    4. Test Adapter BMW/Mini v4.x.x
    • Steffe.S.
      Steffe.S. @tombox last edited by Steffe.S.
      @tombox
      bmw.0
      Zeit
      debug
      Nachricht
      bmw.0
      2025-10-03 14:37:02.559	info	BMW MQTT stream connected
      bmw.0
      2025-10-03 14:37:02.440	info	API quota: 46/50 calls remaining for static data. Updates via MQTT do not count against quota.
      bmw.0
      2025-10-03 14:37:02.440	info	MQTT streaming: enabled
      bmw.0
      2025-10-03 14:37:02.439	info	BMW CarData adapter startup complete
      bmw.0
      2025-10-03 14:37:02.116	error	Failed to setup telematic container
      bmw.0
      2025-10-03 14:37:02.116	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
      bmw.0
      2025-10-03 14:37:02.115	error	Response status: 429
      bmw.0
      2025-10-03 14:37:02.115	error	Failed to create telematic container: Request failed with status code 429
      bmw.0
      2025-10-03 14:37:02.114	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
      bmw.0
      2025-10-03 14:37:02.113	error	Response status: 429
      bmw.0
      2025-10-03 14:37:02.111	error	create telematic container failed: Request failed with status code 429
      bmw.0
      2025-10-03 14:37:02.055	info	Creating container with 294 technical identifiers from telematic.json
      bmw.0
      2025-10-03 14:37:02.043	info	Setting up telematic container...
      API - Ordner ist nach Neuinstallation nicht vorhanden, nur der Streamordner (dieser wird auch befüllt)
      Edit: anscheint habe ich mein Limit überschritten...
        manny4566 last edited by manny4566
        @steffe-s
        Wie hast du den SOC in evcc bei dir eingebaut ? Evcc ist doch noch nicht angepasst für die neue API oder ?
        Steffe.S. 1 Reply Last reply Reply Quote 0
        • JB_Sullivan
          JB_Sullivan last edited by JB_Sullivan
          @tombox
          Vielen Dank für die neue GIT Version. Diese kam für mich gerade passend, da das Auto an der Ladestation hing.
          Es sind nun unglaublich viele neue DP`s unter dem Stream Register dazu gekommen. Für mich macht es den Eindruck als wenn das ALLE verfügbaren Datenpunkte sind die es gibt und nicht mehr über die FIN Fahrzeug spezifisch separiert wird.
          Mit aktivem Ladevorgang und anschließender Testrunde durch den Ort, haben sich 95% der Datenpunkte NICHT mit Leben gefüllt. Ein Großteil der Datenpunkte beziehen sich auf Verbrenner und Funktionen die es bei meinem BMW i3S nie gab (z.B. Lenkradheizung, Sitzbelüftung, Benzinverbräuche usw.)
          Fehlermeldungen während der Installation des neuen Adapter gab es keine.
          PS: Jetzt habe ich im übrigen den DeepSleep Datenpunkt - der bleibt aber leer.
          bmw.0
          14760	2025-10-03 14:04:05.184	info	Container verification successful: Retrieved 293 telematic data points for WBxxxxxxxxxxx
          bmw.0
          14760	2025-10-03 14:04:05.936	info	Setting up periodic telematic data updates every 60 minutes for 1 vehicle(s)
          bmw.0
          14760	2025-10-03 14:04:05.937	info	BMW CarData adapter startup complete
          bmw.0
          14760	2025-10-03 14:04:05.937	info	MQTT streaming: enabled
          bmw.0
          14760	2025-10-03 14:04:05.938	info	API quota: 46/50 calls remaining for static data. Updates via MQTT do not count against quota.
          bmw.0
          14760	2025-10-03 14:04:06.074	info	BMW MQTT stream connected
          • Steffe.S.
            Steffe.S. @manny4566 last edited by Steffe.S.
            @manny4566
            per MQTT schicke ich diese Daten zu EVCC rüber:
            Angemeldet als : Benutzerdefiniertes Gerät
            title: EVE
            icon: car
            capacity: 28.9 # kWh
            ## required attributes
            soc: # battery soc (%)
              source: mqtt
              topic: evcc_meters/mini_soc
            range: # optional electric range (km)
              source: mqtt
              topic: evcc_meters/mini_range
            odometer: # optional odometer (km)
              source: mqtt
              topic: evcc_meters/mini_odometer
            status: # status [A..F]
              source: mqtt
              topic: evcc_meters/mini_charge_status
            Die Datenpunkte befülle ich mit einem Blockly
              manny4566 @Steffe.S. last edited by manny4566
              @steffe-s
              evcc muss ja eh umgestellt werden entweder auf deine Lösung oder das pullen der Daten aus iobroker raus; so mache ich das aktuell.
              Der BMW Stream lässt ja glaube ich nur eine Verbindung zu. Von daher kann man ja nicht den Adapter und evcc zusammen gegen den Stream anmelden.
              Danke für die Info. Bei dir sind das aber nur die Daten, die du im evcc als Objekt dann darstellst ? Oder nutzt du den Soc dann auch für die Berechnung der Ladedauer etc. im evcc ?
              Steffe.S. B 2 Replies Last reply Reply Quote 0
              • Steffe.S.
                @manny4566
                EVCC rechnet selber den SOC hoch, ich liefere quasi den SOC bei Beginn und den Rest macht EVCC. DIE Reichweite wird nicht mit berechnet.
                Wenn sich die Wallbox abschaltet (z.B. wenn zu wenig Sonne da ist) aktualisiert sich der SOC und Range wieder auf den BMW / MINI Wert über MQTT.
                  @steffe-s Ja stimmt, stand gerade auf dem Schlauch 😄
                    sticks @manny4566 last edited by sticks
                    Ich hab den neuen 4.x Adapter nun auch seit gestern am Laufen, zusammen mit meinem BMW ix3 von 2024.
                    Grundsätzlich kommen alle Werte die ich brauche, jetzt über den neuen 4.0.5 Adapter, aber wirklich nachteilig das der SOC der Batterie wirklich nur alle 20 Minuten mal aktualisiert wird, während das Auto lädt. Genauso die "verbleibende Ladezeit" (remainingchargetime), auch nur alle 20 Minuten kommt. - Das ist echt bitter, von wegen MQTT Echtzeitdaten. - Ich hoffe da arbeitet BMW noch dran, so ist das aktuell nicht wirklich brauchbar im SmartHome.
                    Aber nicht missverstehen: Großen Respekt an den Adapter-Autor für die schnelle Reaktion !!!
                    Blöd auch, dass man nicht mehr direkt über diesen Adapter steuern kann. Aber kleiner Tipp: Teilweise kann man den "BMW Alexa-Skill" für die Steuerung missbrauchen. Man kann beispielsweise von iobroker die gesprochenen Kommandos in Textform an einen Alexa-Speaker übergeben, z.B. den Text "Sage BMW starte Klimatisierung" und dann kann iobroker immer noch die standheizung anschalten/ausschalten. - Man kann Alexa ja auch nach dem Ladestand fragen, beispielsweise "sage bmw wie ist der ladestand" und Alexa Antwortet dann mit dem Echtzeitwert, der über MQTT noch nicht da ist. - Ob man diese Antwort wohl weiterverarbeiten könnte 🙂
                    • Steffe.S.
                      Steffe.S. @sticks last edited by
                      @sticks
                      welcher SOC Datenpunkt wird denn automatisch aktualisiert? Bei mit kommt die Aktualisierung nur, wenn der Ladevorgang endet oder startet
                        Blau-Mann @manny4566 last edited by
                        @manny4566
                        Wie bekommst du die Daten aus ioBroker gerade in EVCC rein. Ich scheitere momentan…
                          sticks @Steffe.S. last edited by sticks
                          @steffe-s
                          Der Datenpunkt mit dem Ladestand ist der hier, wird aber leider nur sehr selten aktualisiert bei mir z.B. von 38% auf 47% und dann auf jetzt gerade 56% (lade mit 11kW):
                          bmw.0.WBXXXXXXXXXX.stream.vehicle.drivetrain.batteryManagement.header
                          (Der Datenpunkt mit dem Ladestand scheint aber auch noch vom Fahrzeugmodell abzuhängen, andere BMW-Modelle haben den SOC Datenpunkt wieder ganz woanders. - Und wenn die einen ganz anderen Datenpunkt haben, kann natürlich sein dass der sich auch anders verhält als bei meinem IX3)
                            manny4566 @Blau-Mann last edited by manny4566
                            @blau-mann
                            Über den Simple API Adapter hole ich die einfach mit einem http GET ab. Reicht ja schon.
                            - name: BMWi3
                              type: custom
                              title: BMWi3
                              capacity: 42.2 # Akkukapazität in kWh (optional)
                              soc:
                                source: http
                                uri: "http://192.168.0.201:8087/get/bmw.0.XXX.stream.vehicle.drivetrain.electricEngine.charging.level.value"
                                method: GET
                                jq: .val
                            Doku und weitere Werte, die man liefern kann:
                            https://docs.evcc.io/docs/devices/plugins#vehicle
                              stenmic @tombox last edited by stenmic
                              @tombox sagte in Test Adapter BMW/Mini v4.x.x:
                              @jb_sullivan ich habe die api Nutzung geändert und api container hinzugefügt bitte mal die GitHub version testen und oben man über remote.fetchViaAPI vielleicht Daten während des Ladens bekommt
                              Ich hab die neueste Version installiert und folgende Hinweise:
                              • Es werden jetzt alle Objekte die es gibt im stream erstellt (auch wenn sie leer bleiben, ca 80% bei mir)
                              • Was vorher true/false war ist jetzt vermehrt ein text string (z.B. CLOSED bei Fenstern)
                              • Obwohl ich im Adapter das Aktivierungsintervall für Telematik auf 0 gestellt habe, hagelt es Fehlermeldungen im Log
                              Die manuelle Aktualisierung der API find ich auf jeden Fall den richtigen Weg!
                              • DasBo1975
                                DasBo1975 Developer @Steffe.S. last edited by
                                @steffe-s mega, dankeschön
                                  @tombox
                                  Ich hatte es schon vermutet, da es die einzige Änderung der letzten Tage bei mir war.
                                  Mein Iobroker rennt aufgrund von OOM vor die Wand. Die Ursache ist der BMW Adapter, der plötzlich RAM verschlingt, bis nix mehr da ist.
                                  Habe ihn dabei gerade live erwischt und dann gestoppt.
                                  So fing es an, vorher lief er Stunden ruhig. Er rennt in eine Endlosschleife und mach immer die Autorisierung neu:
                                  2025-10-03 19:18:15.345 - ESC[33mwarnESC[39m: bmw.0 (22461) API quota for static dataexhausted: 50/50 calls used in last 24h. Stream data still working.
                                  2025-10-03 19:18:15.345 - ESC[33mwarnESC[39m: bmw.0 (22461) API quota exhausted for get telematic data for XXX - continuing anyway
                                  2025-10-03 19:18:15.410 - ESC[31merrorESC[39m: bmw.0 (22461) get telematic data for XXX failed: Request failed with status code 429
                                  2025-10-03 19:18:15.410 - ESC[31merrorESC[39m: bmw.0 (22461) Response status: 429
                                  2025-10-03 19:18:15.411 - ESC[31merrorESC[39m: bmw.0 (22461) Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has bee
                                  n reached."}
                                  2025-10-03 19:18:15.411 - ESC[31merrorESC[39m: bmw.0 (22461) Failed to retrieve telematic data for XXX with container M00Q005R511KO: Request failed with status code 429
                                  2025-10-03 19:18:15.411 - ESC[31merrorESC[39m: bmw.0 (22461) Response status: 429
                                  n reached."}
                                  2025-10-03 19:18:15.411 - ESC[33mwarnESC[39m: bmw.0 (22461) No telematic data retrieved for XXX during periodic update
                                  2025-10-03 19:18:16.187 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:18:46.187 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT reconnecting...
                                  2025-10-03 19:18:49.357 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT error: Connection refused: Bad username or password
                                  2025-10-03 19:18:49.357 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:18:49.358 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:18:51.896 - ESC[32minfoESC[39m: bmw.0 (22461) Token refreshed successfully
                                  2025-10-03 19:18:51.956 - ESC[32minfoESC[39m: bmw.0 (22461) BMW MQTT stream connected
                                  2025-10-03 19:18:51.956 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT subscription failed: client disconnecting
                                  2025-10-03 19:18:56.950 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT error: Connection refused: Not authorized
                                  2025-10-03 19:18:56.950 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:18:56.952 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:18:59.117 - ESC[32minfoESC[39m: bmw.0 (22461) Token refreshed successfully
                                  2025-10-03 19:18:59.173 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:18:59.175 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:19:01.591 - ESC[32minfoESC[39m: bmw.0 (22461) Token refreshed successfully
                                  2025-10-03 19:19:11.654 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT error: Connection refused: Not authorized
                                  2025-10-03 19:19:11.654 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:19:11.656 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:19:11.660 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT error: Connection refused: Not authorized
                                  2025-10-03 19:19:11.660 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:19:11.661 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:19:12.238 - ESC[31merrorESC[39m: bmw.0 (22461) Token refresh failed:
                                  2025-10-03 19:19:12.238 - ESC[31merrorESC[39m: bmw.0 (22461) Error stack:
                                  2025-10-03 19:19:12.238 - ESC[31merrorESC[39m: bmw.0 (22461) Response status:
                                  2025-10-03 19:19:12.238 - ESC[31merrorESC[39m: bmw.0 (22461) Response headers:
                                  2025-10-03 19:19:12.238 - ESC[31merrorESC[39m: bmw.0 (22461) Response data:
                                  2025-10-03 19:19:12.238 - ESC[31merrorESC[39m: bmw.0 (22461) Request details:
                                  2025-10-03 19:19:12.238 - ESC[32minfoESC[39m: bmw.0 (22461) Starting new device authorization flow
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) ================================================================================
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) BMW CARDATA AUTHORIZATION REQUIRED
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) 1. Visit: https://customer.bmwgroup.com/oneid/link?user_code=YWkWFi3K
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) 2. Or visit: https://customer.bmwgroup.com/oneid/link and enter code: YWkWFi3K
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) 3. Login with your BMW account and authorize
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) 4. Code expires in 5 minutes
                                  2025-10-03 19:19:12.288 - ESC[32minfoESC[39m: bmw.0 (22461) The adapter will automatically continue after authorization
                                  2025-10-03 19:19:13.824 - ESC[32minfoESC[39m: bmw.0 (22461) Token refreshed successfully
                                  2025-10-03 19:19:13.878 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT error: Connection refused: Not authorized
                                  2025-10-03 19:19:13.878 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:19:13.880 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:19:14.188 - ESC[31merrorESC[39m: bmw.0 (22461) MQTT error: Connection refused: Not authorized
                                  2025-10-03 19:19:14.188 - ESC[33mwarnESC[39m: bmw.0 (22461) MQTT authentication failed - attempting token refresh
                                  2025-10-03 19:19:14.189 - ESC[32minfoESC[39m: bmw.0 (22461) MQTT connection closed
                                  2025-10-03 19:19:15.206 - ESC[31merrorESC[39m: bmw.0 (22461) Token refresh failed:
                                  2025-10-03 19:19:15.206 - ESC[31merrorESC[39m: bmw.0 (22461) Error stack:
                                  2025-10-03 19:19:15.206 - ESC[31merrorESC[39m: bmw.0 (22461) Response status:
                                  2025-10-03 19:19:15.206 - ESC[31merrorESC[39m: bmw.0 (22461) Response headers:
                                  2025-10-03 19:19:15.206 - ESC[31merrorESC[39m: bmw.0 (22461) Response data:
                                  2025-10-03 19:19:15.206 - ESC[31merrorESC[39m: bmw.0 (22461) Request details:
                                  2025-10-03 19:19:15.206 - ESC[32minfoESC[39m: bmw.0 (22461) Starting new device authorization flow
                                  Hast eine Idee woran es liegen kann?
                                  Da steht auch was von
                                  Aber starte ich den Adapter neu, läuft er erstmal wieder paar Stunden ohne Probleme.
                                  S M T 3 Replies Last reply Reply Quote 0
                                    stenmic @manny4566 last edited by stenmic
                                    @manny4566 schau mal bei BMW (Car Data) nach ob der Mqtt Dienst noch läuft. Bei mir war alles weg heute.
                                      manny4566 @stenmic last edited by
                                      @stenmic Der ist eigentlich da. Nach dem Neustart des Adapters läuft er ja erstmal wieder.
                                        tombox @JB_Sullivan last edited by
                                        @jb_sullivan ok ich würde behaupten dass die Datenpunkt mit timestamp null die sind die nicht relevant für das Fahrzeug sind?
                                          manny4566 @manny4566 last edited by manny4566
                                          @manny4566
                                          Update:
                                          der Absturz wird vielleicht auch durch diese Fehler verursacht.
                                          2025-10-03 22:18:09.657  - error: bmw.0 (49709) MQTT error: write EPROTO C04C48597B700000:error:0A0003F2:SSL routines:ssl3_read_bytes:sslv3 alert unexpected message:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1605:SSL alert number 10
                                          2025-10-03 22:18:09.658  - error: bmw.0 (49709) MQTT error: write EPROTO C04C48597B700000:error:0A0003F2:SSL routines:ssl3_read_bytes:sslv3 alert unexpected message:../deps/openssl/openssl/ssl/record/rec_layer_s3.c:1605:SSL alert number 10
                                          Debian 13.1
                                          OpenSSL 3.5.1 1 Jul 2025 (Library: OpenSSL 3.5.1 1 Jul 2025)
                                            tombox @manny4566 last edited by
                                            @manny4566 sollte in der aktuellen GitHub version behoben sein
                                            1.0k
                                            940
                                            213087
