    5. [gelöst] wie mit sendTo History.0 Werte im Voraus übergeben?
      Homoran Global Moderator Administrators @paul53 last edited by Homoran
      @paul53 so, dann warte ich mal auf morgen!
      Die Variable id lag noch rum, da hab ich sie recycelt 😉
      hourly 0...16 existieren
        Homoran Global Moderator Administrators @Homoran last edited by Homoran
        @homoran das konnte ja nicht funktionieren! 😢
        ich hatte doch das array für weitere Bearbeitung gesichert, da steht jetzt
        [{"val":"brightsky.0.hourly.00.solar_estimate","ts":"brightsky.0.hourly.00.timestamp","ack":true},{"val":"brightsky.0.hourly.01.solar_estimate","ts":"brightsky.0.hourly.01.timestamp","ack":true},{"val":"brightsky.0.hourly.02.solar_estimate","ts":"brightsky.0.hourly.02.timestamp","ack":true},{"val":"brightsky.0.hourly.03.solar_estimate","ts":"brightsky.0.hourly.03.timestamp","ack":true},{"val":"brightsky.0.hourly.04.solar_estimate","ts":"brightsky.0.hourly.04.timestamp","ack":true},{"val":"brightsky.0.hourly.05.solar_estimate","ts":"brightsky.0.hourly.05.timestamp","ack":true},{"val":"brightsky.0.hourly.06.solar_estimate","ts":"brightsky.0.hourly.06.timestamp","ack":true},{"val":"brightsky.0.hourly.07.solar_estimate","ts":"brightsky.0.hourly.07.timestamp","ack":true},{"val":"brightsky.0.hourly.08.solar_estimate","ts":"brightsky.0.hourly.08.timestamp","ack":true},{"val":"brightsky.0.hourly.09.solar_estimate","ts":"brightsky.0.hourly.09.timestamp","ack":true},{"val":"brightsky.0.hourly.10.solar_estimate","ts":"brightsky.0.hourly.10.timestamp","ack":true},{"val":"brightsky.0.hourly.11.solar_estimate","ts":"brightsky.0.hourly.11.timestamp","ack":true},{"val":"brightsky.0.hourly.12.solar_estimate","ts":"brightsky.0.hourly.12.timestamp","ack":true},{"val":"brightsky.0.hourly.13.solar_estimate","ts":"brightsky.0.hourly.13.timestamp","ack":true},{"val":"brightsky.0.hourly.14.solar_estimate","ts":"brightsky.0.hourly.14.timestamp","ack":true},{"val":"brightsky.0.hourly.15.solar_estimate","ts":"brightsky.0.hourly.15.timestamp","ack":true},{"val":"brightsky.0.hourly.16.solar_estimate","ts":"brightsky.0.hourly.16.timestamp","ack":true}]
        Da hab ich auch ganz schnell meinen Fehler gefunden.
        Schnell geändert:
        Also noch bis morgen warten
        EDIT:
        Wird auch nicht klappen.
        der Timestamp muss noch konvertiert werden
        [{"val":0.527,"ts":"2025-09-20T07:00:00+00:00","ack":true},{"val":1.211,"ts":"2025-09-20T08:00:00+00:00","ack":true},{"val":1.993,"ts":"2025-09-20T09:00:00+00:00","ack":true},{"val":2.449,"ts":"2025-09-20T10:00:00+00:00","ack":true},{"val":2.532,"ts":"2025-09-20T11:00:00+00:00","ack":true},{"val":2.293,"ts":"2025-09-20T12:00:00+00:00","ack":true},{"val":1.823,"ts":"2025-09-20T13:00:00+00:00","ack":true},{"val":1.276,"ts":"2025-09-20T14:00:00+00:00","ack":true},{"val":0.78,"ts":"2025-09-20T15:00:00+00:00","ack":true},{"val":0.506,"ts":"2025-09-20T16:00:00+00:00","ack":true},{"val":0.178,"ts":"2025-09-20T17:00:00+00:00","ack":true},{"val":0,"ts":"2025-09-20T18:00:00+00:00","ack":true},{"val":0,"ts":"2025-09-20T19:00:00+00:00","ack":true}]
        da steht jetzt verständlicherweise NaN
          Hab noch einiges geändert
          obwohl das Array jetzt so aussieht
          [{"val":527,"ts":1758351600000,"ack":true},{"val":1211,"ts":1758355200000,"ack":true},{"val":1993,"ts":1758358800000,"ack":true},{"val":2449,"ts":1758362400000,"ack":true},{"val":2532,"ts":1758366000000,"ack":true},{"val":2293,"ts":1758369600000,"ack":true},{"val":1823,"ts":1758373200000,"ack":true},{"val":1276,"ts":1758376800000,"ack":true},{"val":780,"ts":1758380400000,"ack":true},{"val":506,"ts":1758384000000,"ack":true},{"val":178,"ts":1758387600000,"ack":true},{"val":0,"ts":1758391200000,"ack":true},{"val":0,"ts":1758394800000,"ack":true}]
          wird jetzt nur noch der 9 Uhr Wert eingetragen.
          den max. - Wert hab ich schon von 100 auf 10000 hochgesetzt
            "common": {
              "name": "clearSkyHourly",
              "desc": "Manuell erzeugt",
              "role": "state",
              "type": "number",
              "read": true,
              "write": true,
              "def": 0,
              "custom": {
                "history.0": {
                  "enabled": true,
                  "aliasId": "",
                  "debounceTime": 0,
                  "blockTime": 0,
                  "changesOnly": true,
                  "changesRelogInterval": 0,
                  "changesMinDelta": "0",
                  "ignoreBelowNumber": "",
                  "disableSkippedValueLogging": false,
                  "retention": "0",
                  "customRetentionDuration": 365,
                  "maxLength": "10",
                  "enableDebugLogs": false,
                  "debounce": "1000"
              "min": 0,
              "max": 10000
            "type": "state",
            "native": {},
            "_id": "Messwerte.0.Solaranlage.Prognosen.clearSkyHourly",
            "acl": {
              "object": 1636,
              "state": 1636,
              "owner": "system.user.admin",
            "user": "system.user.admin",
            "ts": 1758353664668
          EDIT:
          beim nächsten Start nach 10:00 wird wieder der erste Wert, also für 10:00 in die history eingetragen.
          Ein neuer Testdatenpunkt, um auszuschließen dass es Probleme mit dem History.json gibt, wird genauso behandelt.
            paul53 @Homoran last edited by paul53
            @homoran sagte: Start nach 10:00 wird wieder der erste Wert, also für 10:00 in die history eingetragen.
            Hats du die Schleife entsprechend auf 0 bis <= 11 verkürzt?
            @homoran sagte in wie mit sendTo History.0 Werte im Voraus übergeben?:
            Der Datenpunkt wird hoffentlich nicht geschrieben? Die History wird mit sendTo() gefüllt.
            Alternativ zu sendTo() kannst du es mal mit setState() versuchen, der um 5:15 Uhr 17 mal hintereinander den Datenpunkt schreibt:
              @paul53 sagte in wie mit sendTo History.0 Werte im Voraus übergeben?:
              ja!
              richtig!
              hab ihn sogar gelöscht, neu angelegt. Da steht noch die initiale gelbe 0
              Alternativ
              wäre eine Möglichkeit.
              Aber im Moment verstehe ich folgendes nicht:
              gemäß der Historykonfiguration des Datenpunktes, Verlaufsdaten
              zuerst wurde gar nichts geschrieben... ist klar, keine Zahlen
              Anschließend (ohne timestamp-Konvertierung) standen alle Werte drin, mit Timestamp: Datum Uhrzeit .NaN für Millisekunden.
              jetzt passt der Timestamp, aber nur der erste Wert wird in der History angezeigt!
              ist seltsam
              Achtung, es wird noch seltsamer
              gerade sehe ich nochmal nach, da stehen alle Daten der vergangenen und der aktuellen Stunde drin, aber keine in der Zukunft!
              Als ob das Array erst "zeitgerecht" abgearbeitet wird.... 🤔
                @homoran sagte: da stehen alle Daten der vergangenen und der aktuellen Stunde drin
                Die vergangenen Stunden stehen noch drin, oder hast du die History inzwischen gelöscht?
                Die Liste ist aber korrekt? Vielleicht lässt History mit sendTo() keine zukünftigen Daten zu?
                  als ich das letzte mal teingesehen hatte standen nur 0900 und 1000 drin.
                  jetzt sind ohne weitere Aktivitäten meinerseits (war zwischenzeitlich Fliesen abschlagen 😉) die Werte von 1100 und 1200 aufgetaucht
                    die um 10:07:59 geschriebene und gesendete Liste
                    [{"val":1253,"ts":1758355200000,"ack":true},{"val":1920,"ts":1758358800000,"ack":true},{"val":2368,"ts":1758362400000,"ack":true},{"val":2515,"ts":1758366000000,"ack":true},{"val":2293,"ts":1758369600000,"ack":true},{"val":1823,"ts":1758373200000,"ack":true},{"val":1299,"ts":1758376800000,"ack":true},{"val":790,"ts":1758380400000,"ack":true},{"val":513,"ts":1758384000000,"ack":true},{"val":185,"ts":1758387600000,"ack":true},{"val":0,"ts":1758391200000,"ack":true},{"val":0,"ts":1758394800000,"ack":true}]
                    @klassisch kann es aber 😢 mit js
                    EDIT:
                    das gleiche in dem einmalig testweise beschriebenen Datenpunkt
                    EDIT2:
                    damit liegen aber zumindest in flot die zukünftigen Daten vor
                    Möglicherweise ist doch das heutige json vom Original-DP durch diese Spielereien "verbrannt"
                    hab aber keine Lust mir das rauszusuchen und zu analysieren
                      @homoran sagte: das gleiche in dem einmalig testweise beschriebenen Datenpunkt
                      Schau dir mal die Endzeit an: Die zukünftigen Werte werden nur nicht angezeigt, sind aber in der .json-Datei enthalten?
                        @paul53 siehe edit2 bitte!
                          @homoran sagte: @klassisch kann es aber mit js
                          Das ist die Version mit "steuere" ohne sendTo().
                            @paul53 DANKE!
                            ich warte mal ab, ob es morgen woeder klappt, sonst stell ich erstmalnauf den Test-DP um, und wenn das auch nicht stabil läuft mach ich das mit einzelnen Einträgen.
                              ich warte mal ab, ob es morgen wieder klappt
                              Tut es!
                              nochmals Danke @paul53
                              257
