    4. Tester wanted - Zigbee Adapter 3.1
    • Fabio
      Fabio @Asgothian last edited by Fabio
      Hallo @asgothian nein beide Felder waren leer.
      Kein Debug, habe gerade installiert jetzt kommt das: Hat sich nichts geändert wie vorher auch. Habe gerade beide Instanzen auf Error gestellt, jetzt ist erts mal Ruhe.
      zigbee.1
      2025-09-20 10:24:07.136	warn	ELEVATED:I02.1b (2cde) converter 1 : Cluster manuSpecificTuya => payload : {"rain_intensity":6}
      zigbee.1
      2025-09-20 10:24:07.009	warn	ELEVATED:I02.1b (2c5e) converter 1 : Cluster manuSpecificTuya => payload : {"illuminance_average_20min":5260}
      zigbee.1
      2025-09-20 10:24:06.885	warn	ELEVATED:I02.1b (2be3) converter 1 : Cluster manuSpecificTuya => payload : {"illuminance":5321}
      zigbee.0
      2025-09-20 10:24:05.681	warn	ELEVATED:I04 (272e) value generated '13' from device a4c1386ed0c785b7 for 'Rainfall intensity'
      zigbee.0
      2025-09-20 10:24:05.681	warn	ELEVATED:I03 (272e) message received '{"rain_intensity":13}' from device a4c1386ed0c785b7 type 'RB-SRAIN01'
      zigbee.0
      2025-09-20 10:24:05.681	warn	ELEVATED:I02.1b (272e) converter 1 : Cluster manuSpecificTuya => payload : {"rain_intensity":13}
      zigbee.0
      2025-09-20 10:24:05.680	warn	ELEVATED:I02.1a (272e) data: {"seq":256,"dpValues":[{"dp":105,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,13]}}]} options: {} meta:{"deviceIEEE":"0xa4c1386ed0c785b7","logger":"StatesController","state":{"state":""}} result:{"rain_intensity":13}
      zigbee.0
      2025-09-20 10:24:05.680	warn	ELEVATED:I04 (272e) value generated '142' from device a4c1386ed0c785b7 for 'Link quality'
      zigbee.0
      2025-09-20 10:24:05.680	warn	ELEVATED:I03 (272e) message received '{"linkquality":142}' from device a4c1386ed0c785b7 type 'RB-SRAIN01'
      zigbee.0
      2025-09-20 10:24:05.680	warn	ELEVATED:I02 (272e) 1 converter available for 'RB-SRAIN01' 'a4c1386ed0c785b7' with cluster 'manuSpecificTuya' and type 'commandActiveStatusReport'
      zigbee.0
      2025-09-20 10:24:05.678	warn	ELEVATED:I01 (272e) Zigbee Event of Type commandActiveStatusReport from device 0xa4c1386ed0c785b7, incoming event: {"type":"commandActiveStatusReport","data":{"seq":256,"dpValues":[{"dp":105,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,13]}}]},"linkquality":142,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,109,6,0,1,105,2,0,4,0,0,0,13]},"zclTransactionSequenceNumber":109,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-09-20 10:24:05.551	warn	ELEVATED:I04 (26a9) value generated '4965' from device a4c1386ed0c785b7 for 'Illuminance average for the last 20 minutes'
      zigbee.0
      2025-09-20 10:24:05.551	warn	ELEVATED:I03 (26a9) message received '{"illuminance_average_20min":4965}' from device a4c1386ed0c785b7 type 'RB-SRAIN01'
      zigbee.0
      2025-09-20 10:24:05.551	warn	ELEVATED:I02.1b (26a9) converter 1 : Cluster manuSpecificTuya => payload : {"illuminance_average_20min":4965}
      zigbee.0
      2025-09-20 10:24:05.550	warn	ELEVATED:I02.1a (26a9) data: {"seq":256,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,101]}}]} opti
      zigbee.1
      2025-09-20 10:16:07.861	warn	ELEVATED:I02.1b (dcb4) converter 1 : Cluster genBasic => payload : {"linkquality":160}
      zigbee.1
      zigbee.0
      2025-09-20 10:16:07.565	warn	ELEVATED:I02.1b (db8a) converter 1 : Cluster manuSpecificTuya => payload : {"rain_intensity":13}
      zigbee.1
      2025-09-20 10:16:07.335	warn	ELEVATED:I02.1b (daa4) converter 1 : Cluster manuSpecificTuya => payload : {"rain_intensity":6}
      zigbee.1
      2025-09-20 10:16:07.108	warn	ELEVATED:I02.1b (d9c0) converter 1 : Cluster manuSpecificTuya => payload : {"illuminance_average_20min":5296}
      zigbee.1
      2025-09-20 10:16:06.921	warn	ELEVATED:I02.1b (d8d7) converter 1 : Cluster manuSpecificTuya => payload : {"illuminance":5203}
      zigbee.0
      2025-09-20 10:16:06.833	warn	ELEVATED:I02.1b (d8af) converter 1 : Cluster manuSpecificTuya => payload : {"illuminance_average_20min":5200}
      • Asgothian
        Asgothian Developer @Fabio last edited by
        @fabio bitte nochmal installieren. Vorher den Adapter anhalten.
        Fabio 1 Reply Last reply Reply Quote 1
        • Fabio
          Danke @asgothian beide Instanzen laufen normal ohne Meldungen. 👍
          Herzliche Grüße
          Fabio
          • Asgothian
            @fabio sag mal - hast du eine Tuya TS011F_plug_3 in einem deiner Netze ?
            Fabio D 2 Replies Last reply Reply Quote 0
            • Fabio
              @asgothian nein kann ich leider nicht mit dienen das meiste sind ZigBee Plugs von Lidl.
                dimaiv @Asgothian last edited by
                @asgothian
                Ich habe TS011F_plug_1
                Kann ich helfen?
                Die senden Daten wie gewohnt.
                Die TS0121_plug senden NUR Sum energy (kein Load Power, Current) seit Umstellung auf ZHC25
                • Asgothian
                  Asgothian Developer @dimaiv last edited by
                  @dimaiv kannst du folgendes machen:
                  • die aktuelle Github version installieren
                  • nach dem Start eine ts0121 plug auf debug setzen
                  • ein Device Query machen
                  • Dann das Debug interface öffnen
                  • mit dem button 1 aus dem Screenshot die Daten aktualisieren
                  • in jeder Zeile bei incoming messages mit dem blauen Button 2 die Meldungen öffnen
                  • aus dem Dialog heraus kopieren und hier Posten ?
                  Danke.
                  A.
                    Flugschüler @Asgothian last edited by
                    @asgothian Hast du schon was rausgefunden?
                    • Asgothian
                      Asgothian Developer @Flugschüler last edited by
                      @flugschüler Nein - aber das ist auch kein Wunder. Die Daten sind noch unsauber. Folge mal bitte dieser Anleitung (bezogen auf Dein device):
                      https://forum.iobroker.net/topic/82156/tester-wanted-zigbee-adapter-3-1/128?_=1758346925852
                      A.
                        @asgothian in jeder Zeile bei incoming messages mit dem blauen Button 2 die Meldungen öffnen hier habe ich ein problem bei mir kommt kein blauer Button.
                        • Asgothian
                          @flugschüler sagte in Tester wanted - Zigbee Adapter 3.1:
                          Screenshot bitte. Und hast du heute morgen neu von GitHub installiert ?
                            @asgothian meinst du über die Katze? Hab ich nicht gemacht. Wie war nochmal der link? Ich habe die normale 3.1.2 installiert.
                            • Asgothian
                              @flugschüler du brauchst keinen Link:
                              Katze - GitHub auswählen - zigbee auswählen, installieren.
                              Bitte vorher den Adapter anhalten und nachher wieder manuell starten.
                                Flugschüler @Asgothian last edited by Flugschüler
                                @asgothian ```
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":19712,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,172,2,0,77,142,4,0,1,0]},"zclTransactionSequenceNumber":172,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02: 2 converters available for '2CT' 'a4c13886e50d0115' with cluster 'manuSpecificTuya' and type 'commandDataReport'
                                I03: message received '{"linkquality":54}' from device a4c13886e50d0115 type '2CT'
                                I04: value generated '54' from device a4c13886e50d0115 for 'Link quality'
                                I02.1a: data: {"seq":19712,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":19456,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,171,2,0,76,141,4,0,1,0]},"zclTransactionSequenceNumber":171,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":19456,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":19200,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,170,2,0,75,104,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":170,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":19200,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18944,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,169,2,0,74,103,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":169,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":18944,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18688,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,168,2,0,73,102,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":168,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":18688,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18432,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,167,2,0,72,101,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":167,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I03: message received '{"linkquality":51}' from device a4c13886e50d0115 type '2CT'
                                I04: value generated '51' from device a4c13886e50d0115 for 'Link quality'
                                I02.1a: data: {"seq":18432,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18176,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,166,2,0,71,19,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":166,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":18176,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17920,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,216]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,165,2,0,70,20,2,0,4,0,0,8,216]},"zclTransactionSequenceNumber":165,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":17920,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,216]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17664,"dpValues":[{"dp":105,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,51]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,164,2,0,69,105,2,0,4,0,0,19,51]},"zclTransactionSequenceNumber":164,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":17664,"dpValues":[{"dp":105,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,51]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17408,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,72]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,163,2,0,68,110,2,0,4,0,0,170,72]},"zclTransactionSequenceNumber":163,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":17408,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,72]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17152,"dpValues":[{"dp":107,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,162,2,0,67,107,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":162,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":17152,"dpValues":[{"dp":107,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16896,"dpValues":[{"dp":118,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,161,2,0,66,118,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":161,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":16896,"dpValues":[{"dp":118,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16640,"dpValues":[{"dp":117,"datatype":2,"data":{"type":"Buffer","data":[0,0,163,59]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,160,2,0,65,117,2,0,4,0,0,163,59]},"zclTransactionSequenceNumber":160,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":16640,"dpValues":[{"dp":117,"datatype":2,"data":{"type":"Buffer","data":[0,0,163,59]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16384,"dpValues":[{"dp":116,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,159,2,0,64,116,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":159,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":16384,"dpValues":[{"dp":116,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16128,"dpValues":[{"dp":115,"datatype":2,"data":{"type":"Buffer","data":[0,0,7,13]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,158,2,0,63,115,2,0,4,0,0,7,13]},"zclTransactionSequenceNumber":158,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":16128,"dpValues":[{"dp":115,"datatype":2,"data":{"type":"Buffer","data":[0,0,7,13]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15872,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,157,2,0,62,142,4,0,1,0]},"zclTransactionSequenceNumber":157,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":15872,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15616,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,156,2,0,61,141,4,0,1,0]},"zclTransactionSequenceNumber":156,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":15616,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15360,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,155,2,0,60,104,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":155,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":15360,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15104,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,154,2,0,59,103,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":154,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":15104,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":14848,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,153,2,0,58,102,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":153,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":14848,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":14592,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,152,2,0,57,101,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":152,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                I02.1a: data: {"seq":14592,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                                Ich hoffe du kannst damit was anfangen.
                                • Asgothian
                                  @flugschüler Ja. es zeigt ganz deutlich das der Converter für den cluster manuSpecificTuya nicht so arbeitet wie erwartet - Das Ergebnis ist immer 'undefined'
                                  Allerdings grab ich aktuell noch an was anderem, deswegen werd ich erst später darauf reagieren können.
                                  A.
                                    @asgothian o.k. lass dir zeit.
                                    • Asgothian
                                      @flugschüler So - du kannst nochmal probieren - wieder vom aktuellen Github repository installieren
                                      Dann mal keinen Device-Query, sondern einfach nur 30 Minuten sitzen lassen, mit ddevice-debug für Dein Device aktiv.
                                      Dann mal im Debug fenster schauen welche Werte aktualisiert wurden. Dazu solltest du:
                                      • mit dem grünen button oben rechts im screenshot alle Daten aktualisieren
                                      • mit dem blauen Button mit den angedeuteten Pfeilen hoch/runter die Nachrichten einkürzen (gleichartige Nachrichten werden auf eine (die neuste) zusammengezogen
                                      Dann kannst du sehen welche Datenpunkte mit Werten versorgt wurden. Im Beispiel Screenshot
                                      sind das link_quality, state_l4, state_l3, state_l2
                                      A.
                                        @asgothian werde ich gleich testen auf jeden fall kann ich jetzt schon sagen das energy_a und energy_b wieder angezeigt werden. Scheint das es funktioniert.
                                        • Asgothian
                                          @flugschüler beim device_query oder auch so ?
                                            @asgothian Nein auch so. Es scheint das alles so funktioniert wie es soll. Tolle leistung von dir muss ich sagen. Soll ich trozdem noch warten und die daten auslesen wie du oben beschrieben hast? Hab noch mal kontrolliert alle datenpunkte werden aktualisiert.👍 👍 👍Screenshot 2025-09-21 010056.png link_quality ist rot ist das ein fehler oder ist das nur so weil der empfang nicht so gut ist?
                                            tester zhc zigbee zigbee 3.1
                                            12
                                            175
                                            4124
