    4. Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus
      MichaelK @crycode last edited by
      @crycode ok Danke, dann versuche ich es bei Gelegenheit noch mal. Mit 22.18.0 lies er sich bei mir nicht mehr starten.
        @crycode
        Ich habe nun nochmal auf 22.18.0 geupdatet, aber der Adapter lies sich wieder nicht starten.
        Erst nach einem "npm rebuild" von /opt/iobroker/node_modules/socketcan hat es dann funktioniert.
        Log:
        2025-08-21 17:36:01.315 - info: host.raspi instance system.adapter.canbus.0 in version "2.2.0" (non-npm: crycode-de/ioBroker.canbus) started with pid 6611
        2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: node:internal/modules/cjs/loader:1846
        2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: ^
        2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: Error: Module did not self-register: '/opt/iobroker/node_modules/socketcan/build/Release/can.node'.
        2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1846:18)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at require (node:internal/modules/helpers:135:16)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/socketcan/dist/socketcan.js:51:26)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10) {
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: }
        2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: Node.js v22.18.0
        2025-08-21 17:36:01.893 - error: host.raspi instance system.adapter.canbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2025-08-21 17:36:01.893 - info: host.raspi Restart adapter system.adapter.canbus.0 because enabled
        crycode RaspiUser 2 Replies Last reply Reply Quote 1
        • crycode
          crycode Developer @MichaelK last edited by
          @michaelk
          Hmm... den Rebuild hätte ioBroker eigentlich von selbst anstoßen müssen in dem Fall.
          Aber schön, dass es nun läuft. 🙂
          • RaspiUser
            RaspiUser @MichaelK last edited by
            @crycode
            @michaelk sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
            Erst nach einem "npm rebuild" von /opt/iobroker/node_modules/socketcan ....
            ... der "Trick" hat mir auch geholfen, Danke dafür
              earl80 last edited by
              Gibt es eigentlich auch die Möglichkeit, die Heizgrenze Tag/Nacht anzupassen? Abfragen ist canbus.0.680.fa0116/fa0117, aber setzen habe ich nicht gefunden...
              crycode 1 Reply Last reply Reply Quote 0
              • crycode
                crycode Developer @earl80 last edited by
                @earl80 Ich habe der latest Config soeben fa0116-set und fa0117-set hinzugefügt. Kannst du das bitte mal testen, ob es wie gedacht funktioniert?
                  earl80 @crycode last edited by earl80
                  @crycode said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
                  fa0116-set
                  Zuerst habe ich probiert die Config mit der Adapterversion 2.2.0 zu laden, da kommt aber eine Fehlermeldung. Mit der Version 2.2.1 kann man die Config wieder laden. Jetzt habe ich die latest aber direkt von Github (https://github.com/crycode-de/ioBroker.canbus/blob/master/well-known-messages/configs/rotex-hpsu-latest.json) geladen und importiert. Die neuen fa0116-set und fa0117-set sehe ich bei den Objekten nicht.
                  crycode 2 Replies Last reply Reply Quote 0
                  • crycode
                    @earl80 Huch, da scheint was an der Import-Funktion kaputt zu sein. Schaue ich mir an...
                    • crycode
                      crycode Developer @earl80 last edited by crycode
                      @earl80 Mit der neuen Version 2.3.0 vom Adapter (aktuell per NPM installierbar) sollte der Import nun wieder funktionieren.
                      Edit: Wenn wie fa0116-set und fa0117-set Punkte bei dir nicht direkt nach dem Import angezeigt werden, dann einmal mit "Speichern und Schließen" die Adapterkonfiguration beenden und dann neu öffnen. Danach sollten die beiden Parser auf jeden Fall da sein.
                      Zudem wird ab v2.3.0 nun auch Node.js 24 unterstützt.
                        @crycode Da sich meine Fritzbox einfach verabschiedet hat, melde ich mich erst jetzt. Es funktioniert alles - vielen Dank!!!
                        canbus canbus adapter rotex hpsu
                        25
                        522
                        100144
