    4. Test Adapter BMW/Mini v4.x.x
    • JB_Sullivan
      JB_Sullivan @tombox last edited by
      @tombox
      So stream manuell gelöscht und Adapter neu gestartet - jetzt kommt diese Meldung.
      bmw.0
      15620	2025-10-04 10:24:34.831	info	MQTT reconnecting...
      bmw.0
      15620	2025-10-04 10:24:38.044	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
      bmw.0
      15620	2025-10-04 10:24:38.044	warn	MQTT authentication failed - refreshing token for next auto-reconnect
      bmw.0
      15620	2025-10-04 10:24:38.052	info	MQTT connection closed
      bmw.0
      15620	2025-10-04 10:24:38.200	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        jupzup last edited by jupzup
        Version 4.1.0
        Heute morgen per GutHub installiert und anfangs schien soweit alles ok zu sein jedoch nach kurzer Zeit kommen diese Meldungen.:
        bmw.0
        2025-10-04 10:39:52.587	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:39:22.739	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:39:22.586	info	MQTT connection closed
        bmw.0
        2025-10-04 10:39:22.585	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:39:22.585	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:39:19.379	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:38:49.526	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:38:49.378	info	MQTT connection closed
        bmw.0
        2025-10-04 10:38:49.376	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:38:49.376	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:38:46.209	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:38:17.018	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:38:16.210	info	MQTT connection closed
        bmw.0
        2025-10-04 10:38:16.208	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:38:16.208	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:38:12.959	info	MQTT reconnecting...
        javascript.0
        2025-10-04 10:38:11.319	warn	script.js.Licht.HM_Lichtsensor: HM Lichtsensor - Status Lichtsensor2 Rollo-SZ keine Aktion Position Rollo-SZ <> 53
        bmw.0
        2025-10-04 10:37:43.100	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:37:42.959	info	MQTT connection closed
        bmw.0
        2025-10-04 10:37:42.957	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:37:42.957	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:37:39.791	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:37:11.201	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:37:09.791	info	MQTT connection closed
        bmw.0
        2025-10-04 10:37:09.790	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:37:09.790	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:37:06.572	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:36:36.718	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:36:36.571	info	MQTT connection closed
        bmw.0
        2025-10-04 10:36:36.570	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:36:36.570	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:36:33.399	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:36:03.716	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:36:03.399	info	MQTT connection closed
        bmw.0
        2025-10-04 10:36:03.397	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:36:03.397	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        bmw.0
        2025-10-04 10:36:00.219	info	MQTT reconnecting...
        bmw.0
        2025-10-04 10:35:30.847	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
        bmw.0
        2025-10-04 10:35:30.218	info	MQTT connection closed
        bmw.0
        2025-10-04 10:35:30.217	warn	MQTT authentication failed - refreshing token for next auto-reconnect
        bmw.0
        2025-10-04 10:35:30.217	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
        Update: Nach einem Neustart des Adapters kam dann folgendes und MQTT scheint wieder zz funktionieren:
        bmw.0
        2025-10-04 10:40:46.305	info	BMW MQTT stream connected
        bmw.0
        2025-10-04 10:40:46.264	info	API quota: 0/50 calls remaining for static data. Updates via MQTT do not count against quota.
        bmw.0
        2025-10-04 10:40:46.264	info	MQTT streaming: enabled
        bmw.0
        2025-10-04 10:40:46.263	info	BMW CarData adapter startup complete
        bmw.0
        2025-10-04 10:40:46.213	error	Failed to setup telematic container
        bmw.0
        2025-10-04 10:40:46.213	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
        bmw.0
        2025-10-04 10:40:46.213	error	Response status: 429
        bmw.0
        2025-10-04 10:40:46.212	error	Failed to create telematic container: Request failed with status code 429
        bmw.0
        2025-10-04 10:40:46.212	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
        bmw.0
        2025-10-04 10:40:46.212	error	Response status: 429
        bmw.0
        2025-10-04 10:40:46.212	error	create telematic container failed: Request failed with status code 429
        bmw.0
        2025-10-04 10:40:46.172	warn	API quota exhausted for create telematic container - continuing anyway
        bmw.0
        2025-10-04 10:40:46.172	warn	API quota for static dataexhausted: 50/50 calls used in last 24h. Stream data still working.
        bmw.0
        2025-10-04 10:40:46.171	info	Creating container with 294 technical identifiers from telematic.json
        bmw.0
        2025-10-04 10:40:46.168	info	Setting up telematic container...
        bmw.0
        2025-10-04 10:40:44.167	warn	Rate limit exceeded or access denied
        bmw.0
        2025-10-04 10:40:44.167	error	Response: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
        bmw.0
        2025-10-04 10:40:44.167	error	BMW CarData vehicle discovery failed: Request failed with status code 429
        bmw.0
        2025-10-04 10:40:44.167	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
        bmw.0
        2025-10-04 10:40:44.167	error	Response status: 429
        bmw.0
        2025-10-04 10:40:44.167	error	fetch vehicle mappings failed: Request failed with status code 429
        bmw.0
        2025-10-04 10:40:43.799	warn	API quota exhausted for fetch vehicle mappings - continuing anyway
        bmw.0
        2025-10-04 10:40:43.799	warn	API quota for static dataexhausted: 50/50 calls used in last 24h. Stream data still working.
        bmw.0
        2025-10-04 10:40:43.798	info	Starting BMW CarData vehicle discovery...
        bmw.0
        2025-10-04 10:40:43.323	info	Found stored BMW CarData session
        bmw.0
        2025-10-04 10:40:43.269	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.bmw, node: v22.19.0, js-controller: 7.0.7
        • Steffe.S.
          Steffe.S. @Steffe.S. last edited by
          @steffe-s sagte in Test Adapter BMW/Mini v4.x.x:
          @tombox sagte in Test Adapter BMW/Mini v4.x.x:
          @jb_sullivan ich habe die api Nutzung geändert und api container hinzugefügt bitte mal die GitHub version testen und oben man über remote.fetchViaAPI vielleicht Daten während des Ladens bekommt
          👍 neue Version geladen, Ladevorgang um 14:02Uhr gestartet mit 85% --> Rückmeldung folgt
          Danke für die schnelle und unermüdliche Aktualisierung des Adapters
          @tombox
          Hier noch die Rückmeldung zum Aktualisieren des SOC:
          SOC wurde im Abstand von 10 min aktualisiert
          • JB_Sullivan
            JB_Sullivan last edited by JB_Sullivan
            @tombox
            Hier bitte nochmal nachbessern, wenn man den Gesamtkilometer Wert für die Sourceanalytix Verarbeitung nutzt (siehe Digaramm), kommt diese Fehlermeldung. In den Objekteigenschaften ist da ein String hinterlegt.
            Auch habe ich festgestellt, das sich Wert für die Türen und Fenster jetzt schon 2x geändert hat. Mal steht dort "false" dann wieder "CLOSED" drin. Für eine grafische Auswertung in der VIS ist das so Semi gut. Ist für diesen Wechsel der Werte auch BMW verantwortlich?
            sourceanalytix.0
            11304	2025-10-04 11:49:10.719	info	Updating SourceAnalytix configuration for : bmw.0.WBYxxxxxxxxx.stream.vehicle.vehicle.travelledDistance.value
            sourceanalytix.0
            11304	2025-10-04 11:49:10.766	error	Input value for bmw.0.WBYxxxxxxxxx.stream.vehicle.vehicle.travelledDistance.value, type = string but should be a number, cannot handle calculation
            sourceanalytix.0
            11304	2025-10-04 11:49:21.593	error	Input value for bmw.0.WBYxxxxxxxxx.stream.vehicle.vehicle.travelledDistance.value, type = string but should be a number, cannot handle calculation
              tombox @jupzup last edited by
              @jupzup v4.1.1 benutzen die sollte länger als eine stunde funktionieren
                tombox @JB_Sullivan last edited by
                @jb_sullivan BMW liefert das als string ich könnte versuchen es als number zu parsen
                Ich glaube API und stream liefern unterschiedliche Datenformate. Im debug mode sollte man das gut sehen können?
                • Steffe.S.
                  Steffe.S. last edited by Steffe.S.
                  Version 4.1.0 bringt bei mir diesen Fehler, Adapter ist aber grün
                  2025-10-04 13:24:56.288	info	MQTT connection closed
                  bmw.0
                  2025-10-04 13:24:56.276	warn	MQTT authentication failed - refreshing token for next auto-reconnect
                  bmw.0
                  2025-10-04 13:24:56.276	error	MQTT error: ErrorWithReasonCode: Connection refused: Bad username or password
                  bmw.0
                  2025-10-04 13:24:53.087	info	MQTT reconnecting...
                  bmw.0
                  2025-10-04 13:24:23.225	info	Token refreshed successfully - MQTT client will auto-reconnect with new credentials
                  bmw.0
                  2025-10-04 13:24:23.087	info	MQTT connection closed
                  bmw.0
                  2025-10-04 13:24:23.079	warn	MQTT authentication failed - refreshing token for next auto-reconnect
                  Update auf 4.1.1 = Fehler kommt nicht mehr
                  • N
                    Norb 0 @Steffe.S. last edited by
                    Beim Adapter update (z.B. alle 60 Minuten) und stream update kommen unterschiedliche Zustände bei den 4 Türen. Das war bei der Version 4.05 nicht so.
                    Stream update ist der Zustand "true" bzw. "false".
                    Adapter update ist der Zustand der Türen "CLOESED" bzw. "OPEN"
                    S T 2 Replies Last reply Reply Quote 0
                      stenmic @Norb 0 last edited by
                      @norb-0 ist nicht nur bei den Türen so
                        McLane @stenmic last edited by
                        Gerade die 4.1.1 installiert - Adapter wird nicht mehr Grün😵
                          Thomas Braun Most Active @McLane last edited by
                          @mclane sagte in Test Adapter BMW/Mini v4.x.x:
                          Das macht der Adapter aber nicht ohne Einträge im Log...
                            McLane @Thomas Braun last edited by McLane
                            @thomas-braun Hast recht! Habe aber nichts geändert, nur Update.
                            Und:
                            2025-10-04 16:52:34.570 error BMW CarData authentication failed bmw.0
                            2025-10-04 16:52:34.570 error Authorization code expired, please restart adapter
                            Thomas Braun T 2 Replies Last reply Reply Quote 0
                              tombox @Norb 0 last edited by tombox
                              @norb-0 @stenmic @JB_Sullivan Das ist ein Problem bei BMW sollte man mal mit genauen Fahrzeug typ melden
                              bmwcardata-b2c-support@bmwgroup.com
                                Vielleicht liegt es daran. Wie bist du da ansonsten unterwegs?
                                Und BITTE KEINE Screenshots vom Log.
                                Der Text sieht man u. a. unter
                                iob logs
                                  tombox @McLane last edited by
                                  @mclane refresh token hat nicht funktioniert er muss aber auch gesagt haben wieso.. einfach die url besuchen die im log steht
                                    McLane @tombox last edited by McLane
                                    @tombox Musste den Code erneut eingeben. Jetzt rennt er wieder. Danke für eure Hilfe!
                                      stenmic @tombox last edited by
                                      ich hab eigentlich kein Problem damit, da ich in meinen Skripten jetzt alle Varianten abfange.
                                      • N
                                        Norb 0 @stenmic last edited by Norb 0
                                        @stenmic
                                        werde ich auch so umsetzen und alle Varianten abfragen, Danke für den Tipp
                                          also bei mir ist jetzt fast alles wieder beim Alten, im Gegenteil, ich find die neue "Art" sogar besser.
                                          Was mir jedoch noch fehlt sind meine "Trips" ich meine damit die Monatsauswertung meiner Farten.
                                          @tombox siehst du da noch eine Möglichkeit oder gibt der Adapter schon alles möglich aus.
                                          • JB_Sullivan
                                            JB_Sullivan @stenmic last edited by
                                            @stenmic sagte in Test Adapter BMW/Mini v4.x.x:
                                            Die wurden bei meinem BMW i3S auch noch nie ausgegeben. Ich habe mir das auf Basis des Gesamt Kilometerstand mit dem Sourceanalytix Adapter und Grafana in ioBroker selber erstellt.
                                            Siehe Beitrag #855.
                                            938
                                            212732
