Adapter Hyundai (Bluelink) oder KIA (UVO)
Hallo Zusammen,
hab die Version 3.1.21 installiert, einen neuen Token generiert und muss zusätzlich den USER PIN eintragen.
Funktioniert ohne Fehlermeldung mit meinen KIA CEED SW PHEVbluelink.0 2025-10-12 11:17:30.195 info Update for U5XXXXXXXL005240 successfull bluelink.0 2025-10-12 11:17:29.980 info State value to set for "bluelink.0.U5XXXXXXXL005240.vehicleStatus.steerWheelHeat" has to be type "number" but received type "boolean" bluelink.0 2025-10-12 11:17:19.306 info Read new update for U5XXXXXXXL005240directly from the car bluelink.0 2025-10-12 11:17:18.928 info 1 Vehicles found bluelink.0 2025-10-12 11:17:17.468 info Login to api bluelink.0 2025-10-12 11:17:17.418 info starting. Version 3.1.21 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.3, js-controller: 7.0.6 host.raspberrypi 2025-10-12 11:17:12.741 info instance system.adapter.bluelink.0 in version "3.1.21" (non-npm: Newan/ioBroker.bluelink) started with pid 529176
mit 3.1.3
0bekomme ich wieder den Login Fehlerbluelink.0 2025-10-12 11:15:34.978 error next auto login attempt in 1 hour or restart adapter manual bluelink.0 2025-10-12 11:15:34.977 error Server is not available or login credentials are wrong bluelink.0 2025-10-12 11:15:34.975 error ManagedBluelinkyError: @EuropeController.login: [401] Unauthorized on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/language - "{\"errId\":\"a3384d70-0c45-4655-a1c6-cd08f30b2c83\",\"errCode\":\"4010\",\"errMsg\":\"Require authentication\"}\n" bluelink.0 2025-10-12 11:15:33.798 info Login to api bluelink.0 2025-10-12 11:15:33.752 info starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.3, js-controller: 7.0.6 host.raspberrypi 2025-10-12 11:15:29.468 info instance system.adapter.bluelink.0 in version "3.1.3" started with pid 528234
Gruß Matze
@hoepps2802 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
mit 3.1.30 bekomme ich wieder den Login Fehler
wovon redest du ??? was den für eine 3.1.30
@arteck sorry sehe es auch gerade
3.1.3 nicht 3.1.30
Von dem Problem für Hyundai-Fahrer habe ich gerade im GoingElectric-Forum gelesen.
https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/issues/919Tritt das Problem bei Hyundai-Fahrer hier auch auf?
Bei mir hat bis um 19.30 Uhr bluelink 3.1.8 ganz normal funktioniert. Gibt es für Hyundai auch schon eine LÖsung wie bei Kia?
bluelink.0 2025-10-14 20:25:09.410 error next auto login attempt in 1 hour or restart adapter manual bluelink.0 2025-10-14 20:25:09.410 error Server is not available or login credentials are wrong bluelink.0 2025-10-14 20:25:09.409 error ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v1/user/signin - {"errId":"58d79e3d-2138-4aaf-9776-af1de9188d7a","errCode":"4003","errMsg":"Invalid values"}
@meute ja hab auch das Problem mit dem Login
@michi_pi hier geht auch nichts mehr, kann man auch mit Leben, was solls
Hier die Lösung für Hyundai auch aus dem GoingElectric-Forum.
Man braucht den Refresh Token für Hyundai.Für Kia hat es @arteck hier beschrieben.
Für Hyundai ist der Ablauf genau so.
Man braucht nur ein anderes Python-Script.Ablauf für Kia beachten:
https://github.com/Hyundai-Kia-Connect/hyundai_kia_connect_api/wiki/Kia-Europe-Login-FlowDas Python-Script "HyundaiFetchApiTokens . py" für Hyundai gibt es hier:
https://gist.github.com/Maaxion/22a38ba8fb06937da18482ddf35171ac -
@meute so einfach ist das nicht... da die Anpassung an den hyundai Server in der 3.1.21 nicht da ist..
aber jetzt..3.1.22 ... neue Version von GIT laden.. der Fix ist nur für Hyundai also alle die KIA haben => ihr braucht das nicht da reicht die 3.1.21
was ist zu tun
@arteck
erstmal vielen Dank fuer die Muehe!
Seit heute geht die Version 3.1.6 / en bei mir nicht mehr.Also das bluelinky verzeichnis geloescht, Adapter V3.1.22 von git gezogen, nicht gestartet.
Verzeichnis auf meinem testpi angelegt, ein venv erzeugt, und das script gestartet, das geht auch, leider ist der Link hier nicht moeglich, ich lande auf einer Hyundai-Seite mit franzoesischer Fehlermeldung 400, wenn ich in dem Link anstatt fr auf de oder en stelle, das gleiche.. geht nicht.Somit kein Token - keine Daten. Ist wie, keine Arme, keine Kekse
@ilovegym gut dass ich deine Daten noch habe
guckmal PN -
@arteck
Hi, ich habe das bluelinky verzeichnis gelöscht, den Adapter V3.1.22 von git gezogen mit dem script den Refresh Token erstellt und als Passwort eingetragen. Jetzt kommen folgende Fehlermeldungen.host.Debian
2025-10-16 17:41:40.511 error instance system.adapter.bluelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[1]: Node.js v22.20.0host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: }host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: requestPath: 'bluelinky'host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: path: '/opt/iobroker/node_modules/bluelinky/package.json',host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1192:37)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at Function._resolveFilename (node:internal/modules/cjs/loader:1369:27)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at Function._findPath (node:internal/modules/cjs/loader:764:18)host.Debian
2025-10-16 17:41:40.511 error Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:502:19)host.Debian
2025-10-16 17:41:40.510 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/bluelinky/dist/index.cjs'. Please verify that the package.json has a valid "main" entryhost.Debian
2025-10-16 17:41:40.510 error Caught by controller[0]: ^host.Debian
2025-10-16 17:41:40.510 error Caught by controller[0]: throw err;host.Debian
2025-10-16 17:41:40.510 error Caught by controller[0]: node:internal/modules/cjs/loader:510 -
@fichte_112 jo warte da ist was nicht mitgekommen ins GIT
so jetzt lösch den nochmal
rm -r /opt/iobroker/node_modules/bluelinky/
und installier nochmal 3.1.23
Läuft!!! DANKE!!!
@arteck funktioniert, vielen Dank
@arteck Der Adapter läuft wieder. Vielen Dank nochmals.
Es fehlen aber noch einige Datenpunkte in den Objekten.
Bei mir geht es um einen Hyundai Tucson PHEV.
Fehlende Objekte, welche ich bisher genutzt habe:
Plugin, Reichweite Benzin, Reichweite elektrisch, Reichweite gesamt, Ladezustand, Restzeit vom laden. -
Hallo. Ich komme einfach nicht weiter. Wenn chrome unter windows aufgeht, dann melde ich mich mit meinen Hyundai-Zugangsdaten an. Aber dann komme ich auf eine Polnische Hyundai Webseite "click to buy"....
was mache ich falsch. Ich komme auch nicht weiter wenn ich das ganze über die konsole auf meiner iobroker-vm mache.
beim start in der konsole kommt das:
iobuser@iobroker:/tmp/kia$ python3 HyundaiFetchApiTokens.py File "/tmp/kia/HyundaiFetchApiTokens.py", line 124 <title>ioBroker.bluelink/py/HyundaiFetchApiTokens.py at master · Newan/ioBroker.bluelink · GitHub</title> ^ SyntaxError: invalid character '·' (U+00B7) iobuser@iobroker:/tmp/kia$
