      welli last edited by
      Hallo
      Bekomme seit einigen Tagen diese Info im Protokoll Fenster.
      Hat jemand ein Idee wie was das sein könnte?
      mqtt.0
      2025-10-10 18:32:45.158 info Client [DVES_0B8CD4] connection closed: Error: read ECONNRESET
      mqtt.0
      2025-10-10 18:30:47.717 info Client [DVES_0B8CD4] publishOnSubscribe send all known states
      mqtt.0
      mqtt.0
      2025-10-10 18:30:47.715 info Client [DVES_0B8CD4] publishOnSubscribe send all known states
      mqtt.0
      2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "cmnd/DVES_0B8CD4_fb/#" with regex /^mqtt.0.cmnd.DVES_0B8CD4_fb..*/
      mqtt.0
      2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "cmnd/DVES_0B8CD4_fb/#" with regex /^cmnd.DVES_0B8CD4_fb..*/
      mqtt.0
      2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt.0.SmartHome.tasmotas.cmnd..*/
      mqtt.0
      2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome.tasmotas.cmnd..*/
      mqtt.0
      2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/NSPanel_2/cmnd/#" with regex /^mqtt.0.SmartHome.NSPanel_2.cmnd..*/
      mqtt.0
      2025-10-10 18:30:47.516 info Client [DVES_0B8CD4] subscribes on "SmartHome/NSPanel_2/cmnd/#" with regex /^SmartHome.NSPanel_2.cmnd..*/
      mqtt.0
      2025-10-10 18:30:47.463 info Client [DVES_0B8CD4] connected with secret 1760113847461_6512
      mqtt.0
      2025-10-10 18:30:47.277 info Client [DVES_0B8CD4] connection closed: Error: Cannot parse topic
      mqtt.0
      2025-10-10 18:30:47.277 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
      mqtt.0
      mqtt.0
      mqtt.0
      2025-10-10 18:30:42.684 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
      mqtt.0
      2025-10-10 18:30:42.558 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
      mqtt.0
      2025-10-10 18:30:42.268 info Client [DVES_0B8CD4] Received pubrel for unknown message ID: 25964
      • Armilar
        Armilar Most Active Forum Testing @welli last edited by Armilar
        @welli
        Sieh mal nach, ob da ein Haken bei "Ausgabe jeder Nachricht loggen (debug)" gesetzt ist. Falls ja, entfernen...
        Mir quatscht der MQTT-Adapter sowieso zu viel... Habe den Log-Level auf warn eingestellt. Dann kommt nur noch das wichtige...
          mschmidt @Armilar last edited by
          @armilar
          Hier das log im Debug Mode:
          debug.log
          debug_2.log
          Was mir aufgefallen ist, das die Anzeige des Datum/Uhrzeit immer noch bei Freitag 15:05 Uhr stehen geblieben ist
            TT-Tom @mschmidt last edited by
            @mschmidt
            Du wirst ein Problem mit Deiner MQTT Verbindung haben. Hast Du am MQTT Adapter oder am Panel in Tasmota was angepasst???
              mameier1234 @mschmidt last edited by
              @mschmidt
              nein, ich meine unten am Anfang vom Config-Teil:
              Da stand bei mir bei screensaverentity immer noch der alte wetteradapter.. Nachdem ich dies angepasst hatte, war alles ok. Da stand openweather (was ich nicht mal als adapter installiert hatte)
                   **                    Screensaver Configuration                      **
                  leftScreensaverEntity: [
                      // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
                  bottomScreensaverEntity: [
                      // bottomScreensaverEntity 1
                          ScreensaverEntity: 'pirate-weather.0.weather.currently.pressure',
                          ScreensaverEntityFactor: 1,
                          ScreensaverEntityDecimalPlaces: 0,
                          ScreensaverEntityIconOn: 'gauge',
                          ScreensaverEntityIconOff: null,
                          ScreensaverEntityText: 'Druck',
                          ScreensaverEntityUnitText: 'hPa',
                          ScreensaverEntityIconColor: {'val_min': 950, 'val_max': 1050, 'val_best': 1013}
                welli @Armilar last edited by
                @armilar
                "Ausgabe jeder Nachricht loggen (debug)" ist nicht gesetzt.
                Info kommt immer noch aber nur von einem von zwei Paneelen
                Hier drunter meine MQTT einstellungen.
                  ticaki last edited by
                  Achtung! - BREAKING change in der Tasmota Firmware
                  Tasmota 15.1.0 hat ungenannte Änderungen, die das flashen der TFT Firmware unmöglich machen
                  nicht updaten auf die neuste Tasmota Version
                  Wir sind dran. 🙂
                  1 Reply Last reply Reply Quote 5
                  • MichaelF
                    MichaelF last edited by
                    Hätte eine kurze Frage. Ich möchte den Wetter Adapter ändern dazu muss ich den Script updaten.
                    Ich komme von 4.7.1.2, reicht es nur den unteren Teil zu ersetzen oder muss ich komplett?
                    Alternativ vielleicht gleich auf den neuen Adapter wechseln?
                    Und ich lese grade, ja ich habe schon das neue Update
                    Grüsse
                    • Armilar
                      Armilar Most Active Forum Testing @MichaelF last edited by Armilar
                      @michaelf
                      Du kannst natürlich auf den neuen Adapter wechseln... Ist aber nicht zu 100% kompatibel mit dem Skript, dafür aber mächtiger in der Funktionalität... Ich Stelle auch den größten Teil der Panels auf den Adapter um...
                      Falls weiter mit dem Script, dann sollte bei der 4.7.1 reichen den unteren Teil zu tauschen, den Berry upzugraden und das TFT zu flashen:
                      https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
                      Tasmota BerryDriver Update:
                      Backlog UpdateDriverVersion https://raw.githubusercontent.com/ticaki/ioBroker.nspanel-lovelace-ui/refs/heads/main/tasmota/berry/10/autoexec.be; Restart 1
                      TFT EU STABLE Version:
                      FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
                      PS.: Aus meiner Sicht ist es bei dem NSPanel-Adapter nur noch Kleinkram mit wenig Kinderkrankheiten... Also finale Phase
                      MichaelF 1 Reply Last reply Reply Quote 0
                      • MichaelF
                        MichaelF @Armilar last edited by
                        @armilar Danke für die schnelle Antwort, ich denke ich bleibe dann erst mal beim Script ich bräuchte die hochkant us Version fürs Display.
                        Die neuste Tasmota Version ist kein Problem?
                          ticaki @MichaelF last edited by
                          @michaelf sagte in SONOFF NSPanel mit Lovelace UI:
                          DOCH die ist inkompatibel - 15.0.1 ist aktuell die höchste die keine Probleme macht
                          1.0k
                          lovelace ui nspanel sonoff
                          270
                          7684
                          6507371
