    4. instance system.adapter.roborock.0 terminated due to SIGILL
    • holly200289
      holly200289 @Thomas Braun last edited by
      Hallo Leute,
      ich habe folgende Fehlermeldung bei der v0.6.18
      roborock.0
      Nachricht
      roborock.0
      2025-10-19 17:40:18.652 error Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
      roborock.0
      roborock.0
      2025-10-19 17:40:18.566 error Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:105:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
      roborock.0
      roborock.0
      2025-10-19 17:40:18.559 error Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
      roborock.0
      roborock.0
      2025-10-19 17:40:18.430 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
      roborock.0
      roborock.0
      2025-10-19 17:40:18.420 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
      roborock.0
      roborock.0
      2025-10-19 17:40:14.246 info terminating
      roborock.0
      roborock.0
      2025-10-19 17:40:13.745 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      roborock.0
      2025-10-19 17:40:13.745 info terminating
      roborock.0
      roborock.0
      roborock.0
      2025-10-19 17:40:13.744 info Got terminate signal TERMINATE_YOURSELF
      roborock.0
      holly200289 1 Reply Last reply Reply Quote 0
      • holly200289
        holly200289 @holly200289 last edited by
        @holly200289 said in instance system.adapter.roborock.0 terminated due to SIGILL:
        Hallo Leute,
        roborock.0
        Nachricht
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        Plattform: linux
        RAM: 24.4 GB
        Node.js: v22.20.0
        NPM: 11.6.1
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          Ro75 last edited by
          sicher das es die 0.6.18 ist und nicht die 0.6.19? die 18 geht bei mir. Die Fehler, wie bei dir, kommen in der 19.
          Ro75.
          holly200289 2 Replies Last reply Reply Quote 0
          • holly200289
            holly200289 @Ro75 last edited by
            @ro75
            Ja, ich habe das jetzt nochmal kontrolliert,
            es ist die version 0.6.18 auch verbindet sich der
            Adapter nicht mehr.
            • Ro75
              Ro75 @holly200289 last edited by
              @holly200289 sagte in instance system.adapter.roborock.0 terminated due to SIGILL:
              Was ist damit?
              Ro75.
              • holly200289
                @ro75
                Die Login Daten sind korrekt
                • holly200289
                  @holly200289
                  Die App von Roborock schreibt wenn ich mich anmelden möchte,
                  zu viele Anfragen.
                  copystring 1 Reply Last reply Reply Quote 0
                  • copystring
                    copystring @holly200289 last edited by
                    @holly200289 dann wurde dein Zugang vorübergehend gesperrt. Versuchs morgen, also in 24 Stunden, nochmal und starte den Router neu, damit du eine neue IP bekommst.
                    • holly200289
                      holly200289 @copystring last edited by
                      @copystring
                      Okay vielen Dank, ich melde mich morgen nochmal
                      • holly200289
                        @holly200289
                        ich habe jetzt eine neue Email Adresse benutzt, und meinen Router neu gestartet, leider wieder kein Erfolg.
                        roborock.0
                        2025-10-19 22:12:09.630 info MQTT initialized
                        roborock.0
                        2025-10-19 22:12:09.267 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
                        roborock.0
                        2025-10-19 22:12:09.257 info starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
                        roborock.0
                        2025-10-19 22:11:37.800 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                        roborock.0
                        2025-10-19 22:11:37.800 info terminating
                        roborock.0
                        roborock.0
                        roborock.0
                        2025-10-19 22:11:37.794 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                        roborock.0
                        2025-10-19 22:11:37.794 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
                        roborock.0
                        roborock.0
                        roborock.0
                        2025-10-19 22:11:37.793 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
                        roborock.0
                        roborock.0
                        2025-10-19 22:11:34.633 info MQTT initialized
                        roborock.0
                        roborock.0
                        2025-10-19 22:11:34.348 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
                        roborock.0
                        roborock.0
                        2025-10-19 22:11:34.337 info starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
                        roborock.0
                        • holly200289
                          @copystring
                          Aktuell funktioniert es leider immer noch nicht, ich bekomme nur Fehlermeldungen
                          • holly200289
                            @ro75 said in instance system.adapter.roborock.0 terminated due to SIGILL:
                            Ro75.
                            ich habe jetzt so einiges versucht, leider ohne Erfolg
                            das ist die Fehlermeldung
                            roborock.0
                            2025-10-20 21:14:46.191 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                            roborock.0
                            2025-10-20 21:14:46.190 info terminating
                            roborock.0
                            2025-10-20 21:14:46.184 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                            roborock.0
                            2025-10-20 21:14:46.184 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
                            roborock.0
                            2025-10-20 21:14:46.183 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
                            roborock.0
                            2025-10-20 21:14:42.539 info MQTT initialized
                            roborock.0
                            2025-10-20 21:14:42.247 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            roborock.0
                            2025-10-20 21:14:42.237 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
                            roborock.0
                            2025-10-20 21:14:10.889 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                            roborock.0
                            2025-10-20 21:14:10.888 info terminating
                            roborock.0
                            2025-10-20 21:14:10.882 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                            roborock.0
                            2025-10-20 21:14:10.882 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
                            roborock.0
                            2025-10-20 21:14:10.881 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
                            roborock.0
                            2025-10-20 21:14:07.799 info MQTT initialized
                            roborock.0
                            2025-10-20 21:14:07.463 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
                            roborock.0
                            2025-10-20 21:14:07.453 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
                            roborock.0
                            2025-10-20 21:13:36.070 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                            roborock.0
                            2025-10-20 21:13:36.070 info terminating
                            • holly200289
                              holly200289 @mcm1957 last edited by
                              @mcm1957
                              Gibt es schon Lösungen für das Problem ?
                              • copystring
                                @holly200289 mcm1957 ist nicht der Entwickler. Bei Problemen immer ein GitHub issue auf machen.
                                holly200289 2 Replies Last reply Reply Quote 1
                                • holly200289
                                  @copystring
                                  ich habe ein neues GitHub issue aufgemacht
                                  • holly200289
                                    @copystring
                                    Guten Morgen,
                                    ich bekomme jetzt den Adapter gar nicht mehr zum laufen, immer wieder die gleiche Fehlermeldung,
                                    hab nur ich das Problem ?
                                    Egal bei welcher Version
                                    roborock.0
                                    2025-10-23 05:12:59.183 info terminating
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:58.682 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:58.681 info terminating
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:58.679 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                                    roborock.0
                                    2025-10-23 05:12:58.679 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at UDP.onMessage [as onmessage] (node:dgram:990:8)
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:58.678 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:57.776 info MQTT initialized
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:57.054 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:57.048 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.21.0, js-controller: 7.0.7
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:56.688 info Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:52.925 info terminating
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:52.424 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    roborock.0
                                    2025-10-23 05:12:52.424 info terminating
                                    roborock.0
                                    roborock.0
                                    roborock.0
                                    2025-10-23 05:12:52.422 info Got terminate signal TERMINATE_YOURSELF
                                    roborock.0
                                    677
