      australien @Armilar last edited by australien
      @armilar said in SONOFF NSPanel mit Lovelace UI:
      FlashNextionAdv2 http://nspanel.de/nspanel-v5.0.0.tft
      Tasmota ist die letzte 15.0.1
      das log bei der Adv1 Version:
      00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
      00:00:00.016 UFS: FlashFS mounted with 272 kB free
      00:00:00.023 CFG: Loaded from File, Anzahl 1506
      00:00:00.032 QPC: Count 1
      00:00:00.032 CFG: CR 430/699, Busy 0
      00:00:00.037 TYA: Active=0
      00:00:00.042 ROT: Mode 1
      00:00:00.065 CFG: No '*.autoconf' file found
      00:00:00.069 BRY: Berry initialized, RAM used 3493 bytes
      00:00:00.075 BRY: No 'preinit.be'
      00:00:00.077 SRC: Restart
      00:00:00.081 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
      00:00:00.202 NXP: Initializing Driver
      00:00:00.204 BRY: Serial UART2
      00:00:00.206 BRY: Successfully loaded 'autoexec.be'
      00:00:00.287 WIF: Verbindungsversuch…
      00:00:01.000 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
      00:00:03.456 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
      00:00:03.561 WIF: Verbindungsversuch…
      00:00:04.561 WIF: Verbindungsversuch…
      00:00:05.561 WIF: Verbindungsversuch…
      00:00:06.027 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
      00:00:06.561 WIF: verbunden
      00:00:06.818 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
      00:00:06.996 RTC: UTC 2025-09-12T12:58:16Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
      13:58:16.000 RTC: Synced by NTP
      13:58:16.812 MQT: Verbindungsversuch…
      13:58:16.832 MQT: verbunden
      13:58:16.835 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
      13:58:16.836 MQT: SmartHome/NSPanel_1/cmnd/POWER =
      13:58:16.837 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
      13:58:16.838 MQT: abonniere SmartHome/tasmotas/cmnd/#
      13:58:16.839 MQT: abonniere cmnd/NSPanel_1_fb/#
      13:58:16.841 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
      13:58:16.855 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
      13:58:16.879 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":163}}
      13:58:16.884 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      13:58:16.896 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      13:58:16.897 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
      13:58:16.898 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
      13:58:16.959 QPC: Reset
      13:58:17.093 SRC: MQTT
      13:58:17.094 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      13:58:17.105 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      13:58:17.109 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      13:58:17.143 SRC: MQTT
      13:58:17.144 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      13:58:17.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      13:58:17.147 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      13:58:17.193 SRC: MQTT
      13:58:17.194 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      13:58:17.206 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      13:58:17.210 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      13:58:17.243 SRC: MQTT
      13:58:17.244 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      13:58:17.247 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      13:58:17.250 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      13:58:17.293 SRC: MQTT
      13:58:17.294 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      13:58:17.305 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      13:58:17.309 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      13:58:17.343 SRC: MQTT
      13:58:17.344 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      13:58:17.347 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      13:58:17.350 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      13:58:18.844 SRC: MQTT
      13:58:18.844 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
      13:58:18.858 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
      13:58:18.862 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
      13:58:18.893 SRC: MQTT
      13:58:18.894 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
      13:58:18.896 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
      13:58:18.897 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
      13:58:18.952 APP: Startvorgänge 163
      13:58:19.480 CFG: Saved, Anzahl 1507, Bytes 4096
      13:58:21.226 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T13:58:21","Uptime":"0T00:00:12","UptimeSec":12,"Heap":148,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":368,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:06"}}
      13:58:21.270 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T13:58:21","ANALOG":{"Temperature1":20.8},"ESP32":{"Temperature":46.1},"TempUnit":"C"}
      14:01:46.586 HTP: Hauptmenü
      14:01:49.089 HTP: Werkzeuge
      14:01:50.961 HTP: Konsole
      14:01:56.889 HTP: Werkzeuge
      14:01:58.377 HTP: Hauptmenü
      14:02:00.161 HTP: Werkzeuge
      14:02:01.057 HTP: Konsole
      14:02:07.622 CMD: FlashNextionAdv1 http://nspanel.de/nspanel-v5.0.0.tft
      14:02:07.623 SRC: WebConsole from 10.68.0.156
      14:02:07.624 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 1, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
      14:02:07.632 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
      14:02:07.666 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
      14:02:07.811 FLH: Connected:true
      14:02:07.914 FLH: Retry 2
      14:02:08.127 FLH: HTTP Respose is 200 OK or 206 Partial Content
      14:02:08.128 FLH: Flash file size: 12197684
      14:02:08.129 SRC: Berry
      14:02:08.130 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
      14:02:08.135 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
      14:02:08.140 SRC: Berry
      14:02:08.141 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
      14:02:08.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
      14:02:08.161 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
      14:02:08.163 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
      14:02:08.165 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
      14:02:08.172 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
      14:02:08.297 FLH: Send (High Speed) flash start
      14:02:08.303 NXP: Nextion command sent = bytes('77686D692D7772692031323139373638342C3932313630302C72657330FFFFFF')
      14:02:08.326 BRY: Serial UART2
      14:02:08.679 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
      14:02:08.771 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
      14:02:09.279 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
      14:02:09.392 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
      14:02:09.501 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
      14:02:09.611 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
      14:02:09.770 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
      14:02:09.881 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
      14:02:10.073 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
      14:02:10.317 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
      14:02:10.427 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
      14:02:10.536 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
      14:02:10.645 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
      14:02:10.752 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
      14:02:10.863 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
      14:02:11.074 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
      14:02:11.180 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
      14:02:11.293 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
      14:02:11.574 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
      14:02:11.770 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
      14:02:11.971 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
      14:02:12.083 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
      14:02:12.275 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
      14:02:12.471 FLH: Read block - Writing: 4096 - Total: 94208 - Buffer size: 1395
      14:02:12.583 FLH: Read block - Writing: 4096 - Total: 98304 - Buffer size: 1395
      14:02:12.770 FLH: Read block - Writing: 4096 - Total: 102400 - Buffer size: 1395
      14:02:12.885 FLH: Read block - Writing: 4096 - Total: 106496 - Buffer size: 1395
      14:02:13.032 FLH: Read block - Writing: 4096 - Total: 110592 - Buffer size: 1395
      14:02:13.143 FLH: Read block - Writing: 4096 - Total: 114688 - Buffer size: 1395
      14:02:13.254 FLH: Read block - Writing: 4096 - Total: 118784 - Buffer size: 1395
      14:02:13.371 FLH: Read block - Writing: 4096 - Total: 122880 - Buffer size: 1395
      14:02:13.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "1", "time_elapsed": 5}}
      14:02:13.578 FLH: Read block - Writing: 4096 - Total: 126976 - Buffer size: 1395
      14:02:13.771 FLH: Read block - Writing: 4096 - Total: 131072 - Buffer size: 1395
      14:02:13.971 FLH: Read block - Writing: 4096 - Total: 135168 - Buffer size: 1395
      14:02:14.170 FLH: Read block - Writing: 4096 - Total: 139264 - Buffer size: 1395
      14:02:14.283 FLH: Read block - Writing: 4096 - Total: 143360 - Buffer size: 1395
      14:02:14.470 FLH: Read block - Writing: 4096 - Total: 147456 - Buffer size: 1395
      14:02:14.670 FLH: Read block - Writing: 4096 - Total: 151552 - Buffer size: 1395
      14:02:14.870 FLH: Read block - Writing: 4096 - Total: 155648 - Buffer size: 1395
      14:02:15.074 FLH: Read block - Writing: 4096 - Total: 159744 - Buffer size: 1395
      14:02:15.275 FLH: Read block - Writing: 4096 - Total: 163840 - Buffer size: 1395
      14:02:15.471 FLH: Read block - Writing: 4096 - Total: 167936 - Buffer size: 1395
      14:02:15.620 FLH: Read block - Writing: 4096 - Total: 172032 - Buffer size: 1395
      14:02:15.770 FLH: Read block - Writing: 4096 - Total: 176128 - Buffer size: 1395
      14:02:15.882 FLH: Read block - Writing: 4096 - Total: 180224 - Buffer size: 1395
      14:02:16.074 FLH: Read block - Writing: 4096 - Total: 184320 - Buffer size: 1395
      14:02:16.276 FLH: Read block - Writing: 4096 - Total: 188416 - Buffer size: 1395
      14:02:16.470 FLH: Read block - Writing: 4096 - Total: 192512 - Buffer size: 1395
      14:02:16.671 FLH: Read block - Writing: 4096 - Total: 196608 - Buffer size: 1395
      14:02:16.869 FLH: Read block - Writing: 4096 - Total: 200704 - Buffer size: 1395
      14:02:17.074 FLH: Read block - Writing: 4096 - Total: 204800 - Buffer size: 1395
      14:02:17.276 FLH: Read block - Writing: 4096 - Total: 208896 - Buffer size: 1395
      14:02:17.387 FLH: Read block - Writing: 4096 - Total: 212992 - Buffer size: 1395
      14:02:17.574 FLH: Read block - Writing: 4096 - Total: 217088 - Buffer size: 1395
      14:02:17.771 FLH: Read block - Writing: 4096 - Total: 221184 - Buffer size: 1395
      14:02:17.883 FLH: Read block - Writing: 4096 - Total: 225280 - Buffer size: 1395
      14:02:18.029 FLH: Read block - Writing: 4096 - Total: 229376 - Buffer size: 1395
      14:02:18.177 FLH: Read block - Writing: 4096 - Total: 233472 - Buffer size: 1395
      14:02:18.370 FLH: Read block - Writing: 4096 - Total: 237568 - Buffer size: 1395
      14:02:18.573 FLH: Read block - Writing: 4096 - Total: 241664 - Buffer size: 1395
      14:02:18.771 FLH: Read block - Writing: 4096 - Total: 245760 - Buffer size: 1395
      14:02:18.795 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "2", "time_elapsed": 10}}
      14:02:18.888 FLH: Read block - Writing: 4096 - Total: 249856 - Buffer size: 1395
      14:02:19.073 FLH: Read block - Writing: 4096 - Total: 253952 - Buffer size: 1395
      14:02:19.277 FLH: Read block - Writing: 4096 - Total: 258048 - Buffer size: 1395
      14:02:19.388 FLH: Read block - Writing: 4096 - Total: 262144 - Buffer size: 1395
      14:02:19.574 FLH: Read block - Writing: 4096 - Total: 266240 - Buffer size: 1395
      14:02:19.771 FLH: Read block - Writing: 4096 - Total: 270336 - Buffer size: 1395
      14:02:19.881 FLH: Read block - Writing: 4096 - Total: 274432 - Buffer size: 1395
      14:02:20.074 FLH: Read block - Writing: 4096 - Total: 278528 - Buffer size: 1395
      14:02:20.276 FLH: Read block - Writing: 4096 - Total: 282624 - Buffer size: 1395
      14:02:20.386 FLH: Read block - Writing: 4096 - Total: 286720 - Buffer size: 1395
      14:02:20.592 FLH: Read block - Writing: 4096 - Total: 290816 - Buffer size: 1395
      14:02:20.771 FLH: Read block - Writing: 4096 - Total: 294912 - Buffer size: 1395
      14:02:20.881 FLH: Read block - Writing: 4096 - Total: 299008 - Buffer size: 1395
      14:02:21.074 FLH: Read block - Writing: 4096 - Total: 303104 - Buffer size: 1395
      14:02:21.277 FLH: Read block - Writing: 4096 - Total: 307200 - Buffer size: 1395
      14:02:21.386 FLH: Read block - Writing: 4096 - Total: 311296 - Buffer size: 1395
      14:02:21.574 FLH: Read block - Writing: 4096 - Total: 315392 - Buffer size: 1395
      14:02:21.772 FLH: Read block - Writing: 4096 - Total: 319488 - Buffer size: 1395
      14:02:21.882 FLH: Read block - Writing: 4096 - Total: 323584 - Buffer size: 1395
      14:02:22.074 FLH: Read block - Writing: 4096 - Total: 327680 - Buffer size: 1395
      14:02:22.277 FLH: Read block - Writing: 4096 - Total: 331776 - Buffer size: 1395
      14:02:22.470 FLH: Read block - Writing: 4096 - Total: 335872 - Buffer size: 1395
      14:02:22.670 FLH: Read block - Writing: 4096 - Total: 339968 - Buffer size: 1395
      14:02:22.871 FLH: Read block - Writing: 4096 - Total: 344064 - Buffer size: 1395
      14:02:23.073 FLH: Read block - Writing: 4096 - Total: 348160 - Buffer size: 1395
      14:02:23.218 FLH: Read block - Writing: 4096 - Total: 352256 - Buffer size: 1395
      14:02:23.334 FLH: Read block - Writing: 4096 - Total: 356352 - Buffer size: 1395
      14:02:23.469 FLH: Read block - Writing: 4096 - Total: 360448 - Buffer size: 1395
      14:02:23.670 FLH: Read block - Writing: 4096 - Total: 364544 - Buffer size: 1395
      14:02:23.870 FLH: Read block - Writing: 4096 - Total: 368640 - Buffer size: 1395
      14:02:23.986 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "3", "time_elapsed": 15}}
      14:02:24.078 FLH: Read block - Writing: 4096 - Total: 372736 - Buffer size: 1395
      14:02:24.276 FLH: Read block - Writing: 4096 - Total: 376832 - Buffer size: 1395
      14:02:24.388 FLH: Read block - Writing: 4096 - Total: 380928 - Buffer size: 1395
      14:02:24.573 FLH: Read block - Writing: 4096 - Total: 385024 - Buffer size: 1395
      14:02:24.770 FLH: Read block - Writing: 4096 - Total: 389120 - Buffer size: 1395
      14:02:24.970 FLH: Read block - Writing: 4096 - Total: 393216 - Buffer size: 1395
      14:02:25.082 FLH: Read block - Writing: 4096 - Total: 397312 - Buffer size: 1395
      14:02:25.372 FLH: Read block - Writing: 4096 - Total: 401408 - Buffer size: 1395
      14:02:25.574 FLH: Read block - Writing: 4096 - Total: 405504 - Buffer size: 1395
      14:02:25.769 FLH: Read block - Writing: 4096 - Total: 409600 - Buffer size: 1395
      14:02:25.971 FLH: Read block - Writing: 4096 - Total: 413696 - Buffer size: 1395
      14:02:26.085 FLH: Read block - Writing: 4096 - Total: 417792 - Buffer size: 1395
      14:02:26.275 FLH: Read block - Writing: 4096 - Total: 421888 - Buffer size: 1395
      14:02:26.471 FLH: Read block - Writing: 4096 - Total: 425984 - Buffer size: 1395
      14:02:26.671 FLH: Read block - Writing: 4096 - Total: 430080 - Buffer size: 1395
      14:02:26.870 FLH: Read block - Writing: 4096 - Total: 434176 - Buffer size: 1395
      14:02:27.074 FLH: Read block - Writing: 4096 - Total: 438272 - Buffer size: 1395
      14:02:27.276 FLH: Read block - Writing: 4096 - Total: 442368 - Buffer size: 1395
      14:02:27.387 FLH: Read block - Writing: 4096 - Total: 446464 - Buffer size: 1395
      14:02:27.573 FLH: Read block - Writing: 4096 - Total: 450560 - Buffer size: 1395
      14:02:27.771 FLH: Read block - Writing: 4096 - Total: 454656 - Buffer size: 1395
      14:02:27.881 FLH: Read block - Writing: 4096 - Total: 458752 - Buffer size: 1395
      14:02:28.074 FLH: Read block - Writing: 4096 - Total: 462848 - Buffer size: 1395
      14:02:28.277 FLH: Read block - Writing: 4096 - Total: 466944 - Buffer size: 1395
      14:02:28.427 FLH: Read block - Writing: 4096 - Total: 471040 - Buffer size: 1395
      14:02:28.576 FLH: Read block - Writing: 4096 - Total: 475136 - Buffer size: 1395
      14:02:28.770 FLH: Read block - Writing: 4096 - Total: 479232 - Buffer size: 1395
      14:02:28.881 FLH: Read block - Writing: 4096 - Total: 483328 - Buffer size: 1395
      14:02:29.074 FLH: Read block - Writing: 4096 - Total: 487424 - Buffer size: 1395
      14:02:29.277 FLH: Read block - Writing: 4096 - Total: 491520 - Buffer size: 1395
      14:02:29.300 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "4", "time_elapsed": 20}}
      14:02:29.393 FLH: Read block - Writing: 4096 - Total: 495616 - Buffer size: 1395
      14:02:29.574 FLH: Read block - Writing: 4096 - Total: 499712 - Buffer size: 1395
      14:02:29.770 FLH: Read block - Writing: 4096 - Total: 503808 - Buffer size: 1395
      14:02:29.881 FLH: Read block - Writing: 4096 - Total: 507904 - Buffer size: 1395
      14:02:30.073 FLH: Read block - Writing: 4096 - Total: 512000 - Buffer size: 1395
      14:02:30.277 FLH: Read block - Writing: 4096 - Total: 516096 - Buffer size: 1395
      14:02:30.387 FLH: Read block - Writing: 4096 - Total: 520192 - Buffer size: 1395
      14:02:30.574 FLH: Read block - Writing: 4096 - Total: 524288 - Buffer size: 1395
      14:02:30.771 FLH: Read block - Writing: 4096 - Total: 528384 - Buffer size: 1395
      14:02:30.984 FLH: Read block - Writing: 4096 - Total: 532480 - Buffer size: 1395
      14:02:31.171 FLH: Read block - Writing: 4096 - Total: 536576 - Buffer size: 1395
      14:02:31.288 FLH: Read block - Writing: 4096 - Total: 540672 - Buffer size: 1395
      14:02:31.398 FLH: Read block - Writing: 4096 - Total: 544768 - Buffer size: 1395
      14:02:31.573 FLH: Read block - Writing: 4096 - Total: 548864 - Buffer size: 1395
      14:02:31.771 FLH: Read block - Writing: 4096 - Total: 552960 - Buffer size: 1395
      14:02:31.881 FLH: Read block - Writing: 4096 - Total: 557056 - Buffer size: 1395
      14:02:32.073 FLH: Read block - Writing: 4096 - Total: 561152 - Buffer size: 1395
      14:02:32.277 FLH: Read block - Writing: 4096 - Total: 565248 - Buffer size: 1395
      14:02:32.388 FLH: Read block - Writing: 4096 - Total: 569344 - Buffer size: 1395
      14:02:32.574 FLH: Read block - Writing: 4096 - Total: 573440 - Buffer size: 1395
      14:02:32.771 FLH: Read block - Writing: 4096 - Total: 577536 - Buffer size: 1395
      14:02:32.881 FLH: Read block - Writing: 4096 - Total: 581632 - Buffer size: 1395
      14:02:33.074 FLH: Read block - Writing: 4096 - Total: 585728 - Buffer size: 1395
      14:02:33.276 FLH: Read block - Writing: 4096 - Total: 589824 - Buffer size: 1395
      14:02:33.427 FLH: Read block - Writing: 4096 - Total: 593920 - Buffer size: 1395
      14:02:33.671 FLH: Read block - Writing: 4096 - Total: 598016 - Buffer size: 1395
      14:02:33.871 FLH: Read block - Writing: 4096 - Total: 602112 - Buffer size: 1395
      14:02:34.073 FLH: Read block - Writing: 4096 - Total: 606208 - Buffer size: 1395
      14:02:34.276 FLH: Read block - Writing: 4096 - Total: 610304 - Buffer size: 1395
      14:02:34.301 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "5", "time_elapsed": 25}}
      14:02:34.394 FLH: Read block - Writing: 4096 - Total: 614400 - Buffer size: 1395
      14:02:34.573 FLH: Read block - Writing: 4096 - Total: 618496 - Buffer size: 1395
      14:02:34.770 FLH: Read block - Writing: 4096 - Total: 622592 - Buffer size: 1395
      14:02:34.971 FLH: Read block - Writing: 4096 - Total: 626688 - Buffer size: 1395
      14:02:35.082 FLH: Read block - Writing: 4096 - Total: 630784 - Buffer size: 1395
      14:02:35.277 FLH: Read block - Writing: 4096 - Total: 634880 - Buffer size: 1395
      14:02:35.390 FLH: Read block - Writing: 4096 - Total: 638976 - Buffer size: 1395
      14:02:35.573 FLH: Read block - Writing: 4096 - Total: 643072 - Buffer size: 1395
      14:02:35.770 FLH: Read block - Writing: 4096 - Total: 647168 - Buffer size: 1395
      14:02:35.988 FLH: Read block - Writing: 4096 - Total: 651264 - Buffer size: 1395
      14:02:36.101 FLH: Read block - Writing: 4096 - Total: 655360 - Buffer size: 1395
      14:02:36.276 FLH: Read block - Writing: 4096 - Total: 659456 - Buffer size: 1395
      14:02:36.471 FLH: Read block - Writing: 4096 - Total: 663552 - Buffer size: 1395
      14:02:36.580 FLH: Read block - Writing: 4096 - Total: 667648 - Buffer size: 1395
      14:02:36.770 FLH: Read block - Writing: 4096 - Total: 671744 - Buffer size: 1395
      14:02:36.970 FLH: Read block - Writing: 4096 - Total: 675840 - Buffer size: 1395
      14:02:37.081 FLH: Read block - Writing: 4096 - Total: 679936 - Buffer size: 1395
      14:02:37.277 FLH: Read block - Writing: 4096 - Total: 684032 - Buffer size: 1395
      14:02:37.388 FLH: Read block - Writing: 4096 - Total: 688128 - Buffer size: 1395
      14:02:37.573 FLH: Read block - Writing: 4096 - Total: 692224 - Buffer size: 1395
      14:02:37.771 FLH: Read block - Writing: 4096 - Total: 696320 - Buffer size: 1395
      14:02:37.970 FLH: Read block - Writing: 4096 - Total: 700416 - Buffer size: 1395
      14:02:38.081 FLH: Read block - Writing: 4096 - Total: 704512 - Buffer size: 1395
      14:02:38.276 FLH: Read block - Writing: 4096 - Total: 708608 - Buffer size: 1395
      14:02:38.471 FLH: Read block - Writing: 4096 - Total: 712704 - Buffer size: 1395
      14:02:38.619 FLH: Read block - Writing: 4096 - Total: 716800 - Buffer size: 1395
      14:02:38.770 FLH: Read block - Writing: 4096 - Total: 720896 - Buffer size: 1395
      14:02:38.970 FLH: Read block - Writing: 4096 - Total: 724992 - Buffer size: 1395
      14:02:39.169 FLH: Read block - Writing: 4096 - Total: 729088 - Buffer size: 1395
      14:02:39.283 FLH: Read block - Writing: 4096 - Total: 733184 - Buffer size: 1395
      14:02:39.385 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "6", "time_elapsed": 31}}
      14:02:39.477 FLH: Read block - Writing: 4096 - Total: 737280 - Buffer size: 1395
      14:02:39.670 FLH: Read block - Writing: 4096 - Total: 741376 - Buffer size: 1395
      14:02:39.871 FLH: Read block - Writing: 4096 - Total: 745472 - Buffer size: 1395
      14:02:40.074 FLH: Read block - Writing: 4096 - Total: 749568 - Buffer size: 1395
      14:02:40.275 FLH: Read block - Writing: 4096 - Total: 753664 - Buffer size: 1395
      14:02:40.470 FLH: Read block - Writing: 4096 - Total: 757760 - Buffer size: 1395
      14:02:40.671 FLH: Read block - Writing: 4096 - Total: 761856 - Buffer size: 1395
      14:02:40.870 FLH: Read block - Writing: 4096 - Total: 765952 - Buffer size: 1395
      14:02:41.074 FLH: Read block - Writing: 4096 - Total: 770048 - Buffer size: 1395
      14:02:41.221 FLH: Read block - Writing: 4096 - Total: 774144 - Buffer size: 1395
      14:02:41.335 FLH: Read block - Writing: 4096 - Total: 778240 - Buffer size: 1395
      14:02:41.469 FLH: Read block - Writing: 4096 - Total: 782336 - Buffer size: 1395
      14:02:41.671 FLH: Read block - Writing: 4096 - Total: 786432 - Buffer size: 1395
      14:02:41.870 FLH: Read block - Writing: 4096 - Total: 790528 - Buffer size: 1395
      14:02:42.074 FLH: Read block - Writing: 4096 - Total: 794624 - Buffer size: 1395
      14:02:42.277 FLH: Read block - Writing: 4096 - Total: 798720 - Buffer size: 1395
      14:02:42.387 FLH: Read block - Writing: 4096 - Total: 802816 - Buffer size: 1395
      14:02:42.574 FLH: Read block - Writing: 4096 - Total: 806912 - Buffer size: 1395
      14:02:42.770 FLH: Read block - Writing: 4096 - Total: 811008 - Buffer size: 1395
      14:02:42.883 FLH: Read block - Writing: 4096 - Total: 815104 - Buffer size: 1395
      14:02:43.074 FLH: Read block - Writing: 4096 - Total: 819200 - Buffer size: 1395
      14:02:43.277 FLH: Read block - Writing: 4096 - Total: 823296 - Buffer size: 1395
      14:02:43.387 FLH: Read block - Writing: 4096 - Total: 827392 - Buffer size: 1395
      14:02:43.574 FLH: Read block - Writing: 4096 - Total: 831488 - Buffer size: 1395
      14:02:43.720 FLH: Read block - Writing: 4096 - Total: 835584 - Buffer size: 1395
      14:02:43.830 FLH: Read block - Writing: 4096 - Total: 839680 - Buffer size: 1395
      14:02:43.971 FLH: Read block - Writing: 4096 - Total: 843776 - Buffer size: 1395
      14:02:44.084 FLH: Read block - Writing: 4096 - Total: 847872 - Buffer size: 1395
      14:02:44.277 FLH: Read block - Writing: 4096 - Total: 851968 - Buffer size: 1395
      14:02:44.390 FLH: Read block - Writing: 4096 - Total: 856064 - Buffer size: 1395
      14:02:44.584 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "7", "time_elapsed": 36}}
      14:02:44.676 FLH: Read block - Writing: 4096 - Total: 860160 - Buffer size: 1395
      14:02:44.868 FLH: Read block - Writing: 4096 - Total: 864256 - Buffer size: 1395
      14:02:45.070 FLH: Read block - Writing: 4096 - Total: 868352 - Buffer size: 1395
      14:02:45.278 FLH: Read block - Writing: 4096 - Total: 872448 - Buffer size: 1395
      14:02:45.388 FLH: Read block - Writing: 4096 - Total: 876544 - Buffer size: 1395
      14:02:45.574 FLH: Read block - Writing: 4096 - Total: 880640 - Buffer size: 1395
      14:02:45.770 FLH: Read block - Writing: 4096 - Total: 884736 - Buffer size: 1395
      14:02:45.881 FLH: Read block - Writing: 4096 - Total: 888832 - Buffer size: 1395
      14:02:46.069 FLH: Read block - Writing: 4096 - Total: 892928 - Buffer size: 1395
      14:02:46.282 FLH: Read block - Writing: 4096 - Total: 897024 - Buffer size: 1395
      14:02:46.392 FLH: Read block - Writing: 4096 - Total: 901120 - Buffer size: 1395
      14:02:46.573 FLH: Read block - Writing: 4096 - Total: 905216 - Buffer size: 1395
      14:02:46.772 FLH: Read block - Writing: 4096 - Total: 909312 - Buffer size: 1395
      14:02:46.971 FLH: Read block - Writing: 4096 - Total: 913408 - Buffer size: 1395
      14:02:47.084 FLH: Read block - Writing: 4096 - Total: 917504 - Buffer size: 1395
      14:02:47.277 FLH: Read block - Writing: 4096 - Total: 921600 - Buffer size: 1395
      14:02:47.468 FLH: Read block - Writing: 4096 - Total: 925696 - Buffer size: 1395
      14:02:47.672 FLH: Read block - Writing: 4096 - Total: 929792 - Buffer size: 1395
      14:02:47.870 FLH: Read block - Writing: 4096 - Total: 933888 - Buffer size: 1395
      14:02:48.069 FLH: Read block - Writing: 4096 - Total: 937984 - Buffer size: 1395
      14:02:48.275 FLH: Read block - Writing: 4096 - Total: 942080 - Buffer size: 1395
      14:02:48.472 FLH: Read block - Writing: 4096 - Total: 946176 - Buffer size: 1395
      14:02:48.582 FLH: Read block - Writing: 4096 - Total: 950272 - Buffer size: 1395
      14:02:48.769 FLH: Read block - Writing: 4096 - Total: 954368 - Buffer size: 1395
      14:02:48.919 FLH: Read block - Writing: 4096 - Total: 958464 - Buffer size: 1395
      14:02:49.072 FLH: Read block - Writing: 4096 - Total: 962560 - Buffer size: 1395
      14:02:49.277 FLH: Read block - Writing: 4096 - Total: 966656 - Buffer size: 1395
      14:02:49.471 FLH: Read block - Writing: 4096 - Total: 970752 - Buffer size: 1395
      14:02:49.582 FLH: Read block - Writing: 4096 - Total: 974848 - Buffer size: 1395
      14:02:49.769 FLH: Read block - Writing: 4096 - Total: 978944 - Buffer size: 1395
      14:02:49.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "8", "time_elapsed": 41}}
      14:02:49.975 FLH: Read block - Writing: 4096 - Total: 983040 - Buffer size: 1395
      14:02:50.170 FLH: Read block - Writing: 4096 - Total: 987136 - Buffer size: 1395
      14:02:50.372 FLH: Read block - Writing: 4096 - Total: 991232 - Buffer size: 1395
      14:02:50.574 FLH: Read block - Writing: 4096 - Total: 995328 - Buffer size: 1395
      14:02:50.770 FLH: Read block - Writing: 4096 - Total: 999424 - Buffer size: 1395
      14:02:50.881 FLH: Read block - Writing: 4096 - Total: 1003520 - Buffer size: 1395
      14:02:51.074 FLH: Read block - Writing: 4096 - Total: 1007616 - Buffer size: 1395
      14:02:51.275 FLH: Read block - Writing: 4096 - Total: 1011712 - Buffer size: 1395
      14:02:51.389 FLH: Read block - Writing: 4096 - Total: 1015808 - Buffer size: 1395
      14:02:51.535 FLH: Read block - Writing: 4096 - Total: 1019904 - Buffer size: 1395
      14:02:51.646 FLH: Read block - Writing: 4096 - Total: 1024000 - Buffer size: 1395
      14:02:51.770 FLH: Read block - Writing: 4096 - Total: 1028096 - Buffer size: 1395
      14:02:51.970 FLH: Read block - Writing: 4096 - Total: 1032192 - Buffer size: 1395
      14:02:52.081 FLH: Read block - Writing: 4096 - Total: 1036288 - Buffer size: 1395
      14:02:52.276 FLH: Read block - Writing: 4096 - Total: 1040384 - Buffer size: 1395
      14:02:52.389 FLH: Read block - Writing: 4096 - Total: 1044480 - Buffer size: 1395
      14:02:52.574 FLH: Read block - Writing: 4096 - Total: 1048576 - Buffer size: 1395
      14:02:52.771 FLH: Read block - Writing: 4096 - Total: 1052672 - Buffer size: 1395
      14:02:52.971 FLH: Read block - Writing: 4096 - Total: 1056768 - Buffer size: 1395
      14:02:53.083 FLH: Read block - Writing: 4096 - Total: 1060864 - Buffer size: 1395
      14:02:53.277 FLH: Read block - Writing: 4096 - Total: 1064960 - Buffer size: 1395
      14:02:53.390 FLH: Read block - Writing: 4096 - Total: 1069056 - Buffer size: 1395
      14:02:53.573 FLH: Read block - Writing: 4096 - Total: 1073152 - Buffer size: 1395
      14:02:53.771 FLH: Read block - Writing: 4096 - Total: 1077248 - Buffer size: 1395
      14:02:53.970 FLH: Read block - Writing: 4096 - Total: 1081344 - Buffer size: 1395
      14:02:54.081 FLH: Read block - Writing: 4096 - Total: 1085440 - Buffer size: 1395
      14:02:54.276 FLH: Read block - Writing: 4096 - Total: 1089536 - Buffer size: 1395
      14:02:54.471 FLH: Read block - Writing: 4096 - Total: 1093632 - Buffer size: 1395
      14:02:54.580 FLH: Read block - Writing: 4096 - Total: 1097728 - Buffer size: 1395
      14:02:54.770 FLH: Read block - Writing: 4096 - Total: 1101824 - Buffer size: 1395
      14:02:54.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "9", "time_elapsed": 46}}
      14:02:54.977 FLH: Read block - Writing: 4096 - Total: 1105920 - Buffer size: 1395
      14:02:55.170 FLH: Read block - Writing: 4096 - Total: 1110016 - Buffer size: 1395
      14:02:55.281 FLH: Read block - Writing: 4096 - Total: 1114112 - Buffer size: 1395
      14:02:55.394 FLH: Read block - Writing: 4096 - Total: 1118208 - Buffer size: 1395
      14:02:55.670 FLH: Read block - Writing: 4096 - Total: 1122304 - Buffer size: 1395
      14:02:55.871 FLH: Read block - Writing: 4096 - Total: 1126400 - Buffer size: 1395
      14:02:56.074 FLH: Read block - Writing: 4096 - Total: 1130496 - Buffer size: 1395
      14:02:56.275 FLH: Read block - Writing: 4096 - Total: 1134592 - Buffer size: 1395
      14:02:56.387 FLH: Read block - Writing: 4096 - Total: 1138688 - Buffer size: 1395
      14:02:56.533 FLH: Read block - Writing: 4096 - Total: 1142784 - Buffer size: 1395
      14:02:56.670 FLH: Read block - Writing: 4096 - Total: 1146880 - Buffer size: 1395
      14:02:56.872 FLH: Read block - Writing: 4096 - Total: 1150976 - Buffer size: 1395
      14:02:57.075 FLH: Read block - Writing: 4096 - Total: 1155072 - Buffer size: 1395
      14:02:57.276 FLH: Read block - Writing: 4096 - Total: 1159168 - Buffer size: 1395
      14:02:57.388 FLH: Read block - Writing: 4096 - Total: 1163264 - Buffer size: 1395
      14:02:57.574 FLH: Read block - Writing: 4096 - Total: 1167360 - Buffer size: 1395
      14:02:57.769 FLH: Read block - Writing: 4096 - Total: 1171456 - Buffer size: 1395
      14:02:57.881 FLH: Read block - Writing: 4096 - Total: 1175552 - Buffer size: 1395
      14:02:58.074 FLH: Read block - Writing: 4096 - Total: 1179648 - Buffer size: 1395
      14:02:58.275 FLH: Read block - Writing: 4096 - Total: 1183744 - Buffer size: 1395
      14:02:58.471 FLH: Read block - Writing: 4096 - Total: 1187840 - Buffer size: 1395
      14:02:58.671 FLH: Read block - Writing: 4096 - Total: 1191936 - Buffer size: 1395
      14:02:58.870 FLH: Read block - Writing: 4096 - Total: 1196032 - Buffer size: 1395
      14:02:59.098 FLH: Read block - Writing: 4096 - Total: 1200128 - Buffer size: 1395
      14:02:59.276 FLH: Read block - Writing: 4096 - Total: 1204224 - Buffer size: 1395
      14:02:59.387 FLH: Read block - Writing: 4096 - Total: 1208320 - Buffer size: 1395
      14:02:59.573 FLH: Read block - Writing: 4096 - Total: 1212416 - Buffer size: 1395
      14:02:59.771 FLH: Read block - Writing: 4096 - Total: 1216512 - Buffer size: 1395
      14:02:59.881 FLH: Read block - Writing: 4096 - Total: 1220608 - Buffer size: 1395
      14:02:59.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "10", "time_elapsed": 51}}
      14:03:00.080 FLH: Read block - Writing: 4096 - Total: 1224704 - Buffer size: 1395
      14:03:00.276 FLH: Read block - Writing: 4096 - Total: 1228800 - Buffer size: 1395
      14:03:00.386 FLH: Read block - Writing: 4096 - Total: 1232896 - Buffer size: 1395
      14:03:00.574 FLH: Read block - Writing: 4096 - Total: 1236992 - Buffer size: 1395
      14:03:00.771 FLH: Read block - Writing: 4096 - Total: 1241088 - Buffer size: 1395
      14:03:00.881 FLH: Read block - Writing: 4096 - Total: 1245184 - Buffer size: 1395
      14:03:01.074 FLH: Read block - Writing: 4096 - Total: 1249280 - Buffer size: 1395
      14:03:01.277 FLH: Read block - Writing: 4096 - Total: 1253376 - Buffer size: 1395
      14:03:01.388 FLH: Read block - Writing: 4096 - Total: 1257472 - Buffer size: 1395
      14:03:01.574 FLH: Read block - Writing: 4096 - Total: 1261568 - Buffer size: 1395
      14:03:01.723 FLH: Read block - Writing: 4096 - Total: 1265664 - Buffer size: 1395
      14:03:01.833 FLH: Read block - Writing: 4096 - Total: 1269760 - Buffer size: 1395
      14:03:01.970 FLH: Read block - Writing: 4096 - Total: 1273856 - Buffer size: 1395
      14:03:02.082 FLH: Read block - Writing: 4096 - Total: 1277952 - Buffer size: 1395
      14:03:02.275 FLH: Read block - Writing: 4096 - Total: 1282048 - Buffer size: 1395
      14:03:02.471 FLH: Read block - Writing: 4096 - Total: 1286144 - Buffer size: 1395
      14:03:02.671 FLH: Read block - Writing: 4096 - Total: 1290240 - Buffer size: 1395
      14:03:02.870 FLH: Read block - Writing: 4096 - Total: 1294336 - Buffer size: 1395
      14:03:03.073 FLH: Read block - Writing: 4096 - Total: 1298432 - Buffer size: 1395
      14:03:03.277 FLH: Read block - Writing: 4096 - Total: 1302528 - Buffer size: 1395
      14:03:03.387 FLH: Read block - Writing: 4096 - Total: 1306624 - Buffer size: 1395
      14:03:03.573 FLH: Read block - Writing: 4096 - Total: 1310720 - Buffer size: 1395
      14:03:03.771 FLH: Read block - Writing: 4096 - Total: 1314816 - Buffer size: 1395
      14:03:03.970 FLH: Read block - Writing: 4096 - Total: 1318912 - Buffer size: 1395
      14:03:04.171 FLH: Read block - Writing: 4096 - Total: 1323008 - Buffer size: 1395
      14:03:04.323 FLH: Read block - Writing: 4096 - Total: 1327104 - Buffer size: 1395
      14:03:04.434 FLH: Read block - Writing: 4096 - Total: 1331200 - Buffer size: 1395
      14:03:04.574 FLH: Read block - Writing: 4096 - Total: 1335296 - Buffer size: 1395
      14:03:04.770 FLH: Read block - Writing: 4096 - Total: 1339392 - Buffer size: 1395
      14:03:04.883 FLH: Read block - Writing: 4096 - Total: 1343488 - Buffer size: 1395
      14:03:04.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "11", "time_elapsed": 56}}
      14:03:05.080 FLH: Read block - Writing: 4096 - Total: 1347584 - Buffer size: 1395
      14:03:05.277 FLH: Read block - Writing: 4096 - Total: 1351680 - Buffer size: 1395
      14:03:05.387 FLH: Read block - Writing: 4096 - Total: 1355776 - Buffer size: 1395
      14:03:05.574 FLH: Read block - Writing: 4096 - Total: 1359872 - Buffer size: 1395
      14:03:05.770 FLH: Read block - Writing: 4096 - Total: 1363968 - Buffer size: 1395
      14:03:05.883 FLH: Read block - Writing: 4096 - Total: 1368064 - Buffer size: 1395
      14:03:06.074 FLH: Read block - Writing: 4096 - Total: 1372160 - Buffer size: 1395
      14:03:06.277 FLH: Read block - Writing: 4096 - Total: 1376256 - Buffer size: 1395
      14:03:06.389 FLH: Read block - Writing: 4096 - Total: 1380352 - Buffer size: 1395
      14:03:06.671 FLH: Read block - Writing: 4096 - Total: 1384448 - Buffer size: 1395
      14:03:06.881 FLH: Read block - Writing: 4096 - Total: 1388544 - Buffer size: 1395
      14:03:07.073 FLH: Read block - Writing: 4096 - Total: 1392640 - Buffer size: 1395
      14:03:07.276 FLH: Read block - Writing: 4096 - Total: 1396736 - Buffer size: 1395
      14:03:07.471 FLH: Read block - Writing: 4096 - Total: 1400832 - Buffer size: 1395
      14:03:07.670 FLH: Read block - Writing: 4096 - Total: 1404928 - Buffer size: 1395
      14:03:07.870 FLH: Read block - Writing: 4096 - Total: 1409024 - Buffer size: 1395
      14:03:08.074 FLH: Read block - Writing: 4096 - Total: 1413120 - Buffer size: 1395
      14:03:08.275 FLH: Read block - Writing: 4096 - Total: 1417216 - Buffer size: 1395
      14:03:08.386 FLH: Read block - Writing: 4096 - Total: 1421312 - Buffer size: 1395
      14:03:08.574 FLH: Read block - Writing: 4096 - Total: 1425408 - Buffer size: 1395
      14:03:08.770 FLH: Read block - Writing: 4096 - Total: 1429504 - Buffer size: 1395
      14:03:08.971 FLH: Read block - Writing: 4096 - Total: 1433600 - Buffer size: 1395
      14:03:09.083 FLH: Read block - Writing: 4096 - Total: 1437696 - Buffer size: 1395
      14:03:09.275 FLH: Read block - Writing: 4096 - Total: 1441792 - Buffer size: 1395
      14:03:09.390 FLH: Read block - Writing: 4096 - Total: 1445888 - Buffer size: 1395
      14:03:09.670 FLH: Read block - Writing: 4096 - Total: 1449984 - Buffer size: 1395
      14:03:09.870 FLH: Read block - Writing: 4096 - Total: 1454080 - Buffer size: 1395
      14:03:10.074 FLH: Read block - Writing: 4096 - Total: 1458176 - Buffer size: 1395
      14:03:10.277 FLH: Read block - Writing: 4096 - Total: 1462272 - Buffer size: 1395
      14:03:10.388 FLH: Read block - Writing: 4096 - Total: 1466368 - Buffer size: 1395
      14:03:10.488 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "12", "time_elapsed": 62}}
      14:03:10.581 FLH: Read block - Writing: 4096 - Total: 1470464 - Buffer size: 1395
      14:03:10.770 FLH: Read block - Writing: 4096 - Total: 1474560 - Buffer size: 1395
      14:03:10.881 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
      14:03:11.074 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
      14:03:11.277 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
      14:03:11.387 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
      14:03:11.574 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
      14:03:11.771 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
      14:03:11.880 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
      14:03:12.099 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
      14:03:12.277 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
      14:03:12.470 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
      14:03:12.670 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
      14:03:12.871 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
      14:03:13.073 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
      14:03:13.276 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
      14:03:13.471 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
      14:03:13.580 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
      14:03:13.770 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
      14:03:13.882 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
      14:03:14.073 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
      14:03:14.277 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
      14:03:14.502 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
      14:03:14.670 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
      14:03:14.871 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
      14:03:15.074 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
      14:03:15.276 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
      14:03:15.471 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
      14:03:15.671 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
      14:03:15.869 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
      14:03:15.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 67}}
      14:03:16.080 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
      14:03:16.277 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
      14:03:16.387 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
      14:03:16.574 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
      14:03:16.771 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
      14:03:16.880 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
      14:03:17.073 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
      14:03:17.277 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
      14:03:17.387 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
      14:03:17.574 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
      14:03:17.771 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
      14:03:17.881 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
      14:03:18.073 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
      14:03:18.276 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
      14:03:18.387 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
      14:03:18.574 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
      14:03:18.771 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
      14:03:18.882 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
      14:03:19.075 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
      14:03:19.276 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
      14:03:19.388 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 1395
      14:04:02.771 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1395
      14:04:02.882 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1395
      14:04:02.987 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 114}}
      14:04:03.080 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1395
      14:04:03.277 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1395
      14:04:03.388 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1395
      14:04:03.573 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1395
      14:04:03.771 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1395
      14:04:03.881 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1395
      14:04:04.073 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1395
      14:04:04.276 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1395
      14:04:04.385 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1395
      14:04:04.572 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1395
      14:04:04.770 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1395
      14:04:04.880 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1395
      14:04:05.074 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1395
      14:04:05.276 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1395
      14:04:05.387 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1395
      14:04:05.573 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1395
      14:04:05.771 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1395
      14:04:05.970 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1395
      14:04:06.171 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1395
      14:04:06.284 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1395
      14:04:06.395 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1395
      14:04:06.574 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1395
      14:04:06.770 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1395
      14:04:06.881 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1395
      14:04:07.074 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1395
      14:04:07.277 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1395
      14:04:07.389 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1395
      14:04:07.575 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1395
      14:04:07.740 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1395
      14:04:07.782 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 119}}
      14:04:07.875 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1395
      14:04:08.074 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1395
      14:04:08.276 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1395
      14:04:08.388 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1395
      14:04:08.671 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1395
      14:04:08.871 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1395
      14:04:09.073 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1395
      14:04:09.276 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1395
      14:04:09.471 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1395
      14:04:09.670 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1395
      14:04:09.870 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1395
      14:04:10.074 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1395
      14:04:10.276 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1395
      14:04:10.426 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1395
      14:04:10.576 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1395
      14:04:10.770 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1395
      14:04:10.971 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1395
      14:04:11.084 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1395
      14:04:11.275 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1395
      14:04:11.471 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1395
      14:04:11.671 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1395
      14:04:11.870 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1395
      14:04:12.074 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1395
      14:04:12.277 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1395
      14:04:12.388 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1395
      14:04:12.574 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1395
      14:04:12.771 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1395
      14:04:12.881 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1395
      14:04:13.029 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1395
      14:04:13.176 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1395
      14:04:13.283 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 124}}
      14:04:13.376 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1395
      14:04:13.573 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1395
      14:04:13.771 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1395
      14:04:13.880 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1395
      14:04:14.072 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1395
      14:04:14.277 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1395
      14:04:14.470 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1395
      14:04:14.670 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1395
      14:04:14.871 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1395
      14:04:15.073 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1395
      14:04:15.276 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1395
      14:04:15.471 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1395
      14:04:15.582 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1395
      14:04:15.771 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1395
      14:04:15.971 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1395
      14:04:16.083 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1395
      14:04:16.277 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1395
      14:04:16.389 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1395
      14:04:16.573 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1395
      14:04:16.771 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1395
      14:04:16.971 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1395
      14:04:17.081 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1395
      14:04:17.372 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1395
      14:04:17.574 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1395
      14:04:17.769 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1395
      14:04:18.000 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1395
      14:04:18.177 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1395
      14:04:18.370 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1395
      14:04:18.573 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1395
      14:04:18.771 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1395
      14:04:18.883 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 130}}
      14:04:18.976 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1395
      14:04:19.170 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1395
      14:04:19.284 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1395
      14:04:19.394 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1395
      14:04:19.574 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1395
      14:04:19.771 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1395
      14:04:19.970 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1395
      14:04:20.084 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1395
      14:04:20.372 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1395
      14:04:20.573 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1395
      14:04:20.771 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1395
      14:04:20.884 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1395
      14:04:21.073 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1395
      14:04:21.277 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1395
      14:04:21.470 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1395
      14:04:21.579 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1395
      14:04:21.770 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1395
      14:04:21.882 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1395
      14:04:22.073 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1395
      14:04:22.277 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1395
      14:04:22.388 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1395
      14:04:22.572 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1395
      14:04:22.770 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1395
      14:04:22.970 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1395
      14:04:23.170 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1395
      14:04:23.282 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1395
      14:04:23.471 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1395
      14:04:23.581 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1395
      14:04:23.770 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1395
      14:04:23.971 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1395
      14:04:23.996 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 135}}
      14:04:24.088 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1395
      14:04:24.276 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1395
      14:04:24.388 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1395
      14:04:24.571 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1395
      14:04:24.770 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1395
      14:04:24.882 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1395
      14:04:25.074 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1395
      14:04:25.276 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1395
      14:04:25.429 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1395
      14:04:25.572 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1395
      14:04:25.870 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1395
      14:04:26.073 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1395
      14:04:26.276 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1395
      14:04:26.387 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1395
      14:04:26.574 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1395
      14:04:26.770 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1395
      14:04:26.971 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1395
      14:04:27.171 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1395
      14:04:27.282 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1395
      14:04:27.393 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1395
      14:04:27.574 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1395
      14:04:27.770 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1395
      14:04:27.919 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1395
      14:04:28.074 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1395
      14:04:28.275 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1395
      14:04:28.386 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1395
      14:04:28.671 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1395
      14:04:28.870 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1395
      14:04:29.074 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1395
      14:04:29.278 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1395
      14:04:29.303 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 141}}
      14:05:21.573 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1395
      14:05:21.770 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1395
      14:05:21.884 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1395
      14:05:22.094 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1395
      14:05:22.276 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1395
      14:05:22.389 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1395
      14:05:22.573 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1395
      14:05:22.771 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1395
      14:05:22.882 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1395
      14:05:23.073 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1395
      14:05:23.276 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1395
      14:05:23.388 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1395
      14:05:23.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 195}}
      14:05:23.578 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1395
      14:05:23.770 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1395
      14:05:23.970 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1395
      14:05:24.769 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1395
      14:05:24.971 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1395
      14:05:25.171 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1395
      14:05:25.282 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1395
      14:05:25.470 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1395
      14:05:25.671 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1395
      14:05:25.869 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1395
      14:05:26.074 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1395
      14:05:26.277 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1395
      14:05:26.388 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1395
      14:05:26.574 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1395
      14:05:26.771 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1395
      14:05:26.881 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1395
      14:05:27.073 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1395
      14:05:27.220 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1395
      14:05:27.334 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1395
      14:05:28.170 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1395
      14:05:28.282 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1395
      14:05:28.392 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1395
      14:05:28.570 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1395
      14:05:28.772 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1395
      14:05:28.882 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 311
      14:05:29.074 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 311
      14:05:29.276 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 311
      14:05:29.387 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 311
      14:05:29.573 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 311
      14:05:29.771 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 311
      14:05:29.884 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 201}}
      14:05:29.976 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 311
      14:05:30.088 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 311
      14:05:30.275 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 311
      14:05:30.470 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 311
      14:05:30.670 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 311
      14:05:31.470 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 311
      14:05:31.670 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 311
      14:05:31.869 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 311
      14:05:32.071 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 311
      14:05:32.275 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 311
      14:05:32.386 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 311
      14:05:32.573 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 311
      14:05:32.769 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 311
      14:05:32.969 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 311
      14:05:33.080 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 311
      14:05:33.275 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 311
      14:05:33.469 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 311
      14:05:33.670 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 311
      14:05:33.870 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 311
      14:05:34.072 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 311
      14:05:34.276 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 311
      14:05:35.074 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 311
      14:05:35.276 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 311
      14:05:35.388 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 311
      14:05:35.573 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 311
      14:05:35.769 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 311
      14:05:35.970 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 311
      14:05:36.170 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 311
      14:05:36.281 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 311
      14:05:36.392 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 311
      14:05:36.486 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 208}}
      14:05:36.579 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 311
      14:05:36.769 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 311
      14:05:36.970 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 311
      14:05:37.487 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 2607
      14:05:38.106 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 2819
      14:05:38.218 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 2819
      14:05:38.330 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 2819
      mich macht diese Zeile unrund, die kommt immer:
      T teletapi 2 Replies Last reply Reply Quote 0
        TT-Tom @australien last edited by
        @australien
        so sieht es bei mir aus
        zeige mal die komplette Info von Tasmota.
        • Armilar
          Armilar Most Active Forum Testing last edited by
          @australien sagte in SONOFF NSPanel mit Lovelace UI:
          Wirf da mal alles raus (auch mal unter versteckte Dateien nachsehen) bis nur noch die autoexec.be drin ist...
          Mit der nspanel.be hast du 2 unterschiedliche Berry Driver... Der muss auf alle Fälle weg...
          Danach noch mal rebooten... und nochmal mit der Adv0 oder/und Adv2 versuchen...
          A 1 Reply Last reply Reply Quote 2
            australien @TT-Tom last edited by
            @tt-tom
            NSPanel
            Tasmota
            Informationen
            Tasmota Version	15.0.1 (release-tasmota32)
            Erstellt	2025.06.14 10:39:16
            Core-/SDK-Version	3_1_3/5.3.3.250501
            Laufzeit	0T01:05:34
            Schreibzyklen	1509
            Startvorgänge	165
            Grund für Neustart	Vbat power on reset
            Friendly Name 1	Tasmota
            Friendly Name 2
            AP1 Informationen	SSID FR@smart
            RSSI 92%, -54 dBm
            Mode HT40
            Kanal 9
            BSSID 7E:8A:20:51:6B:CA
            Hostname	NSPanel-1-5140
            IPv6 Local (WiFi)	fe80::e2e2:e6ff:fe0c:1414%st1
            MAC-Adresse	E0:E2:E6:0C:14:14
            IP-Adresse (WiFi)	10.68.0.179
            Gateway	10.68.0.1
            Subnetzmaske	255.255.0.0
            DNS-Server1	10.68.0.1
            DNS-Server2	0.0.0.0
            HTTP API	aktiviert
            Host	10.68.10.11
            Port	1886
            MQTT TLS	deaktiviert
            Benutzer	iobroker
            Client	NSPanel_1
            Topic	NSPanel_1
            Group Topic 1	SmartHome/tasmotas/cmnd/
            Full Topic	SmartHome/NSPanel_1/cmnd/
            MQTT Fallback-Topic	cmnd/NSPanel_1_fb/
            No Retain	deaktiviert
            Emulation	keine
            mDNS-Erkennung	deaktiviert
            ESP Chip ID	791572 (ESP32-D0WD-V3 v3.0)
            Flash Chip ID	0x16405E (DIO)
            Größe Flash-Chip	4096 KB
            Flash nutzbar	4096 KB
            Programmgröße	2045 KB
            Flash frei	834 KB
            Freier Arbeitsspeicher	132,5 KB (frag․ 16%)
            Partition safeboot	832 KB (genutzt 96%)
            Partition app0*	2880 KB (genutzt 71%)
            Partition fs	320 KB
            Tasmota 15.0.1 (release-tasmota32) von Theo Arends
              australien @Armilar last edited by
              @armilar
              alles draussen, so schaut es nach dem reboot aus:
              die Fehlermeldung ist weg, nur ist es immer noch das gleiche, geht bis 39%
              hier das log (geküzt mit ...) mit Adv2, die Blockgrössen sind unterschiedlich
              00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
              00:00:00.038 UFS: FlashFS mounted with 292 kB free
              00:00:00.053 CFG: Loaded from NVS, Anzahl 1512
              00:00:00.062 QPC: Count 1
              00:00:00.062 CFG: CR 430/699, Busy 0
              00:00:00.067 TYA: Active=0
              00:00:00.072 ROT: Mode 1
              00:00:00.105 CFG: No '*.autoconf' file found
              00:00:00.110 BRY: Berry initialized, RAM used 3493 bytes
              00:00:00.119 BRY: No 'preinit.be'
              00:00:00.121 SRC: Restart
              00:00:00.125 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
              00:00:00.324 NXP: Initializing Driver
              00:00:00.326 BRY: Serial UART2
              00:00:00.329 BRY: Successfully loaded 'autoexec.be'
              00:00:00.484 WIF: Verbindungsversuch…
              00:00:01.060 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
              00:00:02.069 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
              00:00:03.623 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
              00:00:03.644 WIF: verbunden
              00:00:03.901 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
              00:00:03.967 RTC: UTC 2025-09-12T14:20:54Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
              15:20:54.000 RTC: Synced by NTP
              15:20:54.895 MQT: Verbindungsversuch…
              15:20:54.915 MQT: verbunden
              15:20:54.918 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
              15:20:54.919 MQT: SmartHome/NSPanel_1/cmnd/POWER =
              15:20:54.920 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
              15:20:54.921 MQT: abonniere SmartHome/tasmotas/cmnd/#
              15:20:54.922 MQT: abonniere cmnd/NSPanel_1_fb/#
              15:20:54.924 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
              15:20:54.938 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
              15:20:54.962 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":169}}
              15:20:54.967 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
              15:20:54.978 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
              15:20:54.980 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
              15:20:54.981 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
              15:20:55.195 SRC: MQTT
              15:20:55.196 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
              15:20:55.206 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
              15:20:55.211 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
              15:20:55.244 SRC: MQTT
              15:20:55.245 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
              15:20:55.247 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
              15:20:55.248 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
              15:20:55.295 SRC: MQTT
              15:20:55.296 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
              15:20:55.306 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
              15:20:55.310 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
              15:20:55.344 SRC: MQTT
              15:20:55.345 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
              15:20:55.348 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
              15:20:55.352 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
              15:20:55.394 SRC: MQTT
              15:20:55.395 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
              15:20:55.405 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
              15:20:55.410 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
              15:20:55.444 SRC: MQTT
              15:20:55.445 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
              15:20:55.448 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
              15:20:55.452 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
              15:20:56.945 SRC: MQTT
              15:20:56.946 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
              15:20:56.960 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
              15:20:56.963 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
              15:20:56.995 SRC: MQTT
              15:20:56.995 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
              15:20:56.997 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
              15:20:56.998 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
              15:20:57.133 HTP: Hauptmenü
              15:20:57.929 QPC: Reset
              15:20:58.447 HTP: Werkzeuge
              15:20:58.929 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:20:58","Uptime":"0T00:00:08","UptimeSec":8,"Heap":146,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":241,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":80,"Signal":-60,"LinkCount":1,"Downtime":"0T00:00:03"}}
              15:20:58.972 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:20:58","ANALOG":{"Temperature1":28.0},"ESP32":{"Temperature":59.4},"TempUnit":"C"}
              15:20:59.922 APP: Startvorgänge 169
              15:21:00.102 HTP: Dateisystem verwalten
              15:21:00.103 UFS: File '/' download
              15:21:00.119 UFS: File '/' to download is directory
              15:21:00.646 CFG: Saved, Anzahl 1513, Bytes 4096
              15:21:29.565 HTP: Werkzeuge
              15:21:31.132 HTP: Konsole
              15:21:36.302 CMD: FlashNextionAdv2 http://nspanel.de/nspanel-v5.0.0.tft
              15:21:36.303 SRC: WebConsole from 10.68.0.156
              15:21:36.304 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 2, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
              15:21:36.312 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
              15:21:36.337 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
              15:21:36.411 FLH: Connected:true
              15:21:36.514 FLH: Retry 2
              15:21:36.727 FLH: HTTP Respose is 200 OK or 206 Partial Content
              15:21:36.728 FLH: Flash file size: 12197684
              15:21:36.729 SRC: Berry
              15:21:36.730 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
              15:21:36.735 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
              15:21:36.740 SRC: Berry
              15:21:36.741 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
              15:21:36.746 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
              15:21:36.762 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
              15:21:36.764 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
              15:21:36.766 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
              15:21:36.772 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
              15:21:36.892 FLH: Send (High Speed) flash start
              15:21:36.898 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3131353230302C72657330FFFF...')
              15:21:37.279 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
              15:21:37.625 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
              15:21:37.739 FLH: Waiting offset...
              15:21:42.538 FLH: Flash offset marker 0
              15:21:42.891 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
              15:21:43.359 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
              15:21:43.827 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
              15:21:44.216 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
              15:21:44.685 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
              15:21:45.156 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
              15:21:45.622 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
              15:21:46.085 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
              15:21:46.605 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 3107
              15:21:47.493 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 643
              15:21:47.959 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 643
              15:21:48.425 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 643
              15:21:48.889 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 643
              15:21:49.357 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 643
              15:21:49.746 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 643
              15:21:50.211 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 643
              15:21:50.683 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 643
              15:21:51.148 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 643
              15:21:51.615 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 643
              15:21:52.082 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 643
              15:21:52.551 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 643
              15:21:53.020 FLH: Read block - Writing: 4096 - Total: 94208 - Buffer size: 643
              15:21:53.418 FLH: Read block - Writing: 4096 - Total: 98304 - Buffer size: 643
              15:21:53.883 FLH: Read block - Writing: 4096 - Total: 102400 - Buffer size: 643
              15:21:54.355 FLH: Read block - Writing: 4096 - Total: 106496 - Buffer size: 643
              15:21:54.819 FLH: Read block - Writing: 4096 - Total: 110592 - Buffer size: 643
              15:21:55.284 FLH: Read block - Writing: 4096 - Total: 114688 - Buffer size: 643
              15:21:55.749 FLH: Read block - Writing: 4096 - Total: 118784 - Buffer size: 643
              15:21:56.139 FLH: Read block - Writing: 4096 - Total: 122880 - Buffer size: 643
              15:21:56.267 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "1", "time_elapsed": 19}}
              15:21:56.614 FLH: Read block - Writing: 4096 - Total: 126976 - Buffer size: 643
              15:21:57.079 FLH: Read block - Writing: 4096 - Total: 131072 - Buffer size: 643
              15:21:57.546 FLH: Read block - Writing: 4096 - Total: 135168 - Buffer size: 643
              15:21:58.017 FLH: Read block - Writing: 4096 - Total: 139264 - Buffer size: 643
              15:21:58.485 FLH: Read block - Writing: 4096 - Total: 143360 - Buffer size: 643
              15:21:58.881 FLH: Read block - Writing: 4096 - Total: 147456 - Buffer size: 643
              15:21:59.352 FLH: Read block - Writing: 4096 - Total: 151552 - Buffer size: 643
              15:21:59.815 FLH: Read block - Writing: 4096 - Total: 155648 - Buffer size: 643
              15:22:00.281 FLH: Read block - Writing: 4096 - Total: 159744 - Buffer size: 643
              15:22:00.747 FLH: Read block - Writing: 4096 - Total: 163840 - Buffer size: 643
              15:22:01.211 FLH: Read block - Writing: 4096 - Total: 167936 - Buffer size: 643
              15:22:01.601 FLH: Read block - Writing: 4096 - Total: 172032 - Buffer size: 643
              15:22:02.069 FLH: Read block - Writing: 4096 - Total: 176128 - Buffer size: 643
              15:22:02.537 FLH: Read block - Writing: 4096 - Total: 180224 - Buffer size: 643
              15:22:03.006 FLH: Read block - Writing: 4096 - Total: 184320 - Buffer size: 643
              15:22:03.472 FLH: Read block - Writing: 4096 - Total: 188416 - Buffer size: 643
              15:22:03.937 FLH: Read block - Writing: 4096 - Total: 192512 - Buffer size: 643
              15:22:04.690 FLH: Read block - Writing: 4096 - Total: 196608 - Buffer size: 3967
              15:22:05.156 FLH: Read block - Writing: 4096 - Total: 200704 - Buffer size: 3967
              15:22:05.625 FLH: Read block - Writing: 4096 - Total: 204800 - Buffer size: 3967
              15:22:06.092 FLH: Read block - Writing: 4096 - Total: 208896 - Buffer size: 3967
              15:22:06.561 FLH: Read block - Writing: 4096 - Total: 212992 - Buffer size: 3967
              15:22:06.949 FLH: Read block - Writing: 4096 - Total: 217088 - Buffer size: 3967
              15:22:07.417 FLH: Read block - Writing: 4096 - Total: 221184 - Buffer size: 3967
              15:22:07.884 FLH: Read block - Writing: 4096 - Total: 225280 - Buffer size: 3967
              15:22:08.355 FLH: Read block - Writing: 4096 - Total: 229376 - Buffer size: 3967
              15:22:08.820 FLH: Read block - Writing: 4096 - Total: 233472 - Buffer size: 3967
              15:22:09.285 FLH: Read block - Writing: 4096 - Total: 237568 - Buffer size: 3967
              15:22:09.679 FLH: Read block - Writing: 4096 - Total: 241664 - Buffer size: 3967
              15:22:10.145 FLH: Read block - Writing: 4096 - Total: 245760 - Buffer size: 3967
              15:22:10.274 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "2", "time_elapsed": 33}}
              15:22:10.619 FLH: Read block - Writing: 4096 - Total: 249856 - Buffer size: 3967
              15:22:11.088 FLH: Read block - Writing: 4096 - Total: 253952 - Buffer size: 3967
              15:22:11.555 FLH: Read block - Writing: 4096 - Total: 258048 - Buffer size: 3967
              15:22:12.027 FLH: Read block - Writing: 4096 - Total: 262144 - Buffer size: 3967
              15:22:12.421 FLH: Read block - Writing: 4096 - Total: 266240 - Buffer size: 2055
              15:22:12.885 FLH: Read block - Writing: 4096 - Total: 270336 - Buffer size: 2055
              15:22:13.358 FLH: Read block - Writing: 4096 - Total: 274432 - Buffer size: 2055
              15:22:13.822 FLH: Read block - Writing: 4096 - Total: 278528 - Buffer size: 2055
              15:22:14.288 FLH: Read block - Writing: 4096 - Total: 282624 - Buffer size: 2055
              15:22:14.755 FLH: Read block - Writing: 4096 - Total: 286720 - Buffer size: 2055
              15:22:15.142 FLH: Read block - Writing: 4096 - Total: 290816 - Buffer size: 2055
              15:22:15.609 FLH: Read block - Writing: 4096 - Total: 294912 - Buffer size: 2055
              15:22:16.074 FLH: Read block - Writing: 4096 - Total: 299008 - Buffer size: 2055
              15:22:16.541 FLH: Read block - Writing: 4096 - Total: 303104 - Buffer size: 2055
              15:22:17.015 FLH: Read block - Writing: 4096 - Total: 307200 - Buffer size: 2055
              15:22:17.483 FLH: Read block - Writing: 4096 - Total: 311296 - Buffer size: 2055
              15:22:17.873 FLH: Read block - Writing: 4096 - Total: 315392 - Buffer size: 2055
              15:22:18.341 FLH: Read block - Writing: 4096 - Total: 319488 - Buffer size: 2055
              15:22:18.804 FLH: Read block - Writing: 4096 - Total: 323584 - Buffer size: 2055
              15:22:19.269 FLH: Read block - Writing: 4096 - Total: 327680 - Buffer size: 2055
              15:22:19.737 FLH: Read block - Writing: 4096 - Total: 331776 - Buffer size: 2055
              15:22:20.202 FLH: Read block - Writing: 4096 - Total: 335872 - Buffer size: 2055
              15:22:20.595 FLH: Read block - Writing: 4096 - Total: 339968 - Buffer size: 2055
              15:22:21.059 FLH: Read block - Writing: 4096 - Total: 344064 - Buffer size: 2055
              15:22:21.527 FLH: Read block - Writing: 4096 - Total: 348160 - Buffer size: 2055
              15:22:21.998 FLH: Read block - Writing: 4096 - Total: 352256 - Buffer size: 2055
              15:22:22.463 FLH: Read block - Writing: 4096 - Total: 356352 - Buffer size: 2055
              15:22:22.930 FLH: Read block - Writing: 4096 - Total: 360448 - Buffer size: 2055
              15:22:23.323 FLH: Read block - Writing: 4096 - Total: 364544 - Buffer size: 2055
              15:22:23.789 FLH: Read block - Writing: 4096 - Total: 368640 - Buffer size: 2055
              15:22:23.914 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "3", "time_elapsed": 47}}
              15:22:24.260 FLH: Read block - Writing: 4096 - Total: 372736 - Buffer size: 2055
              15:22:24.730 FLH: Read block - Writing: 4096 - Total: 376832 - Buffer size: 2055
              15:22:25.197 FLH: Read block - Writing: 4096 - Total: 380928 - Buffer size: 2055
              15:22:25.670 FLH: Read block - Writing: 4096 - Total: 385024 - Buffer size: 2055
              15:22:26.066 FLH: Read block - Writing: 4096 - Total: 389120 - Buffer size: 2055
              15:22:26.534 FLH: Read block - Writing: 4096 - Total: 393216 - Buffer size: 2055
              15:22:27.005 FLH: Read block - Writing: 4096 - Total: 397312 - Buffer size: 2055
              15:22:27.472 FLH: Read block - Writing: 4096 - Total: 401408 - Buffer size: 2055
              15:22:27.938 FLH: Read block - Writing: 4096 - Total: 405504 - Buffer size: 2055
              15:22:28.407 FLH: Read block - Writing: 4096 - Total: 409600 - Buffer size: 2055
              15:22:28.922 FLH: Read block - Writing: 4096 - Total: 413696 - Buffer size: 1055
              15:22:29.396 FLH: Read block - Writing: 4096 - Total: 417792 - Buffer size: 1055
              15:22:29.862 FLH: Read block - Writing: 4096 - Total: 421888 - Buffer size: 1055
              15:22:30.326 FLH: Read block - Writing: 4096 - Total: 425984 - Buffer size: 1055
              15:22:30.792 FLH: Read block - Writing: 4096 - Total: 430080 - Buffer size: 1055
              15:22:31.254 FLH: Read block - Writing: 4096 - Total: 434176 - Buffer size: 1055
              15:22:31.729 FLH: Read block - Writing: 4096 - Total: 438272 - Buffer size: 1055
              15:22:32.192 FLH: Read block - Writing: 4096 - Total: 442368 - Buffer size: 1055
              15:22:32.661 FLH: Read block - Writing: 4096 - Total: 446464 - Buffer size: 1055
              15:22:33.125 FLH: Read block - Writing: 4096 - Total: 450560 - Buffer size: 1055
              15:22:33.595 FLH: Read block - Writing: 4096 - Total: 454656 - Buffer size: 1055
              15:22:33.981 FLH: Read block - Writing: 4096 - Total: 458752 - Buffer size: 1055
              15:22:34.453 FLH: Read block - Writing: 4096 - Total: 462848 - Buffer size: 1055
              15:22:34.918 FLH: Read block - Writing: 4096 - Total: 466944 - Buffer size: 939
              15:22:35.943 FLH: Read block - Writing: 4096 - Total: 471040 - Buffer size: 2375
              15:22:36.412 FLH: Read block - Writing: 4096 - Total: 475136 - Buffer size: 2375
              15:22:36.800 FLH: Read block - Writing: 4096 - Total: 479232 - Buffer size: 2375
              15:22:37.272 FLH: Read block - Writing: 4096 - Total: 483328 - Buffer size: 2375
              15:22:37.738 FLH: Read block - Writing: 4096 - Total: 487424 - Buffer size: 2375
              15:22:38.204 FLH: Read block - Writing: 4096 - Total: 491520 - Buffer size: 2375
              15:22:38.332 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "4", "time_elapsed": 61}}
              15:22:38.677 FLH: Read block - Writing: 4096 - Total: 495616 - Buffer size: 2375
              15:22:39.141 FLH: Read block - Writing: 4096 - Total: 499712 - Buffer size: 2375
              15:22:39.538 FLH: Read block - Writing: 4096 - Total: 503808 - Buffer size: 2375
              15:22:40.004 FLH: Read block - Writing: 4096 - Total: 507904 - Buffer size: 2375
              15:22:40.473 FLH: Read block - Writing: 4096 - Total: 512000 - Buffer size: 2375
              15:22:40.944 FLH: Read block - Writing: 4096 - Total: 516096 - Buffer size: 2375
              15:22:41.412 FLH: Read block - Writing: 4096 - Total: 520192 - Buffer size: 2375
              15:22:41.877 FLH: Read block - Writing: 4096 - Total: 524288 - Buffer size: 2375
              15:22:42.270 FLH: Read block - Writing: 4096 - Total: 528384 - Buffer size: 2375
              15:22:42.739 FLH: Read block - Writing: 4096 - Total: 532480 - Buffer size: 2375
              15:22:43.204 FLH: Read block - Writing: 4096 - Total: 536576 - Buffer size: 2375
              15:22:43.672 FLH: Read block - Writing: 4096 - Total: 540672 - Buffer size: 2375
              15:22:44.137 FLH: Read block - Writing: 4096 - Total: 544768 - Buffer size: 2375
              15:22:44.609 FLH: Read block - Writing: 4096 - Total: 548864 - Buffer size: 2375
              15:22:44.997 FLH: Read block - Writing: 4096 - Total: 552960 - Buffer size: 2375
              15:22:45.467 FLH: Read block - Writing: 4096 - Total: 557056 - Buffer size: 2375
              15:22:45.938 FLH: Read block - Writing: 4096 - Total: 561152 - Buffer size: 2375
              15:22:46.406 FLH: Read block - Writing: 4096 - Total: 565248 - Buffer size: 2375
              15:22:46.871 FLH: Read block - Writing: 4096 - Total: 569344 - Buffer size: 2375
              15:22:47.336 FLH: Read block - Writing: 4096 - Total: 573440 - Buffer size: 2375
              15:22:47.723 FLH: Read block - Writing: 4096 - Total: 577536 - Buffer size: 2375
              15:22:48.188 FLH: Read block - Writing: 4096 - Total: 581632 - Buffer size: 2375
              15:22:48.657 FLH: Read block - Writing: 4096 - Total: 585728 - Buffer size: 2375
              15:22:49.123 FLH: Read block - Writing: 4096 - Total: 589824 - Buffer size: 2375
              15:22:49.594 FLH: Read block - Writing: 4096 - Total: 593920 - Buffer size: 2375
              15:22:50.060 FLH: Read block - Writing: 4096 - Total: 598016 - Buffer size: 2375
              15:22:50.452 FLH: Read block - Writing: 4096 - Total: 602112 - Buffer size: 2375
              15:22:50.922 FLH: Read block - Writing: 4096 - Total: 606208 - Buffer size: 2375
              15:22:51.390 FLH: Read block - Writing: 4096 - Total: 610304 - Buffer size: 2375
              15:22:51.516 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "5", "time_elapsed": 74}}
              15:22:51.861 FLH: Read block - Writing: 4096 - Total: 614400 - Buffer size: 2375
              15:22:52.328 FLH: Read block - Writing: 4096 - Total: 618496 - Buffer size: 2375
              15:22:52.793 FLH: Read block - Writing: 4096 - Total: 622592 - Buffer size: 2375
              15:22:53.186 FLH: Read block - Writing: 4096 - Total: 626688 - Buffer size: 2375
              15:22:53.655 FLH: Read block - Writing: 4096 - Total: 630784 - Buffer size: 2375
              15:22:54.120 FLH: Read block - Writing: 4096 - Total: 634880 - Buffer size: 2375
              15:22:54.593 FLH: Read block - Writing: 4096 - Total: 638976 - Buffer size: 2375
              15:22:55.058 FLH: Read block - Writing: 4096 - Total: 643072 - Buffer size: 2375
              15:22:55.528 FLH: Read block - Writing: 4096 - Total: 647168 - Buffer size: 2375
              15:22:55.921 FLH: Read block - Writing: 4096 - Total: 651264 - Buffer size: 2375
              15:22:56.388 FLH: Read block - Writing: 4096 - Total: 655360 - Buffer size: 2375
              15:22:56.854 FLH: Read block - Writing: 4096 - Total: 659456 - Buffer size: 2375
              15:22:57.319 FLH: Read block - Writing: 4096 - Total: 663552 - Buffer size: 2375
              15:22:57.785 FLH: Read block - Writing: 4096 - Total: 667648 - Buffer size: 2375
              15:22:58.258 FLH: Read block - Writing: 4096 - Total: 671744 - Buffer size: 2375
              15:22:58.653 FLH: Read block - Writing: 4096 - Total: 675840 - Buffer size: 2375
              15:22:59.119 FLH: Read block - Writing: 4096 - Total: 679936 - Buffer size: 2375
              15:22:59.590 FLH: Read block - Writing: 4096 - Total: 684032 - Buffer size: 2375
              15:23:00.058 FLH: Read block - Writing: 4096 - Total: 688128 - Buffer size: 2375
              15:23:00.524 FLH: Read block - Writing: 4096 - Total: 692224 - Buffer size: 2375
              15:23:00.990 FLH: Read block - Writing: 4096 - Total: 696320 - Buffer size: 2375
              15:23:01.376 FLH: Read block - Writing: 4096 - Total: 700416 - Buffer size: 2375
              15:23:01.842 FLH: Read block - Writing: 4096 - Total: 704512 - Buffer size: 2375
              15:23:02.307 FLH: Read block - Writing: 4096 - Total: 708608 - Buffer size: 2375
              15:23:02.773 FLH: Read block - Writing: 4096 - Total: 712704 - Buffer size: 2375
              15:23:03.243 FLH: Read block - Writing: 4096 - Total: 716800 - Buffer size: 2375
              15:23:03.710 FLH: Read block - Writing: 4096 - Total: 720896 - Buffer size: 2375
              15:23:04.098 FLH: Read block - Writing: 4096 - Total: 724992 - Buffer size: 2375
              15:23:04.572 FLH: Read block - Writing: 4096 - Total: 729088 - Buffer size: 2375
              15:23:05.035 FLH: Read block - Writing: 4096 - Total: 733184 - Buffer size: 2375
              15:23:05.162 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "6", "time_elapsed": 88}}
              15:23:05.507 FLH: Read block - Writing: 4096 - Total: 737280 - Buffer size: 2375
              15:23:05.976 FLH: Read block - Writing: 4096 - Total: 741376 - Buffer size: 2375
              15:23:06.444 FLH: Read block - Writing: 4096 - Total: 745472 - Buffer size: 2375
              15:23:06.840 FLH: Read block - Writing: 4096 - Total: 749568 - Buffer size: 2375
              15:23:07.305 FLH: Read block - Writing: 4096 - Total: 753664 - Buffer size: 2375
              15:23:07.773 FLH: Read block - Writing: 4096 - Total: 757760 - Buffer size: 2375
              15:23:08.244 FLH: Read block - Writing: 4096 - Total: 761856 - Buffer size: 2375
              15:23:08.712 FLH: Read block - Writing: 4096 - Total: 765952 - Buffer size: 2375
              15:23:09.177 FLH: Read block - Writing: 4096 - Total: 770048 - Buffer size: 2375
              15:23:09.572 FLH: Read block - Writing: 4096 - Total: 774144 - Buffer size: 2375
              15:23:10.035 FLH: Read block - Writing: 4096 - Total: 778240 - Buffer size: 2375
              15:23:10.503 FLH: Read block - Writing: 4096 - Total: 782336 - Buffer size: 2375
              15:23:10.970 FLH: Read block - Writing: 4096 - Total: 786432 - Buffer size: 2375
              15:23:11.438 FLH: Read block - Writing: 4096 - Total: 790528 - Buffer size: 2375
              15:23:11.909 FLH: Read block - Writing: 4096 - Total: 794624 - Buffer size: 2375
              15:23:12.301 FLH: Read block - Writing: 4096 - Total: 798720 - Buffer size: 2375
              15:23:12.770 FLH: Read block - Writing: 4096 - Total: 802816 - Buffer size: 2375
              15:23:13.240 FLH: Read block - Writing: 4096 - Total: 806912 - Buffer size: 2375
              15:23:13.707 FLH: Read block - Writing: 4096 - Total: 811008 - Buffer size: 2375
              15:23:14.172 FLH: Read block - Writing: 4096 - Total: 815104 - Buffer size: 2375
              15:23:14.643 FLH: Read block - Writing: 4096 - Total: 819200 - Buffer size: 2375
              15:23:15.033 FLH: Read block - Writing: 4096 - Total: 823296 - Buffer size: 2375
              15:23:15.500 FLH: Read block - Writing: 4096 - Total: 827392 - Buffer size: 2375
              15:23:15.967 FLH: Read block - Writing: 4096 - Total: 831488 - Buffer size: 2375
              15:23:16.435 FLH: Read block - Writing: 4096 - Total: 835584 - Buffer size: 2375
              15:23:16.906 FLH: Read block - Writing: 4096 - Total: 839680 - Buffer size: 2375
              15:23:17.373 FLH: Read block - Writing: 4096 - Total: 843776 - Buffer size: 2375
              15:23:17.762 FLH: Read block - Writing: 4096 - Total: 847872 - Buffer size: 2375
              15:23:18.230 FLH: Read block - Writing: 4096 - Total: 851968 - Buffer size: 2375
              15:23:18.699 FLH: Read block - Writing: 4096 - Total: 856064 - Buffer size: 2375
              15:23:18.823 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "7", "time_elapsed": 101}}
              15:23:19.169 FLH: Read block - Writing: 4096 - Total: 860160 - Buffer size: 2375
              15:23:19.639 FLH: Read block - Writing: 4096 - Total: 864256 - Buffer size: 2375
              15:23:20.105 FLH: Read block - Writing: 4096 - Total: 868352 - Buffer size: 2375
              15:23:20.502 FLH: Read block - Writing: 4096 - Total: 872448 - Buffer size: 2375
              15:23:20.969 FLH: Read block - Writing: 4096 - Total: 876544 - Buffer size: 2375
              15:23:21.438 FLH: Read block - Writing: 4096 - Total: 880640 - Buffer size: 2375
              15:23:21.908 FLH: Read block - Writing: 4096 - Total: 884736 - Buffer size: 2375
              15:23:22.371 FLH: Read block - Writing: 4096 - Total: 888832 - Buffer size: 2375
              15:23:22.832 FLH: Read block - Writing: 4096 - Total: 892928 - Buffer size: 27
              15:23:23.228 FLH: Read block - Writing: 4096 - Total: 897024 - Buffer size: 27
              15:23:23.698 FLH: Read block - Writing: 4096 - Total: 901120 - Buffer size: 27
              15:23:24.162 FLH: Read block - Writing: 4096 - Total: 905216 - Buffer size: 27
              15:23:24.630 FLH: Read block - Writing: 4096 - Total: 909312 - Buffer size: 27
              15:23:25.094 FLH: Read block - Writing: 4096 - Total: 913408 - Buffer size: 27
              15:23:25.564 FLH: Read block - Writing: 4096 - Total: 917504 - Buffer size: 27
              15:23:25.953 FLH: Read block - Writing: 4096 - Total: 921600 - Buffer size: 27
              15:23:26.420 FLH: Read block - Writing: 4096 - Total: 925696 - Buffer size: 27
              15:23:26.889 FLH: Read block - Writing: 4096 - Total: 929792 - Buffer size: 27
              15:23:27.353 FLH: Read block - Writing: 4096 - Total: 933888 - Buffer size: 27
              15:23:27.817 FLH: Read block - Writing: 4096 - Total: 937984 - Buffer size: 27
              15:23:28.283 FLH: Read block - Writing: 4096 - Total: 942080 - Buffer size: 27
              15:23:28.670 FLH: Read block - Writing: 4096 - Total: 946176 - Buffer size: 27
              15:23:29.133 FLH: Read block - Writing: 4096 - Total: 950272 - Buffer size: 27
              15:23:29.600 FLH: Read block - Writing: 4096 - Total: 954368 - Buffer size: 27
              15:23:30.066 FLH: Read block - Writing: 4096 - Total: 958464 - Buffer size: 27
              15:23:30.538 FLH: Read block - Writing: 4096 - Total: 962560 - Buffer size: 27
              15:23:31.003 FLH: Read block - Writing: 4096 - Total: 966656 - Buffer size: 27
              15:23:31.394 FLH: Read block - Writing: 4096 - Total: 970752 - Buffer size: 27
              15:23:31.863 FLH: Read block - Writing: 4096 - Total: 974848 - Buffer size: 27
              15:23:32.326 FLH: Read block - Writing: 4096 - Total: 978944 - Buffer size: 27
              15:23:32.450 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "8", "time_elapsed": 115}}
              15:23:32.795 FLH: Read block - Writing: 4096 - Total: 983040 - Buffer size: 27
              15:23:33.262 FLH: Read block - Writing: 4096 - Total: 987136 - Buffer size: 27
              15:23:33.728 FLH: Read block - Writing: 4096 - Total: 991232 - Buffer size: 27
              15:23:34.121 FLH: Read block - Writing: 4096 - Total: 995328 - Buffer size: 27
              15:23:34.586 FLH: Read block - Writing: 4096 - Total: 999424 - Buffer size: 27
              15:23:35.050 FLH: Read block - Writing: 4096 - Total: 1003520 - Buffer size: 27
              15:23:35.523 FLH: Read block - Writing: 4096 - Total: 1007616 - Buffer size: 27
              15:23:35.986 FLH: Read block - Writing: 4096 - Total: 1011712 - Buffer size: 27
              15:23:36.453 FLH: Read block - Writing: 4096 - Total: 1015808 - Buffer size: 27
              15:23:36.846 FLH: Read block - Writing: 4096 - Total: 1019904 - Buffer size: 27
              15:23:37.310 FLH: Read block - Writing: 4096 - Total: 1024000 - Buffer size: 27
              15:23:37.773 FLH: Read block - Writing: 4096 - Total: 1028096 - Buffer size: 27
              15:23:38.238 FLH: Read block - Writing: 4096 - Total: 1032192 - Buffer size: 27
              15:23:38.705 FLH: Read block - Writing: 4096 - Total: 1036288 - Buffer size: 27
              15:23:39.174 FLH: Read block - Writing: 4096 - Total: 1040384 - Buffer size: 27
              15:23:39.566 FLH: Read block - Writing: 4096 - Total: 1044480 - Buffer size: 27
              15:23:40.031 FLH: Read block - Writing: 4096 - Total: 1048576 - Buffer size: 27
              15:23:40.503 FLH: Read block - Writing: 4096 - Total: 1052672 - Buffer size: 27
              15:23:40.966 FLH: Read block - Writing: 4096 - Total: 1056768 - Buffer size: 27
              15:23:41.433 FLH: Read block - Writing: 4096 - Total: 1060864 - Buffer size: 27
              15:23:41.897 FLH: Read block - Writing: 4096 - Total: 1064960 - Buffer size: 27
              15:23:42.285 FLH: Read block - Writing: 4096 - Total: 1069056 - Buffer size: 27
              15:23:42.751 FLH: Read block - Writing: 4096 - Total: 1073152 - Buffer size: 27
              15:23:43.215 FLH: Read block - Writing: 4096 - Total: 1077248 - Buffer size: 27
              15:23:43.684 FLH: Read block - Writing: 4096 - Total: 1081344 - Buffer size: 27
              15:23:44.153 FLH: Read block - Writing: 4096 - Total: 1085440 - Buffer size: 27
              15:23:44.618 FLH: Read block - Writing: 4096 - Total: 1089536 - Buffer size: 27
              15:23:45.006 FLH: Read block - Writing: 4096 - Total: 1093632 - Buffer size: 27
              15:23:45.479 FLH: Read block - Writing: 4096 - Total: 1097728 - Buffer size: 27
              15:23:45.942 FLH: Read block - Writing: 4096 - Total: 1101824 - Buffer size: 27
              15:23:46.069 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "9", "time_elapsed": 129}}
              15:23:46.415 FLH: Read block - Writing: 4096 - Total: 1105920 - Buffer size: 27
              15:23:46.881 FLH: Read block - Writing: 4096 - Total: 1110016 - Buffer size: 27
              15:23:47.345 FLH: Read block - Writing: 4096 - Total: 1114112 - Buffer size: 27
              15:23:47.740 FLH: Read block - Writing: 4096 - Total: 1118208 - Buffer size: 27
              15:23:48.203 FLH: Read block - Writing: 4096 - Total: 1122304 - Buffer size: 27
              15:23:48.670 FLH: Read block - Writing: 4096 - Total: 1126400 - Buffer size: 27
              15:23:49.140 FLH: Read block - Writing: 4096 - Total: 1130496 - Buffer size: 27
              15:23:49.606 FLH: Read block - Writing: 4096 - Total: 1134592 - Buffer size: 27
              15:23:50.069 FLH: Read block - Writing: 4096 - Total: 1138688 - Buffer size: 27
              15:23:50.463 FLH: Read block - Writing: 4096 - Total: 1142784 - Buffer size: 27
              15:23:50.928 FLH: Read block - Writing: 4096 - Total: 1146880 - Buffer size: 27
              15:23:51.393 FLH: Read block - Writing: 4096 - Total: 1150976 - Buffer size: 27
              15:23:51.859 FLH: Read block - Writing: 4096 - Total: 1155072 - Buffer size: 27
              15:23:52.323 FLH: Read block - Writing: 4096 - Total: 1159168 - Buffer size: 27
              15:23:52.793 FLH: Read block - Writing: 4096 - Total: 1163264 - Buffer size: 27
              15:23:53.182 FLH: Read block - Writing: 4096 - Total: 1167360 - Buffer size: 27
              15:23:53.647 FLH: Read block - Writing: 4096 - Total: 1171456 - Buffer size: 27
              15:23:54.117 FLH: Read block - Writing: 4096 - Total: 1175552 - Buffer size: 27
              15:23:54.583 FLH: Read block - Writing: 4096 - Total: 1179648 - Buffer size: 27
              15:23:55.045 FLH: Read block - Writing: 4096 - Total: 1183744 - Buffer size: 27
              15:23:55.513 FLH: Read block - Writing: 4096 - Total: 1187840 - Buffer size: 27
              15:23:55.901 FLH: Read block - Writing: 4096 - Total: 1191936 - Buffer size: 27
              15:23:56.366 FLH: Read block - Writing: 4096 - Total: 1196032 - Buffer size: 27
              15:23:56.829 FLH: Read block - Writing: 4096 - Total: 1200128 - Buffer size: 27
              15:23:57.295 FLH: Read block - Writing: 4096 - Total: 1204224 - Buffer size: 27
              15:23:57.765 FLH: Read block - Writing: 4096 - Total: 1208320 - Buffer size: 27
              15:23:58.228 FLH: Read block - Writing: 4096 - Total: 1212416 - Buffer size: 27
              15:23:58.621 FLH: Read block - Writing: 4096 - Total: 1216512 - Buffer size: 27
              15:23:59.090 FLH: Read block - Writing: 4096 - Total: 1220608 - Buffer size: 27
              15:23:59.217 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "10", "time_elapsed": 142}}
              15:23:59.562 FLH: Read block - Writing: 4096 - Total: 1224704 - Buffer size: 27
              15:24:00.025 FLH: Read block - Writing: 4096 - Total: 1228800 - Buffer size: 27
              15:24:00.492 FLH: Read block - Writing: 4096 - Total: 1232896 - Buffer size: 27
              15:24:00.958 FLH: Read block - Writing: 4096 - Total: 1236992 - Buffer size: 27
              15:24:01.353 FLH: Read block - Writing: 4096 - Total: 1241088 - Buffer size: 27
              15:24:01.820 FLH: Read block - Writing: 4096 - Total: 1245184 - Buffer size: 27
              15:24:02.283 FLH: Read block - Writing: 4096 - Total: 1249280 - Buffer size: 27
              15:24:02.751 FLH: Read block - Writing: 4096 - Total: 1253376 - Buffer size: 27
              15:24:03.215 FLH: Read block - Writing: 4096 - Total: 1257472 - Buffer size: 27
              15:24:03.681 FLH: Read block - Writing: 4096 - Total: 1261568 - Buffer size: 27
              15:24:04.073 FLH: Read block - Writing: 4096 - Total: 1265664 - Buffer size: 27
              15:24:04.538 FLH: Read block - Writing: 4096 - Total: 1269760 - Buffer size: 27
              15:24:05.004 FLH: Read block - Writing: 4096 - Total: 1273856 - Buffer size: 27
              15:24:05.471 FLH: Read block - Writing: 4096 - Total: 1277952 - Buffer size: 27
              15:24:05.936 FLH: Read block - Writing: 4096 - Total: 1282048 - Buffer size: 27
              15:24:06.406 FLH: Read block - Writing: 4096 - Total: 1286144 - Buffer size: 27
              15:24:06.794 FLH: Read block - Writing: 4096 - Total: 1290240 - Buffer size: 27
              15:24:07.259 FLH: Read block - Writing: 4096 - Total: 1294336 - Buffer size: 27
              15:24:07.730 FLH: Read block - Writing: 4096 - Total: 1298432 - Buffer size: 27
              15:24:08.194 FLH: Read block - Writing: 4096 - Total: 1302528 - Buffer size: 27
              15:24:08.660 FLH: Read block - Writing: 4096 - Total: 1306624 - Buffer size: 27
              15:24:09.124 FLH: Read block - Writing: 4096 - Total: 1310720 - Buffer size: 27
              15:24:09.513 FLH: Read block - Writing: 4096 - Total: 1314816 - Buffer size: 27
              15:24:09.976 FLH: Read block - Writing: 4096 - Total: 1318912 - Buffer size: 27
              15:24:10.444 FLH: Read block - Writing: 4096 - Total: 1323008 - Buffer size: 27
              15:24:10.910 FLH: Read block - Writing: 4096 - Total: 1327104 - Buffer size: 27
              15:24:11.381 FLH: Read block - Writing: 4096 - Total: 1331200 - Buffer size: 27
              15:24:11.843 FLH: Read block - Writing: 4096 - Total: 1335296 - Buffer size: 27
              15:24:12.235 FLH: Read block - Writing: 4096 - Total: 1339392 - Buffer size: 27
              15:24:12.707 FLH: Read block - Writing: 4096 - Total: 1343488 - Buffer size: 27
              15:24:12.832 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "11", "time_elapsed": 155}}
              15:24:13.178 FLH: Read block - Writing: 4096 - Total: 1347584 - Buffer size: 27
              15:24:13.644 FLH: Read block - Writing: 4096 - Total: 1351680 - Buffer size: 27
              15:24:14.109 FLH: Read block - Writing: 4096 - Total: 1355776 - Buffer size: 27
              15:24:14.575 FLH: Read block - Writing: 4096 - Total: 1359872 - Buffer size: 27
              15:24:14.969 FLH: Read block - Writing: 4096 - Total: 1363968 - Buffer size: 27
              15:24:15.436 FLH: Read block - Writing: 4096 - Total: 1368064 - Buffer size: 27
              15:24:15.900 FLH: Read block - Writing: 4096 - Total: 1372160 - Buffer size: 27
              15:24:16.370 FLH: Read block - Writing: 4096 - Total: 1376256 - Buffer size: 27
              15:24:16.833 FLH: Read block - Writing: 4096 - Total: 1380352 - Buffer size: 27
              15:24:17.295 FLH: Read block - Writing: 4096 - Total: 1384448 - Buffer size: 27
              15:24:17.688 FLH: Read block - Writing: 4096 - Total: 1388544 - Buffer size: 27
              15:24:18.151 FLH: Read block - Writing: 4096 - Total: 1392640 - Buffer size: 27
              15:24:18.617 FLH: Read block - Writing: 4096 - Total: 1396736 - Buffer size: 27
              15:24:19.082 FLH: Read block - Writing: 4096 - Total: 1400832 - Buffer size: 27
              15:24:19.549 FLH: Read block - Writing: 4096 - Total: 1404928 - Buffer size: 27
              15:24:20.019 FLH: Read block - Writing: 4096 - Total: 1409024 - Buffer size: 27
              15:24:20.410 FLH: Read block - Writing: 4096 - Total: 1413120 - Buffer size: 27
              15:24:20.874 FLH: Read block - Writing: 4096 - Total: 1417216 - Buffer size: 27
              15:24:21.342 FLH: Read block - Writing: 4096 - Total: 1421312 - Buffer size: 27
              15:24:21.809 FLH: Read block - Writing: 4096 - Total: 1425408 - Buffer size: 27
              15:24:22.273 FLH: Read block - Writing: 4096 - Total: 1429504 - Buffer size: 27
              15:24:22.741 FLH: Read block - Writing: 4096 - Total: 1433600 - Buffer size: 27
              15:24:23.129 FLH: Read block - Writing: 4096 - Total: 1437696 - Buffer size: 27
              15:24:23.595 FLH: Read block - Writing: 4096 - Total: 1441792 - Buffer size: 27
              15:24:24.060 FLH: Read block - Writing: 4096 - Total: 1445888 - Buffer size: 27
              15:24:24.526 FLH: Read block - Writing: 4096 - Total: 1449984 - Buffer size: 27
              15:24:24.995 FLH: Read block - Writing: 4096 - Total: 1454080 - Buffer size: 27
              15:24:25.461 FLH: Read block - Writing: 4096 - Total: 1458176 - Buffer size: 27
              15:24:25.851 FLH: Read block - Writing: 4096 - Total: 1462272 - Buffer size: 27
              15:24:26.321 FLH: Read block - Writing: 4096 - Total: 1466368 - Buffer size: 27
              15:24:26.444 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "12", "time_elapsed": 169}}
              15:24:26.790 FLH: Read block - Writing: 4096 - Total: 1470464 - Buffer size: 27
              15:24:27.255 FLH: Read block - Writing: 4096 - Total: 1474560 - Buffer size: 27
              15:24:27.722 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 27
              15:24:28.185 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 27
              15:24:28.580 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 27
              15:24:29.045 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 27
              15:24:29.512 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 27
              15:24:29.982 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 27
              15:24:30.449 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 27
              15:24:30.912 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 27
              15:24:31.305 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 27
              15:24:31.769 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 27
              15:24:32.233 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 27
              15:24:32.701 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 27
              15:24:33.166 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 27
              15:24:33.637 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 27
              15:24:34.027 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 27
              15:24:34.493 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 27
              15:24:34.963 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 27
              15:24:35.429 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 27
              15:24:35.893 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 27
              15:24:36.358 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 27
              15:24:36.746 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 27
              15:24:37.210 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 27
              15:24:37.677 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 27
              15:24:38.142 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 27
              15:24:38.614 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 27
              15:24:39.077 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 27
              15:24:39.469 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 27
              15:24:39.938 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 27
              15:24:40.064 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 183}}
              15:24:40.409 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 27
              15:24:40.874 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 27
              15:24:41.337 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 27
              15:24:41.802 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 27
              15:24:42.196 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 27
              15:24:42.663 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 27
              15:24:43.128 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 27
              15:24:43.599 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 27
              15:24:44.063 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 27
              15:24:44.530 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 27
              15:24:44.923 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 27
              15:24:45.391 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 27
              15:24:45.854 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 27
              15:24:46.322 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 27
              15:24:46.785 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 27
              15:24:47.253 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 27
              15:24:47.646 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 27
              15:24:48.109 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 27
              15:24:48.580 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 27
              15:24:49.043 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 27
              15:24:49.508 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 27
              15:24:49.973 FLH: Read block - Writing: 4096 - Total: 1679360 - Buffer size: 27
              15:24:50.361 FLH: Read block - Writing: 4096 - Total: 1683456 - Buffer size: 27
              15:24:50.824 FLH: Read block - Writing: 4096 - Total: 1687552 - Buffer size: 27
              15:24:51.288 FLH: Read block - Writing: 4096 - Total: 1691648 - Buffer size: 27
              15:24:51.755 FLH: Read block - Writing: 4096 - Total: 1695744 - Buffer size: 27
              15:24:52.223 FLH: Read block - Writing: 4096 - Total: 1699840 - Buffer size: 27
              15:24:52.689 FLH: Read block - Writing: 4096 - Total: 1703936 - Buffer size: 27
              15:24:53.080 FLH: Read block - Writing: 4096 - Total: 1708032 - Buffer size: 27
              15:24:53.213 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "14", "time_elapsed": 196}}
              15:24:53.559 FLH: Read block - Writing: 4096 - Total: 1712128 - Buffer size: 27
              15:24:54.023 FLH: Read block - Writing: 4096 - Total: 1716224 - Buffer size: 27
              15:24:54.490 FLH: Read block - Writing: 4096 - Total: 1720320 - Buffer size: 27
              15:24:55.058 FLH: Read block - Writing: 4096 - Total: 1724416 - Buffer size: 2627
              15:24:55.528 FLH: Read block - Writing: 4096 - Total: 1728512 - Buffer size: 2627
              15:24:55.922 FLH: Read block - Writing: 4096 - Total: 1732608 - Buffer size: 2627
              15:24:56.388 FLH: Read block - Writing: 4096 - Total: 1736704 - Buffer size: 2627
              15:24:56.857 FLH: Read block - Writing: 4096 - Total: 1740800 - Buffer size: 2627
              15:24:57.326 FLH: Read block - Writing: 4096 - Total: 1744896 - Buffer size: 2627
              15:24:57.792 FLH: Read block - Writing: 4096 - Total: 1748992 - Buffer size: 2627
              15:24:58.256 FLH: Read block - Writing: 4096 - Total: 1753088 - Buffer size: 2627
              15:24:58.651 FLH: Read block - Writing: 4096 - Total: 1757184 - Buffer size: 2627
              15:24:59.118 FLH: Read block - Writing: 4096 - Total: 1761280 - Buffer size: 2627
              15:24:59.584 FLH: Read block - Writing: 4096 - Total: 1765376 - Buffer size: 2627
              15:25:00.049 FLH: Read block - Writing: 4096 - Total: 1769472 - Buffer size: 2627
              15:25:00.519 FLH: Read block - Writing: 4096 - Total: 1773568 - Buffer size: 2627
              15:25:00.990 FLH: Read block - Writing: 4096 - Total: 1777664 - Buffer size: 2627
              15:25:01.381 FLH: Read block - Writing: 4096 - Total: 1781760 - Buffer size: 2627
              15:25:01.845 FLH: Read block - Writing: 4096 - Total: 1785856 - Buffer size: 2627
              15:25:02.314 FLH: Read block - Writing: 4096 - Total: 1789952 - Buffer size: 2627
              15:25:02.780 FLH: Read block - Writing: 4096 - Total: 1794048 - Buffer size: 2627
              15:25:03.245 FLH: Read block - Writing: 4096 - Total: 1798144 - Buffer size: 2627
              15:25:03.715 FLH: Read block - Writing: 4096 - Total: 1802240 - Buffer size: 2627
              15:25:04.102 FLH: Read block - Writing: 4096 - Total: 1806336 - Buffer size: 2627
              15:25:04.567 FLH: Read block - Writing: 4096 - Total: 1810432 - Buffer size: 2627
              15:25:05.034 FLH: Read block - Writing: 4096 - Total: 1814528 - Buffer size: 2627
              15:25:05.499 FLH: Read block - Writing: 4096 - Total: 1818624 - Buffer size: 535
              15:25:05.969 FLH: Read block - Writing: 4096 - Total: 1822720 - Buffer size: 535
              15:25:06.436 FLH: Read block - Writing: 4096 - Total: 1826816 - Buffer size: 535
              15:25:06.823 FLH: Read block - Writing: 4096 - Total: 1830912 - Buffer size: 535
              15:25:06.954 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "15", "time_elapsed": 210}}
              15:25:07.300 FLH: Read block - Writing: 4096 - Total: 1835008 - Buffer size: 535
              15:25:07.763 FLH: Read block - Writing: 4096 - Total: 1839104 - Buffer size: 535
              15:25:08.228 FLH: Read block - Writing: 4096 - Total: 1843200 - Buffer size: 535
              15:25:08.696 FLH: Read block - Writing: 4096 - Total: 1847296 - Buffer size: 535
              15:25:09.161 FLH: Read block - Writing: 4096 - Total: 1851392 - Buffer size: 535
              15:25:09.556 FLH: Read block - Writing: 4096 - Total: 1855488 - Buffer size: 535
              15:25:10.023 FLH: Read block - Writing: 4096 - Total: 1859584 - Buffer size: 535
              15:25:10.490 FLH: Read block - Writing: 4096 - Total: 1863680 - Buffer size: 535
              15:25:10.960 FLH: Read block - Writing: 4096 - Total: 1867776 - Buffer size: 535
              15:25:11.427 FLH: Read block - Writing: 4096 - Total: 1871872 - Buffer size: 535
              15:25:11.891 FLH: Read block - Writing: 4096 - Total: 1875968 - Buffer size: 535
              15:25:12.283 FLH: Read block - Writing: 4096 - Total: 1880064 - Buffer size: 535
              15:25:12.750 FLH: Read block - Writing: 4096 - Total: 1884160 - Buffer size: 535
              15:25:13.215 FLH: Read block - Writing: 4096 - Total: 1888256 - Buffer size: 535
              15:25:13.683 FLH: Read block - Writing: 4096 - Total: 1892352 - Buffer size: 535
              15:25:14.149 FLH: Read block - Writing: 4096 - Total: 1896448 - Buffer size: 535
              15:25:14.622 FLH: Read block - Writing: 4096 - Total: 1900544 - Buffer size: 535
              15:25:15.009 FLH: Read block - Writing: 4096 - Total: 1904640 - Buffer size: 535
              15:25:15.477 FLH: Read block - Writing: 4096 - Total: 1908736 - Buffer size: 535
              15:25:15.949 FLH: Read block - Writing: 4096 - Total: 1912832 - Buffer size: 535
              15:25:16.416 FLH: Read block - Writing: 4096 - Total: 1916928 - Buffer size: 535
              15:25:16.881 FLH: Read block - Writing: 4096 - Total: 1921024 - Buffer size: 535
              15:25:17.346 FLH: Read block - Writing: 4096 - Total: 1925120 - Buffer size: 535
              15:25:17.736 FLH: Read block - Writing: 4096 - Total: 1929216 - Buffer size: 535
              15:25:18.199 FLH: Read block - Writing: 4096 - Total: 1933312 - Buffer size: 535
              15:25:18.665 FLH: Read block - Writing: 4096 - Total: 1937408 - Buffer size: 535
              15:25:19.130 FLH: Read block - Writing: 4096 - Total: 1941504 - Buffer size: 535
              15:25:19.600 FLH: Read block - Writing: 4096 - Total: 1945600 - Buffer size: 535
              15:25:20.063 FLH: Read block - Writing: 4096 - Total: 1949696 - Buffer size: 535
              15:25:20.452 FLH: Read block - Writing: 4096 - Total: 1953792 - Buffer size: 535
              15:25:20.584 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "16", "time_elapsed": 223}}
              15:25:20.929 FLH: Read block - Writing: 4096 - Total: 1957888 - Buffer size: 535
              15:25:21.394 FLH: Read block - Writing: 4096 - Total: 1961984 - Buffer size: 535
              15:25:21.858 FLH: Read block - Writing: 4096 - Total: 1966080 - Buffer size: 535
              15:25:22.323 FLH: Read block - Writing: 4096 - Total: 1970176 - Buffer size: 535
              15:25:22.786 FLH: Read block - Writing: 4096 - Total: 1974272 - Buffer size: 535
              15:25:23.180 FLH: Read block - Writing: 4096 - Total: 1978368 - Buffer size: 535
              15:25:23.648 FLH: Read block - Writing: 4096 - Total: 1982464 - Buffer size: 535
              15:25:24.113 FLH: Read block - Writing: 4096 - Total: 1986560 - Buffer size: 535
              15:25:24.583 FLH: Read block - Writing: 4096 - Total: 1990656 - Buffer size: 535
              15:25:25.048 FLH: Read block - Writing: 4096 - Total: 1994752 - Buffer size: 535
              15:25:25.515 FLH: Read block - Writing: 4096 - Total: 1998848 - Buffer size: 535
              15:25:25.907 FLH: Read block - Writing: 4096 - Total: 2002944 - Buffer size: 535
              15:25:26.372 FLH: Read block - Writing: 4096 - Total: 2007040 - Buffer size: 535
              15:25:26.837 FLH: Read block - Writing: 4096 - Total: 2011136 - Buffer size: 535
              15:25:27.302 FLH: Read block - Writing: 4096 - Total: 2015232 - Buffer size: 535
              15:25:27.766 FLH: Read block - Writing: 4096 - Total: 2019328 - Buffer size: 535
              15:25:28.238 FLH: Read block - Writing: 4096 - Total: 2023424 - Buffer size: 535
              15:25:28.628 FLH: Read block - Writing: 4096 - Total: 2027520 - Buffer size: 535
              15:25:29.093 FLH: Read block - Writing: 4096 - Total: 2031616 - Buffer size: 535
              15:25:29.570 FLH: Read block - Writing: 4096 - Total: 2035712 - Buffer size: 535
              15:25:30.034 FLH: Read block - Writing: 4096 - Total: 2039808 - Buffer size: 535
              15:25:30.500 FLH: Read block - Writing: 4096 - Total: 2043904 - Buffer size: 535
              15:25:30.964 FLH: Read block - Writing: 4096 - Total: 2048000 - Buffer size: 535
              15:25:31.352 FLH: Read block - Writing: 4096 - Total: 2052096 - Buffer size: 535
              15:25:31.817 FLH: Read block - Writing: 4096 - Total: 2056192 - Buffer size: 535
              15:25:32.283 FLH: Read block - Writing: 4096 - Total: 2060288 - Buffer size: 535
              15:25:32.747 FLH: Read block - Writing: 4096 - Total: 2064384 - Buffer size: 535
              15:25:33.217 FLH: Read block - Writing: 4096 - Total: 2068480 - Buffer size: 535
              15:25:33.683 FLH: Read block - Writing: 4096 - Total: 2072576 - Buffer size: 535
              15:25:34.073 FLH: Read block - Writing: 4096 - Total: 2076672 - Buffer size: 535
              15:25:34.206 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "17", "time_elapsed": 237}}
              15:25:34.551 FLH: Read block - Writing: 4096 - Total: 2080768 - Buffer size: 535
              15:25:35.013 FLH: Read block - Writing: 4096 - Total: 2084864 - Buffer size: 535
              15:25:35.479 FLH: Read block - Writing: 4096 - Total: 2088960 - Buffer size: 535
              15:25:35.946 FLH: Read block - Writing: 4096 - Total: 2093056 - Buffer size: 535
              15:25:36.411 FLH: Read block - Writing: 4096 - Total: 2097152 - Buffer size: 535
              15:25:36.801 FLH: Read block - Writing: 4096 - Total: 2101248 - Buffer size: 535
              15:25:37.267 FLH: Read block - Writing: 4096 - Total: 2105344 - Buffer size: 535
              15:25:37.735 FLH: Read block - Writing: 4096 - Total: 2109440 - Buffer size: 535
              15:25:38.205 FLH: Read block - Writing: 4096 - Total: 2113536 - Buffer size: 535
              15:25:38.672 FLH: Read block - Writing: 4096 - Total: 2117632 - Buffer size: 535
              15:25:39.135 FLH: Read block - Writing: 4096 - Total: 2121728 - Buffer size: 535
              15:25:39.530 FLH: Read block - Writing: 4096 - Total: 2125824 - Buffer size: 535
              15:25:39.994 FLH: Read block - Writing: 4096 - Total: 2129920 - Buffer size: 535
              15:25:40.461 FLH: Read block - Writing: 4096 - Total: 2134016 - Buffer size: 535
              15:25:40.927 FLH: Read block - Writing: 4096 - Total: 2138112 - Buffer size: 535
              15:25:41.392 FLH: Read block - Writing: 4096 - Total: 2142208 - Buffer size: 535
              15:25:41.862 FLH: Read block - Writing: 4096 - Total: 2146304 - Buffer size: 535
              15:25:42.555 FLH: Read block - Writing: 4096 - Total: 2150400 - Buffer size: 1911
              15:25:43.023 FLH: Read block - Writing: 4096 - Total: 2154496 - Buffer size: 1911
              15:25:43.496 FLH: Read block - Writing: 4096 - Total: 2158592 - Buffer size: 1911
              15:25:43.959 FLH: Read block - Writing: 4096 - Total: 2162688 - Buffer size: 1911
              15:25:44.426 FLH: Read block - Writing: 4096 - Total: 2166784 - Buffer size: 1911
              15:25:44.816 FLH: Read block - Writing: 4096 - Total: 2170880 - Buffer size: 115
              15:25:45.281 FLH: Read block - Writing: 4096 - Total: 2174976 - Buffer size: 115
              15:25:45.745 FLH: Read block - Writing: 4096 - Total: 2179072 - Buffer size: 115
              15:25:46.208 FLH: Read block - Writing: 4096 - Total: 2183168 - Buffer size: 115
              15:25:46.675 FLH: Read block - Writing: 4096 - Total: 2187264 - Buffer size: 115
              15:25:47.145 FLH: Read block - Writing: 4096 - Total: 2191360 - Buffer size: 115
              15:25:47.536 FLH: Read block - Writing: 4096 - Total: 2195456 - Buffer size: 115
              15:25:47.000 FLH: Read block - Writing: 4096 - Total: 2199552 - Buffer size: 115
              15:25:48.132 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "18", "time_elapsed": 251}}
              15:25:48.478 FLH: Read block - Writing: 4096 - Total: 2203648 - Buffer size: 115
              15:25:48.942 FLH: Read block - Writing: 4096 - Total: 2207744 - Buffer size: 115
              15:25:49.406 FLH: Read block - Writing: 4096 - Total: 2211840 - Buffer size: 115
              15:25:49.869 FLH: Read block - Writing: 4096 - Total: 2215936 - Buffer size: 115
              15:25:50.263 FLH: Read block - Writing: 4096 - Total: 2220032 - Buffer size: 115
              15:25:50.733 FLH: Read block - Writing: 4096 - Total: 2224128 - Buffer size: 115
              15:25:51.196 FLH: Read block - Writing: 4096 - Total: 2228224 - Buffer size: 115
              15:25:51.667 FLH: Read block - Writing: 4096 - Total: 2232320 - Buffer size: 115
              15:25:52.137 FLH: Read block - Writing: 4096 - Total: 2236416 - Buffer size: 115
              15:25:52.602 FLH: Read block - Writing: 4096 - Total: 2240512 - Buffer size: 115
              15:25:52.991 FLH: Read block - Writing: 4096 - Total: 2244608 - Buffer size: 115
              15:25:53.462 FLH: Read block - Writing: 4096 - Total: 2248704 - Buffer size: 115
              15:25:53.927 FLH: Read block - Writing: 4096 - Total: 2252800 - Buffer size: 115
              15:25:54.392 FLH: Read block - Writing: 4096 - Total: 2256896 - Buffer size: 115
              15:25:54.858 FLH: Read block - Writing: 4096 - Total: 2260992 - Buffer size: 115
              15:25:55.321 FLH: Read block - Writing: 4096 - Total: 2265088 - Buffer size: 115
              15:25:55.707 FLH: Read block - Writing: 4096 - Total: 2269184 - Buffer size: 115
              15:25:56.173 FLH: Read block - Writing: 4096 - Total: 2273280 - Buffer size: 115
              15:25:56.638 FLH: Read block - Writing: 4096 - Total: 2277376 - Buffer size: 115
              15:25:57.108 FLH: Read block - Writing: 4096 - Total: 2281472 - Buffer size: 115
              15:25:57.574 FLH: Read block - Writing: 4096 - Total: 2285568 - Buffer size: 115
              15:25:58.039 FLH: Read block - Writing: 4096 - Total: 2289664 - Buffer size: 115
              15:25:58.433 FLH: Read block - Writing: 4096 - Total: 2293760 - Buffer size: 115
              15:25:58.899 FLH: Read block - Writing: 4096 - Total: 2297856 - Buffer size: 115
              15:25:58.928 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:25:58","Uptime":"0T00:05:08","UptimeSec":308,"Heap":121,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":1024,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":217},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:03"}}
              15:25:58.974 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:25:58","ANALOG":{"Temperature1":28.1},"ESP32":{"Temperature":60.0},"TempUnit":"C"}
              15:25:59.362 FLH: Read block - Writing: 4096 - Total: 2301952 - Buffer size: 115
              15:25:59.830 FLH: Read block - Writing: 4096 - Total: 2306048 - Buffer size: 115
              15:26:00.294 FLH: Read block - Writing: 4096 - Total: 2310144 - Buffer size: 115
              15:26:00.763 FLH: Read block - Writing: 4096 - Total: 2314240 - Buffer size: 115
              15:26:01.158 FLH: Read block - Writing: 4096 - Total: 2318336 - Buffer size: 115
              15:26:01.288 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "19", "time_elapsed": 264}}
              15:26:01.633 FLH: Read block - Writing: 4096 - Total: 2322432 - Buffer size: 115
              15:26:02.105 FLH: Read block - Writing: 4096 - Total: 2326528 - Buffer size: 115
              15:26:02.571 FLH: Read block - Writing: 4096 - Total: 2330624 - Buffer size: 115
              15:26:03.035 FLH: Read block - Writing: 4096 - Total: 2334720 - Buffer size: 115
              15:26:03.502 FLH: Read block - Writing: 4096 - Total: 2338816 - Buffer size: 115
              15:26:03.894 FLH: Read block - Writing: 4096 - Total: 2342912 - Buffer size: 115
              15:26:04.359 FLH: Read block - Writing: 4096 - Total: 2347008 - Buffer size: 115
              15:26:04.821 FLH: Read block - Writing: 4096 - Total: 2351104 - Buffer size: 115
              15:26:05.287 FLH: Read block - Writing: 4096 - Total: 2355200 - Buffer size: 115
              15:26:05.756 FLH: Read block - Writing: 4096 - Total: 2359296 - Buffer size: 115
              15:26:06.217 FLH: Read block - Writing: 4096 - Total: 2363392 - Buffer size: 115
              15:26:06.606 FLH: Read block - Writing: 4096 - Total: 2367488 - Buffer size: 115
              15:26:07.076 FLH: Read block - Writing: 4096 - Total: 2371584 - Buffer size: 115
              15:26:07.542 FLH: Read block - Writing: 4096 - Total: 2375680 - Buffer size: 115
              15:26:08.008 FLH: Read block - Writing: 4096 - Total: 2379776 - Buffer size: 115
              15:26:08.476 FLH: Read block - Writing: 4096 - Total: 2383872 - Buffer size: 115
              15:26:08.941 FLH: Read block - Writing: 4096 - Total: 2387968 - Buffer size: 115
              15:26:09.331 FLH: Read block - Writing: 4096 - Total: 2392064 - Buffer size: 115
              15:26:09.793 FLH: Read block - Writing: 4096 - Total: 2396160 - Buffer size: 115
              15:26:10.260 FLH: Read block - Writing: 4096 - Total: 2400256 - Buffer size: 115
              15:26:10.733 FLH: Read block - Writing: 4096 - Total: 2404352 - Buffer size: 115
              15:26:11.197 FLH: Read block - Writing: 4096 - Total: 2408448 - Buffer size: 115
              15:26:11.663 FLH: Read block - Writing: 4096 - Total: 2412544 - Buffer size: 115
              15:26:12.054 FLH: Read block - Writing: 4096 - Total: 2416640 - Buffer size: 115
              15:26:12.522 FLH: Read block - Writing: 4096 - Total: 2420736 - Buffer size: 115
              15:26:12.984 FLH: Read block - Writing: 4096 - Total: 2424832 - Buffer size: 115
              15:26:13.450 FLH: Read block - Writing: 4096 - Total: 2428928 - Buffer size: 115
              15:26:13.914 FLH: Read block - Writing: 4096 - Total: 2433024 - Buffer size: 115
              15:26:14.383 FLH: Read block - Writing: 4096 - Total: 2437120 - Buffer size: 115
              15:26:14.772 FLH: Read block - Writing: 4096 - Total: 2441216 - Buffer size: 115
              15:26:14.901 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "20", "time_elapsed": 278}}
              15:26:15.246 FLH: Read block - Writing: 4096 - Total: 2445312 - Buffer size: 115
              15:26:15.716 FLH: Read block - Writing: 4096 - Total: 2449408 - Buffer size: 115
              15:26:16.182 FLH: Read block - Writing: 4096 - Total: 2453504 - Buffer size: 115
              15:26:16.651 FLH: Read block - Writing: 4096 - Total: 2457600 - Buffer size: 115
              15:26:17.114 FLH: Read block - Writing: 4096 - Total: 2461696 - Buffer size: 115
              15:26:17.584 FLH: Read block - Writing: 4096 - Total: 2465792 - Buffer size: 115
              15:26:18.055 FLH: Read block - Writing: 4096 - Total: 2469888 - Buffer size: 115
              15:26:18.520 FLH: Read block - Writing: 4096 - Total: 2473984 - Buffer size: 115
              15:26:18.984 FLH: Read block - Writing: 4096 - Total: 2478080 - Buffer size: 115
              15:26:19.451 FLH: Read block - Writing: 4096 - Total: 2482176 - Buffer size: 115
              15:28:18.883 FLH: Read block - Writing: 4096 - Total: 3559424 - Buffer size: 115
              15:28:19.280 FLH: Read block - Writing: 4096 - Total: 3563520 - Buffer size: 115
              15:28:19.748 FLH: Read block - Writing: 4096 - Total: 3567616 - Buffer size: 115
              15:28:20.210 FLH: Read block - Writing: 4096 - Total: 3571712 - Buffer size: 115
              15:28:20.678 FLH: Read block - Writing: 4096 - Total: 3575808 - Buffer size: 115
              15:28:21.144 FLH: Read block - Writing: 4096 - Total: 3579904 - Buffer size: 115
              15:28:21.613 FLH: Read block - Writing: 4096 - Total: 3584000 - Buffer size: 115
              15:28:22.003 FLH: Read block - Writing: 4096 - Total: 3588096 - Buffer size: 115
              15:28:22.470 FLH: Read block - Writing: 4096 - Total: 3592192 - Buffer size: 115
              15:28:22.938 FLH: Read block - Writing: 4096 - Total: 3596288 - Buffer size: 115
              15:28:23.406 FLH: Read block - Writing: 4096 - Total: 3600384 - Buffer size: 115
              15:28:23.871 FLH: Read block - Writing: 4096 - Total: 3604480 - Buffer size: 115
              15:28:24.336 FLH: Read block - Writing: 4096 - Total: 3608576 - Buffer size: 115
              15:28:24.724 FLH: Read block - Writing: 4096 - Total: 3612672 - Buffer size: 115
              15:28:25.186 FLH: Read block - Writing: 4096 - Total: 3616768 - Buffer size: 115
              15:28:25.652 FLH: Read block - Writing: 4096 - Total: 3620864 - Buffer size: 115
              15:28:26.119 FLH: Read block - Writing: 4096 - Total: 3624960 - Buffer size: 115
              15:28:26.590 FLH: Read block - Writing: 4096 - Total: 3629056 - Buffer size: 115
              15:28:27.054 FLH: Read block - Writing: 4096 - Total: 3633152 - Buffer size: 115
              15:28:27.443 FLH: Read block - Writing: 4096 - Total: 3637248 - Buffer size: 115
              15:28:27.914 FLH: Read block - Writing: 4096 - Total: 3641344 - Buffer size: 115
              15:28:28.378 FLH: Read block - Writing: 4096 - Total: 3645440 - Buffer size: 115
              15:28:29.596 FLH: Read block - Writing: 4096 - Total: 3649536 - Buffer size: 523
              15:28:30.064 FLH: Read block - Writing: 4096 - Total: 3653632 - Buffer size: 523
              15:28:30.532 FLH: Read block - Writing: 4096 - Total: 3657728 - Buffer size: 523
              15:28:31.604 FLH: Read block - Writing: 4096 - Total: 3661824 - Buffer size: 1159
              15:28:31.734 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "30", "time_elapsed": 414}}
              15:28:32.080 FLH: Read block - Writing: 4096 - Total: 3665920 - Buffer size: 1159
              15:28:32.550 FLH: Read block - Writing: 4096 - Total: 3670016 - Buffer size: 1159
              15:28:33.013 FLH: Read block - Writing: 4096 - Total: 3674112 - Buffer size: 1159
              15:28:33.480 FLH: Read block - Writing: 4096 - Total: 3678208 - Buffer size: 1159
              15:28:33.951 FLH: Read block - Writing: 4096 - Total: 3682304 - Buffer size: 1159
              15:28:34.419 FLH: Read block - Writing: 4096 - Total: 3686400 - Buffer size: 1159
              15:28:34.884 FLH: Read block - Writing: 4096 - Total: 3690496 - Buffer size: 1159
              15:28:35.275 FLH: Read block - Writing: 4096 - Total: 3694592 - Buffer size: 1159
              15:28:35.742 FLH: Read block - Writing: 4096 - Total: 3698688 - Buffer size: 1159
              15:28:36.206 FLH: Read block - Writing: 4096 - Total: 3702784 - Buffer size: 1159
              15:28:36.674 FLH: Read block - Writing: 4096 - Total: 3706880 - Buffer size: 1159
              15:28:37.139 FLH: Read block - Writing: 4096 - Total: 3710976 - Buffer size: 1159
              15:28:37.613 FLH: Read block - Writing: 4096 - Total: 3715072 - Buffer size: 1159
              15:28:38.059 FLH: Read block - Writing: 4096 - Total: 3719168 - Buffer size: 3931
              15:28:38.528 FLH: Read block - Writing: 4096 - Total: 3723264 - Buffer size: 3931
              15:28:38.998 FLH: Read block - Writing: 4096 - Total: 3727360 - Buffer size: 3931
              15:28:39.469 FLH: Read block - Writing: 4096 - Total: 3731456 - Buffer size: 3931
              15:28:39.936 FLH: Read block - Writing: 4096 - Total: 3735552 - Buffer size: 3931
              15:28:40.404 FLH: Read block - Writing: 4096 - Total: 3739648 - Buffer size: 3931
              15:28:40.871 FLH: Read block - Writing: 4096 - Total: 3743744 - Buffer size: 3931
              15:28:41.343 FLH: Read block - Writing: 4096 - Total: 3747840 - Buffer size: 3931
              15:28:41.809 FLH: Read block - Writing: 4096 - Total: 3751936 - Buffer size: 3931
              15:28:42.275 FLH: Read block - Writing: 4096 - Total: 3756032 - Buffer size: 3931
              15:28:42.745 FLH: Read block - Writing: 4096 - Total: 3760128 - Buffer size: 3931
              15:29:08.206 FLH: Read block - Writing: 4096 - Total: 3989504 - Buffer size: 3931
              15:29:08.680 FLH: Read block - Writing: 4096 - Total: 3993600 - Buffer size: 3931
              15:29:09.144 FLH: Read block - Writing: 4096 - Total: 3997696 - Buffer size: 3931
              15:29:09.612 FLH: Read block - Writing: 4096 - Total: 4001792 - Buffer size: 3931
              15:29:10.080 FLH: Read block - Writing: 4096 - Total: 4005888 - Buffer size: 3931
              15:29:10.477 FLH: Read block - Writing: 4096 - Total: 4009984 - Buffer size: 3931
              15:29:10.944 FLH: Read block - Writing: 4096 - Total: 4014080 - Buffer size: 3931
              15:29:11.413 FLH: Read block - Writing: 4096 - Total: 4018176 - Buffer size: 3931
              15:29:11.880 FLH: Read block - Writing: 4096 - Total: 4022272 - Buffer size: 3931
              15:29:12.353 FLH: Read block - Writing: 4096 - Total: 4026368 - Buffer size: 3931
              15:29:12.479 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "33", "time_elapsed": 455}}
              15:29:12.825 FLH: Read block - Writing: 4096 - Total: 4030464 - Buffer size: 3931
              15:29:13.220 FLH: Read block - Writing: 4096 - Total: 4034560 - Buffer size: 3931
              15:29:13.694 FLH: Read block - Writing: 4096 - Total: 4038656 - Buffer size: 3931
              15:29:14.160 FLH: Read block - Writing: 4096 - Total: 4042752 - Buffer size: 3931
              15:29:14.629 FLH: Read block - Writing: 4096 - Total: 4046848 - Buffer size: 3931
              15:29:15.095 FLH: Read block - Writing: 4096 - Total: 4050944 - Buffer size: 3931
              15:29:15.565 FLH: Read block - Writing: 4096 - Total: 4055040 - Buffer size: 3931
              15:29:15.960 FLH: Read block - Writing: 4096 - Total: 4059136 - Buffer size: 3931
              15:29:16.428 FLH: Read block - Writing: 4096 - Total: 4063232 - Buffer size: 3931
              15:29:16.896 FLH: Read block - Writing: 4096 - Total: 4067328 - Buffer size: 3931
              15:29:17.368 FLH: Read block - Writing: 4096 - Total: 4071424 - Buffer size: 3931
              15:29:17.834 FLH: Read block - Writing: 4096 - Total: 4075520 - Buffer size: 3931
              15:29:18.297 FLH: Read block - Writing: 4096 - Total: 4079616 - Buffer size: 3931
              15:29:18.697 FLH: Read block - Writing: 4096 - Total: 4083712 - Buffer size: 3931
              15:29:19.163 FLH: Read block - Writing: 4096 - Total: 4087808 - Buffer size: 3931
              15:29:19.630 FLH: Read block - Writing: 4096 - Total: 4091904 - Buffer size: 3931
              15:29:20.097 FLH: Read block - Writing: 4096 - Total: 4096000 - Buffer size: 3931
              15:29:20.564 FLH: Read block - Writing: 4096 - Total: 4100096 - Buffer size: 3931
              15:29:21.032 FLH: Read block - Writing: 4096 - Total: 4104192 - Buffer size: 3931
              15:29:21.431 FLH: Read block - Writing: 4096 - Total: 4108288 - Buffer size: 3931
              15:29:21.896 FLH: Read block - Writing: 4096 - Total: 4112384 - Buffer size: 3931
              15:29:22.367 FLH: Read block - Writing: 4096 - Total: 4116480 - Buffer size: 3931
              15:29:22.835 FLH: Read block - Writing: 4096 - Total: 4120576 - Buffer size: 3931
              15:29:23.298 FLH: Read block - Writing: 4096 - Total: 4124672 - Buffer size: 3931
              15:29:23.764 FLH: Read block - Writing: 4096 - Total: 4128768 - Buffer size: 3931
              15:29:24.159 FLH: Read block - Writing: 4096 - Total: 4132864 - Buffer size: 3931
              15:29:24.828 FLH: Read block - Writing: 4096 - Total: 4136960 - Buffer size: 3931
              15:29:25.294 FLH: Read block - Writing: 4096 - Total: 4141056 - Buffer size: 3931
              15:29:25.763 FLH: Read block - Writing: 4096 - Total: 4145152 - Buffer size: 3931
              15:29:26.231 FLH: Read block - Writing: 4096 - Total: 4149248 - Buffer size: 3931
              15:29:26.282 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "34", "time_elapsed": 469}}
              15:29:26.628 FLH: Read block - Writing: 4096 - Total: 4153344 - Buffer size: 3931
              15:29:27.099 FLH: Read block - Writing: 4096 - Total: 4157440 - Buffer size: 3931
              15:29:27.567 FLH: Read block - Writing: 4096 - Total: 4161536 - Buffer size: 3931
              15:29:28.033 FLH: Read block - Writing: 4096 - Total: 4165632 - Buffer size: 3931
              15:29:28.504 FLH: Read block - Writing: 4096 - Total: 4169728 - Buffer size: 3931
              15:29:28.968 FLH: Read block - Writing: 4096 - Total: 4173824 - Buffer size: 1843
              15:29:29.368 FLH: Read block - Writing: 4096 - Total: 4177920 - Buffer size: 587
              15:29:29.833 FLH: Read block - Writing: 4096 - Total: 4182016 - Buffer size: 587
              15:29:30.298 FLH: Read block - Writing: 4096 - Total: 4186112 - Buffer size: 587
              15:29:30.770 FLH: Read block - Writing: 4096 - Total: 4190208 - Buffer size: 587
              15:29:31.232 FLH: Read block - Writing: 4096 - Total: 4194304 - Buffer size: 587
              15:29:31.701 FLH: Read block - Writing: 4096 - Total: 4198400 - Buffer size: 587
              15:29:32.288 FLH: Read block - Writing: 4096 - Total: 4202496 - Buffer size: 587
              15:29:32.753 FLH: Read block - Writing: 4096 - Total: 4206592 - Buffer size: 587
              15:29:33.219 FLH: Read block - Writing: 4096 - Total: 4210688 - Buffer size: 587
              15:29:33.686 FLH: Read block - Writing: 4096 - Total: 4214784 - Buffer size: 587
              15:29:34.158 FLH: Read block - Writing: 4096 - Total: 4218880 - Buffer size: 587
              15:29:34.624 FLH: Read block - Writing: 4096 - Total: 4222976 - Buffer size: 587
              15:29:35.010 FLH: Read block - Writing: 4096 - Total: 4227072 - Buffer size: 587
              15:29:35.482 FLH: Read block - Writing: 4096 - Total: 4231168 - Buffer size: 587
              15:29:35.946 FLH: Read block - Writing: 4096 - Total: 4235264 - Buffer size: 587
              15:29:36.411 FLH: Read block - Writing: 4096 - Total: 4239360 - Buffer size: 587
              15:29:36.878 FLH: Read block - Writing: 4096 - Total: 4243456 - Buffer size: 587
              15:30:15.760 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 587
              15:30:16.229 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 587
              15:30:16.692 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 587
              15:30:17.358 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 587
              15:30:17.823 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 587
              15:30:18.293 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 587
              15:30:18.681 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 587
              15:30:19.146 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 587
              15:30:19.618 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 587
              15:30:20.083 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 587
              15:30:20.549 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 587
              15:30:21.013 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 587
              15:30:21.400 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 587
              15:30:21.868 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 587
              15:30:21.994 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 525}}
              15:30:22.340 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 587
              15:30:22.804 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 587
              15:30:23.277 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 587
              15:30:23.741 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 587
              15:30:24.137 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 587
              15:30:24.905 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 587
              15:30:25.368 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 587
              15:30:25.837 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 587
              15:30:26.300 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 587
              15:30:26.774 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 587
              15:30:27.237 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 587
              15:30:27.704 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 587
              15:30:28.172 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 587
              15:30:28.638 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 587
              15:30:29.110 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 587
              15:30:29.498 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 587
              15:30:29.966 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 587
              15:30:30.943 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 2299
              15:30:31.410 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 2299
              15:30:31.875 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 2299
              15:30:32.268 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 2299
              15:30:33.040 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 2299
              15:30:33.505 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 2299
              15:30:33.971 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 2299
              15:30:34.440 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 2299
              15:30:34.828 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 2299
              15:30:35.293 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 2299
              15:30:35.758 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 2299
              15:30:36.223 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 2299
              15:30:36.698 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 2299
              15:30:36.822 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 539}}
              15:30:37.167 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 2299
              15:30:37.566 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 2299
              15:30:38.036 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 2299
              15:30:38.505 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 2299
              15:30:38.970 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 2299
              15:30:39.439 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 2299
              15:30:39.904 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 2299
              • Armilar
                Armilar Most Active Forum Testing last edited by
                @australien
                und mit Adv0?
                  australien @Armilar last edited by
                  @armilar
                  das gleiche, hab übrigens gesehen die Fehlermeldung ist doch da.
                  00:00:00.001 HDW: ESP32-D0WD-V3 v3.0
                  00:00:00.017 UFS: FlashFS mounted with 288 kB free
                  00:00:00.026 CFG: Loaded from File, Anzahl 1518
                  00:00:00.035 QPC: Count 1
                  00:00:00.035 CFG: CR 430/699, Busy 0
                  00:00:00.041 TYA: Active=0
                  00:00:00.045 ROT: Mode 1
                  00:00:00.069 CFG: No '*.autoconf' file found
                  00:00:00.073 BRY: Berry initialized, RAM used 3493 bytes
                  00:00:00.079 BRY: No 'preinit.be'
                  00:00:00.081 SRC: Restart
                  00:00:00.085 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
                  00:00:00.218 NXP: Initializing Driver
                  00:00:00.220 BRY: Serial UART2
                  00:00:00.223 BRY: Successfully loaded 'autoexec.be'
                  00:00:00.310 WIF: Verbindungsversuch…
                  00:00:00.948 WIF: verbinden mit AP1 FR@smart Channel 9 BSSId 7E:8A:20:51:6B:CA in Modus HT40 als NSPanel-1-5140...
                  00:00:01.077 WIF: IPv4 10.68.0.179, mask 255.255.0.0, gateway 10.68.0.1
                  00:00:03.476 WIF: IPv6 Local fe80::e2e2:e6ff:fe0c:1414%st1
                  00:00:03.498 WIF: verbunden
                  00:00:03.755 HTP: Web server active on NSPanel-1-5140 with IP address 10.68.0.179
                  00:00:04.004 RTC: UTC 2025-09-12T14:50:15Z, DST 2025-03-30T02:00:00, STD 2025-10-26T03:00:00
                  15:50:15.000 RTC: Synced by NTP
                  15:50:15.745 MQT: Verbindungsversuch…
                  15:50:15.761 MQT: verbunden
                  15:50:15.764 MQT: SmartHome/NSPanel_1/tele/LWT = Online (beibehalten)
                  15:50:15.765 MQT: SmartHome/NSPanel_1/cmnd/POWER =
                  15:50:15.766 MQT: abonniere SmartHome/NSPanel_1/cmnd/#
                  15:50:15.767 MQT: abonniere SmartHome/tasmotas/cmnd/#
                  15:50:15.768 MQT: abonniere cmnd/NSPanel_1_fb/#
                  15:50:15.770 MQT: SmartHome/NSPanel_1/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanel_1_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
                  15:50:15.784 MQT: SmartHome/NSPanel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-1-5140","IPAddress":"10.68.0.179","IP6Global":"","IP6Local":"fe80::e2e2:e6ff:fe0c:1414%st1"}}
                  15:50:15.809 MQT: SmartHome/NSPanel_1/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":172}}
                  15:50:15.813 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                  15:50:15.824 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                  15:50:15.826 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                  15:50:15.827 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                  15:50:16.050 SRC: MQTT
                  15:50:16.050 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                  15:50:16.061 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                  15:50:16.065 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                  15:50:16.097 SRC: MQTT
                  15:50:16.098 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                  15:50:16.100 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                  15:50:16.101 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                  15:50:16.148 SRC: MQTT
                  15:50:16.149 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                  15:50:16.159 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                  15:50:16.163 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                  15:50:16.198 SRC: MQTT
                  15:50:16.198 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                  15:50:16.202 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                  15:50:16.205 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                  15:50:16.248 SRC: MQTT
                  15:50:16.249 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                  15:50:16.259 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                  15:50:16.263 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                  15:50:16.298 SRC: MQTT
                  15:50:16.298 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                  15:50:16.302 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                  15:50:16.305 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                  15:50:17.799 SRC: MQTT
                  15:50:17.800 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~21:52'
                  15:50:17.813 NXP: payload sent = bytes('55BB0A0074696D657E32313A3532BA43')
                  15:50:17.817 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                  15:50:17.849 SRC: MQTT
                  15:50:17.850 CMD: Grp 0, Cmd 'POWER', Idx 1, Len 3, Pld -99, Data 'NaN'
                  15:50:17.852 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                  15:50:17.853 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                  15:50:17.956 QPC: Reset
                  15:50:19.949 APP: Startvorgänge 172
                  15:50:19.956 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2025-09-12T15:50:19","Uptime":"0T00:00:09","UptimeSec":9,"Heap":146,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":237,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":212},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"FR@smart","BSSId":"7E:8A:20:51:6B:CA","Channel":9,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:04"}}
                  15:50:20.001 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2025-09-12T15:50:19","ANALOG":{"Temperature1":28.5},"ESP32":{"Temperature":58.9},"TempUnit":"C"}
                  15:50:20.424 CFG: Saved, Anzahl 1519, Bytes 4096
                  15:50:20.441 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
                  15:50:20.442 SRC: WebConsole from 10.68.0.156
                  15:50:20.442 CMD: Grp 0, Cmd 'FLASHNEXTIONADV', Idx 0, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v5.0.0.tft'
                  15:50:20.449 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                  15:50:20.482 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
                  15:50:20.539 FLH: Connected:true
                  15:50:20.641 FLH: Retry 2
                  15:50:20.854 FLH: HTTP Respose is 200 OK or 206 Partial Content
                  15:50:20.855 FLH: Flash file size: 12197684
                  15:50:20.856 SRC: Berry
                  15:50:20.857 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                  15:50:20.863 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                  15:50:20.868 SRC: Berry
                  15:50:20.869 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                  15:50:20.873 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                  15:50:20.888 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                  15:50:20.892 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                  15:50:20.894 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                  15:50:20.900 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                  15:50:22.280 FLH: Send (High Speed) flash start
                  15:50:22.286 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
                  15:50:22.309 BRY: Serial UART2
                  15:50:22.666 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                  15:50:22.759 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                  15:50:22.859 FLH: Waiting offset...
                  15:50:27.659 FLH: Flash offset marker 0
                  15:50:27.760 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                  15:50:27.958 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                  15:50:28.090 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                  15:50:28.200 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395
                  15:50:28.314 FLH: Read block - Writing: 4096 - Total: 24576 - Buffer size: 1395
                  15:50:28.426 FLH: Read block - Writing: 4096 - Total: 28672 - Buffer size: 1395
                  15:50:28.533 FLH: Read block - Writing: 4096 - Total: 32768 - Buffer size: 1395
                  15:50:28.642 FLH: Read block - Writing: 4096 - Total: 36864 - Buffer size: 1395
                  15:50:28.751 FLH: Read block - Writing: 4096 - Total: 40960 - Buffer size: 1395
                  15:50:28.859 FLH: Read block - Writing: 4096 - Total: 45056 - Buffer size: 1395
                  15:50:28.971 FLH: Read block - Writing: 4096 - Total: 49152 - Buffer size: 1395
                  15:50:29.080 FLH: Read block - Writing: 4096 - Total: 53248 - Buffer size: 1395
                  15:50:29.189 FLH: Read block - Writing: 4096 - Total: 57344 - Buffer size: 1395
                  15:50:29.301 FLH: Read block - Writing: 4096 - Total: 61440 - Buffer size: 1395
                  15:50:29.409 FLH: Read block - Writing: 4096 - Total: 65536 - Buffer size: 1395
                  15:50:29.522 FLH: Read block - Writing: 4096 - Total: 69632 - Buffer size: 1395
                  15:50:29.858 FLH: Read block - Writing: 4096 - Total: 73728 - Buffer size: 1395
                  15:50:29.968 FLH: Read block - Writing: 4096 - Total: 77824 - Buffer size: 1395
                  15:50:30.158 FLH: Read block - Writing: 4096 - Total: 81920 - Buffer size: 1395
                  15:50:30.273 FLH: Read block - Writing: 4096 - Total: 86016 - Buffer size: 1395
                  15:50:30.456 FLH: Read block - Writing: 4096 - Total: 90112 - Buffer size: 1395
                  15:51:30.657 FLH: Read block - Writing: 4096 - Total: 1478656 - Buffer size: 1395
                  15:51:30.858 FLH: Read block - Writing: 4096 - Total: 1482752 - Buffer size: 1395
                  15:51:31.058 FLH: Read block - Writing: 4096 - Total: 1486848 - Buffer size: 1395
                  15:51:31.168 FLH: Read block - Writing: 4096 - Total: 1490944 - Buffer size: 1395
                  15:51:31.280 FLH: Read block - Writing: 4096 - Total: 1495040 - Buffer size: 1395
                  15:51:31.458 FLH: Read block - Writing: 4096 - Total: 1499136 - Buffer size: 1395
                  15:51:31.656 FLH: Read block - Writing: 4096 - Total: 1503232 - Buffer size: 1395
                  15:51:31.858 FLH: Read block - Writing: 4096 - Total: 1507328 - Buffer size: 1395
                  15:51:32.058 FLH: Read block - Writing: 4096 - Total: 1511424 - Buffer size: 1395
                  15:51:32.263 FLH: Read block - Writing: 4096 - Total: 1515520 - Buffer size: 1395
                  15:51:32.458 FLH: Read block - Writing: 4096 - Total: 1519616 - Buffer size: 1395
                  15:51:32.657 FLH: Read block - Writing: 4096 - Total: 1523712 - Buffer size: 1395
                  15:51:32.858 FLH: Read block - Writing: 4096 - Total: 1527808 - Buffer size: 1395
                  15:51:32.970 FLH: Read block - Writing: 4096 - Total: 1531904 - Buffer size: 1395
                  15:51:33.158 FLH: Read block - Writing: 4096 - Total: 1536000 - Buffer size: 1395
                  15:51:33.275 FLH: Read block - Writing: 4096 - Total: 1540096 - Buffer size: 1395
                  15:51:33.457 FLH: Read block - Writing: 4096 - Total: 1544192 - Buffer size: 1395
                  15:51:33.658 FLH: Read block - Writing: 4096 - Total: 1548288 - Buffer size: 1395
                  15:51:33.856 FLH: Read block - Writing: 4096 - Total: 1552384 - Buffer size: 1395
                  15:51:33.969 FLH: Read block - Writing: 4096 - Total: 1556480 - Buffer size: 1395
                  15:51:34.157 FLH: Read block - Writing: 4096 - Total: 1560576 - Buffer size: 1395
                  15:51:34.271 FLH: Read block - Writing: 4096 - Total: 1564672 - Buffer size: 1395
                  15:51:34.457 FLH: Read block - Writing: 4096 - Total: 1568768 - Buffer size: 1395
                  15:51:34.657 FLH: Read block - Writing: 4096 - Total: 1572864 - Buffer size: 1395
                  15:51:34.857 FLH: Read block - Writing: 4096 - Total: 1576960 - Buffer size: 1395
                  15:51:35.058 FLH: Read block - Writing: 4096 - Total: 1581056 - Buffer size: 1395
                  15:51:35.264 FLH: Read block - Writing: 4096 - Total: 1585152 - Buffer size: 1395
                  15:51:35.456 FLH: Read block - Writing: 4096 - Total: 1589248 - Buffer size: 1395
                  15:51:35.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "13", "time_elapsed": 73}}
                  15:51:35.664 FLH: Read block - Writing: 4096 - Total: 1593344 - Buffer size: 1395
                  15:51:35.858 FLH: Read block - Writing: 4096 - Total: 1597440 - Buffer size: 1395
                  15:51:35.968 FLH: Read block - Writing: 4096 - Total: 1601536 - Buffer size: 1395
                  15:51:36.158 FLH: Read block - Writing: 4096 - Total: 1605632 - Buffer size: 1395
                  15:51:36.273 FLH: Read block - Writing: 4096 - Total: 1609728 - Buffer size: 1395
                  15:51:36.456 FLH: Read block - Writing: 4096 - Total: 1613824 - Buffer size: 1395
                  15:51:36.658 FLH: Read block - Writing: 4096 - Total: 1617920 - Buffer size: 1395
                  15:51:36.858 FLH: Read block - Writing: 4096 - Total: 1622016 - Buffer size: 1395
                  15:51:36.968 FLH: Read block - Writing: 4096 - Total: 1626112 - Buffer size: 1395
                  15:51:37.158 FLH: Read block - Writing: 4096 - Total: 1630208 - Buffer size: 1395
                  15:51:37.273 FLH: Read block - Writing: 4096 - Total: 1634304 - Buffer size: 1395
                  15:51:37.457 FLH: Read block - Writing: 4096 - Total: 1638400 - Buffer size: 1395
                  15:51:37.657 FLH: Read block - Writing: 4096 - Total: 1642496 - Buffer size: 1395
                  15:51:37.858 FLH: Read block - Writing: 4096 - Total: 1646592 - Buffer size: 1395
                  15:51:37.969 FLH: Read block - Writing: 4096 - Total: 1650688 - Buffer size: 1395
                  15:51:38.157 FLH: Read block - Writing: 4096 - Total: 1654784 - Buffer size: 1395
                  15:51:38.273 FLH: Read block - Writing: 4096 - Total: 1658880 - Buffer size: 1395
                  15:51:38.456 FLH: Read block - Writing: 4096 - Total: 1662976 - Buffer size: 1395
                  15:51:38.657 FLH: Read block - Writing: 4096 - Total: 1667072 - Buffer size: 1395
                  15:51:38.857 FLH: Read block - Writing: 4096 - Total: 1671168 - Buffer size: 1395
                  15:51:38.967 FLH: Read block - Writing: 4096 - Total: 1675264 - Buffer size: 311
                  15:51:39.157 FLH: Read block - Writing: 4096 - Total: 1679360 - Buffer size: 311
                  15:51:39.325 FLH: Read block - Writing: 4096 - Total: 1683456 - Buffer size: 1959
                  15:51:39.439 FLH: Read block - Writing: 4096 - Total: 1687552 - Buffer size: 1959
                  15:51:39.558 FLH: Read block - Writing: 4096 - Total: 1691648 - Buffer size: 1959
                  15:51:39.758 FLH: Read block - Writing: 4096 - Total: 1695744 - Buffer size: 1959
                  15:51:39.958 FLH: Read block - Writing: 4096 - Total: 1699840 - Buffer size: 1959
                  15:51:40.158 FLH: Read block - Writing: 4096 - Total: 1703936 - Buffer size: 1959
                  15:51:40.272 FLH: Read block - Writing: 4096 - Total: 1708032 - Buffer size: 1959
                  15:51:40.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "14", "time_elapsed": 78}}
                  15:51:40.565 FLH: Read block - Writing: 4096 - Total: 1712128 - Buffer size: 1959
                  15:51:40.758 FLH: Read block - Writing: 4096 - Total: 1716224 - Buffer size: 1959
                  15:51:40.958 FLH: Read block - Writing: 4096 - Total: 1720320 - Buffer size: 1959
                  15:51:41.158 FLH: Read block - Writing: 4096 - Total: 1724416 - Buffer size: 1959
                  15:51:41.273 FLH: Read block - Writing: 4096 - Total: 1728512 - Buffer size: 1959
                  15:51:41.458 FLH: Read block - Writing: 4096 - Total: 1732608 - Buffer size: 1959
                  15:51:41.657 FLH: Read block - Writing: 4096 - Total: 1736704 - Buffer size: 1959
                  15:51:41.859 FLH: Read block - Writing: 4096 - Total: 1740800 - Buffer size: 1959
                  15:51:41.971 FLH: Read block - Writing: 4096 - Total: 1744896 - Buffer size: 1959
                  15:51:42.158 FLH: Read block - Writing: 4096 - Total: 1748992 - Buffer size: 1959
                  15:51:42.275 FLH: Read block - Writing: 4096 - Total: 1753088 - Buffer size: 1959
                  15:51:42.458 FLH: Read block - Writing: 4096 - Total: 1757184 - Buffer size: 1959
                  15:51:42.660 FLH: Read block - Writing: 4096 - Total: 1761280 - Buffer size: 1959
                  15:51:42.911 FLH: Read block - Writing: 4096 - Total: 1765376 - Buffer size: 1959
                  15:51:43.023 FLH: Read block - Writing: 4096 - Total: 1769472 - Buffer size: 1959
                  15:51:43.157 FLH: Read block - Writing: 4096 - Total: 1773568 - Buffer size: 1959
                  15:51:43.458 FLH: Read block - Writing: 4096 - Total: 1777664 - Buffer size: 1959
                  15:51:43.657 FLH: Read block - Writing: 4096 - Total: 1781760 - Buffer size: 1959
                  15:51:43.857 FLH: Read block - Writing: 4096 - Total: 1785856 - Buffer size: 1959
                  15:51:43.969 FLH: Read block - Writing: 4096 - Total: 1789952 - Buffer size: 1959
                  15:51:44.157 FLH: Read block - Writing: 4096 - Total: 1794048 - Buffer size: 1959
                  15:51:44.272 FLH: Read block - Writing: 4096 - Total: 1798144 - Buffer size: 1959
                  15:51:44.457 FLH: Read block - Writing: 4096 - Total: 1802240 - Buffer size: 1959
                  15:51:44.658 FLH: Read block - Writing: 4096 - Total: 1806336 - Buffer size: 1959
                  15:51:44.858 FLH: Read block - Writing: 4096 - Total: 1810432 - Buffer size: 1959
                  15:51:45.058 FLH: Read block - Writing: 4096 - Total: 1814528 - Buffer size: 1959
                  15:51:45.263 FLH: Read block - Writing: 4096 - Total: 1818624 - Buffer size: 1959
                  15:51:45.410 FLH: Read block - Writing: 4096 - Total: 1822720 - Buffer size: 1959
                  15:51:45.559 FLH: Read block - Writing: 4096 - Total: 1826816 - Buffer size: 1959
                  15:51:45.758 FLH: Read block - Writing: 4096 - Total: 1830912 - Buffer size: 1959
                  15:51:45.872 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "15", "time_elapsed": 83}}
                  15:51:45.965 FLH: Read block - Writing: 4096 - Total: 1835008 - Buffer size: 1959
                  15:51:46.158 FLH: Read block - Writing: 4096 - Total: 1839104 - Buffer size: 1959
                  15:51:46.360 FLH: Read block - Writing: 4096 - Total: 1843200 - Buffer size: 1959
                  15:51:46.558 FLH: Read block - Writing: 4096 - Total: 1847296 - Buffer size: 1959
                  15:51:46.758 FLH: Read block - Writing: 4096 - Total: 1851392 - Buffer size: 1959
                  15:51:46.958 FLH: Read block - Writing: 4096 - Total: 1855488 - Buffer size: 1959
                  15:51:47.158 FLH: Read block - Writing: 4096 - Total: 1859584 - Buffer size: 1959
                  15:51:47.273 FLH: Read block - Writing: 4096 - Total: 1863680 - Buffer size: 1959
                  15:51:47.458 FLH: Read block - Writing: 4096 - Total: 1867776 - Buffer size: 1959
                  15:51:47.658 FLH: Read block - Writing: 4096 - Total: 1871872 - Buffer size: 1959
                  15:51:47.857 FLH: Read block - Writing: 4096 - Total: 1875968 - Buffer size: 1959
                  15:51:48.058 FLH: Read block - Writing: 4096 - Total: 1880064 - Buffer size: 1959
                  15:51:48.264 FLH: Read block - Writing: 4096 - Total: 1884160 - Buffer size: 1959
                  15:51:48.458 FLH: Read block - Writing: 4096 - Total: 1888256 - Buffer size: 1959
                  15:51:48.658 FLH: Read block - Writing: 4096 - Total: 1892352 - Buffer size: 1959
                  15:51:48.858 FLH: Read block - Writing: 4096 - Total: 1896448 - Buffer size: 1959
                  15:51:49.057 FLH: Read block - Writing: 4096 - Total: 1900544 - Buffer size: 1959
                  15:51:49.263 FLH: Read block - Writing: 4096 - Total: 1904640 - Buffer size: 1959
                  15:51:49.458 FLH: Read block - Writing: 4096 - Total: 1908736 - Buffer size: 1959
                  15:51:49.658 FLH: Read block - Writing: 4096 - Total: 1912832 - Buffer size: 1959
                  15:51:49.858 FLH: Read block - Writing: 4096 - Total: 1916928 - Buffer size: 1959
                  15:51:50.058 FLH: Read block - Writing: 4096 - Total: 1921024 - Buffer size: 1959
                  15:51:50.264 FLH: Read block - Writing: 4096 - Total: 1925120 - Buffer size: 1959
                  15:51:50.411 FLH: Read block - Writing: 4096 - Total: 1929216 - Buffer size: 1959
                  15:51:50.558 FLH: Read block - Writing: 4096 - Total: 1933312 - Buffer size: 1959
                  15:51:50.757 FLH: Read block - Writing: 4096 - Total: 1937408 - Buffer size: 1959
                  15:51:50.956 FLH: Read block - Writing: 4096 - Total: 1941504 - Buffer size: 1959
                  15:51:51.157 FLH: Read block - Writing: 4096 - Total: 1945600 - Buffer size: 1959
                  15:51:51.273 FLH: Read block - Writing: 4096 - Total: 1949696 - Buffer size: 1959
                  15:51:51.457 FLH: Read block - Writing: 4096 - Total: 1953792 - Buffer size: 1959
                  15:51:51.570 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "16", "time_elapsed": 89}}
                  15:51:51.662 FLH: Read block - Writing: 4096 - Total: 1957888 - Buffer size: 1959
                  15:51:51.857 FLH: Read block - Writing: 4096 - Total: 1961984 - Buffer size: 1959
                  15:51:51.970 FLH: Read block - Writing: 4096 - Total: 1966080 - Buffer size: 1959
                  15:51:52.157 FLH: Read block - Writing: 4096 - Total: 1970176 - Buffer size: 1959
                  15:51:52.359 FLH: Read block - Writing: 4096 - Total: 1974272 - Buffer size: 1959
                  15:51:52.558 FLH: Read block - Writing: 4096 - Total: 1978368 - Buffer size: 1959
                  15:51:52.757 FLH: Read block - Writing: 4096 - Total: 1982464 - Buffer size: 1959
                  15:51:52.902 FLH: Read block - Writing: 4096 - Total: 1986560 - Buffer size: 1959
                  15:51:53.016 FLH: Read block - Writing: 4096 - Total: 1990656 - Buffer size: 1959
                  15:51:53.158 FLH: Read block - Writing: 4096 - Total: 1994752 - Buffer size: 1959
                  15:51:53.272 FLH: Read block - Writing: 4096 - Total: 1998848 - Buffer size: 1959
                  15:51:53.458 FLH: Read block - Writing: 4096 - Total: 2002944 - Buffer size: 1959
                  15:51:53.658 FLH: Read block - Writing: 4096 - Total: 2007040 - Buffer size: 1959
                  15:51:53.857 FLH: Read block - Writing: 4096 - Total: 2011136 - Buffer size: 1959
                  15:51:53.969 FLH: Read block - Writing: 4096 - Total: 2015232 - Buffer size: 1959
                  15:51:54.157 FLH: Read block - Writing: 4096 - Total: 2019328 - Buffer size: 1959
                  15:51:54.272 FLH: Read block - Writing: 4096 - Total: 2023424 - Buffer size: 1959
                  15:51:54.458 FLH: Read block - Writing: 4096 - Total: 2027520 - Buffer size: 1959
                  15:51:54.658 FLH: Read block - Writing: 4096 - Total: 2031616 - Buffer size: 1959
                  15:51:54.858 FLH: Read block - Writing: 4096 - Total: 2035712 - Buffer size: 1959
                  15:51:55.058 FLH: Read block - Writing: 4096 - Total: 2039808 - Buffer size: 1959
                  15:51:55.264 FLH: Read block - Writing: 4096 - Total: 2043904 - Buffer size: 1959
                  15:51:55.458 FLH: Read block - Writing: 4096 - Total: 2048000 - Buffer size: 1959
                  15:51:55.658 FLH: Read block - Writing: 4096 - Total: 2052096 - Buffer size: 1959
                  15:51:55.858 FLH: Read block - Writing: 4096 - Total: 2056192 - Buffer size: 1959
                  15:51:56.058 FLH: Read block - Writing: 4096 - Total: 2060288 - Buffer size: 1959
                  15:51:56.264 FLH: Read block - Writing: 4096 - Total: 2064384 - Buffer size: 1959
                  15:51:56.457 FLH: Read block - Writing: 4096 - Total: 2068480 - Buffer size: 1959
                  15:51:56.658 FLH: Read block - Writing: 4096 - Total: 2072576 - Buffer size: 1959
                  15:51:56.858 FLH: Read block - Writing: 4096 - Total: 2076672 - Buffer size: 1959
                  15:51:56.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "17", "time_elapsed": 94}}
                  15:51:57.064 FLH: Read block - Writing: 4096 - Total: 2080768 - Buffer size: 1959
                  15:51:57.264 FLH: Read block - Writing: 4096 - Total: 2084864 - Buffer size: 1959
                  15:51:57.458 FLH: Read block - Writing: 4096 - Total: 2088960 - Buffer size: 1959
                  15:51:57.658 FLH: Read block - Writing: 4096 - Total: 2093056 - Buffer size: 1959
                  15:51:57.857 FLH: Read block - Writing: 4096 - Total: 2097152 - Buffer size: 1959
                  15:51:58.058 FLH: Read block - Writing: 4096 - Total: 2101248 - Buffer size: 1959
                  15:51:58.263 FLH: Read block - Writing: 4096 - Total: 2105344 - Buffer size: 1959
                  15:51:58.458 FLH: Read block - Writing: 4096 - Total: 2109440 - Buffer size: 1959
                  15:51:58.657 FLH: Read block - Writing: 4096 - Total: 2113536 - Buffer size: 1959
                  15:51:58.858 FLH: Read block - Writing: 4096 - Total: 2117632 - Buffer size: 1959
                  15:51:58.970 FLH: Read block - Writing: 4096 - Total: 2121728 - Buffer size: 1959
                  15:51:59.158 FLH: Read block - Writing: 4096 - Total: 2125824 - Buffer size: 1959
                  15:51:59.276 FLH: Read block - Writing: 4096 - Total: 2129920 - Buffer size: 1959
                  15:51:59.457 FLH: Read block - Writing: 4096 - Total: 2134016 - Buffer size: 1959
                  15:51:59.658 FLH: Read block - Writing: 4096 - Total: 2138112 - Buffer size: 1959
                  15:51:59.858 FLH: Read block - Writing: 4096 - Total: 2142208 - Buffer size: 1959
                  15:52:00.058 FLH: Read block - Writing: 4096 - Total: 2146304 - Buffer size: 1959
                  15:52:00.264 FLH: Read block - Writing: 4096 - Total: 2150400 - Buffer size: 1959
                  15:52:00.457 FLH: Read block - Writing: 4096 - Total: 2154496 - Buffer size: 1959
                  15:52:00.605 FLH: Read block - Writing: 4096 - Total: 2158592 - Buffer size: 1959
                  15:52:00.757 FLH: Read block - Writing: 4096 - Total: 2162688 - Buffer size: 1959
                  15:52:00.958 FLH: Read block - Writing: 4096 - Total: 2166784 - Buffer size: 1959
                  15:52:01.156 FLH: Read block - Writing: 4096 - Total: 2170880 - Buffer size: 1959
                  15:52:01.271 FLH: Read block - Writing: 4096 - Total: 2174976 - Buffer size: 1959
                  15:52:01.455 FLH: Read block - Writing: 4096 - Total: 2179072 - Buffer size: 1959
                  15:52:01.656 FLH: Read block - Writing: 4096 - Total: 2183168 - Buffer size: 1959
                  15:52:01.856 FLH: Read block - Writing: 4096 - Total: 2187264 - Buffer size: 1959
                  15:52:02.058 FLH: Read block - Writing: 4096 - Total: 2191360 - Buffer size: 1959
                  15:52:02.264 FLH: Read block - Writing: 4096 - Total: 2195456 - Buffer size: 1959
                  15:52:02.458 FLH: Read block - Writing: 4096 - Total: 2199552 - Buffer size: 1959
                  15:52:02.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "18", "time_elapsed": 100}}
                  15:52:02.664 FLH: Read block - Writing: 4096 - Total: 2203648 - Buffer size: 1959
                  15:52:02.857 FLH: Read block - Writing: 4096 - Total: 2207744 - Buffer size: 1959
                  15:52:03.058 FLH: Read block - Writing: 4096 - Total: 2211840 - Buffer size: 1959
                  15:52:03.203 FLH: Read block - Writing: 4096 - Total: 2215936 - Buffer size: 1959
                  15:52:03.320 FLH: Read block - Writing: 4096 - Total: 2220032 - Buffer size: 1959
                  15:52:03.432 FLH: Read block - Writing: 4096 - Total: 2224128 - Buffer size: 1959
                  15:52:03.560 FLH: Read block - Writing: 4096 - Total: 2228224 - Buffer size: 1959
                  15:52:03.758 FLH: Read block - Writing: 4096 - Total: 2232320 - Buffer size: 1959
                  15:52:03.957 FLH: Read block - Writing: 4096 - Total: 2236416 - Buffer size: 1959
                  15:52:04.157 FLH: Read block - Writing: 4096 - Total: 2240512 - Buffer size: 1959
                  15:52:04.274 FLH: Read block - Writing: 4096 - Total: 2244608 - Buffer size: 1959
                  15:52:04.459 FLH: Read block - Writing: 4096 - Total: 2248704 - Buffer size: 1959
                  15:52:04.658 FLH: Read block - Writing: 4096 - Total: 2252800 - Buffer size: 1959
                  15:52:04.857 FLH: Read block - Writing: 4096 - Total: 2256896 - Buffer size: 1959
                  15:52:05.058 FLH: Read block - Writing: 4096 - Total: 2260992 - Buffer size: 1959
                  15:52:05.263 FLH: Read block - Writing: 4096 - Total: 2265088 - Buffer size: 1959
                  15:52:05.457 FLH: Read block - Writing: 4096 - Total: 2269184 - Buffer size: 1959
                  15:52:05.658 FLH: Read block - Writing: 4096 - Total: 2273280 - Buffer size: 1959
                  15:52:05.807 FLH: Read block - Writing: 4096 - Total: 2277376 - Buffer size: 1959
                  15:52:05.958 FLH: Read block - Writing: 4096 - Total: 2281472 - Buffer size: 1959
                  15:52:06.158 FLH: Read block - Writing: 4096 - Total: 2285568 - Buffer size: 1959
                  15:52:06.273 FLH: Read block - Writing: 4096 - Total: 2289664 - Buffer size: 1959
                  15:52:06.457 FLH: Read block - Writing: 4096 - Total: 2293760 - Buffer size: 1959
                  15:52:06.658 FLH: Read block - Writing: 4096 - Total: 2297856 - Buffer size: 1959
                  15:52:06.858 FLH: Read block - Writing: 4096 - Total: 2301952 - Buffer size: 1959
                  15:52:06.970 FLH: Read block - Writing: 4096 - Total: 2306048 - Buffer size: 1959
                  15:52:07.157 FLH: Read block - Writing: 4096 - Total: 2310144 - Buffer size: 1959
                  15:52:07.273 FLH: Read block - Writing: 4096 - Total: 2314240 - Buffer size: 1959
                  15:52:07.456 FLH: Read block - Writing: 4096 - Total: 2318336 - Buffer size: 1959
                  15:52:07.571 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "19", "time_elapsed": 105}}
                  15:52:07.664 FLH: Read block - Writing: 4096 - Total: 2322432 - Buffer size: 1959
                  15:52:07.858 FLH: Read block - Writing: 4096 - Total: 2326528 - Buffer size: 1959
                  15:52:08.058 FLH: Read block - Writing: 4096 - Total: 2330624 - Buffer size: 1959
                  15:52:08.264 FLH: Read block - Writing: 4096 - Total: 2334720 - Buffer size: 1959
                  15:52:08.457 FLH: Read block - Writing: 4096 - Total: 2338816 - Buffer size: 1959
                  15:52:08.658 FLH: Read block - Writing: 4096 - Total: 2342912 - Buffer size: 1959
                  15:52:08.857 FLH: Read block - Writing: 4096 - Total: 2347008 - Buffer size: 1959
                  15:52:09.058 FLH: Read block - Writing: 4096 - Total: 2351104 - Buffer size: 1959
                  15:52:09.264 FLH: Read block - Writing: 4096 - Total: 2355200 - Buffer size: 1959
                  15:52:09.457 FLH: Read block - Writing: 4096 - Total: 2359296 - Buffer size: 1959
                  15:52:09.658 FLH: Read block - Writing: 4096 - Total: 2363392 - Buffer size: 1959
                  15:52:09.857 FLH: Read block - Writing: 4096 - Total: 2367488 - Buffer size: 1959
                  15:52:10.058 FLH: Read block - Writing: 4096 - Total: 2371584 - Buffer size: 1959
                  15:52:10.263 FLH: Read block - Writing: 4096 - Total: 2375680 - Buffer size: 1959
                  15:52:10.457 FLH: Read block - Writing: 4096 - Total: 2379776 - Buffer size: 1959
                  15:52:10.658 FLH: Read block - Writing: 4096 - Total: 2383872 - Buffer size: 1959
                  15:52:10.806 FLH: Read block - Writing: 4096 - Total: 2387968 - Buffer size: 1959
                  15:52:10.958 FLH: Read block - Writing: 4096 - Total: 2392064 - Buffer size: 1959
                  15:52:11.157 FLH: Read block - Writing: 4096 - Total: 2396160 - Buffer size: 1959
                  15:52:11.272 FLH: Read block - Writing: 4096 - Total: 2400256 - Buffer size: 1959
                  15:52:11.457 FLH: Read block - Writing: 4096 - Total: 2404352 - Buffer size: 1959
                  15:52:11.658 FLH: Read block - Writing: 4096 - Total: 2408448 - Buffer size: 1959
                  15:52:11.857 FLH: Read block - Writing: 4096 - Total: 2412544 - Buffer size: 1959
                  15:52:12.058 FLH: Read block - Writing: 4096 - Total: 2416640 - Buffer size: 1959
                  15:52:12.263 FLH: Read block - Writing: 4096 - Total: 2420736 - Buffer size: 1959
                  15:52:12.458 FLH: Read block - Writing: 4096 - Total: 2424832 - Buffer size: 1959
                  15:52:12.657 FLH: Read block - Writing: 4096 - Total: 2428928 - Buffer size: 1959
                  15:52:12.858 FLH: Read block - Writing: 4096 - Total: 2433024 - Buffer size: 1959
                  15:52:13.058 FLH: Read block - Writing: 4096 - Total: 2437120 - Buffer size: 1959
                  15:52:13.264 FLH: Read block - Writing: 4096 - Total: 2441216 - Buffer size: 1959
                  15:52:13.328 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "20", "time_elapsed": 111}}
                  15:52:13.420 FLH: Read block - Writing: 4096 - Total: 2445312 - Buffer size: 1959
                  15:52:13.558 FLH: Read block - Writing: 4096 - Total: 2449408 - Buffer size: 1959
                  15:52:13.758 FLH: Read block - Writing: 4096 - Total: 2453504 - Buffer size: 1959
                  15:52:13.957 FLH: Read block - Writing: 4096 - Total: 2457600 - Buffer size: 1959
                  15:52:14.158 FLH: Read block - Writing: 4096 - Total: 2461696 - Buffer size: 1959
                  15:52:14.273 FLH: Read block - Writing: 4096 - Total: 2465792 - Buffer size: 1959
                  15:52:14.458 FLH: Read block - Writing: 4096 - Total: 2469888 - Buffer size: 1959
                  15:52:14.657 FLH: Read block - Writing: 4096 - Total: 2473984 - Buffer size: 1959
                  15:52:14.858 FLH: Read block - Writing: 4096 - Total: 2478080 - Buffer size: 1959
                  15:52:15.058 FLH: Read block - Writing: 4096 - Total: 2482176 - Buffer size: 1959
                  15:52:15.263 FLH: Read block - Writing: 4096 - Total: 2486272 - Buffer size: 1959
                  15:52:15.457 FLH: Read block - Writing: 4096 - Total: 2490368 - Buffer size: 1959
                  15:52:15.658 FLH: Read block - Writing: 4096 - Total: 2494464 - Buffer size: 1959
                  15:52:15.858 FLH: Read block - Writing: 4096 - Total: 2498560 - Buffer size: 1959
                  15:52:16.007 FLH: Read block - Writing: 4096 - Total: 2502656 - Buffer size: 1959
                  15:52:16.157 FLH: Read block - Writing: 4096 - Total: 2506752 - Buffer size: 1959
                  15:52:16.273 FLH: Read block - Writing: 4096 - Total: 2510848 - Buffer size: 1959
                  15:52:16.457 FLH: Read block - Writing: 4096 - Total: 2514944 - Buffer size: 1959
                  15:52:16.658 FLH: Read block - Writing: 4096 - Total: 2519040 - Buffer size: 1959
                  15:52:16.857 FLH: Read block - Writing: 4096 - Total: 2523136 - Buffer size: 1959
                  15:52:17.057 FLH: Read block - Writing: 4096 - Total: 2527232 - Buffer size: 1959
                  15:52:17.266 FLH: Read block - Writing: 4096 - Total: 2531328 - Buffer size: 1959
                  15:52:17.457 FLH: Read block - Writing: 4096 - Total: 2535424 - Buffer size: 1959
                  15:52:17.659 FLH: Read block - Writing: 4096 - Total: 2539520 - Buffer size: 1959
                  15:52:17.858 FLH: Read block - Writing: 4096 - Total: 2543616 - Buffer size: 1959
                  15:52:18.057 FLH: Read block - Writing: 4096 - Total: 2547712 - Buffer size: 1959
                  15:52:18.265 FLH: Read block - Writing: 4096 - Total: 2551808 - Buffer size: 1959
                  15:52:18.377 FLH: Read block - Writing: 4096 - Total: 2555904 - Buffer size: 1959
                  15:52:18.530 FLH: Read block - Writing: 4096 - Total: 2560000 - Buffer size: 1959
                  15:52:18.758 FLH: Read block - Writing: 4096 - Total: 2564096 - Buffer size: 1959
                  15:52:18.871 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "21", "time_elapsed": 116}}
                  15:52:18.963 FLH: Read block - Writing: 4096 - Total: 2568192 - Buffer size: 1959
                  15:52:19.158 FLH: Read block - Writing: 4096 - Total: 2572288 - Buffer size: 1959
                  15:52:19.273 FLH: Read block - Writing: 4096 - Total: 2576384 - Buffer size: 1959
                  15:52:19.458 FLH: Read block - Writing: 4096 - Total: 2580480 - Buffer size: 1959
                  15:52:19.464 HTP: Werkzeuge
                  15:52:19.639 FLH: Read block - Writing: 4096 - Total: 2584576 - Buffer size: 1959
                  15:52:19.758 FLH: Read block - Writing: 4096 - Total: 2588672 - Buffer size: 1959
                  15:52:19.958 FLH: Read block - Writing: 4096 - Total: 2592768 - Buffer size: 1959
                  15:52:20.157 FLH: Read block - Writing: 4096 - Total: 2596864 - Buffer size: 1959
                  15:52:20.272 FLH: Read block - Writing: 4096 - Total: 2600960 - Buffer size: 1959
                  15:52:20.457 FLH: Read block - Writing: 4096 - Total: 2605056 - Buffer size: 1959
                  15:52:20.657 FLH: Read block - Writing: 4096 - Total: 2609152 - Buffer size: 1959
                  15:52:20.858 FLH: Read block - Writing: 4096 - Total: 2613248 - Buffer size: 1959
                  15:52:20.970 FLH: Read block - Writing: 4096 - Total: 2617344 - Buffer size: 1959
                  15:52:21.118 FLH: Read block - Writing: 4096 - Total: 2621440 - Buffer size: 1959
                  15:52:21.127 HTP: Hauptmenü
                  15:52:21.316 FLH: Read block - Writing: 4096 - Total: 2625536 - Buffer size: 1959
                  15:52:21.558 FLH: Read block - Writing: 4096 - Total: 2629632 - Buffer size: 1959
                  15:52:21.757 FLH: Read block - Writing: 4096 - Total: 2633728 - Buffer size: 1959
                  15:52:21.957 FLH: Read block - Writing: 4096 - Total: 2637824 - Buffer size: 1959
                  15:52:22.158 FLH: Read block - Writing: 4096 - Total: 2641920 - Buffer size: 1959
                  15:52:22.274 FLH: Read block - Writing: 4096 - Total: 2646016 - Buffer size: 1959
                  15:52:22.458 FLH: Read block - Writing: 4096 - Total: 2650112 - Buffer size: 1959
                  15:52:22.657 FLH: Read block - Writing: 4096 - Total: 2654208 - Buffer size: 1959
                  15:52:22.858 FLH: Read block - Writing: 4096 - Total: 2658304 - Buffer size: 1959
                  15:52:23.058 FLH: Read block - Writing: 4096 - Total: 2662400 - Buffer size: 1959
                  15:52:23.264 FLH: Read block - Writing: 4096 - Total: 2666496 - Buffer size: 1959
                  15:52:23.458 FLH: Read block - Writing: 4096 - Total: 2670592 - Buffer size: 1959
                  15:52:23.604 FLH: Read block - Writing: 4096 - Total: 2674688 - Buffer size: 1959
                  15:52:23.757 FLH: Read block - Writing: 4096 - Total: 2678784 - Buffer size: 1959
                  15:52:23.907 FLH: Read block - Writing: 4096 - Total: 2682880 - Buffer size: 1959
                  15:52:24.057 FLH: Read block - Writing: 4096 - Total: 2686976 - Buffer size: 1959
                  15:52:24.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "22", "time_elapsed": 121}}
                  15:52:24.271 FLH: Read block - Writing: 4096 - Total: 2691072 - Buffer size: 1959
                  15:52:24.457 FLH: Read block - Writing: 4096 - Total: 2695168 - Buffer size: 1959
                  15:52:24.659 FLH: Read block - Writing: 4096 - Total: 2699264 - Buffer size: 1959
                  15:52:24.859 FLH: Read block - Writing: 4096 - Total: 2703360 - Buffer size: 1959
                  15:52:25.056 FLH: Read block - Writing: 4096 - Total: 2707456 - Buffer size: 1959
                  15:52:25.265 FLH: Read block - Writing: 4096 - Total: 2711552 - Buffer size: 1959
                  15:52:25.458 FLH: Read block - Writing: 4096 - Total: 2715648 - Buffer size: 1959
                  15:52:25.658 FLH: Read block - Writing: 4096 - Total: 2719744 - Buffer size: 1959
                  15:52:25.859 FLH: Read block - Writing: 4096 - Total: 2723840 - Buffer size: 1959
                  15:52:26.012 FLH: Read block - Writing: 4096 - Total: 2727936 - Buffer size: 1959
                  15:52:26.157 FLH: Read block - Writing: 4096 - Total: 2732032 - Buffer size: 1959
                  15:52:26.274 FLH: Read block - Writing: 4096 - Total: 2736128 - Buffer size: 1959
                  15:52:26.425 FLH: Read block - Writing: 4096 - Total: 2740224 - Buffer size: 1959
                  15:52:26.558 FLH: Read block - Writing: 4096 - Total: 2744320 - Buffer size: 1959
                  15:52:26.758 FLH: Read block - Writing: 4096 - Total: 2748416 - Buffer size: 1959
                  15:52:26.958 FLH: Read block - Writing: 4096 - Total: 2752512 - Buffer size: 1959
                  15:52:27.158 FLH: Read block - Writing: 4096 - Total: 2756608 - Buffer size: 1959
                  15:52:27.359 FLH: Read block - Writing: 4096 - Total: 2760704 - Buffer size: 1959
                  15:52:27.558 FLH: Read block - Writing: 4096 - Total: 2764800 - Buffer size: 1959
                  15:52:27.757 FLH: Read block - Writing: 4096 - Total: 2768896 - Buffer size: 1959
                  15:52:27.958 FLH: Read block - Writing: 4096 - Total: 2772992 - Buffer size: 1959
                  15:52:28.158 FLH: Read block - Writing: 4096 - Total: 2777088 - Buffer size: 1959
                  15:52:28.275 FLH: Read block - Writing: 4096 - Total: 2781184 - Buffer size: 1959
                  15:52:28.458 FLH: Read block - Writing: 4096 - Total: 2785280 - Buffer size: 1959
                  15:52:28.604 FLH: Read block - Writing: 4096 - Total: 2789376 - Buffer size: 1959
                  15:52:28.757 FLH: Read block - Writing: 4096 - Total: 2793472 - Buffer size: 1959
                  15:52:28.906 FLH: Read block - Writing: 4096 - Total: 2797568 - Buffer size: 1959
                  15:52:29.058 FLH: Read block - Writing: 4096 - Total: 2801664 - Buffer size: 1959
                  15:52:29.264 FLH: Read block - Writing: 4096 - Total: 2805760 - Buffer size: 1959
                  15:52:29.371 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "23", "time_elapsed": 127}}
                  15:52:29.464 FLH: Read block - Writing: 4096 - Total: 2809856 - Buffer size: 1959
                  15:52:29.658 FLH: Read block - Writing: 4096 - Total: 2813952 - Buffer size: 1959
                  15:52:29.858 FLH: Read block - Writing: 4096 - Total: 2818048 - Buffer size: 1959
                  15:52:29.970 FLH: Read block - Writing: 4096 - Total: 2822144 - Buffer size: 1959
                  15:52:30.264 FLH: Read block - Writing: 4096 - Total: 2826240 - Buffer size: 1959
                  15:52:30.457 FLH: Read block - Writing: 4096 - Total: 2830336 - Buffer size: 1959
                  15:52:30.658 FLH: Read block - Writing: 4096 - Total: 2834432 - Buffer size: 1959
                  15:52:30.858 FLH: Read block - Writing: 4096 - Total: 2838528 - Buffer size: 1959
                  15:52:31.057 FLH: Read block - Writing: 4096 - Total: 2842624 - Buffer size: 1959
                  15:52:31.263 FLH: Read block - Writing: 4096 - Total: 2846720 - Buffer size: 1959
                  15:52:31.458 FLH: Read block - Writing: 4096 - Total: 2850816 - Buffer size: 1959
                  15:52:31.658 FLH: Read block - Writing: 4096 - Total: 2854912 - Buffer size: 1959
                  15:52:31.858 FLH: Read block - Writing: 4096 - Total: 2859008 - Buffer size: 1959
                  15:52:32.058 FLH: Read block - Writing: 4096 - Total: 2863104 - Buffer size: 1959
                  15:52:32.264 FLH: Read block - Writing: 4096 - Total: 2867200 - Buffer size: 1959
                  15:52:32.458 FLH: Read block - Writing: 4096 - Total: 2871296 - Buffer size: 1959
                  15:52:32.657 FLH: Read block - Writing: 4096 - Total: 2875392 - Buffer size: 1959
                  15:52:32.858 FLH: Read block - Writing: 4096 - Total: 2879488 - Buffer size: 1959
                  15:52:33.057 FLH: Read block - Writing: 4096 - Total: 2883584 - Buffer size: 1959
                  15:52:33.263 FLH: Read block - Writing: 4096 - Total: 2887680 - Buffer size: 1959
                  15:52:33.457 FLH: Read block - Writing: 4096 - Total: 2891776 - Buffer size: 1959
                  15:52:33.603 FLH: Read block - Writing: 4096 - Total: 2895872 - Buffer size: 1959
                  15:52:33.757 FLH: Read block - Writing: 4096 - Total: 2899968 - Buffer size: 1959
                  15:52:33.906 FLH: Read block - Writing: 4096 - Total: 2904064 - Buffer size: 1959
                  15:52:34.058 FLH: Read block - Writing: 4096 - Total: 2908160 - Buffer size: 1959
                  15:52:34.265 FLH: Read block - Writing: 4096 - Total: 2912256 - Buffer size: 1959
                  15:52:34.458 FLH: Read block - Writing: 4096 - Total: 2916352 - Buffer size: 1959
                  15:52:34.659 FLH: Read block - Writing: 4096 - Total: 2920448 - Buffer size: 1959
                  15:52:34.859 FLH: Read block - Writing: 4096 - Total: 2924544 - Buffer size: 1959
                  15:52:35.056 FLH: Read block - Writing: 4096 - Total: 2928640 - Buffer size: 1959
                  15:52:35.178 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "24", "time_elapsed": 132}}
                  15:52:35.270 FLH: Read block - Writing: 4096 - Total: 2932736 - Buffer size: 1959
                  15:52:35.457 FLH: Read block - Writing: 4096 - Total: 2936832 - Buffer size: 1959
                  15:52:35.658 FLH: Read block - Writing: 4096 - Total: 2940928 - Buffer size: 1959
                  15:52:35.857 FLH: Read block - Writing: 4096 - Total: 2945024 - Buffer size: 1959
                  15:52:35.969 FLH: Read block - Writing: 4096 - Total: 2949120 - Buffer size: 1959
                  15:52:36.167 FLH: Read block - Writing: 4096 - Total: 2953216 - Buffer size: 1959
                  15:52:36.358 FLH: Read block - Writing: 4096 - Total: 2957312 - Buffer size: 1959
                  15:52:36.558 FLH: Read block - Writing: 4096 - Total: 2961408 - Buffer size: 1959
                  15:52:36.758 FLH: Read block - Writing: 4096 - Total: 2965504 - Buffer size: 1959
                  15:52:36.958 FLH: Read block - Writing: 4096 - Total: 2969600 - Buffer size: 1959
                  15:52:37.158 FLH: Read block - Writing: 4096 - Total: 2973696 - Buffer size: 1959
                  15:52:37.272 FLH: Read block - Writing: 4096 - Total: 2977792 - Buffer size: 1959
                  15:52:37.458 FLH: Read block - Writing: 4096 - Total: 2981888 - Buffer size: 1959
                  15:52:37.657 FLH: Read block - Writing: 4096 - Total: 2985984 - Buffer size: 1959
                  15:52:37.858 FLH: Read block - Writing: 4096 - Total: 2990080 - Buffer size: 1959
                  15:52:38.058 FLH: Read block - Writing: 4096 - Total: 2994176 - Buffer size: 1959
                  15:52:38.263 FLH: Read block - Writing: 4096 - Total: 2998272 - Buffer size: 1959
                  15:52:38.458 FLH: Read block - Writing: 4096 - Total: 3002368 - Buffer size: 1959
                  15:52:38.606 FLH: Read block - Writing: 4096 - Total: 3006464 - Buffer size: 1959
                  15:52:38.758 FLH: Read block - Writing: 4096 - Total: 3010560 - Buffer size: 1959
                  15:52:38.957 FLH: Read block - Writing: 4096 - Total: 3014656 - Buffer size: 1959
                  15:52:39.160 FLH: Read block - Writing: 4096 - Total: 3018752 - Buffer size: 1959
                  15:52:39.359 FLH: Read block - Writing: 4096 - Total: 3022848 - Buffer size: 1959
                  15:52:39.559 FLH: Read block - Writing: 4096 - Total: 3026944 - Buffer size: 1959
                  15:52:39.757 FLH: Read block - Writing: 4096 - Total: 3031040 - Buffer size: 1959
                  15:52:39.957 FLH: Read block - Writing: 4096 - Total: 3035136 - Buffer size: 1959
                  15:52:40.157 FLH: Read block - Writing: 4096 - Total: 3039232 - Buffer size: 1959
                  15:52:40.272 FLH: Read block - Writing: 4096 - Total: 3043328 - Buffer size: 1959
                  15:52:40.457 FLH: Read block - Writing: 4096 - Total: 3047424 - Buffer size: 1959
                  15:52:40.658 FLH: Read block - Writing: 4096 - Total: 3051520 - Buffer size: 1959
                  15:52:40.772 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "25", "time_elapsed": 138}}
                  15:52:40.865 FLH: Read block - Writing: 4096 - Total: 3055616 - Buffer size: 1959
                  15:52:41.018 FLH: Read block - Writing: 4096 - Total: 3059712 - Buffer size: 1959
                  15:52:41.170 FLH: Read block - Writing: 4096 - Total: 3063808 - Buffer size: 1959
                  15:52:41.285 FLH: Read block - Writing: 4096 - Total: 3067904 - Buffer size: 1959
                  15:52:41.458 FLH: Read block - Writing: 4096 - Total: 3072000 - Buffer size: 1959
                  15:52:41.657 FLH: Read block - Writing: 4096 - Total: 3076096 - Buffer size: 1959
                  15:52:41.858 FLH: Read block - Writing: 4096 - Total: 3080192 - Buffer size: 1959
                  15:52:42.058 FLH: Read block - Writing: 4096 - Total: 3084288 - Buffer size: 1959
                  15:52:42.264 FLH: Read block - Writing: 4096 - Total: 3088384 - Buffer size: 1959
                  15:52:42.458 FLH: Read block - Writing: 4096 - Total: 3092480 - Buffer size: 1959
                  15:52:42.657 FLH: Read block - Writing: 4096 - Total: 3096576 - Buffer size: 1959
                  15:52:42.858 FLH: Read block - Writing: 4096 - Total: 3100672 - Buffer size: 1959
                  15:52:42.970 FLH: Read block - Writing: 4096 - Total: 3104768 - Buffer size: 1959
                  15:52:43.158 FLH: Read block - Writing: 4096 - Total: 3108864 - Buffer size: 1959
                  15:52:43.274 FLH: Read block - Writing: 4096 - Total: 3112960 - Buffer size: 1959
                  15:52:43.458 FLH: Read block - Writing: 4096 - Total: 3117056 - Buffer size: 1959
                  15:52:43.603 FLH: Read block - Writing: 4096 - Total: 3121152 - Buffer size: 1959
                  15:52:43.755 FLH: Read block - Writing: 4096 - Total: 3125248 - Buffer size: 1959
                  15:52:43.958 FLH: Read block - Writing: 4096 - Total: 3129344 - Buffer size: 1959
                  15:52:44.158 FLH: Read block - Writing: 4096 - Total: 3133440 - Buffer size: 1959
                  15:52:44.273 FLH: Read block - Writing: 4096 - Total: 3137536 - Buffer size: 1959
                  15:52:44.458 FLH: Read block - Writing: 4096 - Total: 3141632 - Buffer size: 1959
                  15:52:44.658 FLH: Read block - Writing: 4096 - Total: 3145728 - Buffer size: 1959
                  15:52:44.858 FLH: Read block - Writing: 4096 - Total: 3149824 - Buffer size: 1959
                  15:52:45.057 FLH: Read block - Writing: 4096 - Total: 3153920 - Buffer size: 1959
                  15:52:45.264 FLH: Read block - Writing: 4096 - Total: 3158016 - Buffer size: 1959
                  15:52:45.458 FLH: Read block - Writing: 4096 - Total: 3162112 - Buffer size: 1959
                  15:52:45.658 FLH: Read block - Writing: 4096 - Total: 3166208 - Buffer size: 1959
                  15:52:45.858 FLH: Read block - Writing: 4096 - Total: 3170304 - Buffer size: 1959
                  15:52:45.970 FLH: Read block - Writing: 4096 - Total: 3174400 - Buffer size: 1959
                  15:52:46.072 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "26", "time_elapsed": 143}}
                  15:52:46.165 FLH: Read block - Writing: 4096 - Total: 3178496 - Buffer size: 1959
                  15:52:46.323 FLH: Read block - Writing: 4096 - Total: 3182592 - Buffer size: 1959
                  15:52:46.435 FLH: Read block - Writing: 4096 - Total: 3186688 - Buffer size: 1959
                  15:52:46.559 FLH: Read block - Writing: 4096 - Total: 3190784 - Buffer size: 1959
                  15:52:46.758 FLH: Read block - Writing: 4096 - Total: 3194880 - Buffer size: 1959
                  15:52:46.958 FLH: Read block - Writing: 4096 - Total: 3198976 - Buffer size: 1959
                  15:52:47.158 FLH: Read block - Writing: 4096 - Total: 3203072 - Buffer size: 1959
                  15:52:47.273 FLH: Read block - Writing: 4096 - Total: 3207168 - Buffer size: 1959
                  15:52:47.458 FLH: Read block - Writing: 4096 - Total: 3211264 - Buffer size: 1959
                  15:52:47.658 FLH: Read block - Writing: 4096 - Total: 3215360 - Buffer size: 1959
                  15:52:47.858 FLH: Read block - Writing: 4096 - Total: 3219456 - Buffer size: 1959
                  15:52:47.970 FLH: Read block - Writing: 4096 - Total: 3223552 - Buffer size: 1959
                  15:52:48.082 FLH: Read block - Writing: 4096 - Total: 3227648 - Buffer size: 1959
                  15:52:48.263 FLH: Read block - Writing: 4096 - Total: 3231744 - Buffer size: 1959
                  15:52:48.457 FLH: Read block - Writing: 4096 - Total: 3235840 - Buffer size: 1959
                  15:52:48.658 FLH: Read block - Writing: 4096 - Total: 3239936 - Buffer size: 1959
                  15:52:48.807 FLH: Read block - Writing: 4096 - Total: 3244032 - Buffer size: 1959
                  15:52:48.957 FLH: Read block - Writing: 4096 - Total: 3248128 - Buffer size: 1959
                  15:52:49.070 FLH: Read block - Writing: 4096 - Total: 3252224 - Buffer size: 1959
                  15:52:49.264 FLH: Read block - Writing: 4096 - Total: 3256320 - Buffer size: 1959
                  15:52:49.458 FLH: Read block - Writing: 4096 - Total: 3260416 - Buffer size: 1959
                  15:52:49.657 FLH: Read block - Writing: 4096 - Total: 3264512 - Buffer size: 1959
                  15:52:49.858 FLH: Read block - Writing: 4096 - Total: 3268608 - Buffer size: 1959
                  15:52:50.058 FLH: Read block - Writing: 4096 - Total: 3272704 - Buffer size: 1959
                  15:52:50.169 FLH: Read block - Writing: 4096 - Total: 3276800 - Buffer size: 1959
                  15:52:50.282 FLH: Read block - Writing: 4096 - Total: 3280896 - Buffer size: 1959
                  15:52:50.558 FLH: Read block - Writing: 4096 - Total: 3284992 - Buffer size: 1959
                  15:52:50.757 FLH: Read block - Writing: 4096 - Total: 3289088 - Buffer size: 1959
                  15:52:50.958 FLH: Read block - Writing: 4096 - Total: 3293184 - Buffer size: 1959
                  15:52:51.158 FLH: Read block - Writing: 4096 - Total: 3297280 - Buffer size: 1959
                  15:52:51.226 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "27", "time_elapsed": 148}}
                  15:52:51.318 FLH: Read block - Writing: 4096 - Total: 3301376 - Buffer size: 1959
                  15:52:51.477 FLH: Read block - Writing: 4096 - Total: 3305472 - Buffer size: 1959
                  15:52:51.659 FLH: Read block - Writing: 4096 - Total: 3309568 - Buffer size: 1959
                  15:52:51.858 FLH: Read block - Writing: 4096 - Total: 3313664 - Buffer size: 1959
                  15:52:51.970 FLH: Read block - Writing: 4096 - Total: 3317760 - Buffer size: 1959
                  15:52:52.158 FLH: Read block - Writing: 4096 - Total: 3321856 - Buffer size: 1959
                  15:52:52.275 FLH: Read block - Writing: 4096 - Total: 3325952 - Buffer size: 1959
                  15:52:52.458 FLH: Read block - Writing: 4096 - Total: 3330048 - Buffer size: 1959
                  15:52:52.658 FLH: Read block - Writing: 4096 - Total: 3334144 - Buffer size: 1959
                  15:52:52.858 FLH: Read block - Writing: 4096 - Total: 3338240 - Buffer size: 1959
                  15:52:53.058 FLH: Read block - Writing: 4096 - Total: 3342336 - Buffer size: 1959
                  15:52:53.263 FLH: Read block - Writing: 4096 - Total: 3346432 - Buffer size: 1959
                  15:52:53.458 FLH: Read block - Writing: 4096 - Total: 3350528 - Buffer size: 1959
                  15:52:53.658 FLH: Read block - Writing: 4096 - Total: 3354624 - Buffer size: 1959
                  15:52:53.874 FLH: Read block - Writing: 4096 - Total: 3358720 - Buffer size: 1959
                  15:52:54.024 FLH: Read block - Writing: 4096 - Total: 3362816 - Buffer size: 1959
                  15:52:54.158 FLH: Read block - Writing: 4096 - Total: 3366912 - Buffer size: 1959
                  15:52:54.272 FLH: Read block - Writing: 4096 - Total: 3371008 - Buffer size: 1959
                  15:52:54.457 FLH: Read block - Writing: 4096 - Total: 3375104 - Buffer size: 1959
                  15:52:54.658 FLH: Read block - Writing: 4096 - Total: 3379200 - Buffer size: 1959
                  15:52:54.858 FLH: Read block - Writing: 4096 - Total: 3383296 - Buffer size: 1959
                  15:52:55.058 FLH: Read block - Writing: 4096 - Total: 3387392 - Buffer size: 1959
                  15:52:55.264 FLH: Read block - Writing: 4096 - Total: 3391488 - Buffer size: 1959
                  15:52:55.457 FLH: Read block - Writing: 4096 - Total: 3395584 - Buffer size: 1959
                  15:52:55.658 FLH: Read block - Writing: 4096 - Total: 3399680 - Buffer size: 1959
                  15:52:55.857 FLH: Read block - Writing: 4096 - Total: 3403776 - Buffer size: 1959
                  15:52:55.970 FLH: Read block - Writing: 4096 - Total: 3407872 - Buffer size: 1959
                  15:52:56.159 FLH: Read block - Writing: 4096 - Total: 3411968 - Buffer size: 1959
                  15:52:56.359 FLH: Read block - Writing: 4096 - Total: 3416064 - Buffer size: 1959
                  15:52:56.386 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "28", "time_elapsed": 154}}
                  15:52:56.479 FLH: Read block - Writing: 4096 - Total: 3420160 - Buffer size: 1959
                  15:52:56.626 FLH: Read block - Writing: 4096 - Total: 3424256 - Buffer size: 1959
                  15:52:56.757 FLH: Read block - Writing: 4096 - Total: 3428352 - Buffer size: 1959
                  15:52:56.958 FLH: Read block - Writing: 4096 - Total: 3432448 - Buffer size: 1959
                  15:52:57.158 FLH: Read block - Writing: 4096 - Total: 3436544 - Buffer size: 1959
                  15:52:57.274 FLH: Read block - Writing: 4096 - Total: 3440640 - Buffer size: 1959
                  15:52:57.458 FLH: Read block - Writing: 4096 - Total: 3444736 - Buffer size: 1959
                  15:52:57.658 FLH: Read block - Writing: 4096 - Total: 3448832 - Buffer size: 1959
                  15:52:57.858 FLH: Read block - Writing: 4096 - Total: 3452928 - Buffer size: 1959
                  15:52:58.056 FLH: Read block - Writing: 4096 - Total: 3457024 - Buffer size: 1959
                  15:52:58.262 FLH: Read block - Writing: 4096 - Total: 3461120 - Buffer size: 1959
                  15:52:58.457 FLH: Read block - Writing: 4096 - Total: 3465216 - Buffer size: 1959
                  15:52:58.658 FLH: Read block - Writing: 4096 - Total: 3469312 - Buffer size: 1959
                  15:52:58.810 FLH: Read block - Writing: 4096 - Total: 3473408 - Buffer size: 1959
                  15:52:58.923 FLH: Read block - Writing: 4096 - Total: 3477504 - Buffer size: 1959
                  15:52:59.265 FLH: Read block - Writing: 4096 - Total: 3481600 - Buffer size: 1959
                  15:52:59.412 FLH: Read block - Writing: 4096 - Total: 3485696 - Buffer size: 1959
                  15:52:59.559 FLH: Read block - Writing: 4096 - Total: 3489792 - Buffer size: 1959
                  15:52:59.758 FLH: Read block - Writing: 4096 - Total: 3493888 - Buffer size: 1959
                  15:52:59.958 FLH: Read block - Writing: 4096 - Total: 3497984 - Buffer size: 1959
                  15:53:00.158 FLH: Read block - Writing: 4096 - Total: 3502080 - Buffer size: 1959
                  15:53:00.275 FLH: Read block - Writing: 4096 - Total: 3506176 - Buffer size: 1959
                  15:53:00.458 FLH: Read block - Writing: 4096 - Total: 3510272 - Buffer size: 1959
                  15:53:00.658 FLH: Read block - Writing: 4096 - Total: 3514368 - Buffer size: 1959
                  15:53:00.770 FLH: Read block - Writing: 4096 - Total: 3518464 - Buffer size: 1959
                  15:53:00.958 FLH: Read block - Writing: 4096 - Total: 3522560 - Buffer size: 1959
                  15:53:01.160 FLH: Read block - Writing: 4096 - Total: 3526656 - Buffer size: 1959
                  15:53:01.320 FLH: Read block - Writing: 4096 - Total: 3530752 - Buffer size: 1959
                  15:53:01.457 FLH: Read block - Writing: 4096 - Total: 3534848 - Buffer size: 1959
                  15:53:01.657 FLH: Read block - Writing: 4096 - Total: 3538944 - Buffer size: 1959
                  15:53:01.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "29", "time_elapsed": 159}}
                  15:53:01.864 FLH: Read block - Writing: 4096 - Total: 3543040 - Buffer size: 1959
                  15:53:02.057 FLH: Read block - Writing: 4096 - Total: 3547136 - Buffer size: 1959
                  15:53:02.264 FLH: Read block - Writing: 4096 - Total: 3551232 - Buffer size: 1959
                  15:53:02.458 FLH: Read block - Writing: 4096 - Total: 3555328 - Buffer size: 1959
                  15:53:02.658 FLH: Read block - Writing: 4096 - Total: 3559424 - Buffer size: 1959
                  15:53:02.858 FLH: Read block - Writing: 4096 - Total: 3563520 - Buffer size: 1959
                  15:53:03.057 FLH: Read block - Writing: 4096 - Total: 3567616 - Buffer size: 1959
                  15:53:03.264 FLH: Read block - Writing: 4096 - Total: 3571712 - Buffer size: 1959
                  15:53:03.458 FLH: Read block - Writing: 4096 - Total: 3575808 - Buffer size: 1959
                  15:53:03.660 FLH: Read block - Writing: 4096 - Total: 3579904 - Buffer size: 1959
                  15:53:03.811 FLH: Read block - Writing: 4096 - Total: 3584000 - Buffer size: 1959
                  15:53:03.924 FLH: Read block - Writing: 4096 - Total: 3588096 - Buffer size: 1959
                  15:53:04.058 FLH: Read block - Writing: 4096 - Total: 3592192 - Buffer size: 1959
                  15:53:04.263 FLH: Read block - Writing: 4096 - Total: 3596288 - Buffer size: 1959
                  15:53:04.458 FLH: Read block - Writing: 4096 - Total: 3600384 - Buffer size: 1959
                  15:53:04.658 FLH: Read block - Writing: 4096 - Total: 3604480 - Buffer size: 1959
                  15:53:04.858 FLH: Read block - Writing: 4096 - Total: 3608576 - Buffer size: 1959
                  15:53:05.058 FLH: Read block - Writing: 4096 - Total: 3612672 - Buffer size: 1959
                  15:53:05.265 FLH: Read block - Writing: 4096 - Total: 3616768 - Buffer size: 1959
                  15:53:05.457 FLH: Read block - Writing: 4096 - Total: 3620864 - Buffer size: 1959
                  15:53:05.657 FLH: Read block - Writing: 4096 - Total: 3624960 - Buffer size: 1959
                  15:53:05.857 FLH: Read block - Writing: 4096 - Total: 3629056 - Buffer size: 1959
                  15:53:06.058 FLH: Read block - Writing: 4096 - Total: 3633152 - Buffer size: 1959
                  15:53:06.211 FLH: Read block - Writing: 4096 - Total: 3637248 - Buffer size: 1959
                  15:53:06.324 FLH: Read block - Writing: 4096 - Total: 3641344 - Buffer size: 1959
                  15:53:06.436 FLH: Read block - Writing: 4096 - Total: 3645440 - Buffer size: 1959
                  15:53:06.560 FLH: Read block - Writing: 4096 - Total: 3649536 - Buffer size: 1959
                  15:53:06.760 FLH: Read block - Writing: 4096 - Total: 3653632 - Buffer size: 1959
                  15:53:06.978 FLH: Read block - Writing: 4096 - Total: 3657728 - Buffer size: 1959
                  15:53:07.160 FLH: Read block - Writing: 4096 - Total: 3661824 - Buffer size: 1959
                  15:53:07.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "30", "time_elapsed": 164}}
                  15:53:07.281 FLH: Read block - Writing: 4096 - Total: 3665920 - Buffer size: 1959
                  15:53:07.460 FLH: Read block - Writing: 4096 - Total: 3670016 - Buffer size: 1959
                  15:53:07.660 FLH: Read block - Writing: 4096 - Total: 3674112 - Buffer size: 1959
                  15:53:07.859 FLH: Read block - Writing: 4096 - Total: 3678208 - Buffer size: 1959
                  15:53:07.971 FLH: Read block - Writing: 4096 - Total: 3682304 - Buffer size: 1959
                  15:53:08.160 FLH: Read block - Writing: 4096 - Total: 3686400 - Buffer size: 1959
                  15:53:08.275 FLH: Read block - Writing: 4096 - Total: 3690496 - Buffer size: 1959
                  15:53:08.460 FLH: Read block - Writing: 4096 - Total: 3694592 - Buffer size: 1959
                  15:53:08.660 FLH: Read block - Writing: 4096 - Total: 3698688 - Buffer size: 1959
                  15:53:08.860 FLH: Read block - Writing: 4096 - Total: 3702784 - Buffer size: 1959
                  15:53:09.059 FLH: Read block - Writing: 4096 - Total: 3706880 - Buffer size: 1959
                  15:53:09.265 FLH: Read block - Writing: 4096 - Total: 3710976 - Buffer size: 1959
                  15:53:09.461 FLH: Read block - Writing: 4096 - Total: 3715072 - Buffer size: 1959
                  15:53:09.609 FLH: Read block - Writing: 4096 - Total: 3719168 - Buffer size: 1959
                  15:53:09.757 FLH: Read block - Writing: 4096 - Total: 3723264 - Buffer size: 1959
                  15:53:09.958 FLH: Read block - Writing: 4096 - Total: 3727360 - Buffer size: 1959
                  15:53:10.158 FLH: Read block - Writing: 4096 - Total: 3731456 - Buffer size: 1959
                  15:53:10.275 FLH: Read block - Writing: 4096 - Total: 3735552 - Buffer size: 1959
                  15:53:10.458 FLH: Read block - Writing: 4096 - Total: 3739648 - Buffer size: 1959
                  15:53:10.658 FLH: Read block - Writing: 4096 - Total: 3743744 - Buffer size: 1959
                  15:53:10.858 FLH: Read block - Writing: 4096 - Total: 3747840 - Buffer size: 1959
                  15:53:11.057 FLH: Read block - Writing: 4096 - Total: 3751936 - Buffer size: 1959
                  15:53:11.264 FLH: Read block - Writing: 4096 - Total: 3756032 - Buffer size: 1959
                  15:53:11.458 FLH: Read block - Writing: 4096 - Total: 3760128 - Buffer size: 1959
                  15:53:11.657 FLH: Read block - Writing: 4096 - Total: 3764224 - Buffer size: 1959
                  15:53:11.858 FLH: Read block - Writing: 4096 - Total: 3768320 - Buffer size: 1959
                  15:53:12.058 FLH: Read block - Writing: 4096 - Total: 3772416 - Buffer size: 1959
                  15:53:12.199 FLH: Read block - Writing: 4096 - Total: 3776512 - Buffer size: 1959
                  15:53:12.315 FLH: Read block - Writing: 4096 - Total: 3780608 - Buffer size: 1959
                  15:53:12.430 FLH: Read block - Writing: 4096 - Total: 3784704 - Buffer size: 1959
                  15:53:12.472 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "31", "time_elapsed": 170}}
                  15:53:12.565 FLH: Read block - Writing: 4096 - Total: 3788800 - Buffer size: 1959
                  15:53:12.758 FLH: Read block - Writing: 4096 - Total: 3792896 - Buffer size: 1959
                  15:53:12.958 FLH: Read block - Writing: 4096 - Total: 3796992 - Buffer size: 1959
                  15:53:13.158 FLH: Read block - Writing: 4096 - Total: 3801088 - Buffer size: 1959
                  15:53:13.274 FLH: Read block - Writing: 4096 - Total: 3805184 - Buffer size: 1959
                  15:53:13.559 FLH: Read block - Writing: 4096 - Total: 3809280 - Buffer size: 1959
                  15:53:13.758 FLH: Read block - Writing: 4096 - Total: 3813376 - Buffer size: 1959
                  15:53:13.958 FLH: Read block - Writing: 4096 - Total: 3817472 - Buffer size: 1959
                  15:53:14.158 FLH: Read block - Writing: 4096 - Total: 3821568 - Buffer size: 1959
                  15:53:14.274 FLH: Read block - Writing: 4096 - Total: 3825664 - Buffer size: 1959
                  15:53:14.458 FLH: Read block - Writing: 4096 - Total: 3829760 - Buffer size: 1959
                  15:53:14.609 FLH: Read block - Writing: 4096 - Total: 3833856 - Buffer size: 1959
                  15:53:14.756 FLH: Read block - Writing: 4096 - Total: 3837952 - Buffer size: 1959
                  15:53:14.957 FLH: Read block - Writing: 4096 - Total: 3842048 - Buffer size: 1959
                  15:53:15.158 FLH: Read block - Writing: 4096 - Total: 3846144 - Buffer size: 1959
                  15:53:15.273 FLH: Read block - Writing: 4096 - Total: 3850240 - Buffer size: 1959
                  15:53:15.457 FLH: Read block - Writing: 4096 - Total: 3854336 - Buffer size: 1959
                  15:53:15.657 FLH: Read block - Writing: 4096 - Total: 3858432 - Buffer size: 1959
                  15:53:15.858 FLH: Read block - Writing: 4096 - Total: 3862528 - Buffer size: 1959
                  15:53:16.057 FLH: Read block - Writing: 4096 - Total: 3866624 - Buffer size: 1959
                  15:53:16.264 FLH: Read block - Writing: 4096 - Total: 3870720 - Buffer size: 1959
                  15:53:16.458 FLH: Read block - Writing: 4096 - Total: 3874816 - Buffer size: 1959
                  15:53:16.658 FLH: Read block - Writing: 4096 - Total: 3878912 - Buffer size: 1959
                  15:53:16.858 FLH: Read block - Writing: 4096 - Total: 3883008 - Buffer size: 1959
                  15:53:17.058 FLH: Read block - Writing: 4096 - Total: 3887104 - Buffer size: 1959
                  15:53:17.206 FLH: Read block - Writing: 4096 - Total: 3891200 - Buffer size: 1959
                  15:53:17.318 FLH: Read block - Writing: 4096 - Total: 3895296 - Buffer size: 1959
                  15:53:17.430 FLH: Read block - Writing: 4096 - Total: 3899392 - Buffer size: 1959
                  15:53:17.558 FLH: Read block - Writing: 4096 - Total: 3903488 - Buffer size: 1959
                  15:53:17.671 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "32", "time_elapsed": 175}}
                  15:53:17.764 FLH: Read block - Writing: 4096 - Total: 3907584 - Buffer size: 1959
                  15:53:17.958 FLH: Read block - Writing: 4096 - Total: 3911680 - Buffer size: 1959
                  15:53:18.158 FLH: Read block - Writing: 4096 - Total: 3915776 - Buffer size: 1959
                  15:53:18.317 FLH: Read block - Writing: 4096 - Total: 3919872 - Buffer size: 1959
                  15:53:18.457 FLH: Read block - Writing: 4096 - Total: 3923968 - Buffer size: 1959
                  15:53:18.657 FLH: Read block - Writing: 4096 - Total: 3928064 - Buffer size: 1959
                  15:53:18.857 FLH: Read block - Writing: 4096 - Total: 3932160 - Buffer size: 1959
                  15:53:18.969 FLH: Read block - Writing: 4096 - Total: 3936256 - Buffer size: 1959
                  15:53:19.264 FLH: Read block - Writing: 4096 - Total: 3940352 - Buffer size: 1959
                  15:53:19.458 FLH: Read block - Writing: 4096 - Total: 3944448 - Buffer size: 1959
                  15:53:19.658 FLH: Read block - Writing: 4096 - Total: 3948544 - Buffer size: 1959
                  15:53:19.804 FLH: Read block - Writing: 4096 - Total: 3952640 - Buffer size: 1959
                  15:53:19.957 FLH: Read block - Writing: 4096 - Total: 3956736 - Buffer size: 1959
                  15:53:20.157 FLH: Read block - Writing: 4096 - Total: 3960832 - Buffer size: 1959
                  15:53:20.273 FLH: Read block - Writing: 4096 - Total: 3964928 - Buffer size: 1959
                  15:53:20.457 FLH: Read block - Writing: 4096 - Total: 3969024 - Buffer size: 1959
                  15:53:20.659 FLH: Read block - Writing: 4096 - Total: 3973120 - Buffer size: 1959
                  15:53:20.812 FLH: Read block - Writing: 4096 - Total: 3977216 - Buffer size: 1959
                  15:53:20.925 FLH: Read block - Writing: 4096 - Total: 3981312 - Buffer size: 1959
                  15:53:21.057 FLH: Read block - Writing: 4096 - Total: 3985408 - Buffer size: 1959
                  15:53:21.264 FLH: Read block - Writing: 4096 - Total: 3989504 - Buffer size: 1959
                  15:53:21.458 FLH: Read block - Writing: 4096 - Total: 3993600 - Buffer size: 1959
                  15:53:21.658 FLH: Read block - Writing: 4096 - Total: 3997696 - Buffer size: 1959
                  15:53:21.858 FLH: Read block - Writing: 4096 - Total: 4001792 - Buffer size: 1959
                  15:53:22.058 FLH: Read block - Writing: 4096 - Total: 4005888 - Buffer size: 1959
                  15:53:22.264 FLH: Read block - Writing: 4096 - Total: 4009984 - Buffer size: 1959
                  15:53:22.410 FLH: Read block - Writing: 4096 - Total: 4014080 - Buffer size: 1959
                  15:53:22.560 FLH: Read block - Writing: 4096 - Total: 4018176 - Buffer size: 1959
                  15:53:22.760 FLH: Read block - Writing: 4096 - Total: 4022272 - Buffer size: 1959
                  15:53:22.959 FLH: Read block - Writing: 4096 - Total: 4026368 - Buffer size: 1959
                  15:53:23.076 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "33", "time_elapsed": 180}}
                  15:53:23.168 FLH: Read block - Writing: 4096 - Total: 4030464 - Buffer size: 1959
                  15:53:23.328 FLH: Read block - Writing: 4096 - Total: 4034560 - Buffer size: 1959
                  15:53:23.440 FLH: Read block - Writing: 4096 - Total: 4038656 - Buffer size: 1959
                  15:53:23.558 FLH: Read block - Writing: 4096 - Total: 4042752 - Buffer size: 1959
                  15:53:23.758 FLH: Read block - Writing: 4096 - Total: 4046848 - Buffer size: 1959
                  15:53:23.958 FLH: Read block - Writing: 4096 - Total: 4050944 - Buffer size: 1959
                  15:53:24.158 FLH: Read block - Writing: 4096 - Total: 4055040 - Buffer size: 1959
                  15:53:24.273 FLH: Read block - Writing: 4096 - Total: 4059136 - Buffer size: 1959
                  15:53:24.458 FLH: Read block - Writing: 4096 - Total: 4063232 - Buffer size: 1959
                  15:53:24.657 FLH: Read block - Writing: 4096 - Total: 4067328 - Buffer size: 1959
                  15:53:24.857 FLH: Read block - Writing: 4096 - Total: 4071424 - Buffer size: 1959
                  15:53:25.057 FLH: Read block - Writing: 4096 - Total: 4075520 - Buffer size: 1959
                  15:53:25.263 FLH: Read block - Writing: 4096 - Total: 4079616 - Buffer size: 1959
                  15:53:25.458 FLH: Read block - Writing: 4096 - Total: 4083712 - Buffer size: 1959
                  15:53:25.658 FLH: Read block - Writing: 4096 - Total: 4087808 - Buffer size: 1959
                  15:53:25.813 FLH: Read block - Writing: 4096 - Total: 4091904 - Buffer size: 1959
                  15:53:25.925 FLH: Read block - Writing: 4096 - Total: 4096000 - Buffer size: 1959
                  15:53:26.058 FLH: Read block - Writing: 4096 - Total: 4100096 - Buffer size: 1959
                  15:53:26.264 FLH: Read block - Writing: 4096 - Total: 4104192 - Buffer size: 1959
                  15:53:26.458 FLH: Read block - Writing: 4096 - Total: 4108288 - Buffer size: 1959
                  15:53:26.658 FLH: Read block - Writing: 4096 - Total: 4112384 - Buffer size: 1959
                  15:53:26.858 FLH: Read block - Writing: 4096 - Total: 4116480 - Buffer size: 1959
                  15:53:26.970 FLH: Read block - Writing: 4096 - Total: 4120576 - Buffer size: 1959
                  15:53:27.158 FLH: Read block - Writing: 4096 - Total: 4124672 - Buffer size: 1959
                  15:53:27.275 FLH: Read block - Writing: 4096 - Total: 4128768 - Buffer size: 1959
                  15:53:27.422 FLH: Read block - Writing: 4096 - Total: 4132864 - Buffer size: 1959
                  15:53:28.057 FLH: Read block - Writing: 4096 - Total: 4136960 - Buffer size: 1959
                  15:53:28.263 FLH: Read block - Writing: 4096 - Total: 4141056 - Buffer size: 1959
                  15:53:28.458 FLH: Read block - Writing: 4096 - Total: 4145152 - Buffer size: 1959
                  15:53:28.657 FLH: Read block - Writing: 4096 - Total: 4149248 - Buffer size: 1959
                  15:53:28.771 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "34", "time_elapsed": 186}}
                  15:53:28.864 FLH: Read block - Writing: 4096 - Total: 4153344 - Buffer size: 1959
                  15:53:29.058 FLH: Read block - Writing: 4096 - Total: 4157440 - Buffer size: 1959
                  15:53:29.263 FLH: Read block - Writing: 4096 - Total: 4161536 - Buffer size: 1959
                  15:53:29.458 FLH: Read block - Writing: 4096 - Total: 4165632 - Buffer size: 1959
                  15:53:29.658 FLH: Read block - Writing: 4096 - Total: 4169728 - Buffer size: 1959
                  15:53:29.858 FLH: Read block - Writing: 4096 - Total: 4173824 - Buffer size: 1959
                  15:53:30.000 FLH: Read block - Writing: 4096 - Total: 4177920 - Buffer size: 1959
                  15:53:30.158 FLH: Read block - Writing: 4096 - Total: 4182016 - Buffer size: 1959
                  15:53:30.273 FLH: Read block - Writing: 4096 - Total: 4186112 - Buffer size: 1959
                  15:53:30.458 FLH: Read block - Writing: 4096 - Total: 4190208 - Buffer size: 1959
                  15:53:30.658 FLH: Read block - Writing: 4096 - Total: 4194304 - Buffer size: 1959
                  15:53:30.858 FLH: Read block - Writing: 4096 - Total: 4198400 - Buffer size: 1959
                  15:53:31.458 FLH: Read block - Writing: 4096 - Total: 4202496 - Buffer size: 1959
                  15:53:31.657 FLH: Read block - Writing: 4096 - Total: 4206592 - Buffer size: 1959
                  15:53:31.857 FLH: Read block - Writing: 4096 - Total: 4210688 - Buffer size: 1959
                  15:53:31.970 FLH: Read block - Writing: 4096 - Total: 4214784 - Buffer size: 1959
                  15:53:32.158 FLH: Read block - Writing: 4096 - Total: 4218880 - Buffer size: 1959
                  15:53:32.274 FLH: Read block - Writing: 4096 - Total: 4222976 - Buffer size: 1959
                  15:53:32.416 FLH: Read block - Writing: 4096 - Total: 4227072 - Buffer size: 1959
                  15:53:32.558 FLH: Read block - Writing: 4096 - Total: 4231168 - Buffer size: 1959
                  15:53:32.757 FLH: Read block - Writing: 4096 - Total: 4235264 - Buffer size: 1959
                  15:53:32.958 FLH: Read block - Writing: 4096 - Total: 4239360 - Buffer size: 1959
                  15:53:33.110 FLH: Read block - Writing: 4096 - Total: 4243456 - Buffer size: 1959
                  15:53:33.265 FLH: Read block - Writing: 4096 - Total: 4247552 - Buffer size: 1959
                  15:53:33.460 FLH: Read block - Writing: 4096 - Total: 4251648 - Buffer size: 1959
                  15:53:33.660 FLH: Read block - Writing: 4096 - Total: 4255744 - Buffer size: 1959
                  15:53:33.860 FLH: Read block - Writing: 4096 - Total: 4259840 - Buffer size: 1959
                  15:53:33.971 FLH: Read block - Writing: 4096 - Total: 4263936 - Buffer size: 1959
                  15:53:34.760 FLH: Read block - Writing: 4096 - Total: 4268032 - Buffer size: 1959
                  15:53:34.901 FLH: Read block - Writing: 4096 - Total: 4272128 - Buffer size: 1959
                  15:53:34.928 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "35", "time_elapsed": 192}}
                  15:53:35.021 FLH: Read block - Writing: 4096 - Total: 4276224 - Buffer size: 1959
                  15:53:35.158 FLH: Read block - Writing: 4096 - Total: 4280320 - Buffer size: 1959
                  15:53:35.274 FLH: Read block - Writing: 4096 - Total: 4284416 - Buffer size: 1959
                  15:53:35.457 FLH: Read block - Writing: 4096 - Total: 4288512 - Buffer size: 1959
                  15:53:35.609 FLH: Read block - Writing: 4096 - Total: 4292608 - Buffer size: 1959
                  15:53:35.757 FLH: Read block - Writing: 4096 - Total: 4296704 - Buffer size: 1959
                  15:53:35.958 FLH: Read block - Writing: 4096 - Total: 4300800 - Buffer size: 1959
                  15:53:36.070 FLH: Read block - Writing: 4096 - Total: 4304896 - Buffer size: 1959
                  15:53:36.265 FLH: Read block - Writing: 4096 - Total: 4308992 - Buffer size: 1959
                  15:53:36.457 FLH: Read block - Writing: 4096 - Total: 4313088 - Buffer size: 1959
                  15:53:36.658 FLH: Read block - Writing: 4096 - Total: 4317184 - Buffer size: 1959
                  15:53:36.859 FLH: Read block - Writing: 4096 - Total: 4321280 - Buffer size: 1959
                  15:53:37.057 FLH: Read block - Writing: 4096 - Total: 4325376 - Buffer size: 1959
                  15:53:37.265 FLH: Read block - Writing: 4096 - Total: 4329472 - Buffer size: 1959
                  15:53:37.962 FLH: Read block - Writing: 4096 - Total: 4333568 - Buffer size: 1959
                  15:53:38.116 FLH: Read block - Writing: 4096 - Total: 4337664 - Buffer size: 1959
                  15:53:38.263 FLH: Read block - Writing: 4096 - Total: 4341760 - Buffer size: 1959
                  15:53:38.457 FLH: Read block - Writing: 4096 - Total: 4345856 - Buffer size: 1959
                  15:53:38.658 FLH: Read block - Writing: 4096 - Total: 4349952 - Buffer size: 1959
                  15:53:38.858 FLH: Read block - Writing: 4096 - Total: 4354048 - Buffer size: 1959
                  15:53:39.058 FLH: Read block - Writing: 4096 - Total: 4358144 - Buffer size: 1959
                  15:53:39.264 FLH: Read block - Writing: 4096 - Total: 4362240 - Buffer size: 1959
                  15:53:39.458 FLH: Read block - Writing: 4096 - Total: 4366336 - Buffer size: 1959
                  15:53:39.658 FLH: Read block - Writing: 4096 - Total: 4370432 - Buffer size: 1959
                  15:53:39.857 FLH: Read block - Writing: 4096 - Total: 4374528 - Buffer size: 1959
                  15:53:39.969 FLH: Read block - Writing: 4096 - Total: 4378624 - Buffer size: 1959
                  15:53:40.110 FLH: Read block - Writing: 4096 - Total: 4382720 - Buffer size: 1959
                  15:53:40.263 FLH: Read block - Writing: 4096 - Total: 4386816 - Buffer size: 1959
                  15:53:40.459 FLH: Read block - Writing: 4096 - Total: 4390912 - Buffer size: 1959
                  15:53:40.612 FLH: Read block - Writing: 4096 - Total: 4395008 - Buffer size: 1959
                  15:53:41.177 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "36", "time_elapsed": 198}}
                  15:53:41.269 FLH: Read block - Writing: 4096 - Total: 4399104 - Buffer size: 1959
                  15:53:41.458 FLH: Read block - Writing: 4096 - Total: 4403200 - Buffer size: 1959
                  15:53:41.658 FLH: Read block - Writing: 4096 - Total: 4407296 - Buffer size: 1959
                  15:53:41.858 FLH: Read block - Writing: 4096 - Total: 4411392 - Buffer size: 1959
                  15:53:42.058 FLH: Read block - Writing: 4096 - Total: 4415488 - Buffer size: 1959
                  15:53:42.264 FLH: Read block - Writing: 4096 - Total: 4419584 - Buffer size: 1959
                  15:53:42.458 FLH: Read block - Writing: 4096 - Total: 4423680 - Buffer size: 1959
                  15:53:42.678 FLH: Read block - Writing: 4096 - Total: 4427776 - Buffer size: 1959
                  15:53:42.858 FLH: Read block - Writing: 4096 - Total: 4431872 - Buffer size: 1959
                  15:53:43.010 FLH: Read block - Writing: 4096 - Total: 4435968 - Buffer size: 1959
                  15:53:43.160 FLH: Read block - Writing: 4096 - Total: 4440064 - Buffer size: 1959
                  15:53:43.275 FLH: Read block - Writing: 4096 - Total: 4444160 - Buffer size: 1959
                  15:53:43.460 FLH: Read block - Writing: 4096 - Total: 4448256 - Buffer size: 1959
                  15:53:43.660 FLH: Read block - Writing: 4096 - Total: 4452352 - Buffer size: 1959
                  15:53:43.859 FLH: Read block - Writing: 4096 - Total: 4456448 - Buffer size: 1959
                  15:53:43.971 FLH: Read block - Writing: 4096 - Total: 4460544 - Buffer size: 1959
                  15:53:44.760 FLH: Read block - Writing: 4096 - Total: 4464640 - Buffer size: 1959
                  15:53:44.960 FLH: Read block - Writing: 4096 - Total: 4468736 - Buffer size: 1959
                  15:53:45.106 FLH: Read block - Writing: 4096 - Total: 4472832 - Buffer size: 1959
                  15:53:45.263 FLH: Read block - Writing: 4096 - Total: 4476928 - Buffer size: 1959
                  15:53:45.418 FLH: Read block - Writing: 4096 - Total: 4481024 - Buffer size: 1959
                  15:53:45.557 FLH: Read block - Writing: 4096 - Total: 4485120 - Buffer size: 1959
                  15:53:45.758 FLH: Read block - Writing: 4096 - Total: 4489216 - Buffer size: 1959
                  15:53:45.958 FLH: Read block - Writing: 4096 - Total: 4493312 - Buffer size: 1959
                  15:53:46.158 FLH: Read block - Writing: 4096 - Total: 4497408 - Buffer size: 1959
                  15:53:46.273 FLH: Read block - Writing: 4096 - Total: 4501504 - Buffer size: 1959
                  15:53:46.458 FLH: Read block - Writing: 4096 - Total: 4505600 - Buffer size: 1959
                  15:53:46.657 FLH: Read block - Writing: 4096 - Total: 4509696 - Buffer size: 1959
                  15:53:46.858 FLH: Read block - Writing: 4096 - Total: 4513792 - Buffer size: 1959
                  15:53:46.971 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "37", "time_elapsed": 204}}
                  15:53:47.064 FLH: Read block - Writing: 4096 - Total: 4517888 - Buffer size: 1959
                  15:53:47.264 FLH: Read block - Writing: 4096 - Total: 4521984 - Buffer size: 1959
                  15:53:47.458 FLH: Read block - Writing: 4096 - Total: 4526080 - Buffer size: 1959
                  15:53:48.158 FLH: Read block - Writing: 4096 - Total: 4530176 - Buffer size: 1959
                  15:53:48.274 FLH: Read block - Writing: 4096 - Total: 4534272 - Buffer size: 1959
                  15:53:48.457 FLH: Read block - Writing: 4096 - Total: 4538368 - Buffer size: 1959
                  15:53:48.658 FLH: Read block - Writing: 4096 - Total: 4542464 - Buffer size: 1959
                  15:53:48.859 FLH: Read block - Writing: 4096 - Total: 4546560 - Buffer size: 1959
                  15:53:48.971 FLH: Read block - Writing: 4096 - Total: 4550656 - Buffer size: 1959
                  15:53:49.158 FLH: Read block - Writing: 4096 - Total: 4554752 - Buffer size: 1959
                  15:53:49.275 FLH: Read block - Writing: 4096 - Total: 4558848 - Buffer size: 1959
                  15:53:49.458 FLH: Read block - Writing: 4096 - Total: 4562944 - Buffer size: 1959
                  15:53:49.657 FLH: Read block - Writing: 4096 - Total: 4567040 - Buffer size: 1959
                  15:53:49.858 FLH: Read block - Writing: 4096 - Total: 4571136 - Buffer size: 1959
                  15:53:50.058 FLH: Read block - Writing: 4096 - Total: 4575232 - Buffer size: 1959
                  15:53:50.217 FLH: Read block - Writing: 4096 - Total: 4579328 - Buffer size: 1959
                  15:53:50.370 FLH: Read block - Writing: 4096 - Total: 4583424 - Buffer size: 1959
                  15:53:50.482 FLH: Read block - Writing: 4096 - Total: 4587520 - Buffer size: 1959
                  15:53:50.658 FLH: Read block - Writing: 4096 - Total: 4591616 - Buffer size: 1959
                  15:53:51.358 FLH: Read block - Writing: 4096 - Total: 4595712 - Buffer size: 1959
                  15:53:51.559 FLH: Read block - Writing: 4096 - Total: 4599808 - Buffer size: 1959
                  15:53:51.758 FLH: Read block - Writing: 4096 - Total: 4603904 - Buffer size: 1959
                  15:53:51.958 FLH: Read block - Writing: 4096 - Total: 4608000 - Buffer size: 1959
                  15:53:52.158 FLH: Read block - Writing: 4096 - Total: 4612096 - Buffer size: 1959
                  15:53:52.273 FLH: Read block - Writing: 4096 - Total: 4616192 - Buffer size: 1959
                  15:53:52.458 FLH: Read block - Writing: 4096 - Total: 4620288 - Buffer size: 1959
                  15:53:52.657 FLH: Read block - Writing: 4096 - Total: 4624384 - Buffer size: 1959
                  15:53:52.858 FLH: Read block - Writing: 4096 - Total: 4628480 - Buffer size: 1959
                  15:53:53.001 FLH: Read block - Writing: 4096 - Total: 4632576 - Buffer size: 1959
                  15:53:53.159 FLH: Read block - Writing: 4096 - Total: 4636672 - Buffer size: 1959
                  15:53:53.189 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "38", "time_elapsed": 210}}
                  15:53:53.281 FLH: Read block - Writing: 4096 - Total: 4640768 - Buffer size: 1959
                  15:53:53.459 FLH: Read block - Writing: 4096 - Total: 4644864 - Buffer size: 1959
                  15:53:53.657 FLH: Read block - Writing: 4096 - Total: 4648960 - Buffer size: 1959
                  15:53:53.857 FLH: Read block - Writing: 4096 - Total: 4653056 - Buffer size: 1959
                  15:53:54.057 FLH: Read block - Writing: 4096 - Total: 4657152 - Buffer size: 1959
                  15:53:54.758 FLH: Read block - Writing: 4096 - Total: 4661248 - Buffer size: 1959
                  15:53:54.958 FLH: Read block - Writing: 4096 - Total: 4665344 - Buffer size: 1959
                  15:53:55.111 FLH: Read block - Writing: 4096 - Total: 4669440 - Buffer size: 1959
                  15:53:55.266 FLH: Read block - Writing: 4096 - Total: 4673536 - Buffer size: 1959
                  15:53:55.407 FLH: Read block - Writing: 4096 - Total: 4677632 - Buffer size: 1959
                  15:53:55.559 FLH: Read block - Writing: 4096 - Total: 4681728 - Buffer size: 1959
                  15:53:55.758 FLH: Read block - Writing: 4096 - Total: 4685824 - Buffer size: 1959
                  15:53:55.958 FLH: Read block - Writing: 4096 - Total: 4689920 - Buffer size: 1959
                  15:53:56.158 FLH: Read block - Writing: 4096 - Total: 4694016 - Buffer size: 1959
                  15:53:56.274 FLH: Read block - Writing: 4096 - Total: 4698112 - Buffer size: 1959
                  15:53:56.458 FLH: Read block - Writing: 4096 - Total: 4702208 - Buffer size: 1959
                  15:53:56.657 FLH: Read block - Writing: 4096 - Total: 4706304 - Buffer size: 1959
                  15:53:56.858 FLH: Read block - Writing: 4096 - Total: 4710400 - Buffer size: 1959
                  15:53:57.058 FLH: Read block - Writing: 4096 - Total: 4714496 - Buffer size: 1959
                  15:53:57.264 FLH: Read block - Writing: 4096 - Total: 4718592 - Buffer size: 1959
                  15:53:57.460 FLH: Read block - Writing: 4096 - Total: 4722688 - Buffer size: 1959
                  15:53:58.160 FLH: Read block - Writing: 4096 - Total: 4726784 - Buffer size: 1959
                  15:53:58.275 FLH: Read block - Writing: 4096 - Total: 4730880 - Buffer size: 1959
                  15:53:58.459 FLH: Read block - Writing: 4096 - Total: 4734976 - Buffer size: 1959
                  15:53:58.660 FLH: Read block - Writing: 4096 - Total: 4739072 - Buffer size: 1959
                  15:53:58.859 FLH: Read block - Writing: 4096 - Total: 4743168 - Buffer size: 1959
                  15:53:58.971 FLH: Read block - Writing: 4096 - Total: 4747264 - Buffer size: 1959
                  15:53:59.160 FLH: Read block - Writing: 4096 - Total: 4751360 - Buffer size: 1959
                  15:53:59.275 FLH: Read block - Writing: 4096 - Total: 4755456 - Buffer size: 1959
                  15:53:59.459 FLH: Read block - Writing: 4096 - Total: 4759552 - Buffer size: 1959
                  15:53:59.573 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "39", "time_elapsed": 217}}
                  15:53:59.666 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1959
                  15:53:59.860 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1959
                  15:54:00.015 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1959
                  15:54:00.158 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1959
                  15:54:00.273 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1959
                  15:54:00.458 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1959
                  15:54:00.605 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1959
                  • Armilar
                    Armilar Most Active Forum Testing @australien last edited by Armilar
                    @australien
                    versuche mal die
                    FlashNextionAdv0 http://nspanel.de/nspanel-v0.0.0.tft
                    EDIT: Ist ja irgendwie immer die gleiche Länge und Zeit und Länge... Gibt es bei dir irgend ein QoS, was da die Leitung einschränkt?
                      australien @Armilar last edited by australien
                      @armilar
                      QOS oder ähnliches gibt es meines Wissens nicht, hatte bis jetzt auch alles funktioniert.
                      genau das gleichen
                      6:11:23.874 MQT: SmartHome/NSPanel_1/stat/RESULT = {"FlashNextionAdv":"Done"}
                      16:11:23.902 FLH: host: nspanel.de, port: 80, get: /nspanel-v0.0.0.tft
                      16:11:23.957 FLH: Connected:true
                      16:11:24.060 FLH: Retry 2
                      16:11:24.273 FLH: HTTP Respose is 200 OK or 206 Partial Content
                      16:11:24.274 FLH: Flash file size: 12197684
                      16:11:24.275 SRC: Berry
                      16:11:24.276 CMD: Grp 0, Cmd 'RULETIMER', Idx 3, Len 1, Pld 0, Data '0'
                      16:11:24.282 MQT: SmartHome/NSPanel_1/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                      16:11:24.287 SRC: Berry
                      16:11:24.288 CMD: Grp 0, Cmd 'RULE', Idx 3, Len 1, Pld 0, Data '0'
                      16:11:24.292 MQT: SmartHome/NSPanel_1/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                      16:11:24.308 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                      16:11:24.311 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                      16:11:24.313 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                      16:11:24.319 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                      16:11:24.444 FLH: Send (High Speed) flash start
                      16:11:24.450 NXP: Nextion command sent = bytes('77686D692D777269732031323139373638342C3932313630302C72657330FFFF...')
                      16:11:24.473 BRY: Serial UART2
                      16:11:24.825 MQT: SmartHome/NSPanel_1/tele/RESULT = {"Flashing":{"complete": "0", "time_elapsed": 0}}
                      16:11:24.918 FLH: Read block - Writing: 4096 - Total: 4096 - Buffer size: 1395
                      16:11:25.019 FLH: Waiting offset...
                      16:11:29.819 FLH: Flash offset marker 0
                      16:11:29.919 FLH: Read block - Writing: 4096 - Total: 8192 - Buffer size: 1395
                      16:11:30.118 FLH: Read block - Writing: 4096 - Total: 12288 - Buffer size: 1395
                      16:11:30.224 FLH: Read block - Writing: 4096 - Total: 16384 - Buffer size: 1395
                      16:11:30.341 FLH: Read block - Writing: 4096 - Total: 20480 - Buffer size: 1395```
                      16:14:53.123 FLH: Read block - Writing: 4096 - Total: 4763648 - Buffer size: 1395
                      16:14:53.324 FLH: Read block - Writing: 4096 - Total: 4767744 - Buffer size: 1395
                      16:14:53.434 FLH: Read block - Writing: 4096 - Total: 4771840 - Buffer size: 1395
                      16:14:53.619 FLH: Read block - Writing: 4096 - Total: 4775936 - Buffer size: 1395
                      16:14:53.819 FLH: Read block - Writing: 4096 - Total: 4780032 - Buffer size: 1395
                      16:14:53.969 FLH: Read block - Writing: 4096 - Total: 4784128 - Buffer size: 1395
                      16:14:54.119 FLH: Read block - Writing: 4096 - Total: 4788224 - Buffer size: 1395
                      Chris_71 1 Reply Last reply Reply Quote 0
                      • Chris_71
                        Chris_71 @australien last edited by
                        @Armilar
                        Beim Wechsel von AccuWeather auf OpenWeatherMap wird mir nun beim Screensaver unter dem Symbol für Sonnenaufgang keine Uhrzeit mehr angezeigt - sondern nur Zahlen zB 1757653.
                        Config alt:
                                // bottomScreensaverEntity 1
                                        ScreensaverEntity: 'accuweather.0.Daily.Day1.Sunrise',
                                        ScreensaverEntityFactor: 1,
                                        ScreensaverEntityDecimalPlaces: 0,
                                        ScreensaverEntityDateFormat: { hour: '2-digit', minute: '2-digit' }, // Description at Wiki-Pages
                                        ScreensaverEntityIconOn: 'weather-sunset-up',
                                        ScreensaverEntityIconOff: null,
                                        ScreensaverEntityText: 'Sonne',
                                        ScreensaverEntityIconColor: MSYellow
                        Config Neu:
                                    ScreensaverEntity: 'openweathermap.0.forecast.current.sunrise',
                        • Armilar
                          Armilar Most Active Forum Testing @Chris_71 last edited by
                          @chris_71
                          kannste entweder formatiert duch einen Alias ziehen oder nimmst einfach etwas, was ne richtige Zeit hat...
                                          ScreensaverEntity: 'javascript.0.variables.astro.sunrise',
                          • teletapi
                            teletapi @australien last edited by teletapi
                            @australien said in SONOFF NSPanel mit Lovelace UI:
                            14:02:08.172 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                            Die Zeile kenne ich nur zu gut aus meinem US_Panel. Ich hab das nie geflasht bekommen ausser per RX/TX direkt am Display dann funktionierte das in kürzester Zeit
                            lovelace ui nspanel sonoff
                            268
                            7577
                            6053724
