    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
      Beowolf @BertDerKleine last edited by Beowolf
      @bertderkleine
      I've fixed the problem by first installing chromium (Debian 12 / ARM64 in my case):
      sudo apt install chromium
      {1}
      Change the adapter's main.js onReady() function to load the correct binary (chromium in my case):
      async onReady() {
          this.browser = await import_puppeteer.default.launch({ headless: "new", defaultViewport: null, executablePath: '/usr/bin/chromium', args: ['--no-sandbox', '--disable-setuid-sandbox'] });
          this.subscribeStates("url");
          this.log.info("Ready to take screenshots");
      Now everything works as expected.
      Das ist schon lange überholt. Mit einem aktuellen System wird einfach Chromium installiert
      sudo apt install chromium-browser -y
      Mache danach event. noch das hier
      sudo apt update && sudo apt full-upgrade
      Mache einen reboot und danach im ioBroker der Puppeteer Adapter. Fertig.
      BertDerKleine 1 Reply Last reply Reply Quote 0
      • BertDerKleine
        BertDerKleine @Beowolf last edited by
        @beowolf sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
        @bertderkleine
        {1}
        async onReady() {
        Habe ich alles gemacht, es führt leider nicht zum Ziel, weiter Fehler:
        $ iobroker add puppeteer auto --host iobrokerpi4b --debug
        NPM version: 10.8.2
        Installing iobroker.puppeteer@0.4.0... (System call)
        > puppeteer@23.11.1 postinstall> node install.mjs
        **INFO** Skipping Firefox download as instructed.
        Error: ERROR: Failed to set up chrome v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 0) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}
        npm error code 1
        npm error path /opt/iobroker/node_modules/puppeteernpm error command failednpm error command sh -c node install.mjs
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-14T06_42_00_915Z-debug-0.log
        Error: ERROR: Failed to set up chrome v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 0) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}npm error code 1npm error path /opt/iobroker/node_modules/puppeteernpm error command failednpm error command sh -c node install.mjsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-14T06_42_00_915Z-debug-0.log
        host.iobrokerpi4b Cannot install iobroker.puppeteer@0.4.0: 1
        ERROR: Process exited with code 25
          @bertderkleine
          Ich habe mal gerade auf meinem Test-Raspberry das aktuelle PI-Image aufgespielt. Danach iobroker, dann Chromium und natürlich den Adapter Puppeteer in ioBroker installiert. Alles lief ohne Problem durch.
          Keine Ahnung was du wo auf deinem System schon gemacht hast, aber ich glaube, das der Fehler ganz woanders liegt.
          Mach doch mal ein Backup, nimm zum Testen eine neue SD-Karte, installiere das aktuelle Image, usw.
          Du wirst sehen, das das alles so durchläuft.
          Möchtest du das nicht, wäre es glaube ich besser, wenn du einen eigenen Beitrag öffnest. Das führt hier wohl etwas zu weit.
          BertDerKleine 1 Reply Last reply Reply Quote 1
          • BertDerKleine
            BertDerKleine @Beowolf last edited by BertDerKleine
            @beowolf
            Danke Dir. Problem ist mittlerweile auch gelöst.
            Ich hatte schon einen eigenen Thread aufgemacht: https://forum.iobroker.net/topic/81640/gelöst-puppeteer-adapter-läuft-auf-raspi-4-nicht
              @bertderkleine
              Trage doch noch den Link zu deinem neuen Beitrag ein. So kann jeder der event. auch damit ein Problem hat es einfacher finden.
              • BertDerKleine
                @beowolf
                erledigt.
                • BertDerKleine
                  eben mal das Blockly aus Beitrag #274 (https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie/274) versucht laufen zu lassen.
                  Das führt aber nur zu Fehler:
                  javascript.0	19:04:21.885	warn	request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                  javascript.0	19:04:21.918	error	    at Object.<anonymous> (script.js.08_E-Ink_Displays.Bild_an_OpenEpaperLink_Tags_senden:41:13)
                  Hat jemand ein Blockly, das heute noch läuft?
                  Mit JS habe ich mir auch was hingefrickelt, aber ein Blockly, das Stand heute noch läuft wäre super.
                  Eisbaeeer 1 Reply Last reply Reply Quote 0
                  • Eisbaeeer
                    Eisbaeeer Developer @BertDerKleine last edited by Eisbaeeer
                    @bertderkleine
                    Ich habe das ganze von Blockly auf Script konvertiert. Damit funktioniert auch puppeteer und upload wieder.
                    Link: https://forum.iobroker.net/post/1265803
                    Oder wieder zurück nach Blockly basteln.
                    Und jetzt auch besser auffindbar hier: E-INK Display OpenEPaperLink - Blockly, Java-Skripte usw.
                    • BertDerKleine
                      So, jetzt habe ich einen Spaghetti AP zusammengebastelt und eine handvoll Displays und konnte aus den theoretischen mal praktische Übungen machen.
                      Dabei stiess ich auf einen bösen Stolperstein bei der Hardware:
                      Es gibt nämlich beim ESP32-S3 Teile, die auf den ersten Block genau passend ausschauen von den Specs, es aber dann doch nicht sind, Beispiel: https://de.aliexpress.com/item/1005009621440783.html
                      Wenn man es weiss, erkennt man die nicht passende Hardware daran, dass es keinen GPIO Pin #20 gibt (und die Pins alle anders sortiert sind).
                      Frage jetzt zur Ansteuerung des Displays:
                      Die Firmware bietet ja eine "copy" Funktion. Irgendwie bekomme ich die aber nicht zum Fliegen.
                      a) gibts dazu irgendwelche Doku Links?
                      b) konkret gefragt: in welchem Format gibt man hier die MAC-Adresse ein? Also eher "00112233..." oder "00:11:22:33..."?
                      Der-Jeti 1 Reply Last reply Reply Quote 0
                      • Der-Jeti
                        Der-Jeti @BertDerKleine last edited by
                        wo bekommt man aktuell noch geflashte Displays?
                        Bräuchte 1/2 Stück zum testen.
                        • Eisbaeeer
                          Eisbaeeer Developer @Der-Jeti last edited by
                          @der-jeti Ich habe noch welche auf Lager. VG Lars
                          a200 1 Reply Last reply Reply Quote 0
                          • a200
                            a200 @Eisbaeeer last edited by
                            @eisbaeeer Moin, ich hätte auch Interesse. Was und wie viel würde mich interessieren. 😀
                            • Eisbaeeer
                              Eisbaeeer Developer @a200 last edited by
                              @a200 Ich hab dir eine PM geschickt.
                              • haselchen
                                haselchen Most Active @Eisbaeeer last edited by haselchen
                                @Eisbaeeer
                                @bimmi
                                @Beowolf
                                Schwupps , aus dem Nichts , hat der Tag den GoogleKalender nicht mehr aktualisiert.
                                function getEventsForNextDay(days) {
                                  var start = new Date();
                                  var end = new Date();
                                  var time_offset = 0;
                                  end.setDate(end.getDate() + 8);
                                  var calendars = CalendarApp.getAllCalendars();
                                  var events = [];
                                  for (var i = 0; i < calendars.length; i++) {
                                    var calendar = calendars[i];
                                    var eventsInCalendar = calendar.getEvents(start, end);
                                    for (var j = 0; j < eventsInCalendar.length; j++) {
                                      var event = eventsInCalendar[j];
                                      events.push({
                                        title: event.getTitle(),
                                        start: Math.floor((event.getStartTime().getTime() / 1000)+(time_offset*3600)),
                                        end: Math.floor((event.getEndTime().getTime() / 1000)+(time_offset*3600)),
                                        description: event.getDescription()
                                  // Sort events by start date/time
                                  events.sort(function(a, b) {
                                    return a.start - b.start;
                                  return JSON.stringify(events);
                                function doGet() {
                                  var content = getEventsForNextDay();
                                  var output = ContentService.createTextOutput(content);
                                  output.setMimeType(ContentService.MimeType.JSON);
                                  return output;
                                Seit dem 05.10. hat der Tag den Kalender nicht aktualisiert.
                                02:45:37 InvalidInput
                                02:45:27 get calendar
                                Das kommt nun im Log.
                                Hab auch alle Punkte und Anleitungen nochmal durch.
                                Tag bleibt leer, Log haut invalidinput raus.
                                Die anderen Tags laufen einwandfrei.
                                Batterien sind alle neu.
                                • Eisbaeeer
                                  Eisbaeeer Developer @haselchen last edited by
                                  @haselchen Hi. Hast du iobroker upgedated? Sowas kenne ich eigentlich nur, wenn man node oder Module updated. Müsste man debuggen, was da schief läuft. Stell mal auf Debug Modus und poste die Ausgabe.
                                  VG Lars
                                  • haselchen
                                    @eisbaeeer
                                    Moin moin,
                                    Iobroker ist völlig außen vor.
                                    Google Apps Script , wie auf Github beschrieben.
                                    Hier im Thread gab es dazu ein angepasstes Skript, weil das Ursprüngliche ab 2.07b (AP Firmware) nicht mehr funktionierte.
                                    Da wäre es interessant von den Usern, die dieses Kalender Script nutzen ,zu erfahren , ob es bei ihnen noch läuft und wenn ja , wie .
                                    • Eisbaeeer
                                      @haselchen sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                                      @eisbaeeer
                                      Dann bin ich raus. Sorry. Ich nutze nur iobroker für die Anzeige.
                                      • haselchen
                                        @eisbaeeer
                                        @bimmi
                                        @Beowolf
                                        Erledigt.
                                        Der Dev auf Github hat in 5min das Problem gelöst.
                                        https://github.com/OpenEPaperLink/OpenEPaperLink/issues/512
                                        haselchen created this issue in OpenEPaperLink/OpenEPaperLink
                                        closed The Template Google Calendar has stopped working #512
                                          Kai 2 last edited by
                                          wo habt ihr denn die ESL Tags her? Auf ebay & Co finde ich keinen von den auf OEPL gelisteten Tags. Gibt es Alternativen?
                                          Danke!!
                                          Kai
                                          • Eisbaeeer
                                            Eisbaeeer Developer @Kai 2 last edited by
                                            @kai-2 Such mal nach Openepaper und kiduild.
                                            1028
                                            342053
