Update von Debian 12 auf 13 möglich?
Danke für deine schnelle Antwort.
Soll heissen wenn ich micht hier lang hangle solle es also klappen.
Ich hoffe das ich mich zu dem Thema nicht mehr melden muss
(befürchte jedoch schon, es wäre das erste mal das bei mir auf anhieb was klappt)Gruß Duffy
Zack und schon kommt die erste rote Meldung ganz unten:
Nach
sudo apt -o APT::Get::Trivial-Only=true full-upgradekommt:
pi@raspberrypi:~ $ sudo apt -o APT::Get::Trivial-Only=true full-upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: g++-12 gdisk libabsl20220623 libappstream4 libassuan0 libavif15 libblockdev-crypto2 libblockdev-loop2 libblockdev-part-err2 libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2 libboost-filesystem1.74.0 libboost-log1.74.0 libboost-program-options1.74.0 libboost-regex1.74.0 libboost-thread1.74.0 libcbor0.8 libdav1d6 libflac12 libfmt9 libfuse3-3 libicu72 libjim0.81 libjsoncpp25 libldap-2.5-0 libnsl-dev libpthread-stubs0-dev libpython3.11 libpython3.11-minimal libpython3.11-stdlib libqt5core5a librav1e0 librhash0 libstdc++-12-dev libsvtav1enc1 libtirpc-dev libunwind8 libx265-199 linux-headers-6.12.25+rpt-common-rpi linux-kbuild-6.12.25+rpt p7zip pkexec python3-six python3-toml python3.11 python3.11-minimal triggerhappy x11proto-core-dev Use 'sudo apt autoremove' to remove them. The following packages will be REMOVED: libarchive13 libasound2 libatopology2 libblockdev-fs2 libcurl3-gnutls libcurl4 libdb5.3 libdebuginfod1 libdvdread8 libdw1 libelf1 libevent-core-2.1-7 libext2fs2 libfreetype6-dev libgdbm-compat4 libgdbm6 libglib2.0-0 libgnutls30 libgpgme11 libgpiod2 libhogweed6 libiw30 liblttng-ust-common1 liblttng-ust-ctl5 liblttng-ust1 libmagic1 libmtp9 libnettle8 libnpth0 libntfs-3g89 libparted-fs-resize0 libparted2 libpcap0.8 libpng16-16 libpsl5 libreadline8 libsource-highlight4v5 libssh2-1 libssl3 libtirpc3 libuv1 libv4l-0 libv4l2rds0 libv4lconvert0 policykit-1 polkitd-pkla python3-distutils python3-lib2to3 python3-spidev The following NEW packages will be installed: 7zip bsd-mailx bzip2-doc cpp-14 cpp-14-aarch64-linux-gnu cpp-aarch64-linux-gnu dracut-install exim4-base exim4-config exim4-daemon-light firmware-ath9k-htc firmware-carl9170 fonts-dejavu-mono g++-14 g++-14-aarch64-linux-gnu g++-aarch64-linux-gnu gcc-14 gcc-14-aarch64-linux-gnu gcc-14-base gcc-aarch64-linux-gnu gir1.2-freedesktop-dev gir1.2-girepository-2.0 gir1.2-glib-2.0-dev girepository-tools initramfs-tools-bin libabsl20240722 libappstream5 libapt-pkg7.0 libarchive13t64 libasound2t64 libassuan9 libatopology2t64 libavif16 libb2-1 libblockdev-crypto3 libblockdev-fs3 libblockdev-loop3 libblockdev-mdraid3 libblockdev-nvme3 libblockdev-part3 libblockdev-swap3 libblockdev-utils3 libblockdev3 libboost-filesystem1.83.0 libboost-log1.83.0 libboost-program-options1.83.0 libboost-thread1.83.0 libbytesize-common libbytesize1 libbz2-dev libcap-dev libcbor0.10 libcurl3t64-gnutls libcurl4t64 libdav1d-dev libdav1d7 libdb5.3t64 libdebuginfod1t64 libdvdread8t64 libdw1t64 libelf1t64 libevent-2.1-7t64 libevent-core-2.1-7t64 libext2fs2t64 libflac14 libfmt10 libfuse3-4 libgcc-14-dev libgdbm-compat4t64 libgdbm6t64 libgio-2.0-dev libgio-2.0-dev-bin libgirepository-2.0-0 libglib2.0-0t64 libgnutls-dane0t64 libgnutls30t64 libgpgme11t64 libgpiod3 libharfbuzz-cairo0 libheif-plugin-aomenc libheif-plugin-dav1d libheif-plugin-libde265 libheif-plugin-x265 libhogweed6t64 libicu76 libidn12 libimagequant0 libiw30t64 libjim0.83 libjsoncpp26 liblastlog2-2 libldap2 liblockfile-bin liblockfile1 liblttng-ust-common1t64 liblttng-ust-ctl5t64 liblttng-ust1t64 libmagic1t64 libmtp9t64 libnetplan1 libnettle8t64 libnghttp3-9 libngtcp2-16 libngtcp2-crypto-gnutls8 libnpth0t64 libntfs-3g89t64 libnvme1t64 libpam-doc libparted2t64 libpcap0.8t64 libperl5.40 libpng16-16t64 libpsl5t64 libpython3.13 libpython3.13-minimal libpython3.13-stdlib libqt6core6t64 librav1e0.7 libreadline8t64 librhash1 libsframe1 libsharpyuv-dev libsharpyuv0 libsource-highlight4t64 libssh2-1t64 libssl3t64 libstdc++-14-dev libsvtav1enc2 libsysprof-capture-4-dev libsystemd-dev libtirpc3t64 libunbound8 libunistring5 libuv1t64 libv4l-0t64 libv4l2rds0t64 libv4lconvert0t64 libwebpdecoder3 libwtmpdb0 libx265-215 libxml2-dev linux-sysctl-defaults login.defs native-architecture netplan-generator netplan.io network-manager-l10n openssl-provider-legacy pahole perl-modules-5.40 python3-autocommand python3-bcrypt python3-inflect python3-jaraco.context python3-jaraco.functools python3-linkify-it python3-markdown-it python3-mdurl python3-more-itertools python3-netplan python3-packaging python3-pygments python3-rich python3-typeguard python3-typing-extensions python3-uc-micro python3-yaml python3.13 python3.13-minimal qt6-translations-l10n retry sqv systemd-cryptsetup xdg-user-dirs The following packages will be upgraded: acl adduser alsa-topology-conf alsa-ucm-conf alsa-utils apparmor appstream apt apt-listchanges apt-transport-https apt-utils avahi-daemon base-files base-passwd bash bash-completion binutils binutils-aarch64-linux-gnu binutils-common bluez bluez-firmware bsdextrautils bsdutils build-essential busybox bzip2 ca-certificates cifs-utils cmake cmake-data console-setup console-setup-linux coreutils cpio cpp cpp-12 cron cron-daemon-common curl dash dbus dbus-bin dbus-daemon dbus-session-bus-common dbus-system-bus-common dbus-user-session dc dconf-cli debconf debconf-i18n debconf-utils debian-archive-keyring debianutils device-tree-compiler diffutils dirmngr distro-info distro-info-data dmidecode dmsetup dns-root-data dnsmasq-base dos2unix dosfstools dphys-swapfile dpkg dpkg-dev e2fsprogs ed eject ethtool exfatprogs fake-hwclock fakeroot fbset fdisk file findutils firmware-atheros firmware-brcm80211 firmware-intel-graphics firmware-intel-misc firmware-libertas firmware-linux-free firmware-marvell-prestera firmware-mediatek firmware-misc-nonfree firmware-nvidia-graphics firmware-realtek flashrom fontconfig fontconfig-config fonts-dejavu-core fuse3 g++ g++-12 gcc gcc-12 gcc-12-base gdb gdisk gettext-base gir1.2-freedesktop gir1.2-gdkpixbuf-2.0 gir1.2-glib-2.0 gir1.2-harfbuzz-0.0 gir1.2-packagekitglib-1.0 gir1.2-pango-1.0 gir1.2-rsvg-2.0 git git-man gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv grep groff-base gzip hostname htop icu-devtools ifupdown init init-system-helpers initramfs-tools initramfs-tools-core iproute2 iputils-ping isc-dhcp-client isc-dhcp-common iso-codes iw kbd keyboard-configuration keyutils klibc-utils kmod kms++-utils less libacl1 libalgorithm-diff-xs-perl libaom3 libapparmor1 libargon2-1 libasan8 libasound2-data libatasmart4 libatomic1 libattr1 libaudit-common libaudit1 libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libbabeltrace1 libbinutils libblkid-dev libblkid1 libbluetooth3 libbpf1 libbrotli-dev libbrotli1 libbsd0 libbz2-1.0 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev libcairo-gobject2 libcairo-script-interpreter2 libcairo2 libcairo2-dev libcamera-ipa libcamera0.5 libcap-ng0 libcap2 libcap2-bin libcc1-0 libcom-err2 libcrypt-dev libcrypt1 libcryptsetup12 libctf-nobfd0 libctf0 libdaemon0 libdatrie-dev libdatrie1 libdbus-1-3 libdbus-1-dev libdconf1 libde265-0 libdebconfclient0 libdebuginfod-common libdeflate-dev libdeflate0 libdevmapper1.02.1 libdouble-conversion3 libdpkg-perl libdrm-common libdrm2 libdtovl0 libduktape207 libebml5 libedit2 liberror-perl libexif12 libexpat1 libexpat1-dev libfakeroot libfdisk1 libfdt1 libffi-dev libffi8 libfftw3-single3 libfido2-1 libfile-fcntllock-perl libfile-find-rule-perl libfontconfig-dev libfontconfig1 libfreetype-dev libfreetype6 libfribidi-dev libfribidi0 libftdi1-2 libgav1-1 libgcc-12-dev libgcc-s1 libgcrypt20 libgd3 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgif-dev libgif7 libgirepository-1.0-1 libglib2.0-bin libglib2.0-data libglib2.0-dev libglib2.0-dev-bin libgmp10 libgomp1 libgpg-error0 libgpiod-dev libgpiolib0 libgprofng0 libgraphite2-3 libgraphite2-dev libgssapi-krb5-2 libgstreamer1.0-0 libgudev-1.0-0 libharfbuzz-dev libharfbuzz-gobject0 libharfbuzz-icu0 libharfbuzz-subset0 libharfbuzz0b libheif1 libhwasan0 libice-dev libice6 libicu-dev libidn2-0 libip4tc2 libisl23 libitm1 libjansson4 libjaylink0 libjbig-dev libjbig0 libjpeg-dev libjpeg62-turbo libjpeg62-turbo-dev libjson-c5 libk5crypto3 libkeyutils1 libklibc libkmod2 libkms++0 libkrb5-3 libkrb5support0 libksba8 libldap-common liblerc-dev liblerc4 liblgpio1 liblocale-gettext-perl liblsan0 libluajit-5.1-2 libluajit-5.1-common liblz4-1 liblzma-dev liblzma5 liblzo2-2 libmagic-mgc libmatroska7 libmbim-glib4 libmbim-proxy libmbim-utils libmd0 libmm-glib0 libmnl0 libmount-dev libmount1 libmpc3 libmpfr6 libmtp-common libmtp-runtime libncursesw6 libndp0 libnetfilter-conntrack3 libnewt0.52 libnfnetlink0 libnfsidmap1 libnftables1 libnftnl11 libnghttp2-14 libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnm0 libnsl-dev libnsl2 libnspr4 libnss-mdns libnss3 libnuma1 libogg0 libossp-uuid16 libp11-kit0 libpackagekit-glib2-18 libpam-chksshpwd libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libpam0g-dev libpango-1.0-0 libpango1.0-dev libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libpci3 libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev libpcre2-posix3 libpcsclite1 libpipeline1 libpisp-common libpisp1 libpixman-1-0 libpixman-1-dev libpkgconf3 libpng-dev libpng-tools libpolkit-agent-1-0 libpolkit-gobject-1-0 libpopt0 libproc2-0 libpthread-stubs0-dev libpugixml1v5 libpython3-stdlib libqmi-glib5 libqmi-proxy libqmi-utils libqrtr-glib0 librpicam-app1 librsvg2-2 librsvg2-common librsvg2-dev librtmp1 libsamplerate0 libsasl2-2 libsasl2-modules libsasl2-modules-db libseccomp2 libselinux1 libselinux1-dev libsemanage-common libsemanage2 libsepol-dev libsepol2 libslang2 libsm-dev libsm6 libsmartcols1 libsource-highlight-common libsqlite3-0 libss2 libstdc++-12-dev libstdc++6 libstemmer0d libsystemd-shared libsystemd0 libtalloc2 libtasn1-6 libteamdctl0 libtext-charwidth-perl libtext-iconv-perl libthai-data libthai-dev libthai0 libtiff-dev libtiff6 libtiffxx6 libtinfo6 libtirpc-common libtirpc-dev libtsan2 libubsan1 libuchardet0 libudev-dev libudev1 libudisks2-0 libunwind8 libusb-1.0-0 libuuid1 libvolume-key1 libvorbis0a libwbclient0 libwebp-dev libwebp7 libwebpdemux2 libwebpmux3 libwrap0 libx11-6 libx11-data libx11-dev libxau-dev libxau6 libxcb-render0 libxcb-render0-dev libxcb-shm0 libxcb-shm0-dev libxcb1 libxcb1-dev libxdmcp-dev libxdmcp6 libxext-dev libxext6 libxft-dev libxft2 libxml2 libxmlb2 libxmuu1 libxpm4 libxrender-dev libxrender1 libxtables12 libxxhash0 libyaml-0-2 libyuv0 libzstd-dev libzstd1 linux-base linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.34+rpt-rpi-2712 linux-headers-6.12.34+rpt-rpi-v8 linux-headers-6.12.47+rpt-common-rpi linux-headers-6.12.47+rpt-rpi-2712 linux-headers-6.12.47+rpt-rpi-v8 linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-6.12.34+rpt-rpi-2712 linux-image-6.12.34+rpt-rpi-v8 linux-image-6.12.47+rpt-rpi-2712 linux-image-6.12.47+rpt-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-libc-dev locales login logrotate logsave lsb-release lua5.1 luajit make man-db manpages manpages-dev mawk media-types mkvtoolnix modemmanager mount musl nano ncdu ncurses-base ncurses-bin ncurses-term net-tools netbase network-manager nfs-common nftables ntfs-3g openssh-client openssh-server openssh-sftp-server openssl p7zip p7zip-full packagekit packagekit-tools pango1.0-tools parted passwd pastebinit patch pci.ids pciutils perl perl-base pinentry-curses pkexec pkg-config pkgconf pkgconf-bin polkitd ppp procps psmisc publicsuffix python-apt-common python-is-python3 python3 python3-apt python3-blinker python3-certifi python3-cffi-backend python3-chardet python3-charset-normalizer python3-colorzero python3-cryptography python3-dbus python3-debconf python3-distro python3-gi python3-gpiozero python3-httplib2 python3-idna python3-jwt python3-lazr.restfulclient python3-lazr.uri python3-lgpio python3-libgpiod python3-minimal python3-oauthlib python3-pkg-resources python3-pycryptodome python3-pyparsing python3-requests python3-rpi.gpio python3-six python3-smbus2 python3-urllib3 python3-wadllib raspberrypi-archive-keyring raspberrypi-net-mods raspberrypi-sys-mods raspi-config raspi-firmware raspi-utils raspi-utils-core raspi-utils-dt raspi-utils-eeprom raspi-utils-otp raspinfo readline-common rfkill rpcbind rpcsvc-proto rpi-eeprom rpi.gpio-common rpicam-apps-core rsync runit-helper sed sensible-utils sgml-base shared-mime-info ssh ssh-import-id strace sudo systemd systemd-sysv systemd-timesyncd sysvinit-utils tar tasksel tasksel-data triggerhappy tzdata ucf udev udisks2 unzip usb-modeswitch usb-modeswitch-data usbutils userconf-pi usrmerge util-linux util-linux-extra uuid uuid-dev v4l-utils vim-common vim-tiny wget whiptail wireless-regdb wireless-tools wpasupplicant x11-common x11proto-core-dev x11proto-dev xauth xkb-data xml-core xz-utils zip zlib1g zlib1g-dev zstd 648 upgraded, 174 newly installed, 49 to remove and 0 not upgraded. Need to get 714 MB of archives. After this operation, 508 MB of additional disk space will be used. E: Trivial Only specified but this is not a trivial operation.
Soll ich nun einfach weiter amchen?
Ja, weiter.
Oh weh, jetzt kam bei mir schon 2 mal die Frage mit den "q"
Nach
sudo apt upgrade --without-new-pkgshabe ich
sudo apt full-upgradegemacht und da kam das 2 mal "q" das habe ich auch gedrückt.
und jetzt kommt die Meldung:
==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** login.defs (Y/I/N/O/D/Z) [default=N] ?Was muss ich da tun?
@duffy sagte in Update von Debian 12 auf 13 möglich?:
Kommt darauf an welche Konfig-Datei das ist und was du da abweichendes eingestellt hast. Mit
dkannst du die Unterschiede ja sehen. -
Ich wüste nicht was ich gemacht haben solle ich bin explizit der Beschreibung gefolgt:
Nach "d" kommt das:--- /etc/login.defs 2023-10-10 05:41:38.092990100 +0200 +++ /etc/login.defs.dpkg-new 2025-04-19 12:20:28.000000000 +0200 @@ -1,14 +1,6 @@ # -# /etc/login.defs - Configuration control definitions for the login package. +# /etc/login.defs - Configuration control definitions for the shadow package. # -# Three items must be defined: MAIL_DIR, ENV_SUPATH, and ENV_PATH. -# If unspecified, some arbitrary (and possibly incorrect) value will -# be assumed. All other items are optional - if not specified then -# the described action or option will be inhibited. -# -# Comment lines (lines beginning with "#") and blank lines are ignored. -# -# Modified for Linux. --marekm # REQUIRED for useradd/userdel/usermod # Directory where mailboxes reside, _or_ name of file, relative to the @@ -36,15 +28,9 @@ #MAIL_FILE .mail # -# Enable logging and display of /var/log/faillog login failure info. -# This option conflicts with the pam_tally PAM module. -# -FAILLOG_ENAB yes - -# lines 1-28 Progress: [ 29%] [############################......................................................................]wie komme ich jetzt weiter?
Hier würde ich die Version des Package Maintainers übernehmen.
Y or I : install the package maintainer's version -
und wo muss ich y oder I eingeben? Es ist ja kein Feld dafür da?
Ich seh mich schon alles neu machen ;-( -
@duffy
Mitqaus der Anzeige raus. -
Danke.
hier und da kommen solche Mledungenist das normal?
Preparing to unpack .../udev_257.8-1~deb13u2_arm64.deb ... Unpacking udev (257.8-1~deb13u2) over (252.39-1~deb12u1) ... dpkg: warning: unable to delete old directory '/lib/udev/hwdb.d': Directory not empty dpkg: warning: unable to delete old directory '/lib/systemd/system/sysinit.target.wants': Directory not empty dpkg: warning: unable to delete old directory '/lib/systemd/system/sockets.target.wants': Directory not empty dpkg: warning: unable to delete old directory '/lib/systemd/network': Directory not empty dpkg: warning: unable to delete old directory '/lib/modprobe.d': Directory not empty Preparing to unpack .../libudev1_257.8-1~deb13u2_arm64.deb ... -
Ja, ist normal. In den Verzeichnissen sind ja die Dateien des vorherigen Releases noch drin.
OK.
Wen das jetzt durchgelaufen ist mit:
"Das Spiel mit
sudo apt update
sudo apt full-upgrade"weiter machen?
nicht das wieder ein "q" auftaucht
Ich kann nicht jede Taste vorhersehen, dafür sind die Systeme jeweils zu unterschiedlich. Was hast du denn für eine Panik vor Rückfragen des Systems?
Bitte nicht falsch versten das sollte in keinster weise ein Vorwurf sein.
Ich habe nur echt Panik in dem Linux rum zu fummeln das endet bei mir in der Regel in Dramen.pi@raspberrypi:~ $ sudo apt full-upgrade The following packages were automatically installed and are no longer required: g++-12 libboost-filesystem1.74.0 libldap-2.5-0 libx265-199 gdisk libboost-log1.74.0 libnsl-dev linux-headers-6.12.25+rpt-common-rpi libabsl20220623 libboost-program-options1.74.0 libpthread-stubs0-dev linux-kbuild-6.12.25+rpt libappstream4 libboost-regex1.74.0 libpython3.11 p7zip libassuan0 libboost-thread1.74.0 libpython3.11-minimal pkexec libavif15 libcbor0.8 libpython3.11-stdlib python3-six libblockdev-crypto2 libdav1d6 libqt5core5a python3-toml libblockdev-loop2 libflac12 librav1e0 python3.11 libblockdev-part-err2 libfmt9 librhash0 python3.11-minimal libblockdev-part2 libfuse3-3 libstdc++-12-dev triggerhappy libblockdev-swap2 libicu72 libsvtav1enc1 x11proto-core-dev libblockdev-utils2 libjim0.81 libtirpc-dev libblockdev2 libjsoncpp25 libunwind8 Use 'sudo apt autoremove' to remove them. Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0ich würde das jetzt mal enfernen mit
'sudo apt autoremove -
Ich habe jetzt nach der Prozedur noch mal iob diag gemacht.
Für mich sieht es so aus als wenn alles ok ist was aber bei mir nichts heißen soll.
schaust bitte noch ml drüber?Script v.2025-08-09 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.12.47+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 08:21:43 up 5 min, 1 user, load average: 4.23, 3.20, 1.45 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Tue 2025-10-14 08:21:43 CEST Universal time: Tue 2025-10-14 06:21:43 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker SUDO_HOME=/home/pi GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 3.4G 3.1G 13M 1.8G 4.8G Swap: 209M 0B 209M Total: 8.4G 3.4G 3.3G Active iob-Instances: 37 7819 M total memory 3241 M used memory 4238 M active memory 408 M inactive memory 2956 M free memory 84 M buffer memory 1650 M swap cache 199 M total swap 0 M used swap 199 M free swap *** top - Table Of Processes *** top - 08:21:44 up 5 min, 1 user, load average: 4.23, 3.20, 1.45 Tasks: 227 total, 1 running, 226 sleeping, 0 stopped, 0 zombie %Cpu(s): 4.3 us, 2.1 sy, 0.0 ni, 93.6 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7819.7 total, 2956.1 free, 3241.2 used, 1735.1 buff/cache MiB Swap: 200.0 total, 200.0 free, 0.0 used. 4578.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 1.6G 11M 1.6G 1% /run /dev/sda2 ext4 29G 12G 16G 44% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock tmpfs tmpfs 3.9G 2.5M 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service /dev/sda1 vfat 510M 74M 437M 15% /boot/firmware tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 782M 8.0K 782M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Oct 14 08:16:05 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:36:CB:32 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=dd528ea5-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Oct 14 08:16:07 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none. [Tue Oct 14 08:16:10 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.5G /var/ 1.5G /var/log/journal/458ebafb08a8432dbfe417c962c32f87 1.5G /var/log/journal 1.5G /var/log 594M /var/lib Archived and active journals take up 1.4G in the file system. /opt/iobroker/backups: 940M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 595M /opt/iobroker/iobroker-data/ 425M /opt/iobroker/iobroker-data/files 116M /opt/iobroker/iobroker-data/backup-objects 74M /opt/iobroker/iobroker-data/files/vis 67M /opt/iobroker/iobroker-data/files/vis/widgets The five largest files in iobroker-data are: 38M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map 27M /opt/iobroker/iobroker-data/states.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 24M /opt/iobroker/iobroker-data/objects.jsonl 19M /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 *** ZigBee Settings *** Your zigbee.0 COM-Port is matching 'by-id'. Very good! Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v22.20.0 /usr/bin/node v22.20.0 /usr/bin/npm 10.9.3 /usr/bin/npx 10.9.3 /usr/bin/corepack 0.34.0 nodejs: Installed: 22.20.0-1nodesource1 Candidate: 22.20.0-1nodesource1 Version table: *** 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 20.19.2+dfsg-1 500 500 http://deb.debian.org/debian trixie/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: raspberrypi raspberrypi (version: 7.0.7, hostname: raspberrypi , alive, uptime: 347) Core adapters versions js-controller: 7.0.7 admin: 7.7.2 javascript: 8.9.2 nodejs modules from github: 1 +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a) Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.device-reminder.0 : device-reminder : raspberrypi - enabled + system.adapter.device-watcher.0 : device-watcher : raspberrypi - enabled system.adapter.discovery.0 : discovery : raspberrypi - disabled + system.adapter.drag-indicator.0 : drag-indicator : raspberrypi - enabled + system.adapter.echarts.0 : echarts : raspberrypi - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi - enabled + system.adapter.energiefluss.0 : energiefluss : raspberrypi - enabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - enabled + system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled + system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - enabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.matter.0 : matter : raspberrypi - enabled + system.adapter.mercedesme.0 : mercedesme : raspberrypi - enabled system.adapter.mqtt.0 : mqtt : raspberrypi - disabled, port: 1884, bind: 0.0.0.0 + system.adapter.mystrom.0 : mystrom : raspberrypi - enabled system.adapter.net-tools.0 : net-tools : raspberrypi - disabled + system.adapter.opendtu.0 : opendtu : raspberrypi - enabled + system.adapter.operating-hours.0 : operating-hours : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.sainlogic.0 : sainlogic : raspberrypi - enabled, port: 1847, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.statistics.0 : statistics : raspberrypi - enabled system.adapter.switchbot-hub.0 : switchbot-hub : raspberrypi - disabled + system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - enabled + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : raspberrypi - enabled + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi - enabled system.adapter.vis-2.0 : vis-2 : raspberrypi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled system.adapter.vis-weather.0 : vis-weather : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.1 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.influxdb.2 : influxdb : raspberrypi - enabled, port: 8086 + system.adapter.sainlogic.0 : sainlogic : raspberrypi - enabled, port: 1847, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Adapter "admin" : 7.7.2 , installed 7.7.2 Adapter "alexa2" : 3.27.3 , installed 3.27.3 Adapter "backitup" : 3.3.5 , installed 3.3.5 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.13.1 , installed 2.13.1 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "drag-indicator": 2.4.0 , installed 2.4.0 Adapter "echarts" : 1.9.2 , installed 2.0.8 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.7.7, installed 0.7.7 Adapter "feiertage" : 1.2.1 , installed 1.2.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "fullybrowser" : 3.1.2 , installed 3.1.2 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.17.0 , installed 1.17.0 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "javascript" : 8.9.2 , installed 8.9.2 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "matter" : 0.5.2 , installed 0.5.2 Adapter "mqtt" : 6.1.4 , installed 6.1.4 Adapter "net-tools" : 1.1.2 , installed 1.1.2 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "operating-hours": 1.3.0 , installed 1.3.0 Adapter "rpi2" : 2.4.0 , installed 2.4.0 Adapter "sainlogic" : 0.11.6 , installed 0.11.6 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.2.1 , installed 3.2.1 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.4 , installed 2.13.4 Adapter "vis-2-widgets-material": 1.4.10, installed 1.4.10 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.18.0 , installed 1.18.0 Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vis-weather" : 2.5.12 , installed 2.5.12 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "zigbee" : 3.0.5 , installed 3.0.5 Objects and States Please stand by - This may take a while Objects: 13565 States: 12503 *** OS-Repositories and Updates *** W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian-security trixie-security InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://archive.raspberrypi.com/debian trixie InRelease Hit:5 https://apt.grafana.com stable InRelease Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease Hit:7 https://repos.influxdata.com/debian stable InRelease Reading package lists... W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 9684 1158/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 7789 1158/iobroker.js-co tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 6885 1112/exim4 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 8372 809/sshd: /usr/sbin tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 8879 1450/io.sonoff.0 tcp 0 0 0.0.0.0:1847 0.0.0.0:* LISTEN 1001 13530 1887/io.sainlogic.0 tcp6 0 0 :::3000 :::* LISTEN 106 6962 1157/grafana tcp6 0 0 :::8081 :::* LISTEN 1001 8594 1204/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 11748 1819/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 999 6907 825/influxd tcp6 0 0 :::8087 :::* LISTEN 1001 12438 1842/io.simple-api. tcp6 0 0 :::22 :::* LISTEN 0 8374 809/sshd: /usr/sbin tcp6 0 0 ::1:25 :::* LISTEN 0 6886 1112/exim4 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 14406 1902/io.matter.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 12518 1902/io.matter.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 10997 1902/io.matter.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 10989 1902/io.matter.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 2012 575/avahi-daemon: r udp 0 0 0.0.0.0:34368 0.0.0.0:* 104 2014 575/avahi-daemon: r udp 0 0 0.0.0.0:49974 0.0.0.0:* 1001 11006 1902/io.matter.0 udp6 0 0 :::5353 :::* 1001 14407 1902/io.matter.0 udp6 0 0 :::5353 :::* 1001 12519 1902/io.matter.0 udp6 0 0 :::5353 :::* 1001 11000 1902/io.matter.0 udp6 0 0 :::5353 :::* 1001 10992 1902/io.matter.0 udp6 0 0 :::5353 :::* 104 2013 575/avahi-daemon: r udp6 0 0 :::52715 :::* 104 2015 575/avahi-daemon: r udp6 0 0 fe80::e5bd:4ca9:170:546 :::* 0 6085 691/NetworkManager udp6 0 0 :::49974 :::* 1001 11005 1902/io.matter.0 *** Log File - Last 25 Lines *** 2025-10-14 08:20:28.151 - info: sourceanalytix.0 (1716) Initialization of 0_userdata.0.PV_Ersparnis.Ersparnis_kWh_2PVs successfully 2025-10-14 08:20:28.152 - info: sourceanalytix.0 (1716) Initialising (9 of 9) "0_userdata.0.PV_Einspeisung.PV_Einspeisung_kWh_2PVs" 2025-10-14 08:20:31.519 - info: sourceanalytix.0 (1716) Initialization of 0_userdata.0.PV_Einspeisung.PV_Einspeisung_kWh_2PVs successfully 2025-10-14 08:20:31.547 - info: sourceanalytix.0 (1716) Successfully activated SourceAnalytix for 9 of 9 states, will do my Job until you stop me! 2025-10-14 08:20:42.108 - info: matter.0 (1902) Node "10769786468529638926" offline, waiting for device discovery 2025-10-14 08:20:42.845 - info: matter.0 (1902) Node "11901481590481904095" offline, waiting for device discovery 2025-10-14 08:21:11.351 - info: alexa2.0 (1592) Unknown Device, but enabling commands, Try it and report back if commands work. 2025-10-14 08:21:11.352 - info: alexa2.0 (1592) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted 2025-10-14 08:21:11.352 - info: alexa2.0 (1592) Device-type:A2V9UEGZ82H4KZ - Fire SZ (MICROPHONE,ASX_TIME_ZONE,TIMERS_AND_ALARMS,SUPPORTS_SOFTWARE_VERSION,ADAPTIVE_LISTENING,VOLUME_SETTING,NO_TIME_ZONE_SETTING,PERSISTENT_CONNECTION,REMINDERS) 2025-10-14 08:21:17.625 - info: alexa2.0 (1592) Unknown Device, but enabling commands, Try it and report back if commands work. 2025-10-14 08:21:17.626 - info: alexa2.0 (1592) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted 2025-10-14 08:21:17.627 - info: alexa2.0 (1592) Device-type:A2QCPPMSOLGVZE - Fire Max (AUDIBLE,VOICE_TRAINING,SUPPORTS_SOFTWARE_VERSION,SIRIUSXM,ARTHUR_TARGET,SET_LOCALE,VOLUME_SETTING,SALMON,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,MICROPHONE,AMAZON_MUSIC,AUDIO_PLAYER,PANDORA,SLEEP,CHANGE_NAME,KINDLE_BOOKS,SUPPORTS_CONNECTED_HOME_ALL,ASCENDING_ALARM_VOLUME,FLASH_BRIEFING,CUSTOM_ALARM_TONE,MUSIC_SKILL,DEEZER,TIMERS_AND_ALARMS,ACTIVE_AFTER_FRO,TAHOE_BYOD,SHARKNADO,TUNE_IN,ADAPTIVE_LISTENING,EARCONS,TIDAL,REMINDERS,DREAM_TRAINING,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,TIMEZONE,I_HEART_RADIO,PERSISTENT_CONNECTION,REQUIRES_OOBE_FOR_SETUP,APPLE_MUSIC) 2025-10-14 08:21:20.258 - info: javascript.0 (1321) script.js.Arbeitszimmer.Fire_Tablet_Arbeitszimmer_an: true 2025-10-14 08:21:20.539 - info: javascript.0 (1321) script.js.Arbeitszimmer.Fire_Tablet_Arbeitszimmer_an: true 2025-10-14 08:21:20.866 - info: fullybrowser.0 (1577) 🗸 192.168.178.157: Command screenOn successfully set to true 2025-10-14 08:21:21.075 - info: fullybrowser.0 (1577) 🗸 192.168.178.157: Command screenOn successfully set to true 2025-10-14 08:21:37.961 - info: web.0 (1819) ==> Connected system.user.admin from ::ffff:192.168.178.157 2025-10-14 08:21:38.636 - info: alexa2.0 (1592) Subscribing to states... 2025-10-14 08:21:38.653 - info: alexa2.0 (1592) Deleting the following states: ["Contacts.AF2FSLWZXZPZ7SST2UEDH5LRWD5Q","Contacts.AF2FSLWZXZPZ7SST2UEDH5LRWD5Q.textMessage"] 2025-10-14 08:21:41.016 - info: alexa2.0 (1592) Alexa-Push-Connection (macDms = true) established. Disable Polling 2025-10-14 08:22:01.584 - info: alexa2.0 (1592) Initialization Done ... 2025-10-14 08:23:11.221 - info: fritzdect.0 (1671) DECT ID: 130770157104-1 identified for command (state) : false 2025-10-14 08:23:11.618 - info: fritzdect.0 (1671) DECT ID: 130770143150-1 identified for command (state) : false 2025-10-14 08:23:11.620 - info: fritzdect.0 (1671) DECT ID: 130770137317-1 identified for command (state) : false 2025-10-14 08:23:11.623 - info: fritzdect.0 (1671) DECT ID: 130770274810-1 identified for command (state) : falseVG Duffy
Ja, passt.
Vielen Dank für deinen Support!!
Jetzt hoffe ich das der nächste Nachfolger von Trixie 10 Jahre auf sich warten lässt was nicht so sein wird
Soll ich das auch schon umstrellen?
sudo apt modernize-sourcesVG Duffy und noch mal vielen Dank
Debian 14 'Forky' kommt im Sommer 2027. Alle zwei Jahre kommt ein neues Debian Stable heraus.
2029 betritt dann Debian 15 'Duke' die Bühne.
Kann man alles sehr gut planen.https://www.debian.org/releases/forky/
Kannste machen, kannste auch im Moment bleiben lassen. Beide Formate der Quellendefinitionen funktionieren.
Guten Morgen,
ich habe
sudo apt modernize-sourcesmal mit "N" simuliert und es kam am ende eine Warnung.
pi@raspberrypi:~ $ sudo apt modernize-sources The following files need modernizing: - /etc/apt/sources.list - /etc/apt/sources.list.d/grafana.list - /etc/apt/sources.list.d/influxdata.list - /etc/apt/sources.list.d/nodesource.list - /etc/apt/sources.list.d/raspi.list Modernizing will replace .list files with the new .sources format, add Signed-By values where they can be determined automatically, and save the old files into .list.bak files. This command supports the 'signed-by' and 'trusted' options. If you have specified other options inside [] brackets, please transfer them manually to the output files; see sources.list(5) for a mapping. For a simulation, respond N in the following prompt. Rewrite 5 sources? [Y/n] N Simulating only... Modernizing /etc/apt/sources.list... # Would write to: /etc/apt/sources.list.d/debian.sources # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg # Would write to: /etc/apt/sources.list.d/debian.sources # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian-security/ Suites: trixie-security Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg # Would write to: /etc/apt/sources.list.d/debian.sources # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie-updates Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg Modernizing /etc/apt/sources.list.d/grafana.list... # Would write to: /etc/apt/sources.list.d/grafana.sources Types: deb URIs: https://apt.grafana.com/ Suites: stable Components: main Signed-By: /etc/apt/keyrings/grafana.gpg Modernizing /etc/apt/sources.list.d/influxdata.list... # Would write to: /etc/apt/sources.list.d/influxdata.sources Types: deb URIs: https://repos.influxdata.com/debian/ Suites: stable Components: main Signed-By: /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg Modernizing /etc/apt/sources.list.d/nodesource.list... # Would write to: /etc/apt/sources.list.d/nodesource.sources Types: deb URIs: https://deb.nodesource.com/node_22.x/ Suites: nodistro Components: main Signed-By: /etc/apt/keyrings/nodesource.gpg Modernizing /etc/apt/sources.list.d/raspi.list... # Would write to: /etc/apt/sources.list.d/raspi.sources Types: deb URIs: http://archive.raspberrypi.com/debian/ Suites: trixie Components: main Signed-By: Warning: Could not determine Signed-By for URIs: http://archive.raspberrypi.com/debian/, Suites: trixie pi@raspberrypi:~ $Warning: Could not determine Signed-By for URIs: http://archive.raspberrypi.com/debian/, Suites: trixieKann ich die ignorieren oder wird mir die Probleme machen?
VG Duffy
Nicht ignorieren.
Die Datei schaut vollständig so aus:Types: deb URIs: http://archive.raspberrypi.com/debian/ Suites: trixie Components: main Signed-By: /usr/share/keyrings/raspberrypi-archive-keyring.pgp
