    4. JavaScript
    5. Zendure SmartMode:1 SolarFlow2400 AC SolarFlow800 ( u. Pro)
    • maxclaudi
      maxclaudi @Daniel 8 last edited by maxclaudi
      @daniel-8
      sieht gut aus
        "timestamp": 1758649975,
        "messageId": 25,
        "sn": "EXXXXXXXXXXXXX0",
        "version": 2,
        "product": "solarFlow800Pro",
        "properties": {
          "heatState": 0,
          "packInputPower": 0,
          "outputPackPower": 0,
          "outputHomePower": 0,
          "remainOutTime": 59940,
          "packState": 0,
          "electricLevel": 15,
          "gridInputPower": 0,
          "solarInputPower": 0,
          "solarPower1": 0,
          "solarPower2": 0,
          "solarPower3": 0,
          "solarPower4": 0,
          "pass": 0,
          "reverseState": 0,
          "socStatus": 0,
          "hyperTmp": 2881,
          "gridOffPower": 0,
          "dcStatus": 0,
          "pvStatus": 1,
          "acStatus": 0,
          "dataReady": 1,
          "gridState": 1,
          "BatVolt": 4947,
          "socLimit": 2,
          "writeRsp": 0,
          "acMode": 2,
          "inputLimit": 0,
          "outputLimit": 0,
          "socSet": 1000,
          "minSoc": 200,
          "gridStandard": 0,
          "gridReverse": 1,
          "inverseMaxPower": 800,
          "lampSwitch": 0,
          "gridOffMode": 2,
          "IOTState": 2,
          "Fanmode": 1,
          "Fanspeed": 0,
          "bindstate": 0,
          "factoryModeState": 0,
          "OTAState": 0,
          "LCNState": 0,
          "oldMode": 0,
          "VoltWakeup": 0,
          "ts": 1758649841,
          "tsZone": 14,
          "smartMode": 1,
          "chargeMaxLimit": 1000,
          "packNum": 2,
          "rssi": -75,
          "is_error": 0
        "packData": [
            "sn": "COXXXXXXXXXXXX9",
            "packType": 300,
            "socLevel": 15,
            "state": 0,
            "power": 0,
            "maxTemp": 2861,
            "totalVol": 4930,
            "batcur": 0,
            "maxVol": 329,
            "minVol": 328,
            "softVersion": 4117
            "sn": "COXXXXXXXXXXXX7",
            "packType": 300,
            "socLevel": 15,
            "state": 0,
            "power": 0,
            "maxTemp": 2851,
            "totalVol": 4910,
            "batcur": 0,
            "maxVol": 328,
            "minVol": 327,
            "softVersion": 4117
      maxTemp: 2851 -> 14,95°C. ist bestimmt outside.
        @maxclaudi
        was meinst mit sieht gut aus?
        maxclaudi 1 Reply Last reply Reply Quote 0
        • maxclaudi
          @daniel-8 sagte in Zendure SmartMode:1 SolarFlow2400 AC SolarFlow800 ( u. Pro):
          @maxclaudi
          dass json quasi genau so aufgebaut ist, wie bisher auch (mqtt, alte Geräte).
          Leicht auszuwerten 🙂
          eigentlich nur properties und Akku(s) -> packData array.
            Daniel 8 @maxclaudi last edited by
            @maxclaudi
            Wenn du mir vielleicht noch verrätst wie?
            Danke für das Blockly mit curl. Funktioniert 1A
              Michi 0 @maxclaudi last edited by
              @maxclaudi
              Ihr habt ein Tempo...
              Mir würde vermutlich reichen, wenn mir der SmartMode Status in einem Datenpunkt angezeigt wird und ich den kontrollieren und steuern kann. Den Rest würde ich vermutlich auch weiterhin nur über MQTT machen.
              Alternativ:
              Alle über MQTT abrufbaren Datenpunkte und den SmartMode Datenpunkt in einem Adapter zusammenfassen. Keine Ahnung was das für einen Aufwand macht. Adpater zu erstellen hat für mich was von schwarzer Magie 😉
              D maxclaudi 3 Replies Last reply Reply Quote 0
                Daniel 8 @Michi 0 last edited by
                @michi-0
                Ist nur weil ich grad nichts machen kann und mit Bänderiss im Fuß nur rumsitzen kann. Deswegen habe ich soviel Zeit gerade
                • maxclaudi
                  maxclaudi @Michi 0 last edited by
                  @michi-0 @Daniel-8
                  Sorry muss früh raus.
                  • maxclaudi
                    maxclaudi @Michi 0 last edited by maxclaudi
                    @michi-0 sagte in Zendure SmartMode:1 SolarFlow2400 AC SolarFlow800 ( u. Pro):
                    @maxclaudi
                    Zendure hat auch angekündigt, dass sie den Datenpunkt irgendwann auch aufnehmen werden, dann wäre alles andere überflüssig.
                    Aber wenn nicht oder bis dahin hier die Lösungen.
                    2 Scripte, die von den Funktionen identisch sind.
                    Script 1: nur für iob unter Linux.
                    Srcipt 2: plattformunabhängig, also auch für Windows.
                    @Daniel-8 und @Michi-0 , bitte testen:
                    Beschreibung für beide scripts:
                    Script hat folgende Funktion:
                    • Alle 60 Sekunden (anpassbar) wird properties/report geholt.
                    • timestamp wird in ein lesbares Datum umgewandelt und in dpTimestamp geschrieben.
                    • Aktueller smartMode wird in dpSmartModeInfo geschrieben (read only).
                    • Wenn man setSmartMode mit 0 oder 1 steuert, sendet das Script automatisch einen POST an /properties/write und schreibt "ok" oder "error" in setResult.
                    Beim Start werden vier Datenpunkte erstellt.
                    Diese können oben im script konfiguriert werden.
                    const dpSmartModeInfo = "0_userdata.0.zendureSmartMode.smartModeInfo";
                    const dpSetSmartMode = "0_userdata.0.zendureSmartMode.setSmartMode";
                    const dpSetSmartModeResult = "0_userdata.0.zendureSmartMode.setResult";
                    const dpTimestamp = "0_userdata.0.zendureSmartMode.timestamp";
                    60 Sekunden Interval ist unkritisch und aktuell.
                    Bei Bedarf kann das auch oben im Script geändert werden:
                    const intervalGet = 60; // Sekunden
                    Oben trägt man auch die IP und Seriennummer des Zendure Geräts ein:
                    const IP = "192.168.177.103"; // IP Zendure
                    const SN = "EXXXXXXXXXXXXX0"; // Seriennummer Zendure
                    Die Datenpunkte können mit anderen scripts / Blocklys gelesen werden oder dpSetSmartMode auf 1 oder 0 gesetzt werden.
                    smartMode:1 ist wichtig.
                    Script 1, mit curl umgesetzt, funktioniert nur wenn iob auf Linux läuft:
                    // konfiguration
                    const IP = "192.168.177.103";           // IP des Zendure Geräts
                    // dp anlegen
                    createState(dpSmartModeInfo, 0, {
                        type: "number",
                        role: "state",
                        read: true,
                        write: false,
                        min: 0,
                        max: 1
                    createState(dpSetSmartMode, 0, {
                        type: "number",
                        role: "state",
                        read: true,
                        write: true,
                        min: 0,
                        max: 1
                    createState(dpSetSmartModeResult, "", {
                        name: "SmartMode Set Result",
                        type: "string",
                        role: "info",
                        read: true,
                        write: false
                    createState(dpTimestamp, "", {
                        type: "string",
                        role: "info",
                        read: true,
                        write: false
                    // time
                    function formatTime(ts) {
                        // ts ist Unix Sekunden
                        const d = new Date(ts * 1000);
                        const pad = n => n.toString().padStart(2, "0");
                        return `${pad(d.getDate())}.${pad(d.getMonth()+1)}.${d.getFullYear().toString().slice(-2)} ${pad(d.getHours())}:${pad(d.getMinutes())}:${pad(d.getSeconds())}`;
                    //curl HTTP GET
                    function getReport() {
                        const cmd = `curl -s "http://${IP}/properties/report"`;
                        exec(cmd, (error, stdout, stderr) => {
                            if (error) {
                                console.error("GET Fehler:", stderr);
                                return;
                            try {
                                const data = JSON.parse(stdout);
                                if (data && data.timestamp) {
                                    setState(dpTimestamp, formatTime(data.timestamp), true);
                                if (data && data.properties && typeof data.properties.smartMode !== "undefined") {
                                    setState(dpSmartModeInfo, data.properties.smartMode, true);
                            } catch (e) {
                                console.error("JSON Parse Fehler:", e);
                    //curl HTTP POST zum Setzen
                    function setSmartMode(val) {
                        const payload = `{"sn":"${SN}","properties":{"smartMode":${val}}}`;
                        const cmd = `curl -s -X POST "http://${IP}/properties/write" -H "Content-Type: application/json" -d '${payload}'`;
                            if (error) {
                                console.error("POST Fehler:", stderr);
                                setState(dpSetSmartModeResult, "error", true);
                                return;
                            setState(dpSetSmartModeResult, "ok", true);
                    // interval
                    getReport();  // sofort bei start
                    schedule(`*/${intervalGet} * * * * *`, getReport); // alle x Sekunden
                    // trigger wenn SmartMode gesetzt wird
                    on({id: dpSetSmartMode, ack: false}, obj => {
                        const val = parseInt(obj.state.val, 10);
                        if (val === 0 || val === 1) {
                            setSmartMode(val);
                    Script 2:
                    Funktionen identisch zum ersten.
                    Skript ist plattformunabhängig und sollte damit für Windows-Installationen von ioBroker funktionieren (ungetestet).
                    Statt curl werden ioBroker/Node.js vorhandene Standardbibliotheken (http und https) verwendet.
                    // konfiguration
                    const http = require("http");           // Node.js Standardmodul
                    // dp
                        type: "number",
                        role: "state",
                        read: true,
                        write: false,
                        min: 0,
                        max: 1
                        type: "number",
                        role: "state",
                        read: true,
                        write: true,
                        min: 0,
                        max: 1
                        type: "string",
                        role: "info",
                        read: true,
                        write: false
                        type: "string",
                        role: "info",
                        read: true,
                        write: false
                    // time
                    //HTTP GET
                        const options = {
                            hostname: IP,
                            port: 80,
                            path: "/properties/report",
                            method: "GET",
                            timeout: 3000
                        const req = http.request(options, res => {
                            let data = "";
                            res.on("data", chunk => data += chunk);
                            res.on("end", () => {
                                try {
                                    const json = JSON.parse(data);
                                    if (json.timestamp) {
                                        setState(dpTimestamp, formatTime(json.timestamp), true);
                                    if (json.properties && typeof json.properties.smartMode !== "undefined") {
                                        setState(dpSmartModeInfo, json.properties.smartMode, true);
                                } catch (e) {
                                    console.error("GET JSON Parse Fehler:", e);
                        req.on("error", err => console.error("HTTP GET Fehler:", err.message));
                        req.end();
                    //HTTP POST zum Setzen
                        const payload = JSON.stringify({
                            sn: SN,
                            properties: { smartMode: val }
                        const options = {
                            hostname: IP,
                            port: 80,
                            path: "/properties/write",
                            method: "POST",
                            headers: {
                                "Content-Type": "application/json",
                                "Content-Length": Buffer.byteLength(payload)
                            timeout: 3000
                            let data = "";
                                if (res.statusCode >= 200 && res.statusCode < 300) {
                                } else {
                                    console.error("POST Antwort:", res.statusCode, data);
                        req.on("error", err => {
                            console.error("HTTP POST Fehler:", err.message);
                        req.write(payload);
                        req.end();
                    // interval
                    getReport();  // sofort einmal abrufen
                            setSmartMode(val);
                    Hinweis: Bei den Scripts wird davon ausgegangen, dass Zendure für HTTP den Standarport 80 verwendet wie von @Daniel-8 getestet.
                    Wenn es bei jemand nicht so sein sollte, dann im script die 2 Port (port: 80,) bei Get und POST anpassen.
                    D M Rene55 3 Replies Last reply Reply Quote 1
                      @maxclaudi
                      Vielen Dank für die Scripte. Werde ich die Tage mal testen.
                      Sehr bewundernswert was du da auf die schnelle mal schreibst.
                      Schreibst du das alles so händisch oder baust du das auch mit art blockly zusammen?
                      • maxclaudi
                        @daniel-8
                        vscode nutze ich dafür und ja, händisch. Ab und zu, dann schon copy paste von meinen vorhandenen Funktionen.
                        blockly dann auch wieder händisches geklicke und umschreiben.
                          @maxclaudi
                          Respekt. Das werde ich wohl nicht mehr lernen.
                          Ich werde wohl bei blockly bleiben für meine Zwecke.
                          Vielen Dank für deine Unterstützung.
                          Ja das hat mir zendure auch geschrieben das sie den Datenpunkt irgendwann aufnehmen wollen.
                            @maxclaudi
                            Es läuft!! Hab ioBroker auf einem Proxmox Host unter Linux laufen.
                            Hab´s grad eingebunden. Datenpunkte wie beschrieben angelegt und auch sofort befüllt. Ich konnte mit SetSmartMode den DP smartMode ändern.
                            Vielen Dank! Echt klasse das Du dich hier so für die Probleme Anderer engagierst.
                            Jetzt kann ich das Ding regeln lassen bis zum umfallen 😉
                              @michi-0
                              Hast du denn schon ein regelungsscript oder blockly gemacht?
                                Michi 0 @Daniel 8 last edited by
                                @daniel-8
                                Regelungsskript hatte ich schon. Da bei mir aber der Smartmode bereits auf 1 stand, werde ich dort erstmal nichts ändern und mir nur ne Mitteilung schicken lassen, wenn der Smartmode geändert werden sollte...
                                  Daniel 8 last edited by Daniel 8
                                  @daniel-8
                                  Bei mir stand er auf 0. Hatte ihn dann vorgestern auf 1 gesetzt. Gerade habe ich geschaut da stand er leider wieder auf 0. Ich habe ihn aus hems raus und hakt als Gerät in der App. Aber die sollte ja nicht einfach dann den smartmode ändern wenn ich keinerlei Einstellungen mache. Sehr merkwürdig.
                                  Mit dem shelly hatte ich auch erst Probleme. Der regelte nicht mehr und ich nahm ihn dann in der zendure app raus und lernte ihn neu an und dann war die mqtt Einstellung im shelly deaktiviert.
                                  Würdest du denn das Script mit uns teilen?
                                  Ich habe auch schon mal angefangen aber da hatte ich einige Probleme. Du hast ja nen 2400 ac oder?
                                    @maxclaudi
                                    Ich habe es gerade eben getestet. Das setzten beim ersten mal hat prima funktioniert.
                                    Kann es sein, wenn aber der SmartmodeInfo auf 0 springt warum auch immer wie bei mir heute morgen und der setSmartMode noch auf 1 steht, das dann das Script ihn nicht wieder auf 1 setzt? Ich musste dann set erst auf 0 und dann wieder auf 1 machen.
                                    M maxclaudi 2 Replies Last reply Reply Quote 0
                                    • Rene55
                                      Rene55 @maxclaudi last edited by
                                      @maxclaudi Ich vermute mal, das Script läuft wirklich nur gegen SolarFlow2400 AC / SolarFlow 800 und nicht gegen den HUB 1200 ? Da geht es nur via MQTT .
                                        @daniel-8
                                        Das Prüfe ich heute Abend. Ich meine ich habe das Skript von Rene55. Bin mir da aber nicht sicher. Zumindest nimmt mein Skript keine Regelung bezüglich dem SmartMode vor. Von daher ist es zumindest gestern Abend immer auf der gleichen Einstellung (SmartMode 1) geblieben.
                                        Rene55 D 2 Replies Last reply Reply Quote 0
                                        • Rene55
                                          Rene55 @Michi 0 last edited by
                                          @michi-0 Das halte ich für Unwahrscheinlich. Ich habe nur Script-Bruchstücke - nichts vernünftiges.
                                            Daniel 8 @Michi 0 last edited by Daniel 8
                                            @daniel-8
                                            Ich habe halt mal mit meinem anderen Script den Smartmode auf 0 gesetzt und dann Bleibt er eben auf 0 bis ich den SetSmartMode einmal ändere.
                                            Was mir noch auffiel, der Wert wird jede Minute als aktualisiert angezeigt obwohl ich das interval auf 200 gestellt habe. Wenn ich unter 60 gehe dann geht es.
                                            3295
