    4. Adapter lassen sich nicht updaten
    • haus-automatisierung
      haus-automatisierung Developer Most Active @Feinfinger last edited by
      @feinfinger sagte in Adapter lassen sich nicht updaten:
      Process exited with code 25
      Einmal den ioBroker Fixer laufen lassen und nochmal das Update anstoßen
        Feinfinger @haus-automatisierung last edited by
        Danke für die Antwort, leider bleibt der Fehler.
          Thomas Braun Most Active @Feinfinger last edited by
          @feinfinger
          Dann schau dir das ganze Konstrukt an. Per
          iob diag
          am besten.
            Feinfinger @Thomas Braun last edited by
            Guten Morgen,
            Hier die Ausgabe von iob diag.
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Operating System: Ubuntu 24.04.3 LTS
             Static hostname: ioBroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
                      Kernel: Linux 6.14.11-1-pve
                Architecture: x86-64
            OS is similar to: debian
            model name      : 13th Gen Intel(R) Core(TM) i5-1340P
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             06:45:07 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Ubuntu LTS release codenamed 'noble'!
            *** TIME AND TIMEZONES ***
                           Local time: Fri 2025-09-19 06:45:07 CEST
                       Universal time: Fri 2025-09-19 04:45:07 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            smarthome
            HOME=/home/smarthome
            GROUPS=smarthome sudo iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Mem:            8.6G         47M        6.1G        139K        2.4G        8.5G
            Swap:             0B          0B          0B
            Total:          8.6G         47M        6.1G
            Active iob-Instances:   1
                     8192 M total memory
                       45 M used memory
                      156 M active memory
                     1938 M inactive memory
                     5833 M free memory
                        0 M buffer memory
                     2313 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 06:45:08 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
            Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8192.0 total,   5832.3 free,     46.7 used,   2313.1 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8145.3 avail Mem
            *** FAILED SERVICES ***
              UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
            * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
            * iobroker.service        loaded failed failed ioBroker Server
            Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                    ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                    SUB    -> The low-level unit activation state, values depend on unit type.
            3 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            dmesg: read kernel buffer failed: Operation not permitted
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--114--disk--0 ext4       16G   12G  3.2G  79% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            efivarfs                         efivarfs  192K  113K   75K  60% /sys/firmware/efi/efivars
            tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
            tmpfs                            tmpfs     6.2G  132K  6.2G   1% /run
            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
            Show mounted filesystems:
            TARGET SOURCE                           FSTYPE OPTIONS
            /      /dev/mapper/pve-vm--114--disk--0 ext4   rw,relatime,stripe=16
            /var:
            3.2G    /var/
            1.6G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
            1.6G    /var/log
            1.3G    /var/cache/apt
            Archived and active journals take up 90.2M in the file system.
            /opt/iobroker/backups:
            353M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            699M    /opt/iobroker/iobroker-data/
            386M    /opt/iobroker/iobroker-data/files
            236M    /opt/iobroker/iobroker-data/backup-objects
            48M     /opt/iobroker/iobroker-data/files/iot.admin
            47M     /opt/iobroker/iobroker-data/files/vis-2
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
            28M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
            22M     /opt/iobroker/iobroker-data/objects.json.migrated
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v22.19.0
            /usr/bin/node           v22.19.0
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            /usr/bin/corepack       0.34.0
            nodejs:
              Installed: 22.19.0-1nodesource1
              Candidate: 22.19.0-1nodesource1
              Version table:
             *** 22.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 22.18.0-1nodesource1 1001
                 22.17.1-1nodesource1 1001
                 22.17.0-1nodesource1 1001
                 22.16.0-1nodesource1 1001
                 22.15.1-1nodesource1 1001
                 22.15.0-1nodesource1 1001
                 22.14.0-1nodesource1 1001
                 22.13.1-1nodesource1 1001
                 22.13.0-1nodesource1 1001
                 22.12.0-1nodesource1 1001
                 22.11.0-1nodesource1 1001
                 22.10.0-1nodesource1 1001
                 22.9.0-1nodesource1 1001
                 22.8.0-1nodesource1 1001
                 22.7.0-1nodesource1 1001
                 22.6.0-1nodesource1 1001
                 22.5.1-1nodesource1 1001
                 22.5.0-1nodesource1 1001
                 22.4.1-1nodesource1 1001
                 22.4.0-1nodesource1 1001
                 22.3.0-1nodesource1 1001
                 22.2.0-1nodesource1 1001
                 22.1.0-1nodesource1 1001
                 22.0.0-1nodesource1 1001
                 18.19.1+dfsg-6ubuntu5 500
                    500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
            No problems detected
            Errors in npm tree: 0
            Checking for nodejs vulnerability:
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 481)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.7.2
            javascript:     8.9.2
            nodejs modules from github:     2
            |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
            | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
            Adapter State
              system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
              system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
              system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
              system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
              system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
              system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
              system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
              system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
              system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
              system.adapter.homekit-controller.0     : homekit-controller    : ioBroker                                 - disabled
              system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
              system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
              system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
              system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
              system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
              system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
              system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
              system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
              system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
              system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
              system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 192.168.178.61
              system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
              system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
              system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
              system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
              system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
              system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.7.2    , installed 7.7.2
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
            Adapter    "fhem"         : 3.0.0    , installed 3.0.0
            Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
            Adapter    "govee-local"  : 0.2.9    , installed 0.2.8  [Updatable]
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homekit-controller": 0.5.11, installed 0.5.11
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
            Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "notification-manager": 1.3.0, installed 1.3.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "radar2"       : 2.4.0    , installed 2.4.0
            Adapter    "shelly"       : 10.1.0   , installed 10.1.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "tado"         : 0.7.10   , installed 0.7.10
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
            Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "web"          : 7.0.8    , installed 7.0.9
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yahka"        : 1.1.5    , installed 1.1.5
            Objects and States
            Objects:        14243
            States:         11994
            Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
            Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      102        133591972  231/systemd-resolve
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          133592326  441/master
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        133591970  231/systemd-resolve
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          133581801  1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          133587946  1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          133581803  1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          133587947  1/init
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          133592327  441/master
            udp        0      0 127.0.0.54:53           0.0.0.0:*                           102        133591971  231/systemd-resolve
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        133591969  231/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          133581802  1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        133594148  237/avahi-daemon: r
            udp        0      0 0.0.0.0:46786           0.0.0.0:*                           108        133594150  237/avahi-daemon: r
            udp6       0      0 :::47825                :::*                                108        133594151  237/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          133581804  1/init
            udp6       0      0 :::5353                 :::*                                108        133594149  237/avahi-daemon: r
            2025-09-19 06:44:03.909  - info: discovery.0 (18819) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.910  - info: ems-esp.0 (18695) terminating
            2025-09-19 06:44:03.909  - info: notification-manager.0 (18757) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.910  - info: trashschedule.0 (18896) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.908  - info: govee-local.0 (18789) terminating
            2025-09-19 06:44:03.909  - info: govee-local.0 (18789) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.911  - info: ems-esp.0 (18695) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.909  - info: vis-2.0 (18881) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:04.325  - info: backitup.0 (18539) terminating
            2025-09-19 06:44:04.326  - info: pushover.0 (18506) terminating
            2025-09-19 06:44:04.327  - info: pushover.0 (18506) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:04.327  - info: synology.0 (18712) terminating
            2025-09-19 06:44:04.328  - info: modbus.0 (18680) terminating
            2025-09-19 06:44:04.328  - info: yahka.0 (18635) terminating
            2025-09-19 06:44:04.328  - info: modbus.1 (18727) terminating
            2025-09-19 06:44:04.329  - info: govee-local.0 (18789) terminating
            2025-09-19 06:44:04.329  - info: notification-manager.0 (18757) terminating
            2025-09-19 06:44:04.330  - info: vis-2.0 (18881) terminating
            2025-09-19 06:44:04.330  - info: discovery.0 (18819) terminating
            2025-09-19 06:44:04.331  - info: trashschedule.0 (18896) terminating
            2025-09-19 06:44:04.332  - info: radar2.0 (18599) terminating
            2025-09-19 06:44:04.338  - info: iot.0 (18834) terminating
            2025-09-19 06:44:04.338  - info: tado.0 (18944) terminating
            2025-09-19 06:44:04.935  - warn: host.ioBroker instance system.adapter.pushover.0 terminated due to SIGKILL
            2025-09-19 06:44:04.953  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
            iob diag has finished.
            Wenn ich dann versuche, einen Adapter upzudaten, kommt dieses raus bei iob diag.
            Script v.2025-08-09
            *** BASE SYSTEM ***
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
            CPU threads: 4
                           Local time: Fri 2025-09-19 06:51:59 CEST
                       Universal time: Fri 2025-09-19 04:51:59 UTC
                             RTC time: n/a
                      RTC in local TZ: no
            smarthome
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Mem:            8.6G        2.3G        4.3G        143K        2.1G        6.3G
            Swap:             0B          0B          0B
            Total:          8.6G        2.3G        4.3G
            Active iob-Instances:   29
                     8192 M total memory
                     2146 M used memory
                     2214 M active memory
                     1557 M inactive memory
                     4090 M free memory
                        0 M buffer memory
                     1955 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
            Tasks:  59 total,   1 running,  58 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  2.5 si,  0.0 st
            MiB Mem :   8192.0 total,   4089.5 free,   2147.1 used,   1955.5 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6044.9 avail Mem
            2 loaded units listed.
            *** FILESYSTEM ***
            tmpfs                            tmpfs     6.2G  136K  6.2G   1% /run
            /var:
            3.2G    /var/
            1.6G    /var/log
            1.3G    /var/cache/apt
            703M    /opt/iobroker/iobroker-data/
            31M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 286)
            admin:          7.7.2
            javascript:     8.9.2
            Adapter State
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
            + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
            + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
            + system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            + system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
            + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
            + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
            + system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
            + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
            + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
            + system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
            + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
            + instance is alive
            Objects and States
            Objects:        14243
            States:         12281
            Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
            Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       142103452  22357/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       142127229  22357/iobroker.js-c
            tcp        0      0 192.168.178.61:42010    0.0.0.0:*               LISTEN      1000       142127710  22615/io.hm-rpc.0
            tcp        0      0 192.168.178.61:42001    0.0.0.0:*               LISTEN      1000       142129503  22695/io.hm-rpc.1
            tcp        0      0 0.0.0.0:37287           0.0.0.0:*               LISTEN      1000       142127662  22585/io.yahka.0
            tcp        0      0 127.0.0.1:36251         0.0.0.0:*               LISTEN      1000       142132584  22585/io.yahka.0
            tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       142134977  22819/io.web.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       142129315  22600/io.shelly.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       142123634  22376/io.admin.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      1000       142129231  22519/io.fullybrows
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       142127596  22549/io.radar2.0
            udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1000       142128073  22742/io.govee-loca
            2025-09-19 06:51:43.283  - error: host.ioBroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:23128) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T04_49_25_414Z-debug-0.loghost.ioBroker Cannot install iobroker.govee-local@0.2.9: 7
              @feinfinger
              cd /opt/iobroker && npm ls noble
                @thomas-braun sagte in Adapter lassen sich nicht updaten:
                smarthome@ioBroker:~$ cd /opt/iobroker && npm ls noble
                [sudo] password for smarthome:
                iobroker.inst@2.0.3 /opt/iobroker
                `-- (empty)
                smarthome@ioBroker:/opt/iobroker$
                  @feinfinger
                  Sorry, mein Fehler:
                  cd /opt/iobroker && npm ls @stoprocent/noble
                    Was heißt hier sorry, ich bin so froh das es dich hier im Forum gibt 😃
                    smarthome@ioBroker:/opt/iobroker$ cd /opt/iobroker && npm ls @stoprocent/noble
                    +-- iobroker.homekit-controller@0.5.11
                    | `-- hap-controller@0.10.2
                    |   `-- @stoprocent/noble@1.19.1 deduped
                    `-- iobroker.radar2@2.4.0
                      homekit-controller
                      radar2
                      installier die beiden Adapter mal neu.
                        Radar2 lies sich ohne Probleme installieren, wenn ich den homekit-controller installieren möchte kommt dieser Fehler:
                        ERROR: Process exited with code 25
                        Weniger Protokolle
                        Detailliert
                        $ iobroker add homekit-controller --host ioBroker
                        Installing iobroker.homekit-controller@0.5.11... (System call)
                        npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:26743) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T06_33_43_583Z-debug-0.log
                        host.ioBroker Cannot install iobroker.homekit-controller@0.5.11: 7
                          Dafür lassen sich jetzt die anderen Adapter updaten.
                            @feinfinger
                            Dann mach mal ein Issue drüben bei github für den homekit-controller auf.
                              Ok, hab ich gemacht.
                              Danke dir erstmal für deine Hilfe!
                              440
