    4. Adresse aus GPS Koordinaten ermitteln ?
      Micha 3 @bahnuhr last edited by
      @bahnuhr sagte in Adresse aus GPS Koordinaten ermitteln ?:
        var lat = "51.4";        var lon = "9.5";        httpGet('https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18', { timeout: 1000 }, (error, response) => {        if (!error) {        //console.log(response.statusCode);        //console.log(response.data);        var result = JSON.parse(response.data);        //log (result.display_name);        log (result.address.road + " " + result.address.house_number);        log (result.address.postcode + " " + result.address.municipality);        } else {        console.error(error);        }        });
      Dankeschön. aber nun kommt wieder was neues. Ich kann es nicht speichern.
      • bahnuhr
        bahnuhr Forum Testing Most Active @Micha 3 last edited by
        @micha-3 sagte in Adresse aus GPS Koordinaten ermitteln ?:
          Micha 3 last edited by Micha 3
          <block xmlns="https://developers.google.com/blockly/xml" type="procedures_defcustomreturn" id="?;wMWdJ!vB8:m#;$39f@" x="-537" y="213">
            <mutation statements="false">
              <arg name="lat" varid="QN!T6w6a-/l=eT]qb^[m"></arg>
              <arg name="lon" varid=";AX~{zgT$/kdtN6_QqtB"></arg>
            </mutation>
            <field name="NAME">OSM</field>
            <field name="SCRIPT">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</field>
          Ich bin echt zu doof. darin kommt das JS und das kann ich nicht speichern.
            das JS was drin ist falls ich es nicht gepostet habe.
            var request =require('request');
            let result;
            const options = {
                url: 'https://nominatim.openstreetmap.org/reverse.php?format=json&lat=' + lat + '&lon=' + lon + '&zoom=18',
                method: 'GET',
                headers: {
                    'Accept': 'application/json',
                    'Accept-Charset': 'utf-8',
                    'User-Agent': 'iobroker script'
            request(options, function(err,response,body){
                result = JSON.parse(body);
            await wait(1000);
            return result;
            • bahnuhr
              @micha-3
              Was machst du da ???
              Versuchst du ein JS in ein blockly rein zu tun ?
              Speichere das JS in ein JS; und nicht in ein blockly.
                ich sag doch, ich kann das nicht. ich hab mir das von oben kopiert und es lief ja auch. nun hab ich die Fehlermeldung und festgestellt, es das JS in der Funktion. aber wie und was das alles macht weiß ich nicht.
                  Razer2412 last edited by
                  @bahnuhr
                  Danke für dein Skript! Leider habe ich das gleiche Problem welches auch @Micha-3 versucht zu erklären: Das Skript lässt sich im Javaskript Editor nicht speichern und damit auch nicht nutzen.
                  @Codierknecht vielen Dank auch für deine Hilfe!
                  Bitte beachte die Abfrage jede Minute nicht - die dient nur zu testzwecken.
                  Das fertige Skript funktioniert dann wie das ursprüngliche Skript bei jeder Statusänderung. 🙂
                  Ich habe schon weit über 30 Skripte (Blockly) zur Hausautomatisierung gebastelt, welche teilweise auch wirklich umfangreich sind. Sehr vieles habe ich über try and error herausgefunden.
                  Auch hier habe ich Stunden selbst versucht ein lauffähiges Skript zu erhalten, bevor ich hier unnötig nachfrage!
                  Ich möchte mich dafür entschuldigen, wenn meine Eigenleistung nicht den Erwartungen gerecht wird.
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @Razer2412 last edited by
                    @razer2412 sagte in Adresse aus GPS Koordinaten ermitteln ?:
                    Wo seid ihr.
                    Das Script läuft in JS einwandfrei.
                    Seit ihr in VIS Editor ???
                      Razer2412 @bahnuhr last edited by
                      @bahnuhr
                      in Blockly:
                      Das JS läuft in Blockly
                      • bahnuhr
                        @razer2412
                        Wie oft muss ichs das sagen !
                        Es ist kein blockly !!
                        Es ist ein stink normales JS.
                          In der JS-Funktion
                          • bahnuhr
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @bahnuhr last edited by
                              @razer2412
                              • bahnuhr
                                und nochmal !
                                JS, kein Blockly !
                                  kommisch nur es geht und trotz der Fehlermeldung.
                                  nimm den Blockly code und teste selber und dasnn gehst du auf JS-Funktion ... da ist das JS drin.
                                  bahnuhr W 2 Replies Last reply Reply Quote 0
                                  • bahnuhr
                                    welche Fehlermeldung ?
                                    Muss man euch alles aus der Nase ziehen ?
                                      @bahnuhr
                                      Ganz ruhig! Eure Diskussion habe ich nicht vollständig mitbekommen während ich meinen Beitrag verfasst habe.
                                      Initial ist das JS in Blockly eingebettet, wie man im Screenshot erkennen kann.
                                      Ich glaube nicht, dass man hätte erahnen können, dass du nicht dieses eingebettete Skript meinst.
                                      Gerne versuche ich es nun nochmals wie von dir vorgeschlagen. 🙂
                                        wolfi913 @Micha 3 last edited by
                                        @micha-3
                                        Warum nicht gleich alles als Blockly?
                                        z.B. so:
                                          https://forum.iobroker.net/topic/57207/adresse-aus-gps-koordinaten-ermitteln/19
                                          https://forum.iobroker.net/topic/57207/adresse-aus-gps-koordinaten-ermitteln/11
                                          https://forum.iobroker.net/topic/57207/adresse-aus-gps-koordinaten-ermitteln/16
                                            @bahnuhr
                                            Dein Skript funktioniert in JS einwandfrei - Danke dafür!
                                            Wie ich dies nun in das vorhandene Blockly integrieren kann ist aber noch nicht ganz klar.
                                            @wolfi913
                                            Das sieht sehr vielversprechend aus und wird direkt mal getestet.
                                            Bitte habt Verständnis dafür, dass hier auch Leute unterwegs sind, die sich mit JS und httpGET etc. noch nicht so gut auskennen.
                                            Ich (wir) haben lediglich versucht, das initial von David G. zu Verfügung gestellte Skript wieder zum Laufen zu bekommen.
                                            Mir war nicht klar, dass dies von euch vollständig in JS gelöst wurde bzw. dass dies mit Blockly auch ohne das eingebettete JS funktioniert.
                                            59
                                            3329
