ioBroker macht Probleme im Docker
es stehen eben nur die Adapter von der Neuinstallation drin.
@mühlenbroker entpack doch mal dein backup und zeig was drin steht
Und was steht sonst drin?
Komplette Ausgabe des Skripts posten. -
========= Start marking the full check here ===========
Script v.2024-09-21 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.31+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 19:08:20 up 2:36, 2 users, load average: 0.22, 0.20, 0.18 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Mon 2025-09-29 19:08:21 CEST Universal time: Mon 2025-09-29 17:08:21 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': thomas XDG_CONFIG_HOME=/home/thomas/.config HOME=/home/thomas GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi User that is running 'js-controller': thomas HOME=/home/thomas GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi *** DISPLAY-SERVER SETUP *** Display-Server: true Desktop: LXDE-pi Terminal: x11 System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n)
@mühlenbroker sagte in ioBroker macht Probleme im Docker:
Docker : false
Da läuft doch gar kein Docker. Dafür halt ein Display-Server:
Unnötig.
Und der Rest der Ausgabe fehlt.
nicht? Ich bin laie, wenn ich in die Portainer Oberfläche gehe, läuft er ja. Bringe ich irgendwas durcheinander?
Offenbar. Und warum ein Laie gleich mit Dockern & Co. herummacht werde ich wohl auch nie verstehen. Da fehlen offenbar die absoluten Grundlagen, die man für den zusätzlichen Stack braucht.
Ich habe mir das damals nach einer Anleitung so zusammengestellt und es war für mich Plausibel.
@mühlenbroker
Poste bitte die ganze ausgabe von iob diag - die ist unglaublich lang. -
========== Start marking the full check here ===========
Script v.2024-09-21 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.31+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 19:08:20 up 2:36, 2 users, load average: 0.22, 0.20, 0.18 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Mon 2025-09-29 19:08:21 CEST Universal time: Mon 2025-09-29 17:08:21 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': thomas XDG_CONFIG_HOME=/home/thomas/.config HOME=/home/thomas GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi User that is running 'js-controller': thomas HOME=/home/thomas GROUPS=thomas adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi *** DISPLAY-SERVER SETUP *** Display-Server: true Desktop: LXDE-pi Terminal: x11 System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Do you want to switch to 'multi-user.target'? (y/n) New boot target is multi-user now! The system needs to be restarted. Removed "/etc/systemd/system/default.target". Created symlink /etc/systemd/system/default.target -> /lib/systemd/system/multi-user.target. *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 2.0G 649M 225M 5.9G 6.2G Swap: 209M 0B 209M Total: 8.4G 2.0G 859M Active iob-Instances: 0 7809 M total memory 1927 M used memory 6028 M active memory 702 M inactive memory 618 M free memory 173 M buffer memory 5426 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 19:29:02 up 2:57, 2 users, load average: 0.20, 0.14, 0.16 Tasks: 252 total, 1 running, 251 sleeping, 0 stopped, 0 zombie %Cpu(s): 22.2 us, 22.2 sy, 0.0 ni, 55.6 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7809.0 total, 616.9 free, 1929.5 used, 5600.0 buff/cache MiB Swap: 200.0 total, 200.0 free, 0.0 used. 5879.5 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 781M 1.8M 780M 1% /run /dev/sda2 ext4 917G 43G 828G 5% / tmpfs tmpfs 3.9G 148K 3.9G 1% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/sda1 vfat 510M 75M 436M 15% /boot/firmware tmpfs tmpfs 781M 40K 781M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Sep 29 16:32:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:06:B6:2B vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=550f0a9c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE [Mon Sep 29 16:32:07 2025] EXT4-fs (sda2): mounted filesystem 4aa56689-dcb4-4759-90e6-179beae559ac ro with ordered data mode. Quota mode: none. [Mon Sep 29 16:32:08 2025] EXT4-fs (sda2): re-mounted 4aa56689-dcb4-4759-90e6-179beae559ac r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 |-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-r `-/home/thomas/thinclient_drives xrdp-chansrv fuse.xrdp-chansr rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 Files in neuralgic directories: /var: 40G /var/ 37G /var/lib/docker 37G /var/lib 29G /var/lib/docker/volumes 27G /var/lib/docker/volumes/influxdb/_data/engine/data/1697462a5e13427f/autogen Archived and active journals take up 1.9G in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 91M /opt/iobroker/iobroker-data/ 69M /opt/iobroker/iobroker-data/files 47M /opt/iobroker/iobroker-data/files/admin.admin 46M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets 46M /opt/iobroker/iobroker-data/files/admin.admin/custom The five largest files in iobroker-data are: 17M /opt/iobroker/iobroker-data/objects.jsonl 8.6M /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js 3.9M /opt/iobroker/iobroker-data/states.jsonl 3.7M /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-00V6sJFg.js 3.7M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** nodejs: N/A node: N/A npm: N/A npx: N/A corepack: N/A *** nodejs is NOT correctly installed *** nodejs: Installed: (none) Candidate: 18.20.4+dfsg-1~deb12u1 Version table: 18.20.4+dfsg-1~deb12u1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 1 Some problems detected, please run iob fix Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status ./iob_diag.sh: line 893: iob: command not found Hosts: ./iob_diag.sh: line 895: iob: command not found Core adapters versions ./iob_diag.sh: line 901: iob: command not found js-controller: ./iob_diag.sh: line 902: iob: command not found admin: ./iob_diag.sh: line 903: iob: command not found javascript: nodejs modules from github: 0 Adapter State Enabled adapters with bindings ioBroker-Repositories ./iob_diag.sh: line 915: iob: command not found Installed ioBroker-Instances ./iob_diag.sh: line 918: iob: command not found Objects and States Please stand by - This may take a while Objects: 0 States: 0 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Reading package lists... Done Pending Updates: 383 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 8609 792/sshd: /usr/sbin tcp 0 0 0.0.0.0:9090 0.0.0.0:* LISTEN 0 9918 2174/docker-proxy tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 12875 2765/cupsd tcp 0 0 0.0.0.0:9443 0.0.0.0:* LISTEN 0 11762 2076/docker-proxy tcp 0 0 0.0.0.0:3000 0.0.0.0:* LISTEN 0 10816 2102/docker-proxy tcp 0 0 0.0.0.0:8081 0.0.0.0:* LISTEN 0 11734 2027/docker-proxy tcp 0 0 0.0.0.0:8086 0.0.0.0:* LISTEN 0 9893 2121/docker-proxy tcp 0 0 127.0.0.1:40743 0.0.0.0:* LISTEN 0 6385 765/containerd tcp 0 0 0.0.0.0:8000 0.0.0.0:* LISTEN 0 12421 2143/docker-proxy tcp6 0 0 ::1:3350 :::* LISTEN 0 7326 766/xrdp-sesman tcp6 0 0 :::22 :::* LISTEN 0 8611 792/sshd: /usr/sbin tcp6 0 0 :::9090 :::* LISTEN 0 11804 2188/docker-proxy tcp6 0 0 :::9443 :::* LISTEN 0 12408 2084/docker-proxy tcp6 0 0 :::3000 :::* LISTEN 0 10819 2109/docker-proxy tcp6 0 0 :::3389 :::* LISTEN 112 9232 804/xrdp tcp6 0 0 :::8081 :::* LISTEN 0 11739 2041/docker-proxy tcp6 0 0 :::8086 :::* LISTEN 0 12418 2129/docker-proxy tcp6 0 0 :::8000 :::* LISTEN 0 12424 2151/docker-proxy tcp6 0 0 ::1:631 :::* LISTEN 0 12874 2765/cupsd udp 0 0 0.0.0.0:32786 0.0.0.0:* 104 5396 579/avahi-daemon: r udp 0 0 0.0.0.0:631 0.0.0.0:* 0 12919 2767/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 5394 579/avahi-daemon: r udp6 0 0 :::49062 :::* 104 5397 579/avahi-daemon: r udp6 0 0 fe80::fda2:67b9:1e9:546 :::* 0 10649 616/NetworkManager udp6 0 0 fe80::e3a4:2db4:b49:546 :::* 0 10428 616/NetworkManager udp6 0 0 :::5353 :::* 104 5395 579/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-09-29 19:14:11.394 - info: mqtt.0 (231) All states published 2025-09-29 19:19:11.394 - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connection closed: timeout 2025-09-29 19:19:11.396 - info: mqtt.0 (231) Disconnected from 127.0.0.1: undefined 2025-09-29 19:19:21.397 - info: mqtt.0 (231) Reconnected to 127.0.0.1 2025-09-29 19:19:21.402 - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connected with secret 1759166361401_1251 2025-09-29 19:19:21.406 - info: mqtt.0 (231) Connected to 127.0.0.1 2025-09-29 19:19:21.408 - info: mqtt.0 (231) Subscribe on "#" 2025-09-29 19:19:21.409 - info: mqtt.0 (231) Publishing state mqtt.0.info.connection 2025-09-29 19:19:21.411 - info: mqtt.0 (231) All states published 2025-09-29 19:24:21.413 - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connection closed: timeout 2025-09-29 19:24:21.415 - info: mqtt.0 (231) Disconnected from 127.0.0.1: undefined 2025-09-29 19:24:31.415 - info: mqtt.0 (231) Reconnected to 127.0.0.1 2025-09-29 19:24:31.419 - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connected with secret 1759166671417_8156 2025-09-29 19:24:31.421 - info: mqtt.0 (231) Connected to 127.0.0.1 2025-09-29 19:24:31.422 - info: mqtt.0 (231) Subscribe on "#" 2025-09-29 19:24:31.423 - info: mqtt.0 (231) Publishing state mqtt.0.info.connection 2025-09-29 19:24:31.424 - info: mqtt.0 (231) All states published 2025-09-29 19:29:31.424 - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connection closed: timeout 2025-09-29 19:29:31.427 - info: mqtt.0 (231) Disconnected from 127.0.0.1: undefined 2025-09-29 19:29:41.428 - info: mqtt.0 (231) Reconnected to 127.0.0.1 2025-09-29 19:29:41.433 - info: sonoff.0 (246) Client [df42066e06c3.mqtt.0] connected with secret 1759166981431_5259 2025-09-29 19:29:41.438 - info: mqtt.0 (231) Connected to 127.0.0.1 2025-09-29 19:29:41.439 - info: mqtt.0 (231) Subscribe on "#" 2025-09-29 19:29:41.439 - info: mqtt.0 (231) Publishing state mqtt.0.info.connection 2025-09-29 19:29:41.441 - info: mqtt.0 (231) All states published
iob diag has finished.
Mal von dem iob diag (und den katastrophalen Infos ) weg , nach welcher Anleitung hast Du installiert ?
das ist eine gute Frage. Wenn ich die Anleitung nur noch hätte. Zwei Jahre sind vergangen...
das sind aber nur wenige,
sonoff und mqtt gehören nicht dazu
ja, jetzt sind es sehr wenige. Ich hab das halt vermasselt und es wird mir wohl viel Arbeit bevorstehen.
hast du gelesen was ich schrieb??
hier nochmal:
laut log läuft bei dir sonoff und mqtt.
Die sind in keiner Neuinstallation dabei!
Also müssten die aus dem Backup kommen.BTW
was ist aus@homoran sagte in ioBroker macht Probleme im Docker:
geworden?
ja, diese beiden habe ich versucht, nach der Neuinstallation zu Installieren. Das hat allerdings auch nicht so recht geklappt. Ich sitze ja nun schon zwei Tage dran und habe sicher eineiges in die falsche Richtung gemacht.
Nach der Backup Datei schaue ich nochmal
@mühlenbroker logs bitte immer als Text in code-tags posten
Sowas gehört auf jeden Fall auf einen separaten Datenträger. Also ins NAS, auf 'nen Stick oder gleich in die Cloud.
Wenn Du ein aktuelles Backup gefunden hast, solltest Du vielleicht nochmal neu anfangen.
Also von Grund auf neu installieren. Und zwar ohne Desktop. Was nicht installiert ist, frisst keine Ressourcen und kann auch keine Probleme produzieren. Braucht man für ioBroker ja auch nicht.
Wie das geht, steht hier: https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nichtAls Anfänger und auf einem kleinen Pi macht Docker IMHO nicht wirklich Sinn. Auch wenn's technisch funktionieren sollte.
Das muss dann erstmal sauber laufen.
Wenn Du soweit bist, melde dich wieder hier. -
Ich habe alles neu aufgesetzt und es läuft wieder hervorragend. Als nächstes kümmere ich mich ums Backup.
