    3. Cloud Dienste
    4. BETA-TEST Neuer Amazon Skill "iobroker.assistant"
    • Duffy
      Duffy @Samson71 last edited by
      @samson71
      Danke schön
        Rushmed Most Active @motugozu last edited by
        @motugozu Nein, das ist das toggle Feature. Ist neu in AlexaV3 und kann deaktiviert werden. Steht auf Github.
        • Michael Schmitt
          Michael Schmitt @apollon77 last edited by
          @apollon77
          iobroker.assistent skill + iot.0 v 4.1.4
          ich bekomme folgende Meldung beim ausschalten des Lichts. Mit Aliases ebenso direkt mit den deconz Datenpunkten probiert.
          deconz.0
          	2025-10-18 14:23:51.844	warn	{"address":"/lights/9/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
          deconz.0
          	2025-10-18 14:23:51.843	warn	Failed action "bri" on light 9! Description: parameter, bri, is not modifiable. Device is set to off.
          deconz.0
          	2025-10-18 14:23:51.832	warn	{"address":"/lights/28/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
          deconz.0
          	2025-10-18 14:23:51.831	warn	Failed action "bri" on light 28! Description: parameter, bri, is not modifiable. Device is set to off.
          javascript.0
          	2025-10-18 14:23:37.431	info	script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: iot.0 is connected Wert: true Adapter ist wieder erreichbar
          deconz.0
          	2025-10-18 14:23:28.004	warn	{"address":"/lights/9/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
          deconz.0
          	2025-10-18 14:23:28.004	warn	Failed action "bri" on light 9! Description: parameter, bri, is not modifiable. Device is set to off.
          deconz.0
          	2025-10-18 14:23:27.998	warn	{"address":"/lights/28/state/bri","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
          deconz.0
          	2025-10-18 14:23:27.997	warn	Failed action "bri" on light 28! Description: parameter, bri, is not modifiable. Device is set to off.
          Fabio apollon77 2 Replies Last reply Reply Quote 0
          • Fabio
            Fabio @Michael Schmitt last edited by Fabio
            @michael-schmitt kannst du das Licht denn schalten direkt über die deconz Datenpunkte?
            Michael Schmitt 1 Reply Last reply Reply Quote 0
            • Michael Schmitt
              Michael Schmitt @Fabio last edited by
              @fabio
              Ja das kann ich. as Licht geht auch an und aus nur die Meldung kommt jedesmal. Die Meldung kommt jedoch nicht wenn ich mit % sage zB "Alexa licht 0 % dann geht es aus und es kommt keine Meldung.
              • Fabio
                @michael-schmitt also dann ist die Lampe im Netzwerk und auch erreichbar. Dann wüßte ich jetzt nicht wieso das so passiert. Teste doch mal ganz genau wann die Fehlermeldung kommt. Also alle Möglichkeiten probieren von Licht An und Aus oder mit % mit Sprachansage ohne und über die App ect. Und halte das mal in Schriftform fest und stelle es dann hier ein.
                • Michael Schmitt
                  @fabio
                  Meldung kommt nicht wenn:
                  • ich das per Sprache und % steuere
                  • wenn in Iot.0 nur AN/AUS ist und kein Level(%). Dann kann ich aber nicht dimmen
                  Meldung kommt wenn:
                  • ich per Sprache ausschalte (nicht beim einschalten)
                  • in der Alexa App beim ausschalten
                  es ist egal ob ich Aliase oder direkt Deconz Punkte nutze. Getestet mit bri und level zum dimmen
                  Fabio 1 Reply Last reply Reply Quote 0
                  • Fabio
                    @michael-schmitt ich denke dann das es ein Bug ist.
                    Mach mal bitte ein Issues auf mit diesen Informationen, dann hat @apollon77 es direkt am richtigen Platz.
                    Herzliche Grüße
                    Fabio
                    Michael Schmitt 1 Reply Last reply Reply Quote 1
                    • Michael Schmitt
                      @fabio
                      issue bei was iot - deconz - alexa v3 ? hmmmm
                        Rogni last edited by
                        @apollon77
                        bei der Nanoleaf shapes, auch das Problem wie bei Zigbee. Egal welchen %Wert ich angebe er dimmt immer auf null. Er schaltet dann aber auch den state nicht auf aus, sodaß ich erstmal händisch ausschalten muss
                        https://github.com/ioBroker/ioBroker.iot/issues/985
                        rogni38 created this issue in ioBroker/ioBroker.iot
                        closed Nanoleaf shapes Brightness dimmt immer auf 0% #985
                          mameier1234 @Rogni last edited by
                          Ich habe in der iot instanz auf AlexaV3 umgestellt, die Geräte wurden übernommen.
                          Dann habe ich auf dem Iphone in der Alexa app den iobroker.iot skill deaktiviert, dann den neuen Skill aktiviert.
                          Die Alexa app sagte: 17 neue Geräte gefunden.
                          Allerdings sehe ich in der App gar keine Geräte mehr, die sind komplett leer. Also auch alle anderen , von Hue, Shelly usw werden nicht angezeigt...
                          Hat mir da jemand einen tipp ?
                          • Duffy
                            Duffy @motugozu last edited by
                            @motugozu sagte in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
                            Habt ihr auch das Problem wenn eine Steckdose eingeschaltet ist und der da drauf folgende Befehl ist die Steckdose erneut " Ein zu schalten " Die Steckdose einfach ausgeht das ist doch ein Bug oder
                            Duffy 1 Reply Last reply Reply Quote 1
                            • Duffy
                              Duffy @Duffy last edited by
                              Frage an alle, ist bei euch die Reaktion der Zigbee Lampen nach einem einschalt Befehl auch „stark“ verzögert; zumindest im Vergleich zu früher?
                              Ist evtl das System aufgrund der vielen Tests von uns allen etwas angespannt?
                              Viele Grüße Duffy
                              • Fabio
                                @michael-schmitt iot adapter
                                  Sandy @Fabio last edited by
                                  hat das bei euch keiner das Alexa beim Suchen nach neuen Geräten kein Gerät findet ? 😞
                                  LG Sandy
                                  • BBTown
                                    BBTown @apollon77 last edited by
                                    @apollon77
                                    ich habe mitlerweile eine ganze Reihe von Problemen, bei denen ich nicht sicher bin ob die Ursache an der Umstellung liegt, oder es nur hier sichtbar wird.
                                    • Neuen Skill "iobroker.assist" aktiviert
                                    • Alten Skill "iobroker.iot" noch aktiviert gelassen
                                    • Alle ioBroker Geräte in der Alexa-App entfernt (sofern diese angezeigt wurden)
                                    • In ioBroker wurde in den Optionen der Instanz "iot.0" (v4.1.4) zusätzlich "Amazon Alexa V3" aktiviert.
                                    Es werden keine Geräte von "Amazon Alexa" in "Amazon Alexa V3" übernommen
                                    Es können manuell keine Geräte in "Amazon Alexa V3" hinzugefügt werden
                                    Beim Start der IOT-Instanz bekomme ich eine Reihe von Fehlern
                                    iot.0
                                    2025-10-18 19:20:42.814	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1545:13)
                                    iot.0
                                    2025-10-18 19:20:42.758	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                                    host.ioBroker
                                    2025-10-18 19:20:33.154	error	iobroker Cannot update apt sources: Command failed: apt updateWARNING: apt does not have a stable CLI interface. Use with caution in scripts.Fehler: Sperrdatei /var/lib/apt/lists/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)Fehler: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.Warnung: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - RemoveCaches (13: Keine Berechtigung)Warnung: Problem beim Entfernen (unlink) der Datei /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Keine Berechtigung)
                                    host.ioBroker
                                    2025-10-18 19:20:33.110	error	iobroker Cannot detect \"sudo -n apt -v\": sudo: Ein Passwort ist notwendig
                                    iot.0
                                    2025-10-18 19:19:46.612	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1531:13)
                                    iot.0
                                    2025-10-18 19:19:46.526	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                                    iot.0
                                    2025-10-18 19:19:33.580	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1531:13)
                                    iot.0
                                    2025-10-18 19:19:33.568	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                                    iot.0
                                    2025-10-18 19:19:33.180	error	Cannot read connection certificates
                                    iot.0
                                    2025-10-18 19:19:33.172	error	Cannot fetch connection certificates: {"error":"Internal server error","time":"2025-10-18T17:19:33.031Z"}
                                    iot.0
                                    2025-10-18 19:18:21.674	error	[AlexaV3::DeviceManager]: TypeError: Cannot create property 'smartType' on string '' at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:440:36) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1531:13)
                                    iot.0
                                    2025-10-18 19:18:21.575	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot create property 'smartType' on string ''
                                    Da ich bem Starten ioBroker plötzlich ebenfalls Fehler erhalte - bei denen ich mir schwer tue diese zu lösen/lokalisieren, kann es natürlich sein, dass diese im Zusammenhang mit dem iot-Fehler stehen
                                    host.ioBroker
                                    2025-10-18 19:40:39.211	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
                                    host.ioBroker
                                    2025-10-18 19:40:39.209	error	Caught by controller[0]: (node:13552) [DEP0170] DeprecationWarning: The URL http://IP:PORT/api/events/raw is invalid. Future versions of Node.js will throw an error.
                                    host.ioBroker
                                    2025-10-18 19:40:34.562	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
                                    host.ioBroker
                                    2025-10-18 19:40:34.554	error	Caught by controller[0]: (node:13524) [DEP0170] DeprecationWarning: The URL http://IP:PORT/api/events/raw is invalid. Future versions of Node.js will throw an error.
                                    Jede Unterstützung ist herzlich Willkommen 😎😎
                                    haselchen apollon77 2 Replies Last reply Reply Quote 0
                                    • haselchen
                                      haselchen Most Active @BBTown last edited by haselchen
                                      @bbtown
                                      Schwierig zu sehen, auf was für nen System Du da unterwegs bist .
                                      Magst mal
                                      iob diag
                                      hier präsentieren !?
                                      Die ganzen Error Meldungen lassen sich vielleicht so eingrenzen .
                                        docsnyder7 @Sandy last edited by
                                        @sandy konntest du eine Lösung finden? Ich komme leider nicht weiter.. auch das aktivieren vom Alex deprecated bringt bei mir nix, die kleine findet keine neuen Geräte...
                                        • BBTown
                                          BBTown @haselchen last edited by
                                          @haselchen iob Diag findet alles prima ☝🏼🤓
                                          ========== Start marking the full check here ===========
                                          ```bash
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                          Operating System: Debian GNU/Linux 13 (trixie)
                                            Static hostname: ioBroker
                                                 Icon name: computer-vm
                                                   Chassis: vm 🖴
                                              AF_VSOCK CID: 1
                                            Virtualization: kvm
                                                    Kernel: Linux 6.12.48+deb13-amd64
                                              Architecture: x86-64
                                           Hardware Vendor: QEMU
                                            Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                          Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                                             Firmware Date: Tue 2014-04-01
                                              Firmware Age: 11y 6month 2w 4d
                                          OS is similar to:
                                          model name      : Common KVM processor
                                          Docker          : false
                                          Virtualization  : kvm
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           20:25:45 up 23 min,  1 user,  load average: 0.35, 0.33, 0.35
                                          CPU threads: 4
                                          *** LIFE CYCLE STATUS ***
                                          Operating System is the current Debian stable version codenamed 'trixie'!
                                          *** TIME AND TIMEZONES ***
                                                         Local time: Sat 2025-10-18 20:25:45 CEST
                                                     Universal time: Sat 2025-10-18 18:25:45 UTC
                                                           RTC time: Sat 2025-10-18 18:25:45
                                                        NTP service: active
                                                    RTC in local TZ: yes
                                          Warning: The system is configured to read the RTC time in the local time zone.
                                                   This mode cannot be fully supported. It will create various problems
                                                   with time zone changes and daylight saving time adjustments. The RTC
                                                   time is never updated, it relies on external facilities to maintain it.
                                                   If at all possible, use RTC in UTC by calling
                                                   'timedatectl set-local-rtc 0'.
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          memyself
                                          HOME=/home/memyself
                                          GROUPS=memyself sudo iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          SUDO_HOME=/home/memyself
                                          GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth
                                          *** DISPLAY-SERVER SETUP ***
                                          Display-Server:         false
                                          Unit display-manager.service could not be found.
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Mem:            4.1G        2.4G        1.4G        8.6M        543M        1.7G
                                          Swap:             0B          0B          0B
                                          Total:          4.1G        2.4G        1.4G
                                          Active iob-Instances:   26
                                                   3921 M total memory
                                                   2278 M used memory
                                                   2083 M active memory
                                                    283 M inactive memory
                                                   1350 M free memory
                                                     73 M buffer memory
                                                    444 M swap cache
                                                      0 M total swap
                                                      0 M used swap
                                                      0 M free swap
                                          top - 20:25:46 up 23 min,  1 user,  load average: 0.40, 0.35, 0.35
                                          Tasks: 148 total,   3 running, 145 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 21.7 us,  8.7 sy,  0.0 ni, 60.9 id,  0.0 wa,  0.0 hi,  8.7 si,  0.0 st
                                          MiB Mem :   3921.8 total,   1350.4 free,   2278.5 used,    519.0 buff/cache
                                          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1643.4 avail Mem
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** DMESG CRITICAL ERRORS ***
                                          No critical errors detected
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                          tmpfs          tmpfs     393M  5.5M  387M   2% /run
                                          /dev/sda1      ext4       40G   15G   23G  39% /
                                          tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                          tmpfs          tmpfs     2.0G  2.8M  2.0G   1% /tmp
                                          tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                                          tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
                                          tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                                          tmpfs          tmpfs     393M   12K  393M   1% /run/user/1003
                                          [Sat Oct 18 20:03:17 2025] EXT4-fs (sda1): mounted filesystem e627c9a7-1a96-462a-8b7f-0ca843bca944 ro with ordered data mode. Quota mode: none.
                                          [Sat Oct 18 20:03:18 2025] EXT4-fs (sda1): re-mounted e627c9a7-1a96-462a-8b7f-0ca843bca944 r/w.
                                          Show mounted filesystems:
                                          TARGET SOURCE    FSTYPE OPTIONS
                                          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                          /var:
                                          303M    /var/
                                          155M    /var/lib
                                          140M    /var/cache
                                          127M    /var/cache/apt
                                          97M     /var/lib/apt
                                          No journal files were opened due to insufficient permissions.
                                          /opt/iobroker/backups:
                                          41M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          409M    /opt/iobroker/iobroker-data/
                                          280M    /opt/iobroker/iobroker-data/files
                                          85M     /opt/iobroker/iobroker-data/backup-objects
                                          47M     /opt/iobroker/iobroker-data/files/admin.admin
                                          46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                          24M     /opt/iobroker/iobroker-data/objects.jsonl
                                          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                          11M     /opt/iobroker/iobroker-data/objects.json
                                          8.2M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js
                                          8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-DDMXSE9w.js
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          Zigbee Network Settings on your coordinator/in nvbackup are:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          To unmask the settings run 'iob diag --unmask'
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v22.20.0
                                          /usr/bin/node           v22.20.0
                                          /usr/bin/npm            10.9.3
                                          /usr/bin/npx            10.9.3
                                          /usr/bin/corepack       0.34.0
                                          nodejs:
                                            Installed: 22.20.0-1nodesource1
                                            Candidate: 22.20.0-1nodesource1
                                            Version table:
                                           *** 22.20.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                                                  100 /var/lib/dpkg/status
                                               22.19.0-1nodesource1 1001
                                               22.18.0-1nodesource1 1001
                                               22.17.1-1nodesource1 1001
                                               22.17.0-1nodesource1 1001
                                               22.16.0-1nodesource1 1001
                                               22.15.1-1nodesource1 1001
                                               22.15.0-1nodesource1 1001
                                               22.14.0-1nodesource1 1001
                                               22.13.1-1nodesource1 1001
                                               22.13.0-1nodesource1 1001
                                               22.12.0-1nodesource1 1001
                                               22.11.0-1nodesource1 1001
                                               22.10.0-1nodesource1 1001
                                               22.9.0-1nodesource1 1001
                                               22.8.0-1nodesource1 1001
                                               22.7.0-1nodesource1 1001
                                               22.6.0-1nodesource1 1001
                                               22.5.1-1nodesource1 1001
                                               22.5.0-1nodesource1 1001
                                               22.4.1-1nodesource1 1001
                                               22.4.0-1nodesource1 1001
                                               22.3.0-1nodesource1 1001
                                               22.2.0-1nodesource1 1001
                                               22.1.0-1nodesource1 1001
                                               22.0.0-1nodesource1 1001
                                               20.19.5-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                               20.19.4-1nodesource1 1001
                                               20.19.3-1nodesource1 1001
                                               20.19.2+dfsg-1 500
                                                  500 http://ftp.debian.org/debian trixie/main amd64 Packages
                                               20.19.2-1nodesource1 1001
                                               20.19.1-1nodesource1 1001
                                               20.19.0-1nodesource1 1001
                                               20.18.3-1nodesource1 1001
                                               20.18.2-1nodesource1 1001
                                               20.18.1-1nodesource1 1001
                                               20.18.0-1nodesource1 1001
                                               20.17.0-1nodesource1 1001
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                          No problems detected
                                          Errors in npm tree: 0
                                          Checking for nodejs vulnerability:
                                          • Samson71
                                            Samson71 Global Moderator @docsnyder7 last edited by
                                            @docsnyder7
                                            @Sandy
                                            Die Geräte sind im iot aber unter V2/V3 vorhanden?
                                            1.3k
                                            759
                                            50576
