    4. docker container startet nicht unter proxmox 9
      astrakid last edited by
      hi,
      hab einen frischen server mit proxmox 9 aufgesetzt. darunter docker-ce installiert, nun iobroker per docker-compose.yml gestartet.
      docker-compose.yml:
      services:
        iobroker:
          container_name: iobroker
          image: buanet/iobroker
          hostname: iobroker
          restart: always
          ports:
            - "8081:8081"
          volumes:
            - iobrokerdata:/opt/iobroker
          environment:
            - TZ=Europe/Berlin
            - DEBUG=yes
      #    devices:
      #      - /dev/ttyUSB0:/dev/ttyUSB0
      volumes:
        iobrokerdata:
      der start über
      docker compose up -d
      schlägt aber fehl. output:
      iobroker  | --------------------------------------------------------------------------------
      iobroker  | -----                    Step 5 of 5: ioBroker Startup                     -----
      iobroker  |
      iobroker  | Starting ioBroker...
      iobroker  |
      iobroker  | ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      iobroker  | Error while calling "getconf CLK_TCK" Error: spawn /bin/sh EACCES
      iobroker  |     at ChildProcess._handle.onexit (node:internal/child_process:285:19)
      iobroker  |     at onErrorNT (node:internal/child_process:483:16)
      iobroker  |     at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
      iobroker  |   errno: -13,
      iobroker  |   code: 'EACCES',
      iobroker  |   syscall: 'spawn /bin/sh',
      iobroker  |   path: '/bin/sh',
      iobroker  |   spawnargs: [ '-c', 'getconf CLK_TCK' ],
      iobroker  |   cmd: 'getconf CLK_TCK'
      iobroker  | }
      iobroker  | read ENOTCONN
      iobroker  | Error: read ENOTCONN
      iobroker  |     at tryReadStart (node:net:716:20)
      iobroker  |     at Socket._read (node:net:731:5)
      iobroker  |     at Readable.read (node:internal/streams/readable:739:12)
      iobroker  |     at Socket.read (node:net:785:39)
      iobroker  |     at new Socket (node:net:494:12)
      iobroker  |     at Object.Socket (node:net:363:41)
      iobroker  |     at createSocket (node:internal/child_process:335:14)
      iobroker  |     at ChildProcess.spawn (node:internal/child_process:450:23)
      iobroker  |     at spawn (node:child_process:786:9)
      iobroker  |     at Object.execFile (node:child_process:349:17)
      hat jemand eine idee, was das ist? hab schon gesucht, aber nichts passendes gefunden.
      gruß,
      andre
        astrakid @astrakid last edited by
        hier das komplette startlog:
        iobroker  | -------------------------     2025-09-24 16:42:38      -------------------------
        iobroker  | -----        -----
        iobroker  | ----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
        iobroker  | ----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
        iobroker  | ----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
        iobroker  | ----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
        iobroker  | ----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
        iobroker  | ----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
        iobroker  | -----              Welcome to your ioBroker Docker container!              -----
        iobroker  | -----                    Startupscript is now running!                     -----
        iobroker  | -----                          Please be patient!                          -----
        iobroker  |
        iobroker  | -----                          System Information                          -----
        iobroker  | -----                    arch:                x86_64                       -----
        iobroker  | -----                    hostname:            iobroker                     -----
        iobroker  | -----                          Version Information                         -----
        iobroker  | -----                    image:               v11.0.0                      -----
        iobroker  | -----                    build:               20250912.234259              -----
        iobroker  | -----                    node:                v22.19.0                     -----
        iobroker  | -----                    npm:                 10.9.3                       -----
        iobroker  | -----                        Environment Variables                         -----
        iobroker  | -----                    DEBUG:               yes                          -----
        iobroker  | -----                    SETGID:              1000                         -----
        iobroker  | -----                    SETUID:              1000                         -----
        iobroker  |
        iobroker  | -----                   Step 1 of 5: Preparing Container                   -----
        iobroker  |
        iobroker  |
        iobroker  |
        iobroker  | -----             Step 2 of 5: Detecting ioBroker Installation             -----
        iobroker  |
        iobroker  | Existing installation of ioBroker detected in "/opt/iobroker".
        iobroker  |
        iobroker  | -----             Step 3 of 5: Checking ioBroker Installation              -----
        iobroker  |
        iobroker  | (Re)setting permissions (This might take a while! Please be patient!)... Done.
        iobroker  |
        iobroker  | Checking database connection... Done.
        iobroker  |
        iobroker  | Hostname in ioBroker matches the hostname of this container.
        iobroker  | No action required.
        iobroker  |
        iobroker  | -----                Step 4 of 5: Applying Special Settings                -----
        iobroker  |
        iobroker  | Some adapters have special requirements/ settings which can be activated by the use of environment variables.
        iobroker  | For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
        iobroker  |
        iobroker  |
        iobroker  |
        iobroker  | }
        • OliverIO
          OliverIO @astrakid last edited by
          @astrakid sagte in docker container startet nicht unter proxmox 9:
          das liegt höchst wahrscheinlich daran, das du dadurch eine verschachtelte virtualisierung erzeugst. also die virtualisierung in einer virtualisierung hat weniger rechte.
          schau mal ob du da was dazu in proxmox konfigurieren kannst.
          A MartinP 2 Replies Last reply Reply Quote 0
            astrakid @OliverIO last edited by
            @oliverio sagte in docker container startet nicht unter proxmox 9:
            innerhalb des OS habe ich docker direkt installiert und gestartet, nicht in einem LXC oder einer VM. und als benutzer root (ich weiß, nicht optimal).
            • MartinP
              MartinP @OliverIO last edited by
              Da fehlt mir die Beschreibung des "Zwischenbaus"
              Auf einem Proxmox System sollte man nur LXC-Container und virtuelle Maschinen installieren...
              docker-ce direkt auf dem PVE Muttersystem installieren schafft Verdruss...
              Wenn Du eine VM aufgesetzt hast oder einen LXC Container, in dem dann wiederum docker läuft:
              Was ist denn die Ausgabe, wenn Du als normaler User in der VM / dem LXC dies hier eintippst:
              marrtin@iobroker-test-sicher:/opt/iobroker$ getconf CLK_TCK
              100
                astrakid @MartinP last edited by
                @martinp sagte in docker container startet nicht unter proxmox 9:
                getconf CLK_TCK
                funktioniert sogar aus dem iobroker-container heraus:
                • MartinP
                  MartinP @astrakid last edited by MartinP
                  @astrakid Du hast also docker direkt im Hypervisor installiert?
                  Etwas direkt im Hypervisor installieren ist schlechter Stil ...
                  https://www.reddit.com/r/Proxmox/comments/1cluao4/whats_the_best_way_to_run_docker_in_proxmox/
                  EDIT: ich sehe gerade "root"
                  Unter welchem User ist denn das Installationsskript gelaufen?
                  OliverIO A 2 Replies Last reply Reply Quote 0
                  • OliverIO
                    OliverIO @MartinP last edited by
                    im link steht was von, das es die netzwerkfähigkeiten von proxmox zerstört.
                    wahrscheinlich wenn man irgendwas mit macvlan oder ipvlan verwenden will, da dann ein eigener treiber genutzt wird.
                    ich dachte proxmox sei ein geschlossenes system/betriebssystem. da dann noch was auf oberster ebene zu installieren dürfte doch dann beim nächsten update ebenfalls schwierigkeiten geben.
                    • Codierknecht
                      Codierknecht Developer Most Active @astrakid last edited by
                      Das ist mehr als nur "nicht optimal". Als root zerschießt Du Dir die Rechte.
                      Darum fummelt mal niemals als root im System rum.
                      Und was Docker auf Proxmox angeht, schließe ich mich den anderen an.
                      Proxmox ist eine Virtualisierungslösung - Docker eine andere. Die beiden zu kombinieren ist vermutlich auch mehr als nur "schlechter Stil".
                      Bei mir läuft ioBroker als LXC. Mit 2 Kernen und 8 GB RAM. Einwandfrei.
                      OliverIO 1 Reply Last reply Reply Quote 1
                      • OliverIO
                        OliverIO @Codierknecht last edited by
                        @codierknecht
                        Es funktioniert, von proxmox wird für Docker allerdings eine vm empfohlen, ein lxc Container soll aber auch funktionieren.
                        Alle virtualisierten Prozesse laufen im Endeffekt parallel auf dem Prozessor, egal wie tief verschachtelt wurde.
                          astrakid @MartinP last edited by astrakid
                          ich hab iobroker über ein docker compose File gebaut, alles als root. Der Rest läuft im docker Container ab.
                          Proxmox ist kein hypervisor, proxmox ist eigentlich nur eine Verwaltungsschicht, das OS ist Debian. Proxmox verwaltet lxc Container und kvm. Alles in einer schicken Oberfläche. Dass docker die Netzwerkkonfiguration von proxmox beeinflusst halte ich für ein Gerücht
                          Ich habe selbst proxmox 8 mit docker im Hostsystem laufen, u.a. auch iobroker. Reibungslos, inkl. Durchreichen eines zigbee USB Sticks.
                          Ich halte die containerisierung innerhalb eines Containers für widersinnig. Der Vorteil ist klar, dass man dann alles innerhalb der proxomox Verwaltung liegen hat.
                          Mir geht es jetzt nur darum, den Fehler zu beheben.
                          Unter root zu arbeiten ist unvernünftig, das weiss ich. Das ist aber ein Sicherheitsthema.
                          110
