    3. Off Topic
    4. Proxmox
    5. Proxmox WebIf nicht erreichbar
    • Negalein
      Negalein Global Moderator @crunchip last edited by
      @crunchip sagte in Proxmox WebIf nicht erreichbar:
      systemctl status pveproxy.service
      ● pveproxy.service - PVE API Proxy Server
           Loaded: loaded (/lib/systemd/system/pveproxy.service; enabled; vendor preset: enabled)
           Active: active (running) since Sat 2025-10-11 23:22:10 CEST; 20min ago
          Process: 24072 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
          Process: 24074 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
         Main PID: 24075 (pveproxy)
            Tasks: 4 (limit: 18839)
           Memory: 132.5M
              CPU: 21.903s
           CGroup: /system.slice/pveproxy.service
                   ├─24075 pveproxy
                   ├─25151 pveproxy worker
                   ├─25152 pveproxy worker
                   └─25153 pveproxy worker
      Oct 11 23:42:38 pve pveproxy[24075]: worker 25143 finished
      Oct 11 23:42:38 pve pveproxy[24075]: worker 25151 started
      Oct 11 23:42:38 pve pveproxy[25151]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
      Oct 11 23:42:38 pve pveproxy[25144]: worker exit
      Oct 11 23:42:38 pve pveproxy[24075]: worker 25144 finished
      Oct 11 23:42:38 pve pveproxy[24075]: starting 2 worker(s)
      Oct 11 23:42:38 pve pveproxy[24075]: worker 25152 started
      Oct 11 23:42:38 pve pveproxy[24075]: worker 25153 started
      Oct 11 23:42:38 pve pveproxy[25152]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
      Oct 11 23:42:38 pve pveproxy[25153]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
      beide so aus heiterem Himmel?
      Nein, die lagen Monate (vor der Erweiterung auf 255.255.254.0) in der Schublade.
      Heute wollte ich sie wieder in Betrieb nehmen.
        crunchip Forum Testing Most Active @Negalein last edited by
        @negalein sagte in Proxmox WebIf nicht erreichbar:
        möglicherweise ist das dein Problem
        https://web-wilke.de/fix-proxmox-error-after-hostname-ip-change
        • Negalein
          ich werde das probieren.
          komisch, da es mit 255.255.255.0 ging.
            crunchip Forum Testing Most Active @Negalein last edited by crunchip
            Ja das kommt durch deine Änderung, sollte aber wieder verschwinden. Wenn...
            Zitat perplexity
            Nach einer Änderung des Netzwerks auf die Subnetzmaske 255.255.254.0 (statt bisher 255.255.255.0) im Bereich von Proxmox ist die Weboberfläche nicht erreichbar – das Problem bleibt bestehen, selbst nach Neustart des pveproxy-Dienstes�.Ursache: Netzwerkbereich und RoutingDie Änderung auf 255.255.254.0 bedeutet ein Subnetz von 10.0.0.1 bis 10.0.1.254�. Die Ausgabe von ip addr und der Inhalt von /etc/network/interfaces zeigen aber weiterhin die Konfiguration mit /24 (also 255.255.255.0) für die IP-Adresse auf vmbr0:address 10.0.1.206/24Die Routingtabelle (route -n) zeigt Netze mit Maske /24 und Gateway im Netz 10.0.1.1�.Dadurch passt die Netzmaske der Proxmox-Konfiguration nicht zum neuen Bereich, den das restliche Netzwerk (z.B. FritzBox) vorgibt.Lösung: Netzmaske und NeustartDie Netzwerkkonfiguration in /etc/network/interfaces muss an die neue Subnetzmaske angepasst werden:Ändern von address 10.0.1.206/24 auf address 10.0.1.206/23/23 entspricht 255.255.254.0
            Beispiel für /etc/network/interfaces:auto vmbr0
            iface vmbr0 inet static
            gateway 10.0.1.1
            bridge-ports enp0s31f6
            bridge-stp off
            bridge-fd 0
            Danach Netzwerkdienst neu starten:systemctl restart networking
            systemctl restart pveproxy.serviceAlternativ kann der Server einmal neu gestartet werden�.Zusätzliche HinweiseNach Änderung der Netzwerkkonfiguration muss die Änderung übernommen werden – per CLI geht das direkt nach Editieren und Dienst-Neustart�.Prüfe, ob die neue Konfiguration tatsächlich aktiv ist mit ip addr und route -n (dort sollte die neue Maske zu sehen sein)�.Stelle sicher, dass die eigene Workstation/PC ebenfalls eine IP im Bereich 10.0.0.x oder 10.0.1.x mit Maske 255.255.254.0 hat.ZusammenfassungDas Problem liegt darin, dass die Proxmox-Netzwerkkonfiguration noch mit 255.255.255.0 läuft, während im restlichen Netzwerk bereits 255.255.254.0 genutzt wird. Die Lösung ist die Anpassung der Netzmaske in /etc/network/interfaces auf /23 und ein Neustart des Netzwerkdienstes, damit die Weboberfläche wieder erreichbar wird�.
            Negalein 2 Replies Last reply Reply Quote 1
            • Negalein
              ich hab mit nano /etc/network/interfaces das File editiert.
              auto lo
              iface lo inet loopback
              iface enp0s31f6 inet manual
              auto vmbr0
                      gateway 10.0.1.1
                      bridge-stp off
                      bridge-fd 0
              dann mit systemctl restart pveproxy.service den Service neu gestartet.
                   Active: active (running) since Sun 2025-10-12 13:34:15 CEST; 7min ago
                  Process: 69400 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
                  Process: 69402 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
                 Main PID: 69403 (pveproxy)
                   Memory: 132.8M
                      CPU: 9.075s
                           ├─69403 pveproxy
                           ├─69820 pveproxy worker
                           ├─69821 pveproxy worker
                           └─69822 pveproxy worker
              Oct 12 13:42:03 pve pveproxy[69403]: starting 2 worker(s)
              Oct 12 13:42:03 pve pveproxy[69403]: worker 69820 started
              Oct 12 13:42:03 pve pveproxy[69403]: worker 69821 started
              Oct 12 13:42:03 pve pveproxy[69818]: worker exit
              Oct 12 13:42:03 pve pveproxy[69820]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
              Oct 12 13:42:03 pve pveproxy[69821]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
              Oct 12 13:42:03 pve pveproxy[69403]: worker 69818 finished
              Oct 12 13:42:03 pve pveproxy[69403]: starting 1 worker(s)
              Oct 12 13:42:03 pve pveproxy[69403]: worker 69822 started
              Oct 12 13:42:03 pve pveproxy[69822]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
              ip addr & route -n zeiigt aber noch
              1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                  link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                  inet 127.0.0.1/8 scope host lo
                     valid_lft forever preferred_lft forever
                  inet6 ::1/128 scope host
              2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master vmbr0 state UP group default qlen 1000
                  link/ether 6c:4b:90:43:c9:19 brd ff:ff:ff:ff:ff:ff
              3: vmbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
                  inet 10.0.1.206/24 scope global vmbr0
                  inet6 fe80::6e4b:90ff:fe43:c919/64 scope link
              Kernel IP routing table
              Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
              0.0.0.0         10.0.1.1        0.0.0.0         UG    0      0        0 vmbr0
              10.0.1.0        0.0.0.0         255.255.255.0   U     0      0        0 vmbr0
              • Negalein
                Negalein Global Moderator @crunchip last edited by Negalein
                @crunchip
                nach einem reboot zeigt ip addr jetzt die passende IP.
                    inet 10.0.1.206/23 scope global vmbr0
                aber https://10.0.1.206:8006/ geht trotzdem noch nicht. 😞
                dann hab ich mit nano /etc/network/interfaces:auto vmbr0 ein neues File erstellt.
                gateway 10.0.1.1
                bridge-stp off
                bridge-fd 0
                     Active: active (running) since Sun 2025-10-12 13:59:51 CEST; 3s ago
                    Process: 1524 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
                    Process: 1525 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
                   Main PID: 1527 (pveproxy)
                     Memory: 132.7M
                        CPU: 943ms
                             ├─1527 pveproxy
                             ├─1528 pveproxy worker
                             ├─1529 pveproxy worker
                             └─1530 pveproxy worker
                Oct 12 13:59:50 pve pvecm[1524]: Unable to load access control list: Connection refused
                Oct 12 13:59:51 pve pveproxy[1527]: starting server
                Oct 12 13:59:51 pve pveproxy[1527]: starting 3 worker(s)
                Oct 12 13:59:51 pve pveproxy[1527]: worker 1528 started
                Oct 12 13:59:51 pve pveproxy[1527]: worker 1529 started
                Oct 12 13:59:51 pve pveproxy[1527]: worker 1530 started
                Oct 12 13:59:51 pve pveproxy[1528]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                Oct 12 13:59:51 pve systemd[1]: Started PVE API Proxy Server.
                Oct 12 13:59:51 pve pveproxy[1529]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                Oct 12 13:59:51 pve pveproxy[1530]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                funktioniert aber auch nicht
                  Weil du nur den proxy und nicht den Netzwerkdienst neu gestartet hast.
                  Ist die 206 auch frei, oder Vllt schon anderweitig belegt?
                  Gibt's im LOG etwas zu sehen? Ist die Fehlermeldung von oben noch vorhanden?
                  Möglichkeit wäre noch testhalber von statisch auf DHCP stellen um eventuelle Fehler auszuschließen.
                    Dann mal doch die etc/hosts anschauen
                    • Negalein
                      ah, deshalb.
                      Nach reboot hat er die richtige IP gehabt.
                      Aber GUI geht nicht.
                      Ja, definitiv frei
                      wo find ich das?
                      Ja
                      in der /etc/network/interfaces:auto?
                      iface vmbr0 inet DHCP
                      gateway 10.0.1.1
                      bridge-stp off
                      bridge-fd 0
                      so?
                      etc/hosts
                      127.0.0.1 localhost.localdomain localhost
                      10.0.1.206 proxmox-3.fritz.box
                      # The following lines are desirable for IPv6 capable hosts
                      ::1     ip6-localhost ip6-loopback
                      fe00::0 ip6-localnet
                      ff00::0 ip6-mcastprefix
                      ff02::1 ip6-allnodes
                      ff02::2 ip6-allrouters
                      ff02::3 ip6-allhosts
                      crunchip 2 Replies Last reply Reply Quote 0
                        @negalein moment, ich geh gleich mal an den Rechner, vom Handy is das immer etwas umständlich.
                          crunchip Forum Testing Most Active last edited by crunchip
                          wo find ich das
                          wie üblich in var/log
                          /var/log/: Enthält eine Vielzahl von Systemprotokollen, darunter:
                          syslog: Allgemeine Systemmeldungen.
                          auth.log: Authentifizierungsereignisse.
                          syslog-ng: Protokolldateien von Syslog-ng (falls konfiguriert).
                          apt/history.log: Zeigt die History von Paketinstallationen an.
                          /var/log/pve/: Enthält Proxmox-spezifische Logs.
                          /var/log/messages/: Enthält eine Auswahl von Systemmeldungen.
                          allerdings seit proxmox v8(debian12)
                          abruf mit
                          z.b.
                          journalctl -f
                          speziell proxy
                          journalctl -u pveproxy
                          so?
                          auto vmbr0
                          iface vmbr0 inet dhcp
                              bridge-stp off
                              bridge-fd 0
                          edit
                          möglichkeit wäre noch
                          GUI per CLI wieder aktivieren: Falls die Netzumstellungen zu Problemen geführt haben, kann per CLI ein Reset oder eine Reparatur versucht werden:
                          systemctl restart pve-manager
                          oder
                          apt-get install --reinstall pve-manager
                          und dann Logs auf Fehler kontrollieren.
                          edit2
                          SSL-Zertifikate defekt: Ein defektes Zertifikat kann die Weboberfläche blockieren. Prüfe Logs auf Fehler zu SSL oder Zertifikat.​
                          Browser-Cache oder HTTPS erzwingen: Lösche den Browser-Cache oder teste mit einem anderen Browser.
                          Negalein 2 Replies Last reply Reply Quote 0
                          • Negalein
                            Failed to restart pve-manager.service: Operation refused, unit pve-guests.service may be requested by dependency only (it is configured to refuse manual start/stop).
                            See system logs and 'systemctl status pve-manager.service' for details.
                            ct 12 14:53:51 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                            Oct 12 14:53:51 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                            Oct 12 14:53:52 pve pveproxy[3628]: worker exit
                            Oct 12 14:53:52 pve pveproxy[890]: worker 3628 finished
                            Oct 12 14:53:52 pve pveproxy[890]: starting 1 worker(s)
                            Oct 12 14:53:52 pve pveproxy[890]: worker 3632 started
                            Oct 12 14:53:52 pve pveproxy[3629]: worker exit
                            Oct 12 14:53:52 pve pveproxy[3630]: worker exit
                            Oct 12 14:53:52 pve pveproxy[3632]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:53:52 pve pveproxy[890]: worker 3629 finished
                            Oct 12 14:53:52 pve pveproxy[890]: worker 3633 started
                            Oct 12 14:53:52 pve pveproxy[890]: worker 3630 finished
                            Oct 12 14:53:52 pve pveproxy[890]: worker 3634 started
                            Oct 12 14:53:52 pve pveproxy[3633]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:53:52 pve pveproxy[3634]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:53:55 pve pmxcfs[3631]: [main] crit: Unable to get local IP address
                            Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                            Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                            Oct 12 14:53:55 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                            Oct 12 14:53:55 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                            Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 676.
                            Oct 12 14:53:55 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                            Oct 12 14:53:55 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                            Oct 12 14:53:57 pve pveproxy[3632]: worker exit
                            Oct 12 14:53:57 pve pveproxy[890]: worker 3632 finished
                            Oct 12 14:53:57 pve pveproxy[890]: starting 1 worker(s)
                            Oct 12 14:53:57 pve pveproxy[890]: worker 3641 started
                            Oct 12 14:53:57 pve pveproxy[3633]: worker exit
                            Oct 12 14:53:57 pve pveproxy[3634]: worker exit
                            Oct 12 14:53:57 pve pveproxy[3641]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:53:57 pve pveproxy[890]: worker 3633 finished
                            Oct 12 14:53:57 pve pveproxy[890]: worker 3642 started
                            Oct 12 14:53:57 pve pveproxy[890]: worker 3634 finished
                            Oct 12 14:53:57 pve pveproxy[890]: worker 3643 started
                            Oct 12 14:53:57 pve pveproxy[3642]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:53:57 pve pveproxy[3643]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:53:59 pve pmxcfs[3635]: [main] crit: Unable to get local IP address
                            Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                            Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                            Oct 12 14:53:59 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                            Oct 12 14:53:59 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                            Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 677.
                            Oct 12 14:53:59 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                            Oct 12 14:53:59 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                            Oct 12 14:54:01 pve cron[843]: (*system*vzdump) CAN'T OPEN SYMLINK (/etc/cron.d/vzdump)
                            Oct 12 14:54:02 pve pveproxy[3641]: worker exit
                            Oct 12 14:54:02 pve pveproxy[890]: worker 3641 finished
                            Oct 12 14:54:02 pve pveproxy[890]: starting 1 worker(s)
                            Oct 12 14:54:02 pve pveproxy[890]: worker 3646 started
                            Oct 12 14:54:02 pve pveproxy[3642]: worker exit
                            Oct 12 14:54:02 pve pveproxy[3646]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:54:02 pve pveproxy[3643]: worker exit
                            Oct 12 14:54:02 pve pveproxy[890]: worker 3642 finished
                            Oct 12 14:54:02 pve pveproxy[890]: worker 3647 started
                            Oct 12 14:54:02 pve pveproxy[890]: worker 3643 finished
                            Oct 12 14:54:02 pve pveproxy[890]: worker 3648 started
                            Oct 12 14:54:02 pve pveproxy[3647]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:54:02 pve pveproxy[3648]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:54:03 pve pmxcfs[3644]: [main] crit: Unable to get local IP address
                            Oct 12 14:54:03 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                            Oct 12 14:54:03 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                            Oct 12 14:54:03 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                            Oct 12 14:54:03 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                            Oct 12 14:54:04 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 678.
                            Oct 12 14:54:04 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                            Oct 12 14:54:04 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                            Oct 12 14:54:07 pve pveproxy[3646]: worker exit
                            Oct 12 14:54:07 pve pveproxy[890]: worker 3646 finished
                            Oct 12 14:54:07 pve pveproxy[890]: starting 1 worker(s)
                            Oct 12 14:54:07 pve pveproxy[890]: worker 3650 started
                            Oct 12 14:54:07 pve pveproxy[3647]: worker exit
                            Oct 12 14:54:07 pve pveproxy[3650]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:54:07 pve pveproxy[3648]: worker exit
                            Oct 12 14:54:07 pve pveproxy[890]: worker 3647 finished
                            Oct 12 14:54:07 pve pveproxy[890]: worker 3651 started
                            Oct 12 14:54:07 pve pveproxy[890]: worker 3648 finished
                            Oct 12 14:54:07 pve pveproxy[890]: worker 3652 started
                            Oct 12 14:54:07 pve pveproxy[3651]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:54:07 pve pveproxy[3652]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                            Oct 12 14:54:08 pve pmxcfs[3649]: [main] crit: Unable to get local IP address
                            Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                            Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                            Oct 12 14:54:08 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                            Oct 12 14:54:08 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                            Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 679.
                            Oct 12 14:54:08 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                            Oct 12 14:54:08 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                            Oct 12 14:54:12 pve pveproxy[3650]: worker exit
                            Oct 12 14:54:12 pve
                            ● pve-guests.service - PVE guests
                                 Loaded: loaded (/lib/systemd/system/pve-guests.service; enabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Sun 2025-10-12 14:04:14 CEST; 53min ago
                                Process: 899 ExecStartPre=/usr/share/pve-manager/helpers/pve-startall-delay (code=exited, status=0/SUCCESS)
                                Process: 900 ExecStart=/usr/bin/pvesh --nooutput create /nodes/localhost/startall (code=exited, status=111)
                               Main PID: 900 (code=exited, status=111)
                                    CPU: 747ms
                            Oct 12 14:04:13 pve systemd[1]: Starting PVE guests...
                            Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[1] failed: Connection refused
                            Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[2] failed: Connection refused
                            Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[3] failed: Connection refused
                            Oct 12 14:04:14 pve pvesh[900]: Unable to load access control list: Connection refused
                            Oct 12 14:04:14 pve systemd[1]: pve-guests.service: Main process exited, code=exited, status=111/n/a
                            Oct 12 14:04:14 pve systemd[1]: pve-guests.service: Failed with result 'exit-code'.
                            Oct 12 14:04:14 pve systemd[1]: Failed to start PVE guests.
                            • Negalein
                              Reading package lists... Done
                              Building dependency tree... Done
                              Reinstallation of pve-manager is not possible, it cannot be downloaded.
                              0 upgraded, 0 newly installed, 0 to remove and 161 not upgraded.
                                pve-ssl.key: failed
                                dann mach mal
                                pvecm updatecerts -f
                                Prüfe, ob die IP angezeigt wird mit hostname -I
                                  Thomas Braun Most Active @Negalein last edited by
                                  Pfleg die Kiste. Da hängt einiges in der Pipeline.
                                  • Negalein
                                    hostname -I
                                    10.0.1.206
                                    @thomas-braun sagte in Proxmox WebIf nicht erreichbar:
                                    I know!
                                    die lag monatelang in der Schublade.
                                    Wird sofort erledigt, sobald wieder alles läuft.
                                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                      Ich würde das ja andersherum angehen.
                                      ZUERST die Basis klar kriegen und erst DANACH die darauf aufbauenden Dinge konfigurieren.
                                      Negalein crunchip 2 Replies Last reply Reply Quote 0
                                        ipcc_send_rec[1] failed: Connection refused ipcc_send_rec[2] failed: Connection refused ipcc_send_rec[3] failed: Connection refused Unable to load access control list: Connection refused
                                        systemctl status pve-cluster
                                        systemctl restart pve-cluster
                                        journalctl -u pve-cluster -b --no-pager | tail -40
                                        • Negalein
                                          Negalein Global Moderator @Thomas Braun last edited by
                                          gerade dabei 🙂
                                            crunchip Forum Testing Most Active @Thomas Braun last edited by
                                            @thomas-braun wird aber schwierig ohne funktionierendes Netzwerk
                                            81.1k
                                            1340
