    4. Tester wanted - Zigbee Adapter 3.1
      dimaiv @Asgothian last edited by
      @asgothian
      Oben eingefügt.
      • Asgothian
        Asgothian Developer @dimaiv last edited by Asgothian
        @dimaiv Patch mal bitte bei Dir die Datei
        /opt/iobroker/node-modules/iobroker.zigbee/lib/zbDeviceEvevnt.js
        von
                if (mappedDevice && mappedDevice.onEvent && eventData.data) {
                    this.warn(`calling onEvent for ${eventData.type} on ${device.ieeeAddr}`);
                    mappedDevice.onEvent({type, data});
        module.exports = DeviceEvent;
        zu
                    try {
                    catch (error)
                        this.warn(`error in onEvent: ${error && error.message ? error.message : 'no details'}`);
        Der eigentliche Fehler kommt aus dem Konverter.
        A.
          @asgothian
          Gleiche Fehler
          2025-09-24 23:03:33.936 - info: zigbee.0 (298385) 20 devices are part of the network
          2025-09-24 23:03:33.938 - info: zigbee.0 (298385) Zigbee started
          2025-09-24 23:03:33.971 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
          2025-09-24 23:03:33.986 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
          2025-09-24 23:03:33.993 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
          2025-09-24 23:03:33.995 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
          2025-09-24 23:03:33.996 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
          2025-09-24 23:03:33.999 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
          2025-09-24 23:03:34.000 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
          2025-09-24 23:03:34.022 - error: zigbee.0 (298385) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-09-24 23:03:34.022 - error: zigbee.0 (298385) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
          2025-09-24 23:03:34.169 - error: zigbee.0 (298385) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
          at onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:678:58)
          at Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:376:27)
          at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:71:30)
          at processTicksAndRejections (node:internal/process/task_queues:95:5)
          at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:13:13)
          at async Promise.all (index 2)
          2025-09-24 23:03:34.169 - error: zigbee.0 (298385) Cannot read properties of undefined (reading 'measurement_poll_interval')
          2025-09-24 23:03:34.285 - info: zigbee.0 (298385) Halting zigbee adapter. Restart delay is at least 30 seconds.
          2025-09-24 23:03:34.286 - info: zigbee.0 (298385) cleaning everything up
          2025-09-24 23:03:34.290 - info: zigbee.0 (298385) Saved local configuration data
          2025-09-24 23:03:34.292 - info: zigbee.0 (298385) cleanup successful
          2025-09-24 23:03:34.293 - info: zigbee.0 (298385) terminating
          2025-09-24 23:03:34.296 - warn: zigbee.0 (298385) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-09-24 23:03:34.304 - info: zigbee.0 (298385) zigbecontroller stopped successfully - ZH was not running
          2025-09-24 23:03:34.439 - info: zigbee.0 (298385) debug devices set to []
          2025-09-24 23:03:34.885 - warn: zigbee.0 (298385) get state error: DB closed
          2025-09-24 23:03:34.886 - warn: zigbee.0 (298385) get state error: DB closed
          • Asgothian
            @dimaiv Seltsam - der try/catch sollte das eigentlich fangen.
            Das kann ich ohne Gerät effektiv nicht Debuggen.
            A.
            Nachtrag: Eine mögliche Quelle hab ich noch. Bitte den folgenden Aufruf auch noch patchen:
                        try {
            zu
                        try {
                            mappedDevice.onEvent(eventData);
              @asgothian
              Aber welchen genau...
              So komme ich such nicht zum deaktivieren...
              Hätte ich eins nach dem anderen probiert...
              • Asgothian
                @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
                @asgothian
                Deaktivieren zieht an der Stelle ggf. noch nicht. Ansonsten, der der den Absturz erzeugt ist dieser:
                0xa4c13801838effff
                Erstmal geht es darum die Abstürze loszuwerden - der Fehler darf bleiben, der Adapter muss weiter laufen
                A.
                  dimaiv @Asgothian last edited by dimaiv
                  @asgothian
                  Jetzt startet gar nicht
                  2025-09-24 23:22:06.365 - info: host.GartenIoB iobroker Updating objects from io-package.json for adapter "zigbee" with version "3.1.3-alpha-4"
                  2025-09-24 23:22:07.449 - info: host.GartenIoB iobroker exit 0
                  2025-09-24 23:22:22.257 - info: host.GartenIoB "system.adapter.zigbee.0" enabled
                  2025-09-24 23:22:23.077 - info: host.GartenIoB instance system.adapter.zigbee.0 in version "3.1.3-alpha-4" (non-npm: ioBroker/ioBroker.zigbee) started with pid 305740
                  2025-09-24 23:22:24.723 - error: host.GartenIoB Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:80
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: SyntaxError: Unexpected end of input
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1472:18)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1501:20)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
                  2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:12:24)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                  2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: Node.js v20.19.4
                  2025-09-24 23:22:24.725 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2025-09-24 23:22:24.726 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
                  2025-09-24 23:22:29.156 - info: host.GartenIoB "system.adapter.zigbee.0" disabled
                  es ist Version frisch vom Git
                    @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
                    @asgothian
                    0xa4c13801838effff
                    A.
                    Es ist ein Temperatur Sensor
                    • Asgothian
                      @asgothian
                      0xa4c13801838effff
                      A.
                      Dumme Tippfehler, jetzt sollte die git Version wieder gehen.
                      Was genau für ein Sensor ?
                        @asgothian
                        Immer noch
                        2025-09-24 23:36:41.771 - info: zigbee.0 (310968) 20 devices are part of the network
                        2025-09-24 23:36:41.774 - info: zigbee.0 (310968) Zigbee started
                        2025-09-24 23:36:41.809 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
                        2025-09-24 23:36:41.825 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
                        2025-09-24 23:36:41.832 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
                        2025-09-24 23:36:41.834 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
                        2025-09-24 23:36:41.835 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
                        2025-09-24 23:36:41.838 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
                        2025-09-24 23:36:41.839 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
                        2025-09-24 23:36:41.841 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:41.842 - error: zigbee.0 (310968) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
                        2025-09-24 23:36:42.010 - error: zigbee.0 (310968) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
                        at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:70:30)
                        2025-09-24 23:36:42.011 - error: zigbee.0 (310968) Cannot read properties of undefined (reading 'measurement_poll_interval')
                        2025-09-24 23:36:42.069 - info: zigbee.0 (310968) Halting zigbee adapter. Restart delay is at least 30 seconds.
                        2025-09-24 23:36:42.070 - info: zigbee.0 (310968) cleaning everything up
                        2025-09-24 23:36:42.073 - info: zigbee.0 (310968) Saved local configuration data
                        2025-09-24 23:36:42.076 - info: zigbee.0 (310968) cleanup successful
                        2025-09-24 23:36:42.077 - info: zigbee.0 (310968) terminating
                        2025-09-24 23:36:42.081 - warn: zigbee.0 (310968) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2025-09-24 23:36:42.089 - info: zigbee.0 (310968) zigbecontroller stopped successfully - ZH was not running
                        2025-09-24 23:36:42.509 - info: zigbee.0 (310968) debug devices set to []
                        2025-09-24 23:36:42.684 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.685 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.686 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.687 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.688 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.689 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.690 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.691 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.693 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.694 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.695 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.696 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.697 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.698 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.699 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.700 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.701 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.702 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.703 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.704 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.705 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.706 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.707 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.708 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.709 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.710 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.711 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.712 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.713 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.714 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.715 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.716 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.717 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.718 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.719 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.720 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.721 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.722 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.723 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.724 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.725 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.726 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.727 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.728 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.729 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.730 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.731 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.732 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.733 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.734 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.735 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.736 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.737 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.738 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.739 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.797 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.798 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.799 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.800 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.801 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.802 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.803 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.804 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.805 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.806 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.807 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.808 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.809 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.810 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:42.811 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/RTCGQ11LM.png to img/RTCGQ11LM.png
                        2025-09-24 23:36:42.838 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/WSDCGQ11LM.png to img/WSDCGQ11LM.png
                        2025-09-24 23:36:42.984 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/ptvo.switch.png$%$data": DB closed
                        2025-09-24 23:36:42.985 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": DB closed
                        2025-09-24 23:36:42.985 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0121_plug.png$%$data": DB closed
                        2025-09-24 23:36:42.986 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/DIYRuZ_Flower.png$%$data": DB closed
                        2025-09-24 23:36:42.986 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": DB closed
                        2025-09-24 23:36:42.994 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/HG08010.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.995 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WXCJKG13LM.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.995 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/Egony_Flower.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.996 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WSDCGQ11LM.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.996 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.997 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.998 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0601_din.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.999 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:42.999 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/Egony_Flower.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.000 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.000 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SNZB-02LD.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.001 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/RB-SRAIN01.png$%$data": Connection is closed.
                        2025-09-24 23:36:43.039 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.040 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.042 - error: zigbee.0 (310968) Error: DB closed
                        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                        at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                        at Object.onceWrapper (node:events:639:26)
                        at Socket.emit (node:events:524:28)
                        at Socket.emit (node:domain:489:12)
                        at TCP. (node:net:343:12)
                        2025-09-24 23:36:43.042 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.050 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.051 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.052 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.052 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.054 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.054 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.055 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.055 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.058 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.059 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.059 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.059 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.061 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.061 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.062 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.062 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.064 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.065 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.065 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.065 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.067 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.068 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.068 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.069 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.070 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.071 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.071 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.072 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.074 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.075 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.075 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.076 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.077 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.078 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.078 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.079 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.081 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.082 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.082 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.082 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.084 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.084 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.085 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.085 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.087 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/ptvo.switch.png to img/ptvo.switch.png
                        2025-09-24 23:36:43.095 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/MCCGQ11LM.png to img/MCCGQ11LM.png
                        2025-09-24 23:36:43.101 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/TS0121_plug.png to img/TS0121_plug.png
                        2025-09-24 23:36:43.107 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/DIYRuZ_Flower.png to img/DIYRuZ_Flower.png
                        2025-09-24 23:36:43.113 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/SWV.png to img/SWV.png
                        2025-09-24 23:36:43.129 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/HG08010.png to img/HG08010.png
                        2025-09-24 23:36:43.137 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/WXCJKG13LM.png to img/WXCJKG13LM.png
                        2025-09-24 23:36:43.146 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/Egony_Flower.png to img/Egony_Flower.png
                        2025-09-24 23:36:43.153 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/TS0601_din.png to img/TS0601_din.png
                        2025-09-24 23:36:43.160 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/SNZB-02LD.png to img/SNZB-02LD.png
                        2025-09-24 23:36:43.166 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/RB-SRAIN01.png to img/RB-SRAIN01.png
                        2025-09-24 23:36:43.172 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.link_quality: DB closed
                        2025-09-24 23:36:43.172 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:43.173 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.msg_from_zigbee: DB closed
                        2025-09-24 23:36:43.174 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:43.174 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.state_l1: DB closed
                        2025-09-24 23:36:43.175 - warn: zigbee.0 (310968) get state error: Connection is closed.
                        2025-09-24 23:36:43.175 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.176 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.177 - error: zigbee.0 (310968) Error: DB closed
                        at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                        at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                        at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                        at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                        at processImmediate (node:internal/timers:485:21)
                        2025-09-24 23:36:43.178 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.183 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.184 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.185 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.186 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.191 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.191 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.193 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.194 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.198 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.198 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.199 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.200 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.203 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.204 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.205 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.205 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.208 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.209 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.210 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.211 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.214 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.214 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.215 - error: zigbee.0 (310968) Error: DB closed
                        2025-09-24 23:36:43.216 - error: zigbee.0 (310968) DB closed
                        2025-09-24 23:36:43.220 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2025-09-24 23:36:43.220 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                        2025-09-24 23:36:43.221 - error: zigbee.0 (310968) Error: DB closed
                        ich muss Log kürzen, sonnst meckert Forum.
                          es ist verlinkt da.
                          • Asgothian
                            Asgothian Developer last edited by Asgothian
                            @dimaiv ok, der kann es nicht sein, der hat kein on Event.
                            Dann sollte es der auf den folgende in der Liste der Geräte sein. Die müsste vorher im log stehen.
                            A.
                            P.s. damit ist für heute erst einmal Schluss. Morgen kann ich weiter machen. Zum Thema log kürzen, alles was nach DB closed oder connection closed kommt ist irrelevant.
                            A.
                              @asgothian
                              0x60a423fffe61dd4a - Steckdose
                              0x28dba7fffe6df66f - SWV
                              0x28dba7fffe6df516 - SWV
                              0x28dba7fffe6df594 - SWV
                              0x881a14fffeea1db2 - SWV
                              0x28dba7fffe6df5f6 - SWV
                              0xa4c13801838effff - Temp Sensor
                              tester zhc zigbee zigbee 3.1
                              12
                              175
                              4455
