    4. Tester wanted - Zigbee Adapter 3.1
    • Asgothian
      Asgothian Developer @Flugschüler last edited by
      @flugschüler du brauchst keinen Link:
      Katze - GitHub auswählen - zigbee auswählen, installieren.
      Bitte vorher den Adapter anhalten und nachher wieder manuell starten.
        Flugschüler @Asgothian last edited by Flugschüler
        @asgothian ```
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":19712,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,172,2,0,77,142,4,0,1,0]},"zclTransactionSequenceNumber":172,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02: 2 converters available for '2CT' 'a4c13886e50d0115' with cluster 'manuSpecificTuya' and type 'commandDataReport'
        I03: message received '{"linkquality":54}' from device a4c13886e50d0115 type '2CT'
        I04: value generated '54' from device a4c13886e50d0115 for 'Link quality'
        I02.1a: data: {"seq":19712,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":19456,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,171,2,0,76,141,4,0,1,0]},"zclTransactionSequenceNumber":171,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":19456,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":19200,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,170,2,0,75,104,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":170,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":19200,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18944,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,169,2,0,74,103,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":169,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":18944,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18688,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,168,2,0,73,102,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":168,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":18688,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18432,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,167,2,0,72,101,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":167,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I03: message received '{"linkquality":51}' from device a4c13886e50d0115 type '2CT'
        I04: value generated '51' from device a4c13886e50d0115 for 'Link quality'
        I02.1a: data: {"seq":18432,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":18176,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,166,2,0,71,19,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":166,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":18176,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17920,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,216]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,165,2,0,70,20,2,0,4,0,0,8,216]},"zclTransactionSequenceNumber":165,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":17920,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,216]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17664,"dpValues":[{"dp":105,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,51]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,164,2,0,69,105,2,0,4,0,0,19,51]},"zclTransactionSequenceNumber":164,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":17664,"dpValues":[{"dp":105,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,51]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17408,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,72]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,163,2,0,68,110,2,0,4,0,0,170,72]},"zclTransactionSequenceNumber":163,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":17408,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,72]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":17152,"dpValues":[{"dp":107,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,162,2,0,67,107,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":162,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":17152,"dpValues":[{"dp":107,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16896,"dpValues":[{"dp":118,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,161,2,0,66,118,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":161,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":16896,"dpValues":[{"dp":118,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16640,"dpValues":[{"dp":117,"datatype":2,"data":{"type":"Buffer","data":[0,0,163,59]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,160,2,0,65,117,2,0,4,0,0,163,59]},"zclTransactionSequenceNumber":160,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":16640,"dpValues":[{"dp":117,"datatype":2,"data":{"type":"Buffer","data":[0,0,163,59]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16384,"dpValues":[{"dp":116,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,159,2,0,64,116,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":159,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":16384,"dpValues":[{"dp":116,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":16128,"dpValues":[{"dp":115,"datatype":2,"data":{"type":"Buffer","data":[0,0,7,13]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,158,2,0,63,115,2,0,4,0,0,7,13]},"zclTransactionSequenceNumber":158,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":16128,"dpValues":[{"dp":115,"datatype":2,"data":{"type":"Buffer","data":[0,0,7,13]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15872,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,157,2,0,62,142,4,0,1,0]},"zclTransactionSequenceNumber":157,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":15872,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15616,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,156,2,0,61,141,4,0,1,0]},"zclTransactionSequenceNumber":156,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":15616,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15360,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,155,2,0,60,104,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":155,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":15360,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":15104,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,154,2,0,59,103,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":154,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":15104,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":14848,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":54,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,153,2,0,58,102,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":153,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":14848,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":14592,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":51,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,152,2,0,57,101,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":152,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
        I02.1a: data: {"seq":14592,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
        Ich hoffe du kannst damit was anfangen.
        • Asgothian
          @flugschüler Ja. es zeigt ganz deutlich das der Converter für den cluster manuSpecificTuya nicht so arbeitet wie erwartet - Das Ergebnis ist immer 'undefined'
          Allerdings grab ich aktuell noch an was anderem, deswegen werd ich erst später darauf reagieren können.
          A.
            @asgothian o.k. lass dir zeit.
            • Asgothian
              @flugschüler So - du kannst nochmal probieren - wieder vom aktuellen Github repository installieren
              Dann mal keinen Device-Query, sondern einfach nur 30 Minuten sitzen lassen, mit ddevice-debug für Dein Device aktiv.
              Dann mal im Debug fenster schauen welche Werte aktualisiert wurden. Dazu solltest du:
              • mit dem grünen button oben rechts im screenshot alle Daten aktualisieren
              • mit dem blauen Button mit den angedeuteten Pfeilen hoch/runter die Nachrichten einkürzen (gleichartige Nachrichten werden auf eine (die neuste) zusammengezogen
              Dann kannst du sehen welche Datenpunkte mit Werten versorgt wurden. Im Beispiel Screenshot
              sind das link_quality, state_l4, state_l3, state_l2
              A.
                @asgothian werde ich gleich testen auf jeden fall kann ich jetzt schon sagen das energy_a und energy_b wieder angezeigt werden. Scheint das es funktioniert.
                • Asgothian
                  @flugschüler beim device_query oder auch so ?
                    @asgothian Nein auch so. Es scheint das alles so funktioniert wie es soll. Tolle leistung von dir muss ich sagen. Soll ich trozdem noch warten und die daten auslesen wie du oben beschrieben hast? Hab noch mal kontrolliert alle datenpunkte werden aktualisiert.👍 👍 👍Screenshot 2025-09-21 010056.png link_quality ist rot ist das ein fehler oder ist das nur so weil der empfang nicht so gut ist?
                    • Asgothian
                      Asgothian Developer last edited by
                      @flugschüler das kann ich so nicht sagen, dazu musst du dir die Meldungen anschauen. Wahrscheinlich gibt es Meldungen ohne Daten (payload = {}).
                      A.
                        @Asgothian
                        I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":9472,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,231]}}]},"linkquality":58,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,111,2,0,37,110,2,0,4,0,0,170,231]},"zclTransactionSequenceNumber":111,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                        I03: message received '{"linkquality":58}' from device a4c13886e50d0115 type '2CT'
                        I04: value generated '58' from device a4c13886e50d0115 for 'Link quality'
                        I02.1a: converter 1 : Cluster manuSpecificTuya
                        I02.0b: data: {"seq":9472,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,231]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
                        I02.2a: converter 2 : Cluster manuSpecificTuya
                        I02.1b: data: {"seq":9472,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,231]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:{}
                        I02.2c: candidates: [{},{}] => payload {}
                        NOVAL: payload {} is empty
                        Aber wie gesagt das Gerät funktioniert und die datenpunkte werden angezeigt.
                        • Asgothian
                          @flugschüler dann würde ich mir erst einmal keine Sorgen machen.
                          A.
                            @asgothian Super gemacht. Wird das Gerät in den neuen Zigbee Adapter integriert? Soll ich den Adapter jetzt über git installiert lassen?
                            Asgothian Thomas Braun 2 Replies Last reply Reply Quote 0
                            • Asgothian
                              @flugschüler sobald die ganzen Nebeneffekte geklärt sind geht das erst ins latest, dann ins stable.
                                Thomas Braun Most Active @Flugschüler last edited by
                                @flugschüler sagte in Tester wanted - Zigbee Adapter 3.1:
                                Ja. Wenn irgendwann über dein bevorzugtes Repository eine Version größer als die jetzige angeboten wird kommt die dann über deine regelmäßige Systempflege auf die Kiste.
                                  Flugschüler @Thomas Braun last edited by
                                  @thomas-braun Ihr seid die besten👍
                                    dimaiv @Asgothian last edited by dimaiv
                                    @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
                                    @dimaiv kannst du folgendes machen:
                                    • die aktuelle Github version installieren
                                    • nach dem Start eine ts0121 plug auf debug setzen
                                    • ein Device Query machen
                                    • Dann das Debug interface öffnen
                                    • mit dem button 1 aus dem Screenshot die Daten aktualisieren
                                    • in jeder Zeile bei incoming messages mit dem blauen Button 2 die Meldungen öffnen
                                    • aus dem Dialog heraus kopieren und hier Posten ?
                                    Danke.
                                    A.
                                    I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"tuyaBacklightMode":1},"linkquality":87,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[24,8,1,1,128,0,48,1]},"zclTransactionSequenceNumber":8,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                    I02: 3 converters available for 'TS0121_plug' '60a423fffe61dd4a' with cluster 'genOnOff' and type 'readResponse'
                                    I03: message received '{"linkquality":87}' from device 60a423fffe61dd4a type 'TS0121_plug'
                                    I04: value generated '87' from device 60a423fffe61dd4a for 'Link quality'
                                    I02.1a: converter 1 : Cluster genOnOff
                                    I02.0b: data: {"tuyaBacklightMode":1} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
                                    I02.2a: converter 2 : Cluster genOnOff
                                    I02.1b: data: {"tuyaBacklightMode":1} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
                                    I02.3a: converter 3 : Cluster genOnOff
                                    I02.2b: data: {"tuyaBacklightMode":1} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"indicator_mode":"off/on"}
                                    I02.3c: candidates: [{},{},{"indicator_mode":"off/on"}] => payload {"indicator_mode":"off/on"}
                                    I03-1: message received '{"indicator_mode":"off/on"}' from device 60a423fffe61dd4a type 'TS0121_plug'
                                    I04-1: value generated '"off/on"' from device 60a423fffe61dd4a for 'LED indicator mode'
                                    I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"moesStartUpOnOff":0},"linkquality":87,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[24,7,1,2,128,0,48,0]},"zclTransactionSequenceNumber":7,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                    I02.0b: data: {"moesStartUpOnOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
                                    I02.1b: data: {"moesStartUpOnOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"power_outage_memory":"off"}
                                    I02.2b: data: {"moesStartUpOnOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
                                    I02.3c: candidates: [{},{"power_outage_memory":"off"},{}] => payload {"power_outage_memory":"off"}
                                    I03-1: message received '{"power_outage_memory":"off"}' from device 60a423fffe61dd4a type 'TS0121_plug'
                                    I04-1: value generated '"off"' from device 60a423fffe61dd4a for 'Recover state after power outage'
                                    I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"onOff":0},"linkquality":87,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[24,6,1,0,0,0,16,0]},"zclTransactionSequenceNumber":6,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                    I02.0b: data: {"onOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"state":"OFF"}
                                    I02.1b: data: {"onOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
                                    I02.2b: data: {"onOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
                                    I02.3c: candidates: [{"state":"OFF"},{},{}] => payload {"state":"OFF"}
                                    I03-1: message received '{"state":"OFF"}' from device 60a423fffe61dd4a type 'TS0121_plug'
                                    I04-1: value generated 'false' from device 60a423fffe61dd4a for 'On/off state of the switch'
                                    P.S.: ich glaube, die weiteren Daten bei diesen Steckdosen wurden immer gepoolt, und jetzt passiert es nicht.
                                      @asgothian
                                      Was mir noch aufgefallen:
                                      Mit 3.1.2 kann ich über:
                                      sendToZigbee { "id": "zigbee.0.842e14fffedb8ae5", "ep": "1", "cid": "haElectricalMeasurement", "cmd": "read", "cmdType": "foundation", "zclData": { "activePower": {} } }
                                      Die weiteren Daten abrufen.
                                      Mit 3.1.3 von jetzt funktioniert es nicht.
                                      Das sind 2 absolut gleiche Steckdosen, unterschiedliche Installationen.
                                      • Asgothian
                                        Asgothian Developer @dimaiv last edited by
                                        @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
                                        Sind die Meldungen nach einem Device_query, oder kommen die normal so ?
                                        Danke für den Hinweis - ich hab im Hintergrund einiges Optimiert.
                                        A.
                                          A.
                                          Die Meldungen sind nach einem Device_query, aber auch normal kommen nur die.
                                          • Asgothian
                                            @dimaiv Ok, danke. Da scheint ein Konverter geändert - da muss ich im Detail graben, und Dir eine extra version machen. Wird aber etwas dauern.
                                            A.
                                            Asgothian 1 Reply Last reply Reply Quote 1
                                            tester zhc zigbee zigbee 3.1
                                            12
                                            175
                                            4124
