    4. Tester wanted - Zigbee Adapter 3.1
      Flugschüler @Asgothian last edited by Flugschüler
      @asgothian
      ELEVATED:I01 (b0bd) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b0bd) value generated '76' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b0bd) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24064,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,205]}}]}...}
      ELEVATED:I01 (b0e8) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b0e8) value generated '80' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b0e8) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24320,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,161]}}]}...}
      ELEVATED:I01 (b113) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b113) value generated '72' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b113) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24576,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]}...}
      ELEVATED:I01 (b13c) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b13c) value generated '76' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b13c) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24832,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,21,196]}}]}...}
      ELEVATED:I01 (b166) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b166) value generated '80' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b166) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25088,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]}...}
      ELEVATED:I01 (b19a) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b19a) value generated '76' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b19a) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25344,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,161]}}]}...}
      ELEVATED:I01 (b1cf) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b1cf) value generated '76' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b1cf) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25600,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]}...}
      ELEVATED:I01 (b1f9) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (b1f9) value generated '76' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (b1f9) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25856,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]}...}
      ELEVATED:I01 (9975) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (9975) value generated '72' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (999e) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
      ELEVATED:I02 (999e) value generated '76' from device a4c13886e50d0115 for 'Link quality'
      ELEVATED:I01 (999e) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":22784,"dpValues":[{"dp":117,"datatype":2,"data":{"type":"Buffer","data":[0,0,161,211]}}]}...}
      ELEVATED:O01 (a68b) User state change of state zigbee.0.a4c13886e50d0115.device_query with value true (ack: false) from system.adapter.admin.0
      ELEVATED:O02 (a68b) Change state 'device_query' at device 0xa4c13886e50d0115 type '2CT'
      ELEVATED:Oqs (a68b) Device query for '0xa4c13886e50d0115/1' triggered
      ELEVATED:Oqe (a68b) ELEVATED O07: Device query for '0xa4c13886e50d0115/1' complete
      Du musst dir sicher das Gerät nicht kaufen. Ich würde mir auch nicht ein gerät kaufen das ich nicht brauche. Ich bin ja froh und dankbar wenn du mir hilfst. Aber ich bin nur ein leihe und kein programmierer ich hoffe die logs bringen dir irgend etwas. Danke!
      • Asgothian
        Asgothian Developer @Flugschüler last edited by
        @flugschüler Die Logs sind immer noch etwas irritierend. Im Payload sind Daten vorhanden, die aber angeblich nicht auf ein Ergebnis verweisen. Das irritiert mich.
        Da grabe ich gerade nach. Im Payload vom Device sind die Daten jedenfalls vorhanden.
        A.
          @asgothian Kann ich noch irgendwie helfen damit wir das Problem lösen können?
          • Asgothian
            @flugschüler Ich grab noch - so in 30 Minuten müsstest du nochmal was testen
              @asgothian 👍
              • Asgothian
                @flugschüler Du hast die Meldungen aus dem Admin kopiert - da sind sie abgeschnitten. Ich brauche zu dieser Meldung
                das vollständige Original.
                Da kommst du ran durch
                • Log Seite aufrufen
                • log herunterladen (das von heute)
                • im Log nach ELEVATED:I01 (b166) suchen - da sollte es genau 2 Zeilen geben.
                A.
                  @asgothian said in Tester wanted - Zigbee Adapter 3.1:
                  ELEVATED:I01 (b166)
                  Ich finde keinen eintrag mit ELEVATED:I01 (b166)
                  • Asgothian
                    @flugschüler den hast du mir aber vorhin selber gepostet. Hast du danach das Log gelöscht ?
                      @asgothian kann sein war das ein Fehler😧
                      2025-09-19 15:04:27.104 - warn: zigbee.0 (56875) ELEVATED:I01 (77e0) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":12032,"dpValues":[{"dp":107,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":72,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,40,2,0,47,107,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":40,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                      2025-09-19 15:04:27.108 - warn: zigbee.0 (56875) ELEVATED:I01 (77e0) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
                      Hilft dir das?
                      • Asgothian
                        @flugschüler sagte in Tester wanted - Zigbee Adapter 3.1:
                        Jein. Zumindest kann ich jetzt sehen welche Daten beim DeviceQuery kommen.
                        Bitte mach folgendes:
                        Installier die 3.1.3 von hier:
                        https://github.com/asgothian/ioBroker.zigbee
                        lass die etwa laufen, damit ich sehen kann was das Gerät an Daten sendet.
                        Nach so 10 Minuten: bitte ein Device Query
                        Und dann nochmal die Log einträge posten. Allerdings bitte die aus dem heruntergeladenen Log, nicht die gekürzten aus dem Admin.
                        Da kommen jetzt mehr Informationen.
                        A.
                          @asgothian iobroker_log.txt
                          • Asgothian
                            @flugschüler Kannst du das bitte auf die relevanten Daten kürzen ? Da ist deutlich zu viel drin - sowohl zeitlich, als auch Adapter-technisch
                            A.
                              @asgothian wie mache ich das?
                              • Asgothian
                                @flugschüler Das ist eine Text-Datei.
                                Aufmachen, die unnötigen Zeilen löschen (z.Bsp was zeitlich nicht passt, oder was von anderen Adaptern ist)
                                Dann speichern
                                  @asgothian iobroker_log.txt Ich hoffe das passt so.
                                  • Asgothian
                                    iobroker_log.txt
                                    Das ist immer noch deutlich zu viel, und deutlich zu wenig Kontext. Da sind mehrere restarts drin, und ich kann nicht sagen wann der device-query gemacht wurde.
                                    Mach das mal bitte genau in dieser Reihenfolge:
                                    • adapter starten
                                    • auf die Protokoll Seite gehen, log löschen
                                    • device query ausführen
                                    • 1 minute warten
                                    • log herunterladen
                                    • alle Zeilen die nicht "zigbee.0" beinhalten löschen.
                                    A.
                                      • Asgothian
                                        @flugschüler Da ist immer noch etwas sehr seltsam.
                                        Bitte nochmal neu von mir installieren (link oben) und dann genau das tun was du als letztes auch getan hast.. Damit kann ich erst einmal arbeiten.
                                        A.
                                          @asgothian iobroker_log2.txt ich hoffe das passt so.
                                          • Asgothian
                                            @flugschüler Unglücklicherweise war bei Deinen Daten ein Zirkelbezug drin.
                                            Deswegen das gleiche Nochmal - ich hab (hoffentlich) dagegen gearbeitet.
                                            1.0k
                                            tester zhc zigbee zigbee 3.1
                                            13
                                            184
                                            4738
