    4. Visu App macht Probleme
      crunchip Forum Testing Most Active @Dragon last edited by
      @dragon sagte in Visu App macht Probleme:
      und die Cloudanbindung nutzen soll
      Dann wird es wohl daran liegen
        Dragon @crunchip last edited by Dragon
        @crunchip
        Und was mache ich jetzt? Weil ja nur die App Probleme macht. Die Cloudanbindung funktioniert ja, wie ich ja geschrieben hatte.
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide
        ========== Start marking the full check here ===========
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Debian GNU/Linux 13 (trixie)                       Static hostname: ioBroker
               Icon name: computer-vm
                 Chassis: vm 🖴
            AF_VSOCK CID: 1                                                   Virtualization: kvm
                  Kernel: Linux 6.12.43+deb13-amd64                             Architecture: x86-64
         Hardware Vendor: QEMU                                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
           Firmware Date: Tue 2014-04-01
            Firmware Age: 11y 5month 3w 3d
        OS is similar to:
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         19:44:16 up 9 days,  2:42,  1 user,  load average: 0.28, 0.63, 0.80CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'trixie'!
        This system needs to be REBOOTED!
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-09-24 19:44:16 CEST
                   Universal time: Wed 2025-09-24 17:44:16 UTC
                         RTC time: Wed 2025-09-24 17:44:16
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        brokeradmin
        HOME=/home/brokeradmin
        GROUPS=brokeradmin adm dialout sudo audio video plugdev users iobroker
        iobroker
        HOME=/home/iobroker
        SUDO_HOME=/home/brokeradmin
        GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            8.3G        5.8G        1.6G        2.8M        1.3G        2.5G
        Swap:           1.0G        676M        346M
        Total:          9.4G        6.5G        1.9G
        Active iob-Instances:   73
                 7947 M total memory
                 5546 M used memory
                 4783 M active memory
                 1204 M inactive memory
                 1496 M free memory
                   73 M buffer memory
                 1120 M swap cache
                  974 M total swap
                  644 M used swap
                  330 M free swap
        top - 19:44:17 up 9 days,  2:42,  1 user,  load average: 0.28, 0.63, 0.80
        Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie%Cpu(s): 42.9 us,  4.8 sy,  0.0 ni, 47.6 id,  0.0 wa,  0.0 hi,  0.0 si,  4.8 st
        MiB Mem :   7947.8 total,   1496.4 free,   5545.8 used,   1194.4 buff/cache
        MiB Swap:    975.0 total,    330.1 free,    644.9 used.   2402.0 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     795M  560K  795M   1% /run
        /dev/sda1      ext4       31G   25G  4.5G  85% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
        tmpfs          tmpfs     3.9G  2.3M  3.9G   1% /tmp
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
        tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1002
        [Mon Sep 15 17:02:01 2025] EXT4-fs (sda1): mounted filesystem a6df39e5-8210-4c92-b9c8-b4b557b9e693 ro with ordered data mode. Quota mode: none.
        [Mon Sep 15 17:02:02 2025] EXT4-fs (sda1): re-mounted a6df39e5-8210-4c92-b9c8-b4b557b9e693 r/w.
        Show mounted filesystems:
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        1.2G    /var/
        834M    /var/log
        804M    /var/log/journal/58d2cc2a97184623922200d7fac194bf
        189M    /var/lib
        Archived and active journals take up 803.1M in the file system.
        /opt/iobroker/backups:
        6.5G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.4G    /opt/iobroker/iobroker-data/
        1.3G    /opt/iobroker/iobroker-data/files
        718M    /opt/iobroker/iobroker-data/history
        301M    /opt/iobroker/iobroker-data/backup-objects
        211M    /opt/iobroker/iobroker-data/files/vis
        58M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/states.jsonl
        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        tcp
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.5
        /usr/bin/node           v20.19.5
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.33.0
        nodejs:
          Installed: 20.19.5-1nodesource1
          Candidate: 20.19.5-1nodesource1
          Version table:
         *** 20.19.5-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.19.4-1nodesource1 1001
             20.19.3-1nodesource1 1001
             20.19.2+dfsg-1 500
                500 http://deb.debian.org/debian trixie/main amd64 Packages
             20.19.2-1nodesource1 1001
             20.19.1-1nodesource1 1001
             20.19.0-1nodesource1 1001
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 787337)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.2
        javascript:     9.0.6
        nodejs modules from github:     4
        +-- iobroker.apsystemsez1@0.0.7 (git+ssh://git@github.com/hefegraphie/ioBroker.apsystemsez1.git#0e771c9d92c4bb4e662b09022820f2aa48358c50)
        +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
        Adapter State
        + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.apsystemsez1.0           : apsystemsez1          : ioBroker                                 -  enabled
        + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
        + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
        + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
        + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
          system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
        + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
        + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
        + system.adapter.history.0                : history               : ioBroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
          system.adapter.iceroad.0                : iceroad               : ioBroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
          system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: ioBroker                                 -  enabled  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
          system.adapter.icons-freepic.0          : icons-freepic         : ioBroker                                 -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
          system.adapter.icons-smarthome.0        : icons-smarthome       : ioBroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
        + system.adapter.imap.0                   : imap                  : ioBroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
        + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
        + system.adapter.meross.1                 : meross                : ioBroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1890, bind: 192.168.178.3
        + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
        + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
        + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
        + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
        + system.adapter.notificationforandroidtv.0: notificationforandroidtv: ioBroker                                 -  enabled
        + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
        + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
          system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
          system.adapter.odl.0                    : odl                   : ioBroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
          system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
        + system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        + system.adapter.pushsafer.0              : pushsafer             : ioBroker                                 -  enabled
          system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
        + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
        + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
          system.adapter.sayit.0                  : sayit                 : ioBroker                                 - disabled
          system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
          system.adapter.schoolfree.1             : schoolfree            : ioBroker                                 -  enabled
        + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
        + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.3
        + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
          system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 - disabled
        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.3               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.4               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.5               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        + system.adapter.text2command.1           : text2command          : ioBroker                                 -  enabled
        + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
        + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
          system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: ioBroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : ioBroker                                 - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
          system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
        + system.adapter.windows-control.0        : windows-control       : ioBroker                                 -  enabled
        + system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
        + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
        + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.222:6638
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "adguard"      : 1.0.1    , installed 1.0.1
        Adapter    "admin"        : 7.7.2    , installed 7.7.2
        Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "countdown"    : 3.0.0    , installed 3.0.0
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.13.1  , installed 2.13.1
        Adapter    "devices"      : 1.2.8    , installed 1.2.8
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "followthesun" : 0.5.2    , installed 0.5.2
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
        Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
        Adapter    "imap"         : 0.3.0    , installed 0.3.0
        Adapter    "iot"          : 3.3.0    , installed 3.5.2
        Adapter    "javascript"   : 8.9.2    , installed 9.0.6
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "logparser"    : 2.4.0    , installed 2.4.0
        Adapter    "matter"       : 0.5.2    , installed 0.5.2
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
        Adapter    "mytime"       : 1.4.7    , installed 1.4.7
        Adapter    "net-tools"    : 1.1.2    , installed 1.2.0
        Adapter    "nina"         : 0.0.25   , installed 0.0.26
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "odl"          : 5.0.0    , installed 5.0.0
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
        Adapter    "ping"         : 1.6.2    , installed 1.7.9
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
        Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
        Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
        Adapter    "ring"         : 6.4.0    , installed 6.3.0  [Updatable]
        Adapter    "samsung"      : 0.6.1    , installed 0.6.1
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
        Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "telegram-menu": 2.4.4    , installed 2.4.4
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 4.0.0
        Adapter    "tuya"         : 3.16.0   , installed 3.17.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
        Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
        Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
        Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "vis-2-widgets-weather-and-heating": 1.1.3, installed 1.1.3
        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-material" : 0.2.0    , installed 0.2.0
        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
        Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
        Adapter    "wled"         : 0.7.2    , installed 0.7.3
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
        Objects and States
        Objects:        32011
        States:         27020
        W: https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
        Hit:1 http://security.debian.org/debian-security trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.3:1883      0.0.0.0:*               LISTEN      1000       10257      1823/io.sonoff.0
        tcp        0      0 192.168.178.3:1890      0.0.0.0:*               LISTEN      1000       9885       1561/io.mqtt.0
        tcp        0      0 192.168.178.3:1891      0.0.0.0:*               LISTEN      1000       9886       1561/io.mqtt.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       7270       609/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       7265       609/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7366       884/exim4
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6346       643/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          372        1/init
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       15444      2932/io.simple-api.
        tcp6       0      0 :::8086                 :::*                    LISTEN      1000       15581      2978/io.ws.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       15505      2910/io.socketio.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       15627      2880/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       7564       991/io.admin.0
        tcp6       0      0 :::8000                 :::*                    LISTEN      1000       4135600    2853/io.upnp.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7367       884/exim4
        tcp6       0      0 :::51989                :::*                    LISTEN      1000       15244      3342/io.nuki-extend
        tcp6       0      0 :::22                   :::*                    LISTEN      0          6348       643/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          374        1/init
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          373        1/init
        udp        0      0 0.0.0.0:49424           0.0.0.0:*                           1000       14268      2853/io.upnp.0
        udp        0      0 0.0.0.0:50209           0.0.0.0:*                           1000       10652473   1504/io.broadlink2.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       15261      3250/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       15253      3250/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       13131      2908/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       10296      1911/io.chromecast.
        udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1000       15278      3250/io.matter.0
        udp        0      0 0.0.0.0:54888           0.0.0.0:*                           1000       9694       1504/io.broadlink2.
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15677      2853/io.upnp.0
        udp        0      0 0.0.0.0:47532           0.0.0.0:*                           1000       15289      3250/io.matter.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       13879      2323/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       13880      2323/io.tuya.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       9674       1504/io.broadlink2.
        udp6       0      0 :::111                  :::*                                0          375        1/init
        udp6       0      0 :::5353                 :::*                                1000       15264      3250/io.matter.0
        udp6       0      0 :::5353                 :::*                                1000       15256      3250/io.matter.0
        udp6       0      0 :::5541                 :::*                                1000       15269      3250/io.matter.0
        udp6       0      0 :::47532                :::*                                1000       15288      3250/io.matter.0
        2025-09-24 19:30:13.731  - info: host.ioBroker instance system.adapter.odl.0 having pid 648294 terminated with code 0 (NO_ERROR)
        2025-09-24 19:30:16.485  - info: host.ioBroker instance system.adapter.dwd.0 having pid 648310 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-09-24 19:30:16.966  - info: host.ioBroker instance system.adapter.ical.0 having pid 648278 terminated with code 0 (NO_ERROR)
        2025-09-24 19:30:34.369  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:30)
        2025-09-24 19:32:04.375  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:32)
        2025-09-24 19:33:34.370  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:33)
        2025-09-24 19:35:03.018  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 648541
        2025-09-24 19:35:07.405  - info: host.ioBroker instance system.adapter.dwd.0 having pid 648541 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-09-24 19:36:34.374  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:36)
        2025-09-24 19:38:34.382  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:38)
        2025-09-24 19:40:03.011  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 648768
        2025-09-24 19:40:04.441  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:40)
        2025-09-24 19:40:08.258  - info: host.ioBroker instance system.adapter.dwd.0 having pid 648768 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-09-24 19:41:34.386  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:41)
        2025-09-24 19:43:04.385  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:43)
        2025-09-24 19:44:34.393  - info: device-watcher.0 (496529) Das folgende Gerät ist nicht mehr erreichbar:
         Garagentoröffner (19:44)
        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Dragon last edited by
          Nimm das Ernst. Ist keine Zeile nur zur Deko.
          Deinem root-System droht in absehbarer Zeit der Platz auszugehen:
          Verwende nodejs@22.
            Entsprechende Einstellungen in der App tätigen?
            Ich selbst nutze das nicht
              @crunchip @Thomas-Braun
              Wenn ich ein Update auf nodejs 22 mache verbindet sich der cloud adapter nicht mehr.
              Einstellungen in der App auf was? Sie funktioniert ja hin und wieder. Es liegt also nicht an der App sondern an der Cloudverbindung, es sei denn in der App ist etwas kaputt geupdated worden. Im App Thread scheint es genau um mein Problem zu gehen. Scheine nicht der einzige zu sein.
              Mit dem Update auf nodejs22 warte ich glaub ich lieber noch. wenn dann die cloudanbindung garnicht mehr funktioniert ist das für mich gar keine Lösung.
              Das mit dem System reboot kommt von automatisch gemachten updates. Wenn ich immer sofort neu starte wenn darum gebeten wird bin ich gefühlt täglich am neustarten. Seitdem ist aber auch schon mehrfach neu gestartet worden.
                Die Meldung wird eigentlich zurückgesetzt, wenn gebootet wurde. Und die erscheint auch nur bei sehr systemnahen Updates, das sind aber nicht besonders viele.
                  Hier schon. Was gibt es für Meldungen im Log dazu?
                    Dragon @Thomas Braun last edited by
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	instance system.adapter.cloud.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at Socket.onError (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:681:8)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at Socket.onClose (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:703:20)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at WS.Transport.close (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:94:10)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at WS.doClose (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:234:13)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at WebSocket.close (node:internal/deps/undici/undici:12676:9)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at closeWebSocketConnection (node:internal/deps/undici/undici:12015:9)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at failWebsocketConnection (node:internal/deps/undici/undici:11744:9)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at fireEvent (node:internal/deps/undici/undici:11663:14)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at WebSocket.dispatchEvent (node:internal/event_target:762:26)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: at WebSocket.[nodejs.internal.kHybridDispatch] (node:internal/event_target:835:9)
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[3]: RangeError: Maximum call stack size exceeded
                    host.ioBroker
                    2025-09-15 15:22:43.253	error	Caught by controller[2]: at Socket.onError (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:681:8)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at Socket.onClose (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:703:20)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at WS.Transport.close (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:94:10)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at WS.doClose (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:234:13)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at WebSocket.close (node:internal/deps/undici/undici:12676:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at closeWebSocketConnection (node:internal/deps/undici/undici:12015:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at failWebsocketConnection (node:internal/deps/undici/undici:11744:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at fireEvent (node:internal/deps/undici/undici:11663:14)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at WebSocket.dispatchEvent (node:internal/event_target:762:26)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: at WebSocket.[nodejs.internal.kHybridDispatch] (node:internal/event_target:835:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[2]: RangeError: Maximum call stack size exceeded
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Intercept (node:internal/deps/undici/undici:7535:20)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at new Request (node:internal/deps/undici/undici:2008:27)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at Channel.publish (node:diagnostics_channel:150:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[1]: TypeError: request.headers.split is not a function
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:192:9)
                    host.ioBroker
                    2025-09-15 15:22:43.252	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:282:39)
                    host.ioBroker
                    2025-09-15 15:22:43.251	error	Caught by controller[0]: TypeError: request.headers.split is not a function
                    cloud.0
                    2025-09-15 15:22:43.060	error	Maximum call stack size exceeded
                    cloud.0
                    2025-09-15 15:22:43.059	error	RangeError: Maximum call stack size exceeded at WebSocket.[nodejs.internal.kHybridDispatch] (node:internal/event_target:835:9) at WebSocket.dispatchEvent (node:internal/event_target:762:26) at fireEvent (node:internal/deps/undici/undici:11663:14) at failWebsocketConnection (node:internal/deps/undici/undici:11744:9) at closeWebSocketConnection (node:internal/deps/undici/undici:12015:9) at WebSocket.close (node:internal/deps/undici/undici:12676:9) at WS.doClose (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:234:13) at WS.Transport.close (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:94:10) at Socket.onClose (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:703:20) at Socket.onError (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:681:8)
                    cloud.0
                    2025-09-15 15:22:43.059	error	uncaught exception: Maximum call stack size exceeded
                      @dragon
                      Welcher Typ ist bei WebSockets eingestellt?
                        Dragon @Thomas Braun last edited by Dragon
                        @thomas-braun in den einstellungen des cloudadapters steht web.0 ist das das was du meintest?
                        im web adapter steht das hier:
                        Oder war die Frage nach etwas anderem?
                        • haselchen
                          haselchen Most Active @Dragon last edited by
                          @dragon
                          Probiers mal so
                            Dragon @haselchen last edited by
                            @haselchen Was ist mit den anderen Einstellungen? Die in deinem Bild fehlen.
                            • haselchen
                              @dragon
                              Würdest Du sehen, wenn Du es so einstellen würdest 😉
                                Einstellung geändert. Die übrigen Infos fehlen trotzdem...
                                • haselchen
                                  haselchen Most Active @Dragon last edited by haselchen
                                  @dragon
                                  Welche Adapter Version von Web.0 hast Du?
                                  Wie sehen Deine WS.0 Einstellungen aus?
                                  Und Simple Api Einstellungen (hast Du eine Instanz davon installiert?)
                                    Dragon @haselchen last edited by Dragon
                                    @haselchen Web.0 ist 7.0.8
                                    • haselchen
                                      @dragon
                                      Im Grunde hast Du auch meine Einstellungen in den 3 Adaptern.
                                      Ich bin bei allen im Latest (Beta)
                                      Ob dadurch andere Einstellungsmöglichkeiten erscheinen oder nicht mehr erscheinen , kann ich Dir nicht mehr sagen.
                                      Bei web.0 jedenfalls habe ich keine anderen Einstellungen mehr wenn ich "ws" angebe.
                                      Edit: ich denke mal, dass liegt vermutlich an den Versionen, da Du im Web.0 den Haken für Simple Api hast, trotz "Ws" Auswahl.
                                        @haselchen ich bin bei allen auf stable. Welche Einstellungen muss ich denn nehmen im webadapter. und bei simple ist ja quasi nichts eingestellt. sollte man da etwas einstellen?
                                        • haselchen
                                          @dragon
                                          Ich hab bei Simple Api auch nichts eingestellt.
                                          Bei web, ws, simple api....kommt es ja darauf an , was Du vor hast.
                                          Ich hab das damals so eingestellt, damit Flot und die VISU App funktionieren.
                                            @haselchen Ich hatte meine Einstellungen gemacht, damit der Fully Browser und die Visu App funktionieren. Noch irgendeine Idee?
                                            app ladeprobleme visu
                                            599
