    4. Neuer Adapter für Roborock-Staubsauger
    • N
      nu_81 @D3ltoroxp last edited by
      Habe den Adapter komplett entfernt und neu installiert.
      Der Fehler bleibt leider.
      Jemand noch eine Idee?
      host.raspberrypi
      2025-09-01 20:11:10.015	info	Restart adapter system.adapter.roborock.0 because enabled
      host.raspberrypi
      2025-09-01 20:11:10.015	error	instance system.adapter.roborock.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      2025-09-01 20:11:10.015	error	Caught by controller[0]: }
      host.raspberrypi
      2025-09-01 20:11:10.015	error	Caught by controller[0]: code: 'ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH'
      host.raspberrypi
      2025-09-01 20:11:10.015	error	Caught by controller[0]: reason: 'wrong final block length',
      host.raspberrypi
      2025-09-01 20:11:10.015	error	Caught by controller[0]: library: 'Provider routines',
      host.raspberrypi
      2025-09-01 20:11:10.015	error	Caught by controller[0]: at UDP.onMessage (node:dgram:988:8) {
      host.raspberrypi
      2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
      host.raspberrypi
      2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.emit (node:events:518:28)
      host.raspberrypi
      2025-09-01 20:11:10.014	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33)
      host.raspberrypi
      2025-09-01 20:11:10.014	error	Caught by controller[0]: at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25)
      host.raspberrypi
      2025-09-01 20:11:10.014	error	Caught by controller[0]: at Decipheriv.final (node:internal/crypto/cipher:184:29)
      host.raspberrypi
      2025-09-01 20:11:10.014	error	Caught by controller[0]: Error: error:1C80006B:Provider routines::wrong final block length
      roborock.0
      2025-09-01 20:11:09.673	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2025-09-01 20:11:09.671	info	terminating
      roborock.0
      2025-09-01 20:11:09.641	error	Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
      roborock.0
      2025-09-01 20:11:09.641	error	Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:518:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
      roborock.0
      2025-09-01 20:11:09.640	error	uncaught exception: error:1C80006B:Provider routines::wrong final block length
      roborock.0
      2025-09-01 20:11:07.212	info	MQTT initialized
      roborock.0
      2025-09-01 20:11:05.656	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
      roborock.0
      2025-09-01 20:11:05.626	info	starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.18.0, js-controller: 7.0.7
      • N
        nu_81 @nu_81 last edited by
        @nu_81 said in Neuer Adapter für Roborock-Staubsauger:
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        Hab es durch iÍnstallation des dev_ts gelöst.
        • N
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          Hab es durch Installation des dev_ts gelöst.
          • N
            Nachtfuchs last edited by
            Hallo Gemeinde,
            wir sind seit gestern Besitzer des QRevo Slim und nun soll dieser natürlich auch mit dem ioBroker sprechen. Adapter aus Adapterliste ausgewählt, aber er wirft diese Fehlermeldungen aus - kennt das jemand?
            Dank euch
            Thomas Braun B 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @Nachtfuchs last edited by Thomas Braun
              @nachtfuchs
              iob stop
              iob fix
              iob start
              Und bring deine nodejs-Installation in Ordnung. Keine aktuelle Version verwendet npm 10.7.0.
              • N
                @Thomas-Braun
                Mal wieder unglaublicher support, DANKE!
                Und danke für den Hinweis, werde mich mal am Wochenende an Dein nodejs Fixer Skript machen.
                • N
                  Nachtfuchs last edited by Nachtfuchs
                  Hallo Gemeinde,
                  ich tauche tiefer in den Adapter ein und habe eine Frage:
                  Setting
                  Wir haben im Anbau ein Badezimmer und Wohn-/Schlafzimmer. Ersteres mit Fliesen, letztere mit Parkett.
                  Ich habe dem QRevo Slim in der App zwei Programme geschrieben:
                  1. im Badezimmer wischen, den Rest saugen
                  2. die gesamte Fläche mit wenig Wasser wischen, also Fliesen und Parkett
                  Im Badezimmer haben wir den HMIP WRC 6, ein Schalter ist "Staubsauger" - dieser führt dazu, dass
                  a) das Sonos ausgeht (Pause button = wahr)
                  b) der Staubsauger angeht mit Programm 1) und
                  c) nach einer Verzögerung das Licht ausgeht
                  1. soll nur sehr selektiv ausgeführt werden; diesen würde ich dann über einen anderen Taster auf dem WRC 6 steuern.
                  Die Idee war nun, in den Datenpunkt "StartProgram" das Programm mit dem Namen "Saug+Wi Anbau" (Programm 1) zu schreiben, damit er genau das tut.
                  Dieses möchte ich über das angefügte Script erreichen, aber wenn ich auslöse, beginnt er mit der Voll-Reinigung, sprich Wischen überall.
                  Ziel wäre wie gesagt, mittels des anderen Tasters auch "Wi Anbau" (2) zu steuern.
                  Wenn ich hingegen das Programm auf der IOBroker Oberfläche setze, so reinigt er richtig.
                  Ich hatte in einer anderen script-Version auch erst das Programm geschrieben und dann den Datenpunkt "app_start" auf TRUE gesetzt, im Sinne erst Programm mitteilen, dann starten - hat leider auch nicht funktioniert.
                  Wo habe ich den Denkfehler?
                  Dank euch
                    bjappler @Nachtfuchs last edited by bjappler
                    @nachtfuchs
                    ich bekomme auch eine ähnliche Fehlermeldung.
                    $ iobroker add roborock --host 43f86e6ffd35
                    NPM version: 10.8.2Installing iobroker.roborock@0.6.18... (System call)
                    npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: iobroker.roborock@0.6.18npm error notsup Not compatible with your version of node/npm: iobroker.roborock@0.6.18npm error notsup Required: {"node":">= 20"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2025-09-11T13_59_37_295Z-debug-0.loghost.43f86e6ffd35 Cannot install iobroker.roborock@0.6.18: 1
                    ERROR: Process exited with code 25
                    Das System ist ein Dockerimage der Version v9.1.2. Doch auch mit Version V10 und der aktuellsten V11 wird die gleiche Fehlermeldung angezeigt (https://github.com/buanet/ioBroker.docker/releases).
                    Leider kann ich die Kommandos
                    @thomas-braun said in Neuer Adapter für Roborock-Staubsauger:
                    @nachtfuchs
                    iob stop
                    iob fix
                    iob start
                    nicht im Container nicht ausführen, dann kommt die Meldung "The execution of this command is blocked as your ioBroker is running inside a Docker container!"
                    Kennt sich jemand hiermit aus?
                      Thomas Braun Most Active @bjappler last edited by Thomas Braun
                      @bjappler sagte in Neuer Adapter für Roborock-Staubsauger:
                      Du hast da noch
                      "node":"v18.20.4"
                      installiert, der Adapter verlangt aber
                      Also nodejs sauber installieren/updaten.
                      Bzw. das akutelle Docker-Imager ausrollen.
                      • D3ltoroxp
                        Habt ihr bei euch den Status euerer Station drin ?
                        • N
                          Nachtfuchs @Nachtfuchs last edited by Nachtfuchs
                          Verzeiht die Nachfrage,
                          hat keiner eine Idee?
                          Dank euch
                          @nachtfuchs said in Neuer Adapter für Roborock-Staubsauger:
                          Hallo Gemeinde,
                          Setting
                          Dank euch
                            wolfi913 @Nachtfuchs last edited by
                            @nachtfuchs sagte in Neuer Adapter für Roborock-Staubsauger:
                            Schau Dir mal mein Blockly hier an
                            Das erstellt Dir für die in der App gespeicherten Programme jeweils einen Datenpunkt mit dem Du das jeweilige Programm starten kannst.
                              samsungfreak last edited by
                              ich habe seid ein paar Tage das Problem, dass der Roborock Adapter "rot" wird und die DPs nicht aktualisiert werden.
                              Wenn ich den Adapter starte ist er für 5 Minuten "grün" ohne die DPs zu aktualsieren. Folgendes steht im Debug LOG:
                              Hat jemand eine Idee, woran es liegt?
                                mx-driver @samsungfreak last edited by
                                @samsungfreak said in Neuer Adapter für Roborock-Staubsauger:
                                Seit mein S8 ein Firmware update bekommen hat geht bei mir auch nix mehr.
                                • Frederik Buss
                                  Frederik Buss last edited by
                                  Ich habe mittlerweile eine HomeAssistant VM auf meinem Proxmox neben iobroker installiert und dort funktioniert der Saros10 vom Start weg. Dank HASS Adapter lässt der sich aus iobroker heraus wirklich gut steuern, mit Bildchen, Programme starten und allem drum und dran. Ich bin kein Freund davon die beiden Systeme parallel laufen zu haben, aber es kommen immer mehr Restriktionen (Roborock, Samsung, BMW, OttoWilde und keine Ahnung wer noch künftig dazu kommt). Immerhin es geht mit etwas einlesen, YouTube Tutorials schauen, Backups ziehen usw.
                                    AXMLM last edited by AXMLM
                                    habe Qrevo Master. Adapter wird für 1 Sekunde grün und wird mit einigen Fehlermeldungen geschlossen.
                                    host.smarthome
                                    2025-10-04 19:08:53.259	info	Restart adapter system.adapter.roborock.0 because enabled
                                    host.smarthome
                                    2025-10-04 19:08:53.259	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    roborock.0
                                    2025-10-04 19:08:52.606	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    roborock.0
                                    2025-10-04 19:08:52.604	info	terminating
                                    roborock.0
                                    2025-10-04 19:08:52.595	error	Cannot read properties of undefined (reading 'captureException')
                                    roborock.0
                                    2025-10-04 19:08:52.594	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:881:44) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:211:19) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
                                    roborock.0
                                    2025-10-04 19:08:52.593	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                                    roborock.0
                                    2025-10-04 19:08:52.592	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    roborock.0
                                    2025-10-04 19:08:52.589	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
                                    roborock.0
                                    2025-10-04 19:08:52.363	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                                    roborock.0
                                    2025-10-04 19:08:52.287	info	MQTT initialized
                                    roborock.0
                                    2025-10-04 19:08:51.821	info	Loaded existing clientID: 031db179-0b1b-4eb0-8104-83d8f1eae377
                                    roborock.0
                                    2025-10-04 19:08:51.798	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                    roborock.0
                                    2025-10-04 19:08:51.779	info	starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.5, js-controller: 7.0.7
                                    host.smarthome
                                    2025-10-04 19:08:48.709	info	instance system.adapter.roborock.0 in version "0.6.19" started with pid 484173
                                    host.smarthome
                                    2025-10-04 19:08:18.230	info	Restart adapter system.adapter.roborock.0 because enabled
                                    host.smarthome
                                    2025-10-04 19:08:18.229	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    roborock.0
                                    2025-10-04 19:08:18.109	info	terminating
                                    roborock.0
                                    2025-10-04 19:08:17.604	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    roborock.0
                                    2025-10-04 19:08:17.602	info	terminating
                                    roborock.0
                                    2025-10-04 19:08:17.593	error	Cannot read properties of undefined (reading 'captureException')
                                    roborock.0
                                    2025-10-04 19:08:17.592	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:881:44) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:211:19) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
                                    roborock.0
                                    2025-10-04 19:08:17.591	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                                    roborock.0
                                    2025-10-04 19:08:17.590	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    roborock.0
                                    2025-10-04 19:08:17.587	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
                                    roborock.0
                                    2025-10-04 19:08:14.483	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
                                    roborock.0
                                    2025-10-04 19:08:14.383	info	MQTT initialized
                                    roborock.0
                                    2025-10-04 19:08:13.808	info	Loaded existing clientID: 031db179-0b1b-4eb0-8104-83d8f1eae377
                                    roborock.0
                                    2025-10-04 19:08:13.787	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                    roborock.0
                                    2025-10-04 19:08:13.768	info	starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.5, js-controller: 7.0.7
                                    ich vermute dass es daran liegt, dass der Roboter nocj nicht unterstützt wird. Oder gibt es noch andere Gründe?
                                      Thomas Braun Most Active @AXMLM last edited by
                                      @axmlm sagte in Neuer Adapter für Roborock-Staubsauger:
                                      Mag zwar kein Grund sein, aber bring das Ding auf nodejs@22. Per
                                      iob nodejs-update
                                      ist das in 2 Minuten passiert.
                                      A 2 Replies Last reply Reply Quote 0
                                        AXMLM @Thomas Braun last edited by
                                        iob nodejs-update
                                        habe kein putty auf dieem Rechner. Gibt es einen weg über IObroker selbst?
                                          @axmlm
                                          Da läuft doch ein Linux. Also hast du da auch ein Teminal.
                                            stehe auf dem Schlauch. habe Ubuntu Server mit IObroker und kann nur über Putty zugreifen. weder monitor noch Tastatur ist angeschlossen.
                                            1.2k
                                            80.8k
                                            912
                                            295712
