    3. Einsteigerfragen
    4. Installation
    5. Zigbee-Stick-Zugriff für (iobroker-docker-container)
      Homoran Global Moderator Administrators @xbow42 last edited by Homoran
      @xbow42 sagte in Zigbee-Stick-Zugriff für (iobroker-docker-container):
      log sieht so aus
      als Text in code-tags sähe es viel schöner aus 😉
      was ich da glaube entziffern zu können, ist nur warn und info, kein debug
      • X
        xbow42 @Homoran last edited by xbow42
        ich gelobe Besserung
        zigbee.0
        	2025-09-27 17:12:34.096	error	Error herdsman start
        zigbee.0
        	2025-09-27 17:12:34.095	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e8f9074b1a3bec11be179c957a0af07f-if00-port0
        zigbee.0
        	2025-09-27 17:12:34.064	info	Unable to obtain herdsman settings
        zigbee.0
        	2025-09-27 17:12:33.782	info	Starting Zigbee-Herdsman
        zigbee.0
        	2025-09-27 17:12:33.781	info	configured transmit power : normal
        zigbee.0
        	2025-09-27 17:12:33.779	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
        zigbee.0
        	2025-09-27 17:12:33.759	info	Starting Adapter npm ...
        zigbee.0
        	2025-09-27 17:12:33.758	info	Autostart Zigbee subsystem
        zigbee.0
        	2025-09-27 17:12:33.758	info	--- creating device debug ---
        zigbee.0
        	2025-09-27 17:12:33.704	info	init localConfig
        zigbee.0
        	2025-09-27 17:12:33.703	info	Adapter ready - starting subsystems. Adapter is running in info mode.
        zigbee.0
        	2025-09-27 17:12:33.673	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
        zigbee.0
        	2025-09-27 17:11:57.136	info	debug devices set to []
        zigbee.0
        	2025-09-27 17:11:56.790	warn	Device 0xffffb40e0600bdbf "3RSM0147Z" not found.
        zigbee.0
        	2025-09-27 17:11:56.790	warn	Device 0x282c02bfffeec20f "3RSPE01044BZ" not found.
        zigbee.0
        	2025-09-27 17:11:56.790	warn	Device 0xffffb40e06000f6f "3RSPE01044BZ" not found.
        zigbee.0
        	2025-09-27 17:11:56.788	warn	Device 0x00158d000232c1c5 "MCCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.778	warn	Device 0x00178801060d52be "7146060PH" not found.
        zigbee.0
        	2025-09-27 17:11:56.778	warn	Device 0x00124b000420cb77 "AV2010/25" not found.
        zigbee.0
        	2025-09-27 17:11:56.778	warn	Device 0x00158d0002c6f552 "RTCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.778	warn	Device 0x00158d0002b74582 "DJT11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.777	warn	Device 0x04cf8cdf3c78c249 "GZCGQ01LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.777	warn	Device 0x00158d0002b6e86a "RTCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.777	warn	Device 0x00158d000205a243 "WXKG11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.777	warn	Device 0x00158d000205bf28 "WXKG11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.776	warn	Device 0x00158d0001ef6817 "WXKG11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.776	warn	Device 0x00158d0001e81c61 "WSDCGQ01LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.776	warn	Device 0x00158d000232c420 "MCCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.775	warn	Device 0x00158d0002090a08 "WSDCGQ01LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.775	warn	Device 0x00158d000208ec61 "WSDCGQ01LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.775	warn	Device 0x00158d00024352a2 "MCCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.775	warn	Device 0x00158d00024348fb "MCCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.774	warn	Device 0x00158d000232c476 "MCCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.773	warn	Device 0x00158d0002495571 "MCCGQ11LM" not found.
        zigbee.0
        	2025-09-27 17:11:56.754	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        	2025-09-27 17:11:56.752	info	terminating
        zigbee.0
        	2025-09-27 17:11:56.752	info	cleanup successful
        zigbee.0
        	2025-09-27 17:11:56.751	info	zigbecontroller stopped successfully
        zigbee.0
        	2025-09-27 17:11:55.902	info	Saved local configuration data
        zigbee.0
        	2025-09-27 17:11:55.892	info	cleaning everything up...
        zigbee.0
        	2025-09-27 17:11:55.889	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
        zigbee.0
        	2025-09-27 17:11:55.855	info	Got terminate signal TERMINATE_YOURSELF```
          Thomas Braun Most Active @xbow42 last edited by
          Die Datei gibt es nicht.
          • X
            xbow42 @Thomas Braun last edited by xbow42
            ich hab in der Adapterconfig bei COM-Anschlussname von /dev/serial/by-id... auf /dev/ttyUSB0 umgestellt. läuft.
            Jetzt muss ich nur hoffen, dass beim Neustart der Alias-link für den Stick immer auf ttyUSB0 bleibt.
            Kann man das mit irgend einer Einstellung erzwingen?
            Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
              Nein. Deswegen verwendet man ja die links 'by-id', die ändern sich nämlich nicht.
              • haselchen
                haselchen Most Active @xbow42 last edited by
                @xbow42
                Wie oft steckst Du denn den Stick um ?
                Homoran X 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @haselchen last edited by
                  @haselchen sagte in Zigbee-Stick-Zugriff für (iobroker-docker-container):
                  @xbow42
                  ein Neustart reicht
                  • X
                    xbow42 @haselchen last edited by
                    @haselchen
                    nie 🤗
                    kleine Anpassung hab ich jetzt noch in der docker-compose-datei gemacht, sollte doch mal jemand(m/ w /d) umstecken wollen.😇
                    devices
                      - /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_.....-port0:/dev/ttyUSB0
                      root@smarthomeserver:/dev/serial/by-id# ls
                      wo bist du da?
                      im Docker container?
                      Da wird die Datei gefunden!
                      Aber möglicherweise ist der root schuld dass der user iobroker da nicht dran darf.
                      Aber alles Vermutungen, ich kenne mich bei Docker gar nicht aus!
                      • X
                        auf dem debian-system. Durch das Mapping vom Debian-pfad ...by-id ... , auf das Verzeichnis im Container /dev/ttyUSB0 passt das jetzt. Adapter läuft wie gewünscht.
                        Danke für eure Hilfe!
                        • haselchen
                          haselchen Most Active @Homoran last edited by haselchen
                          Unter uns Klosterschwestern….ich hab seit Jahren den Conbee und Sonoff Dongle in den gleichen USB Ports , da hat sich bisher von den drölftausend Neustarts nix geändert .
                            Thomas Braun Most Active @haselchen last edited by
                            @haselchen
                            Das heißt aber nicht unbedingt, das es auch beim drölftausendersten Neustart so bleibt.
                            Weil man das nicht ausschließen kann hat man das mit den statischen 'by-id'-Links auf dynamische Ziele ja erst eingeführt.
                            • haselchen
                              haselchen Most Active @Thomas Braun last edited by
                              Wie viele Fälle kennst Du , wo sich der TTY ändert nach einem Neustart ohne das Du das gesteckte Gerät umgesteckt hast ?
                              Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @haselchen last edited by Thomas Braun
                                @haselchen
                                Das spielt keine Rolle.
                                Das ergibt sich einfach daraus, das ein modernes System parallel startet und die die Vergabe der Gerätedateien nach der Reihenfolge des Auffindens erfolgt. Und das kannst du nicht gesichert vorhersehen. Je komplexer das Ding ist (mehrere CPUs, mehrere USB-Sticks, usw.) desto größer ist die Wahrschreinlichkeit, das die Hardware nicht immer auf der gleichen Device-Datei landet. Ist einfach so.
                                  @haselchen
                                  Kannst aber auch mal @hg6806 zu dem Thema befragen...
                                  https://forum.iobroker.net/topic/81899/raspi-vermeidung-der-usb-port-wechsel?_=1758988339938
                                    gibt es hier im Forum einige.
                                    Bevor ich die Version mit by-id kannte und umgesetzt habe, ist es mir auch passiergt.
                                    ich hab dann entwederneu gestartet oder den Stick ab und wieder angesteckt
                                    ja, es war nicht häufig, aber es kommt vor
                                    • haselchen
                                      haselchen Most Active @Thomas Braun last edited by haselchen
                                      Hätte mich fast überzeugt 😉😁
                                      Aber da ich auch mal die Suche bemüht habe , hat der User das Problem schon seit 1 Jahr
                                      https://forum-raspberrypi.de/forum/thread/61082-usb-devices-nach-dem-reboot-verschiedene-zuweisungen/
                                      Dementsprechend vermute ich ein anderes Problem bei ihm.
                                        Nein, es ist haargenau das "Phänomen", das sich Gerätedateien ändern können.
                                        • haselchen
                                          Da er mit Udeev Regeln rumhantiert und config Dateien ändert, spielt das ganz sicher mit in das Problem.
                                          Aber Schwamm drüber , am Sichersten ist natürlich Deine Lösung.
                                            Nein, ganz sicher NICHT.
                                            Der Hinweis auf UUIDs im Raspi-Forum war nämlich auch Quatsch (wie der Poster dann wohl auch selber gemerkt hat).
                                            1.2k
                                            510
