    3. Einsteigerfragen
    4. Update von Debian 12 auf 13 möglich?
    • Duffy
      Duffy @Duffy last edited by
      @Thomas-Braun
      Zack und schon kommt die erste rote Meldung ganz unten:
      Nach
      sudo apt -o APT::Get::Trivial-Only=true full-upgrade
      kommt:
      pi@raspberrypi:~ $ sudo apt -o APT::Get::Trivial-Only=true full-upgrade
      Reading package lists... Done
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        g++-12 gdisk libabsl20220623 libappstream4 libassuan0 libavif15 libblockdev-crypto2 libblockdev-loop2
        libblockdev-part-err2 libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2 libboost-filesystem1.74.0
        libboost-log1.74.0 libboost-program-options1.74.0 libboost-regex1.74.0 libboost-thread1.74.0 libcbor0.8 libdav1d6
        libflac12 libfmt9 libfuse3-3 libicu72 libjim0.81 libjsoncpp25 libldap-2.5-0 libnsl-dev libpthread-stubs0-dev
        libpython3.11 libpython3.11-minimal libpython3.11-stdlib libqt5core5a librav1e0 librhash0 libstdc++-12-dev
        libsvtav1enc1 libtirpc-dev libunwind8 libx265-199 linux-headers-6.12.25+rpt-common-rpi linux-kbuild-6.12.25+rpt
        p7zip pkexec python3-six python3-toml python3.11 python3.11-minimal triggerhappy x11proto-core-dev
      Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
        libarchive13 libasound2 libatopology2 libblockdev-fs2 libcurl3-gnutls libcurl4 libdb5.3 libdebuginfod1 libdvdread8
        libdw1 libelf1 libevent-core-2.1-7 libext2fs2 libfreetype6-dev libgdbm-compat4 libgdbm6 libglib2.0-0 libgnutls30
        libgpgme11 libgpiod2 libhogweed6 libiw30 liblttng-ust-common1 liblttng-ust-ctl5 liblttng-ust1 libmagic1 libmtp9
        libnettle8 libnpth0 libntfs-3g89 libparted-fs-resize0 libparted2 libpcap0.8 libpng16-16 libpsl5 libreadline8
        libsource-highlight4v5 libssh2-1 libssl3 libtirpc3 libuv1 libv4l-0 libv4l2rds0 libv4lconvert0 policykit-1
        polkitd-pkla python3-distutils python3-lib2to3 python3-spidev
      The following NEW packages will be installed:
        7zip bsd-mailx bzip2-doc cpp-14 cpp-14-aarch64-linux-gnu cpp-aarch64-linux-gnu dracut-install exim4-base
        exim4-config exim4-daemon-light firmware-ath9k-htc firmware-carl9170 fonts-dejavu-mono g++-14
        g++-14-aarch64-linux-gnu g++-aarch64-linux-gnu gcc-14 gcc-14-aarch64-linux-gnu gcc-14-base gcc-aarch64-linux-gnu
        gir1.2-freedesktop-dev gir1.2-girepository-2.0 gir1.2-glib-2.0-dev girepository-tools initramfs-tools-bin
        libabsl20240722 libappstream5 libapt-pkg7.0 libarchive13t64 libasound2t64 libassuan9 libatopology2t64 libavif16
        libb2-1 libblockdev-crypto3 libblockdev-fs3 libblockdev-loop3 libblockdev-mdraid3 libblockdev-nvme3
        libblockdev-part3 libblockdev-swap3 libblockdev-utils3 libblockdev3 libboost-filesystem1.83.0 libboost-log1.83.0
        libboost-program-options1.83.0 libboost-thread1.83.0 libbytesize-common libbytesize1 libbz2-dev libcap-dev
        libcbor0.10 libcurl3t64-gnutls libcurl4t64 libdav1d-dev libdav1d7 libdb5.3t64 libdebuginfod1t64 libdvdread8t64
        libdw1t64 libelf1t64 libevent-2.1-7t64 libevent-core-2.1-7t64 libext2fs2t64 libflac14 libfmt10 libfuse3-4
        libgcc-14-dev libgdbm-compat4t64 libgdbm6t64 libgio-2.0-dev libgio-2.0-dev-bin libgirepository-2.0-0 libglib2.0-0t64
        libgnutls-dane0t64 libgnutls30t64 libgpgme11t64 libgpiod3 libharfbuzz-cairo0 libheif-plugin-aomenc
        libheif-plugin-dav1d libheif-plugin-libde265 libheif-plugin-x265 libhogweed6t64 libicu76 libidn12 libimagequant0
        libiw30t64 libjim0.83 libjsoncpp26 liblastlog2-2 libldap2 liblockfile-bin liblockfile1 liblttng-ust-common1t64
        liblttng-ust-ctl5t64 liblttng-ust1t64 libmagic1t64 libmtp9t64 libnetplan1 libnettle8t64 libnghttp3-9 libngtcp2-16
        libngtcp2-crypto-gnutls8 libnpth0t64 libntfs-3g89t64 libnvme1t64 libpam-doc libparted2t64 libpcap0.8t64 libperl5.40
        libpng16-16t64 libpsl5t64 libpython3.13 libpython3.13-minimal libpython3.13-stdlib libqt6core6t64 librav1e0.7
        libreadline8t64 librhash1 libsframe1 libsharpyuv-dev libsharpyuv0 libsource-highlight4t64 libssh2-1t64 libssl3t64
        libstdc++-14-dev libsvtav1enc2 libsysprof-capture-4-dev libsystemd-dev libtirpc3t64 libunbound8 libunistring5
        libuv1t64 libv4l-0t64 libv4l2rds0t64 libv4lconvert0t64 libwebpdecoder3 libwtmpdb0 libx265-215 libxml2-dev
        linux-sysctl-defaults login.defs native-architecture netplan-generator netplan.io network-manager-l10n
        openssl-provider-legacy pahole perl-modules-5.40 python3-autocommand python3-bcrypt python3-inflect
        python3-jaraco.context python3-jaraco.functools python3-linkify-it python3-markdown-it python3-mdurl
        python3-more-itertools python3-netplan python3-packaging python3-pygments python3-rich python3-typeguard
        python3-typing-extensions python3-uc-micro python3-yaml python3.13 python3.13-minimal qt6-translations-l10n retry
        sqv systemd-cryptsetup xdg-user-dirs
      The following packages will be upgraded:
        acl adduser alsa-topology-conf alsa-ucm-conf alsa-utils apparmor appstream apt apt-listchanges apt-transport-https
        apt-utils avahi-daemon base-files base-passwd bash bash-completion binutils binutils-aarch64-linux-gnu
        binutils-common bluez bluez-firmware bsdextrautils bsdutils build-essential busybox bzip2 ca-certificates cifs-utils
        cmake cmake-data console-setup console-setup-linux coreutils cpio cpp cpp-12 cron cron-daemon-common curl dash dbus
        dbus-bin dbus-daemon dbus-session-bus-common dbus-system-bus-common dbus-user-session dc dconf-cli debconf
        debconf-i18n debconf-utils debian-archive-keyring debianutils device-tree-compiler diffutils dirmngr distro-info
        distro-info-data dmidecode dmsetup dns-root-data dnsmasq-base dos2unix dosfstools dphys-swapfile dpkg dpkg-dev
        e2fsprogs ed eject ethtool exfatprogs fake-hwclock fakeroot fbset fdisk file findutils firmware-atheros
        firmware-brcm80211 firmware-intel-graphics firmware-intel-misc firmware-libertas firmware-linux-free
        firmware-marvell-prestera firmware-mediatek firmware-misc-nonfree firmware-nvidia-graphics firmware-realtek flashrom
        fontconfig fontconfig-config fonts-dejavu-core fuse3 g++ g++-12 gcc gcc-12 gcc-12-base gdb gdisk gettext-base
        gir1.2-freedesktop gir1.2-gdkpixbuf-2.0 gir1.2-glib-2.0 gir1.2-harfbuzz-0.0 gir1.2-packagekitglib-1.0
        gir1.2-pango-1.0 gir1.2-rsvg-2.0 git git-man gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client
        gpg-wks-server gpgconf gpgsm gpgv grep groff-base gzip hostname htop icu-devtools ifupdown init init-system-helpers
        initramfs-tools initramfs-tools-core iproute2 iputils-ping isc-dhcp-client isc-dhcp-common iso-codes iw kbd
        keyboard-configuration keyutils klibc-utils kmod kms++-utils less libacl1 libalgorithm-diff-xs-perl libaom3
        libapparmor1 libargon2-1 libasan8 libasound2-data libatasmart4 libatomic1 libattr1 libaudit-common libaudit1
        libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3
        libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libbabeltrace1 libbinutils libblkid-dev
        libblkid1 libbluetooth3 libbpf1 libbrotli-dev libbrotli1 libbsd0 libbz2-1.0 libc-bin libc-dev-bin libc-devtools
        libc-l10n libc6 libc6-dbg libc6-dev libcairo-gobject2 libcairo-script-interpreter2 libcairo2 libcairo2-dev
        libcamera-ipa libcamera0.5 libcap-ng0 libcap2 libcap2-bin libcc1-0 libcom-err2 libcrypt-dev libcrypt1
        libcryptsetup12 libctf-nobfd0 libctf0 libdaemon0 libdatrie-dev libdatrie1 libdbus-1-3 libdbus-1-dev libdconf1
        libde265-0 libdebconfclient0 libdebuginfod-common libdeflate-dev libdeflate0 libdevmapper1.02.1
        libdouble-conversion3 libdpkg-perl libdrm-common libdrm2 libdtovl0 libduktape207 libebml5 libedit2 liberror-perl
        libexif12 libexpat1 libexpat1-dev libfakeroot libfdisk1 libfdt1 libffi-dev libffi8 libfftw3-single3 libfido2-1
        libfile-fcntllock-perl libfile-find-rule-perl libfontconfig-dev libfontconfig1 libfreetype-dev libfreetype6
        libfribidi-dev libfribidi0 libftdi1-2 libgav1-1 libgcc-12-dev libgcc-s1 libgcrypt20 libgd3 libgdk-pixbuf-2.0-0
        libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgif-dev libgif7 libgirepository-1.0-1
        libglib2.0-bin libglib2.0-data libglib2.0-dev libglib2.0-dev-bin libgmp10 libgomp1 libgpg-error0 libgpiod-dev
        libgpiolib0 libgprofng0 libgraphite2-3 libgraphite2-dev libgssapi-krb5-2 libgstreamer1.0-0 libgudev-1.0-0
        libharfbuzz-dev libharfbuzz-gobject0 libharfbuzz-icu0 libharfbuzz-subset0 libharfbuzz0b libheif1 libhwasan0
        libice-dev libice6 libicu-dev libidn2-0 libip4tc2 libisl23 libitm1 libjansson4 libjaylink0 libjbig-dev libjbig0
        libjpeg-dev libjpeg62-turbo libjpeg62-turbo-dev libjson-c5 libk5crypto3 libkeyutils1 libklibc libkmod2 libkms++0
        libkrb5-3 libkrb5support0 libksba8 libldap-common liblerc-dev liblerc4 liblgpio1 liblocale-gettext-perl liblsan0
        libluajit-5.1-2 libluajit-5.1-common liblz4-1 liblzma-dev liblzma5 liblzo2-2 libmagic-mgc libmatroska7 libmbim-glib4
        libmbim-proxy libmbim-utils libmd0 libmm-glib0 libmnl0 libmount-dev libmount1 libmpc3 libmpfr6 libmtp-common
        libmtp-runtime libncursesw6 libndp0 libnetfilter-conntrack3 libnewt0.52 libnfnetlink0 libnfsidmap1 libnftables1
        libnftnl11 libnghttp2-14 libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnm0 libnsl-dev libnsl2 libnspr4
        libnss-mdns libnss3 libnuma1 libogg0 libossp-uuid16 libp11-kit0 libpackagekit-glib2-18 libpam-chksshpwd
        libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libpam0g-dev libpango-1.0-0 libpango1.0-dev
        libpangocairo-1.0-0 libpangoft2-1.0-0 libpangoxft-1.0-0 libpci3 libpcre2-16-0 libpcre2-32-0 libpcre2-8-0
        libpcre2-dev libpcre2-posix3 libpcsclite1 libpipeline1 libpisp-common libpisp1 libpixman-1-0 libpixman-1-dev
        libpkgconf3 libpng-dev libpng-tools libpolkit-agent-1-0 libpolkit-gobject-1-0 libpopt0 libproc2-0
        libpthread-stubs0-dev libpugixml1v5 libpython3-stdlib libqmi-glib5 libqmi-proxy libqmi-utils libqrtr-glib0
        librpicam-app1 librsvg2-2 librsvg2-common librsvg2-dev librtmp1 libsamplerate0 libsasl2-2 libsasl2-modules
        libsasl2-modules-db libseccomp2 libselinux1 libselinux1-dev libsemanage-common libsemanage2 libsepol-dev libsepol2
        libslang2 libsm-dev libsm6 libsmartcols1 libsource-highlight-common libsqlite3-0 libss2 libstdc++-12-dev libstdc++6
        libstemmer0d libsystemd-shared libsystemd0 libtalloc2 libtasn1-6 libteamdctl0 libtext-charwidth-perl
        libtext-iconv-perl libthai-data libthai-dev libthai0 libtiff-dev libtiff6 libtiffxx6 libtinfo6 libtirpc-common
        libtirpc-dev libtsan2 libubsan1 libuchardet0 libudev-dev libudev1 libudisks2-0 libunwind8 libusb-1.0-0 libuuid1
        libvolume-key1 libvorbis0a libwbclient0 libwebp-dev libwebp7 libwebpdemux2 libwebpmux3 libwrap0 libx11-6 libx11-data
        libx11-dev libxau-dev libxau6 libxcb-render0 libxcb-render0-dev libxcb-shm0 libxcb-shm0-dev libxcb1 libxcb1-dev
        libxdmcp-dev libxdmcp6 libxext-dev libxext6 libxft-dev libxft2 libxml2 libxmlb2 libxmuu1 libxpm4 libxrender-dev
        libxrender1 libxtables12 libxxhash0 libyaml-0-2 libyuv0 libzstd-dev libzstd1 linux-base
        linux-headers-6.12.25+rpt-common-rpi linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.34+rpt-rpi-2712
        linux-headers-6.12.34+rpt-rpi-v8 linux-headers-6.12.47+rpt-common-rpi linux-headers-6.12.47+rpt-rpi-2712
        linux-headers-6.12.47+rpt-rpi-v8 linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-6.12.34+rpt-rpi-2712
        linux-image-6.12.34+rpt-rpi-v8 linux-image-6.12.47+rpt-rpi-2712 linux-image-6.12.47+rpt-rpi-v8 linux-image-rpi-2712
        linux-image-rpi-v8 linux-kbuild-6.12.25+rpt linux-kbuild-6.12.34+rpt linux-kbuild-6.12.47+rpt linux-libc-dev locales
        login logrotate logsave lsb-release lua5.1 luajit make man-db manpages manpages-dev mawk media-types mkvtoolnix
        modemmanager mount musl nano ncdu ncurses-base ncurses-bin ncurses-term net-tools netbase network-manager nfs-common
        nftables ntfs-3g openssh-client openssh-server openssh-sftp-server openssl p7zip p7zip-full packagekit
        packagekit-tools pango1.0-tools parted passwd pastebinit patch pci.ids pciutils perl perl-base pinentry-curses
        pkexec pkg-config pkgconf pkgconf-bin polkitd ppp procps psmisc publicsuffix python-apt-common python-is-python3
        python3 python3-apt python3-blinker python3-certifi python3-cffi-backend python3-chardet python3-charset-normalizer
        python3-colorzero python3-cryptography python3-dbus python3-debconf python3-distro python3-gi python3-gpiozero
        python3-httplib2 python3-idna python3-jwt python3-lazr.restfulclient python3-lazr.uri python3-lgpio python3-libgpiod
        python3-minimal python3-oauthlib python3-pkg-resources python3-pycryptodome python3-pyparsing python3-requests
        python3-rpi.gpio python3-six python3-smbus2 python3-urllib3 python3-wadllib raspberrypi-archive-keyring
        raspberrypi-net-mods raspberrypi-sys-mods raspi-config raspi-firmware raspi-utils raspi-utils-core raspi-utils-dt
        raspi-utils-eeprom raspi-utils-otp raspinfo readline-common rfkill rpcbind rpcsvc-proto rpi-eeprom rpi.gpio-common
        rpicam-apps-core rsync runit-helper sed sensible-utils sgml-base shared-mime-info ssh ssh-import-id strace sudo
        systemd systemd-sysv systemd-timesyncd sysvinit-utils tar tasksel tasksel-data triggerhappy tzdata ucf udev udisks2
        unzip usb-modeswitch usb-modeswitch-data usbutils userconf-pi usrmerge util-linux util-linux-extra uuid uuid-dev
        v4l-utils vim-common vim-tiny wget whiptail wireless-regdb wireless-tools wpasupplicant x11-common x11proto-core-dev
        x11proto-dev xauth xkb-data xml-core xz-utils zip zlib1g zlib1g-dev zstd
      648 upgraded, 174 newly installed, 49 to remove and 0 not upgraded.
      Need to get 714 MB of archives.
      After this operation, 508 MB of additional disk space will be used.
      E: Trivial Only specified but this is not a trivial operation.
      Soll ich nun einfach weiter amchen?
        Thomas Braun Most Active @Duffy last edited by
        @duffy
        Ja, weiter.
        • Duffy
          Duffy @Thomas Braun last edited by
          Oh weh, jetzt kam bei mir schon 2 mal die Frage mit den "q"
          Nach
          sudo apt upgrade --without-new-pkgs
          habe ich
          sudo apt full-upgrade
          gemacht und da kam das 2 mal "q" das habe ich auch gedrückt.
          und jetzt kommt die Meldung:
           ==> Modified (by you or by a script) since installation.
           ==> Package distributor has shipped an updated version.
             What would you like to do about it ?  Your options are:
              Y or I  : install the package maintainer's version
              N or O  : keep your currently-installed version
                D     : show the differences between the versions
                Z     : start a shell to examine the situation
           The default action is to keep your current version.
          *** login.defs (Y/I/N/O/D/Z) [default=N] ?
          Was muss ich da tun?
            @duffy sagte in Update von Debian 12 auf 13 möglich?:
            Kommt darauf an welche Konfig-Datei das ist und was du da abweichendes eingestellt hast. Mit d kannst du die Unterschiede ja sehen.
            • Duffy
              Ich wüste nicht was ich gemacht haben solle ich bin explizit der Beschreibung gefolgt:
              Nach "d" kommt das:
              --- /etc/login.defs     2023-10-10 05:41:38.092990100 +0200
              +++ /etc/login.defs.dpkg-new    2025-04-19 12:20:28.000000000 +0200
              @@ -1,14 +1,6 @@
              -# /etc/login.defs - Configuration control definitions for the login package.
              +# /etc/login.defs - Configuration control definitions for the shadow package.
              -# Three items must be defined:  MAIL_DIR, ENV_SUPATH, and ENV_PATH.
              -# If unspecified, some arbitrary (and possibly incorrect) value will
              -# be assumed.  All other items are optional - if not specified then
              -# the described action or option will be inhibited.
              -# Comment lines (lines beginning with "#") and blank lines are ignored.
              -# Modified for Linux.  --marekm
               # REQUIRED for useradd/userdel/usermod
               #   Directory where mailboxes reside, _or_ name of file, relative to the
              @@ -36,15 +28,9 @@
               #MAIL_FILE      .mail
              -# Enable logging and display of /var/log/faillog login failure info.
              -# This option conflicts with the pam_tally PAM module.
              -FAILLOG_ENAB           yes
              lines 1-28
              Progress: [ 29%] [############################......................................................................]
              wie komme ich jetzt weiter?
                @duffy
                Hier würde ich die Version des Package Maintainers übernehmen.
                • Duffy
                  und wo muss ich y oder I eingeben? Es ist ja kein Feld dafür da?
                  Ich seh mich schon alles neu machen ;-(
                    @duffy
                    Mit q aus der Anzeige raus.
                    • Duffy
                      Danke.
                      hier und da kommen solche Mledungenist das normal?
                      Preparing to unpack .../udev_257.8-1~deb13u2_arm64.deb ...
                      Unpacking udev (257.8-1~deb13u2) over (252.39-1~deb12u1) ...
                      dpkg: warning: unable to delete old directory '/lib/udev/hwdb.d': Directory not empty
                      dpkg: warning: unable to delete old directory '/lib/systemd/system/sysinit.target.wants': Directory not empty
                      dpkg: warning: unable to delete old directory '/lib/systemd/system/sockets.target.wants': Directory not empty
                      dpkg: warning: unable to delete old directory '/lib/systemd/network': Directory not empty
                      dpkg: warning: unable to delete old directory '/lib/modprobe.d': Directory not empty
                      Preparing to unpack .../libudev1_257.8-1~deb13u2_arm64.deb ...
                        @duffy
                        Ja, ist normal. In den Verzeichnissen sind ja die Dateien des vorherigen Releases noch drin.
                        • Duffy
                          OK.
                          Wen das jetzt durchgelaufen ist mit:
                          "Das Spiel mit
                          sudo apt update
                          sudo apt full-upgrade"
                          weiter machen?
                          nicht das wieder ein "q" auftaucht
                            @duffy
                            Ich kann nicht jede Taste vorhersehen, dafür sind die Systeme jeweils zu unterschiedlich. Was hast du denn für eine Panik vor Rückfragen des Systems?
                            • Duffy
                              Bitte nicht falsch versten das sollte in keinster weise ein Vorwurf sein.
                              Ich habe nur echt Panik in dem Linux rum zu fummeln das endet bei mir in der Regel in Dramen.
                              pi@raspberrypi:~ $ sudo apt full-upgrade
                                g++-12                 libboost-filesystem1.74.0       libldap-2.5-0          libx265-199
                                gdisk                  libboost-log1.74.0              libnsl-dev             linux-headers-6.12.25+rpt-common-rpi
                                libabsl20220623        libboost-program-options1.74.0  libpthread-stubs0-dev  linux-kbuild-6.12.25+rpt
                                libappstream4          libboost-regex1.74.0            libpython3.11          p7zip
                                libassuan0             libboost-thread1.74.0           libpython3.11-minimal  pkexec
                                libavif15              libcbor0.8                      libpython3.11-stdlib   python3-six
                                libblockdev-crypto2    libdav1d6                       libqt5core5a           python3-toml
                                libblockdev-loop2      libflac12                       librav1e0              python3.11
                                libblockdev-part-err2  libfmt9                         librhash0              python3.11-minimal
                                libblockdev-part2      libfuse3-3                      libstdc++-12-dev       triggerhappy
                                libblockdev-swap2      libicu72                        libsvtav1enc1          x11proto-core-dev
                                libblockdev-utils2     libjim0.81                      libtirpc-dev
                                libblockdev2           libjsoncpp25                    libunwind8
                              Summary:
                                Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
                              ich würde das jetzt mal enfernen mit
                              • Duffy
                                @Thomas-Braun
                                Ich habe jetzt nach der Prozedur noch mal iob diag gemacht.
                                Für mich sieht es so aus als wenn alles ok ist was aber bei mir nichts heißen soll.
                                schaust bitte noch ml drüber?
                                Script v.2025-08-09
                                *** BASE SYSTEM ***
                                Operating System: Debian GNU/Linux 13 (trixie)
                                 Static hostname: raspberrypi
                                       Icon name: computer
                                          Kernel: Linux 6.12.47+rpt-rpi-v8
                                    Architecture: arm64
                                OS is similar to:
                                Model           : Raspberry Pi 4 Model B Rev 1.4
                                Docker          : false
                                Virtualization  : none
                                Kernel          : aarch64
                                Userland        : 64 bit
                                Systemuptime and Load:
                                 08:21:43 up 5 min,  1 user,  load average: 4.23, 3.20, 1.45
                                CPU threads: 4
                                *** LIFE CYCLE STATUS ***
                                Operating System is the current Debian stable version codenamed 'trixie'!
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                Previously detected issues:
                                *** TIME AND TIMEZONES ***
                                               Local time: Tue 2025-10-14 08:21:43 CEST
                                           Universal time: Tue 2025-10-14 06:21:43 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                SUDO_HOME=/home/pi
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                *** DISPLAY-SERVER SETUP ***
                                Display-Server:         false
                                Unit display-manager.service could not be found.
                                Display-Manager:
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                Mem:            8.2G        3.4G        3.1G         13M        1.8G        4.8G
                                Swap:           209M          0B        209M
                                Total:          8.4G        3.4G        3.3G
                                Active iob-Instances:   37
                                         7819 M total memory
                                         3241 M used memory
                                         4238 M active memory
                                          408 M inactive memory
                                         2956 M free memory
                                           84 M buffer memory
                                         1650 M swap cache
                                          199 M total swap
                                            0 M used swap
                                          199 M free swap
                                top - 08:21:44 up 5 min,  1 user,  load average: 4.23, 3.20, 1.45
                                Tasks: 227 total,   1 running, 226 sleeping,   0 stopped,   0 zombie
                                %Cpu(s):  4.3 us,  2.1 sy,  0.0 ni, 93.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   7819.7 total,   2956.1 free,   3241.2 used,   1735.1 buff/cache
                                MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4578.6 avail Mem
                                *** FAILED SERVICES ***
                                0 loaded units listed.
                                *** DMESG CRITICAL ERRORS ***
                                No critical errors detected
                                *** FILESYSTEM ***
                                udev           devtmpfs  3.6G     0  3.6G   0% /dev
                                tmpfs          tmpfs     1.6G   11M  1.6G   1% /run
                                /dev/sda2      ext4       29G   12G   16G  44% /
                                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                tmpfs          tmpfs     3.9G  2.5M  3.9G   1% /tmp
                                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                                /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
                                tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                                tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
                                [Tue Oct 14 08:16:05 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:36:CB:32 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=dd528ea5-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Tue Oct 14 08:16:07 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
                                [Tue Oct 14 08:16:10 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
                                Show mounted filesystems:
                                TARGET           SOURCE    FSTYPE OPTIONS
                                /                /dev/sda2 ext4   rw,noatime
                                `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                2.5G    /var/
                                1.5G    /var/log/journal/458ebafb08a8432dbfe417c962c32f87
                                1.5G    /var/log
                                594M    /var/lib
                                Archived and active journals take up 1.4G in the file system.
                                /opt/iobroker/backups:
                                940M    /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                595M    /opt/iobroker/iobroker-data/
                                425M    /opt/iobroker/iobroker-data/files
                                116M    /opt/iobroker/iobroker-data/backup-objects
                                74M     /opt/iobroker/iobroker-data/files/vis
                                67M     /opt/iobroker/iobroker-data/files/vis/widgets
                                38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                27M     /opt/iobroker/iobroker-data/states.jsonl
                                27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                                24M     /opt/iobroker/iobroker-data/objects.jsonl
                                19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                *** ZigBee Settings ***
                                Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                Zigbee Network Settings on your coordinator/in nvbackup are:
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                To unmask the settings run 'iob diag --unmask'
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v22.20.0
                                /usr/bin/node           v22.20.0
                                /usr/bin/npm            10.9.3
                                /usr/bin/npx            10.9.3
                                /usr/bin/corepack       0.34.0
                                nodejs:
                                  Installed: 22.20.0-1nodesource1
                                  Candidate: 22.20.0-1nodesource1
                                  Version table:
                                 *** 22.20.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                        100 /var/lib/dpkg/status
                                     22.19.0-1nodesource1 1001
                                     22.18.0-1nodesource1 1001
                                     22.17.1-1nodesource1 1001
                                     22.17.0-1nodesource1 1001
                                     22.16.0-1nodesource1 1001
                                     22.15.1-1nodesource1 1001
                                     22.15.0-1nodesource1 1001
                                     22.14.0-1nodesource1 1001
                                     22.13.1-1nodesource1 1001
                                     22.13.0-1nodesource1 1001
                                     22.12.0-1nodesource1 1001
                                     22.11.0-1nodesource1 1001
                                     22.10.0-1nodesource1 1001
                                     22.9.0-1nodesource1 1001
                                     22.8.0-1nodesource1 1001
                                     22.7.0-1nodesource1 1001
                                     22.6.0-1nodesource1 1001
                                     22.5.1-1nodesource1 1001
                                     22.5.0-1nodesource1 1001
                                     22.4.1-1nodesource1 1001
                                     22.4.0-1nodesource1 1001
                                     22.3.0-1nodesource1 1001
                                     22.2.0-1nodesource1 1001
                                     22.1.0-1nodesource1 1001
                                     22.0.0-1nodesource1 1001
                                     20.19.2+dfsg-1 500
                                        500 http://deb.debian.org/debian trixie/main arm64 Packages
                                No problems detected
                                Errors in npm tree: 0
                                Checking for nodejs vulnerability:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 347)
                                Core adapters versions
                                js-controller:  7.0.7
                                admin:          7.7.2
                                javascript:     8.9.2
                                nodejs modules from github:     1
                                +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#666f01f7e8b49322d68d63360322a9f11169911a)
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
                                + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
                                  system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                + system.adapter.drag-indicator.0         : drag-indicator        : raspberrypi                              -  enabled
                                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                                + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                                  system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                  system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
                                + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                                + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                + system.adapter.matter.0                 : matter                : raspberrypi                              -  enabled
                                + system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              -  enabled
                                  system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
                                + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
                                  system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                                + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                + system.adapter.sainlogic.0              : sainlogic             : raspberrypi                              -  enabled, port: 1847, bind: 0.0.0.0
                                + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                                + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                                  system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              - disabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                                  system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                                  system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                  system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                + instance is alive
                                ioBroker-Repositories
                                Active repo(s): stable
                                Upgrade policy: none
                                Installed ioBroker-Adapters
                                Used repository: stable
                                Adapter    "admin"        : 7.7.2    , installed 7.7.2
                                Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                                Adapter    "drag-indicator": 2.4.0   , installed 2.4.0
                                Adapter    "echarts"      : 1.9.2    , installed 2.0.8
                                Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
                                Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                                Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                                Adapter    "ical"         : 1.17.0   , installed 1.17.0
                                Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                Controller "js-controller": 7.0.7    , installed 7.0.7
                                Adapter    "matter"       : 0.5.2    , installed 0.5.2
                                Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                                Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
                                Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                Adapter    "operating-hours": 1.3.0  , installed 1.3.0
                                Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                                Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                                Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                                Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                                Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                                Adapter    "web"          : 7.0.8    , installed 7.0.8
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
                                Objects and States
                                Objects:        13565
                                States:         12503
                                W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                                Hit:1 http://deb.debian.org/debian trixie InRelease
                                Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
                                Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                                Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
                                Hit:5 https://apt.grafana.com stable InRelease
                                Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
                                Hit:7 https://repos.influxdata.com/debian stable InRelease
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9684       1158/iobroker.js-co
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7789       1158/iobroker.js-co
                                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6885       1112/exim4
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8372       809/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8879       1450/io.sonoff.0
                                tcp        0      0 0.0.0.0:1847            0.0.0.0:*               LISTEN      1001       13530      1887/io.sainlogic.0
                                tcp6       0      0 :::3000                 :::*                    LISTEN      106        6962       1157/grafana
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8594       1204/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11748      1819/io.web.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        6907       825/influxd
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12438      1842/io.simple-api.
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          8374       809/sshd: /usr/sbin
                                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6886       1112/exim4
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       14406      1902/io.matter.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12518      1902/io.matter.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10997      1902/io.matter.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10989      1902/io.matter.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2012       575/avahi-daemon: r
                                udp        0      0 0.0.0.0:34368           0.0.0.0:*                           104        2014       575/avahi-daemon: r
                                udp        0      0 0.0.0.0:49974           0.0.0.0:*                           1001       11006      1902/io.matter.0
                                udp6       0      0 :::5353                 :::*                                1001       14407      1902/io.matter.0
                                udp6       0      0 :::5353                 :::*                                1001       12519      1902/io.matter.0
                                udp6       0      0 :::5353                 :::*                                1001       11000      1902/io.matter.0
                                udp6       0      0 :::5353                 :::*                                1001       10992      1902/io.matter.0
                                udp6       0      0 :::5353                 :::*                                104        2013       575/avahi-daemon: r
                                udp6       0      0 :::52715                :::*                                104        2015       575/avahi-daemon: r
                                udp6       0      0 fe80::e5bd:4ca9:170:546 :::*                                0          6085       691/NetworkManager
                                udp6       0      0 :::49974                :::*                                1001       11005      1902/io.matter.0
                                2025-10-14 08:20:28.151  - info: sourceanalytix.0 (1716) Initialization of 0_userdata.0.PV_Ersparnis.Ersparnis_kWh_2PVs successfully
                                2025-10-14 08:20:28.152  - info: sourceanalytix.0 (1716) Initialising (9 of 9) "0_userdata.0.PV_Einspeisung.PV_Einspeisung_kWh_2PVs"
                                2025-10-14 08:20:31.519  - info: sourceanalytix.0 (1716) Initialization of 0_userdata.0.PV_Einspeisung.PV_Einspeisung_kWh_2PVs successfully
                                2025-10-14 08:20:31.547  - info: sourceanalytix.0 (1716) Successfully activated SourceAnalytix for 9 of 9 states, will do my Job until you stop me!
                                2025-10-14 08:20:42.108  - info: matter.0 (1902) Node "10769786468529638926" offline, waiting for device discovery
                                2025-10-14 08:20:42.845  - info: matter.0 (1902) Node "11901481590481904095" offline, waiting for device discovery
                                2025-10-14 08:21:11.351  - info: alexa2.0 (1592) Unknown Device, but enabling commands, Try it and report back if commands work.
                                2025-10-14 08:21:11.352  - info: alexa2.0 (1592) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                2025-10-14 08:21:11.352  - info: alexa2.0 (1592)     Device-type:A2V9UEGZ82H4KZ - Fire SZ (MICROPHONE,ASX_TIME_ZONE,TIMERS_AND_ALARMS,SUPPORTS_SOFTWARE_VERSION,ADAPTIVE_LISTENING,VOLUME_SETTING,NO_TIME_ZONE_SETTING,PERSISTENT_CONNECTION,REMINDERS)
                                2025-10-14 08:21:17.625  - info: alexa2.0 (1592) Unknown Device, but enabling commands, Try it and report back if commands work.
                                2025-10-14 08:21:17.626  - info: alexa2.0 (1592) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                2025-10-14 08:21:17.627  - info: alexa2.0 (1592)     Device-type:A2QCPPMSOLGVZE - Fire Max (AUDIBLE,VOICE_TRAINING,SUPPORTS_SOFTWARE_VERSION,SIRIUSXM,ARTHUR_TARGET,SET_LOCALE,VOLUME_SETTING,SALMON,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,MICROPHONE,AMAZON_MUSIC,AUDIO_PLAYER,PANDORA,SLEEP,CHANGE_NAME,KINDLE_BOOKS,SUPPORTS_CONNECTED_HOME_ALL,ASCENDING_ALARM_VOLUME,FLASH_BRIEFING,CUSTOM_ALARM_TONE,MUSIC_SKILL,DEEZER,TIMERS_AND_ALARMS,ACTIVE_AFTER_FRO,TAHOE_BYOD,SHARKNADO,TUNE_IN,ADAPTIVE_LISTENING,EARCONS,TIDAL,REMINDERS,DREAM_TRAINING,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,TIMEZONE,I_HEART_RADIO,PERSISTENT_CONNECTION,REQUIRES_OOBE_FOR_SETUP,APPLE_MUSIC)
                                2025-10-14 08:21:20.258  - info: javascript.0 (1321) script.js.Arbeitszimmer.Fire_Tablet_Arbeitszimmer_an: true
                                2025-10-14 08:21:20.539  - info: javascript.0 (1321) script.js.Arbeitszimmer.Fire_Tablet_Arbeitszimmer_an: true
                                2025-10-14 08:21:20.866  - info: fullybrowser.0 (1577) 🗸 192.168.178.157: Command screenOn successfully set to true
                                2025-10-14 08:21:21.075  - info: fullybrowser.0 (1577) 🗸 192.168.178.157: Command screenOn successfully set to true
                                2025-10-14 08:21:37.961  - info: web.0 (1819) ==> Connected system.user.admin from ::ffff:192.168.178.157
                                2025-10-14 08:21:38.636  - info: alexa2.0 (1592) Subscribing to states...
                                2025-10-14 08:21:38.653  - info: alexa2.0 (1592) Deleting the following states: ["Contacts.AF2FSLWZXZPZ7SST2UEDH5LRWD5Q","Contacts.AF2FSLWZXZPZ7SST2UEDH5LRWD5Q.textMessage"]
                                2025-10-14 08:21:41.016  - info: alexa2.0 (1592) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2025-10-14 08:22:01.584  - info: alexa2.0 (1592) Initialization Done ...
                                2025-10-14 08:23:11.221  - info: fritzdect.0 (1671) DECT ID: 130770157104-1 identified for command (state) : false
                                2025-10-14 08:23:11.618  - info: fritzdect.0 (1671) DECT ID: 130770143150-1 identified for command (state) : false
                                2025-10-14 08:23:11.620  - info: fritzdect.0 (1671) DECT ID: 130770137317-1 identified for command (state) : false
                                2025-10-14 08:23:11.623  - info: fritzdect.0 (1671) DECT ID: 130770274810-1 identified for command (state) : false
                                VG Duffy
                                  @duffy
                                  Ja, passt.
                                  Duffy 1 Reply Last reply Reply Quote 1
                                  • Duffy
                                    Vielen Dank für deinen Support!!
                                    Jetzt hoffe ich das der nächste Nachfolger von Trixie 10 Jahre auf sich warten lässt was nicht so sein wird 😉
                                    Soll ich das auch schon umstrellen?
                                    sudo apt modernize-sources
                                    VG Duffy und noch mal vielen Dank
                                      Thomas Braun Most Active @Duffy last edited by Thomas Braun
                                      Debian 14 'Forky' kommt im Sommer 2027. Alle zwei Jahre kommt ein neues Debian Stable heraus.
                                      2029 betritt dann Debian 15 'Duke' die Bühne.
                                      Kann man alles sehr gut planen.
                                      https://www.debian.org/releases/forky/
                                      Kannste machen, kannste auch im Moment bleiben lassen. Beide Formate der Quellendefinitionen funktionieren.
                                      Duffy 1 Reply Last reply Reply Quote 2
                                      • Duffy
                                        Guten Morgen,
                                        ich habe
                                        mal mit "N" simuliert und es kam am ende eine Warnung.
                                        pi@raspberrypi:~ $ sudo apt modernize-sources
                                        The following files need modernizing:
                                          - /etc/apt/sources.list
                                          - /etc/apt/sources.list.d/grafana.list
                                          - /etc/apt/sources.list.d/influxdata.list
                                          - /etc/apt/sources.list.d/nodesource.list
                                          - /etc/apt/sources.list.d/raspi.list
                                        Modernizing will replace .list files with the new .sources format,
                                        add Signed-By values where they can be determined automatically,
                                        and save the old files into .list.bak files.
                                        This command supports the 'signed-by' and 'trusted' options. If you
                                        have specified other options inside [] brackets, please transfer them
                                        manually to the output files; see sources.list(5) for a mapping.
                                        For a simulation, respond N in the following prompt.
                                        Rewrite 5 sources? [Y/n] N
                                        Simulating only...
                                        Modernizing /etc/apt/sources.list...
                                        # Would write to: /etc/apt/sources.list.d/debian.sources
                                        # Modernized from /etc/apt/sources.list
                                        Types: deb
                                        URIs: http://deb.debian.org/debian/
                                        Suites: trixie
                                        Components: main contrib non-free non-free-firmware
                                        Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg
                                        Types: deb
                                        URIs: http://deb.debian.org/debian-security/
                                        Suites: trixie-security
                                        Types: deb
                                        Suites: trixie-updates
                                        Modernizing /etc/apt/sources.list.d/grafana.list...
                                        # Would write to: /etc/apt/sources.list.d/grafana.sources
                                        Types: deb
                                        URIs: https://apt.grafana.com/
                                        Suites: stable
                                        Components: main
                                        Signed-By: /etc/apt/keyrings/grafana.gpg
                                        Modernizing /etc/apt/sources.list.d/influxdata.list...
                                        # Would write to: /etc/apt/sources.list.d/influxdata.sources
                                        Types: deb
                                        URIs: https://repos.influxdata.com/debian/
                                        Suites: stable
                                        Components: main
                                        Signed-By: /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg
                                        Modernizing /etc/apt/sources.list.d/nodesource.list...
                                        # Would write to: /etc/apt/sources.list.d/nodesource.sources
                                        Types: deb
                                        URIs: https://deb.nodesource.com/node_22.x/
                                        Suites: nodistro
                                        Components: main
                                        Signed-By: /etc/apt/keyrings/nodesource.gpg
                                        Modernizing /etc/apt/sources.list.d/raspi.list...
                                        # Would write to: /etc/apt/sources.list.d/raspi.sources
                                        Types: deb
                                        URIs: http://archive.raspberrypi.com/debian/
                                        Suites: trixie
                                        Components: main
                                        Signed-By:
                                        Warning: Could not determine Signed-By for URIs: http://archive.raspberrypi.com/debian/, Suites: trixie
                                        pi@raspberrypi:~ $
                                        Kann ich die ignorieren oder wird mir die Probleme machen?
                                        VG Duffy
                                          @duffy
                                          Nicht ignorieren.
                                          Die Datei schaut vollständig so aus:
                                          Types: deb
                                          Suites: trixie
                                          Components: main
                                          Signed-By: /usr/share/keyrings/raspberrypi-archive-keyring.pgp
                                          • Duffy
                                            Hmm, sorry das verstehe ich jetzt nicht.
                                            Warnung "Nicht ignorieren" heisst für mich Finger weg lassen.
                                            Types: deb
                                            Suites: trixie
                                            und die Zeile 4 sieht bei mir anders aus.
                                            VG Duffy
                                            81.1k
                                            1367
