    3. Cloud Dienste
    4. BETA-TEST Neuer Amazon Skill "iobroker.assistant"
    • BBTown
      BBTown @haselchen last edited by
      @haselchen iob Diag findet alles prima ☝🏼🤓
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
        Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm 🖴
          AF_VSOCK CID: 1
        Virtualization: kvm
                Kernel: Linux 6.12.48+deb13-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
         Firmware Date: Tue 2014-04-01
          Firmware Age: 11y 6month 2w 4d
      OS is similar to:
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:25:45 up 23 min,  1 user,  load average: 0.35, 0.33, 0.35
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-10-18 20:25:45 CEST
                 Universal time: Sat 2025-10-18 18:25:45 UTC
                       RTC time: Sat 2025-10-18 18:25:45
                    NTP service: active
                RTC in local TZ: yes
      Warning: The system is configured to read the RTC time in the local time zone.
               This mode cannot be fully supported. It will create various problems
               with time zone changes and daylight saving time adjustments. The RTC
               time is never updated, it relies on external facilities to maintain it.
               If at all possible, use RTC in UTC by calling
               'timedatectl set-local-rtc 0'.
      *** Users and Groups ***
      User that called 'iob diag':
      memyself
      HOME=/home/memyself
      GROUPS=memyself sudo iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/memyself
      GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            4.1G        2.4G        1.4G        8.6M        543M        1.7G
      Swap:             0B          0B          0B
      Total:          4.1G        2.4G        1.4G
      Active iob-Instances:   26
               3921 M total memory
               2278 M used memory
               2083 M active memory
                283 M inactive memory
               1350 M free memory
                 73 M buffer memory
                444 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 20:25:46 up 23 min,  1 user,  load average: 0.40, 0.35, 0.35
      Tasks: 148 total,   3 running, 145 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 21.7 us,  8.7 sy,  0.0 ni, 60.9 id,  0.0 wa,  0.0 hi,  8.7 si,  0.0 st
      MiB Mem :   3921.8 total,   1350.4 free,   2278.5 used,    519.0 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1643.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     393M  5.5M  387M   2% /run
      /dev/sda1      ext4       40G   15G   23G  39% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     2.0G  2.8M  2.0G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     393M   12K  393M   1% /run/user/1003
      [Sat Oct 18 20:03:17 2025] EXT4-fs (sda1): mounted filesystem e627c9a7-1a96-462a-8b7f-0ca843bca944 ro with ordered data mode. Quota mode: none.
      [Sat Oct 18 20:03:18 2025] EXT4-fs (sda1): re-mounted e627c9a7-1a96-462a-8b7f-0ca843bca944 r/w.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      303M    /var/
      155M    /var/lib
      140M    /var/cache
      127M    /var/cache/apt
      97M     /var/lib/apt
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      41M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      409M    /opt/iobroker/iobroker-data/
      280M    /opt/iobroker/iobroker-data/files
      85M     /opt/iobroker/iobroker-data/backup-objects
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      11M     /opt/iobroker/iobroker-data/objects.json
      8.2M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js
      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-DDMXSE9w.js
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.20.0
      /usr/bin/node           v22.20.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.20.0-1nodesource1
        Candidate: 22.20.0-1nodesource1
        Version table:
       *** 22.20.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.5-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.19.4-1nodesource1 1001
           20.19.3-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://ftp.debian.org/debian trixie/main amd64 Packages
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      • Samson71
        Samson71 Global Moderator @docsnyder7 last edited by
        @docsnyder7
        @Sandy
        Die Geräte sind im iot aber unter V2/V3 vorhanden?
          docsnyder7 @Samson71 last edited by
          @samson71 Jepp
          im Screenshot ist das deprecated wieder deaktiviert, weil ich herumprobieren bin, auch mit Zertifikaten etc
            Thomas Braun Most Active @BBTown last edited by
            @bbtown sagte in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
            Außer die Uhrzeit und die Gruppenzugehörigkeit zur Gruppe adm.
            Und vielleicht im fehlenden Rest auch noch was.
            Hatt aber nix mit Alexa dann zu tun.
            • I
              ingel81 last edited by
              Gerade bei mir erfolgreich umgestellt auf den neuen Skill.
              Umfangreiches KNX Haus mit über ~400 Geräten (vieles davon Dupletten wegen Kombinationen wie "Licht Küche", "Küche Licht", "Küche Spots", u.s.w.).
              Lichter
              Dimmbare Lichter
              Steckdosen
              Rolläden
              KNX Szenen auslösen (DummyGeräte die ein Script triggern)
              Diverse Sensorik auslesen
              Klappt alles sehr gut! Vielen, vielen Dank euch für die schnelle Aktion! 😃
              Der Aufwand war eigentlich nur das alte Zeug in der App einzeln rauszuwerfen. Die Webseite auf der man alle Geräte löschen konnte gibt es leider nicht mehr.
              Z 1 Reply Last reply Reply Quote 1
              • Winni
                Winni last edited by
                Bei mir läuft leider nicht. Habe gerade die 4.1.5 installiert. Es kommen aber unter Alexa-Geräte V3 weiterhin keine Geräte und Fehlermeldungen im Log sind auch noch da.
                iot.0
                2025-10-18 20:41:41.712	error	[AlexaV3::DeviceManager]: TypeError: Cannot read properties of undefined (reading 'type') at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:341:47 at Array.forEach (<anonymous>) at /opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:334:42 at Array.forEach (<anonymous>) at Object.controls (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/Helpers/Utils.ts:333:21) at DeviceManager.collectEndpoints (/opt/iobroker/node_modules/iobroker.iot/src/lib/AlexaSmartHomeV3/DeviceManager.ts:139:36) at AlexaSH3.updateDevices (/opt/iobroker/node_modules/iobroker.iot/src/lib/alexaSmartHomeV3.ts:33:9) at IotAdapter.main (/opt/iobroker/node_modules/iobroker.iot/src/main.ts:1545:13)
                iot.0
                2025-10-18 20:41:41.634	error	[AlexaV3::DeviceManager]: failed to collect devices: TypeError: Cannot read properties of undefined (reading 'type')
                • BBTown
                  BBTown @Thomas Braun last edited by BBTown
                  @thomas-braun welchen fehlenden Rest meinst Du?
                  das ist die vollständige Ausgabe von "iob diag"
                  Welche Auswirkungen hat die ADM Zugehörigkeit bzw. wie korrigiere ich diese? Hier wurde von mir nichts beabsichtigt umgestellt.
                  Die Zeitzone ist hingegen gewollt ...
                  (Wenn ich dafür ein neues Thema aufmachen soll, bitte gerne Laut geben)
                    Nein.
                    Besser ist das.
                    Warum? Die Begründung, warum man die RTC nicht in lokaler Zeit betreiben sollte steht ja dabei.
                    • BBTown
                      hier geht es zu desem Thema weiter ...
                      https://forum.iobroker.net/topic/82541/fehler-deprication-warning
                      • Winni
                        Habe jetzt erneut die Installation über npm durchgeführt. Jetzt wurde die 4.1.6 installiert und alle Geräte sind, soweit ich sehen kann, unter Alexa Geräte V3 vorhanden und es erscheinen auch keine Fehlermeldungen mehr im Log. Allerdings werden die Geräte nicht in der Alexa-App gefunden.
                        BBTown 1 Reply Last reply Reply Quote 1
                          Rushmed Most Active last edited by
                          Der Umzug hat jetzt größtenteils geklappt. Offen ist noch das Setup von HUE Lmpen.
                          ich habe folgendes eingestellt:
                          Die Farbsteuerung und der dimmer fuktionieren garnicht. Beim Steuern per Sprachbefehlt wird immer auf Kaltweiß und maximale Helligkeit gestellt.
                          Ich weiß auch nicht welchen typ ich für Straturation abgen soll.
                          • Z
                            ZeroQool last edited by
                            @ingel81 said in BETA-TEST Neuer Amazon Skill "iobroker.assistant":
                            Lichter
                            Dimmbare Lichter
                            Steckdosen
                            Rolläden
                            Wie machst du das mit den Rückmeldung an die Gruppenadresse?
                            • BBTown
                              BBTown @Winni last edited by BBTown
                              @winni
                              @apollon77
                              Ich kann ebenfalls bestätigen, dass mit der v4.1.6 die Geräte bei mir nun in "Amazon Alexa V3" übernommen wurden.
                              Es können jetzt auch manuell im iot-Adapter unter "Alexa-Geräte V3" weitere Geräte hinzugefügt werden.
                              Keine Fehlermeldungen mehr im Log.
                              Die Geräte werden allerdings auch bei mir nicht in der Alexa-App gefunden
                              Nachdem ich in der Alexa App den iobroker.assistent skill noch einmal deaktiviert und erneut mit meinen Iobroker-Pro Account aktiviert habe, wurden meine Geräte eingelesen
                              Winni 1 Reply Last reply Reply Quote 3
                              • Winni
                                Winni @BBTown last edited by
                                Habe ich auch probiert, aber bei mir leider ohne Erfolg.
                                  docsnyder7 @Winni last edited by
                                  @winni das Gleiche hier…
                                  • I
                                    ingel81 @ZeroQool last edited by ingel81
                                    @zeroqool präzisiere mal die Frage oder schreib eine PM, damit ich weiß wie sehr oder wenig ich ausholen muss. Zu den Szenen oder allgemein?
                                    • Duffy
                                      Duffy @ingel81 last edited by
                                      Hallo an alle,
                                      wer kennt folgendes Problem.
                                      Ich habe den iot Adapter 4.1.6 (war auch schon bei 4.1.4 so) installiert und in dem auch Amazon Alexa Custom Skill aktiviert.
                                      wenn ich mich nun über das Handy in dem Skill anmelde wird folgende Meldung angezeigt:
                                      Gleich danach sagt Alexa aber über den Echo:
                                      "Ich habe im Moment schwierigkeiten auf deinen Custom iobroker Skill zuzugreifen"
                                      Auf dem Handy ist nun bei dem Skill wieder der Urspungsscreen zu sehen:
                                      Weis wer Rat?
                                      Und hat es schon einer von euch geschafft Temperatursensoren abzufragen? Das klappt auch noch nicht, vielleicht auch wegen oben genanntem Problem.
                                      Gruß Duffy
                                      BBTown apollon77 2 Replies Last reply Reply Quote 0
                                      • BBTown
                                        BBTown @docsnyder7 last edited by BBTown
                                        @docsnyder7 @Winni
                                        Ich weiß nicht ob das wichtig ist, jedoch habe ich vor dem deaktivieren und neu-aktivieren des "iobroker.assistent" skill auch den "iobroker.iot" skill deaktiviert.
                                        Nachtrag:
                                        Ichhatte zwischendurch im Adapter auch mal den Haken beim Custom skill rausgenommen.
                                        Ich bin mir aber bei den ganzen Versuchen nicht mehr sicher wie der Zustand war, als ich erfolg hatte - sorry!
                                        R Winni 2 Replies Last reply Reply Quote 0
                                        • BBTown
                                          BBTown @Duffy last edited by BBTown
                                          @duffy
                                          Gruß Duffy
                                          Ja, das hat bei mir funktioniert nachdem ich im iot-Adapter den Gerätetyp von "Thermostat" auf "Temperatur" geändert habe.
                                          Ich habe anschließend in der Alexa-App die Geräte neu suchen lassen, ich habe zwar den Hinweis bekommen, dass nichts neues gefunden wurde (das Gerät war ja auch nicht neu) aber die Temperaturen wurden nach einer Weile dann korrekt angesagt
                                            Rushmed Most Active @BBTown last edited by
                                            @bbtown Ich schaffe es auch nicht den Custom Skill zu aktivieren.
                                            Beim Versuch sagt Alexa "Der Service ist nicht aktiviert. Bitte aktivier die Integration im IOT Adapter.
                                            Die ist natürlich aktiv.
                                            759
                                            58496
