    4. Adresse aus GPS Koordinaten ermitteln ?
    • Codierknecht
      Codierknecht Developer Most Active @Razer2412 last edited by
      @razer2412
      Da wurde hier schon X mal besprochen.
      Falls die Forensuche zu viel Aufwand bedeutet: Ich habe da mal was vorbereitet ...
      https://forum.iobroker.net/search?term=request httpget&in=titlesposts&matchWords=all&sortBy=timestamp&sortDirection=desc&showAs=posts
        Micha 3 @Codierknecht last edited by Micha 3
        Geht trotzdem nicht.
        Beim ersten
        	2025-09-13 19:19:24.405	warn	script.js.common.GPS: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
        Wenn wir schon dabei sind, beim Warmwasser sogar die Meldung.
        	2025-09-13 19:16:21.923	error	script.js.Zentrale.Warmwassersteuerung: httpGet(url=http://192.168.178.136/cm?cmnd=counter1%200, error=timeout of 1500ms exceeded)
        das blockly-skript
          <variables>
            <variable id="t{9+flX*7=dsZdJ6pUDs">Position</variable>
            <variable id="InM51wH+hhRZ1K}Uo6R:">result</variable>
          </variables>
          <block type="http_get" id="m-)iMJC?nyP-2Z{jK*{S" x="338" y="502">
            <field name="TIMEOUT">2000</field>
            <field name="UNIT">ms</field>
            <field name="TYPE">arraybuffer</field>
            <value name="URL">
              <shadow type="text" id="mtY5?0cuLz,.0t!EWqIB">
                <field name="TEXT">http://</field>
              <block type="text_join" id="%AIgcwHNe/@sw*U01y$j">
                <value name="ADD0">
                  <block type="text" id="w`-_6V`Q}otb@4S:2plf">
                    <field name="TEXT">https://dataservice.accuweather.com/locations/v1/cities/geoposition/search?apikey=xxxxxxxxxxxxx=</field>
                <value name="ADD1">
                  <block type="get_value" id="SKOaXNue28T!,3USSm[}">
                    <field name="OID">0_userdata.0.GPS.accuweather_GPS</field>
              <block type="variables_set" id="B.8O%)EDl50Pxp@#{+%.">
                <field name="VAR" id="t{9+flX*7=dsZdJ6pUDs">Position</field>
                  <block type="text_getSubstring" id="owiE8!SuQ*Q%@^B#G8=2">
                    <mutation at1="true" at2="true"></mutation>
                    <field name="WHERE1">FROM_START</field>
                    <field name="WHERE2">FROM_START</field>
                    <value name="STRING">
                      <block type="variables_get" id="e4z]G)3d#LQfW2QN0ZM!">
                        <field name="VAR" id="InM51wH+hhRZ1K}Uo6R:">result</field>
                    <value name="AT1">
                      <block type="math_number" id="/`f+By;MjuAQu~YW(O(4">
                        <field name="NUM">21</field>
                    <value name="AT2">
                      <block type="math_number" id="6!?5#)73q+T{zE_B].7O">
                        <field name="NUM">27</field>
                  <block type="update" id="{b$:l~qpE|8N{)e*U6~I">
                    <field name="OID">0_userdata.0.GPS.accuweather_Position</field>
                      <block type="convert_tonumber" id="QWY0%hWvBuBR#=3oK=L*">
                          <block type="variables_get" id="AMy:l(Q?52+HV;3@1K@N">
          <block type="on" id="Oa.K#_8v*gk[2_8:{/hf" x="338" y="738">
            <field name="OID">hm-rpc.2.00021BE99E2EFA.3.STATE</field>
            <field name="CONDITION">false</field>
              <block type="timeouts_settimeout" id="OVb_d2mk9).9s77}ZxLm">
                <field name="DELAY">2000</field>
                  <block type="http_get" id="n$[MBQ:|r$H4L_Fm0-9u">
                    <field name="TIMEOUT">1500</field>
                    <value name="URL">
                      <shadow type="text" id="jy.JTwBxm9C)KyeVI`--">
                        <field name="TEXT">http://192.168.178.136/cm?cmnd=counter1%200</field>
          Homoran Global Moderator Administrators @Micha 3 last edited by
          @micha-3 bitte das Blockly zeigen!
          @micha-3 sagte in Adresse aus GPS Koordinaten ermitteln ?:
          und
          TYPE">arraybuffer
          sieht für mich nicht korrekt aus
            Micha 3 last edited by Micha 3
            Geht mit "text" aber auch nicht.
            EDIT/ Jetzt hab ich den Fehler. Aber wie beheb ich das? ich kann kein JS, das ist alles nur zusammen kopiert.
            var request =require('request');
            let result;
            const options = {
                url: 'https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18',
                method: 'GET',
                headers: {
                    'Accept': 'application/json',
                    'Accept-Charset': 'utf-8',
                    'User-Agent': 'iobroker script'
            request(options, function(err,response,body){
                result = JSON.parse(body);
            await wait(1000);
            return result;
            • bahnuhr
              bahnuhr Forum Testing Most Active last edited by bahnuhr
              Hab das ganze mal schnell mit "httpget" umgesetzt, anbei:
                  var lat = "51.4";
                  var lon = "9.5";
              httpGet('https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18', { timeout: 1000 }, (error, response) => {
                  if (!error) {
                      //console.log(response.statusCode);
                      //console.log(response.data);
                      var result = JSON.parse(response.data);
                      //log (result.display_name);
                      log (result.address.road + " " + result.address.house_number);
                      log (result.address.postcode + " " + result.address.municipality);
                  } else {
                      console.error(error);
                vielen Dank für die schnellen Rückmeldungen.
                @Homoran Ich habe das Script von @David-G verwendet.
                @bahnuhr und @Codierknecht
                natürlich habe ich versucht das ganze mithilfe der Suche und anderen Hilfsmitteln (ChatGPT) selbst zu lösen. Leider ohne Erfolg.
                Mein bisheriges Script:
                var lat, lon, result, hausnummer, strasse, plz, ort, ort2, kreis, bundesland, land, stadt, stadtteil;
                // Beschreibe diese Funktion …
                async function OSM(lat, lon) {
                    let result;
                    const options = {
                       method: 'GET',
                       headers: {
                    await wait(1000);
                    return result;
                schedule("* * * * *", async () => {
                  lat = getState('vw-connect.0.xyz.parkingposition.lat').val;
                  lon = getState('vw-connect.0.xyz.parkingposition.lon').val;
                  result = await OSM(lat, lon);
                  hausnummer = '';
                  strasse = '';
                  plz = '';
                  ort = '';
                  ort2 = '';
                  kreis = '';
                  bundesland = '';
                  land = '';
                  hausnummer = getAttr(result, 'address.house_number');
                  strasse = getAttr(result, 'address.road');
                  plz = getAttr(result, 'address.postcode');
                  stadt = getAttr(result, 'address.town');
                  stadtteil = getAttr(result, 'address.village');
                  kreis = getAttr(result, 'address.county');
                  bundesland = getAttr(result, 'address.state');
                  land = getAttr(result, 'address.country');
                  setState('0_userdata.0.Helfer.Position_Auto' /* Position Auto */, ([strasse ? strasse : null,hausnummer ? [' ',hausnummer,''].join('') : null,strasse ? ', ' : null,plz ? String(plz) + ' ' : null,stadt ? String(stadt) + '' : null,stadtteil ? [' (',stadtteil,')'].join('') : null,kreis ? ', ' + String(kreis) : null,bundesland ? ', ' + String(bundesland) : null,land ? ', ' + String(land) : null,!land ? 'Keine Adressen verfügbar.' : null].join('')), true);
                Über weitere Tipps/Hilfe würde ich mich sehr freuen!
                bahnuhr Codierknecht 2 Replies Last reply Reply Quote 0
                • bahnuhr
                  bahnuhr Forum Testing Most Active @Razer2412 last edited by
                  @razer2412
                  Warum nimmst du nicht das Script was ich 1 Beitrag vor deinem gesendet habe ?
                  Funktioniert einwandfrei.
                  Und benutzt httpget.
                  Komisch.
                  Warum stell ich hier was ein ?
                  • Codierknecht
                    @razer2412
                    Ich hätte da auch noch 'ne Variante.
                    Benötigt allerdings einen (kostenlosen) API-Key:
                    async function getAddress(latitude, longitude) {
                        const url = `https://geocode.maps.co/reverse?lat=${latitude}&lon=${longitude}&api_key=${key}`;
                        httpGet(url, {timeout: 20000}, function(err, response) {
                            if (err) {
                                console.log(err);
                            } else if (response.statusCode == 200) {
                                return response.data.display_name;
                    Im Übrigen finde ich das bisherige Script reichlich spooky.
                    Warum wird da jede Minute die Position bestimmt, wenn das Auto geparkt ist?
                    Die wird sich wohl kaum verändern. Es sei denn, jemand schraubt am Raum-Zeit-Kontinuum.
                    Das Auto wird doch mit ziemlicher Sicherheit den Status (fährt, steht, geparkt, lädt) übermitteln. Dann muss man die Position doch nur bei Statusänderungen ermitteln.
                    @bahnuhr Ist doch viel einfacher, wenn einem jemand das mundgerecht zurechtlegt 😀
                    Ne, im Ernst:
                    @Razer2412 Wir leisten hier "Hilfe zur Selbsthilfe". Da Eine oder Andere muss man sich dann schon noch selbst zurechfummeln. Das übt 😁
                      Micha 3 @bahnuhr last edited by
                      @bahnuhr sagte in Adresse aus GPS Koordinaten ermitteln ?:
        var lat = "51.4";        var lon = "9.5";        httpGet('https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18', { timeout: 1000 }, (error, response) => {        if (!error) {        //console.log(response.statusCode);        //console.log(response.data);        var result = JSON.parse(response.data);        //log (result.display_name);        log (result.address.road + " " + result.address.house_number);        log (result.address.postcode + " " + result.address.municipality);        } else {        console.error(error);        }        });
                      Dankeschön. aber nun kommt wieder was neues. Ich kann es nicht speichern.
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @Micha 3 last edited by
                          <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defcustomreturn" id="?;wMWdJ!vB8:m#;$39f@" x="-537" y="213">
                            <mutation statements="false">
                              <arg name="lat" varid="QN!T6w6a-/l=eT]qb^[m"></arg>
                              <arg name="lon" varid=";AX~{zgT$/kdtN6_QqtB"></arg>
                            </mutation>
                            <field name="NAME">OSM</field>
                            <field name="SCRIPT">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</field>
                          Ich bin echt zu doof. darin kommt das JS und das kann ich nicht speichern.
                            das JS was drin ist falls ich es nicht gepostet habe.
                            let result;
                            const options = {
                                method: 'GET',
                                headers: {
                            await wait(1000);
                            return result;
                            • bahnuhr
                              @micha-3
                              Was machst du da ???
                              Versuchst du ein JS in ein blockly rein zu tun ?
                              Speichere das JS in ein JS; und nicht in ein blockly.
                                ich sag doch, ich kann das nicht. ich hab mir das von oben kopiert und es lief ja auch. nun hab ich die Fehlermeldung und festgestellt, es das JS in der Funktion. aber wie und was das alles macht weiß ich nicht.
                                  @bahnuhr
                                  Danke für dein Skript! Leider habe ich das gleiche Problem welches auch @Micha-3 versucht zu erklären: Das Skript lässt sich im Javaskript Editor nicht speichern und damit auch nicht nutzen.
                                  @Codierknecht vielen Dank auch für deine Hilfe!
                                  Bitte beachte die Abfrage jede Minute nicht - die dient nur zu testzwecken.
                                  Das fertige Skript funktioniert dann wie das ursprüngliche Skript bei jeder Statusänderung. 🙂
                                  Ich habe schon weit über 30 Skripte (Blockly) zur Hausautomatisierung gebastelt, welche teilweise auch wirklich umfangreich sind. Sehr vieles habe ich über try and error herausgefunden.
                                  Auch hier habe ich Stunden selbst versucht ein lauffähiges Skript zu erhalten, bevor ich hier unnötig nachfrage!
                                  Ich möchte mich dafür entschuldigen, wenn meine Eigenleistung nicht den Erwartungen gerecht wird.
                                  • bahnuhr
                                    @razer2412 sagte in Adresse aus GPS Koordinaten ermitteln ?:
                                    Wo seid ihr.
                                    Das Script läuft in JS einwandfrei.
                                    Seit ihr in VIS Editor ???
                                      Razer2412 @bahnuhr last edited by
                                      @bahnuhr
                                      in Blockly:
                                      Das JS läuft in Blockly
                                      • bahnuhr
                                        @razer2412
                                        Wie oft muss ichs das sagen !
                                        Es ist kein blockly !!
                                        Es ist ein stink normales JS.
                                          In der JS-Funktion
                                          • bahnuhr
                                            59
                                            3335
