    4. Neuer Adapter für Roborock-Staubsauger
      AXMLM last edited by AXMLM
      habe Qrevo Master. Adapter wird für 1 Sekunde grün und wird mit einigen Fehlermeldungen geschlossen.
      host.smarthome
      2025-10-04 19:08:53.259	info	Restart adapter system.adapter.roborock.0 because enabled
      host.smarthome
      2025-10-04 19:08:53.259	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      roborock.0
      2025-10-04 19:08:52.606	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2025-10-04 19:08:52.604	info	terminating
      roborock.0
      2025-10-04 19:08:52.595	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2025-10-04 19:08:52.594	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:881:44) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:211:19) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
      roborock.0
      2025-10-04 19:08:52.593	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2025-10-04 19:08:52.592	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2025-10-04 19:08:52.589	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
      roborock.0
      2025-10-04 19:08:52.363	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
      roborock.0
      2025-10-04 19:08:52.287	info	MQTT initialized
      roborock.0
      2025-10-04 19:08:51.821	info	Loaded existing clientID: 031db179-0b1b-4eb0-8104-83d8f1eae377
      roborock.0
      2025-10-04 19:08:51.798	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
      roborock.0
      2025-10-04 19:08:51.779	info	starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.5, js-controller: 7.0.7
      host.smarthome
      2025-10-04 19:08:48.709	info	instance system.adapter.roborock.0 in version "0.6.19" started with pid 484173
      host.smarthome
      2025-10-04 19:08:18.230	info	Restart adapter system.adapter.roborock.0 because enabled
      host.smarthome
      2025-10-04 19:08:18.229	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      roborock.0
      2025-10-04 19:08:18.109	info	terminating
      roborock.0
      2025-10-04 19:08:17.604	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2025-10-04 19:08:17.602	info	terminating
      roborock.0
      2025-10-04 19:08:17.593	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2025-10-04 19:08:17.592	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:881:44) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:211:19) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
      roborock.0
      2025-10-04 19:08:17.591	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2025-10-04 19:08:17.590	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2025-10-04 19:08:17.587	error	Failed to process undefined on robot undefined (unknown device model): Failed to process message: Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:193:29) at local_api.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:248:25) at Socket.handleMessage (/opt/iobroker/node_modules/iobroker.roborock/lib/local_api.js:199:34) at Socket.emit (node:events:524:28) at UDP.onMessage [as onmessage] (node:dgram:951:8)
      roborock.0
      2025-10-04 19:08:14.483	info	MQTT connection established {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
      roborock.0
      2025-10-04 19:08:14.383	info	MQTT initialized
      roborock.0
      2025-10-04 19:08:13.808	info	Loaded existing clientID: 031db179-0b1b-4eb0-8104-83d8f1eae377
      roborock.0
      2025-10-04 19:08:13.787	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
      roborock.0
      2025-10-04 19:08:13.768	info	starting. Version 0.6.19 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.19.5, js-controller: 7.0.7
      ich vermute dass es daran liegt, dass der Roboter nocj nicht unterstützt wird. Oder gibt es noch andere Gründe?
        Thomas Braun Most Active @AXMLM last edited by
        @axmlm sagte in Neuer Adapter für Roborock-Staubsauger:
        Mag zwar kein Grund sein, aber bring das Ding auf nodejs@22. Per
        iob nodejs-update
        ist das in 2 Minuten passiert.
        A 2 Replies Last reply Reply Quote 0
          AXMLM @Thomas Braun last edited by
          @thomas-braun said in Neuer Adapter für Roborock-Staubsauger:
          iob nodejs-update
          habe kein putty auf dieem Rechner. Gibt es einen weg über IObroker selbst?
            @axmlm
            Da läuft doch ein Linux. Also hast du da auch ein Teminal.
              stehe auf dem Schlauch. habe Ubuntu Server mit IObroker und kann nur über Putty zugreifen. weder monitor noch Tastatur ist angeschlossen.
                @axmlm
                Was denn jetzt? SSH-Zugriff (von mir aus per puTTY) oder nicht?
                Die PowerShell kann das aber auch.
                  auch so, jetzt verstehe ich dich. Habe kein Zugriff auf power Shell. Bin gerade an administrierten Rechner. Dann muss ich doch an anderen Rechner gehen.
                    erledigt, hat nichts gebracht
                      hat nichts gebracht
                      Hat ja auch niemand behauptet, das es dein Problem mit einem unbekannten Gerät lösen würde.
                        habe auch nur eine sehr kleine Hoffnung gehabt.
                        Der Adapter sieht den Robi und schreibt die Objekte teilweise aus. Geht aber wie gesagt sofort auf rot.
                        Gibt es einen anderen Adapter, bzw. wie sind die Chancen, dass der Qrevo Master bald unterstützt wird?
                          wolfi913 @AXMLM last edited by
                          @axmlm
                          Schau mal hier:
                          https://github.com/copystring/ioBroker.roborock/issues/752
                          Du müsstest die dev-Version über Git installieren. Mit der soll's scheinbar funktionieren
                          lindi200000 created this issue in copystring/ioBroker.roborock
                          closed qrevo master not fully supported #752
                          80.8k
                          911
                          295620
