    4. Adapter lassen sich nicht updaten
      Thomas Braun Most Active @Feinfinger last edited by
      @feinfinger
      Dann schau dir das ganze Konstrukt an. Per
      iob diag
      am besten.
        Feinfinger @Thomas Braun last edited by
        Guten Morgen,
        Hier die Ausgabe von iob diag.
        ========== Start marking the full check here ===========
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Ubuntu 24.04.3 LTS
         Static hostname: ioBroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.14.11-1-pve
            Architecture: x86-64
        OS is similar to: debian
        model name      : 13th Gen Intel(R) Core(TM) i5-1340P
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         06:45:07 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Ubuntu LTS release codenamed 'noble'!
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2025-09-19 06:45:07 CEST
                   Universal time: Fri 2025-09-19 04:45:07 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        smarthome
        HOME=/home/smarthome
        GROUPS=smarthome sudo iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Mem:            8.6G         47M        6.1G        139K        2.4G        8.5G
        Swap:             0B          0B          0B
        Total:          8.6G         47M        6.1G
        Active iob-Instances:   1
                 8192 M total memory
                   45 M used memory
                  156 M active memory
                 1938 M inactive memory
                 5833 M free memory
                    0 M buffer memory
                 2313 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 06:45:08 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
        Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8192.0 total,   5832.3 free,     46.7 used,   2313.1 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8145.3 avail Mem
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        * iobroker.service        loaded failed failed ioBroker Server
        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                SUB    -> The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--114--disk--0 ext4       16G   12G  3.2G  79% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        efivarfs                         efivarfs  192K  113K   75K  60% /sys/firmware/efi/efivars
        tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                            tmpfs     6.2G  132K  6.2G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--114--disk--0 ext4   rw,relatime,stripe=16
        /var:
        3.2G    /var/
        1.6G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
        1.6G    /var/log
        1.3G    /var/cache/apt
        Archived and active journals take up 90.2M in the file system.
        /opt/iobroker/backups:
        353M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        699M    /opt/iobroker/iobroker-data/
        386M    /opt/iobroker/iobroker-data/files
        236M    /opt/iobroker/iobroker-data/backup-objects
        48M     /opt/iobroker/iobroker-data/files/iot.admin
        47M     /opt/iobroker/iobroker-data/files/vis-2
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
        28M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
        22M     /opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.19.0
        /usr/bin/node           v22.19.0
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.19.0-1nodesource1
          Candidate: 22.19.0-1nodesource1
          Version table:
         *** 22.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.19.1+dfsg-6ubuntu5 500
                500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 481)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.2
        javascript:     8.9.2
        nodejs modules from github:     2
        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
        | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
        Adapter State
          system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
          system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
          system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
          system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
          system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.homekit-controller.0     : homekit-controller    : ioBroker                                 - disabled
          system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
          system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
          system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
          system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
          system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
          system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
          system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
          system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 192.168.178.61
          system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
          system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
          system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
          system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.7.2    , installed 7.7.2
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
        Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
        Adapter    "fhem"         : 3.0.0    , installed 3.0.0
        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
        Adapter    "govee-local"  : 0.2.9    , installed 0.2.8  [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "tado"         : 0.7.10   , installed 0.7.10
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "web"          : 7.0.8    , installed 7.0.9
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.1.5    , installed 1.1.5
        Objects and States
        Objects:        14243
        States:         11994
        Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
        Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      102        133591972  231/systemd-resolve
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          133592326  441/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        133591970  231/systemd-resolve
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          133581801  1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          133587946  1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          133581803  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          133587947  1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          133592327  441/master
        udp        0      0 127.0.0.54:53           0.0.0.0:*                           102        133591971  231/systemd-resolve
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        133591969  231/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          133581802  1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        133594148  237/avahi-daemon: r
        udp        0      0 0.0.0.0:46786           0.0.0.0:*                           108        133594150  237/avahi-daemon: r
        udp6       0      0 :::47825                :::*                                108        133594151  237/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          133581804  1/init
        udp6       0      0 :::5353                 :::*                                108        133594149  237/avahi-daemon: r
        2025-09-19 06:44:03.909  - info: discovery.0 (18819) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:03.910  - info: ems-esp.0 (18695) terminating
        2025-09-19 06:44:03.909  - info: notification-manager.0 (18757) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:03.910  - info: trashschedule.0 (18896) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:03.908  - info: govee-local.0 (18789) terminating
        2025-09-19 06:44:03.909  - info: govee-local.0 (18789) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:03.911  - info: ems-esp.0 (18695) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:03.909  - info: vis-2.0 (18881) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:04.325  - info: backitup.0 (18539) terminating
        2025-09-19 06:44:04.326  - info: pushover.0 (18506) terminating
        2025-09-19 06:44:04.327  - info: pushover.0 (18506) Terminated (NO_ERROR): Without reason
        2025-09-19 06:44:04.327  - info: synology.0 (18712) terminating
        2025-09-19 06:44:04.328  - info: modbus.0 (18680) terminating
        2025-09-19 06:44:04.328  - info: yahka.0 (18635) terminating
        2025-09-19 06:44:04.328  - info: modbus.1 (18727) terminating
        2025-09-19 06:44:04.329  - info: govee-local.0 (18789) terminating
        2025-09-19 06:44:04.329  - info: notification-manager.0 (18757) terminating
        2025-09-19 06:44:04.330  - info: vis-2.0 (18881) terminating
        2025-09-19 06:44:04.330  - info: discovery.0 (18819) terminating
        2025-09-19 06:44:04.331  - info: trashschedule.0 (18896) terminating
        2025-09-19 06:44:04.332  - info: radar2.0 (18599) terminating
        2025-09-19 06:44:04.338  - info: iot.0 (18834) terminating
        2025-09-19 06:44:04.338  - info: tado.0 (18944) terminating
        2025-09-19 06:44:04.935  - warn: host.ioBroker instance system.adapter.pushover.0 terminated due to SIGKILL
        2025-09-19 06:44:04.953  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
        iob diag has finished.
        Wenn ich dann versuche, einen Adapter upzudaten, kommt dieses raus bei iob diag.
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
        CPU threads: 4
                       Local time: Fri 2025-09-19 06:51:59 CEST
                   Universal time: Fri 2025-09-19 04:51:59 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        smarthome
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Mem:            8.6G        2.3G        4.3G        143K        2.1G        6.3G
        Swap:             0B          0B          0B
        Total:          8.6G        2.3G        4.3G
        Active iob-Instances:   29
                 8192 M total memory
                 2146 M used memory
                 2214 M active memory
                 1557 M inactive memory
                 4090 M free memory
                    0 M buffer memory
                 1955 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        top - 06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
        Tasks:  59 total,   1 running,  58 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  2.5 si,  0.0 st
        MiB Mem :   8192.0 total,   4089.5 free,   2147.1 used,   1955.5 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6044.9 avail Mem
        2 loaded units listed.
        *** FILESYSTEM ***
        tmpfs                            tmpfs     6.2G  136K  6.2G   1% /run
        /var:
        3.2G    /var/
        1.6G    /var/log
        1.3G    /var/cache/apt
        703M    /opt/iobroker/iobroker-data/
        31M     /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 286)
        admin:          7.7.2
        javascript:     8.9.2
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
        + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
        + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
        + system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        + system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
        + system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
        + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
        + system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
        + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
        + instance is alive
        Objects and States
        Objects:        14243
        States:         12281
        Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
        Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Pending Updates: 0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       142103452  22357/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       142127229  22357/iobroker.js-c
        tcp        0      0 192.168.178.61:42010    0.0.0.0:*               LISTEN      1000       142127710  22615/io.hm-rpc.0
        tcp        0      0 192.168.178.61:42001    0.0.0.0:*               LISTEN      1000       142129503  22695/io.hm-rpc.1
        tcp        0      0 0.0.0.0:37287           0.0.0.0:*               LISTEN      1000       142127662  22585/io.yahka.0
        tcp        0      0 127.0.0.1:36251         0.0.0.0:*               LISTEN      1000       142132584  22585/io.yahka.0
        tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       142134977  22819/io.web.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       142129315  22600/io.shelly.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       142123634  22376/io.admin.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      1000       142129231  22519/io.fullybrows
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       142127596  22549/io.radar2.0
        udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1000       142128073  22742/io.govee-loca
        2025-09-19 06:51:43.283  - error: host.ioBroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:23128) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T04_49_25_414Z-debug-0.loghost.ioBroker Cannot install iobroker.govee-local@0.2.9: 7
          @feinfinger
          cd /opt/iobroker && npm ls noble
            @thomas-braun sagte in Adapter lassen sich nicht updaten:
            smarthome@ioBroker:~$ cd /opt/iobroker && npm ls noble
            [sudo] password for smarthome:
            iobroker.inst@2.0.3 /opt/iobroker
            `-- (empty)
            smarthome@ioBroker:/opt/iobroker$
              @feinfinger
              Sorry, mein Fehler:
              cd /opt/iobroker && npm ls @stoprocent/noble
                Was heißt hier sorry, ich bin so froh das es dich hier im Forum gibt 😃
                smarthome@ioBroker:/opt/iobroker$ cd /opt/iobroker && npm ls @stoprocent/noble
                +-- iobroker.homekit-controller@0.5.11
                | `-- hap-controller@0.10.2
                |   `-- @stoprocent/noble@1.19.1 deduped
                `-- iobroker.radar2@2.4.0
                  @feinfinger sagte in Adapter lassen sich nicht updaten:
                  homekit-controller
                  radar2
                  installier die beiden Adapter mal neu.
                    Radar2 lies sich ohne Probleme installieren, wenn ich den homekit-controller installieren möchte kommt dieser Fehler:
                    ERROR: Process exited with code 25
                    Weniger Protokolle
                    Detailliert
                    $ iobroker add homekit-controller --host ioBroker
                    Installing iobroker.homekit-controller@0.5.11... (System call)
                    npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:26743) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T06_33_43_583Z-debug-0.log
                    host.ioBroker Cannot install iobroker.homekit-controller@0.5.11: 7
                      Dafür lassen sich jetzt die anderen Adapter updaten.
                        @feinfinger
                        Dann mach mal ein Issue drüben bei github für den homekit-controller auf.
                          Ok, hab ich gemacht.
                          Danke dir erstmal für deine Hilfe!
                          440
