    4. [Aufruf] Dringender Test sql 1.6.4
    • ruhr70
      ruhr70 last edited by
      Und ein paar Log-Einträge direkt nach dem Update auf 1.6.8, die es vorher so nicht gab:
      host.iobrokerng2	2018-02-06 00:15:33.998	error	instance system.adapter.sql.0 terminated with code 0 (OK)
      sql.0	2018-02-06 00:15:33.987	info	terminating
      sql.0	2018-02-06 00:15:33.482	info	Adapter is disabled => stop
      sql.0	2018-02-06 00:15:33.481	error	Error: ER_CON_COUNT_ERROR: Too many connections
      sql.0	2018-02-06 00:15:33.391	error	Cannot insert INSERT INTO `iobrokerng2`.ts_number (id, ts, val, ack, _from, q) VALUES(835, 1517872533303, , 1, 17, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual t
      sql.0	2018-02-06 00:15:33.390	error	Cannot insert INSERT INTO `iobrokerng2`.ts_number (id, ts, val, ack, _from, q) VALUES(834, 1517872533303, , 1, 17, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual t
      sql.0	2018-02-06 00:15:33.368	error	Error: ER_CON_COUNT_ERROR: Too many connections
      host.iobrokerng2	2018-02-06 00:15:33.302	info	stopInstance system.adapter.sql.0
      host.iobrokerng2	2018-02-06 00:15:33.302	info	object change system.adapter.sql.0
      sql.0	2018-02-06 00:15:15.017	error	Cannot insert INSERT INTO `iobrokerng2`.ts_number (id, ts, val, ack, _from, q) VALUES(834, 1517872514003, , 1, 5, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual th
      sql.0	2018-02-06 00:15:15.015	error	Cannot insert INSERT INTO `iobrokerng2`.ts_number (id, ts, val, ack, _from, q) VALUES(835, 1517872514003, , 1, 5, 0);: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual th
      sql.0	2018-02-06 00:14:17.431	error	Error: ER_NO_SUCH_TABLE: Table 'iobrokerng2.undefined' doesn't exist
      sql.0	2018-02-06 00:14:17.424	error	Please wait till next data record is logged and reload.
      sql.0	2018-02-06 00:14:17.424	warn	For getHistory for id javascript.0.Google_Maps.zur_Arbeit.Minuten_0: Type empty. Need to write data first. Index = 826
      sql.0	2018-02-06 00:14:11.916	error	Error: ER_NO_SUCH_TABLE: Table 'iobrokerng2.undefined' doesn't exist
      sql.0	2018-02-06 00:14:11.908	error	Please wait till next data record is logged and reload.
      sql.0	2018-02-06 00:14:17.432	error	Error: ER_NO_SUCH_TABLE: Table 'iobrokerng2.undefined' doesn't exist
      sql.0	2018-02-06 00:14:17.427	error	Please wait till next data record is logged and reload.
      sql.0	2018-02-06 00:14:17.427	warn	For getHistory for id javascript.0.Google_Maps.zur_Arbeit.Minuten_0: Type empty. Need to write data first. Index = 826
      sql.0	2018-02-06 00:14:11.918	error	Error: ER_NO_SUCH_TABLE: Table 'iobrokerng2.undefined' doesn't exist
      sql.0	2018-02-06 00:14:11.912	error	Please wait till next data record is logged and reload.
      sql.0	2018-02-06 00:14:11.912	warn	For getHistory for id javascript.3.co2sensor.co2: Type empty. Need to write data first. Index = 760
      • ruhr70
        Ok, die CPU Last aktuell (alle Intervalle auf 0) reiche ich auch noch schnell nach:
        Aktueller Stand (nach Reboot vom Linux Host).
          apollon77 last edited by
          Die logmeldungen kommen bei nem Start des Adapters? Kannst einmal auf Debug schalten und Adapter starten und mir log schicken. Muss es jetzt final finden. Die gleichen Meldungen hat sissiwup auch. Ich kann es aber nicht nachvollziehen. Komplettes Debug log von Adapter start würde extrem helfen. Daaaanke 😉
          Ich will auch noch das „top many connections“ angehen. Mal schauen.
          • ruhr70
            Im Cloud Adapter gibt es noch kein Log-Download 🙂
            knapp 300 MB. Bekommst DU heute Abend.
              Hey All,
              ich habe ein was rausgefunden: Datenpunkte die als "mixed"-Datentyp angelegt waren haben probleme gemacht … eigentlich haben die wohl schon immer nicht so wiiiiirklich funktioniert. Aber naja.
              Ich hab in der Github Version was eingebaut.
              Und ebenso habe ich versucht die "too many connection" Thematik zu lösen.
              Also daher bitte 1.6.8 vo Github installieren und sagt mir mal was dazu :-))
              • BBTown
                BBTown last edited by
                @apollon77:
                Also daher bitte 1.6.8 vo Github installieren und sagt mir mal was dazu :-)) ` kann es sein dass nun kein NULL mehr nach dem Neustart eingetragen wird?
                  Interessant. Bitte nochmal neu vom Github holen.
                  • BBTown
                    sorry, ich war zu schnell, nach einem nochmaligen Neustart waren die NULLer wieder in den Tabellen.
                    nur nach der Installation der v. 1.6.8 waren keine NULLer zu sehen.
                    Ich habe daher nach der v. 1.6.8 noch keine neue Version von Github geladen
                      Bitte nochmal Github version :-))) … wer will
                      • BBTown
                        @apollon77:
                        Also daher bitte 1.6.8 vo Github installieren und sagt mir mal was dazu :-)) ` derzeit bekomme ich keinen connect mit meinem SQL-Adapter und der v.1.6.8
                        Ich habe gerade mal den raspi rebootet, das brachte aber keine Abhilfe, daher gehe ich erst einmal auf den v.1.6.7 zurück
                        [EDIT]ich sah gerade dein Aufforderung doch noch mal Github zu bemühen, dass will ich dann doch tun 8-)
                        [EDIT2]connect hat schon einmal sofort funktioniert 😉 8-)
                          EIne Version mittendrin hatte einen Fehler und startete nicht. Das sollte jetzt gefixt sein
                          • ruhr70
                            Super! Sieht sehr gut aus. Keine Last mehr.
                            "too many connection" hatte ich beim Start auch nicht mehr.
                            • BBTown
                              Bei mir ist auch alles fein, ich hatte allerdings auch keine gravierenden Probleme zuvor (bzw. nicht bemerkt?) 8-)
                                Bitte prüfen das alle Daten da sind und so. Und bitte auch mal beenden - da sollten auch keine "too many connections" mehr kommen
                                • ruhr70
                                  @apollon77:
                                  Bitte prüfen das alle Daten da sind und so. Und bitte auch mal beenden - da sollten auch keine "too many connections" mehr kommen `
                                  stoppen / starten -> läuft "wie Butter"
                                  Schnell. Sauberes Log und keine "too many connections".
                                  Sollten die Datentypen, die unter Objekte auf "mixed" stehen geändert werden oder kann ich die jetzt so lassen, wie sie sind?
                                    @ruhr70:
                                    Sollten die Datentypen, die unter Objekte auf "mixed" stehen geändert werden oder kann ich die jetzt so lassen, wie sie sind? `
                                    Es ist jetzt eingebaut das er sich bei unklaren Datentypen den aktuellen Wert des Datenpunkts holt und den Datentyp ermittelt. Das wird dann genomen.
                                    • BBTown
                                      @apollon77:
                                      [Es ist jetzt eingebaut das er sich bei unklaren Datentypen den aktuellen Wert des Datenpunkts holt und den Datentyp ermittelt. Das wird dann genommen. ` die Grenzen werden dann sich bei 0 und 1 liegen, oder?
                                      Denn, handelt es sich nun um einen boolscher Wert oder eine Zahl? - wahrscheinlich einmal so und einmal anders, oder?!
                                      Spricht denn etwas dagegen zu Empfehlen den Typen explizit anzugeben und nur im Zweifel auf "automatisch" zu gehen? `
                                      • BBTown
                                        Ich habe beim Ausprobieren zunächst eine PostgreSQL Datenbank aufgesetzt.
                                        Hier stand tatsächlich "wahr" und "falsch" in der "ts_bool"
                                        Nun habe ich eine MariaDB im Einsatz (ein mySQL Fork), hier wird wiederum 0 und 1 für "true" und "false" in die "ts_bool" geschrieben.
                                        Jetzt weiß ich natürlich nicht, ob 0 und 1 erst durch ein mapping entsteht oder bereits beim Erfassen?!
                                          0/1 sind zahlen. True/false ist Boolean. Bei mixed Feldern kann es nur am Wert erkannt werden. Und ja wenn man Typen mischt (=Müll reinschreibt) kommt im sql (aber schon immer) Müll raus 😉
                                          • BBTown
                                            ich habe auch gerade gesehen … das Format der Spalte "val" in der "ts_bool"ist in der MariaDB vom Typ "tinyint", das sollte die 0 und 1 Darstellung von true und false erklären.
                                            203
                                            25321
