    4. ZigBee: 'undefined Devices' unbekannter Herkunft im Netzwerk
    • bilberry
      bilberry last edited by
      • Adaptername: zigbee
      • Link zu Adapterrepository: https://github.com/ioBroker/ioBroker.zigbee
      • Adapterversion: 2.0.5 (auch bei früheen Versioen schon beobachtet)
      • js-controller Version: 7.0.6
      • Admin Version: v7.6.17
      • Hardwaresystem: Master auf VM // ZigBee-Adapter auf Slave (Pi4)
      • Arbeitsspeicher: 4 GB / 4GB
      • Festplattenart: HDD / SSD
      • Betriebssystem: Ubuntu 22.04.5 / Raspberry Pi OS 'bookworm
      • Nodejs-Version: v20.19.5
      • NPM-Version: 10.8.2
      • Installationsart: offizielles Installer-Skript
      • Image, Docker genutzt: Nein
      Linux User bitte hier den Output von iob diag einfügen.
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Ubuntu 22.04.5 LTS
      Static hostname: iobserver
            Icon name: computer-vm
              Chassis: vm
       Virtualization: kvm
               Kernel: Linux 5.15.0-153-generic
         Architecture: x86-64
      Hardware Vendor: QEMU
       Hardware Model: Standard PC _i440FX + PIIX, 1996_
      OS is similar to: debian
      model name      : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      20:27:19 up 7 days,  3:28,  2 users,  load average: 0.98, 1.16, 1.62
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
      *** TIME AND TIMEZONES ***
                    Local time: Fri 2025-09-12 20:27:20 CEST
                Universal time: Fri 2025-09-12 18:27:20 UTC
                      RTC time: Fri 2025-09-12 18:27:20
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      xxx
      HOME=/home/xxx
      GROUPS=xxx adm cdrom sudo dip plugdev lxd iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            3.9G        2.0G        828M        1.0M        1.1G        1.6G
      Swap:           2.0G        2.0M        2.0G
      Total:          6.0G        2.0G        2.9G
      Active iob-Instances:   27
              3911 M total memory
              2002 M used memory
               567 M active memory
              2213 M inactive memory
               828 M free memory
               159 M buffer memory
               921 M swap cache
              2047 M total swap
                 2 M used swap
              2045 M free swap
      top - 20:27:21 up 7 days,  3:28,  2 users,  load average: 1.30, 1.23, 1.64
      Tasks: 143 total,   2 running, 141 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 24.5 us,  8.2 sy,  0.0 ni, 34.7 id,  0.0 wa,  0.0 hi,  0.0 si, 32.7 st
      MiB Mem :   3911.8 total,    828.4 free,   2002.2 used,   1081.2 buff/cache
      MiB Swap:   2048.0 total,   2045.8 free,      2.2 used.   1650.4 avail Mem
      *** FAILED SERVICES ***
       UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * fwupd-refresh.service loaded failed failed Refresh fwupd metadata and update motd
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  392M  1.1M  391M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    31G   12G   17G  42% /
      tmpfs                             tmpfs  2.0G     0  2.0G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   2.0G  252M  1.6G  14% /boot
      tmpfs                             tmpfs  392M  4.0K  392M   1% /run/user/1000
      [Fri Sep  5 16:59:19 2025] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri Sep  5 16:59:29 2025] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Fri Sep  5 16:59:39 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      Show mounted filesystems:
      TARGET              SOURCE                            FSTYPE   OPTIONS
      /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/snap/core20/2599 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2582 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/29351   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/31333   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/24792 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/25202 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue
      `-/boot             /dev/sda2                         ext4     rw,relatime
      /var:
      2.5G    /var/
      1.3G    /var/lib
      1.1G    /var/log/journal/c05560dcf27749d2a066e77e2d40bff4
      1.1G    /var/log
      Ubuntu 22.04.5 LTS
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      64M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      419M    /opt/iobroker/iobroker-data/
      260M    /opt/iobroker/iobroker-data/files
      110M    /opt/iobroker/iobroker-data/backup-objects
      58M     /opt/iobroker/iobroker-data/files/vis-2
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      42M     /opt/iobroker/iobroker-data/objects.jsonl
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
      7.7M    /opt/iobroker/iobroker-data/states.jsonl
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.5
      /usr/bin/node           v20.19.5
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.33.0
      nodejs:
       Installed: 20.19.5-1nodesource1
       Candidate: 20.19.5-1nodesource1
       Version table:
      *** 20.19.5-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             100 /var/lib/dpkg/status
          20.19.4-1nodesource1 1001
          20.19.3-1nodesource1 1001
          20.19.2-1nodesource1 1001
          20.19.1-1nodesource1 1001
          20.19.0-1nodesource1 1001
          20.18.3-1nodesource1 1001
          20.18.2-1nodesource1 1001
          20.18.1-1nodesource1 1001
          20.18.0-1nodesource1 1001
          20.17.0-1nodesource1 1001
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          12.22.9~dfsg-1ubuntu3.6 500
             500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
             500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
          12.22.9~dfsg-1ubuntu3 500
             500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobserver           iobserver (version: 7.0.7, hostname: iobserver     , alive, uptime: 2266)
      raspi4Display       raspi4Display (version: 7.0.7, hostname: raspi4Display , alive, uptime: 1923)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa 6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobserver -     enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.awtrix-light.0           : awtrix-light          : iobserver -     enabled
      + system.adapter.backitup.0               : backitup              : iobserver -     enabled
        system.adapter.backitup.1               : backitup              : raspi4Display - disabled
        system.adapter.dwd.0                    : dwd                   : iobserver -     enabled
        system.adapter.flot.0                   : flot                  : iobserver -     disabled
      + system.adapter.fritzdect.0              : fritzdect             : iobserver -     enabled
        system.adapter.frontier_silicon.0       : frontier_silicon      : iobserver -     disabled
      + system.adapter.frontier_silicon.1       : frontier_silicon      : iobserver -     enabled
        system.adapter.hyperion_ng.0            : hyperion_ng           : iobserver -     disabled
        system.adapter.ical.0                   : ical                  : iobserver -     enabled
      + system.adapter.javascript.0             : javascript            : iobserver -     enabled
      + system.adapter.javascript.1             : javascript            : iobserver -     enabled
      + system.adapter.nut.0                    : nut                   : iobserver -     enabled
      + system.adapter.rainbird.0               : rainbird              : iobserver -     enabled
      + system.adapter.rflink.0                 : rflink                : raspi4Display - enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspi4Display - enabled
      + system.adapter.shelly.0                 : shelly                : iobserver -     enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.socketio.0               : socketio              : iobserver -     enabled, port: 8084, bind: 0.0.0.0, run as: admi n
      + system.adapter.sonoff.0                 : sonoff                : iobserver -     enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sony-bravia.0            : sony-bravia           : iobserver -     enabled
      + system.adapter.sql.0                    : sql                   : iobserver -     enabled, port: 3307
      + system.adapter.synology.0               : synology              : iobserver -     enabled, port: 5001
      + system.adapter.telegram.0               : telegram              : iobserver -     enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobserver -     enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobserver -     enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobserver -     enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobserver -     enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobserver -     enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobserver -     enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobserver -     enabled
        system.adapter.vis.0                    : vis                   : iobserver -     enabled
      + system.adapter.web.0                    : web                   : iobserver -     enabled, port: 8082, bind: 0.0.0.0, run as: admi n
      + system.adapter.wled.0                   : wled                  : iobserver -     enabled
      + system.adapter.yamaha.0                 : yamaha                : iobserver -     enabled
      + system.adapter.zigbee.0                 : zigbee                : raspi4Display - enabled, port: /dev/serial/by-id/usb-Silicon_Lab s_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      + system.adapter.socketio.0               : socketio              : iobserver     -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobserver     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      │ (index) │ name     │ url                                                     │  auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │  false        │
      │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │  false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "frontier_silicon": 0.4.0 , installed 0.4.0
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "rainbird"     : 2.0.2    , installed 2.0.2
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Objects and States
      Objects:        7347
      States:         6902
      Ubuntu 22.04.5 LTS
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN       0          19051      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN       0          20205      768/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN       1001       5363148    102363/iobroker.js-
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN       1001       5363143    102363/iobroker.js-
      tcp        0      0 0.0.0.0:37815           0.0.0.0:*               LISTEN       114        1091660    22460/rpc.statd
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN       102        21703      701/systemd-resolve
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN       1001       5366042    102525/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN       1001       5370579    103113/io.sonoff.0
      tcp6       0      0 :::35231                :::*                    LISTEN       114        1091664    22460/rpc.statd
      tcp6       0      0 :::111                  :::*                    LISTEN       0          19053      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN       0          20207      768/sshd: /usr/sbin
      tcp6       0      0 :::8084                 :::*                    LISTEN       1001       5365104    102786/io.socketio.
      tcp6       0      0 :::8082                 :::*                    LISTEN       1001       5365043    102699/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN       1001       5371738    103193/io.admin.0
      udp        0      0 0.0.0.0:53862           0.0.0.0:*                            114        1091658    22460/rpc.statd
      udp        0      0 xx.xx.xx.xx:50146       0.0.0.0:*                            1001       5366068    102606/io.yamaha.0
      udp        0      0 127.0.0.1:1012          0.0.0.0:*                            0          1091652    22460/rpc.statd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                            1001       5364897    102718/io.wled.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                            1001       5366069    102606/io.yamaha.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                            102        21702      701/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                            0          19052      1/init
      udp6       0      0 :::34067                :::* 114        1091662    22460/rpc.statd
      udp6       0      0 :::111                  :::* 0          19054      1/init
      2025-09-12 20:03:50.338  - info: admin.0 (103193) ==> Connected system.user.admin from ::ffff:
      Seit geraumer Zeit beobachte ich, dass in der Zigbee-Übersicht Kacheln mit 'undefined' Geräten auftauchen. Bevor ich Anfang August diese Geräte bereist zum wiederholten Mal gelöscht habe, hatte ich mir mal deren ieee notiert, um zu shene, ob das immer die gleichen sind, Nun (Mitte Septpber) muss ich feststellen, dass genau diese beiden im August gelöscheten 'undefined'-Geräte nun wieder auftauchen. Seit wann genau die wieder da sind, weiß ich nicht.
      Im Log erscheinen dann folglich auch derartige Warnungen:
      zigbee.0	2025-09-12 19:56:25.907	warn	Device 0x84ba20fxxxxxxxxx "undefined" not found.
      zigbee.0	2025-09-12 19:56:22.849	warn	download icon undefined for undefined Device not available. Check your devices.
      Was kann das sein bzw. wo können die herkommen? Aus der Nachbarschaft? Wie schleichen die sich aber ohne aktivertes Pairing ein? Zudem nutze ich eigene individuelle Pan-IDs. Wie kann ich das verhindern?
      • Asgothian
        Asgothian Developer @bilberry last edited by Asgothian
        @bilberry sagte in ZigBee: 'undefined Devices' unbekannter Herkunft im Netzwerk:
        Script v.2025-08-09
        *** BASE SYSTEM ***
                Chassis: vm
         Virtualization: kvm
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 2
                     NTP service: active
                 RTC in local TZ: no
        xxx
        HOME=/home/xxx
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                3911 M total memory
                2002 M used memory
                 567 M active memory
                 828 M free memory
                 159 M buffer memory
                 921 M swap cache
                2047 M total swap
                   2 M used swap
                2045 M free swap
        *** FILESYSTEM ***
        /var:
        2.5G    /var/
        1.3G    /var/lib
        1.1G    /var/log
        Ubuntu 22.04.5 LTS
        USB-Devices by-id:
        HINT:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
         Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.2
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        7347
        States:         6902
        Ubuntu 22.04.5 LTS
        Pending Updates: 0
        Da du die IEEE zensierst und auch sonst wenig Informationen lieferst ist eine genaue Aussage unmöglich. Es gibt verschiedene Möglichkeiten:
        • Geräte die du per 'force delete' löscht, die dann aber trotzdem noch da sind und senden
        • Geräte die sich selber vom Netz abmelden, aber die Netzverschlüsselung behalten
        • Geräte die den Befehl das Netz zu verlassen nicht sauber umsetzen - Ja, ich meine z.Bsp. die Osram Plug01
        • Fehlverhalten von Routern im Netz
        Im ersten Schritt solltest du den Haken bei 'warn on device announce' setzen. Dann solltest du das Log genauer überwachen ob du Device-Announce Meldungen bekommst mit diesen beiden IEEE
        des Weiteren ist interessant ob es Meldungen zu geblocktem Interview bei geschlossenem Netzwerk gibt (im Log)
        A.
        Nachtrag: die IEEE lässt unter Umständen rückschlüsse auf den Hersteller zu.
        bilberry 1 Reply Last reply Reply Quote 0
        • bilberry
          bilberry @Asgothian last edited by
          @asgothian
          Danke für Deine erste Einschätzung!
          Das sind die vollständigen ieee der beiden:
          • 0x84ba20fffe28ba94
          • 0x540f57fffe760fbc
          Das 'Log warning on Zigbee device announcement' hatte ich bereits aktiv. Ich habe beide Geräte soeben wieder gelöscht. Ich werde jetzt mal in kürzeren Abständen prüfen, ob und ggf. wann die wieder auftauchen und schauen ob in dem Zeitraum was im Log zu finden ist.
          OSRAM SmartPlugs hatte ich tatsächlich auch mal im Einsatz aber vor einem guten Jahr endgültig rausgeschmissen und weggeben. Hab gerade einen alten Screenshot von einer damaligen Konfig gefunden, auf dem ich zumindest zwei der drei ieee der Steckdosen erkennen kann. Die beiden o.g. sind da aber leider nicht dabei.
          • Asgothian
            Damit ist auch nicht zu rechnen. Bei dem 084ba20 vermute ich einen Thermostat GS361AH04
            Für den anderen habe ich kein Beispiel.
            A.
            • bilberry
              @asgothian
              Das ist interessant. Ich erinnere mich! Vor länger Zeit wurde mir tatsächlich ein mir unbekanntes 'Thermostat' (sogar mit Bildchen) angezeigt. Und dabei habe ich gar keine smarten Thermostate im Haus (und Zigbee schon gar nicht) und habe ich auch nie besessen. Ich habe das damals auch mehrmals gelöscht, bis es irgendwann nicht wieder kam. Aber möglicherweise ist jetzt bloß kein Bildchen und kein Name mehr da. Den Namen habe ich mir damals leider nicht gemerkt oder notiert, drum kann ich jetzt nicht sagen, ob es genau das von Dir genannte war.
              In meinen Unterlagen finde ich gerade eine Notiz, dass der 'undefined' 0x84ba20fffe28ba94 mindestens im April 2023 schon mal aufgetaucht ist. Ich weiß - das hilft jetzt auch nicht weiter. Aber offenbar besteht das "Phänomen" schon deutlich länger, als mir vorhin bewusst war.
              • bilberry
                bilberry @bilberry last edited by
                Hallo @Asgothian,
                heute Morgen habe ich noch etwas weiter geforscht und folgende Erkenntnisse hinzugewonnen zu denen ich gern Deine Meinung wüsste:
                Ich habe mir im Ordner /opt/iobroker/iobroker-data/zigbee_0 die Dateien
                • nvbackup.json
                • LocalOverrides.json und
                • shepherd.db
                angeschaut. Dabei ist mir aufgefallen, dass in der 'nvbackup.json' fünf Geräte aufgeführt werden, die ich gar nicht besitze und auch nie besessen habe. Lediglich den 'f0d1b8000015541c ' (SmartPlug) hatte ich früher einmal. Zudem werden in der 'LocalOverrides.json' sogar zu zwei dieser Geräte Alternativbezeichnungen vorgehalten.
                In der 'shepherd.db' kommt derzeit keine der unten in der Tabelle genannten ieee's vor. (sicher auch weil ich gestern die zwei 'undefined' über den Adapter gelöscht hatte)
                Quelle: nvbackup.json		Quelle: LocalOverrides.json	Quelle: persönliche Aufzeichnungen
                ieee			nwk	Bezeichnung			Bezeichnung
                f0d1b8000015541c	f617	<kein Eintrag>			LEDVANCE SmartPlug
                84ba20fffe28ba94	6a61	<kein Eintrag>			TS0601_thermostat_3
                540f57fffe760fbc	fee0	<kein Eintrag>			undefined
                003c84fffebdd3ff	5f9f	ME167
                28dba7fffe741692	98f6	TRVZB
                Kann ich die unbekannten Geräte einfach von Hand aus den Dateien entfernen oder mache ich da mehr Schaden?
                • Asgothian
                  Hallo @Asgothian,
                  • nvbackup.json
                  • shepherd.db
                  Du solltest folgendes machen - zur Sicherheit:
                  • Adapter anhalten
                  • Den Haken bei start the Zigbee network automatically entfernen, settings speichern.
                  • Sicherheitskopie von nvbackup.json machen
                  • adapter starten
                  • über den Start/Stop Button in der Konfiguration (tab Hardware) versuchen den Adapter zu starten - im Textbereich darunter wird angezeigt was passiert. Sofern das Zigbee-Subsystem durchstartet ist alles ok. Wenn es Probleme gibt kannst du die nvbackup.json restaurieren und den Test wiederholen.
                  Alle Geräte die in der LocalOverrides.json eingetragen sind müssen
                  • mit dem Netzwerk verbunden gewesen sein.
                  • korrekt erkannt worden sein.
                    Die Einträge entstehen erst nachdem ein Gerät sauber gepaired wurde.
                  Die Einträge in der nvbackup.json können Grund sein warum die Geräte sich wieder mit dem Netz verbinden, obwohl sie das nicht dürften. Sie müssen aber irgendwo in Reichweite sein.
                  lebst du in einem Mehrfamilienhaus ?
                  A.
                  Die Einträge in der LocalOverrides.json kannst du gefahrlos beseitigen. Das schlimmste was passiert ist das von Dir vergebene Namen ggf. entfallen, und Wieder neu vergeben werden müssen.
                  Bei der nvBackup.json ist es etwas schwieriger - es gibt fälle wo es Probleme gibt den Adapter zu starten nachdem die Datei geändert wurde.
                  • bilberry
                    @asgothian
                    OK, danke für den Tipp. Hab ich gemacht. Lief alles wieder fehlerfrei an. Werde es nun weiter beobachten.
                      arteck Developer Most Active @bilberry last edited by
                      @bilberry kann sein dass du Geräte von einem Nachbar reinbekommst ??
                      • bilberry
                        bilberry @arteck last edited by bilberry
                        @arteck
                        Ausschließen kann ich es nicht - halte es aus persönlicher Erfahrung mit der Zigbee-Reichweite doch für sehr unwahrscheinlich. Mein direktes Nachbarhaus hat definitiv keine Zigbee-Geräte (oder sonstige 'smarte' Komponenten) im Einsatz. Das Nachbarhaus über die Straße ist locker 25 m von meinem Koordinator entfernt plus mind. 2 dicke Außenwände und kleine Fenster. Ich habe ja schon Empfangsprobleme mit Sensoren, die ich selbst außen "nur" 4-5 Meter von der Hauswand entfernt platziert habe.
                        Ich werde aber tatsächlich bei Gelegenheit mal nachfragen. Das interessiert mich schon. Auch wenn ich es für unwahrscheinlich halte, da sie m.W. auch komplett Fußbodenheizung haben und somit ebenfalls keine Verwendung für ein Heizkörperthermostat hätten.
                        Aber mal angenommen das wäre so: In welchen Fällen konnte sich ein fremdes Gerät mit meinem Netzwerk verbinden? So selten und kurz, wie ich den Pairing-Modus aktiv habe. Noch dazu: Wie kommen mir völlig unbekannte Namen in die 'LocalOverrides.json'? Ich habe es so verstanden, dass dort nur selbst vergebene Namen landen.
                        Edit: Habe gerade mal nach ME167 und TRVZB gegoogelt. Das sind ja offensichtlich auch alles Heizkörperthermostate. Also mind. 3 verschiedene, die mal bei mir drin waren.
                        • Asgothian
                          Das ist nicht zu 100% richtig.
                          Vor den LocalOverrides.json in denen deutlich mehr gespeichert werden kann als nur Namen gab es schon eine Datei devNames.json. In diese wurde der Name des Gerätes direkt beim Pairing eingetragen - sprich selbst wenn der Name nicht manuell verändert wurde gab es einen Eintrag in dieser Datei.
                          Beim Update auf 2.x wurde diese Datei eingelesen und dann in die LocalOverrides.json übertragen. Sprich die Geräte waren vor dem Update auf 2.x mal in deinem Netz.
                          A.
                            ja was den jetzt ..
                            hatte ..hat.. werde haben... vielleicht..
                            was den nu???
                            • bilberry
                              @arteck
                              Falls ich mich wirklich missverständlich ausgedrückt habe:
                              • mind. 3 der mir unbekannten Geräte in meiner Zigbee-Konfig sind Heizkörperthermostate
                              • ich besitze aber weder Thermostate und hab auch nie welche bessen
                              • Asgothian
                                Mindestens eine der Aussagen ist falsch.
                                Von alleine kommen die Geräte nicht in Dein Netz. Und da es sich bei den Geräten um TuYa Geräte handelt ist nicht einmal mehr sichergestellt das es sich um Heizkörperthermostate handelt - Sie haben sich halt nur mit den ID's von Heizkörperthermostaten gemeldet. Such mal unter https://www.zigbee2mqtt.io/supported-devices/ nach 'ts0601' und schau Dir an wie viele doch sehr wenig gleiche Geräte da gelistet werden - die alle melden sich initial als TS0601 - Erst durch Fingerprinting lassen die sich exakt identifizieren. Daher ist die Folgende Situation nicht unwahrscheinlich:
                                • Jemand kauft ein TuYa Gerät
                                • Er versucht dieses mit dem Netzwerk zu verbinden - das klappt auch, aber das erkannte Gerät und das gekaufte Gerät passen nicht zusammen (kein passender fingerprint)
                                • Er nimmt das Gerät aus dem Netzwerk und schickt es zurück.
                                  In diesem Fall verbleibt ein Eintrag in der dev_names.json (Absichtlich - die Datei dient ja gerade dazu das ein Gerät basierend auf seiner IEEE auch dann den gleichen Namen bekommt wenn ansonsten alles zurück gesetzt wurde.
                                Wenn man das mit betrachtet erscheint es unmöglich im Nachgang zu klären welches die falsche(n) Aussage(n) ist(sind).
                                Sicher ist:
                                • Irgendwann haben sich Geräte mit den entsprechenden IEEE während des Pairings mit Deinem Netzwerk verbunden und sind entsprechend in der Shepherd.db (und nachfolgend der devnames.json) eingetragen worden. Zu diesem Zeitpunkt muss es auch die Objekte gegeben haben.
                                • Diese Geräte wurden wieder aus dem Netzwerk entfernt - entweder manuell durch einen Bediener oder durch eine device leave Nachricht vom Gerät selber.
                                Zum Thema Reichweite, Funknetz und so weiter:
                                • Insbesondere bei Sensoren die mit Knopfzellen betrieben werden ist oft die Sendeleistung besonders gering um die Lebensdauer der Batterie zu erhöhen
                                • 2.4 GHz Funkwellen können durch Reflexion / Schwebung erstaunliche Reichweite erreichen - teilweise abhängig vom Wetter, von geparkten Autos oder anderen Effekten.
                                • Die Geräte können Zeitweilig irgendwo vorhanden gewesen sein (zum Test, o.ä.)
                                letztendlich bezweifle ich dass du dem wirklich auf den Grund gehen kannst. Was ich anbieten kann
                                Ab Version 3.1.x (wahrscheinlich 3.1.3, ggf. 3.1.2) kann der Adapter die Datenpunkte Zigbee.0.info.devicecount und Zigbee.0.info.groupount (beide neu, gibts aktuell noch nicht) befüllen, so das du einen Zeitlich zum hinzugefügten Device passenden Trigger bekommen kannst. Diese beiden DP werden aktualisiert:
                                • bei jedem Start des Adpaters
                                • Wenn der Adapter ein neues Gerät einbindet
                                • Wenn der Nutzer ein Gerät(eine Gruppe) im Adapter löscht
                                • Wenn ein Gerät via device_leave das Netzwerk verlässt.
                                • Wenn der Nutzer eine Gruppe hinzufügt.
                                Dabei wird nicht garantiert das die Aktualisierung genau den Zeitpunkt trifft wo ein Gerät dem Netz beitritt - es wird der Zeitpunkt genommen an dem der Adapter dieses bemerkt. Und auch da ist es denkbar das zumindest am Anfang nicht alle Möglichkeiten dazu sauber erkannt werden.
                                A.
                                203
