    4. npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie
    • meute
      meute @Thomas Braun last edited by
      @thomas-braun sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
      Dann weiß ich es auch nicht.
      ioBroker läuft ja.
      Vll. verschwindet der Fehler irgendwann von selbst.
      Der npm error kommt nur bei iob diag.
      Zeig mal die komplette Ausgabe von
      iob diag
      Bitteschön:
      ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker84
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.11-3-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:17:09 up 1 day,  7:03,  1 user,  load average: 0.43, 0.46, 0.47
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-10-13 19:17:09 CEST
                 Universal time: Mon 2025-10-13 17:17:09 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mf
      HOME=/home/mf
      GROUPS=mf adm sudo users iobroker lxc_shares
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/mf
      GROUPS=iobroker tty dialout audio video plugdev lxc_shares
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            4.3G        1.5G        1.5G        6.3M        1.4G        2.8G
      Swap:           536M        278K        536M
      Total:          4.8G        1.5G        2.0G
      Active iob-Instances:   15
               4096 M total memory
               1427 M used memory
                623 M active memory
               1872 M inactive memory
               1386 M free memory
                  0 M buffer memory
               1288 M swap cache
                512 M total swap
                  0 M used swap
                511 M free swap
      top - 19:17:09 up 1 day,  7:03,  1 user,  load average: 0.43, 0.46, 0.47
      Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  4.5 sy,  0.0 ni, 90.9 id,  0.0 wa,  0.0 hi,  4.5 si,  0.0 st
      MiB Mem :   4096.0 total,   1384.7 free,   1428.7 used,   1288.4 buff/cache
      MiB Swap:    512.0 total,    511.7 free,      0.3 used.   2667.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                                  Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0            ext4       12G  7.1G  4.2G  64% /
      //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs      467G   50G  417G  11% /mnt/nas8
      none                                        tmpfs     492K  4.0K  488K   1% /dev
      udev                                        devtmpfs  9.7G     0  9.7G   0% /dev/tty
      tmpfs                                       tmpfs     9.7G     0  9.7G   0% /dev/shm
      tmpfs                                       tmpfs     3.9G  3.3M  3.9G   1% /run
      tmpfs                                       tmpfs     9.7G  2.8M  9.7G   1% /tmp
      tmpfs                                       tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                                       tmpfs     2.0G  8.0K  2.0G   1% /run/user/1000
      Show mounted filesystems:
      TARGET      SOURCE                                      FSTYPE OPTIONS
      /           /dev/mapper/pve-vm--100--disk--0            ext4   rw,relatime,stripe=16
      `-/mnt/nas8 //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs   rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=fritznas,uid=100000,forceuid,gid=110000,forcegid,addr=192.168.23.8,file_mode=0770,dir_mode=0770,soft,nounix,mapposix,reparse=nfs,nativesocket,symlink=native,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      2.0G    /var/
      1.3G    /var/log/journal
      1.3G    /var/log
      1.2G    /var/log/journal/649cc30af99f46b985202f72e64de40c
      496M    /var/cache
      Archived and active journals take up 1.1G in the file system.
      /opt/iobroker/backups:
      69M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      383M    /opt/iobroker/iobroker-data/
      300M    /opt/iobroker/iobroker-data/files
      67M     /opt/iobroker/iobroker-data/files/echarts.admin
      61M     /opt/iobroker/iobroker-data/files/echarts
      53M     /opt/iobroker/iobroker-data/backup-objects
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.20.0
      /usr/bin/node           v22.20.0
      /usr/bin/npm            11.6.2
      /usr/bin/npx            11.6.2
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.20.0-1nodesource1
        Candidate: 22.20.0-1nodesource1
        Version table:
       *** 22.20.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker84          iobroker84 (version: 7.0.7, hostname: iobroker84    , alive, uptime: 71195)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker84                               - disabled
      + system.adapter.backitup.0               : backitup              : iobroker84                               -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker84                               -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker84                               -  enabled
        system.adapter.ical.0                   : ical                  : iobroker84                               -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker84                               -  enabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : iobroker84                               -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker84                               -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker84                               -  enabled
        system.adapter.ping.0                   : ping                  : iobroker84                               - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker84                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker84                               -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker84                               -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker84                               -  enabled
      + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker84                               -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "ical"         : 1.17.0   , installed 1.17.0
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "shelly"       : 10.2.0   , installed 10.2.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        1346
      States:         1053
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://security.debian.org trixie-security InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          30476144   255/smbd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30471050   1/init
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          30476143   255/smbd
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       31761702   1730/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31759277   1579/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31758015   1579/iobroker.js-co
      tcp6       0      0 :::139                  :::*                    LISTEN      0          30476142   255/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          30476526   1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          30471052   1/init
      tcp6       0      0 :::445                  :::*                    LISTEN      0          30476141   255/smbd
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        30476154   177/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31759357   1598/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31761907   1805/io.web.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30471051   1/init
      udp        0      0 192.168.23.255:137      0.0.0.0:*                           0          30476030   208/nmbd
      udp        0      0 192.168.23.84:137       0.0.0.0:*                           0          30476029   208/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          30476017   208/nmbd
      udp        0      0 192.168.23.255:138      0.0.0.0:*                           0          30476032   208/nmbd
      udp        0      0 192.168.23.84:138       0.0.0.0:*                           0          30476031   208/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          30476018   208/nmbd
      udp        0      0 192.168.23.84:5353      0.0.0.0:*                           1001       31762800   1775/io.tr-064.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31762618   1715/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          30471053   1/init
      2025-10-13 17:32:33.484  - info: web.0 (1805) ==> Connected system.user.admin from ::ffff:192.168.23.186
      2025-10-13 17:34:19.147  - info: web.0 (1805) <== Disconnect system.user.admin from ::ffff:192.168.23.186 iqontrol.0
      2025-10-13 17:34:19.705  - info: web.0 (1805) ==> Connected system.user.admin from ::ffff:192.168.23.186
      2025-10-13 17:35:19.994  - info: web.0 (1805) <== Disconnect system.user.admin from ::ffff:192.168.23.186 iqontrol.0
      2025-10-13 18:00:00.038  - info: host.iobroker84 instance system.adapter.ical.0 in version "1.17.0" started with pid 5332
      2025-10-13 18:00:02.030  - info: ical.0 (5332) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
      2025-10-13 18:00:02.414  - info: ical.0 (5332) processing URL: Abfuhrkalender https://calendar.google.com/calendar/ical/bd0a1fc1997514e89949bb190399d86de9d17b2640e28a28dbf8f1bf391e5f90%40group.calendar.google.com/private-7d7300d8d092a6268253c104d9f3fdf1/basic.ics
      2025-10-13 18:00:07.500  - info: ical.0 (5332) Terminated (NO_ERROR): Without reason
      2025-10-13 18:00:08.027  - info: host.iobroker84 instance system.adapter.ical.0 having pid 5332 terminated with code 0 (NO_ERROR)
      2025-10-13 18:12:03.795  - info: web.0 (1805) ==> Connected system.user.admin from ::ffff:192.168.23.186
      2025-10-13 18:12:11.020  - info: web.0 (1805) <== Disconnect system.user.admin from ::ffff:192.168.23.186 iqontrol.0
      2025-10-13 18:30:00.031  - info: host.iobroker84 instance system.adapter.ical.0 in version "1.17.0" started with pid 5359
      2025-10-13 18:30:01.837  - info: ical.0 (5359) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
      2025-10-13 18:30:02.240  - info: ical.0 (5359) processing URL: Abfuhrkalender https://calendar.google.com/calendar/ical/bd0a1fc1997514e89949bb190399d86de9d17b2640e28a28dbf8f1bf391e5f90%40group.calendar.google.com/private-7d7300d8d092a6268253c104d9f3fdf1/basic.ics
      2025-10-13 18:30:07.335  - info: ical.0 (5359) Terminated (NO_ERROR): Without reason
      2025-10-13 18:30:07.859  - info: host.iobroker84 instance system.adapter.ical.0 having pid 5359 terminated with code 0 (NO_ERROR)
      2025-10-13 18:46:50.115  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
      2025-10-13 18:47:13.830  - info: admin.0 (1598) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
      2025-10-13 19:00:00.040  - info: host.iobroker84 instance system.adapter.ical.0 in version "1.17.0" started with pid 6152
      2025-10-13 19:00:01.904  - info: ical.0 (6152) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
      2025-10-13 19:00:02.283  - info: ical.0 (6152) processing URL: Abfuhrkalender https://calendar.google.com/calendar/ical/bd0a1fc1997514e89949bb190399d86de9d17b2640e28a28dbf8f1bf391e5f90%40group.calendar.google.com/private-7d7300d8d092a6268253c104d9f3fdf1/basic.ics
      2025-10-13 19:00:07.373  - info: ical.0 (6152) Terminated (NO_ERROR): Without reason
      2025-10-13 19:00:07.903  - info: host.iobroker84 instance system.adapter.ical.0 having pid 6152 terminated with code 0 (NO_ERROR)
      2025-10-13 19:09:32.661  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
      2025-10-13 19:09:43.940  - info: admin.0 (1598) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
      iob diag has finished.
        Thomas Braun Most Active @meute last edited by
        @meute Nutzt dir zwar nix, aber unter nodejs@22 ist das bei mir alles sauber:
        echad@chet:/opt/iobroker $ node -v
        v22.20.0
        echad@chet:/opt/iobroker $ npm ls canvas
        iobroker.inst@3.0.0 /opt/iobroker
        ├─┬ iobroker.echarts@2.0.10
        │ ├── canvas@3.2.0
        │ └─┬ jsdom@26.1.0
        │   └── canvas@3.2.0 deduped
        ├─┬ iobroker.mihome-vacuum@5.3.0
        └─┬ iobroker.parcel@0.2.10
          └─┬ jsdom@25.0.1
            └── canvas@2.11.2
        ├── iobroker.admin@7.7.3
        ├── iobroker.alexa2@3.27.3
        ├── iobroker.alias-manager@2.0.0
        ├── iobroker.ankersolix2@2.4.1
        ├── iobroker.awtrix-light@2.0.0
        ├── iobroker.backitup@3.3.9
        ├── iobroker.ble@0.14.1
        ├── iobroker.cloud@5.0.1
        ├── iobroker.devices@1.2.9
        ├── iobroker.echarts@2.0.10
        ├── iobroker.firetv@2.1.0
        ├── iobroker.followthesun@0.5.2
        ├── iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
        ├── iobroker.govee-local@0.2.9
        ├── iobroker.history@3.0.1
        ├── iobroker.ical@1.17.0
        ├── iobroker.iceroad@1.2.1
        ├── iobroker.iot@4.1.0
        ├── iobroker.javascript@9.0.11
        ├── iobroker.js-controller@7.0.7
        ├── iobroker.mihome-cloud@0.1.1
        ├── iobroker.mihome-vacuum@5.3.0
        ├── iobroker.mihome@1.4.0
        ├── iobroker.mqtt@6.1.4
        ├── iobroker.nina@0.0.26
        ├── iobroker.notification-manager@1.3.0
        ├── iobroker.nuki-extended@2.7.0
        ├── iobroker.nut@1.7.0
        ├── iobroker.opendtu@3.1.0
        ├── iobroker.openweathermap@1.4.0
        ├── iobroker.parcel@0.2.10
        ├── iobroker.playstation@0.0.3
        ├── iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#c87e9539d89bac8f4d19b266679bcb78ed554f1d)
        ├── iobroker.sainlogic@0.12.1
        ├── iobroker.samsung_tizen@1.1.0
        ├── iobroker.samsung@0.6.1
        ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
        ├── iobroker.tado@0.8.0
        ├── iobroker.tankerkoenig@3.4.0
        ├── iobroker.tr-064@4.3.0
        ├── iobroker.tradfri@3.1.3
        ├── iobroker.trashschedule@4.0.1
        ├── iobroker.tuya@3.17.0
        ├── iobroker.weather-warnings@0.8.0
        ├── iobroker.web@7.0.9
        ├── iobroker.whatsapp-cmb@0.3.0
        └── iobroker.zigbee@3.1.5
        echad@chet:/opt/iobroker $ lsb_release -cs
        trixie
        meute 1 Reply Last reply Reply Quote 1
        • meute
          So sieht es bei mir aus:
          mf@iobroker84:/opt/iobroker $ node -v
          v22.20.0
          mf@iobroker84:/opt/iobroker $ npm ls canvas
          └── (empty)
          ├── @mapbox/node-pre-gyp@1.0.11 extraneous
          ├── abbrev@1.1.1 extraneous
          ├── aproba@2.1.0 extraneous
          ├── are-we-there-yet@2.0.0 extraneous
          ├── color-support@1.1.3 extraneous
          ├── concat-map@0.0.1 extraneous
          ├── console-control-strings@1.1.0 extraneous
          ├── delegates@1.0.0 extraneous
          ├── detect-libc@2.1.2 extraneous
          ├── gauge@3.0.2 extraneous
          ├── has-unicode@2.0.1 extraneous
          ├── iobroker.admin@7.7.2
          ├── iobroker.backitup@3.3.5
          ├── iobroker.discovery@5.0.0
          ├── iobroker.echarts@1.9.2
          ├── iobroker.influxdb@4.0.2
          ├── iobroker.iqontrol@3.0.0
          ├── iobroker.javascript@8.9.2
          ├── iobroker.modbus@6.3.2
          ├── iobroker.ping@1.6.2
          ├── iobroker.shelly@10.2.0
          ├── iobroker.simple-api@2.8.0
          ├── iobroker.socketio@6.7.1
          ├── iobroker.sonoff@3.2.1
          ├── iobroker.trashschedule@3.3.0
          ├── iobroker.web@7.0.8
          ├── iobroker.ws@2.6.2
          ├── make-dir@3.1.0 extraneous
          ├── mimic-response@2.1.0 extraneous
          ├── nopt@5.0.0 extraneous
          ├── npmlog@5.0.1 extraneous
          ├── path-is-absolute@1.0.1 extraneous
          ├── rimraf@3.0.2 extraneous
          ├── set-blocking@2.0.0 extraneous
          ├── simple-concat@1.0.1 extraneous
          ├── simple-get@3.1.1 extraneous
          └── wide-align@1.1.5 extraneous
          • meute
            Mir sagt canvas jetzt nicht wirklich was.
            Benötigt der Adapter echarts canvas?
            Wenn ja, warum ist es bei mir (empty)?
              @meute sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
              Ja, einmal als direkte Abhängigkeit und dann braucht jsdom auch canvas. Sieht man hier:
              │ ├── canvas@3.2.0
              │ └─┬ jsdom@26.1.0
              Deduped bedeutet, das es keine doppelte Installation ist sondern das auf das Modul (in gleicher Versionsnummer) auf einer höheren Ebene zurückgegriffen werden kann.
              Weil es aus irgendwelchen Gründen bei dir nicht gebaut/kompiliert werden kann.
                @meute
                Was spuckt denn ein
                apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                aus?
                meute 1 Reply Last reply Reply Quote 0
                • meute
                  $ apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                  build-essential:
                    Installiert:           12.12
                    Installationskandidat: 12.12
                    Versionstabelle:
                   *** 12.12 500
                  libcairo2-dev:
                    Installiert:           1.18.4-1+b1
                    Installationskandidat: 1.18.4-1+b1
                    Versionstabelle:
                   *** 1.18.4-1+b1 500
                  libpango1.0-dev:
                    Installiert:           1.56.3-1
                    Installationskandidat: 1.56.3-1
                    Versionstabelle:
                   *** 1.56.3-1 500
                  libjpeg-dev:
                    Installiert:           1:2.1.5-4
                    Installationskandidat: 1:2.1.5-4
                    Versionstabelle:
                   *** 1:2.1.5-4 500
                  libgif-dev:
                    Installiert:           5.2.2-1+b1
                    Installationskandidat: 5.2.2-1+b1
                    Versionstabelle:
                   *** 5.2.2-1+b1 500
                  librsvg2-dev:
                    Installiert:           2.60.0+dfsg-1
                    Installationskandidat: 2.60.0+dfsg-1
                    Versionstabelle:
                   *** 2.60.0+dfsg-1 500
                    Thomas Braun Most Active @meute last edited by Thomas Braun
                    @meute
                    Schau mal ob canvas alleine baut.
                    cd
                    npm install canvas
                    Damit wird das Modul unabhängig vom iobroker in deinem Heimverzeichnis gebaut.
                    Zeig mal die Meldungen dazu.
                    [Edit:]
                    Mit
                    npm uninstall canvas
                    im gleichen Verzeichnis wirste das auch wieder los.
                    • meute
                      @meute
                      cd
                      npm install canvas
                      mf@iobroker84:~ $ npm install canvas
                      added 37 packages in 5s
                      9 packages are looking for funding
                        run `npm fund` for details
                      Habs im Home wieder deinstalliert.
                        War es denn davor im Baum zu finden?
                        npm ls
                        hätte da ein Modul canvas@3.2.0 zeigen müssen.
                        • meute
                          npm ls
                          added 37 packages in 4s
                          mf@iobroker84:~ $ npm ls
                          mf@ /home/mf
                          └── canvas@3.2.0
                          mf@iobroker84:~ $ npm uninstall canvas
                          removed 37 packages, and audited 1 package in 721ms
                          found 0 vulnerabilities
                            @meute
                            Dann ist da 'irgendwas' anderes in der Installation.
                            Ich kann dir da aber leider nicht wirklich weiterhelfen.
                            • meute
                              @meute
                              Danke trotzdem für alles. 👍
                              Komisch ist aber, dass trotz dem Problem der Adapter echarts funktioniert.
                              581
