    4. RPI-Monitor und GPIO rpi2 v2.3.1
    • Torsten Lehmann
      Torsten Lehmann @Thomas Braun last edited by
      @thomas-braun said in RPI-Monitor und GPIO rpi2 v2.3.1:
      @torsten-lehmann
      Versionen? Insbesondere des Betriebssystems.
      Am besten mal die Ausgabe von
      iob diag
      vollständig hier rein.
      ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.47+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       15:26:50 up 1 day, 13:34,  1 user,  load average: 1.29, 1.13, 1.36
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-10-19 15:26:51 CEST
                 Universal time: Sun 2025-10-19 13:26:51 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/pi
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.2G        4.6G        652M         84M        3.2G        3.6G
      Swap:           2.1G        184M        2.0G
      Total:           10G        4.8G        2.6G
      Active iob-Instances:   41
               7820 M total memory
               4383 M used memory
               3900 M active memory
               2688 M inactive memory
                622 M free memory
                160 M buffer memory
               2881 M swap cache
               2047 M total swap
                175 M used swap
               1872 M free swap
      top - 15:26:51 up 1 day, 13:34,  1 user,  load average: 1.18, 1.11, 1.35
      Tasks: 228 total,   1 running, 227 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.0 us,  0.0 sy,  0.0 ni, 98.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7820.7 total,    621.6 free,   4384.0 used,   3043.1 buff/cache
      MiB Swap:   2048.0 total,   1872.2 free,    175.8 used.   3436.7 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                                Type      Size  Used Avail Use% Mounted on
      udev                                      devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs                                     tmpfs     1.6G   21M  1.6G   2% /run
      /dev/mmcblk0p2                            ext4       29G   11G   18G  38% /
      tmpfs                                     tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                                     tmpfs     5.0M   16K  5.0M   1% /run/lock
      tmpfs                                     tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs                                     tmpfs     3.9G  5.7M  3.9G   1% /tmp
      /dev/mmcblk0p1                            vfat      510M   66M  445M  13% /boot/firmware
      tmpfs                                     tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      //192.168.178.216/BackupHDD               cifs      1.8T  291G  1.6T  16% /mnt/smb
      //192.168.178.216/BackupHDD               cifs      1.8T  291G  1.6T  16% /mnt/nas
      //192.168.178.1/Fritz.NAS/Backup/iobroker cifs      237G  283M  236G   1% /opt/iobroker/backups
      tmpfs                                     tmpfs     783M  8.0K  783M   1% /run/user/1000
      [Sat Oct 18 01:52:33 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:75:02:0D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6eaa3a50-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
      [Sat Oct 18 01:52:35 2025] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Sat Oct 18 01:52:35 2025] EXT4-fs (mmcblk0p2): mounted filesystem f0abac56-08be-42e2-8726-9baa083e8685 ro with ordered data mode. Quota mode: none.
      [Sat Oct 18 01:52:37 2025] EXT4-fs (mmcblk0p2): re-mounted f0abac56-08be-42e2-8726-9baa083e8685 r/w.
      Show mounted filesystems:
      TARGET                  SOURCE                                    FSTYPE OPTIONS
      /                       /dev/mmcblk0p2                            ext4   rw,noatime
      |-/boot/firmware        /dev/mmcblk0p1                            vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      |-/mnt/nas              //192.168.178.216/BackupHDD               cifs   rw,relatime,vers=1.0,cache=strict,upcall_target=app,username=iobroker,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.216,file_mode=0755,dir_mode=0755,iocharset=utf8,soft,nounix,serverino,mapposix,reparse=nfs,rsize=61440,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      |-/mnt/smb              //192.168.178.216/BackupHDD               cifs   rw,relatime,vers=1.0,cache=strict,upcall_target=app,username=Administrator,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.216,file_mode=0755,dir_mode=0755,iocharset=utf8,soft,nounix,serverino,mapposix,reparse=nfs,rsize=61440,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      `-/opt/iobroker/backups //192.168.178.1/Fritz.NAS/Backup/iobroker cifs   rw,relatime,vers=1.0,cache=strict,upcall_target=app,username=NAS,domain=WORKGROUP,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,reparse=nfs,rsize=61440,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      4.0G    /var/
      1.7G    /var/lib
      1.5G    /var/lib/jellyfin
      1.3G    /var/lib/jellyfin/metadata
      751M    /var/lib/jellyfin/metadata/artists
      Archived and active journals take up 19M in the file system.
      /opt/iobroker/backups:
      277M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      882M    /opt/iobroker/iobroker-data/
      594M    /opt/iobroker/iobroker-data/files
      133M    /opt/iobroker/iobroker-data/backup-objects
      90M     /opt/iobroker/iobroker-data/files/vis
      82M     /opt/iobroker/iobroker-data/files/vis/widgets
      61M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2485847-if00
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.20.0
      /usr/bin/node           v22.20.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.20.0-1nodesource1
        Candidate: 22.20.0-1nodesource1
        Version table:
       *** 22.20.0-1nodesource1 600
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           22.19.0-1nodesource1 600
           22.18.0-1nodesource1 600
           22.17.1-1nodesource1 600
           22.17.0-1nodesource1 600
           22.16.0-1nodesource1 600
           22.15.1-1nodesource1 600
           22.15.0-1nodesource1 600
           22.14.0-1nodesource1 600
           22.13.1-1nodesource1 600
           22.13.0-1nodesource1 600
           22.12.0-1nodesource1 600
           22.11.0-1nodesource1 600
           22.10.0-1nodesource1 600
           22.9.0-1nodesource1 600
           22.8.0-1nodesource1 600
           22.7.0-1nodesource1 600
           22.6.0-1nodesource1 600
           22.5.1-1nodesource1 600
           22.5.0-1nodesource1 600
           22.4.1-1nodesource1 600
           22.4.0-1nodesource1 600
           22.3.0-1nodesource1 600
           22.2.0-1nodesource1 600
           22.1.0-1nodesource1 600
           22.0.0-1nodesource1 600
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 1997)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      nodejs modules from github:     2
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.denon.0                  : denon                 : raspberrypi                              - disabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.geofency.0               : geofency              : raspberrypi                              -  enabled, port: 7999, bind: 192.168.178.8
      + system.adapter.geofency.1               : geofency              : raspberrypi                              -  enabled, port: 7998, bind: 0.0.0.0
        system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 8883, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : raspberrypi                              -  enabled, port: 1888, bind: 0.0.0.0
      + system.adapter.mqtt.3                   : mqtt                  : raspberrypi                              -  enabled, port: 1887, bind: 0.0.0.0
      + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
        system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 192.168.178.8
      + system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.8
      + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        system.adapter.sql.0                    : sql                   : raspberrypi                              - disabled, port: 3306
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.trashschedule.1          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "devices"      : 1.2.8    , installed 1.2.8
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ical"         : 1.17.0   , installed 1.17.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "tvprogram"    : 4.0.0    , installed 4.0.0
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Adapter    "zigbee"       : 3.0.5    , installed 2.0.5  [Updatable]
      Objects and States
      Objects:        26033
      States:         21042
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
      Hit:7 https://repo.jellyfin.org/debian trixie InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8096            0.0.0.0:*               LISTEN      104        8453       881/jellyfin
      tcp        0      0 192.168.178.8:1883      0.0.0.0:*               LISTEN      1001       1490509    205104/io.sonoff.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1489082    204345/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1487274    204345/iobroker.js-
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       1493013    204652/io.mqtt.2
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       1492012    204911/io.mqtt.3
      tcp        0      0 0.0.0.0:46425           0.0.0.0:*               LISTEN      1001       1493611    205326/io.yahka.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4435       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8275       870/sshd: /usr/sbin
      tcp        0      0 192.168.178.8:7999      0.0.0.0:*               LISTEN      1001       1487818    204557/io.geofency.
      tcp6       0      0 :::7998                 :::*                    LISTEN      1001       1489861    204564/io.geofency.
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       1492947    205486/io.onvif.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      997        869433     118553/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1496096    205759/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1489119    204366/io.admin.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          114        1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          8277       870/sshd: /usr/sbin
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1491781    205152/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1491782    205152/io.tuya.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1488776    204513/io.broadlink
      udp        0      0 0.0.0.0:60566           0.0.0.0:*                           1001       1491820    205724/io.upnp.0
      udp        0      0 0.0.0.0:7359            0.0.0.0:*                           104        8444       881/jellyfin
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1492122    204990/io.radar2.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5248       1/init
      udp        0      0 0.0.0.0:53520           0.0.0.0:*                           101        6079       644/avahi-daemon: r
      udp        0      0 0.0.0.0:41243           0.0.0.0:*                           1001       1488848    204513/io.broadlink
      udp        0      0 0.0.0.0:54456           0.0.0.0:*                           1001       1491819    205724/io.upnp.0
      udp        0      0 0.0.0.0:38083           0.0.0.0:*                           1001       1488847    204513/io.broadlink
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1491739    205770/io.wled.0
      udp        0      0 192.168.178.9:5353      0.0.0.0:*                           1001       1491332    205141/io.tr-064.0
      udp        0      0 192.168.178.8:5353      0.0.0.0:*                           1001       1491331    205141/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6077       644/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1496143    205724/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1496142    205724/io.upnp.0
      udp        0      0 0.0.0.0:55177           0.0.0.0:*                           1001       1488885    204513/io.broadlink
      udp6       0      0 :::111                  :::*                                0          5249       1/init
      udp6       0      0 :::57583                :::*                                101        6080       644/avahi-daemon: r
      udp6       0      0 fe80::c9f6:8539:e3c:546 :::*                                0          1280423    696/NetworkManager
      udp6       0      0 fe80::e61f:a7d2:6cb:546 :::*                                0          9228       696/NetworkManager
      udp6       0      0 :::5353                 :::*                                101        6078       644/avahi-daemon: r
      2025-10-19 15:28:00.350  - info: fritzdect.0 (205454) DECT ID: 152820238394 identified for command (tsoll) : 26
      2025-10-19 15:28:00.352  - info: fritzdect.0 (205454) DECT ID: 152820187400 identified for command (windowopenactiv) : false
      2025-10-19 15:28:00.356  - info: fritzdect.0 (205454) DECT ID: 152820238394 identified for command (windowopenactiv) : false
      2025-10-19 15:28:00.403  - info: fritzdect.0 (205454) DECT ID: 152820235489 identified for command (hkrmode) : 0
      2025-10-19 15:28:00.415  - info: fritzdect.0 (205454) DECT ID: 152820236432 identified for command (hkrmode) : 1
      2025-10-19 15:28:00.428  - info: fritzdect.0 (205454) DECT ID: 152820240822 identified for command (hkrmode) : 1
      2025-10-19 15:28:00.434  - info: fritzdect.0 (205454) DECT ID: 152820312905 identified for command (hkrmode) : 0
      2025-10-19 15:28:00.437  - info: fritzdect.0 (205454) DECT ID: 152820312895 identified for command (hkrmode) : 0
      2025-10-19 15:28:00.445  - info: fritzdect.0 (205454) DECT ID: 152820312842 identified for command (hkrmode) : 0
      2025-10-19 15:28:00.537  - info: fritzdect.0 (205454) DECT ID: 152820238470 identified for command (hkrmode) : 1
      2025-10-19 15:28:00.548  - info: fritzdect.0 (205454) DECT ID: 152820228774 identified for command (hkrmode) : 1
      2025-10-19 15:28:00.557  - info: fritzdect.0 (205454) DECT ID: 152820313144 identified for command (hkrmode) : 1
      2025-10-19 15:28:00.573  - info: sonoff.0 (208633) terminating
      2025-10-19 15:28:00.581  - info: sonoff.0 (208633) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2025-10-19 15:28:00.583  - info: fritzdect.0 (205454) DECT ID: 152820187400 identified for command (hkrmode) : 0
      2025-10-19 15:28:00.587  - info: fritzdect.0 (205454) DECT ID: 152820238394 identified for command (hkrmode) : 0
      2025-10-19 15:28:01.338  - info: host.raspberrypi instance system.adapter.sonoff.0 scheduled normal terminated and will be restarted on schedule.
      2025-10-19 15:28:01.339  - info: host.raspberrypi Restart adapter system.adapter.sonoff.0 because enabled
      2025-10-19 15:28:01.950  - info: influxdb.0 (204377) Connecting http://192.168.178.8:8086/ ...
      2025-10-19 15:28:01.950  - info: influxdb.0 (204377) Influx DB Version used: 2.x
      2025-10-19 15:28:01.960  - error: influxdb.0 (204377) HttpError: unauthorized access
      2025-10-19 15:28:03.827  - warn: wifilight.0 (205180) [192.168.178.114] onError: EHOSTUNREACH connect EHOSTUNREACH 192.168.178.114:5577 - reconnecting in 5 sec...
      2025-10-19 15:28:04.269  - info: host.raspberrypi instance system.adapter.sonoff.0 in version "3.2.1" started with pid 208871
      2025-10-19 15:28:05.976  - info: ical.0 (208852) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.20.0, js-controller: 7.0.7
      2025-10-19 15:28:06.890  - info: ical.0 (208852) processing URL: Urlaub https://calendar.google.com/calendar/ical/2m76ic2mhracagf6iuppk4dsi0%40group.calendar.google.com/private-735b76e8545484f85111069e865cb9a7/basic.ics
      iob diag has finished.
        Thomas Braun Most Active @Torsten Lehmann last edited by Thomas Braun
        @torsten-lehmann
        Für den rpi2-Adapter musst du wohl derzeitig eine für RaspberryOS 13 angepasste Version von hier installieren:
        https://github.com/Grothesk242/ioBroker.rpi2
        Vorsichtiger beim Neustart sein:
        IMMER sauber herunterfahren oder neustarten, NIE einfach den Stecker ziehen.
        Verwende bei Zigbee den Link 'by-id' und nicht /dev/ttyACM0 als Gerätedatei. Und installier da die aktuelle Version.
        iob update
        iob upgrade all
        sagt?
        Torsten Lehmann 1 Reply Last reply Reply Quote 0
        • Asgothian
          Asgothian Developer @Torsten Lehmann last edited by
          @torsten-lehmann sagte in RPI-Monitor und GPIO rpi2 v2.3.1:
          Zigbee update macht ebenfalls Problem.
          • Du hast den Warnhinweis beim update gelesen und verstanden ?
          • Du hast die Anleitung zum Zigbee Adapter gelesen ?
          Dann solltest du keine Probleme mit dem update des Zigbee Adapters bekommen.
          Ansonsten - Lesen !
          A.
          Torsten Lehmann 1 Reply Last reply Reply Quote 1
          • Torsten Lehmann
            Torsten Lehmann @Thomas Braun last edited by Homoran
            @torsten-lehmann
            iob update
            iob upgrade all
            sagt?
            Befehl ausführen
            ERROR: Process exited with code 25
            Weniger Protokolle
            Detailliert
            $ iobroker url https://github.com/Grothesk242/ioBroker.rpi2.git --host raspberrypi --debug
            install Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d
            NPM version: 10.9.2
            Installing Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d... (System call)
            npm warn skipping integrity check for git dependency ssh://git@github.com/Grothesk242/ioBroker.rpi2.git
            npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
            npm warn deprecated gauge@2.7.4: This package is no longer supported.
            > iobroker.rpi2@2.4.0 preinstall> sudo apt-get install -y libgpiod-dev || exit 0
            Building dependency tree...
            Reading state information...
            libgpiod-dev is already the newest version (2.2.1-2).The following package was automatically installed and is no longer required:
            libyuv0Use 'sudo apt autoremove' to remove it.
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            > @stoprocent/noble@1.19.1 install> node-gyp-build
            gyp info it worked if it ends with ok
            gyp info using node-gyp@8.4.1gyp info using node@23.11.1 | linux | arm64
            (node:30278) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
            gyp info spawn /usr/bin/python3gyp info spawn args [
            gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/@stoprocent/noble/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',
            gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@stoprocent/noble',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
            Traceback (most recent call last):
            File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input
            File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
            gyp ERR! configure error
            gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
            gyp ERR! stack at ChildProcess.emit (node:events:507:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)gyp ERR! System Linux 6.12.47+rpt-rpi-v8gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
            > mdns@2.7.2 install
            > node-gyp rebuild
            (node:30295) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/mdns/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/mdns',gyp info spawn args '-Dnode_engine=v8',
            File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersion
            gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mdnsgyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
            > node-dht-sensor@0.4.5 install
            > node-gyp configure
            (node:30312) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
            gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:507:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)gyp ERR! System Linux 6.12.47+rpt-rpi-v8gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
            > opengpio@2.0.2 install> node-gyp rebuild
            (node:30328) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
            gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
            gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
            npm error code 1
            npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-19T18_27_24_914Z-debug-0.log
            npm warn skipping integrity check for git dependency ssh://git@github.com/Grothesk242/ioBroker.rpi2.gitnpm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supportednpm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@8.4.1gyp info using node@23.11.1 | linux | arm64(node:30278) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/@stoprocent/noble/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@stoprocent/noble',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:507:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)gyp ERR! System Linux 6.12.47+rpt-rpi-v8gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblegyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok gyp info it worked if it ends with okgyp info using node-gyp@8.4.1gyp info using node@23.11.1 | linux | arm64(node:30295) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/mdns/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/mdns',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:507:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)gyp ERR! System Linux 6.12.47+rpt-rpi-v8gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mdnsgyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok gyp info it worked if it ends with okgyp info using node-gyp@8.4.1gyp info using node@23.11.1 | linux | arm64(node:30312) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:507:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)gyp ERR! System Linux 6.12.47+rpt-rpi-v8gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensorgyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok gyp info it worked if it ends with okgyp info using node-gyp@8.4.1gyp info using node@23.11.1 | linux | arm64(node:30328) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/23.11.1/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/23.11.1',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/23.11.1/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:507:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)gyp ERR! System Linux 6.12.47+rpt-rpi-v8gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v23.11.1gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-19T18_27_24_914Z-debug-0.log
            host.raspberrypi Cannot install Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d: 1
            • Torsten Lehmann
              Torsten Lehmann @Asgothian last edited by
              @asgothian ich muss wohl noch viel lernen. ich hab die Warnhinweis beim update gelesen und nicht verstanden . Die Anleitung zum Zigbee Adapter nicht gelesen
                using node@23.11.1
                Wo haste denn jetzt node@23.11.1 her?
                node -v
                liefert?
                • Torsten Lehmann
                  @thomas-braun curl -sL https://deb.nodesource.com/setup_23.x | sudo -E bash - .hier her. War das ein Fehler?
                  node -v v23.11.1
                    War das ein Fehler?
                    JAAAAAAAAAAAA!
                    Warum tut man sowas?
                    Per
                    iob nodejs-update 22
                    wieder die vorgesehene und empfohlene Version 22 installieren. Die war doch oben schon am Start...
                    Man verwendet a) keine abgekündigten und b) keine ungeraden nodejs-Versionen.
                    Torsten Lehmann 2 Replies Last reply Reply Quote 0
                    • Torsten Lehmann
                      @thomas-braun Danke werde ich 22 installieren,
                      • Torsten Lehmann
                        @thomas-braun neuer Versuch
                        NPM version: 10.9.3
                        npm error code 1
                        npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > node-dht-sensor@0.4.5 install
                        npm error > node-gyp configurenpm errornpm errornpm errornpm error > opengpio@2.0.2 installnpm error > node-gyp rebuild
                        npm errornpm errornpm error make: Entering directory '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error make: Leaving directory '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio/build'npm error npm warn using --force Recommended protections disabled.npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.2.0npm error gyp info using node@22.20.0 | linux | arm64npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"npm error gyp http GET https://nodejs.org/download/release/v22.20.0/node-v22.20.0-headers.tar.gznpm error gyp http 200 https://nodejs.org/download/release/v22.20.0/node-v22.20.0-headers.tar.gznpm error gyp http GET https://nodejs.org/download/release/v22.20.0/SHASUMS256.txtnpm error gyp http 200 https://nodejs.org/download/release/v22.20.0/SHASUMS256.txtnpm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/node-dht-sensor/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/node-dht-sensor',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info ok npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.2.0npm error gyp info using node@22.20.0 | linux | arm64npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error ../cpp/opengpio.cpp:3:10: fatal error: gpiod.hpp: No such file or directorynpm error 3 | #include <gpiod.hpp>npm error | ^~~~~~~~~~~npm error compilation terminated.npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)npm error gyp ERR! System Linux 6.12.47+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpionpm error gyp ERR! node -v v22.20.0npm error gyp ERR! node-gyp -v v11.2.0npm error gyp ERR! not ok npm error npm error code 1npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpionpm error npm error command failednpm error npm error command sh -c node-gyp rebuildnpm error npm noticenpm error npm notice New major version of npm available! 10.9.3 -> 11.6.2npm error npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.6.2npm error npm notice To update run: npm install -g npm@11.6.2npm error npm noticenpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-19T20_12_44_363Z-debug-0.lognpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-19T20_12_38_490Z-debug-0.log
                        npm error code 1npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > node-dht-sensor@0.4.5 installnpm error > node-gyp configurenpm errornpm errornpm errornpm error > opengpio@2.0.2 installnpm error > node-gyp rebuildnpm errornpm errornpm error make: Entering directory '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error make: Leaving directory '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio/build'npm error npm warn using --force Recommended protections disabled.npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.2.0npm error gyp info using node@22.20.0 | linux | arm64npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"npm error gyp http GET https://nodejs.org/download/release/v22.20.0/node-v22.20.0-headers.tar.gznpm error gyp http 200 https://nodejs.org/download/release/v22.20.0/node-v22.20.0-headers.tar.gznpm error gyp http GET https://nodejs.org/download/release/v22.20.0/SHASUMS256.txtnpm error gyp http 200 https://nodejs.org/download/release/v22.20.0/SHASUMS256.txtnpm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/node-dht-sensor/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/node-dht-sensor',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info ok npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.2.0npm error gyp info using node@22.20.0 | linux | arm64npm error gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpio',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error ../cpp/opengpio.cpp:3:10: fatal error: gpiod.hpp: No such file or directorynpm error 3 | #include <gpiod.hpp>npm error | ^~~~~~~~~~~npm error compilation terminated.npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)npm error gyp ERR! System Linux 6.12.47+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpionpm error gyp ERR! node -v v22.20.0npm error gyp ERR! node-gyp -v v11.2.0npm error gyp ERR! not ok npm error npm error code 1npm error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneLVOGis/node_modules/opengpionpm error npm error command failednpm error npm error command sh -c node-gyp rebuildnpm error npm noticenpm error npm notice New major version of npm available! 10.9.3 -> 11.6.2npm error npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.6.2npm error npm notice To update run: npm install -g npm@11.6.2npm error npm noticenpm error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-19T20_12_44_363Z-debug-0.lognpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-19T20_12_38_490Z-debug-0.log
                          Ist das Paket libgpiod-dev installiert?
                          sudo apt update
                          apt policy libgpiod-dev
                          Siehe auch die Readme zum Adapter:
                          https://github.com/iobroker-community-adapters/ioBroker.rpi2
                          • Torsten Lehmann
                            @thomas-braun Danke für Deine Geduld
                            pi@raspberrypi:~ $ apt policy libgpiod-dev
                            libgpiod-dev:
                              Installed: 2.2.1-2
                              Candidate: 2.2.1-2
                              Version table:
                             *** 2.2.1-2 500
                            MOD-EDIT: Code in code-tags gesetzt
                              @torsten-lehmann
                              Frisch nachinstalliert?
                              Denn da ist die vermisste Datei drin:
                              Edit:
                              Auf meinem Testsystem baut der Adapter auch einwandfrei:
                              echad@chet:~ $ iobroker url https://github.com/Grothesk242/ioBroker.rpi2.git --host chet --debug
                              NPM version: 11.6.2
                              up to date in 2m
                              245 packages are looking for funding
                                run `npm fund` for details
                              upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                              upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                              upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                              upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                              upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                              upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                              upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                              upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                              upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                              upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                              upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                              upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                              upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                              upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                              Updating objects from io-package.json for adapter "rpi2" with version "2.4.0"
                              echad@chet:~ $
                              • Torsten Lehmann
                                @thomas-braun deine NPM version: 11.6.2 meine 10.9.3 kan es daran liegen?
                                  Nein. Das baut auch mit npm 10:
                                  NPM version: 10.9.3
                                  up to date in 3m
                                  echad@chet:~ $
                                  • Torsten Lehmann
                                    @thomas-braun neue SD ohne Backup zurücksetzen.
                                    added 5 packages in 4m
                                    91 packages are looking for funding
                                      @torsten-lehmann
                                      Setz sowas bitte in </> Codetags. Und die ersten Zeilen fehlen.
                                      • Torsten Lehmann
                                        @thomas-braun Guten Morgen nach erfolgreicher Installation rpi2 fehlt jedoch beim iobroker die rpi2 Instanz. Irgendwie mach ich wohl was falsch bei der iobroker Installation.
                                          Nein, wenn Adapter via GitHub installiert werden muss die Instanz manuell hinzugefügt werden.
                                          • Torsten Lehmann
                                            da bin ich überfordert. Entschuldige, Wie mache ich das?
                                            496
