    4. Tester wanted - Zigbee Adapter 3.1
      dimaiv last edited by dimaiv
      P.S.: Fixed.
      Beim Uberprüfen auf Firmware Updates stürzt der Adapter ab.
      2025-09-12 14:01:38.052 - info: zigbee.0 (248399) 20 devices are part of the network
      2025-09-12 14:01:38.056 - info: zigbee.0 (248399) Zigbee started
      2025-09-12 14:01:38.253 - info: zigbee.0 (248399) debug devices set to []
      2025-09-12 14:01:55.422 - info: admin.0 (890) <== Disconnect system.user.admin from ::ffff:192.168.2.100
      2025-09-12 14:03:02.582 - info: admin.0 (890) ==> Connected system.user.admin from ::ffff:192.168.2.100
      2025-09-12 14:03:03.158 - info: zigbee.0 (248399) List of port: []
      2025-09-12 14:03:10.168 - error: zigbee.0 (248399) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-09-12 14:03:10.169 - error: zigbee.0 (248399) unhandled promise rejection: Cannot read properties of undefined (reading 'indexOf')
      2025-09-12 14:03:10.508 - error: zigbee.0 (248399) TypeError: Cannot read properties of undefined (reading 'indexOf')
      at getZbId (/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js:92:23)
      at Ota.getDeviceForMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/ota.js:194:23)
      at Ota.checkOtaAvail (/opt/iobroker/node_modules/iobroker.zigbee/lib/ota.js:56:35)
      at Ota.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/ota.js:46:26)
      at Zigbee.emit (node:events:536:35)
      at Zigbee.emit (node:domain:489:12)
      at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11040:34)
      at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:365:37)
      at processImmediate (node:internal/timers:483:21)
      2025-09-12 14:03:10.509 - error: zigbee.0 (248399) Cannot read properties of undefined (reading 'indexOf')
      2025-09-12 14:03:10.533 - info: zigbee.0 (248399) Halting zigbee adapter. Restart delay is at least 30 seconds.
      2025-09-12 14:03:10.534 - info: zigbee.0 (248399) cleaning everything up...
      2025-09-12 14:03:10.540 - info: zigbee.0 (248399) Saved local configuration data
      2025-09-12 14:03:10.907 - info: zigbee.0 (248399) Device zigbee.0.00124b0022571c92 is marked unavailable, skipping...
      2025-09-12 14:03:10.982 - info: zigbee.0 (248399) Closing Zigbee network, 0 seconds remaining
      2025-09-12 14:03:11.535 - warn: zigbee.0 (248399) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-09-12 14:03:12.124 - error: host.GartenIoB Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2025-09-12 14:03:12.125 - error: host.GartenIoB Caught by controller[2]: TypeError: Cannot read properties of undefined (reading 'indexOf')
      2025-09-12 14:03:12.125 - error: host.GartenIoB Caught by controller[2]: at getZbId (/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js:92:23)
      2025-09-12 14:03:12.125 - error: host.GartenIoB Caught by controller[2]: at Ota.getDeviceForMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/ota.js:194:23)
      2025-09-12 14:03:12.125 - error: host.GartenIoB Caught by controller[2]: at Ota.checkOtaAvail (/opt/iobroker/node_modules/iobroker.zigbee/lib/ota.js:56:35)
      2025-09-12 14:03:12.125 - error: host.GartenIoB Caught by controller[2]: at Ota.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/ota.js:46:26)
      2025-09-12 14:03:12.125 - error: host.GartenIoB Caught by controller[2]: at Zigbee.emit (node:events:536:35)
      2025-09-12 14:03:12.126 - error: host.GartenIoB Caught by controller[2]: at Zigbee.emit (node:domain:489:12)
      2025-09-12 14:03:12.126 - error: host.GartenIoB Caught by controller[2]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11040:34)
      2025-09-12 14:03:12.126 - error: host.GartenIoB Caught by controller[2]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:365:37)
      2025-09-12 14:03:12.126 - error: host.GartenIoB Caught by controller[2]: at processImmediate (node:internal/timers:483:21)
      2025-09-12 14:03:12.126 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-09-12 14:03:12.127 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
      2025-09-12 14:03:17.768 - info: admin.0 (890) <== Disconnect system.user.admin from ::ffff:192.168.2.100
      2025-09-12 14:03:42.865 - info: host.GartenIoB instance system.adapter.zigbee.0 in version "3.1.0" (non-npm: ioBroker/ioBroker.zigbee) started with pid 248418
      2025-09-12 14:03:46.062 - info: zigbee.0 (248418) starting. Version 3.1.0 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.4, js-controller: 7.0.7
      2025-09-12 14:03:46.119 - info: zigbee.0 (248418) Adapter ready - starting subsystems. Adapter is running in info mode.
      Asgothian Homoran 2 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @dimaiv last edited by
        @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
        Lässt sich das auf bestimmte devices eingrenzen ?
        Zum testen sollte es reichen die Devices über die Oberfläche zu deaktivieren.
          Homoran Global Moderator Administrators @dimaiv last edited by
          hatte ich auch früher schon, lag anscheinend am sentry-Modul.
          Ich sehe bei dir im log, aber nicht die selben Meldungen.
          Du kannst es ja mal abschalten
            dimaiv @Asgothian last edited by dimaiv
            P.S.: Fixed.
            @asgothian
            Es ist egal, was und wie viele ich deaktiviere bis auf alle 20, kommt gleiche Fehler.
            P.S.: Auch wenn ich sentry aus mache...
              arteck Developer Most Active @Homoran last edited by
              @homoran ne das ist nicht sentry
              • Asgothian
                Asgothian Developer @arteck last edited by
                @arteck War nich sentry. Ist gefixed.
                A.
                  Shadowhunter23 @Asgothian last edited by Shadowhunter23
                  @asgothian
                  Bin mal auf 3.1.0, hab allerdings keine Lampen und Gruppen.
                  Bisher keine Probleme.
                  • Asgothian
                    Asgothian Developer last edited by
                    Es gibt wieder eine neue Version.
                    Man kann zusätzlich den Zeit-Abstand zwischen den Pings einstellen. Wobei diese Einstellung nicht fix ist, je nach Anzahl der anzueignenden Devices verändert der Adapter den Timeout um das Netz nicht zu sehr zu belasten.
                    • O
                      oxident last edited by
                      Ich habe ein Test-Netz aufgebaut und möchte da mittelfristig meine (über 100) Geräte/Sensoren von Deconz rüberholen.
                      Daher kann ich ganz entspannt schon direkt ein paar Dinge mit dem latest Release testen.
                      Spontan aufgefallen ist mir, dass der iot-Adapter scheinbar versucht, benannte Farben in den Hex-Datenpunkt eine Hue-Lampe zu schreiben.
                      Bitte steinigt mich nicht, falls das die völlig falsche Baustelle ist 😉
                      Asgothian 2 Replies Last reply Reply Quote 0
                      • Asgothian
                        Asgothian Developer @oxident last edited by Asgothian
                        @oxident sagte in Tester wanted - Zigbee Adapter 3.1:
                        bist du sicher ? der ist Adapter sollte aussschliesslich die im Screenshot markierten Datenpunkte erkennen:
                        Der Zigbee Adapter nutzt den color Datenpunkt aus der Vergangenheit und da z2m das so akzeptiert mir durchaus verschiedenen Formaten. Neben dem für den Zigbee Adapter einzigartigen named color format (dazu gibt es eine Liste von durch alle Web-Browser erkannte benannte Farben (die extended Colors)) werden noch die von Z2M akzeptierten Formate akzeptiert. Die Liste ist lang (kopiert von der Doku auf Z2M, z.Bsp. von diesem Gerät😞
                        • color_xy: To control the XY color (CIE 1931 color space) publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"color": {"x": X_VALUE, "y": Y_VALUE}} (e.g. {"color":{"x":0.123,"y":0.123}}). To read the XY color send a message to zigbee2mqtt/FRIENDLY_NAME/get with payload {"color":{"x":"","y":""}}. Alternatively it is possible to set the XY color via RGB:
                          {"color": {"r": R, "g": G, "b": B}} e.g. {"color":{"r":46,"g":102,"b":150}}
                          {"color": {"rgb": "R,G,B"}} e.g. {"color":{"rgb":"46,102,150"}}
                          {"color": {"hex": HEX}} e.g. {"color":{"hex":"#547CFF"}}
                        • color_hs: To control the hue/saturation (color) publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set with payload {"color": {"hue": HUE, "saturation": SATURATION}} (e.g. {"color":{"hue":360,"saturation":100}}). To read the hue/saturation send a message to zigbee2mqtt/FRIENDLY_NAME/get with payload {"color":{"hue":"","saturation":""}}. Alternatively it is possible to set the hue/saturation via:
                          HSB space (hue, saturation, brightness): {"color": {"h": H, "s": S, "b": B}} e.g. {"color":{"h":360,"s":100,"b":100}} or {"color": {"hsb": "H,S,B"}} e.g. {"color":{"hsb":"360,100,100"}}
                          HSV space (hue, saturation, value):{"color": {"h": H, "s": S, "v": V}} e.g. {"color":{"h":360,"s":100,"v":100}} or {"color": {"hsv": "H,S,V"}} e.g. {"color":{"hsv":"360,100,100"}}
                          HSL space (hue, saturation, lightness){"color": {"h": H, "s": S, "l": L}} e.g. {"color":{"h":360,"s":100,"l":100}} or {"color": {"hsl": "H,S,L"}} e.g. {"color":{"hsl":"360,100,100"}}
                        Jedes Format X das im Payload hinter {"color":X} akzeptiert wird kann auch im DP color benutzt werden.
                        Z2M unterscheided dabei Geräte die mit color_xy und/oder color_hs arbeiten. Der Zigbee-Adapter macht das auch, die Datenpunkte unter color_hs gibt es nur wenn z2m auch color_hs meldet. Mir sind keine Geräte bekannt die color_hs unterstützen, color_xy aber nicht.
                        Damit ist der iot Adapter überfordert. Deswegen gibt es die mit den entsprechenden Rollen versehenen Datenpunkte die ich im Screenshot markiert habe. All diese Datenpunkte machen letztendlich nichts anderes als den color Datenpunkt mit entsprechenden Werten zu füttern, damit diese dann an Z2M geschickt werden.
                        Auf der Kachel im Zigbee-Adapter wird immer nur die 'named' Farbe angeboten - das ist die einzige Möglichkeit wie ich da Farbe bei dem begrenzten Platz überhaupt auswählbar machen kann. Code-Technisch wird da mediumvioletred angezeigt wenn im DP color keine der korrekten named Colors drin steht.
                        Eine falsche Baustelle gibt es nicht. (aber da du danach gefragt hast, nimm dies hier 🪨 🙂 )
                        A.
                        Edit: Quelle hinzugefügt.
                        Asgothian 1 Reply Last reply Reply Quote 1
                        • Asgothian
                          Asgothian Developer @Asgothian last edited by Asgothian
                          Es gibt inzwischen eine 3.1.1
                          Bitte auf die 3.1.1 aktualisieren und normale Gerätefunktion testen. Ich habe auf die ZHC 25 umgestellt, bei der vor breaking changes gewarnt wurde. Was ich gefunden hab habe ich umgestellt. Ob ich alles gefunden habe weiss ich aber nicht!
                          Wichtig: Bitte vor der Installation den Zigbee Adapter anhalten !!!
                          A.
                            @asgothian
                            Hab eben von GitHub installiert, Version bleibt bei 3.1.0.
                            • Asgothian
                              Asgothian Developer @Shadowhunter23 last edited by
                              @shadowhunter23 Bitte nochmal installieren - da ist was mit der Version schief gegangen. Jetzt sollte es 3.1.1 sein
                              A.
                              • Asgothian
                                @oxident Eine Frage,
                                hast du beim Anlernen der Leichen Probleme gehabt ? Mit der 3.1.0 ?
                                Was ist mit der 3.1.1 ? Geht da das Anlernen genau so gut ?
                                Ich hab hier vereinzelt seltsames Verhalten welches ich mit dem Debugger nicht v erfolgen kann da sich dadurch das Timing ändert.
                                A.
                                O Asgothian 2 Replies Last reply Reply Quote 0
                                • O
                                  oxident @Asgothian last edited by
                                  @asgothian Habe ehrlich gesagt nur eine einzelne Hue-Lampe angelernt. Da gab es keine Probleme bei der 3.0.1
                                  • Asgothian
                                    Inzwischen gibt es eine 3.1.2 - der Pairing bug ist gefunden und behoben (hoffentlich) - Es war alter Code der früher wohl mal notwendig war, heute aber Probleme macht.
                                    Dieser musste mit ZHC25 entfernt werden.
                                    A.
                                    Fabio 1 Reply Last reply Reply Quote 2
                                    • Fabio
                                      Fabio @Asgothian last edited by Fabio
                                      @asgothian wenn ich auf eine meiner beidem ZigBee Instanzen klicke kommt diese Meldung:
                                      zigbee.0
                                      2025-09-16 07:32:47.731	warn	Resolve Entity did not manage to find a mapped device for [object Object]
                                      Ansonsten läuft alles super Vielen Dank.
                                      Herzliche Grüße
                                      Fabio
                                      • Asgothian
                                        Asgothian Developer @Fabio last edited by Asgothian
                                        @fabio sagte in Tester wanted - Zigbee Adapter 3.1:
                                        zigbee.0
                                        Herzliche Grüße
                                        Fabio
                                        3.1.1 oder 3.1.2 ?
                                        Die Meldung darf eigentlich nicht kommen - Sie ist ein Zeichen das etwas nicht so ist wie es soll. Ich beheb die Meldung mal eben, dann kannst du die 3.1.2 neu installieren und laufen lassen.
                                        Wenn die Meldung weiterhin kommt bitte mal schauen ob es immer das gleiche Device ist oder ob es unterschiedliche Devices sind.
                                        Wenn es immer das gleiche Device ist müsstest Du mir die Zeile(n) aus der shepherd.db posten in der die IEEE des Devices auftaucht.
                                        A.
                                        Fabio 1 Reply Last reply Reply Quote 0
                                        • Fabio
                                          @asgothian ist die 3.1.2
                                          Welche Version denn von Github oder aus der Beta da hatte ich die 3.1.2 her.
                                          Fabio
                                          • Asgothian
                                            @fabio Github
                                            tester zhc zigbee zigbee 3.1
                                            1229
