    3. Einsteigerfragen
    4. Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter
      AXMLM last edited by
      Irgendwie hat bisher niemand die Importdatei hier gepostet. Anbei meine mit gewissen Selbstzweck als Archiv.
      _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
      1156	Frequency_Grid	Frequency_Grid	Hz	uint16be	1	0,01	0		value		true	false	false	false
      1157	ActivePower_Output_Total	ActivePower_Output_Total	kW	int16be	1	0,01	0		value		true	false	false	false
      1412	Voltage_PV1	Voltage_PV1	V	uint16be	1	0,1	0		value		true	false	false	false
      1413	Current_PV1	Current_PV1	A	uint16be	1	0,01	0		state		true	false	false	false
      1414	Power_PV1	Power_PV1	kW	uint16be	1	0,01	0		state		true	false	false	false
      1415	Voltage_PV2	Voltage_PV2	V	uint16be	1	0,1	0		value		true	false	false	false
      1416	Current_PV2	Current_PV2	A	uint16be	1	0,01	0		state		true	false	false	false
      1417	Power_PV2	Power_PV2	kW	uint16be	1	0,01	0		state		true	false	false	false
      1418	Voltage_PV3	Voltage_PV3	V	uint16be	1	0,1	0		value		true	false	false	false
      1419	Current_PV3	Current_PV3	A	uint16be	1	0,01	0		state		true	false	false	false
      1420	Power_PV3	Power_PV3	kW	uint16be	1	0,01	0		state		true	false	false	false
      1668	PV_Generation_Today	PV_Generation_Today	kWh	uint32be	2	0,01	0		state		true	false	false	false
      1670	PV_Generation_Total	PV_Generation_Total	kWh	uint32be	2	0,1	0		state		true	false	false	false
        worxweis @AXMLM last edited by
        @axmlm
        Da kann ich mich anhängen.
        Anbei meine Register.
        Adresse Name Beschreibung Einheit		Länge	Faktor	Offset	Formel		Raum	Abfrage	WP	CW	SF
        1028    Device Status Gerätestatus Unsigned 16 bit (Big Endian)	1				value
        1029	Fault 1	Fehler 1		Unsigned 16 bit (Big Endian)	1				value
        1030	Fault 2	Fehler 2		Unsigned 16 bit (Big Endian)	1				value
        1031	Fault 3	Fehler 3		Unsigned 16 bit (Big Endian)	1				value
        1032	Fault 4	Fehler 4		Unsigned 16 bit (Big Endian)	1				value
        1033	Fault 5	Fehler 5		Unsigned 16 bit (Big Endian)	1				value
        1047	Countdown	Power-on Countdown	sec.	Unsigned 16 bit (Big Endian)	1				value
        1048	Temperature_Env1	Ambient temperature 1	°C	Signed 16 bit (Big Endian)	1				value
        1049	Temperature_Env2	Ambient temperature 2	°C	Signed 16 bit (Big Endian)	1				value
        1050	Temperatur_HeatSink1	Radiator temperatur 1	°C	Signed 16 bit (Big Endian)	1				value
        1051	Temperatur_HeatSink2	Radiator temperatur 2	°C	Signed 16 bit (Big Endian)	1				value
        1052	Temperatur_HeatSink3	Radiator temperatur 3	°C	Signed 16 bit (Big Endian)	1				value
        1053	Temperatur_HeatSink4	Radiator temperatur 4	°C	Signed 16 bit (Big Endian)	1				value
        1054	Temperatur_HeatSink5	Radiator temperatur 5	°C	Signed 16 bit (Big Endian)	1				value
        1055	Temperatur_HeatSink6	Radiator temperatur 5	°C	Signed 16 bit (Big Endian)	1				value
        1056	Temperature_Inv1	Module temperatur 1	°C	Signed 16 bit (Big Endian)	1				value
        1057	Temperature_Inv2	Module temperatur 2	°C	Signed 16 bit (Big Endian)	1				value
        1058	Temperature_Inv3	Module temperatur 3	°C	Signed 16 bit (Big Endian)	1				value
        1062	ErzeugungszeitHeute	Erzeugungszeit heute	Min	Unsigned 16 bit (Big Endian)	1				value
        1156	Netzfrequenz	Netzfrequenz	Hz	Unsigned 16 bit (Big Endian)	1	0,01			value
        1157	AC-WRWirkleistungTotal	Aktuelle AC Wirkleistung am WR-Ausgang	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1158	ReactivePower_Output_Total	Gesamtblindleistung. Die Wechselrichterseite ist positiv für voreilende und negativ für nacheilende	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1159	ApparentPower_PCC_Total	Gesamte Scheinleistung. Entladung ist positiv, Ladung ist negativ	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1160	AC_EinspeisungBezugWirkleistung	Aktuelle AC-Wirkleistung am SmartMeter	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1161	ReactivePower_PCC_Total	Gesamte PCC-Blindleistung. Die Wechselrichterseite ist positiv für Vorlauf und negativ für Nachlauf	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1162	ApparentPower_PCC_Total	Gesamte PCC-Scheinleistung. Verkaufter Strom ist positiv, gekaufter Strom ist negativ	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1198	AC_Hausverbrauch	Aktueller Hausverbrauch	kW	Unsigned 16 bit (Big Endian)	1	0,01			value
        1199	ActivePower_Load_Sys	System total load power	kW	Unsigned 16 bit (Big Endian)	1	0,01			value
        1284	ActivePower_Load_Total_Offgrid	Load active power. Off grid	kW	Signed 16 bit (Big Endian)	1	01 value
        1285	ReactivePower_Load_Total_Offgrid	Die Lastaufnahme ist positiv und die Rückkopplung ist negativ Off grid	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1286	ApparentPower_Load_Total_Offgrid	Last-Blindleistung Scheinleistung der Last. Die Lastaufnahme ist positiv und die Rückkopplung ist negativ Off grid	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1412	Voltage_PV1	PV_Spannung MPP1	V	Unsigned 16 bit (Big Endian)	1	0,1			value
        1413	Current_PV1	PV_Strom MPP1	A	Unsigned 16 bit (Big Endian)	1	0,01			value
        1414	Power_PV1	PV_Leistung MPP1	kW	Unsigned 16 bit (Big Endian)	1	0,01			value
        1415	Voltage_PV2	PV_Spannung MPP2	V	Unsigned 16 bit (Big Endian)	1	0,1			value
        1416	Current_PV2	PV_Strom MPP2	A	Unsigned 16 bit (Big Endian)	1	0,01			value
        1417	Power_PV2	PV_Leistung MPP2	kW	Unsigned 16 bit (Big Endian)	1	0,01			value
        1476	PV_LeistungTotal	Gesamtleistung	kW	Unsigned 16 bit (Big Endian)	1	0,1			value
        1540	Voltage_Bat1	Batteriespannung	V	Unsigned 16 bit (Big Endian)	1	0,,1			value
        1541	Current_Bat1	Batteriestrom	A	Signed 16 bit (Big Endian)	1	0,01			value
        1542	Power_Bat1	Batterieleistung	kW	Signed 16 bit (Big Endian)	1	0,01			value
        1543	Temperatur_Bat1	Temperatur	°C	Signed 16 bit (Big Endian)	1				value
        1544	battery_soc	Ladezustand	%	Unsigned 16 bit (Big Endian)	1				value
        1545	State of heahlt	Gesundheitszustand Batterie	%	Unsigned 16 bit (Big Endian)	1				value
        1546	BAT_Zyklus	Ladezyklen		Unsigned 16 bit (Big Endian)	1				value
        1668	PVHeute	PV Erzeugung heute	kWh	Unsigned 32 bit (Big Endian)	2	0,01			value
        1670	PVGesamt	PV Erzeugung Gesamt	kWh	Unsigned 32 bit (Big Endian)	2	0,1			value
        1672	VerbrauchHeute	Hausverbrauch heute	kWh	Unsigned 32 bit (Big Endian)	2	0,01			value
        1674	VerbrauchGesamt	Gesamtverbrauch	kWh	Unsigned 32 bit (Big Endian)	2	0,1			value
        1676	BezugHeute	Netzbezug Heute	kWh	Unsigned 32 bit (Big Endian)	2	0,01			value
        1678	BezugGesamt	Netzbezug Gesamt	kWh	Unsigned 32 bit (Big Endian)	2	0,1			value
        1680	EinspeisungHeute	Einspeisung Heute	kWh	Unsigned 32 bit (Big Endian)	2	0,01			value
        1682	EinspeisungGesamt	Einspeisung Gesamt	kWh	Unsigned 32 bit (Big Endian)	2	0,1		value
        1684	BatterieLadungHeute	Batterie Ladung Heute	kWh	Unsigned 32 bit (Big Endian)	2	0,01		value
        1686	BatterieLadungGesamt	Batterie Ladung Gesamt	kWh	Unsigned 32 bit (Big Endian)	2	0,1		value
        1688	BatterieEntladungHeute	Batterie Entladung Heute	kWh	Unsigned 32 bit (Big Endian)	2	0,01	value
        1690	BatterieEntladungGesamt	Batterie Entladung Gesamt	kWh	Unsigned 32 bit (Big Endian)	2  ,1	value
        4173	BatConfig_Depth_of_Discharge	BatConfig_Depth_of_Discharge	%	Unsigned 16 bit (Big Endian)	value
        4174	BatConfig_End_of_Discharge	BatConfig_End_of_Discharge	%	Unsigned 16 bit (Big Endian)	1		value
        4178	BatConfig_EPS_Buffer	BatConfig_EPS_Buffer	%	Unsigned 16 bit (Big Endian)	1				value
        4368	EnergyStorage_Mode_Control	Energie Speicher Mode Kontrolle		Unsigned 16 bit (Big Endian)	1				value
          sail4fun @worxweis last edited by
          Hallo zusammen, ich habe einen Sofar Hyd 4600 EP mit einem LSW und einer DIY Batterie. Des weiteren nutze ich dynamische Strompreise von Tibber. Ich steuere mein ganzes Haus (u.A. Gasheizung, Wärmepumpe, Shellys) über IOBroker. Für den kommenden Winter will ich die automatisierte Batterieladung bei günstigen Strompreisen realisieren. Bislang mache ich das händisch (Keine schöne Lösung aber ne Lösung). Gibt es hier jemand der die Batterieladung in IOBOKER umgesetzt hat. Z.B. über den Modbus Adapter des IObrokers.
          Wenn nicht hat einer hier die Batterie - Steuerung schon mal realisiert?
          Nutzt einer dazu den LSW von Sofar dazu.
          Und wenn ja womit.
          Grüße Chris
          • spicer
            spicer last edited by spicer
            Hallo Gemeinde
            Ich verfolge diesen Thread schon länger.
            Habe erfolgreich einen Waveshare RS485 to LAN Converter an meinen SOFAR HYD20KTL-3PH angeschlossen.
            Wenn ich den modbus Adapter konfiguriere, bekomme ich genau das erste mal beim Starten des Adapters Daten.
            Nachher ist Stille.
            Aufgefallen ist mir, dass "1156-Frequency_Grid" solange funktionierte, wo es an erster Stelle stand und bevor ich weitere IDs rein editierte.
            Log:
            modbus.0
            	2025-08-26 18:45:12.714	info	Disconnected from slave 192.168.88.101
            modbus.0
            	2025-08-26 18:45:12.713	debug	Closing client on purpose.
            modbus.0
            	2025-08-26 18:45:11.665	debug	Cleaning up request fifo.
            modbus.0
            	2025-08-26 18:45:11.665	debug	Clearing timeout of the current request.
            modbus.0
            	2025-08-26 18:45:11.664	debug	Socket closed with error
            modbus.0
            	2025-08-26 18:45:09.642	debug	[DevID_1/holdingRegs] Poll address 1544 - -383 registers
            modbus.0
            	2025-08-26 18:45:09.642	debug	[DevID_1] Poll start ---------------------
            modbus.0
            	2025-08-26 18:45:09.641	info	Connected to slave 192.168.88.101
            Das "Socket closed with error" gefällt mir nicht 😉
            Ich kenne mich mit dem Thema Modbus nicht so gut aus. Ich vermute eine Fehlkonfiguration.
            Oder benutzt ihr gar einen anderen Adapter?
            Hier die JSON des Adapters:
              "_id": "system.adapter.modbus.0",
              "type": "instance",
              "common": {
                "name": "modbus",
                "version": "6.3.2",
                "titleLang": {
                  "en": "ModBus",
                  "de": "ModBus",
                  "ru": "ModBus",
                  "pt": "ModBus",
                  "nl": "ModBus",
                  "fr": "ModBus",
                  "it": "ModBus",
                  "es": "ModBus",
                  "pl": "ModBus",
                  "uk": "ModBus",
                  "zh-cn": "ModBus"
                "desc": {
                  "en": "ModBus connection Slave or Master",
                  "de": "ModBus Verbindung Slave oder Master",
                  "ru": "ModBus соединение Slave или Master",
                  "pt": "Conexão ModBus Escravo ou Mestre",
                  "nl": "ModBus-verbinding Slave of Master",
                  "fr": "Connexion ModBus Esclave ou Maître",
                  "it": "Connessione ModBus Slave o Master",
                  "es": "Conexión ModBus Slave o Master",
                  "pl": "Połączenie ModBus Slave lub Master",
                  "zh-cn": "ModBus连接从站或主站"
                "authors": [
                  "bluefox <dogafox@gmail.com>"
                "licenseInformation": {
                  "license": "MIT",
                  "type": "free"
                "platform": "Javascript/Node.js",
                "mode": "daemon",
                "loglevel": "info",
                "messagebox": true,
                "icon": "modbus.png",
                "keywords": [
                  "ModBus"
                "enabled": true,
                "extIcon": "https://raw.githubusercontent.com/ioBroker/ioBroker.modbus/master/admin/modbus.png",
                "readme": "https://github.com/ioBroker/ioBroker.modbus/blob/master/README.md",
                "type": "protocols",
                "plugins": {
                  "sentry": {
                    "dsn": "https://0c7b6d766435448cbf4908f615efe683@sentry.iobroker.net/84"
                "compact": true,
                "connectionType": "local",
                "dataSource": "poll",
                "tier": 2,
                "eraseOnUpload": true,
                "adminUI": {
                  "config": "materialize"
                "dependencies": [
                    "js-controller": ">=5.0.19"
                "globalDependencies": [
                    "admin": ">=5.1.28"
                "messages": [
                    "condition": {
                      "operand": "and",
                      "rules": [
                        "oldVersion<5.0.0",
                        "newVersion>=5.0.0"
                    "title": {
                      "en": "Objects IDs will change with update!",
                      "de": "Objekt-IDs ändern sich mit dem Update!",
                      "ru": "ID объектов изменятся с обновлением!",
                      "pt": "Os IDs de objetos mudarão com a atualização!",
                      "nl": "Object-ID's veranderen met de update!",
                      "fr": "Les ID d'objets changeront avec la mise à jour !",
                      "it": "Gli ID degli oggetti cambieranno con l'aggiornamento!",
                      "es": "¡Los ID de los objetos cambiarán con la actualización!",
                      "pl": "Identyfikatory obiektów zmienią się wraz z aktualizacją!",
                      "zh-cn": "对象 ID 会随着更新而改变!"
                    "text": {
                      "en": "This update makes sure that all space characters are correctly replaced by underscores on Object-IDs. This means that they will change after this update if you use more then one space in the names of your registers. You need to manually delete the old Object names.",
                      "de": "Dieses Update stellt sicher, dass alle Leerzeichen bei Objekt-IDs korrekt durch Unterstriche ersetzt werden. Das bedeutet, dass sie sich nach diesem Update ändern, wenn mehr als ein Leerzeichen im Namen der Register verwendet wird. Alte Objektnamen müssen manuell gelöscht werden.",
                      "ru": "Это обновление обеспечивает правильную замену всех символов пробела символами подчеркивания в идентификаторах объектов. Это означает, что они изменятся после этого обновления, если вы используете более одного пробела в именах ваших регистров. Вам необходимо вручную удалить старые имена объектов.",
                      "pt": "Essa atualização garante que todos os caracteres de espaço sejam substituídos corretamente por sublinhados em IDs de objeto. Isso significa que eles serão alterados após esta atualização se você usar mais de um espaço nos nomes dos seus registros. Você precisa excluir manualmente os nomes de objetos antigos.",
                      "nl": "Deze update zorgt ervoor dat alle spatietekens correct worden vervangen door onderstrepingstekens op Object-ID's. Dit betekent dat ze na deze update zullen veranderen als u meer dan één spatie gebruikt in de namen van uw registers. U moet de oude objectnamen handmatig verwijderen.",
                      "fr": "Cette mise à jour garantit que tous les espaces sont correctement remplacés par des traits de soulignement sur les ID d'objet. Cela signifie qu'ils changeront après cette mise à jour si vous utilisez plus d'un espace dans les noms de vos registres. Vous devez supprimer manuellement les anciens noms d'objet.",
                      "it": "Questo aggiornamento assicura che tutti i caratteri spazio siano sostituiti correttamente da caratteri di sottolineatura sugli ID oggetto. Ciò significa che cambieranno dopo questo aggiornamento se utilizzi più di uno spazio nei nomi dei tuoi registri. È necessario eliminare manualmente i vecchi nomi degli oggetti.",
                      "es": "Esta actualización garantiza que todos los caracteres de espacio se reemplacen correctamente por guiones bajos en los ID de objetos. Esto significa que cambiarán después de esta actualización si usa más de un espacio en los nombres de sus registros. Debe eliminar manualmente los nombres de objetos antiguos.",
                      "pl": "Ta aktualizacja zapewnia, że wszystkie znaki spacji są poprawnie zastępowane podkreśleniami w identyfikatorach obiektów. Oznacza to, że zmienią się one po tej aktualizacji, jeśli użyjesz więcej niż jednej spacji w nazwach swoich rejestrów. Musisz ręcznie usunąć stare nazwy obiektów.",
                      "zh-cn": "此更新确保所有空格字符都正确替换为对象 ID 上的下划线。这意味着如果您在寄存器名称中使用超过一个空格,它们将在此更新后更改。您需要手动删除旧的对象名称。"
                    "level": "warn",
                    "buttons": [
                      "agree",
                      "cancel"
                "installedFrom": "iobroker.modbus@6.3.2",
                "installedVersion": "6.3.2",
                "host": "ioBroker"
              "native": {
                "params": {
                  "type": "tcp",
                  "bind": "192.168.88.101",
                  "port": "8899",
                  "comName": "",
                  "baudRate": 9600,
                  "dataBits": 8,
                  "stopBits": 1,
                  "parity": "none",
                  "deviceId": 1,
                  "timeout": 5000,
                  "slave": 0,
                  "poll": "5000",
                  "recon": "4000",
                  "keepAliveInterval": 0,
                  "maxBlock": 100,
                  "maxBoolBlock": 128,
                  "multiDeviceId": false,
                  "pulsetime": "2000",
                  "waitTime": "500",
                  "disInputsOffset": 10001,
                  "coilsOffset": 1,
                  "inputRegsOffset": 30001,
                  "holdingRegsOffset": 40001,
                  "showAliases": false,
                  "directAddresses": false,
                  "doNotIncludeAdrInId": false,
                  "preserveDotsInId": false,
                  "round": 2,
                  "doNotRoundAddressToWord": true,
                  "doNotUseWriteMultipleRegisters": false,
                  "onlyUseWriteMultipleRegisters": true,
                  "writeInterval": 0,
                  "readInterval": 0
                "disInputs": [],
                "coils": [],
                "inputRegs": [],
                "holdingRegs": [
                    "address": 1544,
                    "name": "SOC_Bat1",
                    "description": "",
                    "unit": "%",
                    "type": "uint16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1156,
                    "name": "Frequency_Grid",
                    "description": "",
                    "unit": "Hz",
                    "type": "uint16be",
                    "len": 1,
                    "factor": "0.01",
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1157,
                    "name": "ActivePower_Output_Total",
                    "description": "",
                    "unit": "kW",
                    "type": "int16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1160,
                    "name": "ActivePower_PCC_Total",
                    "description": "",
                    "unit": "kW",
                    "type": "int16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1198,
                    "name": "ActivePower_PV_Ext",
                    "description": "",
                    "unit": "kW",
                    "type": "int16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1199,
                    "name": "ActivePower_Load_Sys",
                    "description": "",
                    "unit": "kW",
                    "type": "int16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1284,
                    "name": "ActivePower_Load_Total",
                    "description": "",
                    "unit": "kW",
                    "type": "int16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
                    "address": 1542,
                    "name": "Power_Bat1",
                    "description": "",
                    "unit": "kW",
                    "type": "int16be",
                    "len": 1,
                    "factor": 1,
                    "offset": 0,
                    "formula": "",
                    "role": "value",
                    "room": "",
                    "poll": true,
                    "wp": "",
                    "cw": "",
                    "isScale": "",
                    "deviceId": 1,
                    "_address": 0
              "protectedNative": [],
              "encryptedNative": [],
              "notifications": [],
              "instanceObjects": [
                  "_id": "",
                  "type": "meta",
                  "common": {
                    "type": "meta"
                  "native": {}
                  "_id": "info",
                  "type": "channel",
                  "common": {
                    "name": "Information"
                  "native": {}
                  "_id": "info.connection",
                  "type": "state",
                  "common": {
                    "role": "indicator.connected",
                    "name": "If master connected",
                    "type": "boolean",
                    "read": true,
                    "write": false,
                    "def": false
                  "native": {}
              "objects": [],
              "user": "system.user.admin",
              "ts": 1756223306613
            Habt ihr einen Rat für mich?
              sail4fun @Maddin77 last edited by
              @maddin77
              Hallo
              Ich habe mir jetzt den https://www.amazon.de/Waveshare-RS48…&tag=pvforum-21 gekauft. Ich bin seit 2 Tagen vergeblich dabei die Verbindung hinzubekommen.
              Ich habe einen Sofar Solar 4600 Hyd EP . Ich kann den Waveshare bereits per Wlan erreichen. Ich bekomme aber keine Verbindung/keine Daten in den Modbus Adapter des IO brokers . Was muss ich am Waveshare einstellen . Ich benutzte das originale Waveshare Config und die Weboberfläche des Waveshare. Und wenn das erledigt ist was kommt dann in den IOBROKER ??
              Wäre schön wenn du mir da helfen könntest.
              LG Chris
              spicer M 3 Replies Last reply Reply Quote 0
              • spicer
                spicer @sail4fun last edited by spicer
                @sail4fun
                Ich stehe da leider auch am Anfang.
                Im ioBroker musst Du jedenfalls den Adapter "modbus" verwenden.
                Bei mir war es so, dass Sofar beim vorkonfektionierten Datenkabel die Adern 1 und 3 nicht verdrahtet hat im Stecker.
                  Maddin77 @sail4fun last edited by Maddin77
                  @sail4fun sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                  @maddin77
                  Hallo
                  LG Chris
                  @spicer sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                  @sail4fun
                  ich poste euch heute Abend mal meine Einstellungen vom Waveshare und vom IOB Modbus
                  evtl hilft euch das.
                  Bei mir läuft das im 15Sek Takt ohne Fehler oder Probleme seit langer Zeit
                    Maddin77 @spicer last edited by
                    da ist doch gar kein Kabel in dem Stecker?
                    hier musst du doch eh alles selber anschließen, sei es SM oder Batterie oder RS485
                    spicer 1 Reply Last reply Reply Quote 0
                    • spicer
                      spicer @Maddin77 last edited by
                      @maddin77
                      Bei mir schon, weil ich auch eine Notstromverteilung habe.
                        @maddin77
                        Wir reden schon vom gleichen (hoffentlich)
                        denn Notstrom habe ich auch, des wegen kommt der Stecker auch ohne Kabel, das muss man alles selber anschließen
                        spicer S 2 Replies Last reply Reply Quote 0
                        • spicer
                          @maddin77
                          Jawohl genau den.
                          Da ich auch Notstrom habe, wurde ein 3 zeiliger AP Verteiler inkl vorkonfektioniertes COM Kabel mitgeliefert.
                          In diesem COM Stecker waren nur ein paar Adern aufgeschaltet.
                          Sollte nur ein Hinweis sein. Ich selber habe lange gesucht, bevor ich diesen Stecker auseinander nahm 😉
                            LG Chris
                            @sail4fun
                            hallo ihr zwei
                            Anbei meine ganzen Einstellungen
                            IOBroker
                            Waveshare
                            • spicer
                              @maddin77
                              Als Provisorium, bis Deine Datenübertragung läuft, hätte ich hier
                              https://github.com/ltspicer/ioBroker.sofarcloud
                              einen Adapter geschrieben, welcher über die SOFARcloud läuft.
                                @maddin77
                                Meine Daten laufen....
                                • spicer
                                  spicer @Maddin77 last edited by spicer
                                  @maddin77
                                  Freut mich.
                                  Oder meintest Du, dass Du die Daten ohne meinen Adapter bereits lesen konntest?
                                    @maddin77
                                    Hallo ich habe mir jetzt am Wochenende deine Beschreibung verinnerlicht. Mein Config Programm von Waveshare sieht anders als deines aus., Ich habe den hier https://www.waveshare.com/wiki/RS485_TO_WIFI/ETH und versuche bisher erfolglos eine Wifiverbindung aufzubauen. Weißt du ob das mit dem auch geht? Liebe Grüße Chris
                                      @maddin77
                                      Freut mich.
                                      ja direkt über Modbus und dem Waveshare in den IO
                                        @maddin77
                                        Sorry, da kann ich dir nicht helfen
                                          Herzlichen Dank an alle Mithelfenden. Endlich bekomme ich den Datenzugriff👍
                                          M spicer 2 Replies Last reply Reply Quote 1
                                            kannst deine Lösung hier Schreiben? Was zum Erfolg geführt hat.
                                            Falls nochmal jemand ähnliche Probleme hätte.
                                            81.1k
                                            144
                                            20546
