    4. Tester wanted - Zigbee Adapter 3.1
    • Asgothian
      Asgothian Developer @dimaiv last edited by Asgothian
      @dimaiv Patch mal bitte bei Dir die Datei
      /opt/iobroker/node-modules/iobroker.zigbee/lib/zbDeviceEvevnt.js
      von
              if (mappedDevice && mappedDevice.onEvent && eventData.data) {
                  this.warn(`calling onEvent for ${eventData.type} on ${device.ieeeAddr}`);
                  mappedDevice.onEvent({type, data});
      module.exports = DeviceEvent;
      zu
                  try {
                  catch (error)
                      this.warn(`error in onEvent: ${error && error.message ? error.message : 'no details'}`);
      Der eigentliche Fehler kommt aus dem Konverter.
      A.
        dimaiv @Asgothian last edited by
        @asgothian
        Gleiche Fehler
        2025-09-24 23:03:33.936 - info: zigbee.0 (298385) 20 devices are part of the network
        2025-09-24 23:03:33.938 - info: zigbee.0 (298385) Zigbee started
        2025-09-24 23:03:33.971 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
        2025-09-24 23:03:33.986 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
        2025-09-24 23:03:33.993 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
        2025-09-24 23:03:33.995 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
        2025-09-24 23:03:33.996 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
        2025-09-24 23:03:33.999 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
        2025-09-24 23:03:34.000 - warn: zigbee.0 (298385) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
        2025-09-24 23:03:34.022 - error: zigbee.0 (298385) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-09-24 23:03:34.022 - error: zigbee.0 (298385) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
        2025-09-24 23:03:34.169 - error: zigbee.0 (298385) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
        at onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:678:58)
        at Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:376:27)
        at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:71:30)
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:13:13)
        at async Promise.all (index 2)
        2025-09-24 23:03:34.169 - error: zigbee.0 (298385) Cannot read properties of undefined (reading 'measurement_poll_interval')
        2025-09-24 23:03:34.285 - info: zigbee.0 (298385) Halting zigbee adapter. Restart delay is at least 30 seconds.
        2025-09-24 23:03:34.286 - info: zigbee.0 (298385) cleaning everything up
        2025-09-24 23:03:34.290 - info: zigbee.0 (298385) Saved local configuration data
        2025-09-24 23:03:34.292 - info: zigbee.0 (298385) cleanup successful
        2025-09-24 23:03:34.293 - info: zigbee.0 (298385) terminating
        2025-09-24 23:03:34.296 - warn: zigbee.0 (298385) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-09-24 23:03:34.304 - info: zigbee.0 (298385) zigbecontroller stopped successfully - ZH was not running
        2025-09-24 23:03:34.439 - info: zigbee.0 (298385) debug devices set to []
        2025-09-24 23:03:34.885 - warn: zigbee.0 (298385) get state error: DB closed
        2025-09-24 23:03:34.886 - warn: zigbee.0 (298385) get state error: DB closed
        • Asgothian
          @dimaiv Seltsam - der try/catch sollte das eigentlich fangen.
          Das kann ich ohne Gerät effektiv nicht Debuggen.
          A.
          Nachtrag: Eine mögliche Quelle hab ich noch. Bitte den folgenden Aufruf auch noch patchen:
                      try {
          zu
                      try {
                          mappedDevice.onEvent(eventData);
            @asgothian
            Aber welchen genau...
            So komme ich such nicht zum deaktivieren...
            Hätte ich eins nach dem anderen probiert...
            • Asgothian
              @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
              @asgothian
              Deaktivieren zieht an der Stelle ggf. noch nicht. Ansonsten, der der den Absturz erzeugt ist dieser:
              0xa4c13801838effff
              Erstmal geht es darum die Abstürze loszuwerden - der Fehler darf bleiben, der Adapter muss weiter laufen
              A.
                dimaiv @Asgothian last edited by dimaiv
                @asgothian
                Jetzt startet gar nicht
                2025-09-24 23:22:06.365 - info: host.GartenIoB iobroker Updating objects from io-package.json for adapter "zigbee" with version "3.1.3-alpha-4"
                2025-09-24 23:22:07.449 - info: host.GartenIoB iobroker exit 0
                2025-09-24 23:22:22.257 - info: host.GartenIoB "system.adapter.zigbee.0" enabled
                2025-09-24 23:22:23.077 - info: host.GartenIoB instance system.adapter.zigbee.0 in version "3.1.3-alpha-4" (non-npm: ioBroker/ioBroker.zigbee) started with pid 305740
                2025-09-24 23:22:24.723 - error: host.GartenIoB Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:80
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: SyntaxError: Unexpected end of input
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1472:18)
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1501:20)
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
                2025-09-24 23:22:24.724 - error: host.GartenIoB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
                2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
                2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:12:24)
                2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
                2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                2025-09-24 23:22:24.725 - error: host.GartenIoB Caught by controller[0]: Node.js v20.19.4
                2025-09-24 23:22:24.725 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2025-09-24 23:22:24.726 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
                2025-09-24 23:22:29.156 - info: host.GartenIoB "system.adapter.zigbee.0" disabled
                es ist Version frisch vom Git
                  @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
                  @asgothian
                  0xa4c13801838effff
                  A.
                  Es ist ein Temperatur Sensor
                  • Asgothian
                    @asgothian
                    0xa4c13801838effff
                    A.
                    Dumme Tippfehler, jetzt sollte die git Version wieder gehen.
                    Was genau für ein Sensor ?
                      @asgothian
                      Immer noch
                      2025-09-24 23:36:41.771 - info: zigbee.0 (310968) 20 devices are part of the network
                      2025-09-24 23:36:41.774 - info: zigbee.0 (310968) Zigbee started
                      2025-09-24 23:36:41.809 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
                      2025-09-24 23:36:41.825 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
                      2025-09-24 23:36:41.832 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
                      2025-09-24 23:36:41.834 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
                      2025-09-24 23:36:41.835 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
                      2025-09-24 23:36:41.838 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
                      2025-09-24 23:36:41.839 - warn: zigbee.0 (310968) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
                      2025-09-24 23:36:41.841 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:41.842 - error: zigbee.0 (310968) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
                      2025-09-24 23:36:42.010 - error: zigbee.0 (310968) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
                      at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:70:30)
                      2025-09-24 23:36:42.011 - error: zigbee.0 (310968) Cannot read properties of undefined (reading 'measurement_poll_interval')
                      2025-09-24 23:36:42.069 - info: zigbee.0 (310968) Halting zigbee adapter. Restart delay is at least 30 seconds.
                      2025-09-24 23:36:42.070 - info: zigbee.0 (310968) cleaning everything up
                      2025-09-24 23:36:42.073 - info: zigbee.0 (310968) Saved local configuration data
                      2025-09-24 23:36:42.076 - info: zigbee.0 (310968) cleanup successful
                      2025-09-24 23:36:42.077 - info: zigbee.0 (310968) terminating
                      2025-09-24 23:36:42.081 - warn: zigbee.0 (310968) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-09-24 23:36:42.089 - info: zigbee.0 (310968) zigbecontroller stopped successfully - ZH was not running
                      2025-09-24 23:36:42.509 - info: zigbee.0 (310968) debug devices set to []
                      2025-09-24 23:36:42.684 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.685 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.686 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.687 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.688 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.689 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.690 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.691 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.693 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.694 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.695 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.696 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.697 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.698 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.699 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.700 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.701 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.702 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.703 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.704 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.705 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.706 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.707 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.708 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.709 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.710 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.711 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.712 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.713 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.714 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.715 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.716 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.717 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.718 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.719 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.720 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.721 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.722 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.723 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.724 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.725 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.726 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.727 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.728 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.729 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.730 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.731 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.732 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.733 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.734 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.735 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.736 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.737 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.738 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.739 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.797 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.798 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.799 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.800 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.801 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.802 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.803 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.804 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.805 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.806 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.807 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.808 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.809 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.810 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:42.811 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/RTCGQ11LM.png to img/RTCGQ11LM.png
                      2025-09-24 23:36:42.838 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/WSDCGQ11LM.png to img/WSDCGQ11LM.png
                      2025-09-24 23:36:42.984 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/ptvo.switch.png$%$data": DB closed
                      2025-09-24 23:36:42.985 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": DB closed
                      2025-09-24 23:36:42.985 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0121_plug.png$%$data": DB closed
                      2025-09-24 23:36:42.986 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/DIYRuZ_Flower.png$%$data": DB closed
                      2025-09-24 23:36:42.986 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": DB closed
                      2025-09-24 23:36:42.994 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/HG08010.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.995 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WXCJKG13LM.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.995 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/Egony_Flower.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.996 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WSDCGQ11LM.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.996 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.997 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.998 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0601_din.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.999 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                      2025-09-24 23:36:42.999 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/Egony_Flower.png$%$data": Connection is closed.
                      2025-09-24 23:36:43.000 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                      2025-09-24 23:36:43.000 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SNZB-02LD.png$%$data": Connection is closed.
                      2025-09-24 23:36:43.001 - error: zigbee.0 (310968) Cannot check file existence of "cfg.f.zigbee.admin$%$img/RB-SRAIN01.png$%$data": Connection is closed.
                      2025-09-24 23:36:43.039 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.040 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.042 - error: zigbee.0 (310968) Error: DB closed
                      at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                      at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                      at Object.onceWrapper (node:events:639:26)
                      at Socket.emit (node:events:524:28)
                      at Socket.emit (node:domain:489:12)
                      at TCP. (node:net:343:12)
                      2025-09-24 23:36:43.042 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.050 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.051 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.052 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.052 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.054 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.054 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.055 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.055 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.058 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.059 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.059 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.059 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.061 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.061 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.062 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.062 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.064 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.065 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.065 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.065 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.067 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.068 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.068 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.069 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.070 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.071 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.071 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.072 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.074 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.075 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.075 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.076 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.077 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.078 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.078 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.079 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.081 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.082 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.082 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.082 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.084 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.084 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.085 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.085 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.087 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/ptvo.switch.png to img/ptvo.switch.png
                      2025-09-24 23:36:43.095 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/MCCGQ11LM.png to img/MCCGQ11LM.png
                      2025-09-24 23:36:43.101 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/TS0121_plug.png to img/TS0121_plug.png
                      2025-09-24 23:36:43.107 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/DIYRuZ_Flower.png to img/DIYRuZ_Flower.png
                      2025-09-24 23:36:43.113 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/SWV.png to img/SWV.png
                      2025-09-24 23:36:43.129 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/HG08010.png to img/HG08010.png
                      2025-09-24 23:36:43.137 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/WXCJKG13LM.png to img/WXCJKG13LM.png
                      2025-09-24 23:36:43.146 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/Egony_Flower.png to img/Egony_Flower.png
                      2025-09-24 23:36:43.153 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/TS0601_din.png to img/TS0601_din.png
                      2025-09-24 23:36:43.160 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/SNZB-02LD.png to img/SNZB-02LD.png
                      2025-09-24 23:36:43.166 - info: zigbee.0 (310968) downloading https://www.zigbee2mqtt.io/images/devices/RB-SRAIN01.png to img/RB-SRAIN01.png
                      2025-09-24 23:36:43.172 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.link_quality: DB closed
                      2025-09-24 23:36:43.172 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:43.173 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.msg_from_zigbee: DB closed
                      2025-09-24 23:36:43.174 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:43.174 - warn: zigbee.0 (310968) Could not perform strict object check of state zigbee.0.00124b001ec80d25.state_l1: DB closed
                      2025-09-24 23:36:43.175 - warn: zigbee.0 (310968) get state error: Connection is closed.
                      2025-09-24 23:36:43.175 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.176 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.177 - error: zigbee.0 (310968) Error: DB closed
                      at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                      at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                      at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                      at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                      at processImmediate (node:internal/timers:485:21)
                      2025-09-24 23:36:43.178 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.183 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.184 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.185 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.186 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.191 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.191 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.193 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.194 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.198 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.198 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.199 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.200 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.203 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.204 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.205 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.205 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.208 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.209 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.210 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.211 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.214 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.214 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.215 - error: zigbee.0 (310968) Error: DB closed
                      2025-09-24 23:36:43.216 - error: zigbee.0 (310968) DB closed
                      2025-09-24 23:36:43.220 - error: zigbee.0 (310968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-09-24 23:36:43.220 - error: zigbee.0 (310968) unhandled promise rejection: DB closed
                      2025-09-24 23:36:43.221 - error: zigbee.0 (310968) Error: DB closed
                      ich muss Log kürzen, sonnst meckert Forum.
                        es ist verlinkt da.
                        • Asgothian
                          Asgothian Developer last edited by Asgothian
                          @dimaiv ok, der kann es nicht sein, der hat kein on Event.
                          Dann sollte es der auf den folgende in der Liste der Geräte sein. Die müsste vorher im log stehen.
                          A.
                          P.s. damit ist für heute erst einmal Schluss. Morgen kann ich weiter machen. Zum Thema log kürzen, alles was nach DB closed oder connection closed kommt ist irrelevant.
                          A.
                            @asgothian
                            0x60a423fffe61dd4a - Steckdose
                            0x28dba7fffe6df66f - SWV
                            0x28dba7fffe6df516 - SWV
                            0x28dba7fffe6df594 - SWV
                            0x881a14fffeea1db2 - SWV
                            0x28dba7fffe6df5f6 - SWV
                            0xa4c13801838effff - Temp Sensor
                            tester zhc zigbee zigbee 3.1
                            12
                            175
                            4409
