    4. Shelly cloud in ioBroker einbinden
      ecurb @Heiko Schweder last edited by
      @heiko-schweder
      Hey Sorry das ich mich erst soooo viel später melde.
      Hat geklappt. Ich kann mir zwar nicht erklären wo die "0" bei "data.device_status.meters.0.power" herkommt aber egal hauptsache es klappt.
      Vielen dank
        benbensimpson2204 last edited by
        Nabend bräuchte mal eure Hilfe
        würde gerne den Temperaturwert aus der Shellycloud auslesen und in einem Datenpunkt speichern. Hier mein Blockly
        hier der output
        javascript.0	23:06:18.523	info	script.js.common.test.shellycloud: {"isok":true,"data":{"online":true,"device_status":{"ts":1735941967.78,"_updated":"2025-01-03 22:06:08","input:1":{"id":1,"state":false},"serial":3550,"id":"XXXXXXXXXXXX","v_eve:1":{"ev":"","ttl":-1,"id":1},"input:0":{"id":0,"state":false},"wifi":{"sta_ip":"192.168.1.135","status":"got ip","ssid":"RUT241_77A7","rssi":-24},"addons":["temperature:100","voltmeter:100"],"temperature:100":{"id":100,"errors":[],"tC":6.81,"tF":44.26},"input:2":{"id":2,"counts":{"by_minute":[0,0,0],"minute_ts":1735941900,"total":0},"freq":0},"ws":{"connected":false},"sys":{"webhook_rev":109,"mac":"CC7B5C880810","restart_required":false,"time":"04:01","unixtime":1735873286,"uptime":330882,"ram_size":267904,"ram_free":109720,"fs_size":393216,"fs_free":102400,"cfg_rev":48,"kvs_rev":0,"schedule_rev":6,"available_updates":{},"reset_reason":1},"mqtt":{"connected":false},"v_eve:0":{"ev":"","ttl":-1,"id":0},"v_eve:2":{"ev":"","ttl":-1,"id":2},"voltmeter:100":{"id":100,"voltage":12.49,"errors":[]},"switch:0":{"id":0,"output":false,"source":"timer"},"code":"SNSN-0043X","cloud":{"connected":true},"switch:1":{"id":1,"output":false,"source":"timer"},"ble":{}}}}
        javascript.0	23:06:18.523	info	script.js.common.test.shellycloud: TempC
        leider bekomme ich kein wert raus, und weiß jetzt auch nicht mehr weiter
          Alexvoell @benbensimpson2204 last edited by
          @benbensimpson2204
          Ich bekomme auch kein Werte heraus beim Shelly Aussentempfühler kann mir bitte jemand helfen
          A da_Woody 2 Replies Last reply Reply Quote 0
            Alexvoell @Alexvoell last edited by
            @alexvoell said in Shelly cloud in ioBroker einbinden:
            @benbensimpson2204
              @benbensimpson2204
              • da_Woody
                da_Woody @Alexvoell last edited by
                @alexvoell sagte in Shelly cloud in ioBroker einbinden:
                @benbensimpson2204
                was für einen fühler meinst du denn?
                hab beim pool einen shelly+1pm mit addon und hab im adapter und ioB alle werte drinnen.
                  Alexvoell @da_Woody last edited by
                  @da_woody Vielen Dank, aber ich kann nur über ein anderes Netzwerk auf diese Sensor zugreifen, benötige des wegen den Cloud-Zugang zwecks Logging der Temperatur über das komplette Jahr.f70b1f10-cb07-42b3-ab44-3ce504ee7c01-image.png
                  • da_Woody
                    @alexvoell abgesehn davon, daß dein sensor ein update will.
                    via VPN solltest du ja auf diesen "fühler" zugreifen können in einem anderen netzwerk per IP.
                    nach 10x lesen glaube ich dein problem zu erkennen! 🤡
                    du siehst zwar in der APP die werte,
                    die gibts aber im adapter nicht.
                    IMHO müsstest du das z.b. in influxdb loggen und dann selbst berechnen.
                      @da_woody Hallo, vielen Dank für die Unterstützung bzw. den Versuch zu helfen.
                      Ich möchte den Sensor aus der Ferne – ohne VPN – über die Cloud auslesen und die Daten dort auch loggen.
                      Das Logging an sich ist mir soweit klar.
                      Allerdings wird der Sensor, wie im ursprünglichen Beitrag beschrieben, nicht in der Cloud ausgelesen und IOBroker mit der richtigen Temp angezeigt, und ich verstehe nicht, woran das liegt.
                      • da_Woody
                        @alexvoell du bist da in einem tread wo es um lokales netz geht.
                        ich glaube nicht, daß du aus der cloud was auslesen kannst. kenn mich da zuwenig aus, denke, die API gibt das nicht her...
                        hab ein ähnliches problem. möchte meine shelly 1pm heizung (infrarot) via shelly dw steuern.
                        die heizungskurven in der APP kann ich nicht ansprechen. (on/off) einzige möglichkeit, über alexa umwege um wenigstens die temperatur zu regeln.
                        A 2 Replies Last reply Reply Quote 0
                          @da_woody sagte in Shelly cloud in ioBroker einbinden:
                          shelly dw
                          ja lese den Beitrag von oben scheinbar geht das ich kann die Verbindung über die ID auch herstellen aber keine Werte Temperatur lesen
                            @da_woody Das müsste doch in der Shelly App über Szene gehen, was du da vor hast.
                            • da_Woody
                              @alexvoell das ja, aber eben nicht im ioB und somit auch nicht über mene iQontrol visu.
                                benbensimpson2204 @Alexvoell last edited by
                                @alexvoell mit der cloud ging es bei mir auch nicht
                                hole mir die daten jetzt per mqtt. der shelly schickt seine daten an hivemq und da hole ich sie per mqtt ab
                                81.1k
                                iobroker shelly cloud
                                4803
