #self.sendnx(string.format("whmi-wris %d,115200,res0",self.flash_size))
                              if self.flash_proto_version == 0
                                  self.sendnx(string.format("whmi-wri %d,%d,res0",self.flash_size,self.flash_proto_baud))
                              else
                                  self.sendnx(string.format("whmi-wris %d,%d,res0",self.flash_size,self.flash_proto_baud))
                              end
                              if self.flash_proto_baud != 115200
                                  tasmota.delay(20)
                                  self.ser.deinit()
                                  self.ser = serial(17, 16, self.flash_proto_baud, serial.SERIAL_8N1)
                              end
                          elif size(msg)==1 && msg[0]==0x08
                              log("FLH: Waiting offset...",3)
                              self.awaiting_offset = 1
                          elif size(msg)==4 && self.awaiting_offset==1
                              self.awaiting_offset = 0
                              self.flash_offset = msg.get(0,4)
                              log("FLH: Flash offset marker "+str(self.flash_offset),3)
                              if self.flash_offset != 0
                                  self.open_url_at(self.url, self.flash_offset)
                                  self.flash_written = self.flash_offset
                              end
                              self.write_block()
                          elif size(msg)==1 && msg[0]==0x05
                              self.write_block()
                          else
                              log("FLH: Something has gone wrong flashing display firmware ["+str(msg)+"]",2)
                          end
                      else
                          var msg_list = self.split_55(msg)
                          for i:0..size(msg_list)-1
                              msg = msg_list[i]
                              if size(msg) > 0
                                  if msg == bytes('000000FFFFFF88FFFFFF')
                                      self.screeninit()
                                  elif size(msg)>=2 && msg[0]==0x55 && msg[1]==0xBB
                                      var jm = string.format("{\"CustomRecv\":\"%s\"}",msg[4..-3].asstring())
                                      tasmota.publish_result(jm, "RESULT")
                                  elif msg[0]==0x07 && size(msg)==1 # BELL/Buzzer
                                      tasmota.cmd("buzzer 1,1")
                                  else
                                      var jm = string.format("{\"nextion\":\"%s\"}",str(msg[0..-4]))
                                  end
                              end
                          end
                      end
                  end
              end
          end
          def begin_nextion_flash()
              tasmota.cmd('RuleTimer3 0')
              tasmota.cmd('Rule3 0')
              self.flash_written = 0
              self.flash_offset = 0
              self.sendnx('DRAKJHSUYDGBNCJHGJKSHBDN')
              self.sendnx('recmod=0')
              #self.sendnx('recmod=0')
              self.flash_mode = 1
              self.sendnx("connect")
          end
          def open_url_at(url, pos)
              self.url = url
              import string
              var host
              var port
              var s1 = string.split(url,7)[1]
              var i = string.find(s1,":")
              var sa
              if i<0
                  port = 80
                  i = string.find(s1,"/")
                  sa = string.split(s1,i)
                  host = sa[0]
              else
                  host = sa[0]
                  s1 = string.split(sa[1],1)[1]
                  port = int(sa[0])
              end
              var get = sa[1]
              log(string.format("FLH: host: %s, port: %s, get: %s",host,port,get))
              self.tcp = tcpclient()
              self.tcp.connect(host,port)
              log("FLH: Connected:"+str(self.tcp.connected()),3)
              var get_req = "GET "+get+" HTTP/1.0\r\n"
              get_req += string.format("Range: bytes=%d-\r\n", pos)
              get_req += string.format("HOST: %s:%s\r\n\r\n",host,port)
              self.tcp.write(get_req)
              var a = self.tcp.available()
              i = 1
              while a==0 && i<5
                tasmota.delay(100*i)
                tasmota.yield()
                i += 1
                log("FLH: Retry "+str(i),3)
              end
              if a==0
                  log("FLH: Nothing available to read!",3)
                  return
              end
              var b = self.tcp.readbytes()
              i = 0
              var end_headers = false;
              var headers
              while i<size(b) && headers==nil
                  if b[i..(i+3)]==bytes().fromstring("\r\n\r\n")
                      headers = b[0..(i+3)].asstring()
                      self.flash_buff = b[(i+4)..]
                  else
                      i += 1
                  end
              end
              #print(headers)
              # check http respose for code 200/206
              if string.find(headers,"200 OK")>0 || string.find(headers,"206 Partial Content")>0
                  log("FLH: HTTP Respose is 200 OK or 206 Partial Content",3)
              else
                  log("FLH: HTTP Respose is not 200 OK or 206 Partial Content",3)
                  print(headers)
                  return -1
              end
              # only set flash size if pos is zero
              if pos == 0
                  # check http respose for content-length
                  var tag = "Content-Length: "
                  i = string.find(headers,tag)
                  if (i>0)
                      var i2 = string.find(headers,"\r\n",i)
                      var s = headers[i+size(tag)..i2-1]
                      self.flash_size=int(s)
                  end
                  log("FLH: Flash file size: "+str(self.flash_size),3)
              end
          end
          def flash_nextion(url)
              self.flash_size = 0
              var res = self.open_url_at(url, 0)
              if res != -1
                  self.begin_nextion_flash()
              end
          end
          def init()
              log("NXP: Initializing Driver")
              self.flash_mode = 0
              self.flash_proto_version = 1
              self.flash_proto_baud = 921600
          end
      end
      var nextion = Nextion()
      tasmota.add_driver(nextion)
      def get_current_version(cmd, idx, payload, payload_json)
          import string
          var version_of_this_script = 10
          var jm = string.format("{\"nlui_driver_version\":\"%s\"}", version_of_this_script)
      end
      tasmota.add_cmd('GetDriverVersion', get_current_version)
      def update_berry_driver(cmd, idx, payload, payload_json)
          def task()
              import path
              import string
      		if string.find(payload, ".tapp") > 0
      		    print("tapp in URL; will do .tapp update and migration if necessary")
      			if path.exists("autoexec.be")
      			    print("autoexec.be found; will check for migration")
      				var autoexecfile = open('autoexec.be')
      				var line = autoexecfile.readline()
      				autoexecfile.close()
      				if string.find(line, "NSPanel Tasmota Lovelace UI Berry Driver") > 0
      			        print("found lovelace berry driver, going to delete autoexec.be and .bec")
      					path.remove("autoexec.be")
      					path.remove("autoexec.bec")
      				end
      			end
      			var r = tasmota.urlfetch(payload, "nsp-lovelace-driver.tapp")
                  if r < 0
                      print("Update failed")
                  else
                      tasmota.cmd("Restart 1")
                  end
      		elif string.find(payload, ".be") > 0
      		    print("be in URL; will do .be update")
      			if path.exists("nsp-lovelace-driver.tapp")
      			    print("Error: there is the tapp version of the berry driver installed; cannot do .be update.")
      			else
                      var cl = webclient()
                      cl.begin(payload)
                      var r = cl.GET()
                      if r == 200
                          print("Sucessfully downloaded nspanel-lovelace-ui berry driver")
                      else
                          print("Error while downloading nspanel-lovelace-ui berry driver")
                      end
                      r = cl.write_file("autoexec.be")
                      if r < 0
                          print("Error while writeing nspanel-lovelace-ui berry driver")
                      else
                          print("Sucessfully written nspanel-lovelace-ui berry driver")
                      end
      			end
      		else
      			print("invalid url filetype")
      		end
                  var r = string.find(payload, ".tapp")
                  if r < 0
                      print("URL doesn't contain .tapp skipping update")
                  else
                  end
              else
                  var r = string.find(payload, ".be")
                  if r < 0
                      print("URL doesn't contain .be skipping update")
                  else
                  end
              end
          end
          tasmota.set_timer(0,task)
          tasmota.resp_cmnd_done()
      end
      tasmota.add_cmd('UpdateDriverVersion', update_berry_driver)
      def flash_nextion(cmd, idx, payload, payload_json)
          def task()
          nextion.flash_proto_version = 1
          nextion.flash_proto_baud = 921600
              nextion.flash_nextion(payload)
          end
      end
      def flash_nextion_adv(cmd, idx, payload, payload_json)
          def task()
              if idx==0
              elif idx==1
                  nextion.flash_proto_version = 0
              elif idx==2
                  nextion.flash_proto_baud = 115200
              elif idx==3
              elif idx==4
                  nextion.flash_proto_baud = 256000
              elif idx==5
              elif idx==6
                  nextion.ser.deinit()
                  nextion.ser = serial(17, 16, 9600, serial.SERIAL_8N1)
              else
              end
          end
      end
      def send_cmd(cmd, idx, payload, payload_json)
          nextion.sendnx(payload)
      end
      def send_cmd2(cmd, idx, payload, payload_json)
          nextion.send(payload)
      end
      tasmota.add_cmd('Nextion', send_cmd)
      tasmota.add_cmd('CustomSend', send_cmd2)
      tasmota.add_cmd('FlashNextion', flash_nextion)
      tasmota.add_cmd('FlashNextionAdv', flash_nextion_adv)
      • Armilar
        Armilar Most Active Forum Testing @australien last edited by
        @australien
        @TT-Tom
          TT-Tom @Armilar last edited by
          @armilar
          ich hatte die Versionsmeldung gesucht im Log, gibt aber keine, oder??
          • Armilar
            Armilar Most Active Forum Testing @TT-Tom last edited by
            @tt-tom
            die Berry-Abfrage machen wir erst im Script... Dann sieht man sie auch im Log
              @armilar
              JA die kenn ich, dachte der Treiber meldet sich selber mit der Version.
              • Armilar
                @tt-tom
                die Prüfung ist eigentlich ganz simpel
                in der Tasmota Konsole:
                GetDriverVersion
                eingeben...
                  egal welche Version ich installieren will, immer bei Buffer um 4788224 ist schluss
                  20:57:53.583 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1395
                  20:57:53.782 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1395
                  • Armilar
                    Armilar Most Active Forum Testing @australien last edited by Armilar
                    @australien
                    Das sind die insgesamt übertragenen Bytes. Der Buffer ist hinten und das verwirrt mich etwas, da der bei dir konstant bei 1395 (auch in vorherigen Screenshots) ist.
                    Bei mir ist der sehr dynamisch:
                    • Was ist das für ne Tasmota-Version?
                    • Ist neben dem Berry da sonst noch etwas im Dateiverzeichnis?
                    Bei mir schlägt auch nur 1% der FlashNextion fehl... Und dann gab es in der Regel auch tatsächlich einen Verbindungsabbruch... D.h. 99% laufen stabil durch...
                    Würde gerne mal wissen wie dieser konstante "Buffer size" zustande kommt...
                    EDIT:
                    Könntest du mal die Varianten:
                    FlashNextionAdv1 http://nspanel.de/nspanel-v5.0.0.tft
                    FlashNextionAdv2 http://nspanel.de/nspanel-v5.0.0.tft
                    und
                    FlashNextionAdv3 http://nspanel.de/nspanel-v5.0.0.tft
                    testen?
                      australien @Armilar last edited by australien
                      @armilar said in SONOFF NSPanel mit Lovelace UI:
                      Tasmota ist die letzte 15.0.1
                      das log bei der Adv1 Version:
                      00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
                      00:00:00.016 UFS: FlashFS mounted with 272 kB free
                      00:00:00.023 CFG: Loaded from File, Anzahl 1506
                      00:00:00.032 QPC: Count 1
                      00:00:00.032 CFG: CR 430/699, Busy 0
                      00:00:00.037 TYA: Active=0
                      00:00:00.042 ROT: Mode 1
                      00:00:00.065 CFG: No '*.autoconf' file found
                      00:00:00.069 BRY: Berry initialized, RAM used 3493 bytes
                      00:00:00.075 BRY: No 'preinit.be'
                      00:00:00.077 SRC: Restart
                      00:00:00.081 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
                      00:00:00.202 NXP: Initializing Driver
                      00:00:00.204 BRY: Serial UART2
                      00:00:00.206 BRY: Successfully loaded 'autoexec.be'
                      00:00:00.287 WIF: Verbindungsversuch…
                      00:00:01.000 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
                      00:00:03.456 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
                      00:00:03.561 WIF: Verbindungsversuch…
                      00:00:04.561 WIF: Verbindungsversuch…
                      00:00:05.561 WIF: Verbindungsversuch…
                      00:00:06.027 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
                      00:00:06.561 WIF: verbunden
                      00:00:06.818 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
                      00:00:06.996 RTC: UTC 2025-09-12T12:58:16Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
                      13:58:16.000 RTC: Synced by NTP
                      13:58:16.812 MQT: Verbindungsversuch…
                      13:58:16.832 MQT: verbunden
                      13:58:16.835 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
                      13:58:16.836 MQT: SmartHome/NSPanel_1/cmnd/POWER =
                      13:58:16.837 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
                      13:58:16.838 MQT: abonniere SmartHome/tasmotas/cmnd/#
                      13:58:16.839 MQT: abonniere cmnd/NSPanel_1_fb/#
                      13:58:16.841 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                      13:58:16.855 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
                      13:58:16.879 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":163}}
                      13:58:16.884 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                      13:58:16.896 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                      13:58:16.897 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                      13:58:16.898 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                      13:58:16.959 QPC: Reset
                      13:58:17.093 SRC: MQTT
                      13:58:17.094 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                      13:58:17.105 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                      13:58:17.109 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      13:58:17.143 SRC: MQTT
                      13:58:17.144 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                      13:58:17.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                      13:58:17.147 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                      13:58:17.193 SRC: MQTT
                      13:58:17.194 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                      13:58:17.206 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                      13:58:17.210 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      13:58:17.243 SRC: MQTT
                      13:58:17.244 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                      13:58:17.247 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                      13:58:17.250 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                      13:58:17.293 SRC: MQTT
                      13:58:17.294 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                      13:58:17.305 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                      13:58:17.309 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      13:58:17.343 SRC: MQTT
                      13:58:17.344 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                      13:58:17.347 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                      13:58:17.350 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                      13:58:18.844 SRC: MQTT
                      13:58:18.844 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                      13:58:18.858 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                      13:58:18.862 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                      13:58:18.893 SRC: MQTT
                      13:58:18.894 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                      13:58:18.896 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                      13:58:18.897 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                      13:58:18.952 APP: Startvorgänge 163
                      13:58:19.480 CFG: Saved, Anzahl 1507, Bytes 4096
                      13:58:21.226 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T13:58:21","Uptime":"0T00:00:12","UptimeSec":12,"Heap":148,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":368,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:06"}}
                      13:58:21.270 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T13:58:21","ANALOG":{"Temperature1":20.8},"ESP32":{"Temperature":46.1},"TempUnit":"C"}
                      14:01:46.586 HTP: Hauptmenü
                      14:01:49.089 HTP: Werkzeuge
                      14:01:50.961 HTP: Konsole
                      14:01:56.889 HTP: Werkzeuge
                      14:01:58.377 HTP: Hauptmenü
                      14:02:00.161 HTP: Werkzeuge
                      14:02:01.057 HTP: Konsole
                      14:02:07.622 CMD: FlashNextionAdv1 http://nspanel.de/nspanel-v5.0.0.tft
                      14:02:07.623 SRC: WebConsole from 10.68.0.156
                      14:02:07.624 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 1, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
                      14:02:07.632 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                      14:02:07.666 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
                      14:02:07.811 FLH: Connected:true
                      14:02:07.914 FLH: Retry 2
                      14:02:08.127 FLH: HTTP Respose is 200 OK or 206 Partial Content
                      14:02:08.128 FLH: Flash file size: 12197684
                      14:02:08.129 SRC: Berry
                      14:02:08.130 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                      14:02:08.135 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                      14:02:08.140 SRC: Berry
                      14:02:08.141 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                      14:02:08.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                      14:02:08.161 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                      14:02:08.163 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                      14:02:08.165 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                      14:02:08.172 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                      14:02:08.297 FLH: Send (High Speed) flash start
                      14:02:08.303 NXP: Nextion command sent = bytes('77686D692D7772692031323139373638342C3932313630302C72657330FFFFFF')
                      14:02:08.326 BRY: Serial UART2
                      14:02:08.679 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                      14:02:08.771 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                      14:02:09.279 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                      14:02:09.392 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                      14:02:09.501 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                      14:02:09.611 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
                      14:02:09.770 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
                      14:02:09.881 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
                      14:02:10.073 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
                      14:02:10.317 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
                      14:02:10.427 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
                      14:02:10.536 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
                      14:02:10.645 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
                      14:02:10.752 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
                      14:02:10.863 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
                      14:02:11.074 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
                      14:02:11.180 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
                      14:02:11.293 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
                      14:02:11.574 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
                      14:02:11.770 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
                      14:02:11.971 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
                      14:02:12.083 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
                      14:02:12.275 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
                      14:02:12.471 FLH: Read block - Writing: 4096 - Total: 94208 - Buffer size: 1395
                      14:02:12.583 FLH: Read block - Writing: 4096 - Total: 98304 - Buffer size: 1395
                      14:02:12.770 FLH: Read block - Writing: 4096 - Total: 102400 - Buffer size: 1395
                      14:02:12.885 FLH: Read block - Writing: 4096 - Total: 106496 - Buffer size: 1395
                      14:02:13.032 FLH: Read block - Writing: 4096 - Total: 110592 - Buffer size: 1395
                      14:02:13.143 FLH: Read block - Writing: 4096 - Total: 114688 - Buffer size: 1395
                      14:02:13.254 FLH: Read block - Writing: 4096 - Total: 118784 - Buffer size: 1395
                      14:02:13.371 FLH: Read block - Writing: 4096 - Total: 122880 - Buffer size: 1395
                      14:02:13.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "1", "time_elapsed": 5}}
                      14:02:13.578 FLH: Read block - Writing: 4096 - Total: 126976 - Buffer size: 1395
                      14:02:13.771 FLH: Read block - Writing: 4096 - Total: 131072 - Buffer size: 1395
                      14:02:13.971 FLH: Read block - Writing: 4096 - Total: 135168 - Buffer size: 1395
                      14:02:14.170 FLH: Read block - Writing: 4096 - Total: 139264 - Buffer size: 1395
                      14:02:14.283 FLH: Read block - Writing: 4096 - Total: 143360 - Buffer size: 1395
                      14:02:14.470 FLH: Read block - Writing: 4096 - Total: 147456 - Buffer size: 1395
                      14:02:14.670 FLH: Read block - Writing: 4096 - Total: 151552 - Buffer size: 1395
                      14:02:14.870 FLH: Read block - Writing: 4096 - Total: 155648 - Buffer size: 1395
                      14:02:15.074 FLH: Read block - Writing: 4096 - Total: 159744 - Buffer size: 1395
                      14:02:15.275 FLH: Read block - Writing: 4096 - Total: 163840 - Buffer size: 1395
                      14:02:15.471 FLH: Read block - Writing: 4096 - Total: 167936 - Buffer size: 1395
                      14:02:15.620 FLH: Read block - Writing: 4096 - Total: 172032 - Buffer size: 1395
                      14:02:15.770 FLH: Read block - Writing: 4096 - Total: 176128 - Buffer size: 1395
                      14:02:15.882 FLH: Read block - Writing: 4096 - Total: 180224 - Buffer size: 1395
                      14:02:16.074 FLH: Read block - Writing: 4096 - Total: 184320 - Buffer size: 1395
                      14:02:16.276 FLH: Read block - Writing: 4096 - Total: 188416 - Buffer size: 1395
                      14:02:16.470 FLH: Read block - Writing: 4096 - Total: 192512 - Buffer size: 1395
                      14:02:16.671 FLH: Read block - Writing: 4096 - Total: 196608 - Buffer size: 1395
                      14:02:16.869 FLH: Read block - Writing: 4096 - Total: 200704 - Buffer size: 1395
                      14:02:17.074 FLH: Read block - Writing: 4096 - Total: 204800 - Buffer size: 1395
                      14:02:17.276 FLH: Read block - Writing: 4096 - Total: 208896 - Buffer size: 1395
                      14:02:17.387 FLH: Read block - Writing: 4096 - Total: 212992 - Buffer size: 1395
                      14:02:17.574 FLH: Read block - Writing: 4096 - Total: 217088 - Buffer size: 1395
                      14:02:17.771 FLH: Read block - Writing: 4096 - Total: 221184 - Buffer size: 1395
                      14:02:17.883 FLH: Read block - Writing: 4096 - Total: 225280 - Buffer size: 1395
                      14:02:18.029 FLH: Read block - Writing: 4096 - Total: 229376 - Buffer size: 1395
                      14:02:18.177 FLH: Read block - Writing: 4096 - Total: 233472 - Buffer size: 1395
                      14:02:18.370 FLH: Read block - Writing: 4096 - Total: 237568 - Buffer size: 1395
                      14:02:18.573 FLH: Read block - Writing: 4096 - Total: 241664 - Buffer size: 1395
                      14:02:18.771 FLH: Read block - Writing: 4096 - Total: 245760 - Buffer size: 1395
                      14:02:18.795 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "2", "time_elapsed": 10}}
                      14:02:18.888 FLH: Read block - Writing: 4096 - Total: 249856 - Buffer size: 1395
                      14:02:19.073 FLH: Read block - Writing: 4096 - Total: 253952 - Buffer size: 1395
                      14:02:19.277 FLH: Read block - Writing: 4096 - Total: 258048 - Buffer size: 1395
                      14:02:19.388 FLH: Read block - Writing: 4096 - Total: 262144 - Buffer size: 1395
                      14:02:19.574 FLH: Read block - Writing: 4096 - Total: 266240 - Buffer size: 1395
                      14:02:19.771 FLH: Read block - Writing: 4096 - Total: 270336 - Buffer size: 1395
                      14:02:19.881 FLH: Read block - Writing: 4096 - Total: 274432 - Buffer size: 1395
                      14:02:20.074 FLH: Read block - Writing: 4096 - Total: 278528 - Buffer size: 1395
                      14:02:20.276 FLH: Read block - Writing: 4096 - Total: 282624 - Buffer size: 1395
                      14:02:20.386 FLH: Read block - Writing: 4096 - Total: 286720 - Buffer size: 1395
                      14:02:20.592 FLH: Read block - Writing: 4096 - Total: 290816 - Buffer size: 1395
                      14:02:20.771 FLH: Read block - Writing: 4096 - Total: 294912 - Buffer size: 1395
                      14:02:20.881 FLH: Read block - Writing: 4096 - Total: 299008 - Buffer size: 1395
                      14:02:21.074 FLH: Read block - Writing: 4096 - Total: 303104 - Buffer size: 1395
                      14:02:21.277 FLH: Read block - Writing: 4096 - Total: 307200 - Buffer size: 1395
                      14:02:21.386 FLH: Read block - Writing: 4096 - Total: 311296 - Buffer size: 1395
                      14:02:21.574 FLH: Read block - Writing: 4096 - Total: 315392 - Buffer size: 1395
                      14:02:21.772 FLH: Read block - Writing: 4096 - Total: 319488 - Buffer size: 1395
                      14:02:21.882 FLH: Read block - Writing: 4096 - Total: 323584 - Buffer size: 1395
                      14:02:22.074 FLH: Read block - Writing: 4096 - Total: 327680 - Buffer size: 1395
                      14:02:22.277 FLH: Read block - Writing: 4096 - Total: 331776 - Buffer size: 1395
                      14:02:22.470 FLH: Read block - Writing: 4096 - Total: 335872 - Buffer size: 1395
                      14:02:22.670 FLH: Read block - Writing: 4096 - Total: 339968 - Buffer size: 1395
                      14:02:22.871 FLH: Read block - Writing: 4096 - Total: 344064 - Buffer size: 1395
                      14:02:23.073 FLH: Read block - Writing: 4096 - Total: 348160 - Buffer size: 1395
                      14:02:23.218 FLH: Read block - Writing: 4096 - Total: 352256 - Buffer size: 1395
                      14:02:23.334 FLH: Read block - Writing: 4096 - Total: 356352 - Buffer size: 1395
                      14:02:23.469 FLH: Read block - Writing: 4096 - Total: 360448 - Buffer size: 1395
                      14:02:23.670 FLH: Read block - Writing: 4096 - Total: 364544 - Buffer size: 1395
                      14:02:23.870 FLH: Read block - Writing: 4096 - Total: 368640 - Buffer size: 1395
                      14:02:23.986 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "3", "time_elapsed": 15}}
                      14:02:24.078 FLH: Read block - Writing: 4096 - Total: 372736 - Buffer size: 1395
                      14:02:24.276 FLH: Read block - Writing: 4096 - Total: 376832 - Buffer size: 1395
                      14:02:24.388 FLH: Read block - Writing: 4096 - Total: 380928 - Buffer size: 1395
                      14:02:24.573 FLH: Read block - Writing: 4096 - Total: 385024 - Buffer size: 1395
                      14:02:24.770 FLH: Read block - Writing: 4096 - Total: 389120 - Buffer size: 1395
                      14:02:24.970 FLH: Read block - Writing: 4096 - Total: 393216 - Buffer size: 1395
                      14:02:25.082 FLH: Read block - Writing: 4096 - Total: 397312 - Buffer size: 1395
                      14:02:25.372 FLH: Read block - Writing: 4096 - Total: 401408 - Buffer size: 1395
                      14:02:25.574 FLH: Read block - Writing: 4096 - Total: 405504 - Buffer size: 1395
                      14:02:25.769 FLH: Read block - Writing: 4096 - Total: 409600 - Buffer size: 1395
                      14:02:25.971 FLH: Read block - Writing: 4096 - Total: 413696 - Buffer size: 1395
                      14:02:26.085 FLH: Read block - Writing: 4096 - Total: 417792 - Buffer size: 1395
                      14:02:26.275 FLH: Read block - Writing: 4096 - Total: 421888 - Buffer size: 1395
                      14:02:26.471 FLH: Read block - Writing: 4096 - Total: 425984 - Buffer size: 1395
                      14:02:26.671 FLH: Read block - Writing: 4096 - Total: 430080 - Buffer size: 1395
                      14:02:26.870 FLH: Read block - Writing: 4096 - Total: 434176 - Buffer size: 1395
                      14:02:27.074 FLH: Read block - Writing: 4096 - Total: 438272 - Buffer size: 1395
                      14:02:27.276 FLH: Read block - Writing: 4096 - Total: 442368 - Buffer size: 1395
                      14:02:27.387 FLH: Read block - Writing: 4096 - Total: 446464 - Buffer size: 1395
                      14:02:27.573 FLH: Read block - Writing: 4096 - Total: 450560 - Buffer size: 1395
                      14:02:27.771 FLH: Read block - Writing: 4096 - Total: 454656 - Buffer size: 1395
                      14:02:27.881 FLH: Read block - Writing: 4096 - Total: 458752 - Buffer size: 1395
                      14:02:28.074 FLH: Read block - Writing: 4096 - Total: 462848 - Buffer size: 1395
                      14:02:28.277 FLH: Read block - Writing: 4096 - Total: 466944 - Buffer size: 1395
                      14:02:28.427 FLH: Read block - Writing: 4096 - Total: 471040 - Buffer size: 1395
                      14:02:28.576 FLH: Read block - Writing: 4096 - Total: 475136 - Buffer size: 1395
                      14:02:28.770 FLH: Read block - Writing: 4096 - Total: 479232 - Buffer size: 1395
                      14:02:28.881 FLH: Read block - Writing: 4096 - Total: 483328 - Buffer size: 1395
                      14:02:29.074 FLH: Read block - Writing: 4096 - Total: 487424 - Buffer size: 1395
                      14:02:29.277 FLH: Read block - Writing: 4096 - Total: 491520 - Buffer size: 1395
                      14:02:29.300 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "4", "time_elapsed": 20}}
                      14:02:29.393 FLH: Read block - Writing: 4096 - Total: 495616 - Buffer size: 1395
                      14:02:29.574 FLH: Read block - Writing: 4096 - Total: 499712 - Buffer size: 1395
                      14:02:29.770 FLH: Read block - Writing: 4096 - Total: 503808 - Buffer size: 1395
                      14:02:29.881 FLH: Read block - Writing: 4096 - Total: 507904 - Buffer size: 1395
                      14:02:30.073 FLH: Read block - Writing: 4096 - Total: 512000 - Buffer size: 1395
                      14:02:30.277 FLH: Read block - Writing: 4096 - Total: 516096 - Buffer size: 1395
                      14:02:30.387 FLH: Read block - Writing: 4096 - Total: 520192 - Buffer size: 1395
                      14:02:30.574 FLH: Read block - Writing: 4096 - Total: 524288 - Buffer size: 1395
                      14:02:30.771 FLH: Read block - Writing: 4096 - Total: 528384 - Buffer size: 1395
                      14:02:30.984 FLH: Read block - Writing: 4096 - Total: 532480 - Buffer size: 1395
                      14:02:31.171 FLH: Read block - Writing: 4096 - Total: 536576 - Buffer size: 1395
                      14:02:31.288 FLH: Read block - Writing: 4096 - Total: 540672 - Buffer size: 1395
                      14:02:31.398 FLH: Read block - Writing: 4096 - Total: 544768 - Buffer size: 1395
                      14:02:31.573 FLH: Read block - Writing: 4096 - Total: 548864 - Buffer size: 1395
                      14:02:31.771 FLH: Read block - Writing: 4096 - Total: 552960 - Buffer size: 1395
                      14:02:31.881 FLH: Read block - Writing: 4096 - Total: 557056 - Buffer size: 1395
                      14:02:32.073 FLH: Read block - Writing: 4096 - Total: 561152 - Buffer size: 1395
                      14:02:32.277 FLH: Read block - Writing: 4096 - Total: 565248 - Buffer size: 1395
                      14:02:32.388 FLH: Read block - Writing: 4096 - Total: 569344 - Buffer size: 1395
                      14:02:32.574 FLH: Read block - Writing: 4096 - Total: 573440 - Buffer size: 1395
                      14:02:32.771 FLH: Read block - Writing: 4096 - Total: 577536 - Buffer size: 1395
                      14:02:32.881 FLH: Read block - Writing: 4096 - Total: 581632 - Buffer size: 1395
                      14:02:33.074 FLH: Read block - Writing: 4096 - Total: 585728 - Buffer size: 1395
                      14:02:33.276 FLH: Read block - Writing: 4096 - Total: 589824 - Buffer size: 1395
                      14:02:33.427 FLH: Read block - Writing: 4096 - Total: 593920 - Buffer size: 1395
                      14:02:33.671 FLH: Read block - Writing: 4096 - Total: 598016 - Buffer size: 1395
                      14:02:33.871 FLH: Read block - Writing: 4096 - Total: 602112 - Buffer size: 1395
                      14:02:34.073 FLH: Read block - Writing: 4096 - Total: 606208 - Buffer size: 1395
                      14:02:34.276 FLH: Read block - Writing: 4096 - Total: 610304 - Buffer size: 1395
                      14:02:34.301 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "5", "time_elapsed": 25}}
                      14:02:34.394 FLH: Read block - Writing: 4096 - Total: 614400 - Buffer size: 1395
                      14:02:34.573 FLH: Read block - Writing: 4096 - Total: 618496 - Buffer size: 1395
                      14:02:34.770 FLH: Read block - Writing: 4096 - Total: 622592 - Buffer size: 1395
                      14:02:34.971 FLH: Read block - Writing: 4096 - Total: 626688 - Buffer size: 1395
                      14:02:35.082 FLH: Read block - Writing: 4096 - Total: 630784 - Buffer size: 1395
                      14:02:35.277 FLH: Read block - Writing: 4096 - Total: 634880 - Buffer size: 1395
                      14:02:35.390 FLH: Read block - Writing: 4096 - Total: 638976 - Buffer size: 1395
                      14:02:35.573 FLH: Read block - Writing: 4096 - Total: 643072 - Buffer size: 1395
                      14:02:35.770 FLH: Read block - Writing: 4096 - Total: 647168 - Buffer size: 1395
                      14:02:35.988 FLH: Read block - Writing: 4096 - Total: 651264 - Buffer size: 1395
                      14:02:36.101 FLH: Read block - Writing: 4096 - Total: 655360 - Buffer size: 1395
                      14:02:36.276 FLH: Read block - Writing: 4096 - Total: 659456 - Buffer size: 1395
                      14:02:36.471 FLH: Read block - Writing: 4096 - Total: 663552 - Buffer size: 1395
                      14:02:36.580 FLH: Read block - Writing: 4096 - Total: 667648 - Buffer size: 1395
                      14:02:36.770 FLH: Read block - Writing: 4096 - Total: 671744 - Buffer size: 1395
                      14:02:36.970 FLH: Read block - Writing: 4096 - Total: 675840 - Buffer size: 1395
                      14:02:37.081 FLH: Read block - Writing: 4096 - Total: 679936 - Buffer size: 1395
                      14:02:37.277 FLH: Read block - Writing: 4096 - Total: 684032 - Buffer size: 1395
                      14:02:37.388 FLH: Read block - Writing: 4096 - Total: 688128 - Buffer size: 1395
                      14:02:37.573 FLH: Read block - Writing: 4096 - Total: 692224 - Buffer size: 1395
                      14:02:37.771 FLH: Read block - Writing: 4096 - Total: 696320 - Buffer size: 1395
                      14:02:37.970 FLH: Read block - Writing: 4096 - Total: 700416 - Buffer size: 1395
                      14:02:38.081 FLH: Read block - Writing: 4096 - Total: 704512 - Buffer size: 1395
                      14:02:38.276 FLH: Read block - Writing: 4096 - Total: 708608 - Buffer size: 1395
                      14:02:38.471 FLH: Read block - Writing: 4096 - Total: 712704 - Buffer size: 1395
                      14:02:38.619 FLH: Read block - Writing: 4096 - Total: 716800 - Buffer size: 1395
                      14:02:38.770 FLH: Read block - Writing: 4096 - Total: 720896 - Buffer size: 1395
                      14:02:38.970 FLH: Read block - Writing: 4096 - Total: 724992 - Buffer size: 1395
                      14:02:39.169 FLH: Read block - Writing: 4096 - Total: 729088 - Buffer size: 1395
                      14:02:39.283 FLH: Read block - Writing: 4096 - Total: 733184 - Buffer size: 1395
                      14:02:39.385 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "6", "time_elapsed": 31}}
                      14:02:39.477 FLH: Read block - Writing: 4096 - Total: 737280 - Buffer size: 1395
                      14:02:39.670 FLH: Read block - Writing: 4096 - Total: 741376 - Buffer size: 1395
                      14:02:39.871 FLH: Read block - Writing: 4096 - Total: 745472 - Buffer size: 1395
                      14:02:40.074 FLH: Read block - Writing: 4096 - Total: 749568 - Buffer size: 1395
                      14:02:40.275 FLH: Read block - Writing: 4096 - Total: 753664 - Buffer size: 1395
                      14:02:40.470 FLH: Read block - Writing: 4096 - Total: 757760 - Buffer size: 1395
                      14:02:40.671 FLH: Read block - Writing: 4096 - Total: 761856 - Buffer size: 1395
                      14:02:40.870 FLH: Read block - Writing: 4096 - Total: 765952 - Buffer size: 1395
                      14:02:41.074 FLH: Read block - Writing: 4096 - Total: 770048 - Buffer size: 1395
                      14:02:41.221 FLH: Read block - Writing: 4096 - Total: 774144 - Buffer size: 1395
                      14:02:41.335 FLH: Read block - Writing: 4096 - Total: 778240 - Buffer size: 1395
                      14:02:41.469 FLH: Read block - Writing: 4096 - Total: 782336 - Buffer size: 1395
                      14:02:41.671 FLH: Read block - Writing: 4096 - Total: 786432 - Buffer size: 1395
                      14:02:41.870 FLH: Read block - Writing: 4096 - Total: 790528 - Buffer size: 1395
                      14:02:42.074 FLH: Read block - Writing: 4096 - Total: 794624 - Buffer size: 1395
                      14:02:42.277 FLH: Read block - Writing: 4096 - Total: 798720 - Buffer size: 1395
                      14:02:42.387 FLH: Read block - Writing: 4096 - Total: 802816 - Buffer size: 1395
                      14:02:42.574 FLH: Read block - Writing: 4096 - Total: 806912 - Buffer size: 1395
                      14:02:42.770 FLH: Read block - Writing: 4096 - Total: 811008 - Buffer size: 1395
                      14:02:42.883 FLH: Read block - Writing: 4096 - Total: 815104 - Buffer size: 1395
                      14:02:43.074 FLH: Read block - Writing: 4096 - Total: 819200 - Buffer size: 1395
                      14:02:43.277 FLH: Read block - Writing: 4096 - Total: 823296 - Buffer size: 1395
                      14:02:43.387 FLH: Read block - Writing: 4096 - Total: 827392 - Buffer size: 1395
                      14:02:43.574 FLH: Read block - Writing: 4096 - Total: 831488 - Buffer size: 1395
                      14:02:43.720 FLH: Read block - Writing: 4096 - Total: 835584 - Buffer size: 1395
                      14:02:43.830 FLH: Read block - Writing: 4096 - Total: 839680 - Buffer size: 1395
                      14:02:43.971 FLH: Read block - Writing: 4096 - Total: 843776 - Buffer size: 1395
                      14:02:44.084 FLH: Read block - Writing: 4096 - Total: 847872 - Buffer size: 1395
                      14:02:44.277 FLH: Read block - Writing: 4096 - Total: 851968 - Buffer size: 1395
                      14:02:44.390 FLH: Read block - Writing: 4096 - Total: 856064 - Buffer size: 1395
                      14:02:44.584 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "7", "time_elapsed": 36}}
                      14:02:44.676 FLH: Read block - Writing: 4096 - Total: 860160 - Buffer size: 1395
                      14:02:44.868 FLH: Read block - Writing: 4096 - Total: 864256 - Buffer size: 1395
                      14:02:45.070 FLH: Read block - Writing: 4096 - Total: 868352 - Buffer size: 1395
                      14:02:45.278 FLH: Read block - Writing: 4096 - Total: 872448 - Buffer size: 1395
                      14:02:45.388 FLH: Read block - Writing: 4096 - Total: 876544 - Buffer size: 1395
                      14:02:45.574 FLH: Read block - Writing: 4096 - Total: 880640 - Buffer size: 1395
                      14:02:45.770 FLH: Read block - Writing: 4096 - Total: 884736 - Buffer size: 1395
                      14:02:45.881 FLH: Read block - Writing: 4096 - Total: 888832 - Buffer size: 1395
                      14:02:46.069 FLH: Read block - Writing: 4096 - Total: 892928 - Buffer size: 1395
                      14:02:46.282 FLH: Read block - Writing: 4096 - Total: 897024 - Buffer size: 1395
                      14:02:46.392 FLH: Read block - Writing: 4096 - Total: 901120 - Buffer size: 1395
                      14:02:46.573 FLH: Read block - Writing: 4096 - Total: 905216 - Buffer size: 1395
                      14:02:46.772 FLH: Read block - Writing: 4096 - Total: 909312 - Buffer size: 1395
                      14:02:46.971 FLH: Read block - Writing: 4096 - Total: 913408 - Buffer size: 1395
                      14:02:47.084 FLH: Read block - Writing: 4096 - Total: 917504 - Buffer size: 1395
                      14:02:47.277 FLH: Read block - Writing: 4096 - Total: 921600 - Buffer size: 1395
                      14:02:47.468 FLH: Read block - Writing: 4096 - Total: 925696 - Buffer size: 1395
                      14:02:47.672 FLH: Read block - Writing: 4096 - Total: 929792 - Buffer size: 1395
                      14:02:47.870 FLH: Read block - Writing: 4096 - Total: 933888 - Buffer size: 1395
                      14:02:48.069 FLH: Read block - Writing: 4096 - Total: 937984 - Buffer size: 1395
                      14:02:48.275 FLH: Read block - Writing: 4096 - Total: 942080 - Buffer size: 1395
                      14:02:48.472 FLH: Read block - Writing: 4096 - Total: 946176 - Buffer size: 1395
                      14:02:48.582 FLH: Read block - Writing: 4096 - Total: 950272 - Buffer size: 1395
                      14:02:48.769 FLH: Read block - Writing: 4096 - Total: 954368 - Buffer size: 1395
                      14:02:48.919 FLH: Read block - Writing: 4096 - Total: 958464 - Buffer size: 1395
                      14:02:49.072 FLH: Read block - Writing: 4096 - Total: 962560 - Buffer size: 1395
                      14:02:49.277 FLH: Read block - Writing: 4096 - Total: 966656 - Buffer size: 1395
                      14:02:49.471 FLH: Read block - Writing: 4096 - Total: 970752 - Buffer size: 1395
                      14:02:49.582 FLH: Read block - Writing: 4096 - Total: 974848 - Buffer size: 1395
                      14:02:49.769 FLH: Read block - Writing: 4096 - Total: 978944 - Buffer size: 1395
                      14:02:49.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "8", "time_elapsed": 41}}
                      14:02:49.975 FLH: Read block - Writing: 4096 - Total: 983040 - Buffer size: 1395
                      14:02:50.170 FLH: Read block - Writing: 4096 - Total: 987136 - Buffer size: 1395
                      14:02:50.372 FLH: Read block - Writing: 4096 - Total: 991232 - Buffer size: 1395
                      14:02:50.574 FLH: Read block - Writing: 4096 - Total: 995328 - Buffer size: 1395
                      14:02:50.770 FLH: Read block - Writing: 4096 - Total: 999424 - Buffer size: 1395
                      14:02:50.881 FLH: Read block - Writing: 4096 - Total: 1003520 - Buffer size: 1395
                      14:02:51.074 FLH: Read block - Writing: 4096 - Total: 1007616 - Buffer size: 1395
                      14:02:51.275 FLH: Read block - Writing: 4096 - Total: 1011712 - Buffer size: 1395
                      14:02:51.389 FLH: Read block - Writing: 4096 - Total: 1015808 - Buffer size: 1395
                      14:02:51.535 FLH: Read block - Writing: 4096 - Total: 1019904 - Buffer size: 1395
                      14:02:51.646 FLH: Read block - Writing: 4096 - Total: 1024000 - Buffer size: 1395
                      14:02:51.770 FLH: Read block - Writing: 4096 - Total: 1028096 - Buffer size: 1395
                      14:02:51.970 FLH: Read block - Writing: 4096 - Total: 1032192 - Buffer size: 1395
                      14:02:52.081 FLH: Read block - Writing: 4096 - Total: 1036288 - Buffer size: 1395
                      14:02:52.276 FLH: Read block - Writing: 4096 - Total: 1040384 - Buffer size: 1395
                      14:02:52.389 FLH: Read block - Writing: 4096 - Total: 1044480 - Buffer size: 1395
                      14:02:52.574 FLH: Read block - Writing: 4096 - Total: 1048576 - Buffer size: 1395
                      14:02:52.771 FLH: Read block - Writing: 4096 - Total: 1052672 - Buffer size: 1395
                      14:02:52.971 FLH: Read block - Writing: 4096 - Total: 1056768 - Buffer size: 1395
                      14:02:53.083 FLH: Read block - Writing: 4096 - Total: 1060864 - Buffer size: 1395
                      14:02:53.277 FLH: Read block - Writing: 4096 - Total: 1064960 - Buffer size: 1395
                      14:02:53.390 FLH: Read block - Writing: 4096 - Total: 1069056 - Buffer size: 1395
                      14:02:53.573 FLH: Read block - Writing: 4096 - Total: 1073152 - Buffer size: 1395
                      14:02:53.771 FLH: Read block - Writing: 4096 - Total: 1077248 - Buffer size: 1395
                      14:02:53.970 FLH: Read block - Writing: 4096 - Total: 1081344 - Buffer size: 1395
                      14:02:54.081 FLH: Read block - Writing: 4096 - Total: 1085440 - Buffer size: 1395
                      14:02:54.276 FLH: Read block - Writing: 4096 - Total: 1089536 - Buffer size: 1395
                      14:02:54.471 FLH: Read block - Writing: 4096 - Total: 1093632 - Buffer size: 1395
                      14:02:54.580 FLH: Read block - Writing: 4096 - Total: 1097728 - Buffer size: 1395
                      14:02:54.770 FLH: Read block - Writing: 4096 - Total: 1101824 - Buffer size: 1395
                      14:02:54.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "9", "time_elapsed": 46}}
                      14:02:54.977 FLH: Read block - Writing: 4096 - Total: 1105920 - Buffer size: 1395
                      14:02:55.170 FLH: Read block - Writing: 4096 - Total: 1110016 - Buffer size: 1395
                      14:02:55.281 FLH: Read block - Writing: 4096 - Total: 1114112 - Buffer size: 1395
                      14:02:55.394 FLH: Read block - Writing: 4096 - Total: 1118208 - Buffer size: 1395
                      14:02:55.670 FLH: Read block - Writing: 4096 - Total: 1122304 - Buffer size: 1395
                      14:02:55.871 FLH: Read block - Writing: 4096 - Total: 1126400 - Buffer size: 1395
                      14:02:56.074 FLH: Read block - Writing: 4096 - Total: 1130496 - Buffer size: 1395
                      14:02:56.275 FLH: Read block - Writing: 4096 - Total: 1134592 - Buffer size: 1395
                      14:02:56.387 FLH: Read block - Writing: 4096 - Total: 1138688 - Buffer size: 1395
                      14:02:56.533 FLH: Read block - Writing: 4096 - Total: 1142784 - Buffer size: 1395
                      14:02:56.670 FLH: Read block - Writing: 4096 - Total: 1146880 - Buffer size: 1395
                      14:02:56.872 FLH: Read block - Writing: 4096 - Total: 1150976 - Buffer size: 1395
                      14:02:57.075 FLH: Read block - Writing: 4096 - Total: 1155072 - Buffer size: 1395
                      14:02:57.276 FLH: Read block - Writing: 4096 - Total: 1159168 - Buffer size: 1395
                      14:02:57.388 FLH: Read block - Writing: 4096 - Total: 1163264 - Buffer size: 1395
                      14:02:57.574 FLH: Read block - Writing: 4096 - Total: 1167360 - Buffer size: 1395
                      14:02:57.769 FLH: Read block - Writing: 4096 - Total: 1171456 - Buffer size: 1395
                      14:02:57.881 FLH: Read block - Writing: 4096 - Total: 1175552 - Buffer size: 1395
                      14:02:58.074 FLH: Read block - Writing: 4096 - Total: 1179648 - Buffer size: 1395
                      14:02:58.275 FLH: Read block - Writing: 4096 - Total: 1183744 - Buffer size: 1395
                      14:02:58.471 FLH: Read block - Writing: 4096 - Total: 1187840 - Buffer size: 1395
                      14:02:58.671 FLH: Read block - Writing: 4096 - Total: 1191936 - Buffer size: 1395
                      14:02:58.870 FLH: Read block - Writing: 4096 - Total: 1196032 - Buffer size: 1395
                      14:02:59.098 FLH: Read block - Writing: 4096 - Total: 1200128 - Buffer size: 1395
                      14:02:59.276 FLH: Read block - Writing: 4096 - Total: 1204224 - Buffer size: 1395
                      14:02:59.387 FLH: Read block - Writing: 4096 - Total: 1208320 - Buffer size: 1395
                      14:02:59.573 FLH: Read block - Writing: 4096 - Total: 1212416 - Buffer size: 1395
                      14:02:59.771 FLH: Read block - Writing: 4096 - Total: 1216512 - Buffer size: 1395
                      14:02:59.881 FLH: Read block - Writing: 4096 - Total: 1220608 - Buffer size: 1395
                      14:02:59.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "10", "time_elapsed": 51}}
                      14:03:00.080 FLH: Read block - Writing: 4096 - Total: 1224704 - Buffer size: 1395
                      14:03:00.276 FLH: Read block - Writing: 4096 - Total: 1228800 - Buffer size: 1395
                      14:03:00.386 FLH: Read block - Writing: 4096 - Total: 1232896 - Buffer size: 1395
                      14:03:00.574 FLH: Read block - Writing: 4096 - Total: 1236992 - Buffer size: 1395
                      14:03:00.771 FLH: Read block - Writing: 4096 - Total: 1241088 - Buffer size: 1395
                      14:03:00.881 FLH: Read block - Writing: 4096 - Total: 1245184 - Buffer size: 1395
                      14:03:01.074 FLH: Read block - Writing: 4096 - Total: 1249280 - Buffer size: 1395
                      14:03:01.277 FLH: Read block - Writing: 4096 - Total: 1253376 - Buffer size: 1395
                      14:03:01.388 FLH: Read block - Writing: 4096 - Total: 1257472 - Buffer size: 1395
                      14:03:01.574 FLH: Read block - Writing: 4096 - Total: 1261568 - Buffer size: 1395
                      14:03:01.723 FLH: Read block - Writing: 4096 - Total: 1265664 - Buffer size: 1395
                      14:03:01.833 FLH: Read block - Writing: 4096 - Total: 1269760 - Buffer size: 1395
                      14:03:01.970 FLH: Read block - Writing: 4096 - Total: 1273856 - Buffer size: 1395
                      14:03:02.082 FLH: Read block - Writing: 4096 - Total: 1277952 - Buffer size: 1395
                      14:03:02.275 FLH: Read block - Writing: 4096 - Total: 1282048 - Buffer size: 1395
                      14:03:02.471 FLH: Read block - Writing: 4096 - Total: 1286144 - Buffer size: 1395
                      14:03:02.671 FLH: Read block - Writing: 4096 - Total: 1290240 - Buffer size: 1395
                      14:03:02.870 FLH: Read block - Writing: 4096 - Total: 1294336 - Buffer size: 1395
                      14:03:03.073 FLH: Read block - Writing: 4096 - Total: 1298432 - Buffer size: 1395
                      14:03:03.277 FLH: Read block - Writing: 4096 - Total: 1302528 - Buffer size: 1395
                      14:03:03.387 FLH: Read block - Writing: 4096 - Total: 1306624 - Buffer size: 1395
                      14:03:03.573 FLH: Read block - Writing: 4096 - Total: 1310720 - Buffer size: 1395
                      14:03:03.771 FLH: Read block - Writing: 4096 - Total: 1314816 - Buffer size: 1395
                      14:03:03.970 FLH: Read block - Writing: 4096 - Total: 1318912 - Buffer size: 1395
                      14:03:04.171 FLH: Read block - Writing: 4096 - Total: 1323008 - Buffer size: 1395
                      14:03:04.323 FLH: Read block - Writing: 4096 - Total: 1327104 - Buffer size: 1395
                      14:03:04.434 FLH: Read block - Writing: 4096 - Total: 1331200 - Buffer size: 1395
                      14:03:04.574 FLH: Read block - Writing: 4096 - Total: 1335296 - Buffer size: 1395
                      14:03:04.770 FLH: Read block - Writing: 4096 - Total: 1339392 - Buffer size: 1395
                      14:03:04.883 FLH: Read block - Writing: 4096 - Total: 1343488 - Buffer size: 1395
                      14:03:04.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "11", "time_elapsed": 56}}
                      14:03:05.080 FLH: Read block - Writing: 4096 - Total: 1347584 - Buffer size: 1395
                      14:03:05.277 FLH: Read block - Writing: 4096 - Total: 1351680 - Buffer size: 1395
                      14:03:05.387 FLH: Read block - Writing: 4096 - Total: 1355776 - Buffer size: 1395
                      14:03:05.574 FLH: Read block - Writing: 4096 - Total: 1359872 - Buffer size: 1395
                      14:03:05.770 FLH: Read block - Writing: 4096 - Total: 1363968 - Buffer size: 1395
                      14:03:05.883 FLH: Read block - Writing: 4096 - Total: 1368064 - Buffer size: 1395
                      14:03:06.074 FLH: Read block - Writing: 4096 - Total: 1372160 - Buffer size: 1395
                      14:03:06.277 FLH: Read block - Writing: 4096 - Total: 1376256 - Buffer size: 1395
                      14:03:06.389 FLH: Read block - Writing: 4096 - Total: 1380352 - Buffer size: 1395
                      14:03:06.671 FLH: Read block - Writing: 4096 - Total: 1384448 - Buffer size: 1395
                      14:03:06.881 FLH: Read block - Writing: 4096 - Total: 1388544 - Buffer size: 1395
                      14:03:07.073 FLH: Read block - Writing: 4096 - Total: 1392640 - Buffer size: 1395
                      14:03:07.276 FLH: Read block - Writing: 4096 - Total: 1396736 - Buffer size: 1395
                      14:03:07.471 FLH: Read block - Writing: 4096 - Total: 1400832 - Buffer size: 1395
                      14:03:07.670 FLH: Read block - Writing: 4096 - Total: 1404928 - Buffer size: 1395
                      14:03:07.870 FLH: Read block - Writing: 4096 - Total: 1409024 - Buffer size: 1395
                      14:03:08.074 FLH: Read block - Writing: 4096 - Total: 1413120 - Buffer size: 1395
                      14:03:08.275 FLH: Read block - Writing: 4096 - Total: 1417216 - Buffer size: 1395
                      14:03:08.386 FLH: Read block - Writing: 4096 - Total: 1421312 - Buffer size: 1395
                      14:03:08.574 FLH: Read block - Writing: 4096 - Total: 1425408 - Buffer size: 1395
                      14:03:08.770 FLH: Read block - Writing: 4096 - Total: 1429504 - Buffer size: 1395
                      14:03:08.971 FLH: Read block - Writing: 4096 - Total: 1433600 - Buffer size: 1395
                      14:03:09.083 FLH: Read block - Writing: 4096 - Total: 1437696 - Buffer size: 1395
                      14:03:09.275 FLH: Read block - Writing: 4096 - Total: 1441792 - Buffer size: 1395
                      14:03:09.390 FLH: Read block - Writing: 4096 - Total: 1445888 - Buffer size: 1395
                      14:03:09.670 FLH: Read block - Writing: 4096 - Total: 1449984 - Buffer size: 1395
                      14:03:09.870 FLH: Read block - Writing: 4096 - Total: 1454080 - Buffer size: 1395
                      14:03:10.074 FLH: Read block - Writing: 4096 - Total: 1458176 - Buffer size: 1395
                      14:03:10.277 FLH: Read block - Writing: 4096 - Total: 1462272 - Buffer size: 1395
                      14:03:10.388 FLH: Read block - Writing: 4096 - Total: 1466368 - Buffer size: 1395
                      14:03:10.488 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "12", "time_elapsed": 62}}
                      14:03:10.581 FLH: Read block - Writing: 4096 - Total: 1470464 - Buffer size: 1395
                      14:03:10.770 FLH: Read block - Writing: 4096 - Total: 1474560 - Buffer size: 1395
                      14:03:10.881 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
                      14:03:11.074 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
                      14:03:11.277 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
                      14:03:11.387 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
                      14:03:11.574 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
                      14:03:11.771 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
                      14:03:11.880 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
                      14:03:12.099 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
                      14:03:12.277 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
                      14:03:12.470 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
                      14:03:12.670 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
                      14:03:12.871 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
                      14:03:13.073 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
                      14:03:13.276 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
                      14:03:13.471 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
                      14:03:13.580 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
                      14:03:13.770 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
                      14:03:13.882 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
                      14:03:14.073 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
                      14:03:14.277 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
                      14:03:14.502 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
                      14:03:14.670 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
                      14:03:14.871 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
                      14:03:15.074 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
                      14:03:15.276 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
                      14:03:15.471 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
                      14:03:15.671 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
                      14:03:15.869 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
                      14:03:15.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 67}}
                      14:03:16.080 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
                      14:03:16.277 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
                      14:03:16.387 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
                      14:03:16.574 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
                      14:03:16.771 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
                      14:03:16.880 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
                      14:03:17.073 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
                      14:03:17.277 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
                      14:03:17.387 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
                      14:03:17.574 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
                      14:03:17.771 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
                      14:03:17.881 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
                      14:03:18.073 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
                      14:03:18.276 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
                      14:03:18.387 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
                      14:03:18.574 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
                      14:03:18.771 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
                      14:03:18.882 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
                      14:03:19.075 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
                      14:03:19.276 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
                      14:03:19.388 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 1395
                      14:04:02.771 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1395
                      14:04:02.882 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1395
                      14:04:02.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 114}}
                      14:04:03.080 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1395
                      14:04:03.277 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1395
                      14:04:03.388 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1395
                      14:04:03.573 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1395
                      14:04:03.771 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1395
                      14:04:03.881 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1395
                      14:04:04.073 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1395
                      14:04:04.276 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1395
                      14:04:04.385 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1395
                      14:04:04.572 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1395
                      14:04:04.770 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1395
                      14:04:04.880 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1395
                      14:04:05.074 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1395
                      14:04:05.276 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1395
                      14:04:05.387 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1395
                      14:04:05.573 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1395
                      14:04:05.771 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1395
                      14:04:05.970 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1395
                      14:04:06.171 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1395
                      14:04:06.284 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1395
                      14:04:06.395 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1395
                      14:04:06.574 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1395
                      14:04:06.770 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1395
                      14:04:06.881 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1395
                      14:04:07.074 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1395
                      14:04:07.277 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1395
                      14:04:07.389 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1395
                      14:04:07.575 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1395
                      14:04:07.740 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1395
                      14:04:07.782 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 119}}
                      14:04:07.875 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1395
                      14:04:08.074 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1395
                      14:04:08.276 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1395
                      14:04:08.388 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1395
                      14:04:08.671 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1395
                      14:04:08.871 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1395
                      14:04:09.073 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1395
                      14:04:09.276 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1395
                      14:04:09.471 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1395
                      14:04:09.670 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1395
                      14:04:09.870 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1395
                      14:04:10.074 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1395
                      14:04:10.276 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1395
                      14:04:10.426 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1395
                      14:04:10.576 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1395
                      14:04:10.770 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1395
                      14:04:10.971 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1395
                      14:04:11.084 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1395
                      14:04:11.275 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1395
                      14:04:11.471 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1395
                      14:04:11.671 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1395
                      14:04:11.870 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1395
                      14:04:12.074 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1395
                      14:04:12.277 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1395
                      14:04:12.388 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1395
                      14:04:12.574 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1395
                      14:04:12.771 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1395
                      14:04:12.881 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1395
                      14:04:13.029 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1395
                      14:04:13.176 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1395
                      14:04:13.283 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 124}}
                      14:04:13.376 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1395
                      14:04:13.573 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1395
                      14:04:13.771 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1395
                      14:04:13.880 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1395
                      14:04:14.072 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1395
                      14:04:14.277 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1395
                      14:04:14.470 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1395
                      14:04:14.670 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1395
                      14:04:14.871 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1395
                      14:04:15.073 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1395
                      14:04:15.276 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1395
                      14:04:15.471 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1395
                      14:04:15.582 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1395
                      14:04:15.771 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1395
                      14:04:15.971 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1395
                      14:04:16.083 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1395
                      14:04:16.277 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1395
                      14:04:16.389 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1395
                      14:04:16.573 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1395
                      14:04:16.771 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1395
                      14:04:16.971 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1395
                      14:04:17.081 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1395
                      14:04:17.372 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1395
                      14:04:17.574 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1395
                      14:04:17.769 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1395
                      14:04:18.000 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1395
                      14:04:18.177 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1395
                      14:04:18.370 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1395
                      14:04:18.573 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1395
                      14:04:18.771 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1395
                      14:04:18.883 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 130}}
                      14:04:18.976 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1395
                      14:04:19.170 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1395
                      14:04:19.284 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1395
                      14:04:19.394 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1395
                      14:04:19.574 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1395
                      14:04:19.771 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1395
                      14:04:19.970 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1395
                      14:04:20.084 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1395
                      14:04:20.372 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1395
                      14:04:20.573 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1395
                      14:04:20.771 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1395
                      14:04:20.884 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1395
                      14:04:21.073 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1395
                      14:04:21.277 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1395
                      14:04:21.470 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1395
                      14:04:21.579 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1395
                      14:04:21.770 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1395
                      14:04:21.882 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1395
                      14:04:22.073 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1395
                      14:04:22.277 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1395
                      14:04:22.388 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1395
                      14:04:22.572 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1395
                      14:04:22.770 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1395
                      14:04:22.970 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1395
                      14:04:23.170 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1395
                      14:04:23.282 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1395
                      14:04:23.471 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1395
                      14:04:23.581 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1395
                      14:04:23.770 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1395
                      14:04:23.971 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1395
                      14:04:23.996 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 135}}
                      14:04:24.088 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1395
                      14:04:24.276 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1395
                      14:04:24.388 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1395
                      14:04:24.571 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1395
                      14:04:24.770 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1395
                      14:04:24.882 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1395
                      14:04:25.074 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1395
                      14:04:25.276 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1395
                      14:04:25.429 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1395
                      14:04:25.572 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1395
                      14:04:25.870 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1395
                      14:04:26.073 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1395
                      14:04:26.276 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1395
                      14:04:26.387 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1395
                      14:04:26.574 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1395
                      14:04:26.770 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1395
                      14:04:26.971 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1395
                      14:04:27.171 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1395
                      14:04:27.282 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1395
                      14:04:27.393 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1395
                      14:04:27.574 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1395
                      14:04:27.770 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1395
                      14:04:27.919 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1395
                      14:04:28.074 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1395
                      14:04:28.275 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1395
                      14:04:28.386 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1395
                      14:04:28.671 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1395
                      14:04:28.870 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1395
                      14:04:29.074 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1395
                      14:04:29.278 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1395
                      14:04:29.303 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 141}}
                      14:05:21.573 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1395
                      14:05:21.770 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1395
                      14:05:21.884 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1395
                      14:05:22.094 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1395
                      14:05:22.276 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1395
                      14:05:22.389 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1395
                      14:05:22.573 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1395
                      14:05:22.771 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1395
                      14:05:22.882 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1395
                      14:05:23.073 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1395
                      14:05:23.276 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1395
                      14:05:23.388 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1395
                      14:05:23.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 195}}
                      14:05:23.578 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1395
                      14:05:23.770 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1395
                      14:05:23.970 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1395
                      14:05:24.769 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1395
                      14:05:24.971 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1395
                      14:05:25.171 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1395
                      14:05:25.282 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1395
                      14:05:25.470 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1395
                      14:05:25.671 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1395
                      14:05:25.869 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1395
                      14:05:26.074 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1395
                      14:05:26.277 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1395
                      14:05:26.388 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1395
                      14:05:26.574 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1395
                      14:05:26.771 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1395
                      14:05:26.881 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1395
                      14:05:27.073 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1395
                      14:05:27.220 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1395
                      14:05:27.334 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1395
                      14:05:28.170 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1395
                      14:05:28.282 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1395
                      14:05:28.392 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1395
                      14:05:28.570 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1395
                      14:05:28.772 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1395
                      14:05:28.882 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 311
                      14:05:29.074 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 311
                      14:05:29.276 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 311
                      14:05:29.387 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 311
                      14:05:29.573 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 311
                      14:05:29.771 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 311
                      14:05:29.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 201}}
                      14:05:29.976 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 311
                      14:05:30.088 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 311
                      14:05:30.275 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 311
                      14:05:30.470 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 311
                      14:05:30.670 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 311
                      14:05:31.470 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 311
                      14:05:31.670 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 311
                      14:05:31.869 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 311
                      14:05:32.071 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 311
                      14:05:32.275 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 311
                      14:05:32.386 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 311
                      14:05:32.573 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 311
                      14:05:32.769 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 311
                      14:05:32.969 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 311
                      14:05:33.080 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 311
                      14:05:33.275 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 311
                      14:05:33.469 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 311
                      14:05:33.670 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 311
                      14:05:33.870 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 311
                      14:05:34.072 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 311
                      14:05:34.276 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 311
                      14:05:35.074 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 311
                      14:05:35.276 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 311
                      14:05:35.388 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 311
                      14:05:35.573 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 311
                      14:05:35.769 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 311
                      14:05:35.970 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 311
                      14:05:36.170 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 311
                      14:05:36.281 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 311
                      14:05:36.392 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 311
                      14:05:36.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 208}}
                      14:05:36.579 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 311
                      14:05:36.769 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 311
                      14:05:36.970 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 311
                      14:05:37.487 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 2607
                      14:05:38.106 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 2819
                      14:05:38.218 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 2819
                      14:05:38.330 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 2819
                      mich macht diese Zeile unrund, die kommt immer:
                        TT-Tom @australien last edited by
                        @australien
                        so sieht es bei mir aus
                        zeige mal die komplette Info von Tasmota.
                        • Armilar
                          Armilar Most Active Forum Testing last edited by
                          @australien sagte in SONOFF NSPanel mit Lovelace UI:
                          Wirf da mal alles raus (auch mal unter versteckte Dateien nachsehen) bis nur noch die autoexec.be drin ist...
                          Mit der nspanel.be hast du 2 unterschiedliche Berry Driver... Der muss auf alle Fälle weg...
                          Danach noch mal rebooten... und nochmal mit der Adv0 oder/und Adv2 versuchen...
                          A 1 Reply Last reply Reply Quote 2
                            australien @TT-Tom last edited by
                            @tt-tom
                            NSPanel
                            Tasmota
                            Informationen
                            Tasmota Version	15.0.1 (release-tasmota32)
                            Erstellt	2025.06.14 10:39:16
                            Core-/SDK-Version	3_1_3/5.3.3.250501
                            Laufzeit	0T01:05:34
                            Schreibzyklen	1509
                            Startvorgänge	165
                            Grund für Neustart	Vbat power on reset
                            Friendly Name 1	Tasmota
                            Friendly Name 2
                            AP1 Informationen	SSID FR@smart
                            RSSI 92%, -54 dBm
                            Mode HT40
                            Kanal 9
                            BSSID 7E:8A:20:51:6B:CA
                            Hostname	NSPanel-1-5140
                            IPv6 Local (WiFi)	fe80::e2e2:e6ff:fe0c:1414%st1
                            MAC-Adresse	E0:E2:E6:0C:14:14
                            IP-Adresse (WiFi)	10.68.0.179
                            Gateway	10.68.0.1
                            Subnetzmaske	255.255.0.0
                            DNS-Server1	10.68.0.1
                            DNS-Server2	0.0.0.0
                            HTTP API	aktiviert
                            Host	10.68.10.11
                            Port	1886
                            MQTT TLS	deaktiviert
                            Benutzer	iobroker
                            Client	NSPanel_1
                            Topic	NSPanel_1
                            Group Topic 1	SmartHome/tasmotas/cmnd/
                            Full Topic	SmartHome/NSPanel_1/cmnd/
                            MQTT Fallback-Topic	cmnd/NSPanel_1_fb/
                            No Retain	deaktiviert
                            Emulation	keine
                            mDNS-Erkennung	deaktiviert
                            ESP Chip ID	791572 (ESP32-D0WD-V3 v3.0)
                            Flash Chip ID	0x16405E (DIO)
                            Größe Flash-Chip	4096 KB
                            Flash nutzbar	4096 KB
                            Programmgröße	2045 KB
                            Flash frei	834 KB
                            Freier Arbeitsspeicher	132,5 KB (frag․ 16%)
                            Partition safeboot	832 KB (genutzt 96%)
                            Partition app0*	2880 KB (genutzt 71%)
                            Partition fs	320 KB
                            Tasmota 15.0.1 (release-tasmota32) von Theo Arends
                              australien @Armilar last edited by
                              @armilar
                              alles draussen, so schaut es nach dem reboot aus:
                              die Fehlermeldung ist weg, nur ist es immer noch das gleiche, geht bis 39%
                              hier das log (geküzt mit ...) mit Adv2, die Blockgrössen sind unterschiedlich
                              00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
                              00:00:00.038 UFS: FlashFS mounted with 292 kB free
                              00:00:00.053 CFG: Loaded from NVS, Anzahl 1512
                              00:00:00.062 QPC: Count 1
                              00:00:00.062 CFG: CR 430/699, Busy 0
                              00:00:00.067 TYA: Active=0
                              00:00:00.072 ROT: Mode 1
                              00:00:00.105 CFG: No '*.autoconf' file found
                              00:00:00.110 BRY: Berry initialized, RAM used 3493 bytes
                              00:00:00.119 BRY: No 'preinit.be'
                              00:00:00.121 SRC: Restart
                              00:00:00.125 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
                              00:00:00.324 NXP: Initializing Driver
                              00:00:00.326 BRY: Serial UART2
                              00:00:00.329 BRY: Successfully loaded 'autoexec.be'
                              00:00:00.484 WIF: Verbindungsversuch…
                              00:00:01.060 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
                              00:00:02.069 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
                              00:00:03.623 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
                              00:00:03.644 WIF: verbunden
                              00:00:03.901 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
                              00:00:03.967 RTC: UTC 2025-09-12T14:20:54Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
                              15:20:54.000 RTC: Synced by NTP
                              15:20:54.895 MQT: Verbindungsversuch…
                              15:20:54.915 MQT: verbunden
                              15:20:54.918 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
                              15:20:54.919 MQT: SmartHome/NSPanel_1/cmnd/POWER =
                              15:20:54.920 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
                              15:20:54.921 MQT: abonniere SmartHome/tasmotas/cmnd/#
                              15:20:54.922 MQT: abonniere cmnd/NSPanel_1_fb/#
                              15:20:54.924 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                              15:20:54.938 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
                              15:20:54.962 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":169}}
                              15:20:54.967 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                              15:20:54.978 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                              15:20:54.980 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                              15:20:54.981 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                              15:20:55.195 SRC: MQTT
                              15:20:55.196 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                              15:20:55.206 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                              15:20:55.211 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                              15:20:55.244 SRC: MQTT
                              15:20:55.245 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                              15:20:55.247 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                              15:20:55.248 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                              15:20:55.295 SRC: MQTT
                              15:20:55.296 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                              15:20:55.306 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                              15:20:55.310 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                              15:20:55.344 SRC: MQTT
                              15:20:55.345 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                              15:20:55.348 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                              15:20:55.352 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                              15:20:55.394 SRC: MQTT
                              15:20:55.395 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                              15:20:55.405 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                              15:20:55.410 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                              15:20:55.444 SRC: MQTT
                              15:20:55.445 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                              15:20:55.448 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                              15:20:55.452 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                              15:20:56.945 SRC: MQTT
                              15:20:56.946 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                              15:20:56.960 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                              15:20:56.963 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                              15:20:56.995 SRC: MQTT
                              15:20:56.995 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                              15:20:56.997 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                              15:20:56.998 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                              15:20:57.133 HTP: Hauptmenü
                              15:20:57.929 QPC: Reset
                              15:20:58.447 HTP: Werkzeuge
                              15:20:58.929 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:20:58","Uptime":"0T00:00:08","UptimeSec":8,"Heap":146,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":241,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:03"}}
                              15:20:58.972 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:20:58","ANALOG":{"Temperature1":28.0},"ESP32":{"Temperature":59.4},"TempUnit":"C"}
                              15:20:59.922 APP: Startvorgänge 169
                              15:21:00.102 HTP: Dateisystem verwalten
                              15:21:00.103 UFS: File '/' download
                              15:21:00.119 UFS: File '/' to download is directory
                              15:21:00.646 CFG: Saved, Anzahl 1513, Bytes 4096
                              15:21:29.565 HTP: Werkzeuge
                              15:21:31.132 HTP: Konsole
                              15:21:36.302 CMD: FlashNextionAdv2 http://nspanel.de/nspanel-v5.0.0.tft
                              15:21:36.303 SRC: WebConsole from 10.68.0.156
                              15:21:36.304 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 2, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
                              15:21:36.312 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                              15:21:36.337 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
                              15:21:36.411 FLH: Connected:true
                              15:21:36.514 FLH: Retry 2
                              15:21:36.727 FLH: HTTP Respose is 200 OK or 206 Partial Content
                              15:21:36.728 FLH: Flash file size: 12197684
                              15:21:36.729 SRC: Berry
                              15:21:36.730 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                              15:21:36.735 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                              15:21:36.740 SRC: Berry
                              15:21:36.741 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                              15:21:36.746 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                              15:21:36.762 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                              15:21:36.764 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                              15:21:36.766 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                              15:21:36.772 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                              15:21:36.892 FLH: Send (High Speed) flash start
                              15:21:36.898 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3131353230302C72657330FFFF...')
                              15:21:37.279 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                              15:21:37.625 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                              15:21:37.739 FLH: Waiting offset...
                              15:21:42.538 FLH: Flash offset marker 0
                              15:21:42.891 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                              15:21:43.359 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                              15:21:43.827 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                              15:21:44.216 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
                              15:21:44.685 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
                              15:21:45.156 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
                              15:21:45.622 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
                              15:21:46.085 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
                              15:21:46.605 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 3107
                              15:21:47.493 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 643
                              15:21:47.959 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 643
                              15:21:48.425 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 643
                              15:21:48.889 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 643
                              15:21:49.357 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 643
                              15:21:49.746 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 643
                              15:21:50.211 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 643
                              15:21:50.683 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 643
                              15:21:51.148 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 643
                              15:21:51.615 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 643
                              15:21:52.082 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 643
                              15:21:52.551 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 643
                              15:21:53.020 FLH: Read block - Writing: 4096 - Total: 94208 - Buffer size: 643
                              15:21:53.418 FLH: Read block - Writing: 4096 - Total: 98304 - Buffer size: 643
                              15:21:53.883 FLH: Read block - Writing: 4096 - Total: 102400 - Buffer size: 643
                              15:21:54.355 FLH: Read block - Writing: 4096 - Total: 106496 - Buffer size: 643
                              15:21:54.819 FLH: Read block - Writing: 4096 - Total: 110592 - Buffer size: 643
                              15:21:55.284 FLH: Read block - Writing: 4096 - Total: 114688 - Buffer size: 643
                              15:21:55.749 FLH: Read block - Writing: 4096 - Total: 118784 - Buffer size: 643
                              15:21:56.139 FLH: Read block - Writing: 4096 - Total: 122880 - Buffer size: 643
                              15:21:56.267 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "1", "time_elapsed": 19}}
                              15:21:56.614 FLH: Read block - Writing: 4096 - Total: 126976 - Buffer size: 643
                              15:21:57.079 FLH: Read block - Writing: 4096 - Total: 131072 - Buffer size: 643
                              15:21:57.546 FLH: Read block - Writing: 4096 - Total: 135168 - Buffer size: 643
                              15:21:58.017 FLH: Read block - Writing: 4096 - Total: 139264 - Buffer size: 643
                              15:21:58.485 FLH: Read block - Writing: 4096 - Total: 143360 - Buffer size: 643
                              15:21:58.881 FLH: Read block - Writing: 4096 - Total: 147456 - Buffer size: 643
                              15:21:59.352 FLH: Read block - Writing: 4096 - Total: 151552 - Buffer size: 643
                              15:21:59.815 FLH: Read block - Writing: 4096 - Total: 155648 - Buffer size: 643
                              15:22:00.281 FLH: Read block - Writing: 4096 - Total: 159744 - Buffer size: 643
                              15:22:00.747 FLH: Read block - Writing: 4096 - Total: 163840 - Buffer size: 643
                              15:22:01.211 FLH: Read block - Writing: 4096 - Total: 167936 - Buffer size: 643
                              15:22:01.601 FLH: Read block - Writing: 4096 - Total: 172032 - Buffer size: 643
                              15:22:02.069 FLH: Read block - Writing: 4096 - Total: 176128 - Buffer size: 643
                              15:22:02.537 FLH: Read block - Writing: 4096 - Total: 180224 - Buffer size: 643
                              15:22:03.006 FLH: Read block - Writing: 4096 - Total: 184320 - Buffer size: 643
                              15:22:03.472 FLH: Read block - Writing: 4096 - Total: 188416 - Buffer size: 643
                              15:22:03.937 FLH: Read block - Writing: 4096 - Total: 192512 - Buffer size: 643
                              15:22:04.690 FLH: Read block - Writing: 4096 - Total: 196608 - Buffer size: 3967
                              15:22:05.156 FLH: Read block - Writing: 4096 - Total: 200704 - Buffer size: 3967
                              15:22:05.625 FLH: Read block - Writing: 4096 - Total: 204800 - Buffer size: 3967
                              15:22:06.092 FLH: Read block - Writing: 4096 - Total: 208896 - Buffer size: 3967
                              15:22:06.561 FLH: Read block - Writing: 4096 - Total: 212992 - Buffer size: 3967
                              15:22:06.949 FLH: Read block - Writing: 4096 - Total: 217088 - Buffer size: 3967
                              15:22:07.417 FLH: Read block - Writing: 4096 - Total: 221184 - Buffer size: 3967
                              15:22:07.884 FLH: Read block - Writing: 4096 - Total: 225280 - Buffer size: 3967
                              15:22:08.355 FLH: Read block - Writing: 4096 - Total: 229376 - Buffer size: 3967
                              15:22:08.820 FLH: Read block - Writing: 4096 - Total: 233472 - Buffer size: 3967
                              15:22:09.285 FLH: Read block - Writing: 4096 - Total: 237568 - Buffer size: 3967
                              15:22:09.679 FLH: Read block - Writing: 4096 - Total: 241664 - Buffer size: 3967
                              15:22:10.145 FLH: Read block - Writing: 4096 - Total: 245760 - Buffer size: 3967
                              15:22:10.274 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "2", "time_elapsed": 33}}
                              15:22:10.619 FLH: Read block - Writing: 4096 - Total: 249856 - Buffer size: 3967
                              15:22:11.088 FLH: Read block - Writing: 4096 - Total: 253952 - Buffer size: 3967
                              15:22:11.555 FLH: Read block - Writing: 4096 - Total: 258048 - Buffer size: 3967
                              15:22:12.027 FLH: Read block - Writing: 4096 - Total: 262144 - Buffer size: 3967
                              15:22:12.421 FLH: Read block - Writing: 4096 - Total: 266240 - Buffer size: 2055
                              15:22:12.885 FLH: Read block - Writing: 4096 - Total: 270336 - Buffer size: 2055
                              15:22:13.358 FLH: Read block - Writing: 4096 - Total: 274432 - Buffer size: 2055
                              15:22:13.822 FLH: Read block - Writing: 4096 - Total: 278528 - Buffer size: 2055
                              15:22:14.288 FLH: Read block - Writing: 4096 - Total: 282624 - Buffer size: 2055
                              15:22:14.755 FLH: Read block - Writing: 4096 - Total: 286720 - Buffer size: 2055
                              15:22:15.142 FLH: Read block - Writing: 4096 - Total: 290816 - Buffer size: 2055
                              15:22:15.609 FLH: Read block - Writing: 4096 - Total: 294912 - Buffer size: 2055
                              15:22:16.074 FLH: Read block - Writing: 4096 - Total: 299008 - Buffer size: 2055
                              15:22:16.541 FLH: Read block - Writing: 4096 - Total: 303104 - Buffer size: 2055
                              15:22:17.015 FLH: Read block - Writing: 4096 - Total: 307200 - Buffer size: 2055
                              15:22:17.483 FLH: Read block - Writing: 4096 - Total: 311296 - Buffer size: 2055
                              15:22:17.873 FLH: Read block - Writing: 4096 - Total: 315392 - Buffer size: 2055
                              15:22:18.341 FLH: Read block - Writing: 4096 - Total: 319488 - Buffer size: 2055
                              15:22:18.804 FLH: Read block - Writing: 4096 - Total: 323584 - Buffer size: 2055
                              15:22:19.269 FLH: Read block - Writing: 4096 - Total: 327680 - Buffer size: 2055
                              15:22:19.737 FLH: Read block - Writing: 4096 - Total: 331776 - Buffer size: 2055
                              15:22:20.202 FLH: Read block - Writing: 4096 - Total: 335872 - Buffer size: 2055
                              15:22:20.595 FLH: Read block - Writing: 4096 - Total: 339968 - Buffer size: 2055
                              15:22:21.059 FLH: Read block - Writing: 4096 - Total: 344064 - Buffer size: 2055
                              15:22:21.527 FLH: Read block - Writing: 4096 - Total: 348160 - Buffer size: 2055
                              15:22:21.998 FLH: Read block - Writing: 4096 - Total: 352256 - Buffer size: 2055
                              15:22:22.463 FLH: Read block - Writing: 4096 - Total: 356352 - Buffer size: 2055
                              15:22:22.930 FLH: Read block - Writing: 4096 - Total: 360448 - Buffer size: 2055
                              15:22:23.323 FLH: Read block - Writing: 4096 - Total: 364544 - Buffer size: 2055
                              15:22:23.789 FLH: Read block - Writing: 4096 - Total: 368640 - Buffer size: 2055
                              15:22:23.914 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "3", "time_elapsed": 47}}
                              15:22:24.260 FLH: Read block - Writing: 4096 - Total: 372736 - Buffer size: 2055
                              15:22:24.730 FLH: Read block - Writing: 4096 - Total: 376832 - Buffer size: 2055
                              15:22:25.197 FLH: Read block - Writing: 4096 - Total: 380928 - Buffer size: 2055
                              15:22:25.670 FLH: Read block - Writing: 4096 - Total: 385024 - Buffer size: 2055
                              15:22:26.066 FLH: Read block - Writing: 4096 - Total: 389120 - Buffer size: 2055
                              15:22:26.534 FLH: Read block - Writing: 4096 - Total: 393216 - Buffer size: 2055
                              15:22:27.005 FLH: Read block - Writing: 4096 - Total: 397312 - Buffer size: 2055
                              15:22:27.472 FLH: Read block - Writing: 4096 - Total: 401408 - Buffer size: 2055
                              15:22:27.938 FLH: Read block - Writing: 4096 - Total: 405504 - Buffer size: 2055
                              15:22:28.407 FLH: Read block - Writing: 4096 - Total: 409600 - Buffer size: 2055
                              15:22:28.922 FLH: Read block - Writing: 4096 - Total: 413696 - Buffer size: 1055
                              15:22:29.396 FLH: Read block - Writing: 4096 - Total: 417792 - Buffer size: 1055
                              15:22:29.862 FLH: Read block - Writing: 4096 - Total: 421888 - Buffer size: 1055
                              15:22:30.326 FLH: Read block - Writing: 4096 - Total: 425984 - Buffer size: 1055
                              15:22:30.792 FLH: Read block - Writing: 4096 - Total: 430080 - Buffer size: 1055
                              15:22:31.254 FLH: Read block - Writing: 4096 - Total: 434176 - Buffer size: 1055
                              15:22:31.729 FLH: Read block - Writing: 4096 - Total: 438272 - Buffer size: 1055
                              15:22:32.192 FLH: Read block - Writing: 4096 - Total: 442368 - Buffer size: 1055
                              15:22:32.661 FLH: Read block - Writing: 4096 - Total: 446464 - Buffer size: 1055
                              15:22:33.125 FLH: Read block - Writing: 4096 - Total: 450560 - Buffer size: 1055
                              15:22:33.595 FLH: Read block - Writing: 4096 - Total: 454656 - Buffer size: 1055
                              15:22:33.981 FLH: Read block - Writing: 4096 - Total: 458752 - Buffer size: 1055
                              15:22:34.453 FLH: Read block - Writing: 4096 - Total: 462848 - Buffer size: 1055
                              15:22:34.918 FLH: Read block - Writing: 4096 - Total: 466944 - Buffer size: 939
                              15:22:35.943 FLH: Read block - Writing: 4096 - Total: 471040 - Buffer size: 2375
                              15:22:36.412 FLH: Read block - Writing: 4096 - Total: 475136 - Buffer size: 2375
                              15:22:36.800 FLH: Read block - Writing: 4096 - Total: 479232 - Buffer size: 2375
                              15:22:37.272 FLH: Read block - Writing: 4096 - Total: 483328 - Buffer size: 2375
                              15:22:37.738 FLH: Read block - Writing: 4096 - Total: 487424 - Buffer size: 2375
                              15:22:38.204 FLH: Read block - Writing: 4096 - Total: 491520 - Buffer size: 2375
                              15:22:38.332 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "4", "time_elapsed": 61}}
                              15:22:38.677 FLH: Read block - Writing: 4096 - Total: 495616 - Buffer size: 2375
                              15:22:39.141 FLH: Read block - Writing: 4096 - Total: 499712 - Buffer size: 2375
                              15:22:39.538 FLH: Read block - Writing: 4096 - Total: 503808 - Buffer size: 2375
                              15:22:40.004 FLH: Read block - Writing: 4096 - Total: 507904 - Buffer size: 2375
                              15:22:40.473 FLH: Read block - Writing: 4096 - Total: 512000 - Buffer size: 2375
                              15:22:40.944 FLH: Read block - Writing: 4096 - Total: 516096 - Buffer size: 2375
                              15:22:41.412 FLH: Read block - Writing: 4096 - Total: 520192 - Buffer size: 2375
                              15:22:41.877 FLH: Read block - Writing: 4096 - Total: 524288 - Buffer size: 2375
                              15:22:42.270 FLH: Read block - Writing: 4096 - Total: 528384 - Buffer size: 2375
                              15:22:42.739 FLH: Read block - Writing: 4096 - Total: 532480 - Buffer size: 2375
                              15:22:43.204 FLH: Read block - Writing: 4096 - Total: 536576 - Buffer size: 2375
                              15:22:43.672 FLH: Read block - Writing: 4096 - Total: 540672 - Buffer size: 2375
                              15:22:44.137 FLH: Read block - Writing: 4096 - Total: 544768 - Buffer size: 2375
                              15:22:44.609 FLH: Read block - Writing: 4096 - Total: 548864 - Buffer size: 2375
                              15:22:44.997 FLH: Read block - Writing: 4096 - Total: 552960 - Buffer size: 2375
                              15:22:45.467 FLH: Read block - Writing: 4096 - Total: 557056 - Buffer size: 2375
                              15:22:45.938 FLH: Read block - Writing: 4096 - Total: 561152 - Buffer size: 2375
                              15:22:46.406 FLH: Read block - Writing: 4096 - Total: 565248 - Buffer size: 2375
                              15:22:46.871 FLH: Read block - Writing: 4096 - Total: 569344 - Buffer size: 2375
                              15:22:47.336 FLH: Read block - Writing: 4096 - Total: 573440 - Buffer size: 2375
                              15:22:47.723 FLH: Read block - Writing: 4096 - Total: 577536 - Buffer size: 2375
                              15:22:48.188 FLH: Read block - Writing: 4096 - Total: 581632 - Buffer size: 2375
                              15:22:48.657 FLH: Read block - Writing: 4096 - Total: 585728 - Buffer size: 2375
                              15:22:49.123 FLH: Read block - Writing: 4096 - Total: 589824 - Buffer size: 2375
                              15:22:49.594 FLH: Read block - Writing: 4096 - Total: 593920 - Buffer size: 2375
                              15:22:50.060 FLH: Read block - Writing: 4096 - Total: 598016 - Buffer size: 2375
                              15:22:50.452 FLH: Read block - Writing: 4096 - Total: 602112 - Buffer size: 2375
                              15:22:50.922 FLH: Read block - Writing: 4096 - Total: 606208 - Buffer size: 2375
                              15:22:51.390 FLH: Read block - Writing: 4096 - Total: 610304 - Buffer size: 2375
                              15:22:51.516 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "5", "time_elapsed": 74}}
                              15:22:51.861 FLH: Read block - Writing: 4096 - Total: 614400 - Buffer size: 2375
                              15:22:52.328 FLH: Read block - Writing: 4096 - Total: 618496 - Buffer size: 2375
                              15:22:52.793 FLH: Read block - Writing: 4096 - Total: 622592 - Buffer size: 2375
                              15:22:53.186 FLH: Read block - Writing: 4096 - Total: 626688 - Buffer size: 2375
                              15:22:53.655 FLH: Read block - Writing: 4096 - Total: 630784 - Buffer size: 2375
                              15:22:54.120 FLH: Read block - Writing: 4096 - Total: 634880 - Buffer size: 2375
                              15:22:54.593 FLH: Read block - Writing: 4096 - Total: 638976 - Buffer size: 2375
                              15:22:55.058 FLH: Read block - Writing: 4096 - Total: 643072 - Buffer size: 2375
                              15:22:55.528 FLH: Read block - Writing: 4096 - Total: 647168 - Buffer size: 2375
                              15:22:55.921 FLH: Read block - Writing: 4096 - Total: 651264 - Buffer size: 2375
                              15:22:56.388 FLH: Read block - Writing: 4096 - Total: 655360 - Buffer size: 2375
                              15:22:56.854 FLH: Read block - Writing: 4096 - Total: 659456 - Buffer size: 2375
                              15:22:57.319 FLH: Read block - Writing: 4096 - Total: 663552 - Buffer size: 2375
                              15:22:57.785 FLH: Read block - Writing: 4096 - Total: 667648 - Buffer size: 2375
                              15:22:58.258 FLH: Read block - Writing: 4096 - Total: 671744 - Buffer size: 2375
                              15:22:58.653 FLH: Read block - Writing: 4096 - Total: 675840 - Buffer size: 2375
                              15:22:59.119 FLH: Read block - Writing: 4096 - Total: 679936 - Buffer size: 2375
                              15:22:59.590 FLH: Read block - Writing: 4096 - Total: 684032 - Buffer size: 2375
                              15:23:00.058 FLH: Read block - Writing: 4096 - Total: 688128 - Buffer size: 2375
                              15:23:00.524 FLH: Read block - Writing: 4096 - Total: 692224 - Buffer size: 2375
                              15:23:00.990 FLH: Read block - Writing: 4096 - Total: 696320 - Buffer size: 2375
                              15:23:01.376 FLH: Read block - Writing: 4096 - Total: 700416 - Buffer size: 2375
                              15:23:01.842 FLH: Read block - Writing: 4096 - Total: 704512 - Buffer size: 2375
                              15:23:02.307 FLH: Read block - Writing: 4096 - Total: 708608 - Buffer size: 2375
                              15:23:02.773 FLH: Read block - Writing: 4096 - Total: 712704 - Buffer size: 2375
                              15:23:03.243 FLH: Read block - Writing: 4096 - Total: 716800 - Buffer size: 2375
                              15:23:03.710 FLH: Read block - Writing: 4096 - Total: 720896 - Buffer size: 2375
                              15:23:04.098 FLH: Read block - Writing: 4096 - Total: 724992 - Buffer size: 2375
                              15:23:04.572 FLH: Read block - Writing: 4096 - Total: 729088 - Buffer size: 2375
                              15:23:05.035 FLH: Read block - Writing: 4096 - Total: 733184 - Buffer size: 2375
                              15:23:05.162 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "6", "time_elapsed": 88}}
                              15:23:05.507 FLH: Read block - Writing: 4096 - Total: 737280 - Buffer size: 2375
                              15:23:05.976 FLH: Read block - Writing: 4096 - Total: 741376 - Buffer size: 2375
                              15:23:06.444 FLH: Read block - Writing: 4096 - Total: 745472 - Buffer size: 2375
                              15:23:06.840 FLH: Read block - Writing: 4096 - Total: 749568 - Buffer size: 2375
                              15:23:07.305 FLH: Read block - Writing: 4096 - Total: 753664 - Buffer size: 2375
                              15:23:07.773 FLH: Read block - Writing: 4096 - Total: 757760 - Buffer size: 2375
                              15:23:08.244 FLH: Read block - Writing: 4096 - Total: 761856 - Buffer size: 2375
                              15:23:08.712 FLH: Read block - Writing: 4096 - Total: 765952 - Buffer size: 2375
                              15:23:09.177 FLH: Read block - Writing: 4096 - Total: 770048 - Buffer size: 2375
                              15:23:09.572 FLH: Read block - Writing: 4096 - Total: 774144 - Buffer size: 2375
                              15:23:10.035 FLH: Read block - Writing: 4096 - Total: 778240 - Buffer size: 2375
                              15:23:10.503 FLH: Read block - Writing: 4096 - Total: 782336 - Buffer size: 2375
                              15:23:10.970 FLH: Read block - Writing: 4096 - Total: 786432 - Buffer size: 2375
                              15:23:11.438 FLH: Read block - Writing: 4096 - Total: 790528 - Buffer size: 2375
                              15:23:11.909 FLH: Read block - Writing: 4096 - Total: 794624 - Buffer size: 2375
                              15:23:12.301 FLH: Read block - Writing: 4096 - Total: 798720 - Buffer size: 2375
                              15:23:12.770 FLH: Read block - Writing: 4096 - Total: 802816 - Buffer size: 2375
                              15:23:13.240 FLH: Read block - Writing: 4096 - Total: 806912 - Buffer size: 2375
                              15:23:13.707 FLH: Read block - Writing: 4096 - Total: 811008 - Buffer size: 2375
                              15:23:14.172 FLH: Read block - Writing: 4096 - Total: 815104 - Buffer size: 2375
                              15:23:14.643 FLH: Read block - Writing: 4096 - Total: 819200 - Buffer size: 2375
                              15:23:15.033 FLH: Read block - Writing: 4096 - Total: 823296 - Buffer size: 2375
                              15:23:15.500 FLH: Read block - Writing: 4096 - Total: 827392 - Buffer size: 2375
                              15:23:15.967 FLH: Read block - Writing: 4096 - Total: 831488 - Buffer size: 2375
                              15:23:16.435 FLH: Read block - Writing: 4096 - Total: 835584 - Buffer size: 2375
                              15:23:16.906 FLH: Read block - Writing: 4096 - Total: 839680 - Buffer size: 2375
                              15:23:17.373 FLH: Read block - Writing: 4096 - Total: 843776 - Buffer size: 2375
                              15:23:17.762 FLH: Read block - Writing: 4096 - Total: 847872 - Buffer size: 2375
                              15:23:18.230 FLH: Read block - Writing: 4096 - Total: 851968 - Buffer size: 2375
                              15:23:18.699 FLH: Read block - Writing: 4096 - Total: 856064 - Buffer size: 2375
                              15:23:18.823 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "7", "time_elapsed": 101}}
                              15:23:19.169 FLH: Read block - Writing: 4096 - Total: 860160 - Buffer size: 2375
                              15:23:19.639 FLH: Read block - Writing: 4096 - Total: 864256 - Buffer size: 2375
                              15:23:20.105 FLH: Read block - Writing: 4096 - Total: 868352 - Buffer size: 2375
                              15:23:20.502 FLH: Read block - Writing: 4096 - Total: 872448 - Buffer size: 2375
                              15:23:20.969 FLH: Read block - Writing: 4096 - Total: 876544 - Buffer size: 2375
                              15:23:21.438 FLH: Read block - Writing: 4096 - Total: 880640 - Buffer size: 2375
                              15:23:21.908 FLH: Read block - Writing: 4096 - Total: 884736 - Buffer size: 2375
                              15:23:22.371 FLH: Read block - Writing: 4096 - Total: 888832 - Buffer size: 2375
                              15:23:22.832 FLH: Read block - Writing: 4096 - Total: 892928 - Buffer size: 27
                              15:23:23.228 FLH: Read block - Writing: 4096 - Total: 897024 - Buffer size: 27
                              15:23:23.698 FLH: Read block - Writing: 4096 - Total: 901120 - Buffer size: 27
                              15:23:24.162 FLH: Read block - Writing: 4096 - Total: 905216 - Buffer size: 27
                              15:23:24.630 FLH: Read block - Writing: 4096 - Total: 909312 - Buffer size: 27
                              15:23:25.094 FLH: Read block - Writing: 4096 - Total: 913408 - Buffer size: 27
                              15:23:25.564 FLH: Read block - Writing: 4096 - Total: 917504 - Buffer size: 27
                              15:23:25.953 FLH: Read block - Writing: 4096 - Total: 921600 - Buffer size: 27
                              15:23:26.420 FLH: Read block - Writing: 4096 - Total: 925696 - Buffer size: 27
                              15:23:26.889 FLH: Read block - Writing: 4096 - Total: 929792 - Buffer size: 27
                              15:23:27.353 FLH: Read block - Writing: 4096 - Total: 933888 - Buffer size: 27
                              15:23:27.817 FLH: Read block - Writing: 4096 - Total: 937984 - Buffer size: 27
                              15:23:28.283 FLH: Read block - Writing: 4096 - Total: 942080 - Buffer size: 27
                              15:23:28.670 FLH: Read block - Writing: 4096 - Total: 946176 - Buffer size: 27
                              15:23:29.133 FLH: Read block - Writing: 4096 - Total: 950272 - Buffer size: 27
                              15:23:29.600 FLH: Read block - Writing: 4096 - Total: 954368 - Buffer size: 27
                              15:23:30.066 FLH: Read block - Writing: 4096 - Total: 958464 - Buffer size: 27
                              15:23:30.538 FLH: Read block - Writing: 4096 - Total: 962560 - Buffer size: 27
                              15:23:31.003 FLH: Read block - Writing: 4096 - Total: 966656 - Buffer size: 27
                              15:23:31.394 FLH: Read block - Writing: 4096 - Total: 970752 - Buffer size: 27
                              15:23:31.863 FLH: Read block - Writing: 4096 - Total: 974848 - Buffer size: 27
                              15:23:32.326 FLH: Read block - Writing: 4096 - Total: 978944 - Buffer size: 27
                              15:23:32.450 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "8", "time_elapsed": 115}}
                              15:23:32.795 FLH: Read block - Writing: 4096 - Total: 983040 - Buffer size: 27
                              15:23:33.262 FLH: Read block - Writing: 4096 - Total: 987136 - Buffer size: 27
                              15:23:33.728 FLH: Read block - Writing: 4096 - Total: 991232 - Buffer size: 27
                              15:23:34.121 FLH: Read block - Writing: 4096 - Total: 995328 - Buffer size: 27
                              15:23:34.586 FLH: Read block - Writing: 4096 - Total: 999424 - Buffer size: 27
                              15:23:35.050 FLH: Read block - Writing: 4096 - Total: 1003520 - Buffer size: 27
                              15:23:35.523 FLH: Read block - Writing: 4096 - Total: 1007616 - Buffer size: 27
                              15:23:35.986 FLH: Read block - Writing: 4096 - Total: 1011712 - Buffer size: 27
                              15:23:36.453 FLH: Read block - Writing: 4096 - Total: 1015808 - Buffer size: 27
                              15:23:36.846 FLH: Read block - Writing: 4096 - Total: 1019904 - Buffer size: 27
                              15:23:37.310 FLH: Read block - Writing: 4096 - Total: 1024000 - Buffer size: 27
                              15:23:37.773 FLH: Read block - Writing: 4096 - Total: 1028096 - Buffer size: 27
                              15:23:38.238 FLH: Read block - Writing: 4096 - Total: 1032192 - Buffer size: 27
                              15:23:38.705 FLH: Read block - Writing: 4096 - Total: 1036288 - Buffer size: 27
                              15:23:39.174 FLH: Read block - Writing: 4096 - Total: 1040384 - Buffer size: 27
                              15:23:39.566 FLH: Read block - Writing: 4096 - Total: 1044480 - Buffer size: 27
                              15:23:40.031 FLH: Read block - Writing: 4096 - Total: 1048576 - Buffer size: 27
                              15:23:40.503 FLH: Read block - Writing: 4096 - Total: 1052672 - Buffer size: 27
                              15:23:40.966 FLH: Read block - Writing: 4096 - Total: 1056768 - Buffer size: 27
                              15:23:41.433 FLH: Read block - Writing: 4096 - Total: 1060864 - Buffer size: 27
                              15:23:41.897 FLH: Read block - Writing: 4096 - Total: 1064960 - Buffer size: 27
                              15:23:42.285 FLH: Read block - Writing: 4096 - Total: 1069056 - Buffer size: 27
                              15:23:42.751 FLH: Read block - Writing: 4096 - Total: 1073152 - Buffer size: 27
                              15:23:43.215 FLH: Read block - Writing: 4096 - Total: 1077248 - Buffer size: 27
                              15:23:43.684 FLH: Read block - Writing: 4096 - Total: 1081344 - Buffer size: 27
                              15:23:44.153 FLH: Read block - Writing: 4096 - Total: 1085440 - Buffer size: 27
                              15:23:44.618 FLH: Read block - Writing: 4096 - Total: 1089536 - Buffer size: 27
                              15:23:45.006 FLH: Read block - Writing: 4096 - Total: 1093632 - Buffer size: 27
                              15:23:45.479 FLH: Read block - Writing: 4096 - Total: 1097728 - Buffer size: 27
                              15:23:45.942 FLH: Read block - Writing: 4096 - Total: 1101824 - Buffer size: 27
                              15:23:46.069 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "9", "time_elapsed": 129}}
                              15:23:46.415 FLH: Read block - Writing: 4096 - Total: 1105920 - Buffer size: 27
                              15:23:46.881 FLH: Read block - Writing: 4096 - Total: 1110016 - Buffer size: 27
                              15:23:47.345 FLH: Read block - Writing: 4096 - Total: 1114112 - Buffer size: 27
                              15:23:47.740 FLH: Read block - Writing: 4096 - Total: 1118208 - Buffer size: 27
                              15:23:48.203 FLH: Read block - Writing: 4096 - Total: 1122304 - Buffer size: 27
                              15:23:48.670 FLH: Read block - Writing: 4096 - Total: 1126400 - Buffer size: 27
                              15:23:49.140 FLH: Read block - Writing: 4096 - Total: 1130496 - Buffer size: 27
                              15:23:49.606 FLH: Read block - Writing: 4096 - Total: 1134592 - Buffer size: 27
                              15:23:50.069 FLH: Read block - Writing: 4096 - Total: 1138688 - Buffer size: 27
                              15:23:50.463 FLH: Read block - Writing: 4096 - Total: 1142784 - Buffer size: 27
                              15:23:50.928 FLH: Read block - Writing: 4096 - Total: 1146880 - Buffer size: 27
                              15:23:51.393 FLH: Read block - Writing: 4096 - Total: 1150976 - Buffer size: 27
                              15:23:51.859 FLH: Read block - Writing: 4096 - Total: 1155072 - Buffer size: 27
                              15:23:52.323 FLH: Read block - Writing: 4096 - Total: 1159168 - Buffer size: 27
                              15:23:52.793 FLH: Read block - Writing: 4096 - Total: 1163264 - Buffer size: 27
                              15:23:53.182 FLH: Read block - Writing: 4096 - Total: 1167360 - Buffer size: 27
                              15:23:53.647 FLH: Read block - Writing: 4096 - Total: 1171456 - Buffer size: 27
                              15:23:54.117 FLH: Read block - Writing: 4096 - Total: 1175552 - Buffer size: 27
                              15:23:54.583 FLH: Read block - Writing: 4096 - Total: 1179648 - Buffer size: 27
                              15:23:55.045 FLH: Read block - Writing: 4096 - Total: 1183744 - Buffer size: 27
                              15:23:55.513 FLH: Read block - Writing: 4096 - Total: 1187840 - Buffer size: 27
                              15:23:55.901 FLH: Read block - Writing: 4096 - Total: 1191936 - Buffer size: 27
                              15:23:56.366 FLH: Read block - Writing: 4096 - Total: 1196032 - Buffer size: 27
                              15:23:56.829 FLH: Read block - Writing: 4096 - Total: 1200128 - Buffer size: 27
                              15:23:57.295 FLH: Read block - Writing: 4096 - Total: 1204224 - Buffer size: 27
                              15:23:57.765 FLH: Read block - Writing: 4096 - Total: 1208320 - Buffer size: 27
                              15:23:58.228 FLH: Read block - Writing: 4096 - Total: 1212416 - Buffer size: 27
                              15:23:58.621 FLH: Read block - Writing: 4096 - Total: 1216512 - Buffer size: 27
                              15:23:59.090 FLH: Read block - Writing: 4096 - Total: 1220608 - Buffer size: 27
                              15:23:59.217 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "10", "time_elapsed": 142}}
                              15:23:59.562 FLH: Read block - Writing: 4096 - Total: 1224704 - Buffer size: 27
                              15:24:00.025 FLH: Read block - Writing: 4096 - Total: 1228800 - Buffer size: 27
                              15:24:00.492 FLH: Read block - Writing: 4096 - Total: 1232896 - Buffer size: 27
                              15:24:00.958 FLH: Read block - Writing: 4096 - Total: 1236992 - Buffer size: 27
                              15:24:01.353 FLH: Read block - Writing: 4096 - Total: 1241088 - Buffer size: 27
                              15:24:01.820 FLH: Read block - Writing: 4096 - Total: 1245184 - Buffer size: 27
                              15:24:02.283 FLH: Read block - Writing: 4096 - Total: 1249280 - Buffer size: 27
                              15:24:02.751 FLH: Read block - Writing: 4096 - Total: 1253376 - Buffer size: 27
                              15:24:03.215 FLH: Read block - Writing: 4096 - Total: 1257472 - Buffer size: 27
                              15:24:03.681 FLH: Read block - Writing: 4096 - Total: 1261568 - Buffer size: 27
                              15:24:04.073 FLH: Read block - Writing: 4096 - Total: 1265664 - Buffer size: 27
                              15:24:04.538 FLH: Read block - Writing: 4096 - Total: 1269760 - Buffer size: 27
                              15:24:05.004 FLH: Read block - Writing: 4096 - Total: 1273856 - Buffer size: 27
                              15:24:05.471 FLH: Read block - Writing: 4096 - Total: 1277952 - Buffer size: 27
                              15:24:05.936 FLH: Read block - Writing: 4096 - Total: 1282048 - Buffer size: 27
                              15:24:06.406 FLH: Read block - Writing: 4096 - Total: 1286144 - Buffer size: 27
                              15:24:06.794 FLH: Read block - Writing: 4096 - Total: 1290240 - Buffer size: 27
                              15:24:07.259 FLH: Read block - Writing: 4096 - Total: 1294336 - Buffer size: 27
                              15:24:07.730 FLH: Read block - Writing: 4096 - Total: 1298432 - Buffer size: 27
                              15:24:08.194 FLH: Read block - Writing: 4096 - Total: 1302528 - Buffer size: 27
                              15:24:08.660 FLH: Read block - Writing: 4096 - Total: 1306624 - Buffer size: 27
                              15:24:09.124 FLH: Read block - Writing: 4096 - Total: 1310720 - Buffer size: 27
                              15:24:09.513 FLH: Read block - Writing: 4096 - Total: 1314816 - Buffer size: 27
                              15:24:09.976 FLH: Read block - Writing: 4096 - Total: 1318912 - Buffer size: 27
                              15:24:10.444 FLH: Read block - Writing: 4096 - Total: 1323008 - Buffer size: 27
                              15:24:10.910 FLH: Read block - Writing: 4096 - Total: 1327104 - Buffer size: 27
                              15:24:11.381 FLH: Read block - Writing: 4096 - Total: 1331200 - Buffer size: 27
                              15:24:11.843 FLH: Read block - Writing: 4096 - Total: 1335296 - Buffer size: 27
                              15:24:12.235 FLH: Read block - Writing: 4096 - Total: 1339392 - Buffer size: 27
                              15:24:12.707 FLH: Read block - Writing: 4096 - Total: 1343488 - Buffer size: 27
                              15:24:12.832 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "11", "time_elapsed": 155}}
                              15:24:13.178 FLH: Read block - Writing: 4096 - Total: 1347584 - Buffer size: 27
                              15:24:13.644 FLH: Read block - Writing: 4096 - Total: 1351680 - Buffer size: 27
                              15:24:14.109 FLH: Read block - Writing: 4096 - Total: 1355776 - Buffer size: 27
                              15:24:14.575 FLH: Read block - Writing: 4096 - Total: 1359872 - Buffer size: 27
                              15:24:14.969 FLH: Read block - Writing: 4096 - Total: 1363968 - Buffer size: 27
                              15:24:15.436 FLH: Read block - Writing: 4096 - Total: 1368064 - Buffer size: 27
                              15:24:15.900 FLH: Read block - Writing: 4096 - Total: 1372160 - Buffer size: 27
                              15:24:16.370 FLH: Read block - Writing: 4096 - Total: 1376256 - Buffer size: 27
                              15:24:16.833 FLH: Read block - Writing: 4096 - Total: 1380352 - Buffer size: 27
                              15:24:17.295 FLH: Read block - Writing: 4096 - Total: 1384448 - Buffer size: 27
                              15:24:17.688 FLH: Read block - Writing: 4096 - Total: 1388544 - Buffer size: 27
                              15:24:18.151 FLH: Read block - Writing: 4096 - Total: 1392640 - Buffer size: 27
                              15:24:18.617 FLH: Read block - Writing: 4096 - Total: 1396736 - Buffer size: 27
                              15:24:19.082 FLH: Read block - Writing: 4096 - Total: 1400832 - Buffer size: 27
                              15:24:19.549 FLH: Read block - Writing: 4096 - Total: 1404928 - Buffer size: 27
                              15:24:20.019 FLH: Read block - Writing: 4096 - Total: 1409024 - Buffer size: 27
                              15:24:20.410 FLH: Read block - Writing: 4096 - Total: 1413120 - Buffer size: 27
                              15:24:20.874 FLH: Read block - Writing: 4096 - Total: 1417216 - Buffer size: 27
                              15:24:21.342 FLH: Read block - Writing: 4096 - Total: 1421312 - Buffer size: 27
                              15:24:21.809 FLH: Read block - Writing: 4096 - Total: 1425408 - Buffer size: 27
                              15:24:22.273 FLH: Read block - Writing: 4096 - Total: 1429504 - Buffer size: 27
                              15:24:22.741 FLH: Read block - Writing: 4096 - Total: 1433600 - Buffer size: 27
                              15:24:23.129 FLH: Read block - Writing: 4096 - Total: 1437696 - Buffer size: 27
                              15:24:23.595 FLH: Read block - Writing: 4096 - Total: 1441792 - Buffer size: 27
                              15:24:24.060 FLH: Read block - Writing: 4096 - Total: 1445888 - Buffer size: 27
                              15:24:24.526 FLH: Read block - Writing: 4096 - Total: 1449984 - Buffer size: 27
                              15:24:24.995 FLH: Read block - Writing: 4096 - Total: 1454080 - Buffer size: 27
                              15:24:25.461 FLH: Read block - Writing: 4096 - Total: 1458176 - Buffer size: 27
                              15:24:25.851 FLH: Read block - Writing: 4096 - Total: 1462272 - Buffer size: 27
                              15:24:26.321 FLH: Read block - Writing: 4096 - Total: 1466368 - Buffer size: 27
                              15:24:26.444 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "12", "time_elapsed": 169}}
                              15:24:26.790 FLH: Read block - Writing: 4096 - Total: 1470464 - Buffer size: 27
                              15:24:27.255 FLH: Read block - Writing: 4096 - Total: 1474560 - Buffer size: 27
                              15:24:27.722 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 27
                              15:24:28.185 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 27
                              15:24:28.580 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 27
                              15:24:29.045 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 27
                              15:24:29.512 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 27
                              15:24:29.982 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 27
                              15:24:30.449 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 27
                              15:24:30.912 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 27
                              15:24:31.305 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 27
                              15:24:31.769 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 27
                              15:24:32.233 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 27
                              15:24:32.701 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 27
                              15:24:33.166 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 27
                              15:24:33.637 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 27
                              15:24:34.027 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 27
                              15:24:34.493 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 27
                              15:24:34.963 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 27
                              15:24:35.429 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 27
                              15:24:35.893 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 27
                              15:24:36.358 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 27
                              15:24:36.746 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 27
                              15:24:37.210 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 27
                              15:24:37.677 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 27
                              15:24:38.142 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 27
                              15:24:38.614 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 27
                              15:24:39.077 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 27
                              15:24:39.469 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 27
                              15:24:39.938 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 27
                              15:24:40.064 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 183}}
                              15:24:40.409 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 27
                              15:24:40.874 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 27
                              15:24:41.337 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 27
                              15:24:41.802 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 27
                              15:24:42.196 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 27
                              15:24:42.663 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 27
                              15:24:43.128 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 27
                              15:24:43.599 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 27
                              15:24:44.063 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 27
                              15:24:44.530 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 27
                              15:24:44.923 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 27
                              15:24:45.391 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 27
                              15:24:45.854 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 27
                              15:24:46.322 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 27
                              15:24:46.785 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 27
                              15:24:47.253 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 27
                              15:24:47.646 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 27
                              15:24:48.109 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 27
                              15:24:48.580 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 27
                              15:24:49.043 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 27
                              15:24:49.508 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 27
                              15:24:49.973 FLH: Read block - Writing: 4096 - Total: 1679360 - Buffer size: 27
                              15:24:50.361 FLH: Read block - Writing: 4096 - Total: 1683456 - Buffer size: 27
                              15:24:50.824 FLH: Read block - Writing: 4096 - Total: 1687552 - Buffer size: 27
                              15:24:51.288 FLH: Read block - Writing: 4096 - Total: 1691648 - Buffer size: 27
                              15:24:51.755 FLH: Read block - Writing: 4096 - Total: 1695744 - Buffer size: 27
                              15:24:52.223 FLH: Read block - Writing: 4096 - Total: 1699840 - Buffer size: 27
                              15:24:52.689 FLH: Read block - Writing: 4096 - Total: 1703936 - Buffer size: 27
                              15:24:53.080 FLH: Read block - Writing: 4096 - Total: 1708032 - Buffer size: 27
                              15:24:53.213 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "14", "time_elapsed": 196}}
                              15:24:53.559 FLH: Read block - Writing: 4096 - Total: 1712128 - Buffer size: 27
                              15:24:54.023 FLH: Read block - Writing: 4096 - Total: 1716224 - Buffer size: 27
                              15:24:54.490 FLH: Read block - Writing: 4096 - Total: 1720320 - Buffer size: 27
                              15:24:55.058 FLH: Read block - Writing: 4096 - Total: 1724416 - Buffer size: 2627
                              15:24:55.528 FLH: Read block - Writing: 4096 - Total: 1728512 - Buffer size: 2627
                              15:24:55.922 FLH: Read block - Writing: 4096 - Total: 1732608 - Buffer size: 2627
                              15:24:56.388 FLH: Read block - Writing: 4096 - Total: 1736704 - Buffer size: 2627
                              15:24:56.857 FLH: Read block - Writing: 4096 - Total: 1740800 - Buffer size: 2627
                              15:24:57.326 FLH: Read block - Writing: 4096 - Total: 1744896 - Buffer size: 2627
                              15:24:57.792 FLH: Read block - Writing: 4096 - Total: 1748992 - Buffer size: 2627
                              15:24:58.256 FLH: Read block - Writing: 4096 - Total: 1753088 - Buffer size: 2627
                              15:24:58.651 FLH: Read block - Writing: 4096 - Total: 1757184 - Buffer size: 2627
                              15:24:59.118 FLH: Read block - Writing: 4096 - Total: 1761280 - Buffer size: 2627
                              15:24:59.584 FLH: Read block - Writing: 4096 - Total: 1765376 - Buffer size: 2627
                              15:25:00.049 FLH: Read block - Writing: 4096 - Total: 1769472 - Buffer size: 2627
                              15:25:00.519 FLH: Read block - Writing: 4096 - Total: 1773568 - Buffer size: 2627
                              15:25:00.990 FLH: Read block - Writing: 4096 - Total: 1777664 - Buffer size: 2627
                              15:25:01.381 FLH: Read block - Writing: 4096 - Total: 1781760 - Buffer size: 2627
                              15:25:01.845 FLH: Read block - Writing: 4096 - Total: 1785856 - Buffer size: 2627
                              15:25:02.314 FLH: Read block - Writing: 4096 - Total: 1789952 - Buffer size: 2627
                              15:25:02.780 FLH: Read block - Writing: 4096 - Total: 1794048 - Buffer size: 2627
                              15:25:03.245 FLH: Read block - Writing: 4096 - Total: 1798144 - Buffer size: 2627
                              15:25:03.715 FLH: Read block - Writing: 4096 - Total: 1802240 - Buffer size: 2627
                              15:25:04.102 FLH: Read block - Writing: 4096 - Total: 1806336 - Buffer size: 2627
                              15:25:04.567 FLH: Read block - Writing: 4096 - Total: 1810432 - Buffer size: 2627
                              15:25:05.034 FLH: Read block - Writing: 4096 - Total: 1814528 - Buffer size: 2627
                              15:25:05.499 FLH: Read block - Writing: 4096 - Total: 1818624 - Buffer size: 535
                              15:25:05.969 FLH: Read block - Writing: 4096 - Total: 1822720 - Buffer size: 535
                              15:25:06.436 FLH: Read block - Writing: 4096 - Total: 1826816 - Buffer size: 535
                              15:25:06.823 FLH: Read block - Writing: 4096 - Total: 1830912 - Buffer size: 535
                              15:25:06.954 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "15", "time_elapsed": 210}}
                              15:25:07.300 FLH: Read block - Writing: 4096 - Total: 1835008 - Buffer size: 535
                              15:25:07.763 FLH: Read block - Writing: 4096 - Total: 1839104 - Buffer size: 535
                              15:25:08.228 FLH: Read block - Writing: 4096 - Total: 1843200 - Buffer size: 535
                              15:25:08.696 FLH: Read block - Writing: 4096 - Total: 1847296 - Buffer size: 535
                              15:25:09.161 FLH: Read block - Writing: 4096 - Total: 1851392 - Buffer size: 535
                              15:25:09.556 FLH: Read block - Writing: 4096 - Total: 1855488 - Buffer size: 535
                              15:25:10.023 FLH: Read block - Writing: 4096 - Total: 1859584 - Buffer size: 535
                              15:25:10.490 FLH: Read block - Writing: 4096 - Total: 1863680 - Buffer size: 535
                              15:25:10.960 FLH: Read block - Writing: 4096 - Total: 1867776 - Buffer size: 535
                              15:25:11.427 FLH: Read block - Writing: 4096 - Total: 1871872 - Buffer size: 535
                              15:25:11.891 FLH: Read block - Writing: 4096 - Total: 1875968 - Buffer size: 535
                              15:25:12.283 FLH: Read block - Writing: 4096 - Total: 1880064 - Buffer size: 535
                              15:25:12.750 FLH: Read block - Writing: 4096 - Total: 1884160 - Buffer size: 535
                              15:25:13.215 FLH: Read block - Writing: 4096 - Total: 1888256 - Buffer size: 535
                              15:25:13.683 FLH: Read block - Writing: 4096 - Total: 1892352 - Buffer size: 535
                              15:25:14.149 FLH: Read block - Writing: 4096 - Total: 1896448 - Buffer size: 535
                              15:25:14.622 FLH: Read block - Writing: 4096 - Total: 1900544 - Buffer size: 535
                              15:25:15.009 FLH: Read block - Writing: 4096 - Total: 1904640 - Buffer size: 535
                              15:25:15.477 FLH: Read block - Writing: 4096 - Total: 1908736 - Buffer size: 535
                              15:25:15.949 FLH: Read block - Writing: 4096 - Total: 1912832 - Buffer size: 535
                              15:25:16.416 FLH: Read block - Writing: 4096 - Total: 1916928 - Buffer size: 535
                              15:25:16.881 FLH: Read block - Writing: 4096 - Total: 1921024 - Buffer size: 535
                              15:25:17.346 FLH: Read block - Writing: 4096 - Total: 1925120 - Buffer size: 535
                              15:25:17.736 FLH: Read block - Writing: 4096 - Total: 1929216 - Buffer size: 535
                              15:25:18.199 FLH: Read block - Writing: 4096 - Total: 1933312 - Buffer size: 535
                              15:25:18.665 FLH: Read block - Writing: 4096 - Total: 1937408 - Buffer size: 535
                              15:25:19.130 FLH: Read block - Writing: 4096 - Total: 1941504 - Buffer size: 535
                              15:25:19.600 FLH: Read block - Writing: 4096 - Total: 1945600 - Buffer size: 535
                              15:25:20.063 FLH: Read block - Writing: 4096 - Total: 1949696 - Buffer size: 535
                              15:25:20.452 FLH: Read block - Writing: 4096 - Total: 1953792 - Buffer size: 535
                              15:25:20.584 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "16", "time_elapsed": 223}}
                              15:25:20.929 FLH: Read block - Writing: 4096 - Total: 1957888 - Buffer size: 535
                              15:25:21.394 FLH: Read block - Writing: 4096 - Total: 1961984 - Buffer size: 535
                              15:25:21.858 FLH: Read block - Writing: 4096 - Total: 1966080 - Buffer size: 535
                              15:25:22.323 FLH: Read block - Writing: 4096 - Total: 1970176 - Buffer size: 535
                              15:25:22.786 FLH: Read block - Writing: 4096 - Total: 1974272 - Buffer size: 535
                              15:25:23.180 FLH: Read block - Writing: 4096 - Total: 1978368 - Buffer size: 535
                              15:25:23.648 FLH: Read block - Writing: 4096 - Total: 1982464 - Buffer size: 535
                              15:25:24.113 FLH: Read block - Writing: 4096 - Total: 1986560 - Buffer size: 535
                              15:25:24.583 FLH: Read block - Writing: 4096 - Total: 1990656 - Buffer size: 535
                              15:25:25.048 FLH: Read block - Writing: 4096 - Total: 1994752 - Buffer size: 535
                              15:25:25.515 FLH: Read block - Writing: 4096 - Total: 1998848 - Buffer size: 535
                              15:25:25.907 FLH: Read block - Writing: 4096 - Total: 2002944 - Buffer size: 535
                              15:25:26.372 FLH: Read block - Writing: 4096 - Total: 2007040 - Buffer size: 535
                              15:25:26.837 FLH: Read block - Writing: 4096 - Total: 2011136 - Buffer size: 535
                              15:25:27.302 FLH: Read block - Writing: 4096 - Total: 2015232 - Buffer size: 535
                              15:25:27.766 FLH: Read block - Writing: 4096 - Total: 2019328 - Buffer size: 535
                              15:25:28.238 FLH: Read block - Writing: 4096 - Total: 2023424 - Buffer size: 535
                              15:25:28.628 FLH: Read block - Writing: 4096 - Total: 2027520 - Buffer size: 535
                              15:25:29.093 FLH: Read block - Writing: 4096 - Total: 2031616 - Buffer size: 535
                              15:25:29.570 FLH: Read block - Writing: 4096 - Total: 2035712 - Buffer size: 535
                              15:25:30.034 FLH: Read block - Writing: 4096 - Total: 2039808 - Buffer size: 535
                              15:25:30.500 FLH: Read block - Writing: 4096 - Total: 2043904 - Buffer size: 535
                              15:25:30.964 FLH: Read block - Writing: 4096 - Total: 2048000 - Buffer size: 535
                              15:25:31.352 FLH: Read block - Writing: 4096 - Total: 2052096 - Buffer size: 535
                              15:25:31.817 FLH: Read block - Writing: 4096 - Total: 2056192 - Buffer size: 535
                              15:25:32.283 FLH: Read block - Writing: 4096 - Total: 2060288 - Buffer size: 535
                              15:25:32.747 FLH: Read block - Writing: 4096 - Total: 2064384 - Buffer size: 535
                              15:25:33.217 FLH: Read block - Writing: 4096 - Total: 2068480 - Buffer size: 535
                              15:25:33.683 FLH: Read block - Writing: 4096 - Total: 2072576 - Buffer size: 535
                              15:25:34.073 FLH: Read block - Writing: 4096 - Total: 2076672 - Buffer size: 535
                              15:25:34.206 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "17", "time_elapsed": 237}}
                              15:25:34.551 FLH: Read block - Writing: 4096 - Total: 2080768 - Buffer size: 535
                              15:25:35.013 FLH: Read block - Writing: 4096 - Total: 2084864 - Buffer size: 535
                              15:25:35.479 FLH: Read block - Writing: 4096 - Total: 2088960 - Buffer size: 535
                              15:25:35.946 FLH: Read block - Writing: 4096 - Total: 2093056 - Buffer size: 535
                              15:25:36.411 FLH: Read block - Writing: 4096 - Total: 2097152 - Buffer size: 535
                              15:25:36.801 FLH: Read block - Writing: 4096 - Total: 2101248 - Buffer size: 535
                              15:25:37.267 FLH: Read block - Writing: 4096 - Total: 2105344 - Buffer size: 535
                              15:25:37.735 FLH: Read block - Writing: 4096 - Total: 2109440 - Buffer size: 535
                              15:25:38.205 FLH: Read block - Writing: 4096 - Total: 2113536 - Buffer size: 535
                              15:25:38.672 FLH: Read block - Writing: 4096 - Total: 2117632 - Buffer size: 535
                              15:25:39.135 FLH: Read block - Writing: 4096 - Total: 2121728 - Buffer size: 535
                              15:25:39.530 FLH: Read block - Writing: 4096 - Total: 2125824 - Buffer size: 535
                              15:25:39.994 FLH: Read block - Writing: 4096 - Total: 2129920 - Buffer size: 535
                              15:25:40.461 FLH: Read block - Writing: 4096 - Total: 2134016 - Buffer size: 535
                              15:25:40.927 FLH: Read block - Writing: 4096 - Total: 2138112 - Buffer size: 535
                              15:25:41.392 FLH: Read block - Writing: 4096 - Total: 2142208 - Buffer size: 535
                              15:25:41.862 FLH: Read block - Writing: 4096 - Total: 2146304 - Buffer size: 535
                              15:25:42.555 FLH: Read block - Writing: 4096 - Total: 2150400 - Buffer size: 1911
                              15:25:43.023 FLH: Read block - Writing: 4096 - Total: 2154496 - Buffer size: 1911
                              15:25:43.496 FLH: Read block - Writing: 4096 - Total: 2158592 - Buffer size: 1911
                              15:25:43.959 FLH: Read block - Writing: 4096 - Total: 2162688 - Buffer size: 1911
                              15:25:44.426 FLH: Read block - Writing: 4096 - Total: 2166784 - Buffer size: 1911
                              15:25:44.816 FLH: Read block - Writing: 4096 - Total: 2170880 - Buffer size: 115
                              15:25:45.281 FLH: Read block - Writing: 4096 - Total: 2174976 - Buffer size: 115
                              15:25:45.745 FLH: Read block - Writing: 4096 - Total: 2179072 - Buffer size: 115
                              15:25:46.208 FLH: Read block - Writing: 4096 - Total: 2183168 - Buffer size: 115
                              15:25:46.675 FLH: Read block - Writing: 4096 - Total: 2187264 - Buffer size: 115
                              15:25:47.145 FLH: Read block - Writing: 4096 - Total: 2191360 - Buffer size: 115
                              15:25:47.536 FLH: Read block - Writing: 4096 - Total: 2195456 - Buffer size: 115
                              15:25:47.000 FLH: Read block - Writing: 4096 - Total: 2199552 - Buffer size: 115
                              15:25:48.132 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "18", "time_elapsed": 251}}
                              15:25:48.478 FLH: Read block - Writing: 4096 - Total: 2203648 - Buffer size: 115
                              15:25:48.942 FLH: Read block - Writing: 4096 - Total: 2207744 - Buffer size: 115
                              15:25:49.406 FLH: Read block - Writing: 4096 - Total: 2211840 - Buffer size: 115
                              15:25:49.869 FLH: Read block - Writing: 4096 - Total: 2215936 - Buffer size: 115
                              15:25:50.263 FLH: Read block - Writing: 4096 - Total: 2220032 - Buffer size: 115
                              15:25:50.733 FLH: Read block - Writing: 4096 - Total: 2224128 - Buffer size: 115
                              15:25:51.196 FLH: Read block - Writing: 4096 - Total: 2228224 - Buffer size: 115
                              15:25:51.667 FLH: Read block - Writing: 4096 - Total: 2232320 - Buffer size: 115
                              15:25:52.137 FLH: Read block - Writing: 4096 - Total: 2236416 - Buffer size: 115
                              15:25:52.602 FLH: Read block - Writing: 4096 - Total: 2240512 - Buffer size: 115
                              15:25:52.991 FLH: Read block - Writing: 4096 - Total: 2244608 - Buffer size: 115
                              15:25:53.462 FLH: Read block - Writing: 4096 - Total: 2248704 - Buffer size: 115
                              15:25:53.927 FLH: Read block - Writing: 4096 - Total: 2252800 - Buffer size: 115
                              15:25:54.392 FLH: Read block - Writing: 4096 - Total: 2256896 - Buffer size: 115
                              15:25:54.858 FLH: Read block - Writing: 4096 - Total: 2260992 - Buffer size: 115
                              15:25:55.321 FLH: Read block - Writing: 4096 - Total: 2265088 - Buffer size: 115
                              15:25:55.707 FLH: Read block - Writing: 4096 - Total: 2269184 - Buffer size: 115
                              15:25:56.173 FLH: Read block - Writing: 4096 - Total: 2273280 - Buffer size: 115
                              15:25:56.638 FLH: Read block - Writing: 4096 - Total: 2277376 - Buffer size: 115
                              15:25:57.108 FLH: Read block - Writing: 4096 - Total: 2281472 - Buffer size: 115
                              15:25:57.574 FLH: Read block - Writing: 4096 - Total: 2285568 - Buffer size: 115
                              15:25:58.039 FLH: Read block - Writing: 4096 - Total: 2289664 - Buffer size: 115
                              15:25:58.433 FLH: Read block - Writing: 4096 - Total: 2293760 - Buffer size: 115
                              15:25:58.899 FLH: Read block - Writing: 4096 - Total: 2297856 - Buffer size: 115
                              15:25:58.928 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:25:58","Uptime":"0T00:05:08","UptimeSec":308,"Heap":121,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":1024,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":217},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:03"}}
                              15:25:58.974 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:25:58","ANALOG":{"Temperature1":28.1},"ESP32":{"Temperature":60.0},"TempUnit":"C"}
                              15:25:59.362 FLH: Read block - Writing: 4096 - Total: 2301952 - Buffer size: 115
                              15:25:59.830 FLH: Read block - Writing: 4096 - Total: 2306048 - Buffer size: 115
                              15:26:00.294 FLH: Read block - Writing: 4096 - Total: 2310144 - Buffer size: 115
                              15:26:00.763 FLH: Read block - Writing: 4096 - Total: 2314240 - Buffer size: 115
                              15:26:01.158 FLH: Read block - Writing: 4096 - Total: 2318336 - Buffer size: 115
                              15:26:01.288 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "19", "time_elapsed": 264}}
                              15:26:01.633 FLH: Read block - Writing: 4096 - Total: 2322432 - Buffer size: 115
                              15:26:02.105 FLH: Read block - Writing: 4096 - Total: 2326528 - Buffer size: 115
                              15:26:02.571 FLH: Read block - Writing: 4096 - Total: 2330624 - Buffer size: 115
                              15:26:03.035 FLH: Read block - Writing: 4096 - Total: 2334720 - Buffer size: 115
                              15:26:03.502 FLH: Read block - Writing: 4096 - Total: 2338816 - Buffer size: 115
                              15:26:03.894 FLH: Read block - Writing: 4096 - Total: 2342912 - Buffer size: 115
                              15:26:04.359 FLH: Read block - Writing: 4096 - Total: 2347008 - Buffer size: 115
                              15:26:04.821 FLH: Read block - Writing: 4096 - Total: 2351104 - Buffer size: 115
                              15:26:05.287 FLH: Read block - Writing: 4096 - Total: 2355200 - Buffer size: 115
                              15:26:05.756 FLH: Read block - Writing: 4096 - Total: 2359296 - Buffer size: 115
                              15:26:06.217 FLH: Read block - Writing: 4096 - Total: 2363392 - Buffer size: 115
                              15:26:06.606 FLH: Read block - Writing: 4096 - Total: 2367488 - Buffer size: 115
                              15:26:07.076 FLH: Read block - Writing: 4096 - Total: 2371584 - Buffer size: 115
                              15:26:07.542 FLH: Read block - Writing: 4096 - Total: 2375680 - Buffer size: 115
                              15:26:08.008 FLH: Read block - Writing: 4096 - Total: 2379776 - Buffer size: 115
                              15:26:08.476 FLH: Read block - Writing: 4096 - Total: 2383872 - Buffer size: 115
                              15:26:08.941 FLH: Read block - Writing: 4096 - Total: 2387968 - Buffer size: 115
                              15:26:09.331 FLH: Read block - Writing: 4096 - Total: 2392064 - Buffer size: 115
                              15:26:09.793 FLH: Read block - Writing: 4096 - Total: 2396160 - Buffer size: 115
                              15:26:10.260 FLH: Read block - Writing: 4096 - Total: 2400256 - Buffer size: 115
                              15:26:10.733 FLH: Read block - Writing: 4096 - Total: 2404352 - Buffer size: 115
                              15:26:11.197 FLH: Read block - Writing: 4096 - Total: 2408448 - Buffer size: 115
                              15:26:11.663 FLH: Read block - Writing: 4096 - Total: 2412544 - Buffer size: 115
                              15:26:12.054 FLH: Read block - Writing: 4096 - Total: 2416640 - Buffer size: 115
                              15:26:12.522 FLH: Read block - Writing: 4096 - Total: 2420736 - Buffer size: 115
                              15:26:12.984 FLH: Read block - Writing: 4096 - Total: 2424832 - Buffer size: 115
                              15:26:13.450 FLH: Read block - Writing: 4096 - Total: 2428928 - Buffer size: 115
                              15:26:13.914 FLH: Read block - Writing: 4096 - Total: 2433024 - Buffer size: 115
                              15:26:14.383 FLH: Read block - Writing: 4096 - Total: 2437120 - Buffer size: 115
                              15:26:14.772 FLH: Read block - Writing: 4096 - Total: 2441216 - Buffer size: 115
                              15:26:14.901 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "20", "time_elapsed": 278}}
                              15:26:15.246 FLH: Read block - Writing: 4096 - Total: 2445312 - Buffer size: 115
                              15:26:15.716 FLH: Read block - Writing: 4096 - Total: 2449408 - Buffer size: 115
                              15:26:16.182 FLH: Read block - Writing: 4096 - Total: 2453504 - Buffer size: 115
                              15:26:16.651 FLH: Read block - Writing: 4096 - Total: 2457600 - Buffer size: 115
                              15:26:17.114 FLH: Read block - Writing: 4096 - Total: 2461696 - Buffer size: 115
                              15:26:17.584 FLH: Read block - Writing: 4096 - Total: 2465792 - Buffer size: 115
                              15:26:18.055 FLH: Read block - Writing: 4096 - Total: 2469888 - Buffer size: 115
                              15:26:18.520 FLH: Read block - Writing: 4096 - Total: 2473984 - Buffer size: 115
                              15:26:18.984 FLH: Read block - Writing: 4096 - Total: 2478080 - Buffer size: 115
                              15:26:19.451 FLH: Read block - Writing: 4096 - Total: 2482176 - Buffer size: 115
                              15:28:18.883 FLH: Read block - Writing: 4096 - Total: 3559424 - Buffer size: 115
                              15:28:19.280 FLH: Read block - Writing: 4096 - Total: 3563520 - Buffer size: 115
                              15:28:19.748 FLH: Read block - Writing: 4096 - Total: 3567616 - Buffer size: 115
                              15:28:20.210 FLH: Read block - Writing: 4096 - Total: 3571712 - Buffer size: 115
                              15:28:20.678 FLH: Read block - Writing: 4096 - Total: 3575808 - Buffer size: 115
                              15:28:21.144 FLH: Read block - Writing: 4096 - Total: 3579904 - Buffer size: 115
                              15:28:21.613 FLH: Read block - Writing: 4096 - Total: 3584000 - Buffer size: 115
                              15:28:22.003 FLH: Read block - Writing: 4096 - Total: 3588096 - Buffer size: 115
                              15:28:22.470 FLH: Read block - Writing: 4096 - Total: 3592192 - Buffer size: 115
                              15:28:22.938 FLH: Read block - Writing: 4096 - Total: 3596288 - Buffer size: 115
                              15:28:23.406 FLH: Read block - Writing: 4096 - Total: 3600384 - Buffer size: 115
                              15:28:23.871 FLH: Read block - Writing: 4096 - Total: 3604480 - Buffer size: 115
                              15:28:24.336 FLH: Read block - Writing: 4096 - Total: 3608576 - Buffer size: 115
                              15:28:24.724 FLH: Read block - Writing: 4096 - Total: 3612672 - Buffer size: 115
                              15:28:25.186 FLH: Read block - Writing: 4096 - Total: 3616768 - Buffer size: 115
                              15:28:25.652 FLH: Read block - Writing: 4096 - Total: 3620864 - Buffer size: 115
                              15:28:26.119 FLH: Read block - Writing: 4096 - Total: 3624960 - Buffer size: 115
                              15:28:26.590 FLH: Read block - Writing: 4096 - Total: 3629056 - Buffer size: 115
                              15:28:27.054 FLH: Read block - Writing: 4096 - Total: 3633152 - Buffer size: 115
                              15:28:27.443 FLH: Read block - Writing: 4096 - Total: 3637248 - Buffer size: 115
                              15:28:27.914 FLH: Read block - Writing: 4096 - Total: 3641344 - Buffer size: 115
                              15:28:28.378 FLH: Read block - Writing: 4096 - Total: 3645440 - Buffer size: 115
                              15:28:29.596 FLH: Read block - Writing: 4096 - Total: 3649536 - Buffer size: 523
                              15:28:30.064 FLH: Read block - Writing: 4096 - Total: 3653632 - Buffer size: 523
                              15:28:30.532 FLH: Read block - Writing: 4096 - Total: 3657728 - Buffer size: 523
                              15:28:31.604 FLH: Read block - Writing: 4096 - Total: 3661824 - Buffer size: 1159
                              15:28:31.734 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "30", "time_elapsed": 414}}
                              15:28:32.080 FLH: Read block - Writing: 4096 - Total: 3665920 - Buffer size: 1159
                              15:28:32.550 FLH: Read block - Writing: 4096 - Total: 3670016 - Buffer size: 1159
                              15:28:33.013 FLH: Read block - Writing: 4096 - Total: 3674112 - Buffer size: 1159
                              15:28:33.480 FLH: Read block - Writing: 4096 - Total: 3678208 - Buffer size: 1159
                              15:28:33.951 FLH: Read block - Writing: 4096 - Total: 3682304 - Buffer size: 1159
                              15:28:34.419 FLH: Read block - Writing: 4096 - Total: 3686400 - Buffer size: 1159
                              15:28:34.884 FLH: Read block - Writing: 4096 - Total: 3690496 - Buffer size: 1159
                              15:28:35.275 FLH: Read block - Writing: 4096 - Total: 3694592 - Buffer size: 1159
                              15:28:35.742 FLH: Read block - Writing: 4096 - Total: 3698688 - Buffer size: 1159
                              15:28:36.206 FLH: Read block - Writing: 4096 - Total: 3702784 - Buffer size: 1159
                              15:28:36.674 FLH: Read block - Writing: 4096 - Total: 3706880 - Buffer size: 1159
                              15:28:37.139 FLH: Read block - Writing: 4096 - Total: 3710976 - Buffer size: 1159
                              15:28:37.613 FLH: Read block - Writing: 4096 - Total: 3715072 - Buffer size: 1159
                              15:28:38.059 FLH: Read block - Writing: 4096 - Total: 3719168 - Buffer size: 3931
                              15:28:38.528 FLH: Read block - Writing: 4096 - Total: 3723264 - Buffer size: 3931
                              15:28:38.998 FLH: Read block - Writing: 4096 - Total: 3727360 - Buffer size: 3931
                              15:28:39.469 FLH: Read block - Writing: 4096 - Total: 3731456 - Buffer size: 3931
                              15:28:39.936 FLH: Read block - Writing: 4096 - Total: 3735552 - Buffer size: 3931
                              15:28:40.404 FLH: Read block - Writing: 4096 - Total: 3739648 - Buffer size: 3931
                              15:28:40.871 FLH: Read block - Writing: 4096 - Total: 3743744 - Buffer size: 3931
                              15:28:41.343 FLH: Read block - Writing: 4096 - Total: 3747840 - Buffer size: 3931
                              15:28:41.809 FLH: Read block - Writing: 4096 - Total: 3751936 - Buffer size: 3931
                              15:28:42.275 FLH: Read block - Writing: 4096 - Total: 3756032 - Buffer size: 3931
                              15:28:42.745 FLH: Read block - Writing: 4096 - Total: 3760128 - Buffer size: 3931
                              15:29:08.206 FLH: Read block - Writing: 4096 - Total: 3989504 - Buffer size: 3931
                              15:29:08.680 FLH: Read block - Writing: 4096 - Total: 3993600 - Buffer size: 3931
                              15:29:09.144 FLH: Read block - Writing: 4096 - Total: 3997696 - Buffer size: 3931
                              15:29:09.612 FLH: Read block - Writing: 4096 - Total: 4001792 - Buffer size: 3931
                              15:29:10.080 FLH: Read block - Writing: 4096 - Total: 4005888 - Buffer size: 3931
                              15:29:10.477 FLH: Read block - Writing: 4096 - Total: 4009984 - Buffer size: 3931
                              15:29:10.944 FLH: Read block - Writing: 4096 - Total: 4014080 - Buffer size: 3931
                              15:29:11.413 FLH: Read block - Writing: 4096 - Total: 4018176 - Buffer size: 3931
                              15:29:11.880 FLH: Read block - Writing: 4096 - Total: 4022272 - Buffer size: 3931
                              15:29:12.353 FLH: Read block - Writing: 4096 - Total: 4026368 - Buffer size: 3931
                              15:29:12.479 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "33", "time_elapsed": 455}}
                              15:29:12.825 FLH: Read block - Writing: 4096 - Total: 4030464 - Buffer size: 3931
                              15:29:13.220 FLH: Read block - Writing: 4096 - Total: 4034560 - Buffer size: 3931
                              15:29:13.694 FLH: Read block - Writing: 4096 - Total: 4038656 - Buffer size: 3931
                              15:29:14.160 FLH: Read block - Writing: 4096 - Total: 4042752 - Buffer size: 3931
                              15:29:14.629 FLH: Read block - Writing: 4096 - Total: 4046848 - Buffer size: 3931
                              15:29:15.095 FLH: Read block - Writing: 4096 - Total: 4050944 - Buffer size: 3931
                              15:29:15.565 FLH: Read block - Writing: 4096 - Total: 4055040 - Buffer size: 3931
                              15:29:15.960 FLH: Read block - Writing: 4096 - Total: 4059136 - Buffer size: 3931
                              15:29:16.428 FLH: Read block - Writing: 4096 - Total: 4063232 - Buffer size: 3931
                              15:29:16.896 FLH: Read block - Writing: 4096 - Total: 4067328 - Buffer size: 3931
                              15:29:17.368 FLH: Read block - Writing: 4096 - Total: 4071424 - Buffer size: 3931
                              15:29:17.834 FLH: Read block - Writing: 4096 - Total: 4075520 - Buffer size: 3931
                              15:29:18.297 FLH: Read block - Writing: 4096 - Total: 4079616 - Buffer size: 3931
                              15:29:18.697 FLH: Read block - Writing: 4096 - Total: 4083712 - Buffer size: 3931
                              15:29:19.163 FLH: Read block - Writing: 4096 - Total: 4087808 - Buffer size: 3931
                              15:29:19.630 FLH: Read block - Writing: 4096 - Total: 4091904 - Buffer size: 3931
                              15:29:20.097 FLH: Read block - Writing: 4096 - Total: 4096000 - Buffer size: 3931
                              15:29:20.564 FLH: Read block - Writing: 4096 - Total: 4100096 - Buffer size: 3931
                              15:29:21.032 FLH: Read block - Writing: 4096 - Total: 4104192 - Buffer size: 3931
                              15:29:21.431 FLH: Read block - Writing: 4096 - Total: 4108288 - Buffer size: 3931
                              15:29:21.896 FLH: Read block - Writing: 4096 - Total: 4112384 - Buffer size: 3931
                              15:29:22.367 FLH: Read block - Writing: 4096 - Total: 4116480 - Buffer size: 3931
                              15:29:22.835 FLH: Read block - Writing: 4096 - Total: 4120576 - Buffer size: 3931
                              15:29:23.298 FLH: Read block - Writing: 4096 - Total: 4124672 - Buffer size: 3931
                              15:29:23.764 FLH: Read block - Writing: 4096 - Total: 4128768 - Buffer size: 3931
                              15:29:24.159 FLH: Read block - Writing: 4096 - Total: 4132864 - Buffer size: 3931
                              15:29:24.828 FLH: Read block - Writing: 4096 - Total: 4136960 - Buffer size: 3931
                              15:29:25.294 FLH: Read block - Writing: 4096 - Total: 4141056 - Buffer size: 3931
                              15:29:25.763 FLH: Read block - Writing: 4096 - Total: 4145152 - Buffer size: 3931
                              15:29:26.231 FLH: Read block - Writing: 4096 - Total: 4149248 - Buffer size: 3931
                              15:29:26.282 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "34", "time_elapsed": 469}}
                              15:29:26.628 FLH: Read block - Writing: 4096 - Total: 4153344 - Buffer size: 3931
                              15:29:27.099 FLH: Read block - Writing: 4096 - Total: 4157440 - Buffer size: 3931
                              15:29:27.567 FLH: Read block - Writing: 4096 - Total: 4161536 - Buffer size: 3931
                              15:29:28.033 FLH: Read block - Writing: 4096 - Total: 4165632 - Buffer size: 3931
                              15:29:28.504 FLH: Read block - Writing: 4096 - Total: 4169728 - Buffer size: 3931
                              15:29:28.968 FLH: Read block - Writing: 4096 - Total: 4173824 - Buffer size: 1843
                              15:29:29.368 FLH: Read block - Writing: 4096 - Total: 4177920 - Buffer size: 587
                              15:29:29.833 FLH: Read block - Writing: 4096 - Total: 4182016 - Buffer size: 587
                              15:29:30.298 FLH: Read block - Writing: 4096 - Total: 4186112 - Buffer size: 587
                              15:29:30.770 FLH: Read block - Writing: 4096 - Total: 4190208 - Buffer size: 587
                              15:29:31.232 FLH: Read block - Writing: 4096 - Total: 4194304 - Buffer size: 587
                              15:29:31.701 FLH: Read block - Writing: 4096 - Total: 4198400 - Buffer size: 587
                              15:29:32.288 FLH: Read block - Writing: 4096 - Total: 4202496 - Buffer size: 587
                              15:29:32.753 FLH: Read block - Writing: 4096 - Total: 4206592 - Buffer size: 587
                              15:29:33.219 FLH: Read block - Writing: 4096 - Total: 4210688 - Buffer size: 587
                              15:29:33.686 FLH: Read block - Writing: 4096 - Total: 4214784 - Buffer size: 587
                              15:29:34.158 FLH: Read block - Writing: 4096 - Total: 4218880 - Buffer size: 587
                              15:29:34.624 FLH: Read block - Writing: 4096 - Total: 4222976 - Buffer size: 587
                              15:29:35.010 FLH: Read block - Writing: 4096 - Total: 4227072 - Buffer size: 587
                              15:29:35.482 FLH: Read block - Writing: 4096 - Total: 4231168 - Buffer size: 587
                              15:29:35.946 FLH: Read block - Writing: 4096 - Total: 4235264 - Buffer size: 587
                              15:29:36.411 FLH: Read block - Writing: 4096 - Total: 4239360 - Buffer size: 587
                              15:29:36.878 FLH: Read block - Writing: 4096 - Total: 4243456 - Buffer size: 587
                              15:30:15.760 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 587
                              15:30:16.229 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 587
                              15:30:16.692 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 587
                              15:30:17.358 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 587
                              15:30:17.823 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 587
                              15:30:18.293 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 587
                              15:30:18.681 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 587
                              15:30:19.146 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 587
                              15:30:19.618 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 587
                              15:30:20.083 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 587
                              15:30:20.549 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 587
                              15:30:21.013 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 587
                              15:30:21.400 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 587
                              15:30:21.868 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 587
                              15:30:21.994 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 525}}
                              15:30:22.340 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 587
                              15:30:22.804 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 587
                              15:30:23.277 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 587
                              15:30:23.741 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 587
                              15:30:24.137 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 587
                              15:30:24.905 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 587
                              15:30:25.368 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 587
                              15:30:25.837 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 587
                              15:30:26.300 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 587
                              15:30:26.774 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 587
                              15:30:27.237 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 587
                              15:30:27.704 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 587
                              15:30:28.172 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 587
                              15:30:28.638 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 587
                              15:30:29.110 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 587
                              15:30:29.498 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 587
                              15:30:29.966 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 587
                              15:30:30.943 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 2299
                              15:30:31.410 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 2299
                              15:30:31.875 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 2299
                              15:30:32.268 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 2299
                              15:30:33.040 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 2299
                              15:30:33.505 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 2299
                              15:30:33.971 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 2299
                              15:30:34.440 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 2299
                              15:30:34.828 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 2299
                              15:30:35.293 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 2299
                              15:30:35.758 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 2299
                              15:30:36.223 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 2299
                              15:30:36.698 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 2299
                              15:30:36.822 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 539}}
                              15:30:37.167 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 2299
                              15:30:37.566 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 2299
                              15:30:38.036 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 2299
                              15:30:38.505 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 2299
                              15:30:38.970 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 2299
                              15:30:39.439 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 2299
                              15:30:39.904 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 2299
                              • Armilar
                                Armilar Most Active Forum Testing last edited by
                                @australien
                                und mit Adv0?
                                  australien @Armilar last edited by
                                  @armilar
                                  das gleiche, hab übrigens gesehen die Fehlermeldung ist doch da.
                                  00:00:00.001 HDW: ESP32-D0WD-V3 v3.0
                                  00:00:00.017 UFS: FlashFS mounted with 288 kB free
                                  00:00:00.026 CFG: Loaded from File, Anzahl 1518
                                  00:00:00.035 QPC: Count 1
                                  00:00:00.035 CFG: CR 430/699, Busy 0
                                  00:00:00.041 TYA: Active=0
                                  00:00:00.045 ROT: Mode 1
                                  00:00:00.069 CFG: No '*.autoconf' file found
                                  00:00:00.073 BRY: Berry initialized, RAM used 3493 bytes
                                  00:00:00.079 BRY: No 'preinit.be'
                                  00:00:00.081 SRC: Restart
                                  00:00:00.085 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
                                  00:00:00.218 NXP: Initializing Driver
                                  00:00:00.220 BRY: Serial UART2
                                  00:00:00.223 BRY: Successfully loaded 'autoexec.be'
                                  00:00:00.310 WIF: Verbindungsversuch…
                                  00:00:00.948 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
                                  00:00:01.077 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
                                  00:00:03.476 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
                                  00:00:03.498 WIF: verbunden
                                  00:00:03.755 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
                                  00:00:04.004 RTC: UTC 2025-09-12T14:50:15Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
                                  15:50:15.000 RTC: Synced by NTP
                                  15:50:15.745 MQT: Verbindungsversuch…
                                  15:50:15.761 MQT: verbunden
                                  15:50:15.764 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
                                  15:50:15.765 MQT: SmartHome/NSPanel_1/cmnd/POWER =
                                  15:50:15.766 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
                                  15:50:15.767 MQT: abonniere SmartHome/tasmotas/cmnd/#
                                  15:50:15.768 MQT: abonniere cmnd/NSPanel_1_fb/#
                                  15:50:15.770 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                                  15:50:15.784 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
                                  15:50:15.809 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":172}}
                                  15:50:15.813 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                  15:50:15.824 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                  15:50:15.826 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                                  15:50:15.827 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                                  15:50:16.050 SRC: MQTT
                                  15:50:16.050 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                                  15:50:16.061 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                                  15:50:16.065 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                  15:50:16.097 SRC: MQTT
                                  15:50:16.098 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                                  15:50:16.100 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                  15:50:16.101 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                  15:50:16.148 SRC: MQTT
                                  15:50:16.149 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                                  15:50:16.159 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                                  15:50:16.163 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                  15:50:16.198 SRC: MQTT
                                  15:50:16.198 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                                  15:50:16.202 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                  15:50:16.205 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                  15:50:16.248 SRC: MQTT
                                  15:50:16.249 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                                  15:50:16.259 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                                  15:50:16.263 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                  15:50:16.298 SRC: MQTT
                                  15:50:16.298 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                                  15:50:16.302 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                  15:50:16.305 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                  15:50:17.799 SRC: MQTT
                                  15:50:17.800 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                                  15:50:17.813 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                                  15:50:17.817 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                  15:50:17.849 SRC: MQTT
                                  15:50:17.850 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                                  15:50:17.852 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                  15:50:17.853 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                  15:50:17.956 QPC: Reset
                                  15:50:19.949 APP: Startvorgänge 172
                                  15:50:19.956 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:50:19","Uptime":"0T00:00:09","UptimeSec":9,"Heap":146,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":237,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:04"}}
                                  15:50:20.001 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:50:19","ANALOG":{"Temperature1":28.5},"ESP32":{"Temperature":58.9},"TempUnit":"C"}
                                  15:50:20.424 CFG: Saved, Anzahl 1519, Bytes 4096
                                  15:50:20.441 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
                                  15:50:20.442 SRC: WebConsole from 10.68.0.156
                                  15:50:20.442 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 0, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
                                  15:50:20.449 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                                  15:50:20.482 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
                                  15:50:20.539 FLH: Connected:true
                                  15:50:20.641 FLH: Retry 2
                                  15:50:20.854 FLH: HTTP Respose is 200 OK or 206 Partial Content
                                  15:50:20.855 FLH: Flash file size: 12197684
                                  15:50:20.856 SRC: Berry
                                  15:50:20.857 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                                  15:50:20.863 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                                  15:50:20.868 SRC: Berry
                                  15:50:20.869 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                                  15:50:20.873 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                                  15:50:20.888 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                                  15:50:20.892 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                                  15:50:20.894 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                                  15:50:20.900 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                                  15:50:22.280 FLH: Send (High Speed) flash start
                                  15:50:22.286 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
                                  15:50:22.309 BRY: Serial UART2
                                  15:50:22.666 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                                  15:50:22.759 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                                  15:50:22.859 FLH: Waiting offset...
                                  15:50:27.659 FLH: Flash offset marker 0
                                  15:50:27.760 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                                  15:50:27.958 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                                  15:50:28.090 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                                  15:50:28.200 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
                                  15:50:28.314 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
                                  15:50:28.426 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
                                  15:50:28.533 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
                                  15:50:28.642 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
                                  15:50:28.751 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
                                  15:50:28.859 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
                                  15:50:28.971 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
                                  15:50:29.080 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
                                  15:50:29.189 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
                                  15:50:29.301 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
                                  15:50:29.409 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
                                  15:50:29.522 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
                                  15:50:29.858 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
                                  15:50:29.968 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
                                  15:50:30.158 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
                                  15:50:30.273 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
                                  15:50:30.456 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
                                  15:51:30.657 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
                                  15:51:30.858 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
                                  15:51:31.058 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
                                  15:51:31.168 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
                                  15:51:31.280 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
                                  15:51:31.458 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
                                  15:51:31.656 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
                                  15:51:31.858 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
                                  15:51:32.058 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
                                  15:51:32.263 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
                                  15:51:32.458 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
                                  15:51:32.657 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
                                  15:51:32.858 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
                                  15:51:32.970 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
                                  15:51:33.158 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
                                  15:51:33.275 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
                                  15:51:33.457 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
                                  15:51:33.658 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
                                  15:51:33.856 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
                                  15:51:33.969 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
                                  15:51:34.157 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
                                  15:51:34.271 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
                                  15:51:34.457 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
                                  15:51:34.657 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
                                  15:51:34.857 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
                                  15:51:35.058 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
                                  15:51:35.264 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
                                  15:51:35.456 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
                                  15:51:35.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 73}}
                                  15:51:35.664 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
                                  15:51:35.858 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
                                  15:51:35.968 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
                                  15:51:36.158 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
                                  15:51:36.273 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
                                  15:51:36.456 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
                                  15:51:36.658 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
                                  15:51:36.858 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
                                  15:51:36.968 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
                                  15:51:37.158 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
                                  15:51:37.273 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
                                  15:51:37.457 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
                                  15:51:37.657 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
                                  15:51:37.858 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
                                  15:51:37.969 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
                                  15:51:38.157 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
                                  15:51:38.273 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
                                  15:51:38.456 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
                                  15:51:38.657 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
                                  15:51:38.857 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
                                  15:51:38.967 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 311
                                  15:51:39.157 FLH: Read block - Writing: 4096 - Total: 1679360 - Buffer size: 311
                                  15:51:39.325 FLH: Read block - Writing: 4096 - Total: 1683456 - Buffer size: 1959
                                  15:51:39.439 FLH: Read block - Writing: 4096 - Total: 1687552 - Buffer size: 1959
                                  15:51:39.558 FLH: Read block - Writing: 4096 - Total: 1691648 - Buffer size: 1959
                                  15:51:39.758 FLH: Read block - Writing: 4096 - Total: 1695744 - Buffer size: 1959
                                  15:51:39.958 FLH: Read block - Writing: 4096 - Total: 1699840 - Buffer size: 1959
                                  15:51:40.158 FLH: Read block - Writing: 4096 - Total: 1703936 - Buffer size: 1959
                                  15:51:40.272 FLH: Read block - Writing: 4096 - Total: 1708032 - Buffer size: 1959
                                  15:51:40.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "14", "time_elapsed": 78}}
                                  15:51:40.565 FLH: Read block - Writing: 4096 - Total: 1712128 - Buffer size: 1959
                                  15:51:40.758 FLH: Read block - Writing: 4096 - Total: 1716224 - Buffer size: 1959
                                  15:51:40.958 FLH: Read block - Writing: 4096 - Total: 1720320 - Buffer size: 1959
                                  15:51:41.158 FLH: Read block - Writing: 4096 - Total: 1724416 - Buffer size: 1959
                                  15:51:41.273 FLH: Read block - Writing: 4096 - Total: 1728512 - Buffer size: 1959
                                  15:51:41.458 FLH: Read block - Writing: 4096 - Total: 1732608 - Buffer size: 1959
                                  15:51:41.657 FLH: Read block - Writing: 4096 - Total: 1736704 - Buffer size: 1959
                                  15:51:41.859 FLH: Read block - Writing: 4096 - Total: 1740800 - Buffer size: 1959
                                  15:51:41.971 FLH: Read block - Writing: 4096 - Total: 1744896 - Buffer size: 1959
                                  15:51:42.158 FLH: Read block - Writing: 4096 - Total: 1748992 - Buffer size: 1959
                                  15:51:42.275 FLH: Read block - Writing: 4096 - Total: 1753088 - Buffer size: 1959
                                  15:51:42.458 FLH: Read block - Writing: 4096 - Total: 1757184 - Buffer size: 1959
                                  15:51:42.660 FLH: Read block - Writing: 4096 - Total: 1761280 - Buffer size: 1959
                                  15:51:42.911 FLH: Read block - Writing: 4096 - Total: 1765376 - Buffer size: 1959
                                  15:51:43.023 FLH: Read block - Writing: 4096 - Total: 1769472 - Buffer size: 1959
                                  15:51:43.157 FLH: Read block - Writing: 4096 - Total: 1773568 - Buffer size: 1959
                                  15:51:43.458 FLH: Read block - Writing: 4096 - Total: 1777664 - Buffer size: 1959
                                  15:51:43.657 FLH: Read block - Writing: 4096 - Total: 1781760 - Buffer size: 1959
                                  15:51:43.857 FLH: Read block - Writing: 4096 - Total: 1785856 - Buffer size: 1959
                                  15:51:43.969 FLH: Read block - Writing: 4096 - Total: 1789952 - Buffer size: 1959
                                  15:51:44.157 FLH: Read block - Writing: 4096 - Total: 1794048 - Buffer size: 1959
                                  15:51:44.272 FLH: Read block - Writing: 4096 - Total: 1798144 - Buffer size: 1959
                                  15:51:44.457 FLH: Read block - Writing: 4096 - Total: 1802240 - Buffer size: 1959
                                  15:51:44.658 FLH: Read block - Writing: 4096 - Total: 1806336 - Buffer size: 1959
                                  15:51:44.858 FLH: Read block - Writing: 4096 - Total: 1810432 - Buffer size: 1959
                                  15:51:45.058 FLH: Read block - Writing: 4096 - Total: 1814528 - Buffer size: 1959
                                  15:51:45.263 FLH: Read block - Writing: 4096 - Total: 1818624 - Buffer size: 1959
                                  15:51:45.410 FLH: Read block - Writing: 4096 - Total: 1822720 - Buffer size: 1959
                                  15:51:45.559 FLH: Read block - Writing: 4096 - Total: 1826816 - Buffer size: 1959
                                  15:51:45.758 FLH: Read block - Writing: 4096 - Total: 1830912 - Buffer size: 1959
                                  15:51:45.872 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "15", "time_elapsed": 83}}
                                  15:51:45.965 FLH: Read block - Writing: 4096 - Total: 1835008 - Buffer size: 1959
                                  15:51:46.158 FLH: Read block - Writing: 4096 - Total: 1839104 - Buffer size: 1959
                                  15:51:46.360 FLH: Read block - Writing: 4096 - Total: 1843200 - Buffer size: 1959
                                  15:51:46.558 FLH: Read block - Writing: 4096 - Total: 1847296 - Buffer size: 1959
                                  15:51:46.758 FLH: Read block - Writing: 4096 - Total: 1851392 - Buffer size: 1959
                                  15:51:46.958 FLH: Read block - Writing: 4096 - Total: 1855488 - Buffer size: 1959
                                  15:51:47.158 FLH: Read block - Writing: 4096 - Total: 1859584 - Buffer size: 1959
                                  15:51:47.273 FLH: Read block - Writing: 4096 - Total: 1863680 - Buffer size: 1959
                                  15:51:47.458 FLH: Read block - Writing: 4096 - Total: 1867776 - Buffer size: 1959
                                  15:51:47.658 FLH: Read block - Writing: 4096 - Total: 1871872 - Buffer size: 1959
                                  15:51:47.857 FLH: Read block - Writing: 4096 - Total: 1875968 - Buffer size: 1959
                                  15:51:48.058 FLH: Read block - Writing: 4096 - Total: 1880064 - Buffer size: 1959
                                  15:51:48.264 FLH: Read block - Writing: 4096 - Total: 1884160 - Buffer size: 1959
                                  15:51:48.458 FLH: Read block - Writing: 4096 - Total: 1888256 - Buffer size: 1959
                                  15:51:48.658 FLH: Read block - Writing: 4096 - Total: 1892352 - Buffer size: 1959
                                  15:51:48.858 FLH: Read block - Writing: 4096 - Total: 1896448 - Buffer size: 1959
                                  15:51:49.057 FLH: Read block - Writing: 4096 - Total: 1900544 - Buffer size: 1959
                                  15:51:49.263 FLH: Read block - Writing: 4096 - Total: 1904640 - Buffer size: 1959
                                  15:51:49.458 FLH: Read block - Writing: 4096 - Total: 1908736 - Buffer size: 1959
                                  15:51:49.658 FLH: Read block - Writing: 4096 - Total: 1912832 - Buffer size: 1959
                                  15:51:49.858 FLH: Read block - Writing: 4096 - Total: 1916928 - Buffer size: 1959
                                  15:51:50.058 FLH: Read block - Writing: 4096 - Total: 1921024 - Buffer size: 1959
                                  15:51:50.264 FLH: Read block - Writing: 4096 - Total: 1925120 - Buffer size: 1959
                                  15:51:50.411 FLH: Read block - Writing: 4096 - Total: 1929216 - Buffer size: 1959
                                  15:51:50.558 FLH: Read block - Writing: 4096 - Total: 1933312 - Buffer size: 1959
                                  15:51:50.757 FLH: Read block - Writing: 4096 - Total: 1937408 - Buffer size: 1959
                                  15:51:50.956 FLH: Read block - Writing: 4096 - Total: 1941504 - Buffer size: 1959
                                  15:51:51.157 FLH: Read block - Writing: 4096 - Total: 1945600 - Buffer size: 1959
                                  15:51:51.273 FLH: Read block - Writing: 4096 - Total: 1949696 - Buffer size: 1959
                                  15:51:51.457 FLH: Read block - Writing: 4096 - Total: 1953792 - Buffer size: 1959
                                  15:51:51.570 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "16", "time_elapsed": 89}}
                                  15:51:51.662 FLH: Read block - Writing: 4096 - Total: 1957888 - Buffer size: 1959
                                  15:51:51.857 FLH: Read block - Writing: 4096 - Total: 1961984 - Buffer size: 1959
                                  15:51:51.970 FLH: Read block - Writing: 4096 - Total: 1966080 - Buffer size: 1959
                                  15:51:52.157 FLH: Read block - Writing: 4096 - Total: 1970176 - Buffer size: 1959
                                  15:51:52.359 FLH: Read block - Writing: 4096 - Total: 1974272 - Buffer size: 1959
                                  15:51:52.558 FLH: Read block - Writing: 4096 - Total: 1978368 - Buffer size: 1959
                                  15:51:52.757 FLH: Read block - Writing: 4096 - Total: 1982464 - Buffer size: 1959
                                  15:51:52.902 FLH: Read block - Writing: 4096 - Total: 1986560 - Buffer size: 1959
                                  15:51:53.016 FLH: Read block - Writing: 4096 - Total: 1990656 - Buffer size: 1959
                                  15:51:53.158 FLH: Read block - Writing: 4096 - Total: 1994752 - Buffer size: 1959
                                  15:51:53.272 FLH: Read block - Writing: 4096 - Total: 1998848 - Buffer size: 1959
                                  15:51:53.458 FLH: Read block - Writing: 4096 - Total: 2002944 - Buffer size: 1959
                                  15:51:53.658 FLH: Read block - Writing: 4096 - Total: 2007040 - Buffer size: 1959
                                  15:51:53.857 FLH: Read block - Writing: 4096 - Total: 2011136 - Buffer size: 1959
                                  15:51:53.969 FLH: Read block - Writing: 4096 - Total: 2015232 - Buffer size: 1959
                                  15:51:54.157 FLH: Read block - Writing: 4096 - Total: 2019328 - Buffer size: 1959
                                  15:51:54.272 FLH: Read block - Writing: 4096 - Total: 2023424 - Buffer size: 1959
                                  15:51:54.458 FLH: Read block - Writing: 4096 - Total: 2027520 - Buffer size: 1959
                                  15:51:54.658 FLH: Read block - Writing: 4096 - Total: 2031616 - Buffer size: 1959
                                  15:51:54.858 FLH: Read block - Writing: 4096 - Total: 2035712 - Buffer size: 1959
                                  15:51:55.058 FLH: Read block - Writing: 4096 - Total: 2039808 - Buffer size: 1959
                                  15:51:55.264 FLH: Read block - Writing: 4096 - Total: 2043904 - Buffer size: 1959
                                  15:51:55.458 FLH: Read block - Writing: 4096 - Total: 2048000 - Buffer size: 1959
                                  15:51:55.658 FLH: Read block - Writing: 4096 - Total: 2052096 - Buffer size: 1959
                                  15:51:55.858 FLH: Read block - Writing: 4096 - Total: 2056192 - Buffer size: 1959
                                  15:51:56.058 FLH: Read block - Writing: 4096 - Total: 2060288 - Buffer size: 1959
                                  15:51:56.264 FLH: Read block - Writing: 4096 - Total: 2064384 - Buffer size: 1959
                                  15:51:56.457 FLH: Read block - Writing: 4096 - Total: 2068480 - Buffer size: 1959
                                  15:51:56.658 FLH: Read block - Writing: 4096 - Total: 2072576 - Buffer size: 1959
                                  15:51:56.858 FLH: Read block - Writing: 4096 - Total: 2076672 - Buffer size: 1959
                                  15:51:56.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "17", "time_elapsed": 94}}
                                  15:51:57.064 FLH: Read block - Writing: 4096 - Total: 2080768 - Buffer size: 1959
                                  15:51:57.264 FLH: Read block - Writing: 4096 - Total: 2084864 - Buffer size: 1959
                                  15:51:57.458 FLH: Read block - Writing: 4096 - Total: 2088960 - Buffer size: 1959
                                  15:51:57.658 FLH: Read block - Writing: 4096 - Total: 2093056 - Buffer size: 1959
                                  15:51:57.857 FLH: Read block - Writing: 4096 - Total: 2097152 - Buffer size: 1959
                                  15:51:58.058 FLH: Read block - Writing: 4096 - Total: 2101248 - Buffer size: 1959
                                  15:51:58.263 FLH: Read block - Writing: 4096 - Total: 2105344 - Buffer size: 1959
                                  15:51:58.458 FLH: Read block - Writing: 4096 - Total: 2109440 - Buffer size: 1959
                                  15:51:58.657 FLH: Read block - Writing: 4096 - Total: 2113536 - Buffer size: 1959
                                  15:51:58.858 FLH: Read block - Writing: 4096 - Total: 2117632 - Buffer size: 1959
                                  15:51:58.970 FLH: Read block - Writing: 4096 - Total: 2121728 - Buffer size: 1959
                                  15:51:59.158 FLH: Read block - Writing: 4096 - Total: 2125824 - Buffer size: 1959
                                  15:51:59.276 FLH: Read block - Writing: 4096 - Total: 2129920 - Buffer size: 1959
                                  15:51:59.457 FLH: Read block - Writing: 4096 - Total: 2134016 - Buffer size: 1959
                                  15:51:59.658 FLH: Read block - Writing: 4096 - Total: 2138112 - Buffer size: 1959
                                  15:51:59.858 FLH: Read block - Writing: 4096 - Total: 2142208 - Buffer size: 1959
                                  15:52:00.058 FLH: Read block - Writing: 4096 - Total: 2146304 - Buffer size: 1959
                                  15:52:00.264 FLH: Read block - Writing: 4096 - Total: 2150400 - Buffer size: 1959
                                  15:52:00.457 FLH: Read block - Writing: 4096 - Total: 2154496 - Buffer size: 1959
                                  15:52:00.605 FLH: Read block - Writing: 4096 - Total: 2158592 - Buffer size: 1959
                                  15:52:00.757 FLH: Read block - Writing: 4096 - Total: 2162688 - Buffer size: 1959
                                  15:52:00.958 FLH: Read block - Writing: 4096 - Total: 2166784 - Buffer size: 1959
                                  15:52:01.156 FLH: Read block - Writing: 4096 - Total: 2170880 - Buffer size: 1959
                                  15:52:01.271 FLH: Read block - Writing: 4096 - Total: 2174976 - Buffer size: 1959
                                  15:52:01.455 FLH: Read block - Writing: 4096 - Total: 2179072 - Buffer size: 1959
                                  15:52:01.656 FLH: Read block - Writing: 4096 - Total: 2183168 - Buffer size: 1959
                                  15:52:01.856 FLH: Read block - Writing: 4096 - Total: 2187264 - Buffer size: 1959
                                  15:52:02.058 FLH: Read block - Writing: 4096 - Total: 2191360 - Buffer size: 1959
                                  15:52:02.264 FLH: Read block - Writing: 4096 - Total: 2195456 - Buffer size: 1959
                                  15:52:02.458 FLH: Read block - Writing: 4096 - Total: 2199552 - Buffer size: 1959
                                  15:52:02.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "18", "time_elapsed": 100}}
                                  15:52:02.664 FLH: Read block - Writing: 4096 - Total: 2203648 - Buffer size: 1959
                                  15:52:02.857 FLH: Read block - Writing: 4096 - Total: 2207744 - Buffer size: 1959
                                  15:52:03.058 FLH: Read block - Writing: 4096 - Total: 2211840 - Buffer size: 1959
                                  15:52:03.203 FLH: Read block - Writing: 4096 - Total: 2215936 - Buffer size: 1959
                                  15:52:03.320 FLH: Read block - Writing: 4096 - Total: 2220032 - Buffer size: 1959
                                  15:52:03.432 FLH: Read block - Writing: 4096 - Total: 2224128 - Buffer size: 1959
                                  15:52:03.560 FLH: Read block - Writing: 4096 - Total: 2228224 - Buffer size: 1959
                                  15:52:03.758 FLH: Read block - Writing: 4096 - Total: 2232320 - Buffer size: 1959
                                  15:52:03.957 FLH: Read block - Writing: 4096 - Total: 2236416 - Buffer size: 1959
                                  15:52:04.157 FLH: Read block - Writing: 4096 - Total: 2240512 - Buffer size: 1959
                                  15:52:04.274 FLH: Read block - Writing: 4096 - Total: 2244608 - Buffer size: 1959
                                  15:52:04.459 FLH: Read block - Writing: 4096 - Total: 2248704 - Buffer size: 1959
                                  15:52:04.658 FLH: Read block - Writing: 4096 - Total: 2252800 - Buffer size: 1959
                                  15:52:04.857 FLH: Read block - Writing: 4096 - Total: 2256896 - Buffer size: 1959
                                  15:52:05.058 FLH: Read block - Writing: 4096 - Total: 2260992 - Buffer size: 1959
                                  15:52:05.263 FLH: Read block - Writing: 4096 - Total: 2265088 - Buffer size: 1959
                                  15:52:05.457 FLH: Read block - Writing: 4096 - Total: 2269184 - Buffer size: 1959
                                  15:52:05.658 FLH: Read block - Writing: 4096 - Total: 2273280 - Buffer size: 1959
                                  15:52:05.807 FLH: Read block - Writing: 4096 - Total: 2277376 - Buffer size: 1959
                                  15:52:05.958 FLH: Read block - Writing: 4096 - Total: 2281472 - Buffer size: 1959
                                  15:52:06.158 FLH: Read block - Writing: 4096 - Total: 2285568 - Buffer size: 1959
                                  15:52:06.273 FLH: Read block - Writing: 4096 - Total: 2289664 - Buffer size: 1959
                                  15:52:06.457 FLH: Read block - Writing: 4096 - Total: 2293760 - Buffer size: 1959
                                  15:52:06.658 FLH: Read block - Writing: 4096 - Total: 2297856 - Buffer size: 1959
                                  15:52:06.858 FLH: Read block - Writing: 4096 - Total: 2301952 - Buffer size: 1959
                                  15:52:06.970 FLH: Read block - Writing: 4096 - Total: 2306048 - Buffer size: 1959
                                  15:52:07.157 FLH: Read block - Writing: 4096 - Total: 2310144 - Buffer size: 1959
                                  15:52:07.273 FLH: Read block - Writing: 4096 - Total: 2314240 - Buffer size: 1959
                                  15:52:07.456 FLH: Read block - Writing: 4096 - Total: 2318336 - Buffer size: 1959
                                  15:52:07.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "19", "time_elapsed": 105}}
                                  15:52:07.664 FLH: Read block - Writing: 4096 - Total: 2322432 - Buffer size: 1959
                                  15:52:07.858 FLH: Read block - Writing: 4096 - Total: 2326528 - Buffer size: 1959
                                  15:52:08.058 FLH: Read block - Writing: 4096 - Total: 2330624 - Buffer size: 1959
                                  15:52:08.264 FLH: Read block - Writing: 4096 - Total: 2334720 - Buffer size: 1959
                                  15:52:08.457 FLH: Read block - Writing: 4096 - Total: 2338816 - Buffer size: 1959
                                  15:52:08.658 FLH: Read block - Writing: 4096 - Total: 2342912 - Buffer size: 1959
                                  15:52:08.857 FLH: Read block - Writing: 4096 - Total: 2347008 - Buffer size: 1959
                                  15:52:09.058 FLH: Read block - Writing: 4096 - Total: 2351104 - Buffer size: 1959
                                  15:52:09.264 FLH: Read block - Writing: 4096 - Total: 2355200 - Buffer size: 1959
                                  15:52:09.457 FLH: Read block - Writing: 4096 - Total: 2359296 - Buffer size: 1959
                                  15:52:09.658 FLH: Read block - Writing: 4096 - Total: 2363392 - Buffer size: 1959
                                  15:52:09.857 FLH: Read block - Writing: 4096 - Total: 2367488 - Buffer size: 1959
                                  15:52:10.058 FLH: Read block - Writing: 4096 - Total: 2371584 - Buffer size: 1959
                                  15:52:10.263 FLH: Read block - Writing: 4096 - Total: 2375680 - Buffer size: 1959
                                  15:52:10.457 FLH: Read block - Writing: 4096 - Total: 2379776 - Buffer size: 1959
                                  15:52:10.658 FLH: Read block - Writing: 4096 - Total: 2383872 - Buffer size: 1959
                                  15:52:10.806 FLH: Read block - Writing: 4096 - Total: 2387968 - Buffer size: 1959
                                  15:52:10.958 FLH: Read block - Writing: 4096 - Total: 2392064 - Buffer size: 1959
                                  15:52:11.157 FLH: Read block - Writing: 4096 - Total: 2396160 - Buffer size: 1959
                                  15:52:11.272 FLH: Read block - Writing: 4096 - Total: 2400256 - Buffer size: 1959
                                  15:52:11.457 FLH: Read block - Writing: 4096 - Total: 2404352 - Buffer size: 1959
                                  15:52:11.658 FLH: Read block - Writing: 4096 - Total: 2408448 - Buffer size: 1959
                                  15:52:11.857 FLH: Read block - Writing: 4096 - Total: 2412544 - Buffer size: 1959
                                  15:52:12.058 FLH: Read block - Writing: 4096 - Total: 2416640 - Buffer size: 1959
                                  15:52:12.263 FLH: Read block - Writing: 4096 - Total: 2420736 - Buffer size: 1959
                                  15:52:12.458 FLH: Read block - Writing: 4096 - Total: 2424832 - Buffer size: 1959
                                  15:52:12.657 FLH: Read block - Writing: 4096 - Total: 2428928 - Buffer size: 1959
                                  15:52:12.858 FLH: Read block - Writing: 4096 - Total: 2433024 - Buffer size: 1959
                                  15:52:13.058 FLH: Read block - Writing: 4096 - Total: 2437120 - Buffer size: 1959
                                  15:52:13.264 FLH: Read block - Writing: 4096 - Total: 2441216 - Buffer size: 1959
                                  15:52:13.328 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "20", "time_elapsed": 111}}
                                  15:52:13.420 FLH: Read block - Writing: 4096 - Total: 2445312 - Buffer size: 1959
                                  15:52:13.558 FLH: Read block - Writing: 4096 - Total: 2449408 - Buffer size: 1959
                                  15:52:13.758 FLH: Read block - Writing: 4096 - Total: 2453504 - Buffer size: 1959
                                  15:52:13.957 FLH: Read block - Writing: 4096 - Total: 2457600 - Buffer size: 1959
                                  15:52:14.158 FLH: Read block - Writing: 4096 - Total: 2461696 - Buffer size: 1959
                                  15:52:14.273 FLH: Read block - Writing: 4096 - Total: 2465792 - Buffer size: 1959
                                  15:52:14.458 FLH: Read block - Writing: 4096 - Total: 2469888 - Buffer size: 1959
                                  15:52:14.657 FLH: Read block - Writing: 4096 - Total: 2473984 - Buffer size: 1959
                                  15:52:14.858 FLH: Read block - Writing: 4096 - Total: 2478080 - Buffer size: 1959
                                  15:52:15.058 FLH: Read block - Writing: 4096 - Total: 2482176 - Buffer size: 1959
                                  15:52:15.263 FLH: Read block - Writing: 4096 - Total: 2486272 - Buffer size: 1959
                                  15:52:15.457 FLH: Read block - Writing: 4096 - Total: 2490368 - Buffer size: 1959
                                  15:52:15.658 FLH: Read block - Writing: 4096 - Total: 2494464 - Buffer size: 1959
                                  15:52:15.858 FLH: Read block - Writing: 4096 - Total: 2498560 - Buffer size: 1959
                                  15:52:16.007 FLH: Read block - Writing: 4096 - Total: 2502656 - Buffer size: 1959
                                  15:52:16.157 FLH: Read block - Writing: 4096 - Total: 2506752 - Buffer size: 1959
                                  15:52:16.273 FLH: Read block - Writing: 4096 - Total: 2510848 - Buffer size: 1959
                                  15:52:16.457 FLH: Read block - Writing: 4096 - Total: 2514944 - Buffer size: 1959
                                  15:52:16.658 FLH: Read block - Writing: 4096 - Total: 2519040 - Buffer size: 1959
                                  15:52:16.857 FLH: Read block - Writing: 4096 - Total: 2523136 - Buffer size: 1959
                                  15:52:17.057 FLH: Read block - Writing: 4096 - Total: 2527232 - Buffer size: 1959
                                  15:52:17.266 FLH: Read block - Writing: 4096 - Total: 2531328 - Buffer size: 1959
                                  15:52:17.457 FLH: Read block - Writing: 4096 - Total: 2535424 - Buffer size: 1959
                                  15:52:17.659 FLH: Read block - Writing: 4096 - Total: 2539520 - Buffer size: 1959
                                  15:52:17.858 FLH: Read block - Writing: 4096 - Total: 2543616 - Buffer size: 1959
                                  15:52:18.057 FLH: Read block - Writing: 4096 - Total: 2547712 - Buffer size: 1959
                                  15:52:18.265 FLH: Read block - Writing: 4096 - Total: 2551808 - Buffer size: 1959
                                  15:52:18.377 FLH: Read block - Writing: 4096 - Total: 2555904 - Buffer size: 1959
                                  15:52:18.530 FLH: Read block - Writing: 4096 - Total: 2560000 - Buffer size: 1959
                                  15:52:18.758 FLH: Read block - Writing: 4096 - Total: 2564096 - Buffer size: 1959
                                  15:52:18.871 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "21", "time_elapsed": 116}}
                                  15:52:18.963 FLH: Read block - Writing: 4096 - Total: 2568192 - Buffer size: 1959
                                  15:52:19.158 FLH: Read block - Writing: 4096 - Total: 2572288 - Buffer size: 1959
                                  15:52:19.273 FLH: Read block - Writing: 4096 - Total: 2576384 - Buffer size: 1959
                                  15:52:19.458 FLH: Read block - Writing: 4096 - Total: 2580480 - Buffer size: 1959
                                  15:52:19.464 HTP: Werkzeuge
                                  15:52:19.639 FLH: Read block - Writing: 4096 - Total: 2584576 - Buffer size: 1959
                                  15:52:19.758 FLH: Read block - Writing: 4096 - Total: 2588672 - Buffer size: 1959
                                  15:52:19.958 FLH: Read block - Writing: 4096 - Total: 2592768 - Buffer size: 1959
                                  15:52:20.157 FLH: Read block - Writing: 4096 - Total: 2596864 - Buffer size: 1959
                                  15:52:20.272 FLH: Read block - Writing: 4096 - Total: 2600960 - Buffer size: 1959
                                  15:52:20.457 FLH: Read block - Writing: 4096 - Total: 2605056 - Buffer size: 1959
                                  15:52:20.657 FLH: Read block - Writing: 4096 - Total: 2609152 - Buffer size: 1959
                                  15:52:20.858 FLH: Read block - Writing: 4096 - Total: 2613248 - Buffer size: 1959
                                  15:52:20.970 FLH: Read block - Writing: 4096 - Total: 2617344 - Buffer size: 1959
                                  15:52:21.118 FLH: Read block - Writing: 4096 - Total: 2621440 - Buffer size: 1959
                                  15:52:21.127 HTP: Hauptmenü
                                  15:52:21.316 FLH: Read block - Writing: 4096 - Total: 2625536 - Buffer size: 1959
                                  15:52:21.558 FLH: Read block - Writing: 4096 - Total: 2629632 - Buffer size: 1959
                                  15:52:21.757 FLH: Read block - Writing: 4096 - Total: 2633728 - Buffer size: 1959
                                  15:52:21.957 FLH: Read block - Writing: 4096 - Total: 2637824 - Buffer size: 1959
                                  15:52:22.158 FLH: Read block - Writing: 4096 - Total: 2641920 - Buffer size: 1959
                                  15:52:22.274 FLH: Read block - Writing: 4096 - Total: 2646016 - Buffer size: 1959
                                  15:52:22.458 FLH: Read block - Writing: 4096 - Total: 2650112 - Buffer size: 1959
                                  15:52:22.657 FLH: Read block - Writing: 4096 - Total: 2654208 - Buffer size: 1959
                                  15:52:22.858 FLH: Read block - Writing: 4096 - Total: 2658304 - Buffer size: 1959
                                  15:52:23.058 FLH: Read block - Writing: 4096 - Total: 2662400 - Buffer size: 1959
                                  15:52:23.264 FLH: Read block - Writing: 4096 - Total: 2666496 - Buffer size: 1959
                                  15:52:23.458 FLH: Read block - Writing: 4096 - Total: 2670592 - Buffer size: 1959
                                  15:52:23.604 FLH: Read block - Writing: 4096 - Total: 2674688 - Buffer size: 1959
                                  15:52:23.757 FLH: Read block - Writing: 4096 - Total: 2678784 - Buffer size: 1959
                                  15:52:23.907 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1959
                                  15:52:24.057 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1959
                                  15:52:24.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 121}}
                                  15:52:24.271 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1959
                                  15:52:24.457 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1959
                                  15:52:24.659 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1959
                                  15:52:24.859 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1959
                                  15:52:25.056 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1959
                                  15:52:25.265 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1959
                                  15:52:25.458 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1959
                                  15:52:25.658 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1959
                                  15:52:25.859 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1959
                                  15:52:26.012 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1959
                                  15:52:26.157 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1959
                                  15:52:26.274 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1959
                                  15:52:26.425 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1959
                                  15:52:26.558 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1959
                                  15:52:26.758 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1959
                                  15:52:26.958 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1959
                                  15:52:27.158 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1959
                                  15:52:27.359 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1959
                                  15:52:27.558 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1959
                                  15:52:27.757 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1959
                                  15:52:27.958 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1959
                                  15:52:28.158 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1959
                                  15:52:28.275 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1959
                                  15:52:28.458 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1959
                                  15:52:28.604 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1959
                                  15:52:28.757 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1959
                                  15:52:28.906 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1959
                                  15:52:29.058 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1959
                                  15:52:29.264 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1959
                                  15:52:29.371 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 127}}
                                  15:52:29.464 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1959
                                  15:52:29.658 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1959
                                  15:52:29.858 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1959
                                  15:52:29.970 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1959
                                  15:52:30.264 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1959
                                  15:52:30.457 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1959
                                  15:52:30.658 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1959
                                  15:52:30.858 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1959
                                  15:52:31.057 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1959
                                  15:52:31.263 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1959
                                  15:52:31.458 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1959
                                  15:52:31.658 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1959
                                  15:52:31.858 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1959
                                  15:52:32.058 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1959
                                  15:52:32.264 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1959
                                  15:52:32.458 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1959
                                  15:52:32.657 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1959
                                  15:52:32.858 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1959
                                  15:52:33.057 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1959
                                  15:52:33.263 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1959
                                  15:52:33.457 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1959
                                  15:52:33.603 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1959
                                  15:52:33.757 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1959
                                  15:52:33.906 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1959
                                  15:52:34.058 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1959
                                  15:52:34.265 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1959
                                  15:52:34.458 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1959
                                  15:52:34.659 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1959
                                  15:52:34.859 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1959
                                  15:52:35.056 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1959
                                  15:52:35.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 132}}
                                  15:52:35.270 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1959
                                  15:52:35.457 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1959
                                  15:52:35.658 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1959
                                  15:52:35.857 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1959
                                  15:52:35.969 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1959
                                  15:52:36.167 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1959
                                  15:52:36.358 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1959
                                  15:52:36.558 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1959
                                  15:52:36.758 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1959
                                  15:52:36.958 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1959
                                  15:52:37.158 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1959
                                  15:52:37.272 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1959
                                  15:52:37.458 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1959
                                  15:52:37.657 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1959
                                  15:52:37.858 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1959
                                  15:52:38.058 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1959
                                  15:52:38.263 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1959
                                  15:52:38.458 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1959
                                  15:52:38.606 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1959
                                  15:52:38.758 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1959
                                  15:52:38.957 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1959
                                  15:52:39.160 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1959
                                  15:52:39.359 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1959
                                  15:52:39.559 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1959
                                  15:52:39.757 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1959
                                  15:52:39.957 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1959
                                  15:52:40.157 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1959
                                  15:52:40.272 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1959
                                  15:52:40.457 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1959
                                  15:52:40.658 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1959
                                  15:52:40.772 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 138}}
                                  15:52:40.865 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1959
                                  15:52:41.018 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1959
                                  15:52:41.170 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1959
                                  15:52:41.285 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1959
                                  15:52:41.458 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1959
                                  15:52:41.657 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1959
                                  15:52:41.858 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1959
                                  15:52:42.058 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1959
                                  15:52:42.264 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1959
                                  15:52:42.458 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1959
                                  15:52:42.657 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1959
                                  15:52:42.858 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1959
                                  15:52:42.970 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1959
                                  15:52:43.158 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1959
                                  15:52:43.274 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1959
                                  15:52:43.458 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1959
                                  15:52:43.603 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1959
                                  15:52:43.755 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1959
                                  15:52:43.958 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1959
                                  15:52:44.158 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1959
                                  15:52:44.273 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1959
                                  15:52:44.458 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1959
                                  15:52:44.658 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1959
                                  15:52:44.858 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1959
                                  15:52:45.057 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1959
                                  15:52:45.264 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1959
                                  15:52:45.458 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1959
                                  15:52:45.658 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1959
                                  15:52:45.858 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1959
                                  15:52:45.970 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1959
                                  15:52:46.072 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 143}}
                                  15:52:46.165 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1959
                                  15:52:46.323 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1959
                                  15:52:46.435 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1959
                                  15:52:46.559 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1959
                                  15:52:46.758 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1959
                                  15:52:46.958 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1959
                                  15:52:47.158 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1959
                                  15:52:47.273 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1959
                                  15:52:47.458 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1959
                                  15:52:47.658 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1959
                                  15:52:47.858 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1959
                                  15:52:47.970 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1959
                                  15:52:48.082 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1959
                                  15:52:48.263 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1959
                                  15:52:48.457 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1959
                                  15:52:48.658 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1959
                                  15:52:48.807 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1959
                                  15:52:48.957 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1959
                                  15:52:49.070 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1959
                                  15:52:49.264 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1959
                                  15:52:49.458 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1959
                                  15:52:49.657 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1959
                                  15:52:49.858 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1959
                                  15:52:50.058 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1959
                                  15:52:50.169 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1959
                                  15:52:50.282 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1959
                                  15:52:50.558 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1959
                                  15:52:50.757 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1959
                                  15:52:50.958 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1959
                                  15:52:51.158 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1959
                                  15:52:51.226 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 148}}
                                  15:52:51.318 FLH: Read block - Writing: 4096 - Total: 3301376 - Buffer size: 1959
                                  15:52:51.477 FLH: Read block - Writing: 4096 - Total: 3305472 - Buffer size: 1959
                                  15:52:51.659 FLH: Read block - Writing: 4096 - Total: 3309568 - Buffer size: 1959
                                  15:52:51.858 FLH: Read block - Writing: 4096 - Total: 3313664 - Buffer size: 1959
                                  15:52:51.970 FLH: Read block - Writing: 4096 - Total: 3317760 - Buffer size: 1959
                                  15:52:52.158 FLH: Read block - Writing: 4096 - Total: 3321856 - Buffer size: 1959
                                  15:52:52.275 FLH: Read block - Writing: 4096 - Total: 3325952 - Buffer size: 1959
                                  15:52:52.458 FLH: Read block - Writing: 4096 - Total: 3330048 - Buffer size: 1959
                                  15:52:52.658 FLH: Read block - Writing: 4096 - Total: 3334144 - Buffer size: 1959
                                  15:52:52.858 FLH: Read block - Writing: 4096 - Total: 3338240 - Buffer size: 1959
                                  15:52:53.058 FLH: Read block - Writing: 4096 - Total: 3342336 - Buffer size: 1959
                                  15:52:53.263 FLH: Read block - Writing: 4096 - Total: 3346432 - Buffer size: 1959
                                  15:52:53.458 FLH: Read block - Writing: 4096 - Total: 3350528 - Buffer size: 1959
                                  15:52:53.658 FLH: Read block - Writing: 4096 - Total: 3354624 - Buffer size: 1959
                                  15:52:53.874 FLH: Read block - Writing: 4096 - Total: 3358720 - Buffer size: 1959
                                  15:52:54.024 FLH: Read block - Writing: 4096 - Total: 3362816 - Buffer size: 1959
                                  15:52:54.158 FLH: Read block - Writing: 4096 - Total: 3366912 - Buffer size: 1959
                                  15:52:54.272 FLH: Read block - Writing: 4096 - Total: 3371008 - Buffer size: 1959
                                  15:52:54.457 FLH: Read block - Writing: 4096 - Total: 3375104 - Buffer size: 1959
                                  15:52:54.658 FLH: Read block - Writing: 4096 - Total: 3379200 - Buffer size: 1959
                                  15:52:54.858 FLH: Read block - Writing: 4096 - Total: 3383296 - Buffer size: 1959
                                  15:52:55.058 FLH: Read block - Writing: 4096 - Total: 3387392 - Buffer size: 1959
                                  15:52:55.264 FLH: Read block - Writing: 4096 - Total: 3391488 - Buffer size: 1959
                                  15:52:55.457 FLH: Read block - Writing: 4096 - Total: 3395584 - Buffer size: 1959
                                  15:52:55.658 FLH: Read block - Writing: 4096 - Total: 3399680 - Buffer size: 1959
                                  15:52:55.857 FLH: Read block - Writing: 4096 - Total: 3403776 - Buffer size: 1959
                                  15:52:55.970 FLH: Read block - Writing: 4096 - Total: 3407872 - Buffer size: 1959
                                  15:52:56.159 FLH: Read block - Writing: 4096 - Total: 3411968 - Buffer size: 1959
                                  15:52:56.359 FLH: Read block - Writing: 4096 - Total: 3416064 - Buffer size: 1959
                                  15:52:56.386 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "28", "time_elapsed": 154}}
                                  15:52:56.479 FLH: Read block - Writing: 4096 - Total: 3420160 - Buffer size: 1959
                                  15:52:56.626 FLH: Read block - Writing: 4096 - Total: 3424256 - Buffer size: 1959
                                  15:52:56.757 FLH: Read block - Writing: 4096 - Total: 3428352 - Buffer size: 1959
                                  15:52:56.958 FLH: Read block - Writing: 4096 - Total: 3432448 - Buffer size: 1959
                                  15:52:57.158 FLH: Read block - Writing: 4096 - Total: 3436544 - Buffer size: 1959
                                  15:52:57.274 FLH: Read block - Writing: 4096 - Total: 3440640 - Buffer size: 1959
                                  15:52:57.458 FLH: Read block - Writing: 4096 - Total: 3444736 - Buffer size: 1959
                                  15:52:57.658 FLH: Read block - Writing: 4096 - Total: 3448832 - Buffer size: 1959
                                  15:52:57.858 FLH: Read block - Writing: 4096 - Total: 3452928 - Buffer size: 1959
                                  15:52:58.056 FLH: Read block - Writing: 4096 - Total: 3457024 - Buffer size: 1959
                                  15:52:58.262 FLH: Read block - Writing: 4096 - Total: 3461120 - Buffer size: 1959
                                  15:52:58.457 FLH: Read block - Writing: 4096 - Total: 3465216 - Buffer size: 1959
                                  15:52:58.658 FLH: Read block - Writing: 4096 - Total: 3469312 - Buffer size: 1959
                                  15:52:58.810 FLH: Read block - Writing: 4096 - Total: 3473408 - Buffer size: 1959
                                  15:52:58.923 FLH: Read block - Writing: 4096 - Total: 3477504 - Buffer size: 1959
                                  15:52:59.265 FLH: Read block - Writing: 4096 - Total: 3481600 - Buffer size: 1959
                                  15:52:59.412 FLH: Read block - Writing: 4096 - Total: 3485696 - Buffer size: 1959
                                  15:52:59.559 FLH: Read block - Writing: 4096 - Total: 3489792 - Buffer size: 1959
                                  15:52:59.758 FLH: Read block - Writing: 4096 - Total: 3493888 - Buffer size: 1959
                                  15:52:59.958 FLH: Read block - Writing: 4096 - Total: 3497984 - Buffer size: 1959
                                  15:53:00.158 FLH: Read block - Writing: 4096 - Total: 3502080 - Buffer size: 1959
                                  15:53:00.275 FLH: Read block - Writing: 4096 - Total: 3506176 - Buffer size: 1959
                                  15:53:00.458 FLH: Read block - Writing: 4096 - Total: 3510272 - Buffer size: 1959
                                  15:53:00.658 FLH: Read block - Writing: 4096 - Total: 3514368 - Buffer size: 1959
                                  15:53:00.770 FLH: Read block - Writing: 4096 - Total: 3518464 - Buffer size: 1959
                                  15:53:00.958 FLH: Read block - Writing: 4096 - Total: 3522560 - Buffer size: 1959
                                  15:53:01.160 FLH: Read block - Writing: 4096 - Total: 3526656 - Buffer size: 1959
                                  15:53:01.320 FLH: Read block - Writing: 4096 - Total: 3530752 - Buffer size: 1959
                                  15:53:01.457 FLH: Read block - Writing: 4096 - Total: 3534848 - Buffer size: 1959
                                  15:53:01.657 FLH: Read block - Writing: 4096 - Total: 3538944 - Buffer size: 1959
                                  15:53:01.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "29", "time_elapsed": 159}}
                                  15:53:01.864 FLH: Read block - Writing: 4096 - Total: 3543040 - Buffer size: 1959
                                  15:53:02.057 FLH: Read block - Writing: 4096 - Total: 3547136 - Buffer size: 1959
                                  15:53:02.264 FLH: Read block - Writing: 4096 - Total: 3551232 - Buffer size: 1959
                                  15:53:02.458 FLH: Read block - Writing: 4096 - Total: 3555328 - Buffer size: 1959
                                  15:53:02.658 FLH: Read block - Writing: 4096 - Total: 3559424 - Buffer size: 1959
                                  15:53:02.858 FLH: Read block - Writing: 4096 - Total: 3563520 - Buffer size: 1959
                                  15:53:03.057 FLH: Read block - Writing: 4096 - Total: 3567616 - Buffer size: 1959
                                  15:53:03.264 FLH: Read block - Writing: 4096 - Total: 3571712 - Buffer size: 1959
                                  15:53:03.458 FLH: Read block - Writing: 4096 - Total: 3575808 - Buffer size: 1959
                                  15:53:03.660 FLH: Read block - Writing: 4096 - Total: 3579904 - Buffer size: 1959
                                  15:53:03.811 FLH: Read block - Writing: 4096 - Total: 3584000 - Buffer size: 1959
                                  15:53:03.924 FLH: Read block - Writing: 4096 - Total: 3588096 - Buffer size: 1959
                                  15:53:04.058 FLH: Read block - Writing: 4096 - Total: 3592192 - Buffer size: 1959
                                  15:53:04.263 FLH: Read block - Writing: 4096 - Total: 3596288 - Buffer size: 1959
                                  15:53:04.458 FLH: Read block - Writing: 4096 - Total: 3600384 - Buffer size: 1959
                                  15:53:04.658 FLH: Read block - Writing: 4096 - Total: 3604480 - Buffer size: 1959
                                  15:53:04.858 FLH: Read block - Writing: 4096 - Total: 3608576 - Buffer size: 1959
                                  15:53:05.058 FLH: Read block - Writing: 4096 - Total: 3612672 - Buffer size: 1959
                                  15:53:05.265 FLH: Read block - Writing: 4096 - Total: 3616768 - Buffer size: 1959
                                  15:53:05.457 FLH: Read block - Writing: 4096 - Total: 3620864 - Buffer size: 1959
                                  15:53:05.657 FLH: Read block - Writing: 4096 - Total: 3624960 - Buffer size: 1959
                                  15:53:05.857 FLH: Read block - Writing: 4096 - Total: 3629056 - Buffer size: 1959
                                  15:53:06.058 FLH: Read block - Writing: 4096 - Total: 3633152 - Buffer size: 1959
                                  15:53:06.211 FLH: Read block - Writing: 4096 - Total: 3637248 - Buffer size: 1959
                                  15:53:06.324 FLH: Read block - Writing: 4096 - Total: 3641344 - Buffer size: 1959
                                  15:53:06.436 FLH: Read block - Writing: 4096 - Total: 3645440 - Buffer size: 1959
                                  15:53:06.560 FLH: Read block - Writing: 4096 - Total: 3649536 - Buffer size: 1959
                                  15:53:06.760 FLH: Read block - Writing: 4096 - Total: 3653632 - Buffer size: 1959
                                  15:53:06.978 FLH: Read block - Writing: 4096 - Total: 3657728 - Buffer size: 1959
                                  15:53:07.160 FLH: Read block - Writing: 4096 - Total: 3661824 - Buffer size: 1959
                                  15:53:07.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "30", "time_elapsed": 164}}
                                  15:53:07.281 FLH: Read block - Writing: 4096 - Total: 3665920 - Buffer size: 1959
                                  15:53:07.460 FLH: Read block - Writing: 4096 - Total: 3670016 - Buffer size: 1959
                                  15:53:07.660 FLH: Read block - Writing: 4096 - Total: 3674112 - Buffer size: 1959
                                  15:53:07.859 FLH: Read block - Writing: 4096 - Total: 3678208 - Buffer size: 1959
                                  15:53:07.971 FLH: Read block - Writing: 4096 - Total: 3682304 - Buffer size: 1959
                                  15:53:08.160 FLH: Read block - Writing: 4096 - Total: 3686400 - Buffer size: 1959
                                  15:53:08.275 FLH: Read block - Writing: 4096 - Total: 3690496 - Buffer size: 1959
                                  15:53:08.460 FLH: Read block - Writing: 4096 - Total: 3694592 - Buffer size: 1959
                                  15:53:08.660 FLH: Read block - Writing: 4096 - Total: 3698688 - Buffer size: 1959
                                  15:53:08.860 FLH: Read block - Writing: 4096 - Total: 3702784 - Buffer size: 1959
                                  15:53:09.059 FLH: Read block - Writing: 4096 - Total: 3706880 - Buffer size: 1959
                                  15:53:09.265 FLH: Read block - Writing: 4096 - Total: 3710976 - Buffer size: 1959
                                  15:53:09.461 FLH: Read block - Writing: 4096 - Total: 3715072 - Buffer size: 1959
                                  15:53:09.609 FLH: Read block - Writing: 4096 - Total: 3719168 - Buffer size: 1959
                                  15:53:09.757 FLH: Read block - Writing: 4096 - Total: 3723264 - Buffer size: 1959
                                  15:53:09.958 FLH: Read block - Writing: 4096 - Total: 3727360 - Buffer size: 1959
                                  15:53:10.158 FLH: Read block - Writing: 4096 - Total: 3731456 - Buffer size: 1959
                                  15:53:10.275 FLH: Read block - Writing: 4096 - Total: 3735552 - Buffer size: 1959
                                  15:53:10.458 FLH: Read block - Writing: 4096 - Total: 3739648 - Buffer size: 1959
                                  15:53:10.658 FLH: Read block - Writing: 4096 - Total: 3743744 - Buffer size: 1959
                                  15:53:10.858 FLH: Read block - Writing: 4096 - Total: 3747840 - Buffer size: 1959
                                  15:53:11.057 FLH: Read block - Writing: 4096 - Total: 3751936 - Buffer size: 1959
                                  15:53:11.264 FLH: Read block - Writing: 4096 - Total: 3756032 - Buffer size: 1959
                                  15:53:11.458 FLH: Read block - Writing: 4096 - Total: 3760128 - Buffer size: 1959
                                  15:53:11.657 FLH: Read block - Writing: 4096 - Total: 3764224 - Buffer size: 1959
                                  15:53:11.858 FLH: Read block - Writing: 4096 - Total: 3768320 - Buffer size: 1959
                                  15:53:12.058 FLH: Read block - Writing: 4096 - Total: 3772416 - Buffer size: 1959
                                  15:53:12.199 FLH: Read block - Writing: 4096 - Total: 3776512 - Buffer size: 1959
                                  15:53:12.315 FLH: Read block - Writing: 4096 - Total: 3780608 - Buffer size: 1959
                                  15:53:12.430 FLH: Read block - Writing: 4096 - Total: 3784704 - Buffer size: 1959
                                  15:53:12.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "31", "time_elapsed": 170}}
                                  15:53:12.565 FLH: Read block - Writing: 4096 - Total: 3788800 - Buffer size: 1959
                                  15:53:12.758 FLH: Read block - Writing: 4096 - Total: 3792896 - Buffer size: 1959
                                  15:53:12.958 FLH: Read block - Writing: 4096 - Total: 3796992 - Buffer size: 1959
                                  15:53:13.158 FLH: Read block - Writing: 4096 - Total: 3801088 - Buffer size: 1959
                                  15:53:13.274 FLH: Read block - Writing: 4096 - Total: 3805184 - Buffer size: 1959
                                  15:53:13.559 FLH: Read block - Writing: 4096 - Total: 3809280 - Buffer size: 1959
                                  15:53:13.758 FLH: Read block - Writing: 4096 - Total: 3813376 - Buffer size: 1959
                                  15:53:13.958 FLH: Read block - Writing: 4096 - Total: 3817472 - Buffer size: 1959
                                  15:53:14.158 FLH: Read block - Writing: 4096 - Total: 3821568 - Buffer size: 1959
                                  15:53:14.274 FLH: Read block - Writing: 4096 - Total: 3825664 - Buffer size: 1959
                                  15:53:14.458 FLH: Read block - Writing: 4096 - Total: 3829760 - Buffer size: 1959
                                  15:53:14.609 FLH: Read block - Writing: 4096 - Total: 3833856 - Buffer size: 1959
                                  15:53:14.756 FLH: Read block - Writing: 4096 - Total: 3837952 - Buffer size: 1959
                                  15:53:14.957 FLH: Read block - Writing: 4096 - Total: 3842048 - Buffer size: 1959
                                  15:53:15.158 FLH: Read block - Writing: 4096 - Total: 3846144 - Buffer size: 1959
                                  15:53:15.273 FLH: Read block - Writing: 4096 - Total: 3850240 - Buffer size: 1959
                                  15:53:15.457 FLH: Read block - Writing: 4096 - Total: 3854336 - Buffer size: 1959
                                  15:53:15.657 FLH: Read block - Writing: 4096 - Total: 3858432 - Buffer size: 1959
                                  15:53:15.858 FLH: Read block - Writing: 4096 - Total: 3862528 - Buffer size: 1959
                                  15:53:16.057 FLH: Read block - Writing: 4096 - Total: 3866624 - Buffer size: 1959
                                  15:53:16.264 FLH: Read block - Writing: 4096 - Total: 3870720 - Buffer size: 1959
                                  15:53:16.458 FLH: Read block - Writing: 4096 - Total: 3874816 - Buffer size: 1959
                                  15:53:16.658 FLH: Read block - Writing: 4096 - Total: 3878912 - Buffer size: 1959
                                  15:53:16.858 FLH: Read block - Writing: 4096 - Total: 3883008 - Buffer size: 1959
                                  15:53:17.058 FLH: Read block - Writing: 4096 - Total: 3887104 - Buffer size: 1959
                                  15:53:17.206 FLH: Read block - Writing: 4096 - Total: 3891200 - Buffer size: 1959
                                  15:53:17.318 FLH: Read block - Writing: 4096 - Total: 3895296 - Buffer size: 1959
                                  15:53:17.430 FLH: Read block - Writing: 4096 - Total: 3899392 - Buffer size: 1959
                                  15:53:17.558 FLH: Read block - Writing: 4096 - Total: 3903488 - Buffer size: 1959
                                  15:53:17.671 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "32", "time_elapsed": 175}}
                                  15:53:17.764 FLH: Read block - Writing: 4096 - Total: 3907584 - Buffer size: 1959
                                  15:53:17.958 FLH: Read block - Writing: 4096 - Total: 3911680 - Buffer size: 1959
                                  15:53:18.158 FLH: Read block - Writing: 4096 - Total: 3915776 - Buffer size: 1959
                                  15:53:18.317 FLH: Read block - Writing: 4096 - Total: 3919872 - Buffer size: 1959
                                  15:53:18.457 FLH: Read block - Writing: 4096 - Total: 3923968 - Buffer size: 1959
                                  15:53:18.657 FLH: Read block - Writing: 4096 - Total: 3928064 - Buffer size: 1959
                                  15:53:18.857 FLH: Read block - Writing: 4096 - Total: 3932160 - Buffer size: 1959
                                  15:53:18.969 FLH: Read block - Writing: 4096 - Total: 3936256 - Buffer size: 1959
                                  15:53:19.264 FLH: Read block - Writing: 4096 - Total: 3940352 - Buffer size: 1959
                                  15:53:19.458 FLH: Read block - Writing: 4096 - Total: 3944448 - Buffer size: 1959
                                  15:53:19.658 FLH: Read block - Writing: 4096 - Total: 3948544 - Buffer size: 1959
                                  15:53:19.804 FLH: Read block - Writing: 4096 - Total: 3952640 - Buffer size: 1959
                                  15:53:19.957 FLH: Read block - Writing: 4096 - Total: 3956736 - Buffer size: 1959
                                  15:53:20.157 FLH: Read block - Writing: 4096 - Total: 3960832 - Buffer size: 1959
                                  15:53:20.273 FLH: Read block - Writing: 4096 - Total: 3964928 - Buffer size: 1959
                                  15:53:20.457 FLH: Read block - Writing: 4096 - Total: 3969024 - Buffer size: 1959
                                  15:53:20.659 FLH: Read block - Writing: 4096 - Total: 3973120 - Buffer size: 1959
                                  15:53:20.812 FLH: Read block - Writing: 4096 - Total: 3977216 - Buffer size: 1959
                                  15:53:20.925 FLH: Read block - Writing: 4096 - Total: 3981312 - Buffer size: 1959
                                  15:53:21.057 FLH: Read block - Writing: 4096 - Total: 3985408 - Buffer size: 1959
                                  15:53:21.264 FLH: Read block - Writing: 4096 - Total: 3989504 - Buffer size: 1959
                                  15:53:21.458 FLH: Read block - Writing: 4096 - Total: 3993600 - Buffer size: 1959
                                  15:53:21.658 FLH: Read block - Writing: 4096 - Total: 3997696 - Buffer size: 1959
                                  15:53:21.858 FLH: Read block - Writing: 4096 - Total: 4001792 - Buffer size: 1959
                                  15:53:22.058 FLH: Read block - Writing: 4096 - Total: 4005888 - Buffer size: 1959
                                  15:53:22.264 FLH: Read block - Writing: 4096 - Total: 4009984 - Buffer size: 1959
                                  15:53:22.410 FLH: Read block - Writing: 4096 - Total: 4014080 - Buffer size: 1959
                                  15:53:22.560 FLH: Read block - Writing: 4096 - Total: 4018176 - Buffer size: 1959
                                  15:53:22.760 FLH: Read block - Writing: 4096 - Total: 4022272 - Buffer size: 1959
                                  15:53:22.959 FLH: Read block - Writing: 4096 - Total: 4026368 - Buffer size: 1959
                                  15:53:23.076 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "33", "time_elapsed": 180}}
                                  15:53:23.168 FLH: Read block - Writing: 4096 - Total: 4030464 - Buffer size: 1959
                                  15:53:23.328 FLH: Read block - Writing: 4096 - Total: 4034560 - Buffer size: 1959
                                  15:53:23.440 FLH: Read block - Writing: 4096 - Total: 4038656 - Buffer size: 1959
                                  15:53:23.558 FLH: Read block - Writing: 4096 - Total: 4042752 - Buffer size: 1959
                                  15:53:23.758 FLH: Read block - Writing: 4096 - Total: 4046848 - Buffer size: 1959
                                  15:53:23.958 FLH: Read block - Writing: 4096 - Total: 4050944 - Buffer size: 1959
                                  15:53:24.158 FLH: Read block - Writing: 4096 - Total: 4055040 - Buffer size: 1959
                                  15:53:24.273 FLH: Read block - Writing: 4096 - Total: 4059136 - Buffer size: 1959
                                  15:53:24.458 FLH: Read block - Writing: 4096 - Total: 4063232 - Buffer size: 1959
                                  15:53:24.657 FLH: Read block - Writing: 4096 - Total: 4067328 - Buffer size: 1959
                                  15:53:24.857 FLH: Read block - Writing: 4096 - Total: 4071424 - Buffer size: 1959
                                  15:53:25.057 FLH: Read block - Writing: 4096 - Total: 4075520 - Buffer size: 1959
                                  15:53:25.263 FLH: Read block - Writing: 4096 - Total: 4079616 - Buffer size: 1959
                                  15:53:25.458 FLH: Read block - Writing: 4096 - Total: 4083712 - Buffer size: 1959
                                  15:53:25.658 FLH: Read block - Writing: 4096 - Total: 4087808 - Buffer size: 1959
                                  15:53:25.813 FLH: Read block - Writing: 4096 - Total: 4091904 - Buffer size: 1959
                                  15:53:25.925 FLH: Read block - Writing: 4096 - Total: 4096000 - Buffer size: 1959
                                  15:53:26.058 FLH: Read block - Writing: 4096 - Total: 4100096 - Buffer size: 1959
                                  15:53:26.264 FLH: Read block - Writing: 4096 - Total: 4104192 - Buffer size: 1959
                                  15:53:26.458 FLH: Read block - Writing: 4096 - Total: 4108288 - Buffer size: 1959
                                  15:53:26.658 FLH: Read block - Writing: 4096 - Total: 4112384 - Buffer size: 1959
                                  15:53:26.858 FLH: Read block - Writing: 4096 - Total: 4116480 - Buffer size: 1959
                                  15:53:26.970 FLH: Read block - Writing: 4096 - Total: 4120576 - Buffer size: 1959
                                  15:53:27.158 FLH: Read block - Writing: 4096 - Total: 4124672 - Buffer size: 1959
                                  15:53:27.275 FLH: Read block - Writing: 4096 - Total: 4128768 - Buffer size: 1959
                                  15:53:27.422 FLH: Read block - Writing: 4096 - Total: 4132864 - Buffer size: 1959
                                  15:53:28.057 FLH: Read block - Writing: 4096 - Total: 4136960 - Buffer size: 1959
                                  15:53:28.263 FLH: Read block - Writing: 4096 - Total: 4141056 - Buffer size: 1959
                                  15:53:28.458 FLH: Read block - Writing: 4096 - Total: 4145152 - Buffer size: 1959
                                  15:53:28.657 FLH: Read block - Writing: 4096 - Total: 4149248 - Buffer size: 1959
                                  15:53:28.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "34", "time_elapsed": 186}}
                                  15:53:28.864 FLH: Read block - Writing: 4096 - Total: 4153344 - Buffer size: 1959
                                  15:53:29.058 FLH: Read block - Writing: 4096 - Total: 4157440 - Buffer size: 1959
                                  15:53:29.263 FLH: Read block - Writing: 4096 - Total: 4161536 - Buffer size: 1959
                                  15:53:29.458 FLH: Read block - Writing: 4096 - Total: 4165632 - Buffer size: 1959
                                  15:53:29.658 FLH: Read block - Writing: 4096 - Total: 4169728 - Buffer size: 1959
                                  15:53:29.858 FLH: Read block - Writing: 4096 - Total: 4173824 - Buffer size: 1959
                                  15:53:30.000 FLH: Read block - Writing: 4096 - Total: 4177920 - Buffer size: 1959
                                  15:53:30.158 FLH: Read block - Writing: 4096 - Total: 4182016 - Buffer size: 1959
                                  15:53:30.273 FLH: Read block - Writing: 4096 - Total: 4186112 - Buffer size: 1959
                                  15:53:30.458 FLH: Read block - Writing: 4096 - Total: 4190208 - Buffer size: 1959
                                  15:53:30.658 FLH: Read block - Writing: 4096 - Total: 4194304 - Buffer size: 1959
                                  15:53:30.858 FLH: Read block - Writing: 4096 - Total: 4198400 - Buffer size: 1959
                                  15:53:31.458 FLH: Read block - Writing: 4096 - Total: 4202496 - Buffer size: 1959
                                  15:53:31.657 FLH: Read block - Writing: 4096 - Total: 4206592 - Buffer size: 1959
                                  15:53:31.857 FLH: Read block - Writing: 4096 - Total: 4210688 - Buffer size: 1959
                                  15:53:31.970 FLH: Read block - Writing: 4096 - Total: 4214784 - Buffer size: 1959
                                  15:53:32.158 FLH: Read block - Writing: 4096 - Total: 4218880 - Buffer size: 1959
                                  15:53:32.274 FLH: Read block - Writing: 4096 - Total: 4222976 - Buffer size: 1959
                                  15:53:32.416 FLH: Read block - Writing: 4096 - Total: 4227072 - Buffer size: 1959
                                  15:53:32.558 FLH: Read block - Writing: 4096 - Total: 4231168 - Buffer size: 1959
                                  15:53:32.757 FLH: Read block - Writing: 4096 - Total: 4235264 - Buffer size: 1959
                                  15:53:32.958 FLH: Read block - Writing: 4096 - Total: 4239360 - Buffer size: 1959
                                  15:53:33.110 FLH: Read block - Writing: 4096 - Total: 4243456 - Buffer size: 1959
                                  15:53:33.265 FLH: Read block - Writing: 4096 - Total: 4247552 - Buffer size: 1959
                                  15:53:33.460 FLH: Read block - Writing: 4096 - Total: 4251648 - Buffer size: 1959
                                  15:53:33.660 FLH: Read block - Writing: 4096 - Total: 4255744 - Buffer size: 1959
                                  15:53:33.860 FLH: Read block - Writing: 4096 - Total: 4259840 - Buffer size: 1959
                                  15:53:33.971 FLH: Read block - Writing: 4096 - Total: 4263936 - Buffer size: 1959
                                  15:53:34.760 FLH: Read block - Writing: 4096 - Total: 4268032 - Buffer size: 1959
                                  15:53:34.901 FLH: Read block - Writing: 4096 - Total: 4272128 - Buffer size: 1959
                                  15:53:34.928 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "35", "time_elapsed": 192}}
                                  15:53:35.021 FLH: Read block - Writing: 4096 - Total: 4276224 - Buffer size: 1959
                                  15:53:35.158 FLH: Read block - Writing: 4096 - Total: 4280320 - Buffer size: 1959
                                  15:53:35.274 FLH: Read block - Writing: 4096 - Total: 4284416 - Buffer size: 1959
                                  15:53:35.457 FLH: Read block - Writing: 4096 - Total: 4288512 - Buffer size: 1959
                                  15:53:35.609 FLH: Read block - Writing: 4096 - Total: 4292608 - Buffer size: 1959
                                  15:53:35.757 FLH: Read block - Writing: 4096 - Total: 4296704 - Buffer size: 1959
                                  15:53:35.958 FLH: Read block - Writing: 4096 - Total: 4300800 - Buffer size: 1959
                                  15:53:36.070 FLH: Read block - Writing: 4096 - Total: 4304896 - Buffer size: 1959
                                  15:53:36.265 FLH: Read block - Writing: 4096 - Total: 4308992 - Buffer size: 1959
                                  15:53:36.457 FLH: Read block - Writing: 4096 - Total: 4313088 - Buffer size: 1959
                                  15:53:36.658 FLH: Read block - Writing: 4096 - Total: 4317184 - Buffer size: 1959
                                  15:53:36.859 FLH: Read block - Writing: 4096 - Total: 4321280 - Buffer size: 1959
                                  15:53:37.057 FLH: Read block - Writing: 4096 - Total: 4325376 - Buffer size: 1959
                                  15:53:37.265 FLH: Read block - Writing: 4096 - Total: 4329472 - Buffer size: 1959
                                  15:53:37.962 FLH: Read block - Writing: 4096 - Total: 4333568 - Buffer size: 1959
                                  15:53:38.116 FLH: Read block - Writing: 4096 - Total: 4337664 - Buffer size: 1959
                                  15:53:38.263 FLH: Read block - Writing: 4096 - Total: 4341760 - Buffer size: 1959
                                  15:53:38.457 FLH: Read block - Writing: 4096 - Total: 4345856 - Buffer size: 1959
                                  15:53:38.658 FLH: Read block - Writing: 4096 - Total: 4349952 - Buffer size: 1959
                                  15:53:38.858 FLH: Read block - Writing: 4096 - Total: 4354048 - Buffer size: 1959
                                  15:53:39.058 FLH: Read block - Writing: 4096 - Total: 4358144 - Buffer size: 1959
                                  15:53:39.264 FLH: Read block - Writing: 4096 - Total: 4362240 - Buffer size: 1959
                                  15:53:39.458 FLH: Read block - Writing: 4096 - Total: 4366336 - Buffer size: 1959
                                  15:53:39.658 FLH: Read block - Writing: 4096 - Total: 4370432 - Buffer size: 1959
                                  15:53:39.857 FLH: Read block - Writing: 4096 - Total: 4374528 - Buffer size: 1959
                                  15:53:39.969 FLH: Read block - Writing: 4096 - Total: 4378624 - Buffer size: 1959
                                  15:53:40.110 FLH: Read block - Writing: 4096 - Total: 4382720 - Buffer size: 1959
                                  15:53:40.263 FLH: Read block - Writing: 4096 - Total: 4386816 - Buffer size: 1959
                                  15:53:40.459 FLH: Read block - Writing: 4096 - Total: 4390912 - Buffer size: 1959
                                  15:53:40.612 FLH: Read block - Writing: 4096 - Total: 4395008 - Buffer size: 1959
                                  15:53:41.177 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "36", "time_elapsed": 198}}
                                  15:53:41.269 FLH: Read block - Writing: 4096 - Total: 4399104 - Buffer size: 1959
                                  15:53:41.458 FLH: Read block - Writing: 4096 - Total: 4403200 - Buffer size: 1959
                                  15:53:41.658 FLH: Read block - Writing: 4096 - Total: 4407296 - Buffer size: 1959
                                  15:53:41.858 FLH: Read block - Writing: 4096 - Total: 4411392 - Buffer size: 1959
                                  15:53:42.058 FLH: Read block - Writing: 4096 - Total: 4415488 - Buffer size: 1959
                                  15:53:42.264 FLH: Read block - Writing: 4096 - Total: 4419584 - Buffer size: 1959
                                  15:53:42.458 FLH: Read block - Writing: 4096 - Total: 4423680 - Buffer size: 1959
                                  15:53:42.678 FLH: Read block - Writing: 4096 - Total: 4427776 - Buffer size: 1959
                                  15:53:42.858 FLH: Read block - Writing: 4096 - Total: 4431872 - Buffer size: 1959
                                  15:53:43.010 FLH: Read block - Writing: 4096 - Total: 4435968 - Buffer size: 1959
                                  15:53:43.160 FLH: Read block - Writing: 4096 - Total: 4440064 - Buffer size: 1959
                                  15:53:43.275 FLH: Read block - Writing: 4096 - Total: 4444160 - Buffer size: 1959
                                  15:53:43.460 FLH: Read block - Writing: 4096 - Total: 4448256 - Buffer size: 1959
                                  15:53:43.660 FLH: Read block - Writing: 4096 - Total: 4452352 - Buffer size: 1959
                                  15:53:43.859 FLH: Read block - Writing: 4096 - Total: 4456448 - Buffer size: 1959
                                  15:53:43.971 FLH: Read block - Writing: 4096 - Total: 4460544 - Buffer size: 1959
                                  15:53:44.760 FLH: Read block - Writing: 4096 - Total: 4464640 - Buffer size: 1959
                                  15:53:44.960 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1959
                                  15:53:45.106 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1959
                                  15:53:45.263 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1959
                                  15:53:45.418 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1959
                                  15:53:45.557 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1959
                                  15:53:45.758 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1959
                                  15:53:45.958 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1959
                                  15:53:46.158 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1959
                                  15:53:46.273 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1959
                                  15:53:46.458 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1959
                                  15:53:46.657 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1959
                                  15:53:46.858 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1959
                                  15:53:46.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 204}}
                                  15:53:47.064 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1959
                                  15:53:47.264 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1959
                                  15:53:47.458 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1959
                                  15:53:48.158 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1959
                                  15:53:48.274 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1959
                                  15:53:48.457 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1959
                                  15:53:48.658 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1959
                                  15:53:48.859 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1959
                                  15:53:48.971 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1959
                                  15:53:49.158 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1959
                                  15:53:49.275 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1959
                                  15:53:49.458 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1959
                                  15:53:49.657 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1959
                                  15:53:49.858 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1959
                                  15:53:50.058 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1959
                                  15:53:50.217 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1959
                                  15:53:50.370 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1959
                                  15:53:50.482 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1959
                                  15:53:50.658 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1959
                                  15:53:51.358 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1959
                                  15:53:51.559 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1959
                                  15:53:51.758 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1959
                                  15:53:51.958 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1959
                                  15:53:52.158 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1959
                                  15:53:52.273 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 1959
                                  15:53:52.458 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 1959
                                  15:53:52.657 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 1959
                                  15:53:52.858 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 1959
                                  15:53:53.001 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 1959
                                  15:53:53.159 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 1959
                                  15:53:53.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 210}}
                                  15:53:53.281 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 1959
                                  15:53:53.459 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 1959
                                  15:53:53.657 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 1959
                                  15:53:53.857 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 1959
                                  15:53:54.057 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 1959
                                  15:53:54.758 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 1959
                                  15:53:54.958 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 1959
                                  15:53:55.111 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 1959
                                  15:53:55.266 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 1959
                                  15:53:55.407 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 1959
                                  15:53:55.559 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 1959
                                  15:53:55.758 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 1959
                                  15:53:55.958 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 1959
                                  15:53:56.158 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 1959
                                  15:53:56.274 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 1959
                                  15:53:56.458 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 1959
                                  15:53:56.657 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 1959
                                  15:53:56.858 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 1959
                                  15:53:57.058 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 1959
                                  15:53:57.264 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 1959
                                  15:53:57.460 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 1959
                                  15:53:58.160 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 1959
                                  15:53:58.275 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 1959
                                  15:53:58.459 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 1959
                                  15:53:58.660 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 1959
                                  15:53:58.859 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 1959
                                  15:53:58.971 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 1959
                                  15:53:59.160 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 1959
                                  15:53:59.275 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 1959
                                  15:53:59.459 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 1959
                                  15:53:59.573 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 217}}
                                  15:53:59.666 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1959
                                  15:53:59.860 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1959
                                  15:54:00.015 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1959
                                  15:54:00.158 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1959
                                  15:54:00.273 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1959
                                  15:54:00.458 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1959
                                  15:54:00.605 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1959
                                  • Armilar
                                    Armilar Most Active Forum Testing @australien last edited by Armilar
                                    @australien
                                    versuche mal die
                                    FlashNextionAdv0 http://nspanel.de/nspanel-v0.0.0.tft
                                    EDIT: Ist ja irgendwie immer die gleiche Länge und Zeit und Länge... Gibt es bei dir irgend ein QoS, was da die Leitung einschränkt?
                                      australien @Armilar last edited by australien
                                      @armilar
                                      QOS oder ähnliches gibt es meines Wissens nicht, hatte bis jetzt auch alles funktioniert.
                                      genau das gleichen
                                      6:11:23.874 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                                      16:11:23.902 FLH: host: nspanel.de, port: 80, get: /nspanel-v0.0.0.tft
                                      16:11:23.957 FLH: Connected:true
                                      16:11:24.060 FLH: Retry 2
                                      16:11:24.273 FLH: HTTP Respose is 200 OK or 206 Partial Content
                                      16:11:24.274 FLH: Flash file size: 12197684
                                      16:11:24.275 SRC: Berry
                                      16:11:24.276 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                                      16:11:24.282 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                                      16:11:24.287 SRC: Berry
                                      16:11:24.288 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                                      16:11:24.292 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                                      16:11:24.308 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                                      16:11:24.311 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                                      16:11:24.313 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                                      16:11:24.319 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                                      16:11:24.444 FLH: Send (High Speed) flash start
                                      16:11:24.450 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
                                      16:11:24.473 BRY: Serial UART2
                                      16:11:24.825 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                                      16:11:24.918 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                                      16:11:25.019 FLH: Waiting offset...
                                      16:11:29.819 FLH: Flash offset marker 0
                                      16:11:29.919 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                                      16:11:30.118 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                                      16:11:30.224 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                                      16:11:30.341 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395```
                                      16:14:53.123 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1395
                                      16:14:53.324 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1395
                                      16:14:53.434 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1395
                                      16:14:53.619 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1395
                                      16:14:53.819 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1395
                                      16:14:53.969 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1395
                                      16:14:54.119 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1395
                                      Chris_71 1 Reply Last reply Reply Quote 0
                                      • Chris_71
                                        Chris_71 @australien last edited by
                                        @Armilar
                                        Beim Wechsel von AccuWeather auf OpenWeatherMap wird mir nun beim Screensaver unter dem Symbol für Sonnenaufgang keine Uhrzeit mehr angezeigt - sondern nur Zahlen zB 1757653.
                                        Config alt:
                                                // bottomScreensaverEntity 1
                                                        ScreensaverEntity: 'accuweather.0.Daily.Day1.Sunrise',
                                                        ScreensaverEntityFactor: 1,
                                                        ScreensaverEntityDecimalPlaces: 0,
                                                        ScreensaverEntityDateFormat: { hour: '2-digit', minute: '2-digit' }, // Description at Wiki-Pages
                                                        ScreensaverEntityIconOn: 'weather-sunset-up',
                                                        ScreensaverEntityIconOff: null,
                                                        ScreensaverEntityText: 'Sonne',
                                                        ScreensaverEntityIconColor: MSYellow
                                        Config Neu:
                                                    ScreensaverEntity: 'openweathermap.0.forecast.current.sunrise',
                                        • Armilar
                                          Armilar Most Active Forum Testing @Chris_71 last edited by
                                          @chris_71
                                          kannste entweder formatiert duch einen Alias ziehen oder nimmst einfach etwas, was ne richtige Zeit hat...
                                                          ScreensaverEntity: 'javascript.0.variables.astro.sunrise',
                                          lovelace ui nspanel sonoff
                                          268
                                          7576
                                          6051949
