ds18b20 remote : Wieder derselbe Fehler nach Update
OK, hier iob diag.
ich hatte heute "iob nodejs-update" auf dem hauptsystem gemacht. Nun sagt "iob diag" u.a. dass die dort installierte v22.15.0 gefährlich ist. Wie komme ich zurück?
OK, hier sehr langes diag-Ergebnis:
========== Start marking the full check here =========== ```bash Script v.2025-08-09 *** BASE SYSTEM *** Operating System: Raspbian GNU/Linux 11 (bullseye) Static hostname: iobrokerpi Icon name: computer Kernel: Linux 6.1.21-v8+ Architecture: arm64 OS is similar to: debian Model : Raspberry Pi 400 Rev 1.0 Docker : false Virtualization : none Kernel : aarch64 Userland : 32 bit Systemuptime and Load: 22:34:58 up 5 days, 12:40, 1 user, load average: 3.19, 1.46, 1.08 CPU threads: 4 *** LIFE CYCLE STATUS *** Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Wed 2025-10-15 22:34:58 CEST Universal time: Wed 2025-10-15 20:34:58 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin wireshark gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Display-Manager: * lightdm.service - Light Display Manager Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.4G 567M 13M 1.8G 2.4G Swap: 99M 0B 99M Total: 3.9G 1.4G 667M Active iob-Instances: 3 3794 M total memory 1355 M used memory 2069 M active memory 726 M inactive memory 589 M free memory 288 M buffer memory 1560 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 22:34:59 up 5 days, 12:40, 1 user, load average: 3.19, 1.46, 1.08 Tasks: 196 total, 7 running, 189 sleeping, 0 stopped, 0 zombie %Cpu(s): 80.3 us, 12.7 sy, 0.0 ni, 5.6 id, 0.0 wa, 0.0 hi, 1.4 si, 0.0 st MiB Mem : 3794.3 total, 584.1 free, 1360.7 used, 1849.6 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 2439.1 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * haveged.service loaded failed failed Entropy Daemon based on the HAVEGE algorithm * iobroker-ds18b20-remote.service loaded failed failed ioBroker.ds18b20 remote client LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 2 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 57G 17G 38G 31% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 7.7M 1.9G 1% /dev/shm tmpfs tmpfs 759M 1.2M 758M 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot tmpfs tmpfs 380M 12K 380M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Oct 10 09:54:38 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enabl e_hdmi=0 smsc95xx.macaddr=E4:5F:01:32:A1:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=b22b52c6-02 rootfstype=ext4 fsck.r epair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Fri Oct 10 09:54:39 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Fri Oct 10 09:54:39 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Fri Oct 10 09:54:42 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 5.2G /var/ 2.5G /var/lib 2.3G /var/lib/influxdb/data/iobroker/global 2.3G /var/lib/influxdb/data/iobroker 2.3G /var/lib/influxdb/data Archived and active journals take up 1.6G in the file system. /opt/iobroker/backups: 2.9G /opt/iobroker/backups/ 4.0K /opt/iobroker/backups/redistmp /opt/iobroker/iobroker-data: 455M /opt/iobroker/iobroker-data/ 263M /opt/iobroker/iobroker-data/files 158M /opt/iobroker/iobroker-data/backup-objects 47M /opt/iobroker/iobroker-data/files/admin.admin 46M /opt/iobroker/iobroker-data/files/admin.admin/custom/assets The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map 16M /opt/iobroker/iobroker-data/objects.jsonl 9.8M /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js 9.3M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js 8.6M /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v22.15.0 /usr/bin/node v22.15.0 /usr/bin/npm 10.9.2 /usr/bin/npx 10.9.2 /usr/bin/corepack 0.32.0 nodejs: Installed: 22.15.0-1nodesource1 Candidate: 22.15.0-1nodesource1 Version table: *** 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u7 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: ██████ █████ ███ ██ ██████ ███████ ███████ ██ ██ ██ ██ ████ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ██ ███ █████ ███████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██████ ██ ██ ██ ████ ██████ ███████ ██ ██ The current Node.js version (v22.15.0) is vulnerable to the following CVEs: CVE-2025-23166(high): The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime. Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2 = *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobrokerpi iobrokerpi (version: 7.0.7, hostname: iobrokerpi , alive, uptime: 79) Core adapters versions js-controller: 7.0.7 admin: 7.7.2 javascript: 8.9.2 nodejs modules from github: 1 | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) Adapter State system.adapter.accuweather.0 : accuweather : iobrokerpi - enabled + system.adapter.admin.0 : admin : iobrokerpi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin system.adapter.alias-manager.0 : alias-manager : iobrokerpi - enabled system.adapter.backitup.0 : backitup : iobrokerpi - enabled system.adapter.ble.0 : ble : iobrokerpi - enabled system.adapter.device-watcher.0 : device-watcher : iobrokerpi - enabled system.adapter.devices.0 : devices : iobrokerpi - disabled system.adapter.discovery.0 : discovery : iobrokerpi - disabled system.adapter.ds18b20.0 : ds18b20 : iobrokerpi - enabled system.adapter.flot.0 : flot : iobrokerpi - disabled system.adapter.fritzdect.0 : fritzdect : iobrokerpi - enabled system.adapter.ham.0 : ham : iobrokerpi - enabled system.adapter.hm-rpc.0 : hm-rpc : iobrokerpi - enabled system.adapter.homekit-controller.0 : homekit-controller : iobrokerpi - disabled system.adapter.hue.0 : hue : iobrokerpi - disabled, port: 443 system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobrokerpi - enabled system.adapter.icons-icons8.0 : icons-icons8 : iobrokerpi - enabled + system.adapter.influxdb.0 : influxdb : iobrokerpi - enabled, port: 8086 system.adapter.info.0 : info : iobrokerpi - disabled system.adapter.iqontrol.0 : iqontrol : iobrokerpi - disabled system.adapter.javascript.0 : javascript : iobrokerpi - enabled system.adapter.modbus.0 : modbus : iobrokerpi - enabled system.adapter.net-tools.0 : net-tools : iobrokerpi - disabled system.adapter.netatmo-crawler.0 : netatmo-crawler : iobrokerpi - enabled system.adapter.ping.0 : ping : iobrokerpi - disabled system.adapter.rpi2.0 : rpi2 : iobrokerpi - disabled system.adapter.shelly.0 : shelly : iobrokerpi - enabled, port: 1884, bind: 0.0.0.0 system.adapter.smartmeter.0 : smartmeter : iobrokerpi - disabled system.adapter.smartthings.0 : smartthings : iobrokerpi - disabled system.adapter.solaredge.0 : solaredge : iobrokerpi - disabled system.adapter.sonoff.0 : sonoff : iobrokerpi - enabled, port: 1882, bind: 192.168.220.41 system.adapter.statistics.0 : statistics : iobrokerpi - disabled system.adapter.synochat.0 : synochat : iobrokerpi - enabled system.adapter.synology.0 : synology : iobrokerpi - disabled, port: 5001 system.adapter.tr-064.0 : tr-064 : iobrokerpi - disabled system.adapter.tuya.0 : tuya : iobrokerpi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokerpi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : iobrokerpi - enabled system.adapter.vis-inventwo.0 : vis-inventwo : iobrokerpi - enabled system.adapter.vis-justgage.0 : vis-justgage : iobrokerpi - enabled system.adapter.vis-map.0 : vis-map : iobrokerpi - enabled system.adapter.vis.0 : vis : iobrokerpi - enabled system.adapter.web.0 : web : iobrokerpi - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.wifilight.0 : wifilight : iobrokerpi - disabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobrokerpi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin + system.adapter.influxdb.0 : influxdb : iobrokerpi - enabled, port: 8086 system.adapter.shelly.0 : shelly : iobrokerpi - enabled, port: 1884, bind: 0.0.0.0 system.adapter.sonoff.0 : sonoff : iobrokerpi - enabled, port: 1882, bind: 192.168.220.41 system.adapter.web.0 : web : iobrokerpi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬────────────────────┬───────────────────────────────────────────────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼───────────────────────────────────────────────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ │ 2 │ 'online' │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json' │ false │ └─────────┴────────────────────┴───────────────────────────────────────────────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "accuweather" : 2.1.1 , installed 2.1.1 Adapter "admin" : 7.7.2 , installed 7.7.2 Adapter "alias-manager": 2.0.0 , installed 2.0.0 Adapter "backitup" : 3.3.5 , installed 3.3.5 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "bydbatt" : 1.1.0 , installed 1.1.0 Adapter "device-watcher": 2.13.1 , installed 2.13.1 Adapter "devices" : 1.2.8 , installed 1.2.8 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "ds18b20" : 3.0.1 , installed 3.0.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.6.2 , installed 2.6.2 Adapter "ham" : 5.3.1 , installed 5.3.1 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "homekit-controller": 0.5.11, installed 0.5.11 Adapter "hue" : 3.16.2 , installed 3.16.2 Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iqontrol" : 3.0.0 , installed 3.0.0 Adapter "javascript" : 8.9.2 , installed 8.9.2 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "net-tools" : 1.1.2 , installed 1.1.2 Adapter "netatmo-crawler": 1.1.0 , installed 1.1.0 Adapter "ping" : 1.6.2 , installed 1.7.3 Adapter "rpi2" : 2.4.0 , installed 2.4.0 Adapter "shelly" : 10.2.0 , installed 10.2.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartmeter" : 3.4.0 , installed 3.4.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "solaredge" : 1.4.1 , installed 1.4.1 Adapter "sonoff" : 3.2.1 , installed 3.2.1 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "synochat" : 1.3.3 , installed 1.3.3 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.18.0 , installed 1.18.0 Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-map" : 1.1.2 , installed 1.1.2 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "wifilight" : 2.0.3 , installed 2.0.3 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 4431 States: 3259 *** OS-Repositories and Updates *** W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx> W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx> W: Some index files failed to download. They have been ignored, or old ones used instead. Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Get:3 https://dl.yarnpkg.com/debian stable InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Hit:5 https://repo.homebridge.io stable InRelease Err:3 https://dl.yarnpkg.com/debian stable InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx> Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease Fetched 17.1 kB in 1s (12.4 kB/s) Reading package lists... W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx> W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx> W: Some index files failed to download. They have been ignored, or old ones used instead. Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1599201 28586/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1599840 28586/iobroker.js-c tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 1599394 28734/io.shelly.0 tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 999 14023 739/pihole-FTL tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 1314469 24575/cupsd tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 1933 1014/exim4 tcp 0 0 192.168.220.41:1882 0.0.0.0:* LISTEN 1001 1600163 28747/io.sonoff.0 tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 109 13188 476/influxd tcp 0 0 127.0.0.1:1883 0.0.0.0:* LISTEN 119 1753 506/mosquitto tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 1970 1002/lighttpd tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 14431 520/sshd: /usr/sbin tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 999 14017 739/pihole-FTL tcp 0 0 192.168.220.41:42010 0.0.0.0:* LISTEN 1001 1599457 28890/io.hm-rpc.0 tcp6 0 0 :::8081 :::* LISTEN 1001 1599282 28607/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 1602719 29123/io.web.0 tcp6 0 0 :::8086 :::* LISTEN 109 15672 476/influxd tcp6 0 0 ::1:631 :::* LISTEN 0 1314468 24575/cupsd tcp6 0 0 :::1820 :::* LISTEN 1001 1603896 29271/io.ds18b20.0 tcp6 0 0 ::1:4711 :::* LISTEN 999 14024 739/pihole-FTL tcp6 0 0 ::1:25 :::* LISTEN 0 1934 1014/exim4 tcp6 0 0 :::3389 :::* LISTEN 117 13225 523/xrdp tcp6 0 0 ::1:1883 :::* LISTEN 119 1754 506/mosquitto tcp6 0 0 :::51750 :::* LISTEN 998 15714 1088/homebridge tcp6 0 0 :::80 :::* LISTEN 0 1971 1002/lighttpd tcp6 0 0 ::1:3350 :::* LISTEN 0 13112 507/xrdp-sesman tcp6 0 0 :::22 :::* LISTEN 0 14433 520/sshd: /usr/sbin tcp6 0 0 :::53 :::* LISTEN 999 14019 739/pihole-FTL tcp6 0 0 :::8581 :::* LISTEN 998 14079 1046/hb-service udp 0 0 0.0.0.0:5353 0.0.0.0:* 998 14076 1046/hb-service udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 1617 324/avahi-daemon: r udp 0 0 0.0.0.0:54644 0.0.0.0:* 108 1619 324/avahi-daemon: r udp 0 0 0.0.0.0:53 0.0.0.0:* 999 14016 739/pihole-FTL udp6 0 0 fe80::3d11:1894:391:546 :::* 0 14514 342/NetworkManager udp6 0 0 :::5353 :::* 108 1618 324/avahi-daemon: r udp6 0 0 :::54718 :::* 108 1620 324/avahi-daemon: r udp6 0 0 :::53 :::* 999 14018 739/pihole-FTL *** Log File - Last 25 Lines *** 2025-10-15 22:35:27.778 - info: javascript.0 (28687) Start JavaScript script.js.Heizungen.Badfußboden_Soll_an_Heizung_(Homematic)_angleichen (Blockly) 2025-10-15 22:35:27.786 - info: javascript.0 (28687) script.js.Heizungen.Badfußboden_Soll_an_Heizung_(Homematic)_angleichen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions 2025-10-15 22:35:29.094 - error: hm-rpc.0 (28890) xmlrpc -> setValue ["001F9F29B2C4F0:HomeMatic-Servicemeldungen",null,"Derzeit keine Servicemeldungen"] undefined 2025-10-15 22:35:29.097 - error: hm-rpc.0 (28890) Cannot call setValue: XML-RPC fault: For input string: "HomeMatic-Servicemeldungen" 2025-10-15 22:35:29.620 - info: javascript.0 (28687) script.js.Anruf_an_SynoChat: Das Blockly Synology Chat Anrufer Versand wurde gestartet ✅ 2025-10-15 22:35:29.621 - warn: javascript.0 (28687) getState "tr-064.0.callmonitor.inbound.json" not found (3) 2025-10-15 22:35:29.622 - warn: javascript.0 (28687) at main (script.js.Anruf_an_SynoChat:49:15) 2025-10-15 22:35:29.622 - warn: javascript.0 (28687) at mainAsync (script.js.Anruf_an_SynoChat:16:5) 2025-10-15 22:35:31.617 - info: host.iobrokerpi instance system.adapter.vis.0 terminated while should be started once 2025-10-15 22:35:31.714 - info: host.iobrokerpi instance system.adapter.netatmo-crawler.0 terminated with code 0 (NO_ERROR) 2025-10-15 22:35:32.402 - warn: ds18b20.0 (29271) Error reading sensor 28-012212b8303c: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.439 - warn: ds18b20.0 (29271) Error reading sensor 28-3c1ce38132c3: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.460 - warn: ds18b20.0 (29271) Error reading sensor 28-062017fe1767: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.474 - warn: ds18b20.0 (29271) Error reading sensor 28-062017fde388: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.524 - warn: ds18b20.0 (29271) Error reading sensor 28-0620181c6e58: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.569 - warn: ds18b20.0 (29271) Error reading sensor 28-3ccfe38142b0: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.633 - warn: ds18b20.0 (29271) Error reading sensor 28-062017f1b859: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.674 - warn: ds18b20.0 (29271) Error reading sensor 28-3c68f6498fbb: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.713 - warn: ds18b20.0 (29271) Error reading sensor 28-3c27f6498941: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.749 - warn: ds18b20.0 (29271) Error reading sensor 28-3c50f64995df: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.768 - warn: ds18b20.0 (29271) Error reading sensor 28-00000002400d: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.784 - warn: ds18b20.0 (29271) Error reading sensor 28-3cc2f64915c2: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.798 - warn: ds18b20.0 (29271) Error reading sensor 28-3c7ae381bdc0: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.832 - warn: ds18b20.0 (29271) Error reading sensor 28-3c2be3819166: Error: Remote system temperaturraspi is not connected. 2025-10-15 22:35:32.901 - warn: ds18b20.0 (29271) Error reading sensor 28-3c5df649bd65: Error: Remote system temperaturraspi is not connected.
iob diag has finished.
@thomas-braun Danke ja. Zu Fuß habe ich das gemacht. Aber er bleibt dann bei v 20, wogegen iob -nodejs-update auf dem Hauptsystem v22 installiert hat (was diag jetzt als gefährlich anmeckert)
Installier da NEU ein reines 64Bit-System. Du fährst da diesen Mix aus 32Bit-Userland und 64Bit-Kernel.
Das funktioniert nicht richtig gut. Noch dazu ist dein OS abgesoffen:
@mcm1957 Danke. Das lief bisher ganz gut. ich wollte nur nach 1,7 Jahren den Remote-Raspi mal wieder updaten. never update a running system? Wohl doch auch nicht.
Interessant ist die Frage mit der remote-Installation im alten Thread. Damals hatte ich von @crycode eine anderen Link bekommen, als im Adapter angegeben.
Der funkltionierte einen Tag nicht, später dann plötzlich doch. Damit ging es. Nun geht es aber hier wieder nicht. u.a. hatte ich gehofft, ob jemand von einer Aktualisierung dort weiße. Aber das scheint noch alles der alte Zustand zu sein.
Statt dessen habe ich nun a) das nodejs-Problem am Hals und b) die Verbindung zum remote geht gar nicht mehr.
@thomas-braun Danke, wie mache ich das am besten?
@wrod sagte in ds18b20 remote : Wieder derselbe Fehler nach Update:
Immer, immer, immer updaten. Man verwendet keine Releases, die EOL sind.
So:
https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht -
@thomas-braun OK- das geht über update oder -dist-update nicht?
Nein.
@thomas-braun OK. Damit spiele ich ein neues OS auf.
Was aber mache ich mit den übrigen Daten auf der SD?- Vor dem Flashen eine ganze Kopie anlegen
- Nach dem Flashen die Kopie wieder aufspielen und alles Überschreiben verweigern?
Ist es das schon?
Backup anlegen.
Nicht 1:1 wieder alles draufklatschen. Ein ordentliches Backup der Nutzdaten anlegen und nur diese einspielen.
@thomas-braun OK, doch noch eine Frage, Ich bin eben kein Linux Experte.
Es geht hier ja um ein Backup vor/nach einem OS-Update.
D.H., es geht nicht um ein Backup der gesamten Systems bzw. der gesamten SD-Karte, denn am Ende soll das System ja neu sein, aber die Nutzerdaten weder aufgespielt sein.Aber es soll auch nicht nur ein Backup von iobroker sein ("iobroker backup"), sonder da gibt es ja sicher im Hintergrund "oberhalb" des OB, aber "unterhalb" von iobroker u.a. weiteres.
Was also muss / kann alles gesichert werden -- /home/pi?
Das weißt du besser als ich. Woher soll ich wissen, was da alles noch zusätzlich läuft und gesichert werden kann.
