    3. Off Topic
    4. zigbee2mqtt läuft sein heute morgen nicht mehr
      Homoran Global Moderator Administrators @Mico last edited by
      @mico sagte in zigbee2mqtt läuft sein heute morgen nicht mehr:
      mein Zigbee2mqtt
      das wäre nich ioBroker!
        Mico @Homoran last edited by
        @arteck
         cd /opt/zigbee2mqtt
        npm start
        > zigbee2mqtt@2.6.1 start
        > node index.js
        Starting Zigbee2MQTT without watchdog.
        Error: EACCES: permission denied, unlink '/opt/zigbee2mqtt/data/log/2025-09-22.0        7-05-31/log.log'
            at unlinkSync (node:fs:1952:11)
            at _unlinkSync (node:internal/fs/rimraf:215:14)
            at rimrafSync (node:internal/fs/rimraf:196:7)
            at node:internal/fs/rimraf:254:9
            at Array.forEach (<anonymous>)
            at _rmdirSync (node:internal/fs/rimraf:251:7)
            at rimrafSync (node:internal/fs/rimraf:194:7)
            at rmSync (node:fs:1247:10)
            at rimrafNativeSync (/opt/zigbee2mqtt/node_modules/.pnpm/rimraf@6.0.1/node_m        odules/rimraf/src/rimraf-native.ts:21:9)
            at /opt/zigbee2mqtt/node_modules/.pnpm/rimraf@6.0.1/node_modules/rimraf/src/        index.ts:78:21
        npm notice
        npm notice New major version of npm available! 10.9.3 -> 11.6.0
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.6.0
        npm notice To update run: npm install -g npm@11.6.0
        npm notice
        pi@raspberrypi5:/opt/zigbee2mqtt $
        Das ist vom Coordinator da gibts keine Verbindung mehr
          Mico @Mico last edited by Mico
          und das ist beim Iobroker
          ee2mqtt.1
          	2025-09-22 13:38:57.543	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:56.542	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:55.541	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:54.540	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:53.539	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:52.537	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:51.535	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:50.534	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:49.532	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:48.530	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:47.529	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:46.527	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:45.526	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:44.526	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:43.524	warn	Start try again in 1 seconds...
          zigbee2mqtt.1
          	2025-09-22 13:38:42.523	warn	Start try again in 1 seconds...
          • Asgothian
            Asgothian Developer @Mico last edited by
            @mico Logisch. Solange zigbee2mqtt.io nicht läuft wird der Adapter keine Verbindung aufbauen können.
            Laut dieser Meldung:
            hast du ein Rechte-Problem.
            Ich würde als erstens das System / den Container auf/in dem z2m läuft komplett neu starten. Dann versuchen z2m zu starten um zu sehen mit welchen Meldungen das schief geht. (wenn er nicht läuft)
            Ab da müsstest Du dann bei Zigbee2mqtt nachfragen - da sitzen die Experten für diese Probleme.
            A
            M 1 Reply Last reply Reply Quote 2
              Mico @Asgothian last edited by Mico
              @asgothian
              Wie mache ich das genau ? Ich habe von Linux keinerlei Ahnung und hatte mir das einrichten lassen, und es lief ja auch deswegen könnte ich mir vorstellen das die Rechte ja noch da sind.
              hat das was mit diesem pnpm zu tun.
                Thomas Braun Most Active @Mico last edited by
                Schau nach, was da genau los ist. Wie sehen die Rechte denn momentan aus? Auch am Dateisystem. Wenn es da Probleme gibt wird das z.B. 'nur lesend' eingehängt.
                Sowas steht u.a. in der Ausgabe von
                iob diag
                drin.
                  Mico @Thomas Braun last edited by Mico
                  Hiermal die iob diag
                  ========== Start marking the full check here ===========
                  ```bash
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi5
                         Icon name: computer
                            Kernel: Linux 6.12.34+rpt-rpi-2712
                      Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 5 Model B Rev 1.0
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   11:24:49 up 1 day,  3:42,  4 users,  load average: 0.25, 0.20, 0.26
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  ~ Under-voltage has occurred
                  ~ Arm frequency capping has occurred
                  ~ Throttling has occurred
                  ~ Soft temperature limit has occurred
                  *** TIME AND TIMEZONES ***
                                 Local time: Tue 2025-09-23 11:24:49 CEST
                             Universal time: Tue 2025-09-23 09:24:49 UTC
                                   RTC time: Tue 2025-09-23 09:24:49
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server:         true
                  Display-Manager:        * lightdm.service - Light Display Manager
                  Desktop:
                  Session:                tty
                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                  *** MEMORY ***
                  Mem:            8.5G        4.1G        1.9G         28M        2.6G        4.4G
                  Swap:           209M          0B        209M
                  Total:          8.7G        4.1G        2.1G
                  Active iob-Instances:   34
                           8063 M total memory
                           3902 M used memory
                           4344 M active memory
                           1354 M inactive memory
                           1832 M free memory
                            193 M buffer memory
                           2249 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  top - 11:24:50 up 1 day,  3:42,  4 users,  load average: 0.25, 0.20, 0.26
                  Tasks: 264 total,   1 running, 263 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 66.7 id, 33.3 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   8063.2 total,   1832.7 free,   3902.8 used,   2443.0 buff/cache
                  MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4160.4 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  udev           devtmpfs  3.9G     0  3.9G   0% /dev
                  tmpfs          tmpfs     1.6G  6.0M  1.6G   1% /run
                  /dev/mmcblk0p2 ext4       58G   52G  3.5G  94% /
                  tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
                  tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                  /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
                  tmpfs          tmpfs     807M  176K  807M   1% /run/user/1000
                  [Mon Sep 22 07:42:33 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:68:16 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a84847a9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Mon Sep 22 07:42:34 2025] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
                  [Mon Sep 22 07:42:35 2025] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
                  Show mounted filesystems:
                  TARGET               SOURCE         FSTYPE      OPTIONS
                  /                    /dev/mmcblk0p2 ext4        rw,noatime
                  |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  41G     /var/
                  38G     /var/lib/influxdb/engine/data
                  38G     /var/lib
                  Archived and active journals take up 2.3G in the file system.
                  /opt/iobroker/backups:
                  90M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  1.4G    /opt/iobroker/iobroker-data/
                  855M    /opt/iobroker/iobroker-data/history
                  381M    /opt/iobroker/iobroker-data/files
                  123M    /opt/iobroker/iobroker-data/backup-objects
                  52M     /opt/iobroker/iobroker-data/files/vis-2
                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                  24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                  20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
                  19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03218114-if00-port0
                  *** ZigBee Settings ***
                  Zigbee Network Settings on your coordinator/in nvbackup are:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  To unmask the settings run 'iob diag --unmask'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v22.19.0
                  /usr/bin/node           v22.19.0
                  /usr/bin/npm            10.9.3
                  /usr/bin/npx            10.9.3
                  /usr/bin/corepack       0.34.0
                  nodejs:
                    Installed: 22.19.0-1nodesource1
                    Candidate: 22.19.0-1nodesource1
                    Version table:
                   *** 22.19.0-1nodesource1 600
                          500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       22.18.0-1nodesource1 600
                       22.17.1-1nodesource1 600
                       22.17.0-1nodesource1 600
                       22.16.0-1nodesource1 600
                       22.15.1-1nodesource1 600
                       22.15.0-1nodesource1 600
                       22.14.0-1nodesource1 600
                       22.13.1-1nodesource1 600
                       22.13.0-1nodesource1 600
                       22.12.0-1nodesource1 600
                       22.11.0-1nodesource1 600
                       22.10.0-1nodesource1 600
                       22.9.0-1nodesource1 600
                       22.8.0-1nodesource1 600
                       22.7.0-1nodesource1 600
                       22.6.0-1nodesource1 600
                       22.5.1-1nodesource1 600
                       22.5.0-1nodesource1 600
                       22.4.1-1nodesource1 600
                       22.4.0-1nodesource1 600
                       22.3.0-1nodesource1 600
                       22.2.0-1nodesource1 600
                       22.1.0-1nodesource1 600
                       22.0.0-1nodesource1 600
                       18.20.4+dfsg-1~deb12u1 500
                  No problems detected
                  Errors in npm tree: 0
                  Checking for nodejs vulnerability:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  raspberrypi2        raspberrypi2 (version: 7.0.7, hostname: raspberrypi2  , alive, uptime: 110835)
                  raspberrypi5        raspberrypi5 (version: 7.0.7, hostname: raspberrypi5  , alive, uptime: 99713)
                  Core adapters versions
                  js-controller:  7.0.7
                  admin:          7.7.2
                  javascript:     8.9.2
                  nodejs modules from github:     2
                  | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                  +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : raspberrypi5                             - disabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
                  + system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             -  enabled
                    system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
                  + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi5                             -  enabled
                  + system.adapter.geofency.0               : geofency              : raspberrypi5                             -  enabled, port: 7999, bind: 0.0.0.0
                  + system.adapter.growatt.0                : growatt               : raspberrypi5                             -  enabled
                    system.adapter.habpanel.0               : habpanel              : raspberrypi5                             - disabled
                  + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
                    system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
                    system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi5                             - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi5                             -  enabled, port: 8086
                  + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
                  + system.adapter.meross.0                 : meross                : raspberrypi5                             -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi2                             -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.mqtt.1                   : mqtt                  : raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
                  + system.adapter.node-red.0               : node-red              : raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
                    system.adapter.openweathermap.0         : openweathermap        : raspberrypi5                             -  enabled
                  + system.adapter.pushover.0               : pushover              : raspberrypi5                             -  enabled
                  + system.adapter.reolink.0                : reolink               : raspberrypi5                             -  enabled
                  + system.adapter.reolink.1                : reolink               : raspberrypi5                             -  enabled
                    system.adapter.samsung.0                : samsung               : raspberrypi5                             - disabled
                    system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi5                             - disabled, port: 8002
                  + system.adapter.scenes.0                 : scenes                : raspberrypi5                             -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
                    system.adapter.smartthings.0            : smartthings           : raspberrypi5                             - disabled
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi2                             -  enabled, port: 1889, bind: 0.0.0.0
                  + system.adapter.statistics.0             : statistics            : raspberrypi5                             -  enabled
                  + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : raspberrypi5                             -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi5                             -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
                  + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
                    system.adapter.yr.0                     : yr                    : raspberrypi5                             -  enabled
                  + system.adapter.zigbee2mqtt.1            : zigbee2mqtt           : raspberrypi5                             -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: stable
                  Adapter    "admin"        : 7.7.2    , installed 7.7.2
                  Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                  Adapter    "devices"      : 1.2.8    , installed 1.2.8
                  Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                  Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                  Adapter    "growatt"      : 3.3.1    , installed 3.3.1
                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                  Adapter    "ical"         : 1.16.2   , installed 1.16.2
                  Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                  Controller "js-controller": 7.0.7    , installed 7.0.7
                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                  Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                  Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                  Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                  Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                  Adapter    "shelly"       : 10.2.0   , installed 10.1.0 [Updatable]
                  Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                  Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                  Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                  Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                  Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Adapter    "ws"           : 2.6.2    , installed 3.0.19
                  Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                  Adapter    "yr"           : 5.3.0    , installed 5.3.0
                  Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
                  Objects and States
                  Objects:        14307
                  States:         11426
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                  W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                  Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                  Get:6 https://apt.grafana.com stable InRelease [7661 B]
                  Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Hit:8 https://repo.mosquitto.org/debian bookworm InRelease
                  Err:6 https://apt.grafana.com stable InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       13481      2232/node-red
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13669      2493/io.shelly.0
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      113        5712       826/mosquitto
                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       12770      2448/io.mqtt.1
                  tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       12771      2448/io.mqtt.1
                  tcp        0      0 0.0.0.0:42545           0.0.0.0:*               LISTEN      1001       14969      2551/io.yahka.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4964       839/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          725830     76392/cupsd
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14338      2031/iobroker.js-co
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       11261      2031/iobroker.js-co
                  tcp        0      0 127.0.0.1:35259         0.0.0.0:*               LISTEN      1001       974326     2551/io.yahka.0
                  tcp6       0      0 :::1884                 :::*                    LISTEN      113        5713       826/mosquitto
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          4966       839/sshd: /usr/sbin
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          725829     76392/cupsd
                  tcp6       0      0 :::7999                 :::*                    LISTEN      1001       12219      2389/io.geofency.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11813      2082/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       15708      2768/io.web.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        10181      1440/influxd
                  tcp6       0      0 :::3000                 :::*                    LISTEN      112        13322      2030/grafana
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5597       652/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       13692      2508/io.shelly.1
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       12853      2532/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       12854      2532/io.tuya.0
                  udp        0      0 0.0.0.0:55972           0.0.0.0:*                           104        5599       652/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                104        5598       652/avahi-daemon: r
                  udp6       0      0 :::43836                :::*                                104        5600       652/avahi-daemon: r
                  udp6       0      0 fe80::201f:2fec:9bc:546 :::*                                0          10723      783/NetworkManager
                  2025-09-23 11:24:56.154  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:24:57.154  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:24:58.156  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:24:59.157  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:00.161  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:01.161  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:02.162  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:03.164  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:04.164  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:05.166  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:06.167  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:07.167  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:08.167  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:09.169  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:10.170  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:11.172  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:12.173  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:13.173  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:14.173  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:15.175  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:16.176  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:17.177  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:18.178  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:19.179  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  2025-09-23 11:25:20.180  - warn: zigbee2mqtt.1 (29444) Start try again in 1 seconds...
                  iob diag has finished.
                  Mico
                    Da ist die Spannungsversorgung zu knapp.
                    Betreib die Kiste ohne graphische Oberfläche.
                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs engineering@grafana.com
                    Leg das Grafana-Repository neu an.
                    Zu zigbee2mqtt:
                    systemctl status zigbee2mqtt
                    sagt?
                      @thomas-braun said in zigbee2mqtt läuft sein heute morgen nicht mehr:
                      Grafana nutze ich gar nicht wirklich hatte dieses nur mitinstaliert brauche ich bisher nicht.
                      pi@raspberrypi5:/opt/zigbee2mqtt $ systemctl status zigbee2mqtt
                      ● zigbee2mqtt.service - zigbee2mqtt
                           Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
                           Active: active (running) since Tue 2025-09-23 11:59:07 CEST; 44s ago
                         Main PID: 131911 (node)
                            Tasks: 11 (limit: 9572)
                              CPU: 3.211s
                           CGroup: /system.slice/zigbee2mqtt.service
                                   └─131911 /usr/bin/node index.js
                      Sep 23 11:59:07 raspberrypi5 systemd[1]: Started zigbee2mqtt.service - zigbee2mqtt.
                      Sep 23 11:59:10 raspberrypi5 node[131911]: [2025-09-23 11:59:10] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Keller', payload '{"child_lock":"UNLOCK","countdown":0,"current":0,"energy":0,"indicator_mode":"off/on","linkquality":80,"power":0,"power_o>
                      Sep 23 11:59:19 raspberrypi5 node[131911]: [2025-09-23 11:59:19] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SNZB-02 Gästezimmer', payload '{"battery":100,"humidity":71.5,"linkquality":131,"temperature":18.08,"voltage":3000}'
                      Sep 23 11:59:25 raspberrypi5 node[131911]: [2025-09-23 11:59:25] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Mückensteckdose', payload '{"child_lock":"UNLOCK","current":0.02,"energy":3.39,"indicator_mode":"off","linkquality":29,"power":3,"power_outage_memory>
                      Sep 23 11:59:26 raspberrypi5 node[131911]: [2025-09-23 11:59:26] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fernseherleiste', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.24,"energy":88.88,"indicator_mode":"off/on","linkquality":138,"power":28,>
                      Sep 23 11:59:26 raspberrypi5 node[131911]: [2025-09-23 11:59:26] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fernseherleiste', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.24,"energy":90.27,"indicator_mode":"off/on","linkquality":138,"power":28,>
                      Sep 23 11:59:26 raspberrypi5 node[131911]: [2025-09-23 11:59:26] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IR-Licht Steuerung-01', payload '{"countdown":0,"current":0,"energy":1.92,"indicator_mode":"off","linkquality":80,"power":0,"state":"OFF","update":{">
                      Sep 23 11:59:28 raspberrypi5 node[131911]: [2025-09-23 11:59:28] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SNZB-02 Bad', payload '{"battery":100,"humidity":78.68,"linkquality":80,"temperature":21.74,"voltage":3000}'
                      Sep 23 11:59:33 raspberrypi5 node[131911]: [2025-09-23 11:59:33] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Wasch-Küche', payload '{"child_lock":"UNLOCK","current":0,"energy":6.32,"indicator_mode":"off","linkquality":80,"power":0,"power_outage_mem>
                      Sep 23 11:59:48 raspberrypi5 node[131911]: [2025-09-23 11:59:48] info:         z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Steckdose Küche', payload '{"child_lock":"UNLOCK","countdown":0,"current":0.03,"energy":7.75,"indicator_mode":"off/on","linkquality":36,"power":3,"po>
                      lines 1-19/19 (END)
                      Was hat das zu sagen von der pnpm
                      pi@raspberrypi5:/opt/zigbee2mqtt $ sudo pnpm start
                      > zigbee2mqtt@2.6.1 start /opt/zigbee2mqtt
                      > node index.js
                      [2025-09-23 11:57:42] info:     z2m: Logging to console, file (filename: log.log)
                      [2025-09-23 11:57:43] info:     z2m: Starting Zigbee2MQTT version 2.6.1 (commit #d44463a3)
                      [2025-09-23 11:57:43] info:     z2m: Starting zigbee-herdsman (6.0.4)
                      [2025-09-23 11:57:43] info:     zh:zstack:znp: Opening TCP socket with 192.168.178.103:6638
                      [2025-09-23 11:57:43] info:     zh:zstack:znp: Socket connected
                      [2025-09-23 11:57:43] info:     zh:zstack:znp: Socket ready
                      [2025-09-23 11:57:43] info:     zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
                      [2025-09-23 11:57:44] info:     zh:zstack:znp: Skip bootloader for CC2652/CC1352
                      [2025-09-23 11:58:10] error:    z2m: Error while starting zigbee-herdsman
                      [2025-09-23 11:58:10] error:    z2m: Failed to start zigbee-herdsman
                      [2025-09-23 11:58:10] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
                      [2025-09-23 11:58:10] error:    z2m: Exiting...
                      [2025-09-23 11:58:10] error:    z2m: TypeError: Cannot read properties of undefined (reading 'payload')
                          at AdapterNvMemory.readExtendedTableEntry (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:219:30)
                          at processTicksAndRejections (node:internal/process/task_queues:105:5)
                          at AdapterNvMemory.readTable (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-nv-memory.ts:365:28)
                          at AdapterBackup.getNetworkSecurityMaterialTable (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:508:20)
                          at AdapterBackup.restoreBackup (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:288:44)
                          at ZnpAdapterManager.beginRestore (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:316:9)
                          at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:78:21)
                          at ZStackAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
                          at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@6.0.4/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
                          at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:67:27)
                       ELIFECYCLE  Command failed with exit code 1.
                      Mico
                        Egal, korrigier das.
                        Schau da mal rein.
                          sudo pnpm start
                          Und da bin ich nicht sicher, ob das der richtige und beste Weg ist zigbee2mqtt zu starten.
                          Das macht man eigentlich über die systemd-Services, wenn es die ja schon gibt. Also
                          systemctl [start|stop|restart] zigbee2mqtt.service
                          arteck 1 Reply Last reply Reply Quote 1
                            arteck Developer Most Active @Thomas Braun last edited by
                            @thomas-braun ne du ist es auch nicht... das ist nur mal zum starten wenn du debug infos haben willst..
                            @Mico hier steht alles beschrieben und bitte die Seite zu ende lesen
                            https://www.zigbee2mqtt.io/guide/installation/01_linux.html#starting-zigbee2mqtt
                            1.0k
                            225
