    3. Off Topic
    4. Proxmox
    5. Proxmox WebIf nicht erreichbar
    • Negalein
      Negalein Global Moderator @crunchip last edited by Negalein
      @crunchip
      nach einem reboot zeigt ip addr jetzt die passende IP.
      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
          inet 127.0.0.1/8 scope host lo
             valid_lft forever preferred_lft forever
          inet6 ::1/128 scope host
      2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master vmbr0 state UP group default qlen 1000
          link/ether 6c:4b:90:43:c9:19 brd ff:ff:ff:ff:ff:ff
      3: vmbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
          inet 10.0.1.206/23 scope global vmbr0
          inet6 fe80::6e4b:90ff:fe43:c919/64 scope link
      aber https://10.0.1.206:8006/ geht trotzdem noch nicht. 😞
      dann hab ich mit nano /etc/network/interfaces:auto vmbr0 ein neues File erstellt.
      iface vmbr0 inet static
      address 10.0.1.206/23
      gateway 10.0.1.1
      bridge-ports enp0s31f6
      bridge-stp off
      bridge-fd 0
      ● pveproxy.service - PVE API Proxy Server
           Loaded: loaded (/lib/systemd/system/pveproxy.service; enabled; vendor preset: enabled)
           Active: active (running) since Sun 2025-10-12 13:59:51 CEST; 3s ago
          Process: 1524 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
          Process: 1525 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
         Main PID: 1527 (pveproxy)
            Tasks: 4 (limit: 18839)
           Memory: 132.7M
              CPU: 943ms
           CGroup: /system.slice/pveproxy.service
                   ├─1527 pveproxy
                   ├─1528 pveproxy worker
                   ├─1529 pveproxy worker
                   └─1530 pveproxy worker
      Oct 12 13:59:50 pve pvecm[1524]: Unable to load access control list: Connection refused
      Oct 12 13:59:51 pve pveproxy[1527]: starting server
      Oct 12 13:59:51 pve pveproxy[1527]: starting 3 worker(s)
      Oct 12 13:59:51 pve pveproxy[1527]: worker 1528 started
      Oct 12 13:59:51 pve pveproxy[1527]: worker 1529 started
      Oct 12 13:59:51 pve pveproxy[1527]: worker 1530 started
      Oct 12 13:59:51 pve pveproxy[1528]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
      Oct 12 13:59:51 pve systemd[1]: Started PVE API Proxy Server.
      Oct 12 13:59:51 pve pveproxy[1529]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
      Oct 12 13:59:51 pve pveproxy[1530]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
      funktioniert aber auch nicht
        crunchip Forum Testing Most Active @Negalein last edited by
        @negalein sagte in Proxmox WebIf nicht erreichbar:
        ip addr & route -n zeiigt aber noch
        Weil du nur den proxy und nicht den Netzwerkdienst neu gestartet hast.
        Ist die 206 auch frei, oder Vllt schon anderweitig belegt?
        Gibt's im LOG etwas zu sehen? Ist die Fehlermeldung von oben noch vorhanden?
        Möglichkeit wäre noch testhalber von statisch auf DHCP stellen um eventuelle Fehler auszuschließen.
          Dann mal doch die etc/hosts anschauen
          • Negalein
            @crunchip sagte in Proxmox WebIf nicht erreichbar:
            ah, deshalb.
            Nach reboot hat er die richtige IP gehabt.
            Aber GUI geht nicht.
            Ja, definitiv frei
            wo find ich das?
            Ja
            in der /etc/network/interfaces:auto?
            iface vmbr0 inet DHCP
            gateway 10.0.1.1
            bridge-stp off
            bridge-fd 0
            so?
            etc/hosts
            127.0.0.1 localhost.localdomain localhost
            10.0.1.206 proxmox-3.fritz.box
            # The following lines are desirable for IPv6 capable hosts
            ::1     ip6-localhost ip6-loopback
            fe00::0 ip6-localnet
            ff00::0 ip6-mcastprefix
            ff02::1 ip6-allnodes
            ff02::2 ip6-allrouters
            ff02::3 ip6-allhosts
            crunchip 2 Replies Last reply Reply Quote 0
              @negalein moment, ich geh gleich mal an den Rechner, vom Handy is das immer etwas umständlich.
                crunchip Forum Testing Most Active last edited by crunchip
                wo find ich das
                wie üblich in var/log
                /var/log/: Enthält eine Vielzahl von Systemprotokollen, darunter:
                syslog: Allgemeine Systemmeldungen.
                auth.log: Authentifizierungsereignisse.
                syslog-ng: Protokolldateien von Syslog-ng (falls konfiguriert).
                apt/history.log: Zeigt die History von Paketinstallationen an.
                /var/log/pve/: Enthält Proxmox-spezifische Logs.
                /var/log/messages/: Enthält eine Auswahl von Systemmeldungen.
                allerdings seit proxmox v8(debian12)
                abruf mit
                z.b.
                journalctl -f
                speziell proxy
                journalctl -u pveproxy
                so?
                auto vmbr0
                iface vmbr0 inet dhcp
                    bridge-stp off
                    bridge-fd 0
                edit
                möglichkeit wäre noch
                GUI per CLI wieder aktivieren: Falls die Netzumstellungen zu Problemen geführt haben, kann per CLI ein Reset oder eine Reparatur versucht werden:
                systemctl restart pve-manager
                oder
                apt-get install --reinstall pve-manager
                und dann Logs auf Fehler kontrollieren.
                edit2
                SSL-Zertifikate defekt: Ein defektes Zertifikat kann die Weboberfläche blockieren. Prüfe Logs auf Fehler zu SSL oder Zertifikat.​
                Browser-Cache oder HTTPS erzwingen: Lösche den Browser-Cache oder teste mit einem anderen Browser.
                Negalein 2 Replies Last reply Reply Quote 0
                • Negalein
                  Failed to restart pve-manager.service: Operation refused, unit pve-guests.service may be requested by dependency only (it is configured to refuse manual start/stop).
                  See system logs and 'systemctl status pve-manager.service' for details.
                  ct 12 14:53:51 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                  Oct 12 14:53:51 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                  Oct 12 14:53:52 pve pveproxy[3628]: worker exit
                  Oct 12 14:53:52 pve pveproxy[890]: worker 3628 finished
                  Oct 12 14:53:52 pve pveproxy[890]: starting 1 worker(s)
                  Oct 12 14:53:52 pve pveproxy[890]: worker 3632 started
                  Oct 12 14:53:52 pve pveproxy[3629]: worker exit
                  Oct 12 14:53:52 pve pveproxy[3630]: worker exit
                  Oct 12 14:53:52 pve pveproxy[3632]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:53:52 pve pveproxy[890]: worker 3629 finished
                  Oct 12 14:53:52 pve pveproxy[890]: worker 3633 started
                  Oct 12 14:53:52 pve pveproxy[890]: worker 3630 finished
                  Oct 12 14:53:52 pve pveproxy[890]: worker 3634 started
                  Oct 12 14:53:52 pve pveproxy[3633]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:53:52 pve pveproxy[3634]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:53:55 pve pmxcfs[3631]: [main] crit: Unable to get local IP address
                  Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                  Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                  Oct 12 14:53:55 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                  Oct 12 14:53:55 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                  Oct 12 14:53:55 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 676.
                  Oct 12 14:53:55 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                  Oct 12 14:53:55 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                  Oct 12 14:53:57 pve pveproxy[3632]: worker exit
                  Oct 12 14:53:57 pve pveproxy[890]: worker 3632 finished
                  Oct 12 14:53:57 pve pveproxy[890]: starting 1 worker(s)
                  Oct 12 14:53:57 pve pveproxy[890]: worker 3641 started
                  Oct 12 14:53:57 pve pveproxy[3633]: worker exit
                  Oct 12 14:53:57 pve pveproxy[3634]: worker exit
                  Oct 12 14:53:57 pve pveproxy[3641]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:53:57 pve pveproxy[890]: worker 3633 finished
                  Oct 12 14:53:57 pve pveproxy[890]: worker 3642 started
                  Oct 12 14:53:57 pve pveproxy[890]: worker 3634 finished
                  Oct 12 14:53:57 pve pveproxy[890]: worker 3643 started
                  Oct 12 14:53:57 pve pveproxy[3642]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:53:57 pve pveproxy[3643]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:53:59 pve pmxcfs[3635]: [main] crit: Unable to get local IP address
                  Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                  Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                  Oct 12 14:53:59 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                  Oct 12 14:53:59 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                  Oct 12 14:53:59 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 677.
                  Oct 12 14:53:59 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                  Oct 12 14:53:59 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                  Oct 12 14:54:01 pve cron[843]: (*system*vzdump) CAN'T OPEN SYMLINK (/etc/cron.d/vzdump)
                  Oct 12 14:54:02 pve pveproxy[3641]: worker exit
                  Oct 12 14:54:02 pve pveproxy[890]: worker 3641 finished
                  Oct 12 14:54:02 pve pveproxy[890]: starting 1 worker(s)
                  Oct 12 14:54:02 pve pveproxy[890]: worker 3646 started
                  Oct 12 14:54:02 pve pveproxy[3642]: worker exit
                  Oct 12 14:54:02 pve pveproxy[3646]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:54:02 pve pveproxy[3643]: worker exit
                  Oct 12 14:54:02 pve pveproxy[890]: worker 3642 finished
                  Oct 12 14:54:02 pve pveproxy[890]: worker 3647 started
                  Oct 12 14:54:02 pve pveproxy[890]: worker 3643 finished
                  Oct 12 14:54:02 pve pveproxy[890]: worker 3648 started
                  Oct 12 14:54:02 pve pveproxy[3647]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:54:02 pve pveproxy[3648]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:54:03 pve pmxcfs[3644]: [main] crit: Unable to get local IP address
                  Oct 12 14:54:03 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                  Oct 12 14:54:03 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                  Oct 12 14:54:03 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                  Oct 12 14:54:03 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                  Oct 12 14:54:04 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 678.
                  Oct 12 14:54:04 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                  Oct 12 14:54:04 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                  Oct 12 14:54:07 pve pveproxy[3646]: worker exit
                  Oct 12 14:54:07 pve pveproxy[890]: worker 3646 finished
                  Oct 12 14:54:07 pve pveproxy[890]: starting 1 worker(s)
                  Oct 12 14:54:07 pve pveproxy[890]: worker 3650 started
                  Oct 12 14:54:07 pve pveproxy[3647]: worker exit
                  Oct 12 14:54:07 pve pveproxy[3650]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:54:07 pve pveproxy[3648]: worker exit
                  Oct 12 14:54:07 pve pveproxy[890]: worker 3647 finished
                  Oct 12 14:54:07 pve pveproxy[890]: worker 3651 started
                  Oct 12 14:54:07 pve pveproxy[890]: worker 3648 finished
                  Oct 12 14:54:07 pve pveproxy[890]: worker 3652 started
                  Oct 12 14:54:07 pve pveproxy[3651]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:54:07 pve pveproxy[3652]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                  Oct 12 14:54:08 pve pmxcfs[3649]: [main] crit: Unable to get local IP address
                  Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                  Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                  Oct 12 14:54:08 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                  Oct 12 14:54:08 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                  Oct 12 14:54:08 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 679.
                  Oct 12 14:54:08 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                  Oct 12 14:54:08 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                  Oct 12 14:54:12 pve pveproxy[3650]: worker exit
                  Oct 12 14:54:12 pve
                  ● pve-guests.service - PVE guests
                       Loaded: loaded (/lib/systemd/system/pve-guests.service; enabled; vendor preset: enabled)
                       Active: failed (Result: exit-code) since Sun 2025-10-12 14:04:14 CEST; 53min ago
                      Process: 899 ExecStartPre=/usr/share/pve-manager/helpers/pve-startall-delay (code=exited, status=0/SUCCESS)
                      Process: 900 ExecStart=/usr/bin/pvesh --nooutput create /nodes/localhost/startall (code=exited, status=111)
                     Main PID: 900 (code=exited, status=111)
                          CPU: 747ms
                  Oct 12 14:04:13 pve systemd[1]: Starting PVE guests...
                  Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[1] failed: Connection refused
                  Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[2] failed: Connection refused
                  Oct 12 14:04:14 pve pvesh[900]: ipcc_send_rec[3] failed: Connection refused
                  Oct 12 14:04:14 pve pvesh[900]: Unable to load access control list: Connection refused
                  Oct 12 14:04:14 pve systemd[1]: pve-guests.service: Main process exited, code=exited, status=111/n/a
                  Oct 12 14:04:14 pve systemd[1]: pve-guests.service: Failed with result 'exit-code'.
                  Oct 12 14:04:14 pve systemd[1]: Failed to start PVE guests.
                  • Negalein
                    Reading package lists... Done
                    Building dependency tree... Done
                    Reinstallation of pve-manager is not possible, it cannot be downloaded.
                    0 upgraded, 0 newly installed, 0 to remove and 161 not upgraded.
                      pve-ssl.key: failed
                      dann mach mal
                      pvecm updatecerts -f
                      systemctl restart pveproxy
                      Prüfe, ob die IP angezeigt wird mit hostname -I
                        Thomas Braun Most Active @Negalein last edited by
                        Pfleg die Kiste. Da hängt einiges in der Pipeline.
                        • Negalein
                          hostname -I
                          10.0.1.206
                          @thomas-braun sagte in Proxmox WebIf nicht erreichbar:
                          I know!
                          die lag monatelang in der Schublade.
                          Wird sofort erledigt, sobald wieder alles läuft.
                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                            Ich würde das ja andersherum angehen.
                            ZUERST die Basis klar kriegen und erst DANACH die darauf aufbauenden Dinge konfigurieren.
                            Negalein crunchip 2 Replies Last reply Reply Quote 0
                              ipcc_send_rec[1] failed: Connection refused ipcc_send_rec[2] failed: Connection refused ipcc_send_rec[3] failed: Connection refused Unable to load access control list: Connection refused
                              systemctl status pve-cluster
                              systemctl restart pve-cluster
                              journalctl -u pve-cluster -b --no-pager | tail -40
                              • Negalein
                                Negalein Global Moderator @Thomas Braun last edited by
                                gerade dabei 🙂
                                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                                  @thomas-braun wird aber schwierig ohne funktionierendes Netzwerk
                                    Thomas Braun Most Active @crunchip last edited by
                                    Grundsätzlich scheint doch da was zu sein.
                                    Sonst hätte apt-get ja nicht ausrechnen können, das 161 Pakete zum Update anstehen.
                                    crunchip uweklatt 2 Replies Last reply Reply Quote 0
                                      @thomas-braun ja, aber gewisse Dinge können dann aber nicht umgesetzt werden bzw bestimmte Befehle nicht auf Proxmoxebene ausgeführt werden, solange der Proxmox Cluster-Dienst bzw. Corosync nicht laufen, deshalb greifen auch die obigen Befehle nicht
                                      • Negalein
                                        ● pve-cluster.service - The Proxmox VE cluster filesystem
                                             Loaded: loaded (/lib/systemd/system/pve-cluster.service; enabled; vendor preset: enabled)
                                             Active: activating (start) since Sun 2025-10-12 15:27:11 CEST; 1ms ago
                                        Cntrl PID: 930 (pmxcfs)
                                              Tasks: 1 (limit: 18839)
                                             Memory: 128.0K
                                                CPU: 199us
                                             CGroup: /system.slice/pve-cluster.service
                                                     └─930 /usr/bin/pmxcfs
                                        Oct 12 15:27:11 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                                        Job for pve-cluster.service failed because the control process exited with error code.
                                        See "systemctl status pve-cluster.service" and "journalctl -xe" for details.
                                        journalctl -xe
                                        ░░ The job identifier is 8927 and the job result is done.
                                        Oct 12 15:30:03 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                                        ░░ Subject: A start job for unit pve-cluster.service has begun execution
                                        ░░ Defined-By: systemd
                                        ░░ Support: https://www.debian.org/support
                                        ░░ A start job for unit pve-cluster.service has begun execution.
                                        ░░ The job identifier is 8927.
                                        Oct 12 15:30:07 pve pmxcfs[1084]: [main] crit: Unable to get local IP address
                                        Oct 12 15:30:07 pve systemd[1]: pve-cluster.service: Control process exited, code=exited, status=255/EXCEPTION
                                        ░░ Subject: Unit process exited
                                        ░░ An ExecStart= process belonging to unit pve-cluster.service has exited.
                                        ░░ The process' exit code is 'exited' and its exit status is 255.
                                        Oct 12 15:30:07 pve systemd[1]: pve-cluster.service: Failed with result 'exit-code'.
                                        ░░ Subject: Unit failed
                                        ░░ The unit pve-cluster.service has entered the 'failed' state with result 'exit-code'.
                                        Oct 12 15:30:07 pve systemd[1]: Failed to start The Proxmox VE cluster filesystem.
                                        ░░ Subject: A start job for unit pve-cluster.service has failed
                                        ░░ A start job for unit pve-cluster.service has finished with a failure.
                                        ░░ The job identifier is 8927 and the job result is failed.
                                        Oct 12 15:30:07 pve systemd[1]: Condition check resulted in Corosync Cluster Engine being skipped.
                                        ░░ Subject: A start job for unit corosync.service has finished successfully
                                        ░░ A start job for unit corosync.service has finished successfully.
                                        ░░ The job identifier is 8930.
                                        Oct 12 15:30:07 pve pveproxy[1081]: worker exit
                                        Oct 12 15:30:07 pve pveproxy[1082]: worker exit
                                        Oct 12 15:30:07 pve pveproxy[889]: worker 1081 finished
                                        Oct 12 15:30:07 pve pveproxy[889]: starting 1 worker(s)
                                        Oct 12 15:30:07 pve pveproxy[889]: worker 1082 finished
                                        Oct 12 15:30:07 pve pveproxy[889]: worker 1085 started
                                        Oct 12 15:30:07 pve pveproxy[1083]: worker exit
                                        Oct 12 15:30:07 pve pveproxy[1085]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                        Oct 12 15:30:07 pve pveproxy[889]: worker 1083 finished
                                        Oct 12 15:30:07 pve pveproxy[889]: starting 2 worker(s)
                                        Oct 12 15:30:07 pve pveproxy[889]: worker 1086 started
                                        Oct 12 15:30:07 pve pveproxy[889]: worker 1087 started
                                        Oct 12 15:30:07 pve pveproxy[1086]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                        Oct 12 15:30:07 pve pveproxy[1087]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                        Oct 12 15:30:08 pve systemd[1]: pve-cluster.service: Scheduled restart job, restart counter is at 22.
                                        ░░ Subject: Automatic restarting of a unit has been scheduled
                                        ░░ Automatic restarting of the unit pve-cluster.service has been scheduled, as the result for
                                        ░░ the configured Restart= setting for the unit.
                                        Oct 12 15:30:08 pve systemd[1]: Stopped The Proxmox VE cluster filesystem.
                                        ░░ Subject: A stop job for unit pve-cluster.service has finished
                                        ░░ A stop job for unit pve-cluster.service has finished.
                                        ░░ The job identifier is 9103 and the job result is done.
                                        Oct 12 15:30:08 pve systemd[1]: Starting The Proxmox VE cluster filesystem...
                                        ░░ The job identifier is 9103.
                                        • uweklatt
                                          uweklatt @Thomas Braun last edited by
                                          Wenn man die Netzwerkmaske ändert, sollte es bei allen Geräten im zugehörigen Netzwerk identisch eingestellt werden. Danach den Netzwerkstack neu starten (z.B. mit einem Reboot).
                                          Sind ALLE Beteiligten Geräte umgestellt?
                                          Tschau
                                          Uwe
                                            @negalein zeig mal den Eintrag in /etc/pve/corosync.conf
                                            81.1k
                                            1340
